# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 16:43:22 Tue, 19 Jan 2010 01:56:28 GMT Joel Sherrill [d22cd4a] * cpukit/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2010-01-18 Joel Sherrill * ... Tue, 19 Jan 2010 01:55:28 GMT Joel Sherrill [ad7824bc] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2010-01-18 Joel Sherrill ... Mon, 18 Jan 2010 23:39:31 GMT Joel Sherrill [9ba0e55] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) 2010-01-18 Joel Sherrill ... Mon, 18 Jan 2010 23:04:09 GMT Joel Sherrill [2bac9489] * cpukit/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2010-01-18 Joel Sherrill ... Mon, 18 Jan 2010 18:24:53 GMT Joel Sherrill [8c29e98] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) 2010-01-18 Joel Sherrill * ... Mon, 18 Jan 2010 18:20:28 GMT Joel Sherrill [abf9ea0] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) 2010-01-18 Joel Sherrill * ... Sun, 17 Jan 2010 18:50:11 GMT Ralf Corsepius [04453b7] * cpukit/zlib/examples/gun.c (added) This commit was generated by cvs2svn to compensate for changes in ... Sun, 17 Jan 2010 18:50:11 GMT Ralf Corsepius [ef15ee0] * cpukit/zlib/examples/gun.c (added) Import from zlib-1.2.4 Tue, 12 Jan 2010 15:03:22 GMT Thomas Doerfler [39c8fdb] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-ethernet-config.h (added) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bspopts.h.in (modified) * c/src/lib/libbsp/arm/lpc32xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-ethernet-config.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (added) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/Makefile.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/arm/shared/arm920/mmu.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (added) * c/src/lib/libcpu/arm/shared/include/cache.h (added) * c/src/lib/libcpu/arm/shared/include/cache_.h (added) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (added) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) add support for lpc32xx Mon, 28 Dec 2009 16:36:08 GMT Joel Sherrill [44be50c] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) * cpukit/libfs/src/pipe/pipe.c (modified) 2009-12-28 Shrikant Gaikwad * ... Mon, 21 Dec 2009 15:13:24 GMT Joel Sherrill [b45ba525] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-12-21 Joel Sherrill * ... Mon, 21 Dec 2009 06:06:54 GMT Ralf Corsepius [ced3e37] * cpukit/zlib/nintendods/Makefile (added) * cpukit/zlib/nintendods/README (added) Import from zlib-1.2.4 Mon, 21 Dec 2009 06:06:54 GMT Ralf Corsepius [db15ab3] * cpukit/zlib/nintendods/Makefile (added) * cpukit/zlib/nintendods/README (added) This commit was generated by cvs2svn to compensate for changes in ... Fri, 18 Dec 2009 20:18:30 GMT Joel Sherrill [5b91459] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/login_prompt.c (modified) 2009-12-18 Joel Sherrill * ... Fri, 18 Dec 2009 15:59:30 GMT Thomas Doerfler [1e0a5512] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) Update for block device API change Thu, 17 Dec 2009 20:27:28 GMT Joel Sherrill [c5fd2cb6] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) 2009-12-17 Joel Sherrill * ... Thu, 17 Dec 2009 20:26:09 GMT Joel Sherrill [27643e03] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) 2009-12-17 Joel Sherrill * ... Thu, 17 Dec 2009 19:41:20 GMT Joel Sherrill [72b5f2e4] * cpukit/ChangeLog (modified) * cpukit/telnetd/telnetd.c (modified) 2009-12-17 Joel Sherrill * ... Tue, 15 Dec 2009 18:26:42 GMT Glenn Humphrey [d3b72ca3] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) 2009-12-15 Glenn Humphrey ... Tue, 15 Dec 2009 15:14:12 GMT Thomas Doerfler [9db18dd] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) add support for ARM11, reimplement nested interrupts Fri, 11 Dec 2009 12:53:48 GMT Ralf Corsepius [4045c26e] * cpukit/ChangeLog (modified) * cpukit/include/rtems/pci.h (modified) 2009-12-11 Ralf Corsépius ... Thu, 10 Dec 2009 22:20:11 GMT Joel Sherrill [dc09e380] * cpukit/ChangeLog (modified) * cpukit/posix/src/timersettime.c (modified) 2009-12-10 Joel Sherrill ... Thu, 10 Dec 2009 20:23:22 GMT Joel Sherrill [ba3e987e] * cpukit/ChangeLog (modified) * cpukit/rtems/src/ratemonperiod.c (modified) 2009-12-10 Joel Sherrill ... Thu, 10 Dec 2009 18:05:54 GMT Ralf Corsepius [77f7498] * cpukit/ChangeLog (modified) * cpukit/telnetd/pty.c (modified) 2009-12-10 Ralf Corsépius * ... Thu, 10 Dec 2009 14:10:57 GMT Ralf Corsepius [b2cc165] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) 2009-12-10 Ralf Corsépius * ... Thu, 10 Dec 2009 07:18:18 GMT Ralf Corsepius [c9ece2e] * cpukit/ChangeLog (modified) 2009-12-10 Ralf Corsépius * ... Thu, 10 Dec 2009 07:18:03 GMT Ralf Corsepius [5718bc2] * cpukit/posix/Makefile.am (modified) Unconditionally build src/sigprocmask.c. Thu, 10 Dec 2009 07:17:48 GMT Ralf Corsepius [b68e2b9a] * cpukit/posix/src/sigprocmask.c (modified) Provide stub if RTEMS_POSIX_API is disabled. Thu, 10 Dec 2009 03:14:16 GMT Ralf Corsepius [b9636c24] * cpukit/mghttpd/mongoose.h (modified) Whitespace removal. Tue, 08 Dec 2009 23:05:30 GMT Glenn Humphrey [eb37f9d] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) 2009-12-08 Glenn Humphrey ... Mon, 07 Dec 2009 17:27:46 GMT Joel Sherrill [2eb59419] * cpukit/ChangeLog (modified) * cpukit/score/src/objectsetname.c (modified) 2009-12-07 Cindy Cicalese PR ... Sun, 06 Dec 2009 08:16:57 GMT Ralf Corsepius [82292dc5] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/uio.h (modified) 2009-12-06 Ralf Corsépius * ... Fri, 04 Dec 2009 16:09:05 GMT Ralf Corsepius [ee75aad] * cpukit/ChangeLog (modified) * cpukit/posix/Makefile.am (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 15:48:05 GMT Ralf Corsepius [c2488e3] * cpukit/ChangeLog (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 15:47:57 GMT Ralf Corsepius [9a94e081] * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/sigprocmask.c (modified) Remove unnecessary includes. Fri, 04 Dec 2009 15:32:08 GMT Ralf Corsepius [7ad405c] * cpukit/posix/preinstall.am (modified) Regenerate. Fri, 04 Dec 2009 15:31:02 GMT Ralf Corsepius [e7b9fee] * cpukit/ChangeLog (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 15:30:35 GMT Ralf Corsepius [522f374] * cpukit/posix/Makefile.am (modified) Unconditionally install posix/include/rtems/posix/sigset.h. Fri, 04 Dec 2009 15:30:08 GMT Ralf Corsepius [654e1f3] * cpukit/posix/include/rtems/posix/psignal.h (modified) Reflect having split out posix/include/rtems/posix/sigset.h. Fri, 04 Dec 2009 15:24:21 GMT Ralf Corsepius [a6b8754] * cpukit/ChangeLog (modified) * cpukit/posix/include/rtems/posix/sigset.h (added) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 06:52:56 GMT Ralf Corsepius [2845bd1] * cpukit/ChangeLog (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 06:52:47 GMT Ralf Corsepius [ce98cec] * cpukit/posix/Makefile.am (modified) Unconditionally build src/wait.c src/waitpid.c. Fri, 04 Dec 2009 06:27:08 GMT Ralf Corsepius [eada19a] * cpukit/ChangeLog (modified) * cpukit/posix/Makefile.am (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 06:05:31 GMT Ralf Corsepius [a2c2bbb0] * cpukit/ChangeLog (modified) 2009-12-04 Ralf Corsépius * ... Fri, 04 Dec 2009 06:05:20 GMT Ralf Corsepius [586d96ed] * cpukit/posix/preinstall.am (modified) Regenerate. Fri, 04 Dec 2009 06:05:05 GMT Ralf Corsepius [10f4120] * cpukit/configure.ac (modified) * cpukit/posix/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) Eliminate AM_CONDITIONAL LIBPOSIX. Fri, 04 Dec 2009 05:25:30 GMT Ralf Corsepius [5bb38e15] * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/h8300.h (modified) * cpukit/score/cpu/m32c/varvects.S (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/cpu_asm.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/m32r.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh_io.h (modified) Whitespace removal. Fri, 04 Dec 2009 04:27:21 GMT Ralf Corsepius [42e243e] * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/idtr.S (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (modified) * cpukit/score/cpu/bfin/irq.c (modified) * cpukit/score/cpu/bfin/rtems/score/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/c4x/cpu_asm.S (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/lm32.h (modified) Whitespace removal. Wed, 02 Dec 2009 18:22:19 GMT Glenn Humphrey [dca9a82] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadtickletimeslice.c (modified) 2009-12-02 Glenn Humphrey ... Wed, 02 Dec 2009 18:15:16 GMT Glenn Humphrey [c6f7e060] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadtickletimeslice.c (modified) 2009-12-02 Glenn Humphrey ... Wed, 02 Dec 2009 11:42:15 GMT Ralf Corsepius [b50e48b] * cpukit/ChangeLog (modified) * cpukit/shttpd/defs.h (modified) 2009-12-02 Ralf Corsépius * ... Wed, 02 Dec 2009 11:00:38 GMT Ralf Corsepius [086442b7] * cpukit/shttpd/cgi.c (modified) * cpukit/shttpd/compat_unix.c (modified) * cpukit/shttpd/compat_win32.c (modified) * cpukit/shttpd/compat_wince.c (modified) * cpukit/shttpd/compat_wince.h (modified) * cpukit/shttpd/config.c (modified) * cpukit/shttpd/log.c (modified) * cpukit/shttpd/md5.c (modified) * cpukit/shttpd/shttpd.c (modified) Whitespace removal. Wed, 02 Dec 2009 11:00:17 GMT Ralf Corsepius [65c3dca4] * cpukit/ChangeLog (modified) * cpukit/shttpd/defs.h (modified) 2009-12-02 Ralf Corsépius * ... Wed, 02 Dec 2009 10:23:33 GMT Ralf Corsepius [46e483b8] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) 2009-12-02 Ralf Corsépius * ... Wed, 02 Dec 2009 09:48:25 GMT Ralf Corsepius [80f7732] * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/telnetd/des.c (modified) * cpukit/telnetd/genpw.c (modified) * cpukit/telnetd/icmds.c (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/pty.h (modified) Whitespace removal. Wed, 02 Dec 2009 01:24:52 GMT Till Straumann [6c28773e] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) 2009-12-01 Till Straumann ... Tue, 01 Dec 2009 22:16:10 GMT Joel Sherrill [2c6a3e7e] * cpukit/ChangeLog (modified) * cpukit/libmisc/stringto/stringto.h (modified) * cpukit/libmisc/stringto/stringto_template.h (modified) 2009-12-01 Joel Sherrill * ... Tue, 01 Dec 2009 14:22:58 GMT Joel Sherrill [1eb97ad] * cpukit/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/kill_noposix.c (added) * cpukit/libcsupport/src/sleep_noposix.c (moved) 2009-12-01 Joel Sherrill * ... Tue, 01 Dec 2009 10:12:55 GMT Thomas Doerfler [0b0485ae] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/vprintk.c (modified) Fixed usage of va_arg(). Mon, 30 Nov 2009 22:13:48 GMT Joel Sherrill [6f70c07] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/login_prompt.c (modified) 2009-11-30 Joel Sherrill * ... Mon, 30 Nov 2009 19:44:57 GMT Joel Sherrill [dbec22db] * cpukit/ChangeLog (modified) * cpukit/score/src/threaddelayended.c (modified) 2009-11-30 Sebastian Huber ... Mon, 30 Nov 2009 16:01:51 GMT Ralf Corsepius [05c1886] * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_arm.h (modified) * cpukit/libnetworking/rtems/bsdnet/_types.h (modified) * cpukit/libnetworking/rtems/bsdnet/servers.h (modified) * cpukit/libnetworking/rtems/dhcp.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.h (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/cbcp.c (modified) * cpukit/pppd/ccp.c (modified) * cpukit/pppd/chap.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/ipcp.h (modified) * cpukit/pppd/lcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/score/cpu/avr/avr/boot.h (modified) * cpukit/score/cpu/avr/avr/common.h (modified) * cpukit/score/cpu/avr/avr/eeprom.h (modified) * cpukit/score/cpu/avr/avr/fuse.h (modified) * cpukit/score/cpu/avr/avr/interrupt.h (modified) * cpukit/score/cpu/avr/avr/io.h (modified) * cpukit/score/cpu/avr/avr/io1200.h (modified) * cpukit/score/cpu/avr/avr/io2313.h (modified) * cpukit/score/cpu/avr/avr/io2323.h (modified) * cpukit/score/cpu/avr/avr/io2333.h (modified) * cpukit/score/cpu/avr/avr/io2343.h (modified) * cpukit/score/cpu/avr/avr/io43u32x.h (modified) * cpukit/score/cpu/avr/avr/io43u35x.h (modified) * cpukit/score/cpu/avr/avr/io4414.h (modified) * cpukit/score/cpu/avr/avr/io4433.h (modified) * cpukit/score/cpu/avr/avr/io4434.h (modified) * cpukit/score/cpu/avr/avr/io76c711.h (modified) * cpukit/score/cpu/avr/avr/io8515.h (modified) * cpukit/score/cpu/avr/avr/io8534.h (modified) * cpukit/score/cpu/avr/avr/io8535.h (modified) * cpukit/score/cpu/avr/avr/io86r401.h (modified) * cpukit/score/cpu/avr/avr/io90pwm1.h (modified) * cpukit/score/cpu/avr/avr/io90pwm216.h (modified) * cpukit/score/cpu/avr/avr/io90pwm2b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm316.h (modified) * cpukit/score/cpu/avr/avr/io90pwm3b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm81.h (modified) * cpukit/score/cpu/avr/avr/io90pwmx.h (modified) * cpukit/score/cpu/avr/avr/io90scr100.h (modified) * cpukit/score/cpu/avr/avr/ioa6289.h (modified) * cpukit/score/cpu/avr/avr/ioat94k.h (modified) * cpukit/score/cpu/avr/avr/iocan128.h (modified) * cpukit/score/cpu/avr/avr/iocan32.h (modified) * cpukit/score/cpu/avr/avr/iocan64.h (modified) * cpukit/score/cpu/avr/avr/iocanxx.h (modified) * cpukit/score/cpu/avr/avr/iom103.h (modified) * cpukit/score/cpu/avr/avr/iom128.h (modified) * cpukit/score/cpu/avr/avr/iom1280.h (modified) * cpukit/score/cpu/avr/avr/iom1281.h (modified) * cpukit/score/cpu/avr/avr/iom128rfa1.h (modified) * cpukit/score/cpu/avr/avr/iom16.h (modified) * cpukit/score/cpu/avr/avr/iom161.h (modified) * cpukit/score/cpu/avr/avr/iom162.h (modified) * cpukit/score/cpu/avr/avr/iom163.h (modified) * cpukit/score/cpu/avr/avr/iom164.h (modified) * cpukit/score/cpu/avr/avr/iom165.h (modified) * cpukit/score/cpu/avr/avr/iom165p.h (modified) * cpukit/score/cpu/avr/avr/iom168.h (modified) * cpukit/score/cpu/avr/avr/iom168p.h (modified) * cpukit/score/cpu/avr/avr/iom169.h (modified) * cpukit/score/cpu/avr/avr/iom169p.h (modified) * cpukit/score/cpu/avr/avr/iom16hva.h (modified) * cpukit/score/cpu/avr/avr/iom16m1.h (modified) * cpukit/score/cpu/avr/avr/iom16u4.h (modified) * cpukit/score/cpu/avr/avr/iom2560.h (modified) * cpukit/score/cpu/avr/avr/iom2561.h (modified) * cpukit/score/cpu/avr/avr/iom32.h (modified) * cpukit/score/cpu/avr/avr/iom323.h (modified) * cpukit/score/cpu/avr/avr/iom324.h (modified) * cpukit/score/cpu/avr/avr/iom325.h (modified) * cpukit/score/cpu/avr/avr/iom3250.h (modified) * cpukit/score/cpu/avr/avr/iom328p.h (modified) * cpukit/score/cpu/avr/avr/iom329.h (modified) * cpukit/score/cpu/avr/avr/iom3290.h (modified) * cpukit/score/cpu/avr/avr/iom32c1.h (modified) * cpukit/score/cpu/avr/avr/iom32hvb.h (modified) * cpukit/score/cpu/avr/avr/iom32m1.h (modified) * cpukit/score/cpu/avr/avr/iom32u4.h (modified) * cpukit/score/cpu/avr/avr/iom32u6.h (modified) * cpukit/score/cpu/avr/avr/iom406.h (modified) * cpukit/score/cpu/avr/avr/iom48p.h (modified) * cpukit/score/cpu/avr/avr/iom64.h (modified) * cpukit/score/cpu/avr/avr/iom640.h (modified) * cpukit/score/cpu/avr/avr/iom644.h (modified) * cpukit/score/cpu/avr/avr/iom645.h (modified) * cpukit/score/cpu/avr/avr/iom6450.h (modified) * cpukit/score/cpu/avr/avr/iom649.h (modified) * cpukit/score/cpu/avr/avr/iom6490.h (modified) * cpukit/score/cpu/avr/avr/iom64c1.h (modified) * cpukit/score/cpu/avr/avr/iom64m1.h (modified) * cpukit/score/cpu/avr/avr/iom8.h (modified) * cpukit/score/cpu/avr/avr/iom8515.h (modified) * cpukit/score/cpu/avr/avr/iom8535.h (modified) * cpukit/score/cpu/avr/avr/iom88.h (modified) * cpukit/score/cpu/avr/avr/iom88p.h (modified) * cpukit/score/cpu/avr/avr/iom8hva.h (modified) * cpukit/score/cpu/avr/avr/iomx8.h (modified) * cpukit/score/cpu/avr/avr/iomxx0_1.h (modified) * cpukit/score/cpu/avr/avr/iomxxhva.h (modified) * cpukit/score/cpu/avr/avr/iotn11.h (modified) * cpukit/score/cpu/avr/avr/iotn12.h (modified) * cpukit/score/cpu/avr/avr/iotn13.h (modified) * cpukit/score/cpu/avr/avr/iotn13a.h (modified) * cpukit/score/cpu/avr/avr/iotn15.h (modified) * cpukit/score/cpu/avr/avr/iotn167.h (modified) * cpukit/score/cpu/avr/avr/iotn22.h (modified) * cpukit/score/cpu/avr/avr/iotn26.h (modified) * cpukit/score/cpu/avr/avr/iotn28.h (modified) * cpukit/score/cpu/avr/avr/iotn43u.h (modified) * cpukit/score/cpu/avr/avr/iotn48.h (modified) * cpukit/score/cpu/avr/avr/iotn87.h (modified) * cpukit/score/cpu/avr/avr/iotn88.h (modified) * cpukit/score/cpu/avr/avr/iotnx4.h (modified) * cpukit/score/cpu/avr/avr/iotnx5.h (modified) * cpukit/score/cpu/avr/avr/iotnx61.h (modified) * cpukit/score/cpu/avr/avr/iousb1286.h (modified) * cpukit/score/cpu/avr/avr/iousb1287.h (modified) * cpukit/score/cpu/avr/avr/iousb162.h (modified) * cpukit/score/cpu/avr/avr/iousb646.h (modified) * cpukit/score/cpu/avr/avr/iousb647.h (modified) * cpukit/score/cpu/avr/avr/iousb82.h (modified) * cpukit/score/cpu/avr/avr/iousbxx2.h (modified) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (modified) * cpukit/score/cpu/avr/avr/iox128a1.h (modified) * cpukit/score/cpu/avr/avr/iox128a3.h (modified) * cpukit/score/cpu/avr/avr/iox16a4.h (modified) * cpukit/score/cpu/avr/avr/iox16d4.h (modified) * cpukit/score/cpu/avr/avr/iox256a3.h (modified) * cpukit/score/cpu/avr/avr/iox256a3b.h (modified) * cpukit/score/cpu/avr/avr/iox32a4.h (modified) * cpukit/score/cpu/avr/avr/iox32d4.h (modified) * cpukit/score/cpu/avr/avr/iox64a1.h (modified) * cpukit/score/cpu/avr/avr/iox64a3.h (modified) * cpukit/score/cpu/avr/avr/lock.h (modified) * cpukit/score/cpu/avr/avr/pgmspace.h (modified) * cpukit/score/cpu/avr/avr/power.h (modified) * cpukit/score/cpu/avr/avr/sfr_defs.h (modified) * cpukit/score/cpu/avr/avr/sleep.h (modified) * cpukit/score/cpu/avr/avr/wdt.h (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/asm.h (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) Whitespace removal. Mon, 30 Nov 2009 15:49:52 GMT Ralf Corsepius [1de949a8] * cpukit/libgnat/ada_intrsupp.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/posix/include/rtems/posix/barrier.h (modified) * cpukit/posix/include/rtems/posix/cancel.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/priority.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/rwlock.h (modified) * cpukit/posix/include/rtems/posix/spinlock.h (modified) * cpukit/posix/include/rtems/posix/time.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/src/canceleval.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/ualarm.c (modified) Whitespace removal. Mon, 30 Nov 2009 14:18:22 GMT Joel Sherrill [524ff1cf] * cpukit/ChangeLog (modified) Spaces to tabs. Mon, 30 Nov 2009 13:24:59 GMT Thomas Doerfler [8bca4fc] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/shell.c (modified) Added format string to fprintf(). Mon, 30 Nov 2009 13:23:58 GMT Thomas Doerfler [42836e3] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios.c (modified) Obtain output semaphore before drain output during close to prevent ... Mon, 30 Nov 2009 13:20:29 GMT Thomas Doerfler [5ad790ff] * cpukit/ChangeLog (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) Added defines for initialization of empty chains. Mon, 30 Nov 2009 13:06:21 GMT Thomas Doerfler [9224a751] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/rtems_malloc.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapallocatealigned.c (deleted) Changed base implementation of protected heap allocations to use ... Mon, 30 Nov 2009 12:47:44 GMT Thomas Doerfler [2feeb26] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/vprintk.c (modified) Fixed output of unsigned integers. Changed type of boolean variables ... Mon, 30 Nov 2009 12:39:51 GMT Thomas Doerfler [47c2327] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) documentation fixes Avoid designated initializers for C++ ... Mon, 30 Nov 2009 09:08:35 GMT Thomas Doerfler [6e51c4c] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp31/task1.c (modified) * testsuites/sptests/sp52/init.c (modified) * testsuites/sptests/sp67/init.c (modified) * testsuites/sptests/sp68/Makefile.am (added) * testsuites/sptests/sp68/Makefile.in (added) * testsuites/sptests/sp68/init.c (added) * testsuites/sptests/sp68/sp68.doc (added) * testsuites/sptests/sp68/sp68.scn (added) * testsuites/sptests/spintrcritical17/Makefile.am (added) * testsuites/sptests/spintrcritical17/Makefile.in (added) * testsuites/sptests/spintrcritical17/init.c (added) * testsuites/sptests/spintrcritical17/spintrcritical17.doc (added) * testsuites/sptests/spintrcritical17/spintrcritical17.scn (added) Added timer server control block Removed _Timer_Server thread ... Sun, 29 Nov 2009 13:51:53 GMT Ralf Corsepius [28352fae] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/c4x/rtems/score/c4x.h (modified) * cpukit/score/cpu/c4x/rtems/score/cpu.h (modified) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/m32c.h (modified) * cpukit/score/cpu/m32c/varvects.h (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecgreaterthan.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64divide.c (modified) * cpukit/score/src/ts64getnanoseconds.c (modified) * cpukit/score/src/ts64toticks.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddapiset.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/userextthreadswitch.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdogreport.c (modified) * cpukit/score/src/watchdogtickle.c (modified) Whitespace removal. Sun, 29 Nov 2009 13:35:32 GMT Ralf Corsepius [18daff9] * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_init.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/writev.c (modified) Whitespace removal. Sun, 29 Nov 2009 13:20:53 GMT Ralf Corsepius [0a7278e] * cpukit/httpd/asp.c (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/cgi.c (modified) * cpukit/httpd/default.c (modified) * cpukit/httpd/ej.h (modified) * cpukit/httpd/ejIntrn.h (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/ejparse.c (modified) * cpukit/httpd/emfdb.c (modified) * cpukit/httpd/form.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/md5c.c (modified) * cpukit/httpd/misc.c (modified) * cpukit/httpd/ringq.c (modified) * cpukit/httpd/security.c (modified) * cpukit/httpd/sock.c (modified) * cpukit/httpd/sockGen.c (modified) * cpukit/httpd/socket.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/um.c (modified) * cpukit/httpd/umui.c (modified) * cpukit/httpd/url.c (modified) * cpukit/httpd/wbase64.c (modified) * cpukit/httpd/webcomp.c (modified) * cpukit/httpd/webmain.c (modified) * cpukit/httpd/webs.c (modified) * cpukit/httpd/webs.h (modified) * cpukit/httpd/websSSL.c (modified) * cpukit/httpd/websSSL.h (modified) * cpukit/httpd/websda.c (modified) * cpukit/httpd/websda.h (modified) * cpukit/httpd/websuemf.c (modified) * cpukit/httpd/wsIntrn.h (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_mknod.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (modified) * cpukit/libfs/src/devfs/devfs_show.c (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.modini.c (modified) * cpukit/libfs/src/nfsclient/src/nfsTest.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.h (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) * cpukit/libfs/src/pipe/pipe.h (modified) Whitespace removal. Sun, 29 Nov 2009 12:12:39 GMT Ralf Corsepius [0893220] * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparam.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/monitor/mon-region.c (modified) * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/dd-args.c (modified) * cpukit/libmisc/shell/dd-position.c (modified) * cpukit/libmisc/shell/fts.c (modified) * cpukit/libmisc/shell/hexdump-conv.c (modified) * cpukit/libmisc/shell/hexdump-display.c (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) * cpukit/libmisc/shell/hexsyntax.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cp.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_dd.c (modified) * cpukit/libmisc/shell/main_getenv.c (modified) * cpukit/libmisc/shell/main_hexdump.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/shell/main_ln.c (modified) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_mv.c (modified) * cpukit/libmisc/shell/main_mwdump.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/main_route.c (modified) * cpukit/libmisc/shell/main_setenv.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_unsetenv.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shell_getprompt.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/uuid/gen_uuid.c (modified) Whitespace removal. Sun, 29 Nov 2009 11:57:23 GMT Ralf Corsepius [33c3b54d] * cpukit/include/rtems/bsd/sys/queue.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/pci.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/include/rtems/nvdisk-sram.h (modified) * cpukit/libblock/include/rtems/nvdisk.h (modified) * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtc.h (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/include/sys/ioctl.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/dumpbuf/dumpbuf.h (modified) * cpukit/libmisc/fb/fb.h (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/libmisc/stringto/stringto_template.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) Whitespace removal. Sat, 28 Nov 2009 06:15:55 GMT Ralf Corsepius [e447c7d2] * cpukit/automake/subdirs.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) Whitespace removal. Sat, 28 Nov 2009 05:58:54 GMT Ralf Corsepius [20f02c6] * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/corebarrier.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/corerwlock.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/corespinlock.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadsync.h (modified) * cpukit/score/include/rtems/score/timespec.h (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) Whitespace removal. Mon, 23 Nov 2009 21:56:50 GMT Joel Sherrill [13c37ad] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/shell.c (modified) 2009-11-23 Joel Sherrill * ... Mon, 23 Nov 2009 21:55:36 GMT Joel Sherrill [8a68b60] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/login_prompt.c (modified) 2009-11-23 Joel Sherrill * ... Mon, 23 Nov 2009 20:07:04 GMT Joel Sherrill [ef85611] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) 2009-11-23 Joel Sherrill * ... Mon, 23 Nov 2009 14:53:04 GMT Joel Sherrill [fdc57ca] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) 2009-11-23 Joel Sherrill ... Mon, 23 Nov 2009 14:33:23 GMT Joel Sherrill [3f255ce1] * cpukit/ChangeLog (modified) * cpukit/mghttpd/mongoose.c (modified) 2009-11-23 Joel Sherrill * ... Sun, 22 Nov 2009 07:04:54 GMT Ralf Corsepius [1eefa75] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) 2009-11-22 Ralf Corsépius * ... Fri, 20 Nov 2009 06:33:38 GMT Thomas Doerfler [6d612944] * cpukit/ChangeLog (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) numerous changes Thu, 19 Nov 2009 14:46:11 GMT Ralf Corsepius [b5b51fc] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) 2009-11-19 Ralf Corsépius * ... Thu, 19 Nov 2009 14:39:39 GMT Ralf Corsepius [999de9b] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) 2009-11-19 Ralf Corsépius * ... Thu, 19 Nov 2009 13:51:40 GMT Ralf Corsepius [88db141] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_boundary.c (modified) 2009-11-19 Ralf Corsépius * ... Wed, 18 Nov 2009 00:09:21 GMT Chris Johns [0540498] * cpukit/ChangeLog (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_getenv.c (added) * cpukit/libmisc/shell/main_setenv.c (added) * cpukit/libmisc/shell/main_unsetenv.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) 2009-11-18 Chris Johns * ... Tue, 17 Nov 2009 17:33:40 GMT Ralf Corsepius [ba955609] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) 2009-11-17 Ralf Corsépius * ... Tue, 17 Nov 2009 17:32:24 GMT Ralf Corsepius [06604c14] * cpukit/ChangeLog (modified) 2009-11-17 Ralf Corsépius * ... Tue, 17 Nov 2009 17:30:41 GMT Ralf Corsepius [3202cd8] * cpukit/mghttpd/mongoose.c (modified) Various 16bit fixes. Tue, 17 Nov 2009 17:15:08 GMT Ralf Corsepius [56f9698] * cpukit/mghttpd/mongoose.c (modified) Add HAVE_CONFIG_H. Tue, 17 Nov 2009 17:02:08 GMT Ralf Corsepius [ce841ab] * cpukit/mghttpd/mongoose.c (modified) Add HAVE_SYS_MMAN_H HAVE_DLFCN_H. Tue, 17 Nov 2009 16:58:36 GMT Ralf Corsepius [dd1569b] * cpukit/mghttpd/mongoose.c (modified) * cpukit/mghttpd/mongoose.h (modified) Convert to unix encoding. Tue, 17 Nov 2009 16:55:52 GMT Ralf Corsepius [390631d3] * cpukit/mghttpd/.cvsignore (added) * cpukit/mghttpd/Makefile.am (added) * cpukit/mghttpd/preinstall.am (added) New. Tue, 17 Nov 2009 16:55:35 GMT Ralf Corsepius [4b0856d] * cpukit/ChangeLog (modified) 2009-11-17 Ralf Corsépius * ... Tue, 17 Nov 2009 16:53:48 GMT Ralf Corsepius [b45feba] * cpukit/ChangeLog (modified) * cpukit/mghttpd/mongoose.1 (added) * cpukit/mghttpd/mongoose.c (added) * cpukit/mghttpd/mongoose.h (added) 2009-11-17 Ralf Corsépius * ... Fri, 13 Nov 2009 15:12:53 GMT Ralf Corsepius [787519fb] * cpukit/ChangeLog (modified) * cpukit/libmisc/capture/capture-cli.c (modified) 2009-11-13 Ralf Corsépius * ... Fri, 13 Nov 2009 11:57:52 GMT Ralf Corsepius [10b83e6] * cpukit/ChangeLog (modified) * cpukit/telnetd/telnetd.c (modified) 2009-11-13 Ralf Corsépius * ...
