# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 18:55:25 Wed, 28 Mar 2007 15:34:23 GMT Ralf Corsepius [816f4222] * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) Include instead of . Wed, 28 Mar 2007 15:31:39 GMT Ralf Corsepius [a67c316] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 05:36:54 GMT Ralf Corsepius [d3819b5] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 05:36:38 GMT Ralf Corsepius [387cc207] * cpukit/libnetworking/netinet/ip_output.c (modified) Use uint32_t optlen. Wed, 28 Mar 2007 05:23:42 GMT Ralf Corsepius [de4b317] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 05:23:18 GMT Ralf Corsepius [e5d6315e] * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) Eliminate __P(). Wed, 28 Mar 2007 04:48:14 GMT Ralf Corsepius [5c93ba2b] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:48:01 GMT Ralf Corsepius [d506dff] * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) Reflect changes to sys/protosw.h. Wed, 28 Mar 2007 04:47:30 GMT Ralf Corsepius [1a795c31] * cpukit/libnetworking/sys/protosw.h (modified) Change int args to intptr_t because they are casted to pointers. Wed, 28 Mar 2007 04:43:04 GMT Ralf Corsepius [fa768df] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:40:36 GMT Ralf Corsepius [0b07d87] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:38:44 GMT Ralf Corsepius [d5fce8fe] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 04:38:00 GMT Ralf Corsepius [239d981f] * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) Eliminate __P(). Wed, 28 Mar 2007 04:37:16 GMT Ralf Corsepius [a4ebe302] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 03:08:35 GMT Ralf Corsepius [c31fbf5] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 03:08:08 GMT Ralf Corsepius [652f618] * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) Eliminate __P(). Wed, 28 Mar 2007 02:43:37 GMT Ralf Corsepius [2c52cfb] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 02:42:47 GMT Ralf Corsepius [dcefab6] * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Eliminate __P(). Wed, 28 Mar 2007 02:20:23 GMT Ralf Corsepius [bd6dfc9a] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Wed, 28 Mar 2007 02:19:18 GMT Ralf Corsepius [0d150a4c] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 02:19:04 GMT Ralf Corsepius [47a8868] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) Use net/slcompress.h instead of net/pppcompress.h. Wed, 28 Mar 2007 02:16:27 GMT Ralf Corsepius [179c2c33] * cpukit/libnetworking/net/slcompress.h (modified) Cosmetics from FreeBSD. Wed, 28 Mar 2007 02:15:57 GMT Ralf Corsepius [c85f596b] * cpukit/libnetworking/Makefile.am (modified) Remove net/pppcompress.c, net/pppcompress.h. Wed, 28 Mar 2007 02:15:38 GMT Ralf Corsepius [a0a45be] * cpukit/libnetworking/net/pppcompress.c (deleted) * cpukit/libnetworking/net/pppcompress.h (deleted) Remove (Abandoned in FreeBSD). Wed, 28 Mar 2007 01:08:49 GMT Ralf Corsepius [55fe04b] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 01:08:37 GMT Ralf Corsepius [d142d8c] * cpukit/libnetworking/net/pppcompress.h (modified) Eliminate __P(). Wed, 28 Mar 2007 01:06:36 GMT Ralf Corsepius [e052fc9] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 01:06:21 GMT Ralf Corsepius [296f9c2] * cpukit/libnetworking/net/if_pppvar.h (modified) Cosmetics from FreeBSD. Wed, 28 Mar 2007 00:56:11 GMT Ralf Corsepius [fb1d7c83] * cpukit/ChangeLog (modified) 2007-03-28 Ralf Corsépius * ... Wed, 28 Mar 2007 00:55:54 GMT Ralf Corsepius [83be736] * cpukit/libnetworking/net/if_llc.h (modified) Update from FreeBSD. Tue, 27 Mar 2007 17:06:37 GMT Ralf Corsepius [867fd35] * cpukit/libnetworking/net/ppp-comp.h (modified) Include . Warn about using it. Tue, 27 Mar 2007 17:02:59 GMT Ralf Corsepius [d9270b5] * cpukit/ChangeLog (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 17:02:30 GMT Ralf Corsepius [ed92e28] * cpukit/pppd/ccp.c (modified) * cpukit/pppd/options.c (modified) Include instead of . Tue, 27 Mar 2007 16:50:42 GMT Ralf Corsepius [e9b9de6] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Tue, 27 Mar 2007 16:49:54 GMT Ralf Corsepius [84e49054] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 16:48:46 GMT Ralf Corsepius [0e253a0] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/ppp_comp.h (added) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 16:15:00 GMT Ralf Corsepius [3c4c5e0] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/ppp-comp.h (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 15:50:06 GMT Ralf Corsepius [768fe4e] * cpukit/ChangeLog (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 15:47:48 GMT Ralf Corsepius [23af1d4] * cpukit/ChangeLog (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 15:47:35 GMT Ralf Corsepius [d08e825b] * cpukit/pppd/auth.c (modified) * cpukit/pppd/cbcp.c (modified) * cpukit/pppd/ccp.c (modified) * cpukit/pppd/chap.c (modified) * cpukit/pppd/chap_ms.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/demand.c (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/lcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.c (modified) * cpukit/pppd/utils.c (modified) Eliminate __P(). Tue, 27 Mar 2007 15:44:14 GMT Ralf Corsepius [0f0b5e8] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/scandir.c (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 10:22:55 GMT Ralf Corsepius [a52a20fc] * cpukit/ChangeLog (modified) 2007-03-27 Ralf Corsépius * ... Tue, 27 Mar 2007 10:22:16 GMT Ralf Corsepius [5078ee32] * cpukit/pppd/chap.h (modified) * cpukit/pppd/chap_ms.h (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.h (modified) * cpukit/pppd/lcp.h (modified) * cpukit/pppd/magic.h (modified) * cpukit/pppd/md4.h (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/upap.h (modified) Eliminate __P(). Tue, 27 Mar 2007 10:18:16 GMT Ralf Corsepius [6b4010d6] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) 2007-03-26 Ralf Corsépius * ... Tue, 27 Mar 2007 10:17:09 GMT Ralf Corsepius [c95ac2f3] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_mroute.h (modified) 2007-03-26 Ralf Corsépius * ... Tue, 27 Mar 2007 04:24:41 GMT Ralf Corsepius [e6a59370] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/raw_cb.c (modified) 2007-03-26 Ralf Corsépius * ... Mon, 26 Mar 2007 22:56:12 GMT Joel Sherrill [0061ef98] * cpukit/ChangeLog (modified) * cpukit/posix/src/adasupp.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexdefaultattributes.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexmp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/posixintervaltotimespec.c (modified) * cpukit/posix/src/posixtimespecsubtract.c (modified) * cpukit/posix/src/posixtimespectointerval.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/ptimer1.c (modified) * cpukit/posix/src/sched.c (modified) * cpukit/posix/src/time.c (modified) 2007-03-26 Joel Sherrill PR ... Mon, 26 Mar 2007 22:53:45 GMT Joel Sherrill [9d52e69] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/assoc.h (modified) 2007-03-26 Joel Sherrill * ... Mon, 26 Mar 2007 22:51:52 GMT Joel Sherrill [359322a] * cpukit/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) 2007-03-26 Joel Sherrill * ... Mon, 26 Mar 2007 22:31:31 GMT Joel Sherrill [55568af] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/assoc.c (modified) * cpukit/libcsupport/src/assoclocalbyname.c (added) * cpukit/libcsupport/src/assoclocalbyremote.c (added) * cpukit/libcsupport/src/assoclocalbyremotebitfield.c (added) * cpukit/libcsupport/src/assocnamebylocal.c (added) * cpukit/libcsupport/src/assocnamebylocalbitfield.c (added) * cpukit/libcsupport/src/assocnamebyremote.c (added) * cpukit/libcsupport/src/assocnamebyremotebitfield.c (added) * cpukit/libcsupport/src/assocptrbylocal.c (added) * cpukit/libcsupport/src/assocptrbyname.c (added) * cpukit/libcsupport/src/assocptrbyremote.c (added) * cpukit/libcsupport/src/assocremotebylocal.c (added) * cpukit/libcsupport/src/assocremotebylocalbitfield.c (added) * cpukit/libcsupport/src/assocremotebyname.c (added) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_init.c (added) * cpukit/libcsupport/src/write.c (modified) * cpukit/libcsupport/src/write_r.c (added) 2007-03-26 Joel Sherrill * ... Mon, 26 Mar 2007 22:10:56 GMT Joel Sherrill [2777290] * cpukit/libcsupport/src/__gettod.c (modified) Updated copyright date. Mon, 26 Mar 2007 17:04:53 GMT Joel Sherrill [1002abb9] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/__gettod.c (modified) 2007-03-26 Joel Sherrill * ... Mon, 26 Mar 2007 08:06:44 GMT Ralf Corsepius [2661376d] * cpukit/ChangeLog (modified) 2007-03-26 Ralf Corsépius * ... Mon, 26 Mar 2007 08:06:30 GMT Ralf Corsepius [f4ebd28] * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/libnetworking/net/ppp_defs.h (modified) Partial update from FreeBSD. Mon, 26 Mar 2007 07:12:36 GMT Ralf Corsepius [6efd1a6] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/if_ether.h (modified) 2007-03-26 Ralf Corsépius * ... Mon, 26 Mar 2007 06:01:00 GMT Ralf Corsepius [19ef9f72] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/ip_var.h (modified) 2007-03-26 Ralf Corsépius * ... Mon, 26 Mar 2007 05:59:33 GMT Ralf Corsepius [bc1e0b1] * cpukit/libnetworking/netinet/in.h (modified) Fix typo in previous patch. Mon, 26 Mar 2007 05:51:45 GMT Ralf Corsepius [da9078a3] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/in.h (modified) 2007-03-26 Ralf Corsépius * ... Mon, 26 Mar 2007 03:43:28 GMT Ralf Corsepius [dc2a1750] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) 2007-03-26 Ralf Corsépius * ... Sun, 25 Mar 2007 16:50:37 GMT Ralf Corsepius [29bac07b] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/udp_var.h (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 16:43:43 GMT Ralf Corsepius [b61d89c9] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 16:43:30 GMT Ralf Corsepius [883ba09] * cpukit/libnetworking/netinet/in_pcb.h (modified) More partial updates from FreeBSD. Sun, 25 Mar 2007 16:41:50 GMT Ralf Corsepius [a8c31243] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 16:41:18 GMT Ralf Corsepius [7db1de3] * cpukit/libnetworking/netinet/in_systm.h (modified) * cpukit/libnetworking/netinet/in_var.h (modified) Remove __P(). Sun, 25 Mar 2007 16:40:09 GMT Ralf Corsepius [9b97dbfe] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 07:54:43 GMT Ralf Corsepius [a3bf7fc] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 07:54:29 GMT Ralf Corsepius [b91ebbc] * cpukit/libnetworking/netinet/in_pcb.h (modified) Partial updates from FreeBSD. Sun, 25 Mar 2007 07:33:38 GMT Ralf Corsepius [295bd2b5] * cpukit/ChangeLog (modified) changes Sun, 25 Mar 2007 07:33:20 GMT Ralf Corsepius [3bf2241f] * cpukit/libnetworking/sys/socketvar.h (modified) Cosmetics from FreeBSD. Sun, 25 Mar 2007 06:19:12 GMT Ralf Corsepius [590bf06] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 05:40:30 GMT Ralf Corsepius [f190f08] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 05:40:14 GMT Ralf Corsepius [4c672b93] * cpukit/libnetworking/net/raw_cb.h (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) More updates from FreeBSD. Sun, 25 Mar 2007 05:30:11 GMT Ralf Corsepius [c922991b] * cpukit/ChangeLog (modified) 2007-03-25 Ralf Corsépius * ... Sun, 25 Mar 2007 05:29:54 GMT Ralf Corsepius [e791c230] * cpukit/libnetworking/net/raw_cb.h (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.h (modified) Partial update from FreeBSD. Sun, 25 Mar 2007 04:36:35 GMT Ralf Corsepius [2a93bb6] * cpukit/ChangeLog (modified) * cpukit/libnetworking/nfs/krpc.h (deleted) 2007-03-24 Ralf Corsépius * ... Sun, 25 Mar 2007 04:33:51 GMT Ralf Corsepius [1d6915e] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Sat, 24 Mar 2007 10:41:24 GMT Ralf Corsepius [701740c] * cpukit/libnetworking/Makefile.am (modified) 2007-03-24 Ralf Corsépius * ... Sat, 24 Mar 2007 10:34:07 GMT Ralf Corsepius [3818bcb] * cpukit/ChangeLog (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) 2007-03-24 Ralf Corsépius * ... Sat, 24 Mar 2007 10:32:56 GMT Ralf Corsepius [520ee740] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Sat, 24 Mar 2007 10:32:01 GMT Ralf Corsepius [e86108f] * cpukit/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) 2007-03-24 Ralf Corsépius * ... Sat, 24 Mar 2007 10:30:19 GMT Ralf Corsepius [5e073707] * cpukit/ChangeLog (modified) 2007-03-24 Ralf Corsépius * ... Sat, 24 Mar 2007 10:30:04 GMT Ralf Corsepius [a583b06] * cpukit/libnetworking/nfs/nfs.h (deleted) Remove (Unused). Mon, 19 Mar 2007 08:28:04 GMT Ralf Corsepius [5b8e5034] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/buf.h (modified) 2007-03-19 Ralf Corsépius * ... Mon, 19 Mar 2007 07:02:50 GMT Ralf Corsepius [de507c5] * cpukit/libnetworking/preinstall.am (modified) Regenerate. Mon, 19 Mar 2007 07:01:57 GMT Ralf Corsepius [63a5c63] * cpukit/ChangeLog (modified) 2007-03-19 Ralf Corsépius * ... Mon, 19 Mar 2007 07:01:40 GMT Ralf Corsepius [1a26f53b] * cpukit/libnetworking/sys/conf.h (modified) Don't include machine/conf.h. Update copyright notice. Remove ... Mon, 19 Mar 2007 07:01:08 GMT Ralf Corsepius [cf9fd567] * cpukit/libnetworking/Makefile.am (modified) Remove machine/conf.h. Mon, 19 Mar 2007 06:59:51 GMT Ralf Corsepius [95516ff3] * cpukit/libnetworking/machine/conf.h (deleted) Remove. Mon, 19 Mar 2007 05:40:12 GMT Ralf Corsepius [6cf0fae8] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/systm.h (modified) 2007-03-19 Ralf Corsépius * ... Sun, 18 Mar 2007 14:03:16 GMT Ralf Corsepius [417edf2] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/ucred.h (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 13:33:05 GMT Ralf Corsepius [8dcdb051] * cpukit/ChangeLog (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 13:31:48 GMT Ralf Corsepius [51cda9a] * cpukit/libnetworking/sys/callout.h (modified) * cpukit/libnetworking/sys/domain.h (modified) * cpukit/libnetworking/sys/kernel.h (modified) * cpukit/libnetworking/sys/protosw.h (modified) * cpukit/libnetworking/sys/select.h (modified) * cpukit/libnetworking/sys/socket.h (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/sys/ucred.h (modified) Remove __P(). Sun, 18 Mar 2007 08:31:57 GMT Ralf Corsepius [1963463] * cpukit/ChangeLog (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 08:31:46 GMT Ralf Corsepius [c475e3e9] * cpukit/libnetworking/sys/conf.h (modified) Remove bdevsw, cdevsw, swdevt (Unused). Sun, 18 Mar 2007 08:30:47 GMT Ralf Corsepius [f5f1b9c] * cpukit/ChangeLog (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 08:29:23 GMT Ralf Corsepius [689516cc] * cpukit/libnetworking/sys/systm.h (modified) Remove nblkdev, nchrdev, swdevt, nswdev, nswap (Unused). Sun, 18 Mar 2007 07:56:34 GMT Ralf Corsepius [72cbfbb3] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/conf.h (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 07:52:48 GMT Ralf Corsepius [f0e48c5] * cpukit/ChangeLog (modified) 2007-03-18 Ralf Corsépius * ... Sun, 18 Mar 2007 07:52:33 GMT Ralf Corsepius [a5f6802] * cpukit/libnetworking/sys/systm.h (modified) Comment out copyin/copyout to work around clash with defines from ... Sun, 18 Mar 2007 07:52:13 GMT Ralf Corsepius [fed7d90] * cpukit/libnetworking/net/ppp_tty.c (modified) Use struct rtems_termios_linesw instead of struct linesw (PR 1229).
