# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/16/24 04:28:26 Thu, 05 Feb 2015 15:58:09 GMT Sebastian Huber [9247d3f] * cpukit/libfs/src/imfs/imfs_symlink.c (modified) IMFS: Simplify IMFS_symlink() Thu, 05 Feb 2015 15:43:58 GMT Sebastian Huber [e4d35d8] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (moved) * cpukit/libfs/src/imfs/imfs_memfile.c (moved) * cpukit/libfs/src/imfs/imfs_stat_file.c (added) IMFS: Split linfile and memfile modules Make several functions static. Thu, 05 Feb 2015 15:14:59 GMT Sebastian Huber [24ec25d] * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) IMFS: Introduce IMFS_mknod_control Drop ... Thu, 12 Feb 2015 19:52:16 GMT Sebastian Huber [194eb007] * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_unmount.c (modified) Filesystem: Use ENOTSUP for default mount/unmount Tue, 10 Feb 2015 20:18:27 GMT Hesham ALMatary [1c7ee73] * cpukit/score/cpu/or1k/cpu.c (modified) or1k/cpu.c: Eliminate dependency on BSP provided header Mon, 09 Feb 2015 18:09:23 GMT Sebastian Huber [16939b18] * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) Filesystem: Simplify FIFO and pipe configuration Mon, 09 Feb 2015 14:37:00 GMT Sebastian Huber [eb77534] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_fsmount.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Filesystem: Delete unused fsmountme_h handler Sat, 31 Jan 2015 20:27:01 GMT Sebastian Huber [924cbd4f] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) IMFS: Simplify ino generation The type of ino_t is unsigned long, ... Sat, 31 Jan 2015 20:25:57 GMT Sebastian Huber [95308caf] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) IMFS: Use rtems_filesystem_make_dev_t_from_pointer Sat, 31 Jan 2015 20:23:26 GMT Sebastian Huber [4c14ace6] * cpukit/libcsupport/include/rtems/libio.h (modified) Add rtems_filesystem_make_dev_t_from_pointer() Mon, 02 Feb 2015 14:25:26 GMT Sebastian Huber [efd2965a] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal22/Makefile.am (deleted) * testsuites/sptests/spfatal22/spfatal22.doc (deleted) * testsuites/sptests/spfatal22/spfatal22.scn (deleted) * testsuites/sptests/spfatal22/testcase.h (deleted) Filesystem: Statically initialize rtems_libio_iops Mon, 02 Feb 2015 14:25:25 GMT Sebastian Huber [ec0f2df] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Filesystem: Use rtems_libio_iop_to_descriptor() Drop parameter ... Mon, 02 Feb 2015 14:25:24 GMT Sebastian Huber [97db9e30] * cpukit/libcsupport/include/rtems/libio_.h (modified) Filesystem: Delete rtems_libio_last_iop Mon, 02 Feb 2015 14:25:23 GMT Sebastian Huber [ead010c] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/sapi/include/confdefs.h (modified) Filesystem: Make rtems_libio_number_iops const Wed, 28 Jan 2015 17:47:19 GMT Sebastian Huber [40d062f5] * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) IMFS: Reduce IMFS node types Provide only types used by IMFS_mknod(). Wed, 28 Jan 2015 17:25:49 GMT Sebastian Huber [29fa241] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (deleted) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (deleted) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) IMFS: Aggregate link support in dedicated modules Wed, 31 Dec 2014 09:56:05 GMT Sebastian Huber [cf36b70] * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (deleted) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.scn (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psximfs02/psximfs02.scn (modified) IMFS: Replace node union with individual struct This reduces the ... Fri, 23 Jan 2015 15:43:59 GMT Joel Sherrill [081a697] * cpukit/libnetworking/sys/socket.h (modified) sys/socket.h: Add include of for ssize_t This was ... Fri, 23 Jan 2015 11:56:53 GMT Sebastian Huber [c8cd4ff] * cpukit/libnetworking/lib/ftpfs.c (modified) libnetworking: Fix memset() call Close #2244. Wed, 21 Jan 2015 14:22:46 GMT Sebastian Huber [50a50313] * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heap.c (modified) * doc/shell/memory.t (modified) score: Delete superfluous Heap_Statistics::instance This value ... Sun, 21 Dec 2014 19:12:28 GMT Sebastian Huber [c625a641] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/sup_fs_node_type.c (deleted) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_node_type.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (deleted) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (deleted) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (deleted) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) Filesystem: Delete node type operation Use the fstat handler instead. Tue, 20 Jan 2015 13:01:50 GMT Sebastian Huber [60d39b66] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix AltiVec VSCR save/restore Thu, 15 Jan 2015 13:13:19 GMT Sebastian Huber [f87ede5] * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/samples/loopback/init.c (modified) libnetworking: Fix close of active sockets Send a special event to ... Fri, 16 Jan 2015 08:08:23 GMT Sebastian Huber [51c88e8b] * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) libnetworking: Delete dead code The so_uid is always 0 in RTEMS. Fri, 16 Jan 2015 08:05:15 GMT Sebastian Huber [f2f39f3c] * cpukit/libnetworking/kern/uipc_socket2.c (modified) libnetworking: Avoid spurious event delivery The so_pgid field ... Thu, 15 Jan 2015 10:30:13 GMT Sebastian Huber [ac6e8c4] * cpukit/libnetworking/rtems/rtems_glue.c (modified) libnetworking: Simplify sbwait() Tue, 23 Dec 2014 13:18:06 GMT Sebastian Huber [3e2647a7] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: AltiVec and FPU context support Add AltiVec and FPU ... Tue, 13 Jan 2015 07:24:36 GMT Sebastian Huber [99a1f122] * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) nios2: Disable assembler warning Close #2232. Fri, 09 Jan 2015 12:25:09 GMT Sebastian Huber [5759510] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix compile error for ARMv6-M multilib ARMv6-M is not ... Wed, 07 Jan 2015 09:37:23 GMT Sebastian Huber [b1268e6] * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: Add AltiVec register ASM defines Tue, 23 Dec 2014 11:27:53 GMT Sebastian Huber [2e19bfd] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use PPC_HAS_FPU Provide floating point context support ... Tue, 23 Dec 2014 10:46:08 GMT Sebastian Huber [0d0095f1] * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add PPC_STACK_ALIGN_POWER Simplify PPC_STACK_ALIGNMENT ... Tue, 23 Dec 2014 10:38:34 GMT Sebastian Huber [7c16e1a5] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Set PPC_DEFAULT_CACHE_LINE_SIZE for e6500 Tue, 23 Dec 2014 10:34:40 GMT Sebastian Huber [84d3b9b0] * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Use PPC_DEFAULT_CACHE_LINE_SIZE Use it for the default ... Tue, 23 Dec 2014 10:05:21 GMT Sebastian Huber [7f28f237] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * testsuites/sptests/spsize/size.c (modified) powerpc: Delete _CPU_IRQ_info Mon, 22 Dec 2014 10:46:17 GMT Sebastian Huber [bb7bd148] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use alternate time base for CPU counter Tue, 23 Dec 2014 07:28:24 GMT Sebastian Huber [2a4f9d7] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _SMP_Should_start_processor() Tue, 23 Dec 2014 09:32:22 GMT Sebastian Huber [cfe6d05e] * cpukit/libmisc/capture/capture.c (modified) capture: Fix lock initialization Sun, 14 Dec 2014 23:30:23 GMT Joel Sherrill [09220c8] * cpukit/libmisc/untar/untar.c (modified) untar.c: Coverity ID 26151 and reformat The Coverity issue was an ... Thu, 05 Dec 2013 01:52:42 GMT Nick Withers [86364e8] * cpukit/libfs/src/rfs/rtems-rfs-buffer.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) Correct error return mismatches Closes #2139 Wed, 24 Dec 2014 03:14:50 GMT Peter Dufault [da10694] * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (modified) libnetworking: Make rtems_dhcp_failsafe() run time configurable ... Thu, 18 Dec 2014 09:48:35 GMT Sebastian Huber [8ce00eaf] * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) posix: Delete unused _POSIX_Threads_Get() Close #1759. Wed, 17 Dec 2014 14:11:00 GMT Sebastian Huber [864d3475] * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smp: Fix timeout for MrsP semaphores The previous timeout handling ... Mon, 15 Dec 2014 13:19:43 GMT Sebastian Huber [a0b1b5ed] * cpukit/libi2c/libi2c.h (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/fsrofs01/init.c (modified) * testsuites/fstests/imfs_support/fs_support.c (modified) * testsuites/fstests/jffs2_support/fs_support.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/block17/init.c (modified) * testsuites/libtests/crypt01/init.c (modified) * testsuites/libtests/devfs03/init.c (modified) * testsuites/libtests/deviceio01/init.c (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/libtests/i2c01/init.c (modified) * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/monitor02/system.h (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp02/init.c (modified) * testsuites/libtests/sha/init.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/utf8proc01/init.c (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/system.h (modified) * testsuites/psxtests/psxchroot01/main.c (modified) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile02/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/psxtests/psxrdwrv/main.c (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/loopback/init.c (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spfifo01/init.c (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spresource01/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) * testsuites/sptests/spsem03/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM This define was ... Mon, 15 Dec 2014 07:01:59 GMT Sebastian Huber [b2ee119f] * cpukit/include/sys/endian.h (modified) sys/endian.h: Fix 16-bit int problems Mon, 15 Dec 2014 02:26:31 GMT Nick Withers [f42d429] * cpukit/mghttpd/Makefile.am (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/mghttpd01/test-http-client.c (modified) * testsuites/libtests/mghttpd01/test-http-client.h (modified) Enable WebSocket support in the Mongoose HTTP server Fri, 12 Dec 2014 10:03:42 GMT Sebastian Huber [25e5f61] * cpukit/libcsupport/src/sync.c (modified) libcsupport: Do not use _Assert() for sync() Use a best-effort approach. Fri, 12 Dec 2014 08:42:07 GMT Sebastian Huber [26e04e2f] * cpukit/libmisc/shell/main_help.c (modified) shell: Add 'all' topic for help for all commands Fri, 12 Dec 2014 07:46:30 GMT Sebastian Huber [7bdb765] * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) Add POSIX key value pairs to resource snapshot Fri, 12 Dec 2014 12:16:11 GMT Sebastian Huber [172e953] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * testsuites/psxtests/psxkey02/init.c (modified) posix: Delete key/value if value is set to NULL Fri, 12 Dec 2014 10:19:10 GMT Sebastian Huber [dac340dd] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) posix: Simplify _POSIX_Keys_Find() Fri, 12 Dec 2014 07:07:49 GMT Sebastian Huber [3feb372] * cpukit/sapi/include/confdefs.h (modified) confdefs.h: Fix workspace size if idle task is FP Fri, 07 Mar 2014 03:23:30 GMT Nick Withers [9d9c426] * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.scn (modified) Teach rtems_tarfs_load() about symlinks Mon, 08 Dec 2014 18:16:37 GMT Gedare Bloom [71d97c9] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) sparc64: put each copyright on one line Fri, 05 Dec 2014 12:09:11 GMT Sebastian Huber [a2097c5] * cpukit/libmisc/shell/shell.c (modified) shell: Avoid __DATE__ and adjust welcome message The use of ... Fri, 05 Dec 2014 12:05:34 GMT Sebastian Huber [b657ea4d] * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) nfsclient: Avoid __FILE__ and __LINE__ The __FILE__ prevents ... Thu, 04 Dec 2014 09:03:50 GMT Sebastian Huber [12072880] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Update bug report URL Thu, 04 Dec 2014 08:38:27 GMT Sebastian Huber [e870941] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/shared/bspinit.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/README (deleted) * cpukit/libmisc/dummy/default-configuration.c (added) * cpukit/libmisc/dummy/dummy.c (deleted) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/defaultconfig01/Makefile.am (added) * testsuites/libtests/defaultconfig01/defaultconfig01.doc (added) * testsuites/libtests/defaultconfig01/defaultconfig01.scn (added) * testsuites/libtests/defaultconfig01/init.c (added) libmisc: More useful default configuration The dummy.c was a ... Wed, 03 Dec 2014 23:56:40 GMT Jan Dolezal [4251b88] * cpukit/Doxyfile.in (modified) doxygen: expand specified compiler macros to empty string, so they ... Wed, 03 Dec 2014 23:56:39 GMT Jan Dolezal [038e1dba] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: doxygen and comments related to VESA real mode framebuffer Wed, 03 Dec 2014 10:35:52 GMT Daniel Hellstrom [dff1803] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * doc/cpu_supplement/sparc.t (modified) SPARC: optimize IRQ enable & disable * Coding style cleanups. * ... Wed, 03 Dec 2014 12:00:59 GMT Sebastian Huber [8905201] * cpukit/libmisc/monitor/mon-editor.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) monitor: Replace puts() with proper fprintf() Fri, 14 Nov 2014 07:58:00 GMT Daniel Cederman [e4d8513] * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) nfs: Add RPCd task affinity config option Similar to the task ... Fri, 14 Nov 2014 07:58:00 GMT Daniel Cederman [69e3f27] * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) net: Add network task affinity config This patch adds a default ... Mon, 01 Dec 2014 03:53:55 GMT Chris Johns [e37e8504] * cpukit/libmisc/shell/main_edit.c (modified) libmisc/shell: Edit history hack is corrupting memory. Remove it. ... Fri, 28 Nov 2014 10:53:55 GMT Sebastian Huber [d006b46d] * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapfree.c (modified) * doc/shell/memory.t (modified) score: Add heap statistics Add lifetime bytes allocated and freed ... Thu, 27 Nov 2014 12:25:22 GMT Sebastian Huber [2c3c657] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heapgetinfo.c (modified) * doc/shell/memory.t (modified) score: Return heap stats via _Heap_Get_information Print out heap ... Thu, 27 Nov 2014 10:44:48 GMT Sebastian Huber [01557b0] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (deleted) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_report_statistics.c (deleted) * cpukit/libcsupport/src/malloc_report_statistics_plugin.c (deleted) * cpukit/libcsupport/src/malloc_statistics_helpers.c (deleted) * cpukit/libcsupport/src/posix_memalign.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/shell/memory.t (modified) * doc/user/conf.t (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/malloc05/Makefile.am (deleted) * testsuites/libtests/malloc05/init.c (deleted) * testsuites/libtests/malloc05/malloc05.doc (deleted) * testsuites/libtests/malloc05/malloc05.scn (deleted) * testsuites/libtests/malloctest/task1.c (modified) libcsupport: Delete malloc statistics Use the heap handler ... Thu, 27 Nov 2014 13:41:17 GMT Sebastian Huber [3b4ca3a] * cpukit/libblock/src/bdbuf.c (modified) bdbuf: Fix race condition with sync active flag Bug report by Oleg ... Thu, 27 Nov 2014 15:30:12 GMT Joel Sherrill [e22af78] * cpukit/libcsupport/src/sync.c (modified) sync.c: Add asserts to document and check assumptions Thu, 27 Nov 2014 15:29:16 GMT Joel Sherrill [8dbbea6b] * cpukit/libfs/src/dosfs/msdos_file.c (modified) msdos_file.c: Reverse return codes per Gedare Thu, 27 Nov 2014 12:37:04 GMT Sebastian Huber [43b09a98] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_mv.c (modified) * cpukit/libmisc/shell/shell.h (modified) * doc/shell/file.t (modified) shell: Make mv, cp and rm usable for applications close #2030 Wed, 26 Nov 2014 10:51:34 GMT Sebastian Huber [5bd822a7] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smp: Fix scheduler helping protocol Ensure that scheduler nodes in ... Wed, 26 Nov 2014 09:00:13 GMT Sebastian Huber [79569ae] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) smp: Fix scheduler helping protocol assertions Tue, 25 Nov 2014 15:47:20 GMT Sebastian Huber [038faca1] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (added) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcache01/spcache01.doc (modified) * testsuites/sptests/spcache01/spcache01.scn (modified) rtems: Add rtems_cache_coherent_allocate() Add ... Wed, 19 Nov 2014 20:50:45 GMT Josh Oguin [d4ec0a2] * cpukit/libmisc/monitor/mon-prmisc.c (modified) monitor/mon-prmisc.c: Use puts() not fprintf() CodeSonar flagged ... Wed, 19 Nov 2014 20:49:46 GMT Josh Oguin [8b9bc54] * cpukit/score/src/objectgetnameasstring.c (modified) objectgetnameasstring.c: Reformat _Objects_Get() switch to follow pattern Wed, 19 Nov 2014 20:47:57 GMT Josh Oguin [c562d0c] * cpukit/score/include/rtems/score/objectimpl.h (modified) objectimpl.h: Add _Assert() to _Objects_Invalidate_Id() CodeSonar ... Wed, 19 Nov 2014 20:46:43 GMT Josh Oguin [fbafb8f2] * cpukit/score/include/rtems/score/chainimpl.h (modified) chainimpl.h: Add _Assert() to _Chain_Initialize_empty() CodeSonar ... Wed, 19 Nov 2014 20:44:54 GMT Josh Oguin [e106aa73] * cpukit/posix/src/timertsr.c (modified) cpukit/posix/src/timertsr.c: Add _Assert() CodeSonar flagged this ... Wed, 19 Nov 2014 20:42:02 GMT Josh Oguin [90a8e42b] * cpukit/libmisc/monitor/mon-editor.c (modified) monitor/mon-editor.c: Use puts() and snprintf() not fprintf() or ... Wed, 19 Nov 2014 20:40:16 GMT Josh Oguin [4862532] * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) imfs/imfs_handlers_link.c: Add _Assert for NULL pointer CodeSonar ... Wed, 19 Nov 2014 20:39:14 GMT Josh Oguin [43d6a28] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs/msdos_misc.c: Remove unnecessary operation CodeSonar flagged ... Wed, 19 Nov 2014 20:38:16 GMT Josh Oguin [21c0ca8] * cpukit/libfs/src/dosfs/msdos_file.c (modified) dosfs/msdos_file.c: Return an error if it occurs CodeSonar flagged ... Wed, 19 Nov 2014 20:36:44 GMT Josh Oguin [10f28a3a] * cpukit/libfs/src/dosfs/msdos_conv.c (modified) dosfs/msdos_conv.c: Remove unnecessary operations These were ... Wed, 19 Nov 2014 20:34:40 GMT Josh Oguin [72f63eef] * cpukit/libcsupport/src/newlibc_exit.c (modified) libcsupport/src/newlibc_exit.c: Remove dead code This was flagged ... Wed, 19 Nov 2014 20:34:06 GMT Josh Oguin [f18fd4f] * cpukit/libcsupport/src/mount.c (modified) libcsupport/src/mount.c: Remove unnecessary operation This was ... Tue, 28 Oct 2014 16:38:54 GMT Josh Oguin [ba3b6fd] * cpukit/score/src/apimutex.c (modified) apimutex.c: Add _Assert for NULL pointer access CodeSonar detects a ... Wed, 26 Nov 2014 08:57:57 GMT Sebastian Huber [fdd1e20] * cpukit/libmisc/shell/main_edit.c (modified) shell: Include missing header Wed, 26 Nov 2014 08:53:52 GMT Sebastian Huber [90b0e28] * cpukit/dev/i2c/i2c-dev.c (modified) i2c: Do not close file descriptor 0 if open fails Wed, 26 Nov 2014 07:24:39 GMT Sebastian Huber [d6f0ca64] * cpukit/dev/i2c/eeprom.c (modified) i2c: Avoid undefined right shift operation Mon, 24 Nov 2014 19:55:29 GMT Joel Sherrill [505b6806] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) rtems-rfs-rtems.c: Add cast to address warning Mon, 24 Nov 2014 19:54:37 GMT Joel Sherrill [ebb39a21] * cpukit/libmisc/shell/hexdump-conv.c (modified) hexdump-conv.c: Use proper printf() formatting for wchar_t Mon, 24 Nov 2014 19:54:26 GMT Joel Sherrill [3bd0cd1] * cpukit/libmisc/shell/main_edit.c (modified) main_edit.c: Do not reference beyond end of array Mon, 24 Nov 2014 23:11:55 GMT Joel Sherrill [d152024] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Note return value not checked Coverity Id ... Mon, 24 Nov 2014 20:18:16 GMT Joel Sherrill [3211e8e] * cpukit/libcsupport/src/pwdgrp.c (modified) cpukit/libcsupport/src/pwdgrp.c: Check return value Coverity Id ... Mon, 24 Nov 2014 20:14:35 GMT Joel Sherrill [630642e] * cpukit/libmisc/shell/main_blksync.c (modified) shell/main_blksync.c: Fix leak of file descriptor Coverity Id ... Mon, 24 Nov 2014 20:12:54 GMT Joel Sherrill [4afa216] * cpukit/libmisc/shell/main_edit.c (modified) cpukit/libmisc/shell/main_edit.c: Fix use after free() Coverity Id ... Mon, 24 Nov 2014 20:06:49 GMT Joel Sherrill [a0bf44e] * cpukit/dev/i2c/i2c-dev.c (modified) cpukit/dev/i2c/i2c-dev.c: Fix leak on error path Coverity ID ... Tue, 25 Nov 2014 18:50:01 GMT Jennifer Averett [0a0ded70] * cpukit/libmisc/capture/capture_support.c (modified) capture: Resolve failure path memory leak.
