# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 18:35:40 Tue, 16 May 2017 15:37:27 GMT Gedare Bloom [a330c5d] * cpukit/posix/src/mmap.c (modified) posix: clarify expression with parentheses Close #3010. Fri, 12 May 2017 07:53:35 GMT Sebastian Huber [6bc63df1] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp37/system.h (modified) * testsuites/sptests/spcbssched01/system.h (modified) * testsuites/sptests/spcbssched02/system.h (modified) * testsuites/sptests/spcbssched03/system.h (modified) * testsuites/sptests/spedfsched01/system.h (modified) * testsuites/sptests/spedfsched02/system.h (modified) * testsuites/sptests/spedfsched03/system.h (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm22/system.h (modified) confdefs.h: Add SMP enabled field to configuration Do not use the ... Tue, 16 May 2017 07:47:08 GMT Sebastian Huber [0b8084c2] * cpukit/sapi/include/confdefs.h (modified) confdefs.h: Fix compile error in non-SMP cfg Bug introduced by ... Fri, 12 May 2017 06:35:36 GMT Sebastian Huber [f778b7f3] * cpukit/sapi/include/confdefs.h (modified) * testsuites/sptests/sp65/init.c (modified) confdefs.h: Use SMP scheduler only if necessary Update #3001. Thu, 11 May 2017 09:03:00 GMT Sebastian Huber [13097181] * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATION Enable the SMP ... Wed, 15 Mar 2017 18:31:00 GMT Gedare Bloom [87de70a2] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (modified) * cpukit/posix/include/rtems/posix/shm.h (modified) * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxshm02/system.h (modified) posix/mman: add mmap support for shm objects Update #2859. Mon, 13 Mar 2017 16:00:35 GMT Chris Johns [8290f95c] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: Add mmap/unmap support for mapping files. This version of ... Fri, 31 Mar 2017 19:23:47 GMT Gedare Bloom [bd9d5eb] * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/shmopen.c (modified) posix/shm: replace threadq with mutex (allocator lock) Closes #2957. Wed, 15 Mar 2017 18:29:19 GMT Gedare Bloom [889eb76] * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/shmopen.c (modified) posix/mman: update atime on shared memory read call Update #2859. Tue, 02 May 2017 08:19:34 GMT Sebastian Huber [e0627c69] * cpukit/configure.ac (modified) cpukit: Fix __RTEMS_REVISION__ define Wed, 08 Mar 2017 11:59:07 GMT Javier Jalle [6234abe] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l4stat.h (added) * c/src/lib/libbsp/sparc/shared/stat/l4stat.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l4stat: Initial driver commit Wed, 15 Mar 2017 13:38:21 GMT Javier Jalle [c241236] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * c/src/lib/libbsp/sparc/shared/include/memscrub.h (added) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, memscrub: add GR740 memory scrubber driver Wed, 15 Mar 2017 14:04:33 GMT Javier Jalle [d79429f] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/griommu.h (added) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, griommu: add GR740 IOMMU driver The driver is limited to the ... Tue, 21 Feb 2017 08:14:46 GMT Javier Jalle [dfa86338] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l2c.h (added) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l2cache: add GR740 L2-Cache driver Fri, 07 Apr 2017 06:30:46 GMT Daniel Hellstrom [7075fb11] * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) drvmgr: ability to configure IRQ affinity Tue, 31 Jan 2017 09:13:41 GMT Javier Jalle [61788e76] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) leon, GR-CPCI-GR740: Added peripheral PCI driver Tue, 02 May 2017 06:06:12 GMT Sebastian Huber [6b42018e] * cpukit/libmisc/shell/print_heapinfo.c (modified) shell: Fix format specifiers Fri, 28 Apr 2017 16:11:14 GMT Joel Sherrill [20775247] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h: Add PRIdrtems_vector_number. Missed in previous commit Thu, 27 Apr 2017 23:52:01 GMT Joel Sherrill [12f9c5b7] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Reorder to make priority a scoped variable Wed, 26 Apr 2017 20:42:09 GMT Joel Sherrill [c16d45a5] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Reorder to make priority a scoped variable Wed, 26 Apr 2017 01:14:28 GMT Joel Sherrill [9e6ef36] * cpukit/include/rtems/inttypes.h (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum Wed, 26 Apr 2017 01:02:09 GMT Joel Sherrill [03e4be12] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning Wed, 26 Apr 2017 01:01:41 GMT Joel Sherrill [65807379] * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning Tue, 25 Apr 2017 18:57:21 GMT Joel Sherrill [c723ee4] * cpukit/libdl/rtl-obj-cache.c (modified) libdl/rtl-obj-cache.c: Fix printf() format warning Tue, 25 Apr 2017 18:57:03 GMT Joel Sherrill [6601684f] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Fix used before initialized warning Tue, 25 Apr 2017 18:56:31 GMT Joel Sherrill [f6bd41e] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxie/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 18:39:50 GMT Joel Sherrill [fdfbb0a8] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 16:42:18 GMT Joel Sherrill [7db09923] * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number ... Tue, 25 Apr 2017 16:41:35 GMT Joel Sherrill [28e5749e] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix typo to eliminate warning Mon, 24 Apr 2017 17:00:43 GMT Joel Sherrill [b261dec] * cpukit/libmisc/xz/xz_config.h (modified) xz/xz_config.h: Address unable to inline warning Mon, 24 Apr 2017 16:18:47 GMT Joel Sherrill [3144292b] * cpukit/libdl/rtl-obj-cache.c (modified) libdl/rtl-obj-cache.c: Use PRIdoff_t to avoid printf() format ... Mon, 24 Apr 2017 01:35:41 GMT Joel Sherrill [a300ca1b] * cpukit/rtems/src/ratemonreportstatistics.c (modified) ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and ... Sun, 23 Apr 2017 17:57:27 GMT Joel Sherrill [0c334a5] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix not a prototype warning Sun, 23 Apr 2017 17:53:44 GMT Joel Sherrill [473a3cd] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h: Add PRIdioctl_command_t Sat, 22 Apr 2017 19:15:22 GMT Joel Sherrill [438ca2f] * cpukit/configure.ac (modified) * cpukit/include/rtems/inttypes.h (modified) * testsuites/psxtests/include/pmacros.h (modified) rtems/inttypes.h: Add blksize_t and blkcnt_t Wed, 19 Apr 2017 04:33:29 GMT Chris Johns [7f95cc0] * cpukit/libdebugger/rtems-debugger-server.c (modified) libdebugger: Fix the mode on task create. Clean up warnings. Closes ... Tue, 18 Apr 2017 02:44:44 GMT Chris Johns [4fd25c4] * cpukit/libmisc/monitor/mon-config.c (modified) libmisc/monitor: Correctly print unlimited configuration table ... Fri, 14 Apr 2017 20:18:56 GMT Joel Sherrill [d420b67] * cpukit/configure.ac (modified) * cpukit/include/rtems/inttypes.h (modified) * testsuites/support/include/tmacros.h (modified) Merge tmacros.h PRIxxx constants from testsuites/ into ... Fri, 14 Apr 2017 18:55:48 GMT Joel Sherrill [54bdf0c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/inttypes.h (added) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/preinstall.am (modified) rtems/inttypes.h: New file. Uses contents from cpukit Provide ... Fri, 14 Apr 2017 07:12:44 GMT Chris Johns [b53ad46] * cpukit/libdebugger/rtems-debugger-arm.c (modified) * cpukit/libdebugger/rtems-debugger-target.c (modified) libdebugger: Work around assert when using _Thread_Executing. Using ... Sat, 08 Apr 2017 10:30:50 GMT Cillian O'Donnell [62c238e] * cpukit/score/cpu/i386/cpu.c (modified) cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning. Mon, 10 Apr 2017 13:41:02 GMT Kevin Kirspel [d2390ce4] * cpukit/libcsupport/src/termios.c (modified) Updating default termios initialization for dedicated input/output ... Fri, 07 Apr 2017 20:40:11 GMT Cillian O'Donnell [2c23639] * cpukit/libdl/rtl-obj-cache.c (modified) libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warnings Thu, 06 Apr 2017 23:24:58 GMT Joel Sherrill [c475924d] * cpukit/libmisc/xz/xz_config.h (modified) xz_config.h: Define XZ_USE_CRC64 close #2909. Wed, 05 Apr 2017 09:28:46 GMT Sebastian Huber [46f05b92] * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) SMP: Simplify SMP multicast actions Tue, 04 Apr 2017 08:39:45 GMT Sebastian Huber [b3bfc242] * cpukit/libcsupport/include/sys/event.h (modified) sys/event.h: Update to FreeBSD head 2017-02-13 Mon, 03 Apr 2017 10:51:51 GMT Sebastian Huber [1301468] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) bsps: Fix baud settings Update #2897. Thu, 30 Mar 2017 11:59:16 GMT Sebastian Huber [36f0ac2] * cpukit/configure.ac (modified) configure: Remove defunct configure stuff Thu, 30 Mar 2017 00:06:24 GMT Chris Johns [bba48d9] * cpukit/libdl/include/sys/exec_elf.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * testsuites/libtests/dl05/dl05.scn (modified) libdl: Support link ordered loading of ELF sections. The ARM C++ ... Mon, 27 Mar 2017 06:01:38 GMT Sebastian Huber [cd3d747] * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Optimize context switch Set CPU_ENABLE_ROBUST_THREAD_DISPATCH ... Tue, 28 Mar 2017 05:51:16 GMT Sebastian Huber [82c0836] * cpukit/posix/src/pthreaddetach.c (modified) posix: Fix pthread_detach() internal lock acquire Tue, 28 Mar 2017 06:18:06 GMT Sebastian Huber [70ddaa0e] * cpukit/rtems/src/semsetpriority.c (modified) rtems: Fix error return path Mon, 27 Mar 2017 12:23:52 GMT Sebastian Huber [5f382713] * cpukit/Makefile.am (modified) * cpukit/preinstall.am (modified) cpukit: Fix Makefile.am and update preinstall.am Update #2897. Mon, 27 Mar 2017 08:30:23 GMT Sebastian Huber [94a4865] * cpukit/libcsupport/src/termios.c (modified) termios: Avoid invalid memory access Update #2897. Tue, 21 Mar 2017 19:39:48 GMT Kevin Kirspel [1c6926c1] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2400.h (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2410.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (added) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/include/sys/ttydefaults.h (added) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfmakeraw.c (modified) * cpukit/libcsupport/src/cfmakesane.c (added) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/preinstall.am (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.scn (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios02/termios02.scn (modified) * testsuites/libtests/termios03/termios03.scn (modified) * testsuites/libtests/termios04/termios04.scn (modified) * testsuites/libtests/termios05/termios05.scn (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.scn (modified) * testsuites/libtests/termios07/termios07.scn (modified) * testsuites/libtests/termios08/termios08.scn (modified) * tools/cpu/sh/sci.c (modified) termios: Synchronize with latest FreeBSD headers Adding modified ... Thu, 16 Mar 2017 14:12:20 GMT Sebastian Huber [d50ab079] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) dosfs: Fix file name search Do not use our long file name entry ... Thu, 16 Mar 2017 10:59:23 GMT Sebastian Huber [dfd879fa] * cpukit/libfs/src/dosfs/msdos_dir.c (modified) dosfs: Fix race condition msdos_dir_read() Obtain file system ... Thu, 16 Mar 2017 07:03:42 GMT Sebastian Huber [6c988987] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Rename fat_entries to lfn_entries The name "fat_entries" for ... Thu, 16 Mar 2017 06:44:38 GMT Sebastian Huber [5f8ed0d] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Fix long file name padding Update #2934. Thu, 16 Mar 2017 06:37:20 GMT Sebastian Huber [e625a57] * cpukit/libfs/src/dosfs/msdos_conv.c (modified) dosfs: msdos_filename_utf8_to_short_name_for_save Simplify. Tue, 14 Mar 2017 10:41:18 GMT Sebastian Huber [b1daf0f] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Fix msdos_add_file() Make sure that long file names work ... Tue, 14 Mar 2017 09:28:19 GMT Sebastian Huber [1a9483e2] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Simplify msdos_add_file() Update #2929. Tue, 14 Mar 2017 08:36:07 GMT Sebastian Huber [3efe749] * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Add and use msdos_lfn_checksum() Update #2929. Tue, 14 Mar 2017 07:26:40 GMT Sebastian Huber [063eb574] * cpukit/libfs/src/dosfs/fat_file.c (modified) dosfs: Simplify fat_file_open() Update #2929. Tue, 14 Mar 2017 07:13:07 GMT Sebastian Huber [ccd4a7f] * cpukit/libfs/src/dosfs/msdos_create.c (modified) dosfs: Simplify msdos_creat_node() Update #2929. Mon, 13 Mar 2017 14:20:20 GMT Sebastian Huber [e69ee36] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsdosfsname02/Makefile.am (added) * testsuites/fstests/fsdosfsname02/fsdosfsname02.doc (added) * testsuites/fstests/fsdosfsname02/fsdosfsname02.scn (added) * testsuites/fstests/fsdosfsname02/init.c (added) * testsuites/fstests/fsdosfswrite01/init.c (modified) dosfs: Fix fat_file_write() Remove forced overwrite which leads to ... Tue, 14 Mar 2017 12:59:09 GMT Sebastian Huber [1becaa9] * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) dosfs: Fix msdos_utf8_normalize_and_fold() It is all right in case ... Thu, 16 Mar 2017 10:54:29 GMT Sebastian Huber [66fac03] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * testsuites/fstests/fsnofs01/init.c (modified) libio: Fix deadlock in location management Perform a ... Thu, 09 Mar 2017 13:32:04 GMT Sebastian Huber [b437a360] * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) arm: Fix CPU context validation for Cortex-R4 Do not touch the ... Tue, 07 Mar 2017 13:32:42 GMT Sebastian Huber [2433a8ab] * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (deleted) * c/src/lib/libbsp/arm/shared/abort/abort.h (deleted) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (deleted) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/start/start.S (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (deleted) * cpukit/score/cpu/arm/arm_exc_handler_low.S (deleted) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Remove legacy execption support Tue, 07 Mar 2017 12:41:37 GMT Sebastian Huber [36338fb] * cpukit/libmisc/monitor/mon-sema.c (modified) monitor: Do not zero sema id and name Tue, 07 Mar 2017 12:07:02 GMT Sebastian Huber [088acbb0] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulersmp.c (added) score: Fix scheduler yield in SMP configurations Check that no ask ... Mon, 06 Mar 2017 10:16:25 GMT Sebastian Huber [f61195b2] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Mon, 06 Feb 2017 14:11:55 GMT Daniel Cederman [84557ef] * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) libdrvmgr: remove braces Wed, 01 Feb 2017 09:48:38 GMT Daniel Hellstrom [418149c8] * cpukit/libdrvmgr/drvmgr.c (modified) libdrvmgr: added default BSP init level hook Fri, 02 Jan 2015 12:17:18 GMT Daniel Hellstrom [91df5a69] * cpukit/libpci/pci_access.c (modified) libpci: code cleanup Thu, 02 Mar 2017 06:54:52 GMT Sebastian Huber [1f618ab0] * cpukit/libcsupport/src/posix_devctl.c (modified) posix_devctl: Fix for pre C99 Use __restrict just like in ... Mon, 27 Feb 2017 10:50:30 GMT Sebastian Huber [a60db69] * cpukit/libfs/src/dosfs/msdos_format.c (modified) dosfs: Fix FAT32 formatter The second FAT entry contains a bit to ... Mon, 27 Feb 2017 09:40:49 GMT Sebastian Huber [267de79a] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Directories should have a file size of 0 Close #2755. Tue, 28 Feb 2017 08:12:13 GMT Sebastian Huber [f71ccc34] * cpukit/libcsupport/src/termios.c (modified) termios: Simplify some calculations Use the modular arithmetic ... Fri, 24 Feb 2017 13:44:04 GMT Sebastian Huber [36635433] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Implement non-blocking write Thu, 23 Feb 2017 14:43:41 GMT Sebastian Huber [a165a96] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Make write POSIX compatible Currently only blocking ... Thu, 23 Feb 2017 14:19:47 GMT Sebastian Huber [c41b47e3] * cpukit/libcsupport/src/termios.c (modified) termios: Introduce doTransmit() Thu, 23 Feb 2017 13:04:24 GMT Sebastian Huber [5244d31e] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Simplify oproc() Call rtems_termios_puts() only once. ... Fri, 24 Feb 2017 09:29:05 GMT Sebastian Huber [c80f6aa9] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Fix infinite loop in receive path In canonical mode, the ... Thu, 23 Feb 2017 10:35:44 GMT Sebastian Huber [9fa0f54] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Change receive callback invocation Call the receive ... Thu, 23 Feb 2017 08:38:54 GMT Sebastian Huber [49d8f653] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Change tty_rcvwakeup to bool Optimize callout invocation check. Thu, 23 Feb 2017 09:35:16 GMT Sebastian Huber [9f69ac2] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/termios09/Makefile.am (added) * testsuites/libtests/termios09/init.c (added) * testsuites/libtests/termios09/termios09.doc (added) * testsuites/libtests/termios09/termios09.scn (added) termios: Ignore carriage return early if desired In case carriage ... Thu, 23 Feb 2017 09:06:52 GMT Sebastian Huber [bb087cb0] * cpukit/libcsupport/src/termios.c (modified) termios: Protect raw input buffer with device lock Use the device ... Thu, 23 Feb 2017 08:12:36 GMT Sebastian Huber [d60c2d79] * cpukit/libcsupport/src/termios.c (modified) termios: Simplify rtems_termios_read_tty() Remove dead code. ... Tue, 21 Feb 2017 08:01:49 GMT Sebastian Huber [5bfeddc0] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) termios: Add kqueue() and poll() support Real implementation is ... Tue, 21 Feb 2017 07:58:29 GMT Sebastian Huber [c833970] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_WEAK_ALIAS() Tue, 21 Feb 2017 14:25:03 GMT Sebastian Huber [3398602] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_request_submit() This function may be ... Mon, 10 Aug 2015 04:21:02 GMT Nick Withers [df184eb] * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) Remove old CVS keywords Update #2388. Wed, 15 Feb 2017 12:22:36 GMT Sebastian Huber [c847451b] * cpukit/sapi/include/rtems/fatal.h (modified) sapi: Fix warnings Wed, 15 Feb 2017 12:05:27 GMT Sebastian Huber [661be20] * cpukit/libmisc/shell/hexdump-conv.c (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) shell: Fix warnings Wed, 15 Feb 2017 10:19:50 GMT Sebastian Huber [f5cf2fe] * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) libdl: Fix warning Wed, 15 Feb 2017 10:09:32 GMT Sebastian Huber [7a462cc] * cpukit/score/src/threadinitialize.c (modified) score: Fix warning Tue, 14 Feb 2017 10:10:40 GMT Sebastian Huber [468e9a4] * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) monitor: Print short and long task names Print wait object ... Wed, 01 Feb 2017 13:10:18 GMT Sebastian Huber [54835ae] * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcapture01/init.c (modified) * testsuites/smptests/smpcapture02/init.c (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/smptests/smpipi01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpmutex02/init.c (modified) * testsuites/smptests/smppsxaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschedaffinity01/init.c (modified) * testsuites/smptests/smpschedaffinity02/init.c (modified) * testsuites/smptests/smpschedaffinity03/init.c (modified) * testsuites/smptests/smpschedaffinity04/init.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) * testsuites/smptests/smpschedsem01/init.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler04/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpstrongapa01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS Rename ...
