# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/01/24 19:30:59 Tue, 12 Feb 2019 11:19:38 GMT Sebastian Huber [e4ad14cc] * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/src/once.c (modified) * testsuites/psxtests/psxonce01/init.c (modified) * testsuites/psxtests/psxonce01/psxonce01.scn (modified) * testsuites/psxtests/psxonce01/system.h (modified) * testsuites/sptests/spcxx01/init.cc (modified) * testsuites/sptests/spcxx01/spcxx01.doc (modified) score: Avoid some deadlocks in _Once() Recursive usage of the same ... Thu, 14 Feb 2019 23:38:41 GMT Chris Johns [3ecb207] * cpukit/libdl/rtl-rap.c (modified) libdl/rap: Add the section alloc call after section load was split ... Thu, 14 Feb 2019 03:00:05 GMT Chris Johns [e309f77] * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-alloc-heap.h (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Allocator does not unlock and lock memory on loading. Close #3692 Tue, 12 Feb 2019 12:18:56 GMT Sebastian Huber [e214ff4b] * cpukit/include/rtems/posix/posixapi.h (modified) posix: Remove unused _POSIX_Get_object_body() Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 21 Jan 2019 21:48:19 GMT Chris Johns [194eb403] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add support for large memory programs - Add trampolines to ... Tue, 15 Jan 2019 06:47:41 GMT Chris Johns [d8c70ba6] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (added) * testsuites/libtests/dl09/dl-load.h (added) * testsuites/libtests/dl09/dl-o1.c (added) * testsuites/libtests/dl09/dl-o1.h (added) * testsuites/libtests/dl09/dl-o2.c (added) * testsuites/libtests/dl09/dl-o2.h (added) * testsuites/libtests/dl09/dl-o3.c (added) * testsuites/libtests/dl09/dl-o3.h (added) * testsuites/libtests/dl09/dl-o4.c (added) * testsuites/libtests/dl09/dl-o4.h (added) * testsuites/libtests/dl09/dl-o5.c (added) * testsuites/libtests/dl09/dl-o5.h (added) * testsuites/libtests/dl09/dl09.doc (added) * testsuites/libtests/dl09/dl09.scn (added) * testsuites/libtests/dl09/init.c (added) libdl: Add support for trampolines - Trampolines or fixups for ... Wed, 09 Jan 2019 11:14:11 GMT Chris Johns [4408603] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * cpukit/score/cpu/arm/include/machine/elf_machdep.h (modified) * testsuites/libtests/dl08/dl-load.c (modified) libdl: Fix the support for constructors and desctructors. - Fix the ... Mon, 17 Dec 2018 06:48:30 GMT Chris Johns [a7c6176] * cpukit/headers.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl08/dl-load.c (added) * testsuites/libtests/dl08/dl-load.h (added) * testsuites/libtests/dl08/dl-o1.c (added) * testsuites/libtests/dl08/dl-o1.h (added) * testsuites/libtests/dl08/dl-o2.c (added) * testsuites/libtests/dl08/dl-o2.h (added) * testsuites/libtests/dl08/dl-o3.c (added) * testsuites/libtests/dl08/dl-o3.h (added) * testsuites/libtests/dl08/dl-o4.c (added) * testsuites/libtests/dl08/dl-o4.h (added) * testsuites/libtests/dl08/dl-o5.c (added) * testsuites/libtests/dl08/dl-o5.h (added) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (added) * testsuites/libtests/dl08/dl-o6.h (added) * testsuites/libtests/dl08/dl08.doc (added) * testsuites/libtests/dl08/dl08.scn (added) * testsuites/libtests/dl08/init.c (added) libtest/dl08: Add a test for archives. - Create 2 archives. - Load ... Mon, 17 Dec 2018 05:36:48 GMT Chris Johns [89c59be] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-archive.h (added) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-archive.c (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Add symbol searching and loading from archives. - Load ... Sat, 02 Feb 2019 04:19:59 GMT Chris Johns [e2f13430] * cpukit/libdl/dlfcn.c (modified) libdl: Fix dlerror non-conformance Closes #3298 Sat, 02 Feb 2019 04:22:04 GMT Chris Johns [2d8a9c79] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) libmisc: Fix rtems_print_buffer Closes #3684 Fri, 08 Feb 2019 09:16:07 GMT Sebastian Huber [26333f2a] * cpukit/include/rtems/score/userextimpl.h (modified) score: Fix _User_extensions_Thread_switch() (SMP) We have to read ... Thu, 07 Feb 2019 06:46:38 GMT Sebastian Huber [fbd08066] * cpukit/score/src/threadqops.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) score: Fix plain priority thread queues (SMP) We must add/remove ... Tue, 27 Nov 2018 11:45:53 GMT Sebastian Huber [03fcbb1] * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) * cpukit/libfs/src/jffs2/include/linux/fs.h (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * testsuites/fstests/fsscandir01/init.c (modified) fs: Add struct dirent::d_type support Sat, 02 Feb 2019 10:03:13 GMT Sebastian Huber [9399473c] * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) riscv: Fix misaligned access in context validate Wed, 30 Jan 2019 08:41:49 GMT Sebastian Huber [03cdd5ea] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record01/init.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add enum value for each event Update #3665. Sat, 28 Apr 2018 09:36:11 GMT Sebastian Huber [dca6184] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (added) * cpukit/include/rtems/recordclient.h (added) * cpukit/include/rtems/recorddata.h (added) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-client.c (added) * cpukit/libtrace/record/record-server.c (added) * cpukit/libtrace/record/record-sysinit.c (added) * cpukit/libtrace/record/record-text.c (added) * cpukit/libtrace/record/record-userext.c (added) * cpukit/libtrace/record/record.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/record01/init.c (added) * testsuites/libtests/record01/record01.doc (added) * testsuites/libtests/record01/record01.scn (added) * testsuites/libtests/record02/init.c (added) * testsuites/libtests/record02/record02.doc (added) * testsuites/libtests/record02/record02.scn (added) Add low level event recording support Add low level event recording ... Thu, 17 Jan 2019 06:33:08 GMT Sebastian Huber [f0ae613b] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k: Avoid _Addresses_Add_offset() This prevents a cyclic ... Wed, 23 Jan 2019 12:17:44 GMT Maksim E. Kozlov [afd50b3] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) libmisc: Fix swapped parameters and enable floating point usage. Fri, 18 Jan 2019 11:37:55 GMT Jiri Gaisler [d3d4e77] * bsps/riscv/griscv/clock/clockdrv.c (added) * bsps/riscv/griscv/config/griscv.cfg (added) * bsps/riscv/griscv/console/console.c (added) * bsps/riscv/griscv/console/printk_support.c (added) * bsps/riscv/griscv/headers.am (added) * bsps/riscv/griscv/include/amba.h (added) * bsps/riscv/griscv/include/bsp.h (added) * bsps/riscv/griscv/include/bsp/irq.h (added) * bsps/riscv/griscv/include/tm27.h (added) * bsps/riscv/griscv/irq/irq.c (added) * bsps/riscv/griscv/start/amba.c (added) * bsps/riscv/griscv/start/bsp_fatal_halt.c (added) * bsps/riscv/griscv/start/bsp_specs (added) * bsps/riscv/griscv/start/bspsmp.c (added) * bsps/riscv/griscv/start/bspstart.c (added) * bsps/riscv/griscv/start/linkcmds.in (added) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/shared/start/linkcmds.base (moved) * bsps/riscv/shared/start/start.S (moved) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (added) * c/src/lib/libbsp/riscv/griscv/configure.ac (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: add griscv bsp Update #3678. Fri, 18 Jan 2019 17:00:47 GMT Jiri Gaisler [9b2b389] * bsps/include/grlib/grlib_impl.h (modified) * bsps/shared/grlib/1553/b1553brm.c (modified) * bsps/shared/grlib/1553/b1553rt.c (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/pci/grpci2dma.c (modified) * bsps/shared/grlib/spw/grspw.c (modified) * bsps/shared/grlib/spw/grspw_pkt.c (modified) * cpukit/score/cpu/riscv/headers.am (modified) * cpukit/score/cpu/riscv/include/libcpu/access.h (added) * cpukit/score/cpu/riscv/include/libcpu/byteorder.h (added) grlib: use cpu-independent routines for uncached access Update #3678. Fri, 18 Jan 2019 12:32:51 GMT Sebastian Huber [926ed2b0] * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Remove unused _ISR_lock_Flash() Fri, 18 Jan 2019 12:16:29 GMT Sebastian Huber [41310c02] * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Improve debug support for ISR locks Ensure that interrupts ... Fri, 18 Jan 2019 11:54:05 GMT Sebastian Huber [b5bdecf] * cpukit/score/src/smpmulticastaction.c (modified) score: Avoid internal API and use ISR lock Mon, 14 Jan 2019 06:50:26 GMT Sebastian Huber [93e3b341] * cpukit/include/rtems/score/address.h (modified) score: Simplify _Addresses_Is_aligned() The CPU_ALIGNMENT must not ... Thu, 10 Jan 2019 19:14:03 GMT Joel Sherrill [4596127] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k/include/rtems/score/cpu.h: Add include of address.h Thu, 10 Jan 2019 10:35:12 GMT Sebastian Huber [8eaf136d] * cpukit/libcsupport/src/alignedalloc.c (modified) memalign: Add missing attributes to fix warning Update #3666. Thu, 10 Jan 2019 08:05:49 GMT Sebastian Huber [7bde91b] * cpukit/include/rtems/inttypes.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) Fix format warnings due to ino_t changes Tue, 08 Jan 2019 08:50:50 GMT Sebastian Huber [b9ffc41c] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Enable robust thread dispatch It must be enabled, since the ... Tue, 08 Jan 2019 08:53:26 GMT Sebastian Huber [3bd39999] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp37/init.c (modified) Adjust interrupt mode tests for some CPU ports In case the robust ... Tue, 08 Jan 2019 07:39:42 GMT Sebastian Huber [1f285186] * cpukit/rtems/src/taskmode.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) rtems: Allow to set ISR level 0 in SMP config Update #3000. Tue, 08 Jan 2019 07:36:31 GMT Sebastian Huber [38cb59e] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) Separate task mode checks Update #3000. Mon, 07 Jan 2019 08:32:16 GMT Sebastian Huber [9c12bcfd] * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_pci.c (modified) * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_print.c (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) Fix format warnings Mon, 07 Jan 2019 08:30:43 GMT Sebastian Huber [956d76cc] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove superfluous include from chainimpl.h Fri, 21 Dec 2018 20:09:53 GMT Sebastian Huber [a7e8996] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) drvmgr: Improve LP64 compatibility Fri, 21 Dec 2018 20:09:15 GMT Sebastian Huber [6073c71d] * cpukit/configure.ac (modified) drvmgr: Enable build for riscv Wed, 19 Dec 2018 08:25:29 GMT Sebastian Huber [2158621] * cpukit/Makefile.am (modified) * cpukit/libcsupport/src/alignedalloc.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcxx01/init.cc (added) * testsuites/sptests/spcxx01/spcxx01.doc (added) * testsuites/sptests/spcxx01/spcxx01.scn (added) Add aligned_alloc() and memalign() Ensure that the C++17 aligned ... Thu, 20 Dec 2018 13:26:50 GMT Thomas Dörfler [10135fa] * cpukit/libnetworking/lib/tftpDriver.c (modified) tftpfs: Some bug fixes Fix for: - tftpfs did not mount, when ... Tue, 18 Dec 2018 07:45:06 GMT Sebastian Huber [7c19e50] * cpukit/include/rtems/score/interr.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal09/init.c (added) * testsuites/smptests/smpfatal09/smpfatal09.doc (added) * testsuites/smptests/smpfatal09/smpfatal09.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Fix per-CPU data allocation Allocate the per-CPU data for ... Fri, 14 Dec 2018 07:07:08 GMT Sebastian Huber [e7b0a72] * cpukit/include/rtems/confdefs.h (modified) config: Remove CONFIGURE_CONFDEFS_DEBUG This configuration option ... Thu, 13 Dec 2018 08:39:20 GMT Sebastian Huber [6b0a729b] * ampolish3 (deleted) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (deleted) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * cpukit/aclocal/rtems-ampolish.m4 (deleted) * cpukit/configure.ac (modified) build: Remove ampolish3 Update #3254. Thu, 22 Nov 2018 18:14:51 GMT Sebastian Huber [21275b58] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keyzerokvp.c (added) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal13/spfatal13.doc (deleted) * testsuites/sptests/spfatal13/spfatal13.scn (deleted) * testsuites/sptests/spfatal13/testcase.h (deleted) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Static Objects_Information initialization Statically ... Mon, 10 Dec 2018 11:51:33 GMT Sebastian Huber [0f5b2c09] * cpukit/Makefile.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/getconfigmax.c (added) rtems: Use object information to get config max Use functions ... Mon, 10 Dec 2018 12:44:53 GMT Sebastian Huber [8b0e752f] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Remove Objects_Information::auto_extend Use ... Tue, 11 Dec 2018 14:11:10 GMT Sebastian Huber [a1eb0a5] * cpukit/posix/src/shmunlink.c (modified) posix: Fix shm_unlink() This function is untested. Sun, 25 Nov 2018 19:26:02 GMT Sebastian Huber [f70079c] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove Objects_Information::the_api Remove ... Sun, 25 Nov 2018 19:15:26 GMT Sebastian Huber [1c2d178] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threaditerate.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Remove Objects_Information::maximum This information is ... Sat, 24 Nov 2018 10:51:28 GMT Sebastian Huber [3899bc1a] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threaditerate.c (modified) * testsuites/sptests/spconfig02/init.c (modified) score: Optimize object lookup Use the maximum ID for the ID to ... Thu, 22 Nov 2018 05:38:42 GMT Sebastian Huber [359a3a3] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) score: Rename Objects_Information::allocation_size Rename ... Thu, 22 Nov 2018 05:16:52 GMT Sebastian Huber [0da9d80] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Rename Objects_Information::size Rename ... Wed, 21 Nov 2018 16:30:52 GMT Sebastian Huber [9c9c6a9] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) score: Remove Objects_Information::is_string Use ... Fri, 23 Nov 2018 19:37:57 GMT Sebastian Huber [d6e3473] * cpukit/score/src/objectallocate.c (modified) score: Remove dead code Update #3621. Thu, 06 Dec 2018 08:57:01 GMT Sebastian Huber [7ee6437] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetmaxprio.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_get_maximum_priority() Update #3636. Thu, 03 May 2018 11:03:27 GMT Sebastian Huber [0a1f5df9] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/shared/dev/cpucounter/cpucounterdiff.c (deleted) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-counter.c (deleted) Simplify _CPU_Counter_difference() In order to simplify the use of ... Mon, 03 Dec 2018 12:10:21 GMT Sebastian Huber [ef23838] * cpukit/headers.am (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (added) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) score: Avoid sbintime_t in API headers The sbintime_t is a ... Thu, 06 Dec 2018 12:40:08 GMT Sebastian Huber [e50b4bd3] * cpukit/include/rtems/score/basedefs.h (modified) score: Use __typeof__ for strict ISO C compat Enable the use of ... Thu, 06 Dec 2018 09:49:43 GMT Sebastian Huber [4e46ba8] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskrestart.c (modified) rtems: Fix rtems_task_restart() argument type Close #3637. Mon, 03 Dec 2018 20:37:32 GMT Marçal Comajoan Cara [0446f680] * bsps/i386/pc386/start/README-SMP (modified) * bsps/powerpc/shared/exceptions/ppc_exc_address.c (modified) * bsps/sparc/leon3/start/bspclean.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libi2c/README_libi2c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * testsuites/smptests/smpmutex01/init.c (modified) Spelling and grammar fixes in source code comments (GCI 2018) Mon, 03 Dec 2018 12:34:28 GMT Sebastian Huber [577d9a5] * cpukit/libmisc/testsupport/testextension.c (modified) testsupport: Include missing Fri, 30 Nov 2018 12:57:04 GMT Sebastian Huber [b9ffb624] * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * testsuites/sptests/spcpucounter01/init.c (modified) Convert CPU counter ticks to/from sbintime_t The sbintime_t is an ... Mon, 03 Dec 2018 03:13:23 GMT Jacob Shin [d0a7f03] * aclocal/project-root.m4 (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) 5 spelling errors for a Google Code-In task. Username: ... Tue, 27 Nov 2018 10:56:01 GMT Sebastian Huber [06331e4] * cpukit/libfs/src/dosfs/fat.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) dosfs: Fix device identifier Update #3358. Mon, 26 Nov 2018 13:04:59 GMT Sebastian Huber [0a75a4aa] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * testsuites/smptests/smpcache01/init.c (modified) Remove rtems_cache_*_processor_set() functions The following ... Mon, 26 Nov 2018 09:14:00 GMT Sebastian Huber [6378978] * cpukit/rtems/src/semmp.c (modified) rtems: Fix semaphore MPCI support Mon, 26 Nov 2018 07:25:36 GMT Sebastian Huber [5fc727f] * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/score/src/profilingsmplock.c (modified) score: Remove ... Tue, 20 Nov 2018 15:22:56 GMT Sebastian Huber [eaa5ea84] * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapinfo.h (added) * testsuites/libtests/stackchk/blow.c (modified) score: Introduce Move ... Thu, 22 Nov 2018 00:46:35 GMT Joel Sherrill [9dfb9a98] * cpukit/libfs/src/pipe/fifo.c (modified) pipe/fifo.c: Remove dead code (CID 1437649) Closes #3581. Tue, 20 Nov 2018 03:56:11 GMT Chris Johns [03139d5b] * cpukit/include/rtems/rtl/rtl-obj-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (added) * testsuites/libtests/dl07/dl-load.h (added) * testsuites/libtests/dl07/dl-o1.c (added) * testsuites/libtests/dl07/dl-o1.h (added) * testsuites/libtests/dl07/dl-o2.c (added) * testsuites/libtests/dl07/dl-o2.h (added) * testsuites/libtests/dl07/dl-o3.c (added) * testsuites/libtests/dl07/dl-o4.c (added) * testsuites/libtests/dl07/dl-o4.h (added) * testsuites/libtests/dl07/dl-o5.c (added) * testsuites/libtests/dl07/dl-o5.h (added) * testsuites/libtests/dl07/dl07.doc (added) * testsuites/libtests/dl07/dl07.scn (added) * testsuites/libtests/dl07/init.c (added) libdl: Add object file dependencies to track references Tracking ... Tue, 20 Nov 2018 03:00:48 GMT Chris Johns [8e7c72a7] * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) libdl: Reindex unresolved names after removing used records. ... Tue, 13 Nov 2018 06:26:17 GMT Chris Johns [803eac9] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Manage the allocation of common uninitialised variables. The ... Wed, 21 Nov 2018 16:30:22 GMT Sebastian Huber [52c7cb1] * cpukit/score/src/wkstringduplicate.c (modified) score: Simplify _Workspace_String_duplicate() Fri, 16 Nov 2018 06:06:12 GMT Sebastian Huber [59e7209f] * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) score: Remove support for RTEMS_USE_16_BIT_OBJECT The ... Tue, 20 Nov 2018 15:45:51 GMT kuaLeYi [bde6ac20] * cpukit/ftpd/ftpd.c (modified) * cpukit/libdrvmgr/README (modified) * make/leaf.cfg (modified) * testsuites/libtests/POSIX/README (modified) Misc: Minor English fixes (GCI 2018) Wed, 14 Nov 2018 06:23:21 GMT Sebastian Huber [dc563556] * cpukit/include/rtems/rtems/cache.h (modified) Include missing Update #3598. Wed, 14 Nov 2018 06:00:59 GMT Sebastian Huber [28bf4ca] * bsps/or1k/generic_or1k/start/bsp_specs (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/src/threadhandler.c (modified) or1k: Support GCC 9 Close #3602. Fri, 09 Nov 2018 11:11:11 GMT Sebastian Huber [6efc831] * cpukit/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * testsuites/libtests/malloctest/init.c (modified) Add rtems_malloc() and rtems_calloc() Close #3583. Fri, 09 Nov 2018 10:20:09 GMT Sebastian Huber [c1f3c2b8] * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) score: Add and use malloc() family attributes Update #3583. Thu, 08 Nov 2018 15:06:44 GMT Sebastian Huber [4539e307] * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) x86_64: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 07:12:49 GMT Sebastian Huber [70928bc9] * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) sparc64: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 05:41:15 GMT Sebastian Huber [ce37237f] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) sparc: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:31:03 GMT Sebastian Huber [510fbfc3] * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/ispsh7032.c (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/ispsh7045.c (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/shared/start/setvec.c (modified) * bsps/sh/shsim/start/ispshgdb.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) sh: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 06:56:48 GMT Sebastian Huber [ed9da8e] * cpukit/Makefile.am (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (deleted) powerpc: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:05:22 GMT Sebastian Huber [54c5ffc] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) or1k: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 15:03:10 GMT Sebastian Huber [12dfa5e2] * cpukit/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-isr-install-raw-handler.c (deleted) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) nios2: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 07:04:23 GMT Sebastian Huber [264e128] * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) moxie: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:34:59 GMT Sebastian Huber [b6be8f33] * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) mips: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:44:56 GMT Sebastian Huber [5c6edee] * bsps/m68k/gen68340/console/console.c (modified) * bsps/m68k/shared/fpsp/rtems_fpsp.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:47:42 GMT Sebastian Huber [0e16fa45] * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) lm32: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:14:32 GMT Sebastian Huber [3c6a6e8] * bsps/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) i386: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:33:47 GMT Sebastian Huber [a043ff8] * bsps/epiphany/epiphany_sim/btimer/btimer.c (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) epiphany: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 06:59:57 GMT Sebastian Huber [8203db45] * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) bfin: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 07:01:53 GMT Sebastian Huber [685aa28] * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) arm: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 06:54:31 GMT Sebastian Huber [d997aa1] * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) no_cpu: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 05:25:32 GMT Sebastian Huber [3faa8459] * cpukit/rtems/src/intrcatch.c (modified) rtems: Simplify rtems_interrupt_catch() Remove casts and ... Thu, 08 Nov 2018 05:25:06 GMT Sebastian Huber [b15b288] * cpukit/include/rtems/score/basedefs.h (modified) score: Deprecate proc_ptr Update #3585. Mon, 12 Nov 2018 08:28:49 GMT Sebastian Huber [963c6c2] * cpukit/headers.am (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextdata.h (added) * cpukit/include/rtems/score/userextimpl.h (modified) score: Move internal structures to userextdata.h Update #3598. Mon, 12 Nov 2018 08:24:28 GMT Sebastian Huber [356b07e6] * cpukit/include/rtems/score/smplockstats.h (modified) score: Includes in Include ... Mon, 12 Nov 2018 08:23:32 GMT Sebastian Huber [3b69a0e2] * cpukit/include/rtems/rtems/cache.h (modified) rtems: Simplify includes in Update #3598. Mon, 12 Nov 2018 08:00:36 GMT Sebastian Huber [a6e7d5e4] * cpukit/headers.am (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (added) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) score: Move internal structures to objectdata.h Update #3598.
