# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 20:18:07 Wed, 18 Dec 2013 17:37:47 GMT Alan Cudmore [9b48dc6] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) For PR 2162 - RFS File System - statvfs reports 1 block free This ... Wed, 18 Dec 2013 16:39:19 GMT Alan Cudmore [e60b7b1] * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) For PR 2163 - RFS File System - fix group search algorithm bug This ... Mon, 16 Dec 2013 13:45:26 GMT Sebastian Huber [f859d20] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix set by but not used warning Mon, 16 Dec 2013 09:55:27 GMT Sebastian Huber [fb664a2] * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) nfsclient: Move defines to cover all header files Fri, 13 Dec 2013 12:57:06 GMT Sebastian Huber [99c2323] * cpukit/libfs/src/jffs2/src/os-rtems.h (modified) JFFS2: Do not re-define struct iovec Mon, 16 Dec 2013 00:59:51 GMT Chris Johns [259328a7] * cpukit/libmisc/shell/main_help.c (modified) * doc/shell/general.t (modified) cpukit/shell: Control help break with SHELL_LINES env variable. ... Sat, 14 Dec 2013 17:56:33 GMT Joel Sherrill [4402308b] * cpukit/score/cpu/no_cpu/rtems/score/cpusmplock.h (modified) no_cpu/cpusmplock.h: Clean up to be compilable Mon, 09 Dec 2013 20:22:33 GMT Joel Sherrill [801a1fc6] * cpukit/configure.ac (modified) cpukit/configure.ac: Probe for SMP affinity methods Wed, 11 Dec 2013 08:39:09 GMT Sebastian Huber [98e5c95] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * testsuites/sptests/spfifo01/init.c (modified) PR2160: imfs: Use ENOSYS for unsupported nodes Return an error ... Tue, 10 Dec 2013 15:08:16 GMT Joel Sherrill [0f01de2b] * cpukit/posix/src/alarm.c (modified) alarm.c: Use _Assert() not assert() Tue, 10 Dec 2013 04:00:27 GMT Chris Johns [c59f668] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) PR2138: rtems_rfs_rtems_initialize() can erroneously set errno. ... Tue, 10 Dec 2013 01:53:13 GMT Joel Sherrill [798b8da] * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) Merge branch 'master' into am Mon, 09 Dec 2013 21:36:38 GMT Joel Sherrill [967c1438] * cpukit/posix/src/alarm.c (modified) alarm.c: Per comment add debug code for kill() failing This is ... Mon, 09 Dec 2013 21:28:55 GMT Joel Sherrill [8ae999c3] * cpukit/posix/src/pthread.c (modified) pthread.c: Use UINT32_MAX rather than constant value Mon, 09 Dec 2013 21:25:16 GMT Joel Sherrill [327fbd6] * cpukit/posix/src/condwaitsupp.c (modified) condwaitsupp.c: Return EPERM if waiting and mutex is not locked ... Mon, 09 Dec 2013 21:12:36 GMT Joel Sherrill [96281908] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) psignalimpl.h: Remove dead comment Mon, 09 Dec 2013 21:10:55 GMT Joel Sherrill [fa820b9] * cpukit/posix/src/pthread.c (modified) pthread.c: Remove XXX and use SIGNAL_ constants Mon, 09 Dec 2013 21:04:40 GMT Joel Sherrill [01d43180] * cpukit/posix/include/rtems/posix/config.h (modified) posix/config.h: Comment clean up Mon, 09 Dec 2013 20:37:03 GMT Joel Sherrill [2b3a648] * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/rtems/src/signalcatch.c (modified) signalcatch.c: Remove junk comment Mon, 09 Dec 2013 19:46:50 GMT Joel Sherrill [16b1c350] * cpukit/posix/include/rtems/posix/timerimpl.h (modified) timerimpl.h: Comment clean up Mon, 09 Dec 2013 19:46:37 GMT Joel Sherrill [610825b1] * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) semaphoreimpl.h: Comment clean up Mon, 09 Dec 2013 19:29:51 GMT Joel Sherrill [849b98e8] * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) mqueueimpl.h: Comment clean up Mon, 09 Dec 2013 19:29:41 GMT Joel Sherrill [07a3aa9d] * cpukit/posix/include/rtems/posix/condimpl.h (modified) condimpl.h: Comment clean up Mon, 09 Dec 2013 19:13:33 GMT Joel Sherrill [71f2a83d] * cpukit/posix/include/rtems/posix/ptimer.h (modified) ptimer.h: Comment clean up Mon, 09 Dec 2013 18:53:24 GMT Joel Sherrill [4600bd7c] * cpukit/posix/include/rtems/posix/muteximpl.h (modified) muteximpl.h: Comment clean up Mon, 09 Dec 2013 18:52:55 GMT Joel Sherrill [1de916b4] * cpukit/posix/src/pspin.c (modified) pspin.c: Comment clean up Mon, 09 Dec 2013 18:52:43 GMT Joel Sherrill [7bb33391] * cpukit/posix/src/pbarrier.c (modified) pbarrier.c: Comment clean up Tue, 10 Dec 2013 01:37:05 GMT Chris Johns [663ffd0e] * cpukit/libnetworking/lib/syslog.c (modified) PR2161: Set the source port to SYSLOG in the syslog socket. Tue, 10 Dec 2013 01:35:29 GMT Chris Johns [6122cb6a] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) PR2158: Add support for dup2. Split the dub call into dup and dup2 ... Tue, 10 Dec 2013 01:33:22 GMT Chris Johns [9da8740] * cpukit/libfs/src/pipe/fifo.c (modified) PR2159: Have the FIFO driver read follow POSIX standard. The read ... Tue, 10 Dec 2013 01:30:20 GMT Chris Johns [b51d8a4] * cpukit/libfs/src/imfs/imfs_init.c (modified) libfs/imfs: Set the FIFO control block. The FIFO was incorrectly ... Mon, 09 Dec 2013 16:17:00 GMT Joel Sherrill [651e3aa] * cpukit/posix/src/sempost.c (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/object.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) cpukit/rtems: Remove XXX in comments Thu, 04 Jun 2009 15:54:40 GMT Nickolay Semyonov-Kolchin [8ed1a54c] * cpukit/rtems/src/clocktodvalidate.c (modified) Fix leap year calculation Reference: ... Tue, 03 Dec 2013 23:42:26 GMT Nick Withers [b5d2d4a] * cpukit/mghttpd/mongoose.1 (deleted) * cpukit/mghttpd/mongoose.c (modified) * cpukit/mghttpd/mongoose.h (modified) * testsuites/libtests/mghttpd01/init.c (modified) Update to Mongoose 3.9 at the last point before the MIT -> GPL ... Wed, 04 Dec 2013 08:12:42 GMT Sebastian Huber [0adc8a7] * cpukit/libblock/src/bdpart-dump.c (modified) libblock: Use LAST for the last partition block Tue, 03 Dec 2013 19:55:34 GMT Wendell P Silva [62ba20d] * cpukit/libblock/src/bdpart-dump.c (modified) PR2157: fdisk partition table dump improvement Show the correct ... Mon, 23 Apr 2012 13:56:14 GMT Gedare Bloom [09a8188] * cpukit/libqos/qreslib.h (modified) PR2056: libqos conversion from uint32_t to time_t AquosA defines ... Tue, 03 Dec 2013 10:56:55 GMT Sebastian Huber [b4e8306] * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) arm: Clear reservations Recent GCC versions use atomic operations ... Fri, 29 Nov 2013 10:13:51 GMT Sebastian Huber [aaaedba] * cpukit/score/src/threaddispatch.c (modified) score: Minor _Thread_Dispatch() optimization It is not necessary to ... Mon, 02 Dec 2013 07:33:35 GMT Sebastian Huber [927a0a1] * cpukit/configure.ac (modified) * cpukit/posix/include/rtems/posix/cancel.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/pthread.c (modified) * testsuites/psxtests/psxcleanup/psxcleanup.c (modified) posix: Use cleanup contexts on the stack Provide support for latest ... Sun, 24 Nov 2013 17:48:08 GMT Sahil Patnayakuni [ad36dc2c] * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timersettime.c (modified) POSIX timers: Add restrict keyword + timer_create() + timer_settime() Fri, 22 Nov 2013 23:09:44 GMT Bryan Dunsmore [77b1de22] * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libmisc/uuid/gen_uuid.c (modified) gettimeofday: Add restrict keyword Thu, 21 Nov 2013 06:20:42 GMT Chirayu Desai [4f8ac34] * cpukit/libcsupport/src/readlink.c (modified) libcsupport: readlink: add c99 'restrict' keyword Signed-off-by: ... Thu, 21 Nov 2013 00:05:17 GMT Bryan Dunsmore [e5d60243] * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) signal methods: Add restrict keyword Wed, 27 Nov 2013 18:00:20 GMT Philipp Eppelt [6ffaeb28] * cpukit/aclocal/enable-paravirt.m4 (added) * cpukit/configure.ac (modified) add --enable-paravirt in cpukit configure scripts Wed, 27 Nov 2013 19:06:16 GMT Joel Sherrill [03e54614] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) statvfs filesystem handlers: Remove restrict Tue, 26 Nov 2013 07:08:38 GMT Sebastian Huber [ea3e6928] * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) nios2: Typos Fri, 22 Nov 2013 09:53:17 GMT Sebastian Huber [1350a702] * cpukit/score/src/threadsetstate.c (modified) score: Format changes in _Thread_Set_state() Thu, 21 Nov 2013 14:09:46 GMT Sebastian Huber [96962b5] * cpukit/score/src/threadqdequeuepriority.c (modified) score: Simplify _Thread_queue_Dequeue_priority() Thu, 21 Nov 2013 12:43:07 GMT Sebastian Huber [e99b0e2] * cpukit/score/include/rtems/score/coremuteximpl.h (modified) score: Use local variables for consistency Thu, 21 Nov 2013 22:54:21 GMT Daniel Ramirez [bb81e04] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/statvfs.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) statvfs and ALL filesystem handlers: Add restrict keyword. Tue, 19 Nov 2013 15:21:54 GMT Sebastian Huber [4ea97d24] * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/scheduleredfenqueue.c (modified) * cpukit/score/src/scheduleredfextract.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) score/rbtree: Remove "unprotected" from API Tue, 19 Nov 2013 15:09:39 GMT Sebastian Huber [833dd90] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreefindheader.c (deleted) * cpukit/score/src/rbtreeget.c (deleted) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreenext.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) score/rbtree: Delete protected operations The user of the red-black ... Tue, 19 Nov 2013 15:09:17 GMT Sebastian Huber [eea7c937] * cpukit/score/src/scheduleredfenqueue.c (modified) * cpukit/score/src/scheduleredfextract.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) scheduler/EDF: Use unprotected insert and extract Interrupts are ... Thu, 21 Nov 2013 00:24:48 GMT Daniel Ramirez [14876018] * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/sys/select.h (modified) select.h, rtems_select.c, nds select: Add restrict keyword Mon, 24 Jun 2013 13:21:46 GMT Sebastian Huber [39a4574] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Add r2 to CPU context The r2 may be used for thread-local ... Mon, 18 Nov 2013 13:34:13 GMT Sebastian Huber [8dc2e7b] * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) powerpc: Do not validate reserved XER bits Fri, 15 Nov 2013 14:38:52 GMT Sebastian Huber [3a7628e8] * cpukit/score/include/rtems/score/objectimpl.h (modified) score: Objects_Information::extract visibility This filed is only ... Thu, 14 Nov 2013 15:21:41 GMT Sebastian Huber [85b52642] * cpukit/score/src/heapgetinfo.c (modified) heapgetinfo: Free all delayed blocks Thu, 14 Nov 2013 23:27:13 GMT Joel Sherrill [f8a39cdc] * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) no_cpu/.../cpu.h: Comment improvement Thu, 14 Nov 2013 23:26:31 GMT Joel Sherrill [bd90283] * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) mips/.../cpu.h: Comment improvement Thu, 14 Nov 2013 14:56:46 GMT Sebastian Huber [17ba419] * cpukit/libmisc/monitor/mon-prmisc.c (modified) monitor: Add support for BSD wakeup state Thu, 31 Oct 2013 14:00:20 GMT Sebastian Huber [8cb2882] * cpukit/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/event.h (added) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (added) * cpukit/preinstall.am (modified) Filesystem: Add kernel event filter handler This handler is ... Thu, 31 Oct 2013 14:00:14 GMT Sebastian Huber [16829460] * cpukit/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/poll.h (added) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_poll.c (added) * cpukit/preinstall.am (modified) Filesystem: Add poll() handler This handler is necessary to ... Thu, 31 Oct 2013 13:17:57 GMT Sebastian Huber [ba120d1] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) Filesystem: Use ENOTTY for default ioctl() handler This is in line ... Thu, 31 Oct 2013 12:56:19 GMT Sebastian Huber [8d66446] * cpukit/libcsupport/include/rtems/libio.h (modified) Filesystem: Documentation Thu, 31 Oct 2013 12:50:49 GMT Sebastian Huber [44790069] * cpukit/libmd/md5.c (modified) * cpukit/libmd/md5.h (modified) libmd: Change MD5Update() prototype This is in line with the ... Fri, 25 Oct 2013 09:51:10 GMT Sebastian Huber [61e3d1a] * cpukit/libcsupport/src/close.c (modified) Filesystem: Clear open flag early in close() This helps to prevent ... Fri, 25 Oct 2013 09:50:12 GMT Sebastian Huber [d44d31c] * cpukit/libcsupport/src/libio.c (modified) Filesystem: Zero flags in rtems_libio_free() Wed, 23 Oct 2013 11:29:17 GMT Sebastian Huber [b68cef17] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: New state STATES_WAITING_FOR_BSD_WAKEUP This state is ... Sun, 27 Oct 2013 17:49:01 GMT Sebastian Huber [73e7345] * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) IMFS: Use IMFS_mtime_ctime_update() Wed, 23 Oct 2013 08:59:12 GMT Sebastian Huber [5fe19134] * cpukit/libcsupport/include/rtems/libio.h (modified) Filesystem: PR2146: Documentation Tue, 22 Oct 2013 09:00:04 GMT Sebastian Huber [8e8b18bb] * cpukit/libmd/md5.h (modified) libmd: New defines for FreeBSD compatibility Fri, 18 Oct 2013 16:08:00 GMT Ralf Kirchner [e89ed92] * cpukit/libfs/src/dosfs/fat.c (modified) dosfs: Ensure initially the sector size is used as bdbuf block size Thu, 17 Oct 2013 02:15:18 GMT Ric Claus [865c307] * cpukit/libblock/src/bdbuf.c (modified) Remove double count of start offset Wed, 16 Oct 2013 11:04:33 GMT Sebastian Huber [b8de8281] * cpukit/libcsupport/include/sys/ioccom.h (modified) libcsupport: Updates from latest FreeBSD version Wed, 16 Oct 2013 12:45:00 GMT Sebastian Huber [1f724a0] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) RFS: Include missing header file Tue, 15 Oct 2013 07:10:38 GMT Sebastian Huber [816a9cad] * cpukit/libcsupport/include/rtems/libio.h (modified) Filesystem: PR2146: Documentation Fri, 11 Oct 2013 14:22:00 GMT Sebastian Huber [3c2bb22] * cpukit/libfs/src/defaults/default_ftruncate.c (modified) Return EINVAL in default ftruncate() handler According to POSIX ... Mon, 30 Sep 2013 17:09:12 GMT Joel Sherrill [abceda99] * cpukit/posix/src/sigsuspend.c (modified) Merge branch 'master' into warnings Mon, 30 Sep 2013 06:10:45 GMT Chris Johns [85c855af] * cpukit/posix/src/sigsuspend.c (modified) Fix building with RTEMS_DEBUG. Mon, 23 Sep 2013 13:22:02 GMT Joel Sherrill [db97feb5] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mdump.c (modified) internal.h/main_mdump.c: Convert main methods to static Sun, 22 Sep 2013 15:36:57 GMT Joel Sherrill [40eea001] * cpukit/libfs/src/nfsclient/src/dirutils.c (modified) nfsclient/src/dirutils.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:34:20 GMT Joel Sherrill [37a7c27] * cpukit/libcsupport/src/getdents.c (modified) getdents.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:32:20 GMT Joel Sherrill [59a2b2b] * cpukit/libcsupport/src/ctermid.c (modified) ctermid.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:31:08 GMT Joel Sherrill [359b6d0] * cpukit/libcsupport/src/getpwent.c (modified) getpwent.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:29:45 GMT Joel Sherrill [f3a5d86f] * cpukit/libcsupport/src/newlibc_init.c (modified) newlibc_init.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:28:23 GMT Joel Sherrill [01b7b69] * cpukit/libcsupport/src/__times.c (modified) __times.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:24:39 GMT Joel Sherrill [59abbec] * cpukit/libcsupport/src/stat.c (modified) stat.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:22:01 GMT Joel Sherrill [d334b60b] * cpukit/libcsupport/src/__gettod.c (modified) __gettod.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:07:20 GMT Joel Sherrill [196749c] * cpukit/libcsupport/src/__getpid.c (modified) __gitpid.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:06:15 GMT Joel Sherrill [e0e2615e] * cpukit/libcsupport/src/__assert.c (modified) __assert.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:05:53 GMT Joel Sherrill [3ea6b88] * cpukit/libcsupport/src/issetugid.c (modified) issetugid.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:02:18 GMT Joel Sherrill [a85a552] * cpukit/posix/src/_execve.c (modified) _execve.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:01:58 GMT Joel Sherrill [137f947] * cpukit/rtems/src/rtemsbuildname.c (modified) rtemsbuildname.c: Fix missing prototype warnings Sun, 22 Sep 2013 15:01:44 GMT Joel Sherrill [90a2a6d] * cpukit/rtems/src/intrbody.c (modified) intrbody.c: Fix missing prototype warnings Sun, 22 Sep 2013 14:41:25 GMT Joel Sherrill [f972703d] * cpukit/posix/src/semopen.c (modified) semopen.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE Sun, 22 Sep 2013 14:41:13 GMT Joel Sherrill [49fb4dcb] * cpukit/posix/src/mqueueopen.c (modified) mqueueopen.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE Sun, 22 Sep 2013 14:40:44 GMT Joel Sherrill [ecd82b6d] * cpukit/score/include/rtems/score/basedefs.h (modified) basedefs.h: Add RTEMS_COMPILER_UNUSED_ATTRIBUTE. Sat, 21 Sep 2013 21:17:48 GMT Joel Sherrill [94926599] * cpukit/posix/src/semopen.c (modified) semopen.c: Address set but unused variable warning
