# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 14:40:14 Thu, 10 Dec 2015 14:44:02 GMT Sebastian Huber [a853c851] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/userext.c (modified) * doc/user/init.t (modified) * testsuites/sptests/spsysinit01/init.c (modified) Optional Initial Extensions initialization Update #2408. Mon, 25 Jan 2016 19:55:52 GMT Sebastian Huber [36b86d7] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Create idle threads via linker set This allows a more fine ... Mon, 14 Dec 2015 13:26:13 GMT Sebastian Huber [17e6f86] * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) Statically initialize _Objects_Information_table Tue, 02 Feb 2016 07:00:34 GMT Sebastian Huber [e079b33e] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) Filesystem: Export most generic path eval function Add path length ... Tue, 26 Jan 2016 15:26:01 GMT Sebastian Huber [93244a9] * cpukit/Makefile.am (modified) * cpukit/preinstall.am (modified) drvmgr: Install header files conditionally The --enable-drvmgr ... Tue, 26 Jan 2016 15:22:46 GMT Sebastian Huber [297aa07] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/sapi/src/exinit.c (modified) Revert "drvmgr: Move bsp_driver_level_hook() calls" The ... Tue, 26 Jan 2016 10:53:09 GMT Sebastian Huber [27580641] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Adjust CPU_CACHE_LINE_BYTES for LEON3 Fix for commit ... Tue, 26 Jan 2016 06:17:27 GMT Sebastian Huber [61bbf919] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/sapi/src/exinit.c (modified) drvmgr: Move bsp_driver_level_hook() calls Tue, 26 Jan 2016 06:16:52 GMT Sebastian Huber [47190194] * c/src/lib/libbsp/shared/bspdriverlevelhook.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c (modified) * cpukit/Makefile.am (modified) * cpukit/preinstall.am (modified) drvmgr: Remove dupl bsp_driver_level_hook() decl Tue, 26 Jan 2016 09:29:28 GMT Sebastian Huber [addb600] * cpukit/score/src/mpci.c (modified) mpci: Fix warning Assignment is superfluous due to later call to ... Tue, 26 Jan 2016 09:23:22 GMT Sebastian Huber [885c342e] * cpukit/score/include/rtems/score/mpciimpl.h (modified) * cpukit/score/src/mpci.c (modified) mpci: Update due to API changes Update due to API changes ... Mon, 25 Jan 2016 09:20:28 GMT Sebastian Huber [a8865f8] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Introduce CPU_CACHE_LINE_BYTES Add CPU_CACHE_LINE_BYTES for ... Mon, 25 Jan 2016 09:20:14 GMT Sebastian Huber [cd9ef185] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_ALIGNED() Mon, 25 Jan 2016 08:36:50 GMT Sebastian Huber [a0c79c1f] * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64: No explicit align of _CPU_Null_fp_context This structure ... Mon, 25 Jan 2016 08:35:52 GMT Sebastian Huber [beab4245] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: No explicit align of _CPU_Null_fp_context This structure is ... Mon, 25 Jan 2016 07:54:17 GMT Sebastian Huber [01b32d4] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * testsuites/sptests/sp2038/init.c (modified) score: Delete obsolete CPU_TIMESTAMP_* defines Update #2271. Thu, 21 Jan 2016 09:53:16 GMT Sebastian Huber [370cdefd] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) arm: Use DWT CYCCNT for timecounter if available Tue, 03 Nov 2015 10:44:11 GMT Sebastian Huber [d9bd59da] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) bsp/irq-server: Support shared interrupts Wed, 20 Jan 2016 01:38:35 GMT Joel Sherrill [15068f4c] * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/avr/Makefile.am (deleted) * c/src/lib/libbsp/avr/acinclude.m4 (deleted) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/avr/Makefile.am (deleted) * cpukit/score/cpu/avr/README (deleted) * cpukit/score/cpu/avr/avr-exception-frame-print.c (deleted) * cpukit/score/cpu/avr/avr/boot.h (deleted) * cpukit/score/cpu/avr/avr/common.h (deleted) * cpukit/score/cpu/avr/avr/crc16.h (deleted) * cpukit/score/cpu/avr/avr/delay.h (deleted) * cpukit/score/cpu/avr/avr/eeprom.h (deleted) * cpukit/score/cpu/avr/avr/fuse.h (deleted) * cpukit/score/cpu/avr/avr/interrupt.h (deleted) * cpukit/score/cpu/avr/avr/io.h (deleted) * cpukit/score/cpu/avr/avr/io1200.h (deleted) * cpukit/score/cpu/avr/avr/io2313.h (deleted) * cpukit/score/cpu/avr/avr/io2323.h (deleted) * cpukit/score/cpu/avr/avr/io2333.h (deleted) * cpukit/score/cpu/avr/avr/io2343.h (deleted) * cpukit/score/cpu/avr/avr/io43u32x.h (deleted) * cpukit/score/cpu/avr/avr/io43u35x.h (deleted) * cpukit/score/cpu/avr/avr/io4414.h (deleted) * cpukit/score/cpu/avr/avr/io4433.h (deleted) * cpukit/score/cpu/avr/avr/io4434.h (deleted) * cpukit/score/cpu/avr/avr/io76c711.h (deleted) * cpukit/score/cpu/avr/avr/io8515.h (deleted) * cpukit/score/cpu/avr/avr/io8534.h (deleted) * cpukit/score/cpu/avr/avr/io8535.h (deleted) * cpukit/score/cpu/avr/avr/io86r401.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm1.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm216.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm2b.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm316.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm3b.h (deleted) * cpukit/score/cpu/avr/avr/io90pwm81.h (deleted) * cpukit/score/cpu/avr/avr/io90pwmx.h (deleted) * cpukit/score/cpu/avr/avr/io90scr100.h (deleted) * cpukit/score/cpu/avr/avr/ioa6289.h (deleted) * cpukit/score/cpu/avr/avr/ioat94k.h (deleted) * cpukit/score/cpu/avr/avr/iocan128.h (deleted) * cpukit/score/cpu/avr/avr/iocan32.h (deleted) * cpukit/score/cpu/avr/avr/iocan64.h (deleted) * cpukit/score/cpu/avr/avr/iocanxx.h (deleted) * cpukit/score/cpu/avr/avr/iom103.h (deleted) * cpukit/score/cpu/avr/avr/iom128.h (deleted) * cpukit/score/cpu/avr/avr/iom1280.h (deleted) * cpukit/score/cpu/avr/avr/iom1281.h (deleted) * cpukit/score/cpu/avr/avr/iom1284p.h (deleted) * cpukit/score/cpu/avr/avr/iom128rfa1.h (deleted) * cpukit/score/cpu/avr/avr/iom16.h (deleted) * cpukit/score/cpu/avr/avr/iom161.h (deleted) * cpukit/score/cpu/avr/avr/iom162.h (deleted) * cpukit/score/cpu/avr/avr/iom163.h (deleted) * cpukit/score/cpu/avr/avr/iom164.h (deleted) * cpukit/score/cpu/avr/avr/iom165.h (deleted) * cpukit/score/cpu/avr/avr/iom165p.h (deleted) * cpukit/score/cpu/avr/avr/iom168.h (deleted) * cpukit/score/cpu/avr/avr/iom168p.h (deleted) * cpukit/score/cpu/avr/avr/iom169.h (deleted) * cpukit/score/cpu/avr/avr/iom169p.h (deleted) * cpukit/score/cpu/avr/avr/iom169pa.h (deleted) * cpukit/score/cpu/avr/avr/iom16a.h (deleted) * cpukit/score/cpu/avr/avr/iom16hva.h (deleted) * cpukit/score/cpu/avr/avr/iom16hva2.h (deleted) * cpukit/score/cpu/avr/avr/iom16hvb.h (deleted) * cpukit/score/cpu/avr/avr/iom16m1.h (deleted) * cpukit/score/cpu/avr/avr/iom16u2.h (deleted) * cpukit/score/cpu/avr/avr/iom16u4.h (deleted) * cpukit/score/cpu/avr/avr/iom2560.h (deleted) * cpukit/score/cpu/avr/avr/iom2561.h (deleted) * cpukit/score/cpu/avr/avr/iom32.h (deleted) * cpukit/score/cpu/avr/avr/iom323.h (deleted) * cpukit/score/cpu/avr/avr/iom324.h (deleted) * cpukit/score/cpu/avr/avr/iom324pa.h (deleted) * cpukit/score/cpu/avr/avr/iom325.h (deleted) * cpukit/score/cpu/avr/avr/iom3250.h (deleted) * cpukit/score/cpu/avr/avr/iom328p.h (deleted) * cpukit/score/cpu/avr/avr/iom329.h (deleted) * cpukit/score/cpu/avr/avr/iom3290.h (deleted) * cpukit/score/cpu/avr/avr/iom32c1.h (deleted) * cpukit/score/cpu/avr/avr/iom32hvb.h (deleted) * cpukit/score/cpu/avr/avr/iom32m1.h (deleted) * cpukit/score/cpu/avr/avr/iom32u2.h (deleted) * cpukit/score/cpu/avr/avr/iom32u4.h (deleted) * cpukit/score/cpu/avr/avr/iom32u6.h (deleted) * cpukit/score/cpu/avr/avr/iom406.h (deleted) * cpukit/score/cpu/avr/avr/iom48.h (deleted) * cpukit/score/cpu/avr/avr/iom48p.h (deleted) * cpukit/score/cpu/avr/avr/iom64.h (deleted) * cpukit/score/cpu/avr/avr/iom640.h (deleted) * cpukit/score/cpu/avr/avr/iom644.h (deleted) * cpukit/score/cpu/avr/avr/iom644p.h (deleted) * cpukit/score/cpu/avr/avr/iom644pa.h (deleted) * cpukit/score/cpu/avr/avr/iom645.h (deleted) * cpukit/score/cpu/avr/avr/iom6450.h (deleted) * cpukit/score/cpu/avr/avr/iom649.h (deleted) * cpukit/score/cpu/avr/avr/iom6490.h (deleted) * cpukit/score/cpu/avr/avr/iom649p.h (deleted) * cpukit/score/cpu/avr/avr/iom64c1.h (deleted) * cpukit/score/cpu/avr/avr/iom64hve.h (deleted) * cpukit/score/cpu/avr/avr/iom64m1.h (deleted) * cpukit/score/cpu/avr/avr/iom8.h (deleted) * cpukit/score/cpu/avr/avr/iom8515.h (deleted) * cpukit/score/cpu/avr/avr/iom8535.h (deleted) * cpukit/score/cpu/avr/avr/iom88.h (deleted) * cpukit/score/cpu/avr/avr/iom88p.h (deleted) * cpukit/score/cpu/avr/avr/iom88pa.h (deleted) * cpukit/score/cpu/avr/avr/iom8hva.h (deleted) * cpukit/score/cpu/avr/avr/iom8u2.h (deleted) * cpukit/score/cpu/avr/avr/iomx8.h (deleted) * cpukit/score/cpu/avr/avr/iomxx0_1.h (deleted) * cpukit/score/cpu/avr/avr/iomxx4.h (deleted) * cpukit/score/cpu/avr/avr/iomxxhva.h (deleted) * cpukit/score/cpu/avr/avr/iotn11.h (deleted) * cpukit/score/cpu/avr/avr/iotn12.h (deleted) * cpukit/score/cpu/avr/avr/iotn13.h (deleted) * cpukit/score/cpu/avr/avr/iotn13a.h (deleted) * cpukit/score/cpu/avr/avr/iotn15.h (deleted) * cpukit/score/cpu/avr/avr/iotn167.h (deleted) * cpukit/score/cpu/avr/avr/iotn22.h (deleted) * cpukit/score/cpu/avr/avr/iotn2313.h (deleted) * cpukit/score/cpu/avr/avr/iotn2313a.h (deleted) * cpukit/score/cpu/avr/avr/iotn24.h (deleted) * cpukit/score/cpu/avr/avr/iotn24a.h (deleted) * cpukit/score/cpu/avr/avr/iotn25.h (deleted) * cpukit/score/cpu/avr/avr/iotn26.h (deleted) * cpukit/score/cpu/avr/avr/iotn261.h (deleted) * cpukit/score/cpu/avr/avr/iotn261a.h (deleted) * cpukit/score/cpu/avr/avr/iotn28.h (deleted) * cpukit/score/cpu/avr/avr/iotn4313.h (deleted) * cpukit/score/cpu/avr/avr/iotn43u.h (deleted) * cpukit/score/cpu/avr/avr/iotn44.h (deleted) * cpukit/score/cpu/avr/avr/iotn44a.h (deleted) * cpukit/score/cpu/avr/avr/iotn45.h (deleted) * cpukit/score/cpu/avr/avr/iotn461.h (deleted) * cpukit/score/cpu/avr/avr/iotn461a.h (deleted) * cpukit/score/cpu/avr/avr/iotn48.h (deleted) * cpukit/score/cpu/avr/avr/iotn84.h (deleted) * cpukit/score/cpu/avr/avr/iotn85.h (deleted) * cpukit/score/cpu/avr/avr/iotn861.h (deleted) * cpukit/score/cpu/avr/avr/iotn861a.h (deleted) * cpukit/score/cpu/avr/avr/iotn87.h (deleted) * cpukit/score/cpu/avr/avr/iotn88.h (deleted) * cpukit/score/cpu/avr/avr/iotnx4.h (deleted) * cpukit/score/cpu/avr/avr/iotnx5.h (deleted) * cpukit/score/cpu/avr/avr/iotnx61.h (deleted) * cpukit/score/cpu/avr/avr/iousb1286.h (deleted) * cpukit/score/cpu/avr/avr/iousb1287.h (deleted) * cpukit/score/cpu/avr/avr/iousb162.h (deleted) * cpukit/score/cpu/avr/avr/iousb646.h (deleted) * cpukit/score/cpu/avr/avr/iousb647.h (deleted) * cpukit/score/cpu/avr/avr/iousb82.h (deleted) * cpukit/score/cpu/avr/avr/iousbxx2.h (deleted) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (deleted) * cpukit/score/cpu/avr/avr/iox128a1.h (deleted) * cpukit/score/cpu/avr/avr/iox128a3.h (deleted) * cpukit/score/cpu/avr/avr/iox128d3.h (deleted) * cpukit/score/cpu/avr/avr/iox16a4.h (deleted) * cpukit/score/cpu/avr/avr/iox16d4.h (deleted) * cpukit/score/cpu/avr/avr/iox192a3.h (deleted) * cpukit/score/cpu/avr/avr/iox192d3.h (deleted) * cpukit/score/cpu/avr/avr/iox256a3.h (deleted) * cpukit/score/cpu/avr/avr/iox256a3b.h (deleted) * cpukit/score/cpu/avr/avr/iox256d3.h (deleted) * cpukit/score/cpu/avr/avr/iox32a4.h (deleted) * cpukit/score/cpu/avr/avr/iox32d4.h (deleted) * cpukit/score/cpu/avr/avr/iox64a1.h (deleted) * cpukit/score/cpu/avr/avr/iox64a3.h (deleted) * cpukit/score/cpu/avr/avr/iox64d3.h (deleted) * cpukit/score/cpu/avr/avr/lock.h (deleted) * cpukit/score/cpu/avr/avr/parity.h (deleted) * cpukit/score/cpu/avr/avr/pgmspace.h (deleted) * cpukit/score/cpu/avr/avr/portpins.h (deleted) * cpukit/score/cpu/avr/avr/power.h (deleted) * cpukit/score/cpu/avr/avr/sfr_defs.h (deleted) * cpukit/score/cpu/avr/avr/signal.h (deleted) * cpukit/score/cpu/avr/avr/signature.h (deleted) * cpukit/score/cpu/avr/avr/sleep.h (deleted) * cpukit/score/cpu/avr/avr/version.h (deleted) * cpukit/score/cpu/avr/avr/wdt.h (deleted) * cpukit/score/cpu/avr/cpu.c (deleted) * cpukit/score/cpu/avr/cpu_asm.S (deleted) * cpukit/score/cpu/avr/preinstall.am (deleted) * cpukit/score/cpu/avr/rtems/asm.h (deleted) * cpukit/score/cpu/avr/rtems/score/avr.h (deleted) * cpukit/score/cpu/avr/rtems/score/cpu.h (deleted) * cpukit/score/cpu/avr/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/avr/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/avr/rtems/score/types.h (deleted) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/avr.t (deleted) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/user/preface.texi (modified) * testsuites/support/include/buffer_test_io.h (modified) Remove AVR port closes #2443. Tue, 19 Jan 2016 18:11:47 GMT Joel Sherrill [22bb1b61] * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/execl.c (deleted) * cpukit/posix/src/execle.c (deleted) * cpukit/posix/src/execlp.c (deleted) * cpukit/posix/src/execv.c (deleted) * cpukit/posix/src/execve.c (deleted) * cpukit/posix/src/execvp.c (deleted) posix/src/exec*: Remove all variants already in Newlib The RTEMS ... Wed, 23 Dec 2015 06:29:47 GMT Sebastian Huber [76ac1ee3] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/sapi/include/rtems/timecounter.h (modified) * cpukit/score/include/rtems/score/timecounter.h (modified) * cpukit/score/src/kern_tc.c (modified) * doc/bsp_howto/clock.t (modified) score: Fix simple timecounter support Update #2502. Mon, 18 Jan 2016 23:34:25 GMT Joel Sherrill [2b9374e1] * cpukit/rtems/src/taskcreate.c (modified) taskcreate.c: Add method name to comment to be clearer Mon, 18 Jan 2016 23:31:09 GMT Joel Sherrill [33ece0da] * cpukit/rtems/include/rtems/rtems/sem.h (modified) sem.h: Delete junk in comment Mon, 18 Jan 2016 23:30:38 GMT Joel Sherrill [815b653] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) ratemon.h: Fix comments Mon, 18 Jan 2016 20:28:00 GMT Joel Sherrill [e39cdb8] * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/clockgetenableattr.c (deleted) * cpukit/posix/src/clocksetenableattr.c (deleted) posix: Remove clock_getenable_attr() and clock_setenable_attr() ... Thu, 10 Dec 2015 09:01:52 GMT Nick Withers [4202a31] * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/preinstall.am (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/sys/selinfo.h (moved) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) Chase Newlib sys/types.h / sys/select.h changes Thu, 14 Jan 2016 07:07:06 GMT Sebastian Huber [819a6b35] * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) arm: Honor cache for Cortex-M7 support Tue, 12 Jan 2016 13:36:56 GMT Sebastian Huber [3252126] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) arm: Accept Cortex-M7 multilib Fri, 15 Jan 2016 13:11:03 GMT Sebastian Huber [47a471a7] * cpukit/libblock/src/ramdisk-init.c (modified) libblock: Fix ramdisk::free_at_delete_request init Avoid ... Tue, 12 Jan 2016 11:02:57 GMT Sebastian Huber [e4752d1d] * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Fix alignment for AltiVec multilibs Mon, 11 Jan 2016 12:02:06 GMT Sebastian Huber [599d71f] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/timecounterimpl.h (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Statically initialize TOD handler Fri, 08 Jan 2016 11:11:03 GMT Sebastian Huber [1506658c] * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadstart.c (modified) score: Simplify _Thread_Start() Thu, 07 Jan 2016 08:55:45 GMT Sebastian Huber [ccd5434] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadentryadaptoridle.c (added) * cpukit/score/src/threadentryadaptornumeric.c (added) * cpukit/score/src/threadentryadaptorpointer.c (added) * cpukit/score/src/threadglobalconstruction.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadstart.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/sptests/sp54/init.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) score: Introduce Thread_Entry_information This avoids potential ... Fri, 08 Jan 2016 08:05:34 GMT Sebastian Huber [4e3bb2dd] * cpukit/rtems/src/tasks.c (modified) rtems: Fix warning Tue, 22 Dec 2015 08:40:48 GMT Sebastian Huber [44e9871] * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadglobalconstruction.c (modified) score: Avoid dead code in global construction Update #2514. Tue, 22 Dec 2015 08:13:08 GMT Sebastian Huber [fe100e16] * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Add fatal errors for NULL entry init tasks This simplifies ... Tue, 22 Dec 2015 06:56:57 GMT Sebastian Huber [f9f7321e] * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * testsuites/fstests/fspermission/test.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) Filesystem: Remove superfluous permission checks The permission is ... Sat, 26 Dec 2015 16:58:25 GMT Joel Sherrill [f6a8663e] * c/ACKNOWLEDGEMENTS (modified) * c/TOOL_TARGETS (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/h8300/Makefile.am (deleted) * c/src/lib/libbsp/h8300/acinclude.m4 (deleted) * c/src/lib/libbsp/h8300/configure.ac (deleted) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/h8300/Makefile.am (deleted) * cpukit/score/cpu/h8300/README (deleted) * cpukit/score/cpu/h8300/cpu.c (deleted) * cpukit/score/cpu/h8300/cpu_asm.S (deleted) * cpukit/score/cpu/h8300/h8300-exception-frame-print.c (deleted) * cpukit/score/cpu/h8300/preinstall.am (deleted) * cpukit/score/cpu/h8300/rtems/asm.h (deleted) * cpukit/score/cpu/h8300/rtems/score/cpu.h (deleted) * cpukit/score/cpu/h8300/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/h8300/rtems/score/h8300.h (deleted) * cpukit/score/cpu/h8300/rtems/score/types.h (deleted) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/h8300.t (deleted) * testsuites/libtests/configure.ac (modified) * testsuites/psxtests/psx04/task3.c (modified) Remove H8300 port updates #2452. Tue, 15 Dec 2015 17:25:01 GMT Joel Sherrill [f5201df] * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32r/Makefile.am (deleted) * c/src/lib/libbsp/m32r/acinclude.m4 (deleted) * c/src/lib/libbsp/m32r/configure.ac (deleted) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libdl/include/arch/m32r/machine/elf_machdep.h (deleted) * cpukit/libdl/rtl-mdreloc-m32r.c (deleted) * cpukit/libdl/rtl-shell.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (deleted) * cpukit/score/cpu/m32r/context_init.c (deleted) * cpukit/score/cpu/m32r/context_switch.S (deleted) * cpukit/score/cpu/m32r/cpu.c (deleted) * cpukit/score/cpu/m32r/cpu_asm.c (deleted) * cpukit/score/cpu/m32r/m32r-exception-frame-print.c (deleted) * cpukit/score/cpu/m32r/preinstall.am (deleted) * cpukit/score/cpu/m32r/rtems/asm.h (deleted) * cpukit/score/cpu/m32r/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32r/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32r/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32r/rtems/score/m32r.h (deleted) * cpukit/score/cpu/m32r/rtems/score/types.h (deleted) * cpukit/score/src/threadglobalconstruction.c (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/m32r.t (deleted) * doc/user/preface.texi (modified) * testsuites/libtests/configure.ac (modified) Remove M32R architecture updates #2446. Mon, 04 Jan 2016 08:55:59 GMT Sebastian Huber [a061f9d] * cpukit/score/src/watchdoginsert.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) score: Fix watchdog insert Under certain conditions a new watchdog ... Wed, 23 Dec 2015 20:44:02 GMT Aun-Ali Zaidi [d5154d0f] * c/src/ada-tests/ada_mvscn (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (modified) * c/src/ada-tests/mptests/mp02/Makefile.am (deleted) * c/src/ada-tests/mptests/mp02/config_base.h (deleted) * c/src/ada-tests/mptests/mp02/mptest.adb (deleted) * c/src/ada-tests/mptests/mp02/mptest.ads (deleted) * c/src/ada-tests/mptests/mp02/node1/Makefile.am (deleted) * c/src/ada-tests/mptests/mp02/node1/ada_mp02-node1.scn (deleted) * c/src/ada-tests/mptests/mp02/node1/config.h (deleted) * c/src/ada-tests/mptests/mp02/node1/mp02_node1.adb (deleted) * c/src/ada-tests/mptests/mp02/node2/Makefile.am (deleted) * c/src/ada-tests/mptests/mp02/node2/ada_mp02-node2.scn (deleted) * c/src/ada-tests/mptests/mp02/node2/config.h (deleted) * c/src/ada-tests/mptests/mp02/node2/mp02_node2.adb (deleted) * c/src/ada-tests/sptests/sp07/ada_sp07.scn (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/ada_sp09.scn (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada/rtems-tasks.adb (modified) * c/src/lib/libbsp/arm/csb336/times (modified) * c/src/lib/libbsp/arm/csb337/times (modified) * c/src/lib/libbsp/arm/edb7312/times (modified) * c/src/lib/libbsp/bfin/TLL6527M/times (modified) * c/src/lib/libbsp/bfin/eZKit533/times (modified) * c/src/lib/libbsp/i386/pc386/times_i486dx (modified) * c/src/lib/libbsp/i386/pc386/times_p5 (modified) * c/src/lib/libbsp/m68k/av5282/README (modified) * c/src/lib/libbsp/m68k/csb360/times (modified) * c/src/lib/libbsp/m68k/gen68302/times (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/idp/times (modified) * c/src/lib/libbsp/m68k/mcf5206elite/times (modified) * c/src/lib/libbsp/m68k/mcf52235/README (modified) * c/src/lib/libbsp/m68k/mcf5225x/README (modified) * c/src/lib/libbsp/m68k/mcf5235/README (modified) * c/src/lib/libbsp/m68k/mcf5329/README (modified) * c/src/lib/libbsp/m68k/mrm332/times (modified) * c/src/lib/libbsp/m68k/mvme162/times (modified) * c/src/lib/libbsp/m68k/mvme167/times (modified) * c/src/lib/libbsp/m68k/uC5282/TIMES (modified) * c/src/lib/libbsp/mips/csb350/times (modified) * c/src/lib/libbsp/mips/hurricane/times (modified) * c/src/lib/libbsp/nios2/nios2_iss/times (modified) * c/src/lib/libbsp/no_cpu/no_bsp/times (modified) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (modified) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx860 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750 (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/times.mvme2307 (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/README (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/times (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/powerpc/ss555/times (modified) * c/src/lib/libbsp/sh/gensh1/times (modified) * c/src/lib/libbsp/sparc/erc32/times (modified) * c/src/lib/libbsp/sparc/leon2/times (modified) * c/src/lib/libbsp/sparc/leon3/times (modified) * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * c/src/librtems++/src/rtemsTask.cc (modified) * cpukit/libcsupport/src/README (modified) * cpukit/libmisc/monitor/README (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/taskgetnote.c (deleted) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetnote.c (deleted) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * doc/user/conf.t (modified) * doc/user/intr.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) * testsuites/PROBLEMS (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/rtems++.scn (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/configure.ac (modified) * testsuites/mptests/mp02/Makefile.am (deleted) * testsuites/mptests/mp02/init.c (deleted) * testsuites/mptests/mp02/node1/Makefile.am (deleted) * testsuites/mptests/mp02/node1/mp02-node1.doc (deleted) * testsuites/mptests/mp02/node1/mp02-node1.scn (deleted) * testsuites/mptests/mp02/node2/Makefile.am (deleted) * testsuites/mptests/mp02/node2/mp02-node2.doc (deleted) * testsuites/mptests/mp02/node2/mp02-node2.scn (deleted) * testsuites/mptests/mp02/system.h (deleted) * testsuites/mptests/mp02/task1.c (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.scn (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/spnotepad01/Makefile.am (deleted) * testsuites/sptests/spnotepad01/init.c (deleted) * testsuites/sptests/spnotepad01/spnotepad01.doc (deleted) * testsuites/sptests/spnotepad01/spnotepad01.scn (deleted) * testsuites/sptests/spnotepad02/Makefile.am (deleted) * testsuites/sptests/spnotepad02/init.c (deleted) * testsuites/sptests/spnotepad02/spnotepad02.doc (deleted) * testsuites/sptests/spnotepad02/spnotepad02.scn (deleted) * testsuites/sptests/sptask_err04/sptask_err04.doc (modified) * testsuites/sptests/sptask_err04/sptask_err04.scn (modified) * testsuites/sptests/sptask_err04/system.h (modified) * testsuites/sptests/sptask_err04/task1.c (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * testsuites/tmtests/tmtests_plan.csv (modified) * testsuites/tools/generic/sorttimes.in (modified) api: Remove deprecated Notepads Notepads where a feature of RTEMS' ... Sun, 20 Dec 2015 20:47:12 GMT Sebastian Huber [a48b7c44] * cpukit/score/src/watchdogremove.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) score: Fix watchdog removal Under certain conditions a new watchdog ... Tue, 15 Dec 2015 10:25:47 GMT Sebastian Huber [07b76fd] * cpukit/score/src/kern_tc.c (modified) score: Avoid dependency on bcopy() Thu, 10 Dec 2015 09:04:54 GMT Nick Withers [7a0c485] * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) libmisc: Include missing header file, fix warnings Mon, 14 Dec 2015 13:07:40 GMT Sebastian Huber [e01b184] * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) rtems: Delete empty function Mon, 14 Dec 2015 12:10:24 GMT Sebastian Huber [173d1f8] * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) posix: Store unblocked signals Store the unblock signals to exploit ... Fri, 11 Dec 2015 10:09:13 GMT Sebastian Huber [54c3fbd] * cpukit/posix/src/pthread.c (modified) * cpukit/rtems/include/rtems/rtems/asrimpl.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Initialize thread control to zero This reduces the code size ... Fri, 11 Dec 2015 08:48:09 GMT Sebastian Huber [00dbecb8] * cpukit/score/src/rbtreeinsert.c (modified) score: Help GCC to inline a function Thu, 10 Dec 2015 13:10:48 GMT Sebastian Huber [df55d07f] * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Untangle thread actions Remove the thread action handler ... Tue, 22 Sep 2015 14:21:12 GMT Sebastian Huber [d0c39838] * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/sysinit.h (added) * cpukit/score/preinstall.am (modified) * doc/user/init.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spsysinit01/Makefile.am (added) * testsuites/sptests/spsysinit01/init.c (added) * testsuites/sptests/spsysinit01/spsysinit01.doc (added) * testsuites/sptests/spsysinit01/spsysinit01.scn (added) Use linker set for system initialization Make ... Wed, 09 Dec 2015 11:03:49 GMT Sebastian Huber [2858939a] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/avr/avrtest/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/acinclude.m4 (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m32r/m32rsim/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bsppretaskinghook.c (deleted) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * cpukit/libi2c/libi2c.h (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/support.t (modified) bsps: Delete superfluous bsp_pretasking_hook() Use the ... Thu, 10 Dec 2015 07:10:29 GMT Sebastian Huber [b318cb13] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Simplify _CPU_Get_current_per_CPU_control() Drop the ... Wed, 16 Sep 2015 05:13:58 GMT Sebastian Huber [b618d8c] * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/avr/avrtest/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/linkcmds (modified) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (modified) * c/src/lib/libbsp/lm32/lm32_evr/startup/linkcmds (modified) * c/src/lib/libbsp/lm32/milkymist/startup/linkcmds (modified) * c/src/lib/libbsp/m32c/m32cbsp/startup/linkcmds (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/csb360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds.flash (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/rom (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/mips/csb350/startup/linkcmds (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) * c/src/lib/libbsp/mips/hurricane/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/linkcmds (modified) * c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/score603e/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ss555/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom2ram (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim (modified) * c/src/lib/libbsp/sparc64/shared/startup/linkcmds (modified) * c/src/lib/libbsp/v850/gdbv850sim/startup/linkcmds (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/linkersets.h (added) * cpukit/score/preinstall.am (modified) * doc/user/Makefile.am (modified) * doc/user/c_user.texi (modified) * doc/user/example.texi (modified) * doc/user/linkersets.t (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/splinkersets01/Makefile.am (added) * testsuites/sptests/splinkersets01/init.c (added) * testsuites/sptests/splinkersets01/items.c (added) * testsuites/sptests/splinkersets01/sets.c (added) * testsuites/sptests/splinkersets01/splinkersets01.doc (added) * testsuites/sptests/splinkersets01/splinkersets01.h (added) * testsuites/sptests/splinkersets01/splinkersets01.scn (added) Add RTEMS linker sets Update #2408. Tue, 08 Dec 2015 07:43:41 GMT Sebastian Huber [9736283] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) score: Statically initialize system state Update #2408. Tue, 08 Dec 2015 07:34:08 GMT Sebastian Huber [bd91f446] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/src/apiext.c (modified) score: Delete unused API extensions Update #2408. Tue, 08 Dec 2015 07:33:08 GMT Sebastian Huber [60c5461] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/src/apiext.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Statically initialize API extensions Update #2408. Thu, 26 Nov 2015 13:08:56 GMT Sebastian Huber [8054b1c] * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/src/debug.c (deleted) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/debug.h (deleted) * cpukit/score/preinstall.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp10/Makefile.am (deleted) * testsuites/sptests/sp10/init.c (deleted) * testsuites/sptests/sp10/sp10.doc (deleted) * testsuites/sptests/sp10/sp10.scn (deleted) * testsuites/sptests/spregion_err01/init.c (modified) * testsuites/sptests/spsize/size.c (modified) Remove Close #2477. Thu, 26 Nov 2015 13:11:19 GMT Sebastian Huber [a062014] * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) Delete _Region_Debug_Walk() The expensive heap walks are ... Thu, 26 Nov 2015 06:29:33 GMT Sebastian Huber [5055281] * cpukit/libcsupport/include/rtems/libcsupport.h (modified) Delete unused declarations and define Wed, 25 Nov 2015 08:01:57 GMT Sebastian Huber [443c61ec] * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/newlibc_init.c (deleted) Delete empty libc_init() Wed, 25 Nov 2015 07:33:31 GMT Sebastian Huber [ac5f2442] * cpukit/configure.ac (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) Require __getreent() This function is used by Newlib since ... Wed, 25 Nov 2015 06:55:00 GMT Sebastian Huber [8ce0b0cb] * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/score/src/threadtimeout.c (modified) Fix _Assert() statement Tue, 24 Nov 2015 14:58:26 GMT Sebastian Huber [f6a1ef9] * cpukit/configure.ac (modified) * cpukit/posix/include/rtems/posix/cancel.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/pthread.c (modified) posix: Require struct _pthread_cleanup_context This structure is ... Mon, 23 Nov 2015 09:09:06 GMT Pavel Pisa [9394aa5e] * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libmisc/untar/untar.c (modified) untar: do not exit with error when created directory already exists. ... Wed, 18 Nov 2015 08:22:48 GMT Sebastian Huber [8708900] * cpukit/include/sys/priority.h (modified) Provide dummy Required by new network stack. Tue, 17 Nov 2015 14:22:18 GMT Sebastian Huber [8f3ec7c0] * cpukit/libcsupport/include/sys/ttycom.h (modified) Import latest from FreeBSD Required by new network stack. Tue, 17 Nov 2015 14:12:34 GMT Sebastian Huber [f757bb7c] * cpukit/libcsupport/include/sys/sockio.h (modified) Merge with latest from FreeBSD Required by new ... Tue, 17 Nov 2015 13:57:47 GMT Sebastian Huber [836803f] * cpukit/libcsupport/include/sys/filio.h (modified) * cpukit/libcsupport/include/sys/ioccom.h (modified) Import latest from FreeBSD Required by new network stack. Mon, 16 Nov 2015 13:13:28 GMT Daniel Cederman [78cac9b] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Fix context switch on SMP We must not load registers (e.g. ... Tue, 10 Nov 2015 16:23:12 GMT Sebastian Huber [b84a51c] * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/score/src/threadtimeout.c (modified) score: Fix race condition on SMP We must ensure that the ... Wed, 11 Nov 2015 10:49:45 GMT Sebastian Huber [5c7bfcf] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) Fix interrupt epilogue for ARMv7-AR and PowerPC Wed, 11 Nov 2015 09:47:52 GMT Sebastian Huber [4fee129] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/src/timerserver.c (modified) Introduce general purpose system server event Use this event for ... Tue, 03 Nov 2015 10:10:21 GMT Sebastian Huber [aa47302] * cpukit/sapi/include/rtems/chain.h (modified) * doc/user/chains.t (modified) * testsuites/sptests/spchain/init.c (modified) sapi: Add rtems_chain_get_first_unprotected() Close #2459. Wed, 04 Nov 2015 06:39:45 GMT Sebastian Huber [eab538c] * cpukit/score/src/threadqops.c (modified) score: Fix warning Close #2454. Mon, 02 Nov 2015 07:20:11 GMT Sebastian Huber [08a807b0] * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * testsuites/libtests/block14/block14.scn (modified) * testsuites/libtests/block14/init.c (modified) libblock: Print block sizes and count Fri, 30 Oct 2015 12:00:01 GMT Sebastian Huber [09d4f62] * cpukit/libblock/src/media.c (modified) libblock: Avoid NULL pointer access Thu, 29 Oct 2015 21:10:31 GMT Jan Sommer [65243416] * cpukit/libgnat/adasupp.c (modified) ada: Add missing include Include stackimpl.h otherwise ... Tue, 27 Oct 2015 09:20:02 GMT Sebastian Huber [e96feeb] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add FSL cache defines Tue, 20 Oct 2015 19:47:10 GMT Joel Sherrill [69be1a22] * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/psxtests/psximfs02/init.c (modified) CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error ... Fri, 16 Oct 2015 06:26:44 GMT Sebastian Huber [bc792bb] * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) basdefs.h: Add and use RTEMS_PACKED Fri, 16 Oct 2015 06:21:48 GMT Sebastian Huber [f97536d] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/_calloc_r.c (modified) * cpukit/libcsupport/src/_free_r.c (modified) * cpukit/libcsupport/src/_malloc_r.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/envlock.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/flockfile.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/ftrylockfile.c (modified) * cpukit/libcsupport/src/funlockfile.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/isatty_r.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/setpgid.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcgetpgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/devnull/devnull.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/fb/mw_uid.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/monitor/mon-part.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/monitor/mon-region.c (modified) * cpukit/libmisc/monitor/mon-sema.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/err.h (modified) * cpukit/libmisc/shell/extern-cp.h (modified) * cpukit/libmisc/shell/extern-ls.h (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) * cpukit/libmisc/shell/main_dd.c (modified) * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_mount_nfs.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) * cpukit/libmisc/shell/utils-cp.c (modified) * cpukit/libmisc/shell/utils-ls.c (modified) * cpukit/libmisc/shell/verr.c (modified) * cpukit/libmisc/shell/verrx.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/threadqflush.c (modified) * testsuites/libtests/devfs04/test_driver.c (modified) * testsuites/libtests/deviceio01/test_driver.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spfatal_support/consume_sems.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) basdefs.h: Add and use RTEMS_UNUSED Fri, 16 Oct 2015 06:17:52 GMT Sebastian Huber [c52568d] * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) basdefs.h: Add and use RTEMS_DEPRECATED Fri, 16 Oct 2015 06:17:20 GMT Sebastian Huber [a3ba5b37] * cpukit/score/include/rtems/score/basedefs.h (modified) basdefs.h: Add RTEMS_PURE Fri, 16 Oct 2015 06:15:03 GMT Sebastian Huber [143696a] * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) basedefs.h: Add and use RTEMS_NO_RETURN Fri, 16 Oct 2015 06:13:15 GMT Sebastian Huber [2423857] * cpukit/score/include/rtems/score/basedefs.h (modified) basedefs.h: Add compiler attributes Wed, 21 Oct 2015 07:52:36 GMT Sebastian Huber [7d59bb6] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) RFS: Fix resource leak Close #2433. Mon, 19 Oct 2015 06:57:31 GMT Sebastian Huber [c03c71b] * cpukit/dtc/libfdt/Makefile.am (modified) * cpukit/dtc/libfdt/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/libfdt01/Makefile.am (modified) libfdt: Merge into librtemscpu This allows BSPs to use this library. Thu, 15 Oct 2015 09:38:03 GMT Sebastian Huber [175263e] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/dtc/README (added) * cpukit/dtc/README.license (added) * cpukit/dtc/libfdt/Makefile.am (added) * cpukit/dtc/libfdt/TODO (added) * cpukit/dtc/libfdt/fdt.c (added) * cpukit/dtc/libfdt/fdt.h (added) * cpukit/dtc/libfdt/fdt_addresses.c (added) * cpukit/dtc/libfdt/fdt_empty_tree.c (added) * cpukit/dtc/libfdt/fdt_ro.c (added) * cpukit/dtc/libfdt/fdt_rw.c (added) * cpukit/dtc/libfdt/fdt_strerror.c (added) * cpukit/dtc/libfdt/fdt_sw.c (added) * cpukit/dtc/libfdt/fdt_wip.c (added) * cpukit/dtc/libfdt/libfdt.h (added) * cpukit/dtc/libfdt/libfdt_env.h (added) * cpukit/dtc/libfdt/libfdt_internal.h (added) * cpukit/dtc/libfdt/preinstall.am (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/libfdt01/Makefile.am (added) * testsuites/libtests/libfdt01/init.c (added) * testsuites/libtests/libfdt01/libfdt01.doc (added) * testsuites/libtests/libfdt01/libfdt01.scn (added) * testsuites/libtests/libfdt01/some.c (added) * testsuites/libtests/libfdt01/some.dts (added) * testsuites/libtests/libfdt01/some.h (added) libfdt: Initial import Import from: ... Thu, 10 Sep 2015 15:12:06 GMT Sebastian Huber [cff773f] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libstdthreads/Makefile.am (added) * cpukit/libstdthreads/call_once.c (modified) * cpukit/libstdthreads/cnd.c (modified) * cpukit/libstdthreads/mtx.c (modified) * cpukit/libstdthreads/thrd.c (modified) * cpukit/libstdthreads/tss.c (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spstdthreads01/Makefile.am (added) * testsuites/sptests/spstdthreads01/init.c (added) * testsuites/sptests/spstdthreads01/spstdthreads01.doc (added) * testsuites/sptests/spstdthreads01/spstdthreads01.scn (added) libstdthreads: Add C11 threads Wed, 16 Sep 2015 04:13:45 GMT Sebastian Huber [e333089] * cpukit/libstdthreads/call_once.c (added) * cpukit/libstdthreads/cnd.c (added) * cpukit/libstdthreads/mtx.c (added) * cpukit/libstdthreads/thrd.c (added) * cpukit/libstdthreads/tss.c (added) libstdthreads: Import from FreeBSD Wed, 07 Oct 2015 07:13:23 GMT Sebastian Huber [6959e66] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany: Delete CPU_UNROLL_ENQUEUE_PRIORITY Fri, 02 Oct 2015 05:59:24 GMT Sebastian Huber [ba1ed52] * cpukit/score/include/rtems/score/smplock.h (modified) SMP: Optimize ticket lock implementation This reverts the relevant ... Fri, 02 Oct 2015 05:30:13 GMT Sebastian Huber [08317ef3] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Use wrtee for e6500 multilib This reduces the code size. Fri, 25 Sep 2015 12:34:24 GMT Sebastian Huber [258ad71] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) SMP: Fix and optimize thread dispatching According to the C11 and ... Mon, 28 Sep 2015 05:29:11 GMT Sebastian Huber [aee6a1d0] * cpukit/score/include/rtems/score/threadimpl.h (modified) SMP: Simplify thread lock operations Sat, 26 Sep 2015 11:03:16 GMT Sebastian Huber [8d296cd5] * cpukit/score/include/rtems/score/atomic.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpatomic01/smpatomic01.doc (modified) * testsuites/sptests/spatomic01/init.c (modified) * testsuites/sptests/spatomic01/spatomic01.doc (modified) score: Use uintptr_t for atomic pointer operations Do not obfuscate ... Fri, 25 Sep 2015 19:31:00 GMT Sebastian Huber [1f7c5c88] * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * testsuites/sptests/spatomic01/init.c (modified) score: Fix atomic compare exchange Fri, 18 Sep 2015 21:53:31 GMT Martin Galvan [f52885b] * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) ARMv7M: Improve exception handler routine and add comments on SP ... Thu, 27 Aug 2015 18:19:24 GMT Sudarshan Rajagopalan [7263a50] * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) Fix exception handler for supporting FPU Mon, 14 Sep 2015 05:10:24 GMT Sebastian Huber [314ff3c4] * cpukit/score/src/mutex.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) score: Fix resource count for self-contained mutex
