# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 19:00:28 Mon, 30 Sep 2019 06:01:24 GMT Sebastian Huber [d4880509] * cpukit/libfs/src/dosfs/msdos_format.c (modified) dosfs: Fix format with media block sizes > 512 Tue, 01 Oct 2019 06:05:21 GMT Sebastian Huber [de6348a] * cpukit/include/machine/_kernel_time.h (modified) _kernel_time.h: Compatibility to future Newlib Tue, 10 Sep 2019 17:53:31 GMT Joel Sherrill [8798372] * cpukit/posix/src/pthreadcreate.c (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxsignal01/init.c (modified) * testsuites/psxtests/psxsignal02/init.c (modified) * testsuites/psxtests/psxsignal03/init.c (modified) * testsuites/psxtests/psxsignal07/main.c (added) * testsuites/psxtests/psxsignal07/psxsignal07.doc (added) * testsuites/psxtests/psxsignal07/psxsignal07.scn (added) * testsuites/psxtests/psxsignal07/rtems_config.c (added) * testsuites/psxtests/psxsignal08/main.c (added) * testsuites/psxtests/psxsignal08/psxsignal08.doc (added) * testsuites/psxtests/psxsignal08/psxsignal08.scn (added) * testsuites/psxtests/psxsignal08/rtems_config.c (added) Correct initial POSIX signals mask + Modify POSIX thread ... Fri, 20 Sep 2019 07:16:17 GMT Sebastian Huber [33ed412] * bsps/shared/irq/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) rtems: Add rtems_interrupt_server_entry_move() The use case for ... Tue, 10 Sep 2019 07:21:11 GMT Sebastian Huber [c1a1f2c] * cpukit/include/rtems/version.h (modified) * testsuites/sptests/spversion01/init.c (modified) Add rtems_version_control_key_is_valid() Fri, 06 Sep 2019 12:31:32 GMT Sebastian Huber [eaa415b2] * cpukit/include/rtems/version.h (modified) * cpukit/sapi/src/version.c (modified) rtems: Make rtems_version_control_key() safer Return the empty ... Tue, 03 Sep 2019 08:11:21 GMT Sebastian Huber [0b3dcb3] * cpukit/score/cpu/arm/armv4-exception-default.S (modified) arm: Fix default exception handler Keep the stack pointer properly ... Mon, 02 Sep 2019 05:47:15 GMT Sebastian Huber [e41e9961] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) record: Add system events Update #3665. Fri, 30 Aug 2019 11:22:54 GMT Sebastian Huber [1c72ad7] * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-util.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add system events Add system events for memory ... Fri, 30 Aug 2019 07:21:22 GMT Sebastian Huber [8ace7ead] * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add system events Add system events to identify the target ... Fri, 30 Aug 2019 06:40:14 GMT Sebastian Huber [1e18f64] * cpukit/include/rtems/sysinit.h (modified) record: Initialize records earlier The _Record_Initialize() ... Fri, 30 Aug 2019 06:09:46 GMT Sebastian Huber [11f196d6] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (modified) * cpukit/libtrace/record/record-sysinit.c (modified) record: Simplify configuration Update #3665. Thu, 29 Aug 2019 14:50:12 GMT Sebastian Huber [d78082c] * cpukit/include/rtems/record.h (modified) * cpukit/libtrace/record/record.c (modified) record: Introduce _Record_Drain() This allows its use in crash dump ... Mon, 26 Aug 2019 12:58:54 GMT Sebastian Huber [58bd67b] * cpukit/Makefile.am (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-util.c (added) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) record: Add more system events Reduce the system dependencies to ... Wed, 28 Aug 2019 12:59:16 GMT Sebastian Huber [807ea67] * cpukit/include/rtems/score/basedefs.h (modified) * testsuites/sptests/spmisc01/init.c (modified) score: Add RTEMS_RETURN_ADDRESS() Wed, 28 Aug 2019 12:28:14 GMT Sebastian Huber [956a2ef] * cpukit/include/rtems/record.h (modified) * testsuites/libtests/record01/init.c (modified) record: Add variants for critical sections Update #3665. Wed, 28 Aug 2019 12:45:24 GMT Sebastian Huber [3eb8d783] * cpukit/headers.am (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recordserver.h (added) * cpukit/libtrace/record/record-server.c (modified) * testsuites/libtests/record01/init.c (modified) record: Introduce This helps to get rid of ... Tue, 27 Aug 2019 13:39:43 GMT Sebastian Huber [a2684c2b] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-sysinit.c (modified) * testsuites/libtests/record01/init.c (modified) record: Use BSS section instead of per-CPU data The .rtemsrwset ... Tue, 27 Aug 2019 06:30:43 GMT Sebastian Huber [e273e7a9] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Add data size to client This is necessary to get the thread ... Mon, 26 Aug 2019 20:02:32 GMT Sebastian Huber [a8af7a14] * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-userext.c (modified) record: Fix thread names on 64-bit targets Also fixes the thread ... Sun, 25 Aug 2019 10:14:11 GMT Sebastian Huber [dfdc3fa] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Improve overflow handling Signal the accumulated item ... Sun, 25 Aug 2019 10:04:49 GMT Sebastian Huber [45d4ea31] * cpukit/libtrace/record/record-server.c (modified) record: Fix off by one error Fri, 09 Aug 2019 05:59:46 GMT Sebastian Huber [62fc148] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Reduce RX FIFO trigger level This may help to avoid ... Fri, 09 Aug 2019 05:59:13 GMT Sebastian Huber [aa7b76e] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Set TLS to zero Ensures that the FCR values are used. Fri, 09 Aug 2019 05:54:40 GMT Sebastian Huber [2a2a0fdd] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Do FIFO reset separately Fri, 09 Aug 2019 05:46:08 GMT Sebastian Huber [73826b4] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Enable enhanced func early Fri, 09 Aug 2019 05:45:06 GMT Sebastian Huber [da1b471] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Write to right register Sat, 17 Aug 2019 16:58:53 GMT Sebastian Huber [4a9a58e] * cpukit/include/rtems/recordclient.h (modified) record: Add rtems_record_client_set_handler() Sat, 17 Aug 2019 12:49:42 GMT Sebastian Huber [c91f6f5] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) * testsuites/libtests/record02/init.c (modified) record: Pass bintime to client handlers This is a minor optimization. Sat, 17 Aug 2019 12:34:59 GMT Sebastian Huber [1733102] * cpukit/libtrace/record/record-client.c (modified) record: Simplify client visit() Sat, 17 Aug 2019 12:28:41 GMT Sebastian Huber [5c37f03f] * cpukit/libtrace/record/record-client.c (modified) record: Remove superfluous cast Sat, 17 Aug 2019 11:25:57 GMT Sebastian Huber [2ef2c14] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Increase client robustness Do nothing after errors. Fri, 16 Aug 2019 16:40:55 GMT Sebastian Huber [52c8ac7b] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) record: Improve overflow handling In case of a ring buffer ... Fri, 16 Aug 2019 05:40:05 GMT Sebastian Huber [b2c060a5] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Detect also large overflows Fri, 16 Aug 2019 18:12:03 GMT Sebastian Huber [d3c4d48] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Simplify rtems_record_client_context Sun, 11 Aug 2019 22:56:37 GMT Chris Johns [df256505] * cpukit/libdebugger/rtems-debugger-arm.c (modified) libdebugger/arm: Support ROM tables. - Parse the ROM taables if ... Sun, 04 Aug 2019 23:58:07 GMT Chris Johns [9cb19ded] * bsps/arm/raspberrypi/start/linkcmds.in (moved) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) libdl/debugger: Fix the broken list delete when unloading an object ... Tue, 06 Aug 2019 05:47:57 GMT Sebastian Huber [cc91fae] * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * testsuites/libtests/record01/init.c (modified) record: Change thread name encoding This scheme is easier to decode. Tue, 30 Jul 2019 10:43:15 GMT Chris Johns [8c66acc8] * cpukit/libdl/rtl-mdreloc-arm.c (modified) libdl/arm: Add support for ARM trampolines Closes #3776 Tue, 25 Jun 2019 11:07:40 GMT Chris Johns [cb1e8497] * cpukit/Makefile.am (modified) * cpukit/include/rtems/debugger/rtems-debugger-bsp.h (added) * cpukit/libdebugger/rtems-debugger-arm.c (modified) * cpukit/libdebugger/rtems-debugger-bsp.c (added) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) libdebugger: ARM fixes for Cortex-A8 and ARM mode. - Fix destorying ... Fri, 26 Jul 2019 14:36:10 GMT Sebastian Huber [036717ed] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * testsuites/libtests/record01/init.c (modified) record: Add support for thread names Tue, 30 Jul 2019 04:24:00 GMT Sebastian Huber [5ee70c5] * bsps/shared/start/bspfatal-default.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/libmisc/stackchk/check.c (modified) Add and use THREAD_DEFAULT_MAXIMUM_NAME_SIZE Sat, 27 Jul 2019 23:12:53 GMT Chris Johns [5a678de] * cpukit/libdl/rtl-mdreloc-arm.c (modified) * testsuites/libtests/dl01/dl-load.c (modified) libdl/arm: Fix ARM mode trampoline parsing of relocs - No need to ... Wed, 03 Jul 2019 02:18:18 GMT Chris Johns [c4d89de] * cpukit/include/rtems/score/interr.h (modified) score/interr: Fix comments. Tue, 02 Jul 2019 08:44:18 GMT Chris Johns [5cbee18] * cpukit/libmisc/dummy/default-configuration.c (modified) misc/rtemsdefaultconfig: Add bdbuf so libbsd can be used with configure. Fri, 28 Jun 2019 06:30:11 GMT Sebastian Huber [5803f37] * cpukit/include/rtems/capture.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) score: Add and use _Thread_Get_unmapped_priority(). Add and use ... Tue, 25 Jun 2019 08:43:55 GMT Chris Johns [c43071f] * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Return the current handler from arm_cp15_set_exception_handler ... Wed, 26 Jun 2019 05:57:50 GMT Sebastian Huber [54ac945] * cpukit/libdebugger/rtems-debugger-threads.c (modified) libdebugger: Unmap thread priorities Wed, 22 May 2019 14:29:33 GMT Joel Sherrill [373cd1c5] * cpukit/include/rtems/confdefs.h (modified) rtems/confdefs.h: Fix typo Fri, 14 Jun 2019 05:41:36 GMT Sebastian Huber [2be6ab7f] * cpukit/dev/serial/sc16is752.c (modified) * cpukit/include/dev/serial/sc16is752.h (modified) dev/sc16is752: Add set/get EFCR IO controls Fri, 14 Jun 2019 05:35:21 GMT Sebastian Huber [6ff1da40] * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/include/dev/serial/sc16is752.h (modified) dev/sc16is752: Add RS485 mode variants Wed, 12 Jun 2019 05:22:38 GMT zhengxiaojun [38b29232] * cpukit/libdl/rtl-rap.c (modified) libdl/rap: fix RAP file load error. Thu, 06 Jun 2019 12:57:54 GMT Maksim E. Kozlov [2a720f4] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Fix mistakenly cleared PSR[EF] bit. The superfluously ... Wed, 05 Jun 2019 19:22:36 GMT Maksim E. Kozlov [a3818705] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Fix missed restoring of PSR in syscall_lazy_fp_switch It is ... Thu, 06 Jun 2019 05:53:09 GMT Sebastian Huber [7d7cbf3c] * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Improve _CPU_Context_validate() Use the FPU and check that ... Wed, 22 May 2019 05:51:14 GMT Sebastian Huber [10251b3] * cpukit/include/rtems/score/objectdata.h (modified) score: Compact objects class indices Tue, 14 May 2019 00:34:32 GMT Chris Johns [327e45da] * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) libdl: Sort object file symbols and use a binary search to find - ... Mon, 20 May 2019 07:15:36 GMT Sebastian Huber [5fa893e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpunicastaction.c (added) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Add _SMP_Unicast_action() Mon, 20 May 2019 07:06:48 GMT Sebastian Huber [41cddcc] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _Per_CPU_Wait_for_job() Thu, 02 May 2019 03:29:27 GMT Sebastian Huber [9b8e85e2] * cpukit/include/rtems/score/smpimpl.h (modified) score: Remove superfluous include Sun, 28 Apr 2019 12:31:10 GMT Sebastian Huber [577293f0] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Add _SMP_Synchronize() Sun, 28 Apr 2019 12:15:45 GMT Sebastian Huber [bf867c55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Remove unused SMP_MESSAGE_TEST All uses were replaced by ... Fri, 19 Apr 2019 09:02:02 GMT Sebastian Huber [c63e8bb] * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Modify _Per_CPU_Perform_jobs() Process only the jobs ... Fri, 19 Apr 2019 09:01:31 GMT Sebastian Huber [85d6e845] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _Per_CPU_Add_job() Thu, 18 Apr 2019 06:38:00 GMT Sebastian Huber [8fa14da0] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Move per-processor job data structures This enables re-use ... Thu, 18 Apr 2019 05:38:13 GMT Sebastian Huber [1a971d8] * bsps/i386/pc386/clock/ckinit.c (modified) * bsps/i386/pc386/start/smp-imps.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) score: Remove SMP_MESSAGE_CLOCK_TICK Use _SMP_Multicast_action() ... Thu, 18 Apr 2019 05:08:32 GMT Sebastian Huber [3b2481f] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Simplify _SMP_Multicast_action() Move resposibility to ... Sun, 28 Apr 2019 12:29:21 GMT Sebastian Huber [7fdf48a] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _SMP_Othercast_action() Thu, 18 Apr 2019 04:47:01 GMT Sebastian Huber [65870044] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _SMP_Broadcast_action() Thu, 18 Apr 2019 04:31:33 GMT Sebastian Huber [4f06863] * cpukit/score/src/smpmulticastaction.c (modified) score: Use dedicated lock for per-CPU jobs Fri, 17 May 2019 07:21:03 GMT Sebastian Huber [b4f895e] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) posix: Remove unused OBJECTS_POSIX_INTERRUPTS Thu, 18 Apr 2019 04:29:57 GMT Sebastian Huber [327ae9ac] * cpukit/score/src/smpmulticastaction.c (modified) score: Fix per-CPU job done handling Fri, 10 May 2019 12:38:28 GMT Sebastian Huber [cc060f0] * cpukit/libmisc/shell/shell.c (modified) shell: Avoid rtems_error() Do not use the rtems_error() function ... Tue, 14 May 2019 00:15:51 GMT Chris Johns [d0f627d] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix size bug in loading symbols. This was introduced in ... Mon, 13 May 2019 00:46:45 GMT Chris Johns [74883be5] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix loading symbol that reference unknown sections. - Make ... Mon, 13 May 2019 22:39:55 GMT Chris Johns [0b698ba5] * cpukit/include/rtems/score/rbtree.h (modified) doxygen: score: Fix block comment end marker. Thu, 18 Apr 2019 08:19:23 GMT Andreas Dachsberger [f49618d] * cpukit/include/rtems/score/percpudata.h (modified) doxygen: score: adjust doc in percpudata.h to doxygen guidelines ... Thu, 18 Apr 2019 08:13:25 GMT Andreas Dachsberger [3238c162] * cpukit/include/rtems/score/smp.h (modified) doxygen: score: adjust doc in smp.h to doxygen guidelines Update #3706. Thu, 18 Apr 2019 07:54:49 GMT Andreas Dachsberger [1bd608b] * cpukit/include/rtems/score/onceimpl.h (modified) doxygen: score: adjust doc in onceimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 07:43:41 GMT Andreas Dachsberger [2463c10] * cpukit/include/rtems/score/muteximpl.h (modified) doxygen: score: adjust doc in muteximpl.h to doxygen guidelines ... Thu, 18 Apr 2019 07:38:47 GMT Andreas Dachsberger [7b90bb5] * cpukit/include/rtems/score/wkspace.h (modified) doxygen: score: adjust doc in wkspace.h to doxygen guidelines ... Thu, 18 Apr 2019 07:31:27 GMT Andreas Dachsberger [904c2312] * cpukit/include/rtems/score/watchdogticks.h (modified) doxygen: score: adjust doc in watchdogticks.h to doxygen guidelines ... Thu, 18 Apr 2019 07:30:32 GMT Andreas Dachsberger [c53ec8c4] * cpukit/include/rtems/score/watchdogimpl.h (modified) doxygen: score: adjust doc in watchdogimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:58:48 GMT Andreas Dachsberger [eb84cc3f] * cpukit/include/rtems/score/watchdog.h (modified) doxygen: score: adjust doc in watchdog.h to doxygen guidelines ... Thu, 18 Apr 2019 06:57:32 GMT Andreas Dachsberger [7d2cc98] * cpukit/include/rtems/score/userextimpl.h (modified) doxygen: score: adjust doc in userextimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:37:02 GMT Andreas Dachsberger [5791a3c] * cpukit/include/rtems/score/todimpl.h (modified) doxygen: score: adjust doc in todimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:28:21 GMT Andreas Dachsberger [5c91b54b] * cpukit/include/rtems/score/tls.h (modified) doxygen: score: adjust doc in tls.h to doxygen guidelines Update #3706. Thu, 18 Apr 2019 06:12:07 GMT Andreas Dachsberger [4a693e7] * cpukit/include/rtems/score/timestampimpl.h (modified) doxygen: score: adjust doc in timestampimpl.h to doxygen guidelines ... Wed, 17 Apr 2019 15:51:55 GMT Andreas Dachsberger [1b5ba76] * cpukit/include/rtems/score/timestamp.h (modified) doxygen: score: adjust doc in timestamp.h to doxygen guidelines ... Wed, 17 Apr 2019 15:50:38 GMT Andreas Dachsberger [bded63fc] * cpukit/include/rtems/score/timespec.h (modified) doxygen: score: adjust doc in timespec.h to doxygen guidelines ... Wed, 17 Apr 2019 15:42:41 GMT Andreas Dachsberger [3e98049] * cpukit/include/rtems/score/timecounterimpl.h (modified) doxygen: score: adjust doc in timecounterimpl.h to doxygen guidelines ... Wed, 17 Apr 2019 15:40:14 GMT Andreas Dachsberger [843879d0] * cpukit/include/rtems/score/timecounter.h (modified) doxygen: score: adjust doc in timecounter.h to doxygen guidelines ... Wed, 17 Apr 2019 15:35:43 GMT Andreas Dachsberger [b6bbe83] * cpukit/include/rtems/score/threadqimpl.h (modified) doxygen: score: adjust doc in threadqimpl.h to doxygen guidelines ... Tue, 16 Apr 2019 10:52:26 GMT Andreas Dachsberger [f1507fb] * cpukit/include/rtems/score/threadq.h (modified) doxygen: score: adjust doc in threadq.h to doxygen guidelines ... Tue, 16 Apr 2019 10:50:08 GMT Andreas Dachsberger [8f89dc62] * cpukit/include/rtems/score/threadmp.h (modified) doxygen: score: adjust doc in threadmp.h to doxygen guidelines ... Tue, 16 Apr 2019 10:40:38 GMT Andreas Dachsberger [3657cde] * cpukit/include/rtems/score/threadimpl.h (modified) doxygen: score: adjust doc in threadimpl.h to doxygen guidelines ... Tue, 16 Apr 2019 06:42:21 GMT Andreas Dachsberger [5bb6ac9] * cpukit/include/rtems/score/thread.h (modified) doxygen: score: adjust doc in thread.h to doxygen guidelines Update ... Tue, 16 Apr 2019 06:37:21 GMT Andreas Dachsberger [7d93c447] * cpukit/include/rtems/score/threaddispatch.h (modified) doxygen: score: adjust doc in threaddispatch.h to doxygen guidelines ... Tue, 16 Apr 2019 06:16:06 GMT Andreas Dachsberger [6af85ee6] * cpukit/include/rtems/score/sysstate.h (modified) doxygen: score: adjust doc in sysstate.h to doxygen guidelines ... Tue, 16 Apr 2019 06:07:09 GMT Andreas Dachsberger [5ba93a5] * cpukit/include/rtems/score/statesimpl.h (modified) doxygen: score: adjust doc in statesimpl.h to doxygen guidelines ...
