# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 06:25:40 Mon, 13 Apr 2015 09:26:52 GMT Daniel Hellstrom [4d3e70f4] * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553rt.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c (modified) * c/src/lib/libbsp/sparc/shared/gpio/grgpio.c (modified) * c/src/lib/libbsp/sparc/shared/mem/mctrl.c (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) * c/src/lib/libbsp/sparc/shared/spi/spictrl.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libdrvmgr/drvmgr_res.c (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) DRVMGR: KEY_TYPE now a enum drvmgr_kt Mon, 13 Apr 2015 09:12:04 GMT Daniel Hellstrom [14d55deb] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libpci/pci_bus.c (modified) DRVMGR: renamed info_dev to get_info_dev Mon, 13 Apr 2015 09:07:54 GMT Daniel Hellstrom [246fe22] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/libpci/pci_bus.c (modified) DRVMGR: change name of freq_get to get_freq Mon, 13 Apr 2015 08:49:47 GMT Daniel Hellstrom [bb2f220] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/libdrvmgr/drvmgr_by_id.c (modified) * cpukit/libdrvmgr/drvmgr_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_internal.h (modified) * cpukit/libdrvmgr/drvmgr_lock.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libdrvmgr/drvmgr_translate.c (modified) * cpukit/libdrvmgr/drvmgr_unregister.c (modified) DRVMGR: renamed private drv_mgr and its struct name Mon, 13 Apr 2015 08:47:22 GMT Daniel Hellstrom [bf2c3f8b] * cpukit/libdrvmgr/README (modified) DRVMGR: updated README Mon, 13 Apr 2015 08:32:50 GMT Daniel Hellstrom [4f09060] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libdrvmgr/Makefile.am (modified) * cpukit/preinstall.am (modified) DRVMGR: only build on SPARC platform Thu, 09 Apr 2015 14:09:42 GMT Daniel Hellstrom [e53daed] * cpukit/libpci/pci.h (modified) * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/cfg.h (modified) * cpukit/libpci/pci/cfg_auto.h (modified) * cpukit/libpci/pci/cfg_peripheral.h (modified) * cpukit/libpci/pci/cfg_read.h (modified) * cpukit/libpci/pci/cfg_static.h (modified) * cpukit/libpci/pci/irq.h (modified) * cpukit/libpci/pci_access.c (modified) * cpukit/libpci/pci_access_func.c (modified) * cpukit/libpci/pci_access_io.c (modified) * cpukit/libpci/pci_access_mem.c (modified) * cpukit/libpci/pci_access_mem_be.c (modified) * cpukit/libpci/pci_access_mem_le.c (modified) * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_bus.h (modified) * cpukit/libpci/pci_cfg.c (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_peripheral.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_dev_create.c (modified) * cpukit/libpci/pci_find.c (modified) * cpukit/libpci/pci_find_dev.c (modified) * cpukit/libpci/pci_for_each.c (modified) * cpukit/libpci/pci_for_each_child.c (modified) * cpukit/libpci/pci_for_each_dev.c (modified) * cpukit/libpci/pci_get_dev.c (modified) * cpukit/libpci/pci_internal.h (modified) * cpukit/libpci/pci_irq.c (modified) * cpukit/libpci/pci_print.c (modified) LIBPCI: updated license to rtems.org Thu, 09 Apr 2015 14:09:13 GMT Daniel Hellstrom [0decc806] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_by_id.c (modified) * cpukit/libdrvmgr/drvmgr_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_list_dev.c (modified) * cpukit/libdrvmgr/drvmgr_func.c (modified) * cpukit/libdrvmgr/drvmgr_func_call.c (modified) * cpukit/libdrvmgr/drvmgr_init.c (modified) * cpukit/libdrvmgr/drvmgr_internal.h (modified) * cpukit/libdrvmgr/drvmgr_list.c (modified) * cpukit/libdrvmgr/drvmgr_list.h (modified) * cpukit/libdrvmgr/drvmgr_lock.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libdrvmgr/drvmgr_res.c (modified) * cpukit/libdrvmgr/drvmgr_rw.c (modified) * cpukit/libdrvmgr/drvmgr_translate.c (modified) * cpukit/libdrvmgr/drvmgr_translate_check.c (modified) * cpukit/libdrvmgr/drvmgr_unregister.c (modified) DRVMGR: updated license to rtems.org Thu, 09 Apr 2015 06:36:39 GMT Daniel Hellstrom [cc3f87c0] * cpukit/libdrvmgr/drvmgr.c (modified) DRVMGR: removed a goto and added comments Wed, 08 Apr 2015 08:51:45 GMT Daniel Hellstrom [f4bf22c] * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_peripheral.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_dev_create.c (added) * cpukit/libpci/pci_internal.h (added) LIBPCI: new implementation private header file - new ... Wed, 08 Apr 2015 08:39:41 GMT Daniel Hellstrom [1f4f1e2e] * cpukit/libpci/pci_cfg_auto.c (modified) LIBPCI: various comment/unsed clean-ups Wed, 08 Apr 2015 08:16:51 GMT Daniel Hellstrom [346a9a5] * cpukit/libpci/pci.h (modified) * cpukit/libpci/pci_cfg.c (modified) LIBPCI: use enum with pci_system_type Wed, 08 Apr 2015 08:03:45 GMT Daniel Hellstrom [15620f5b] * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/irq.h (modified) LIBPCI: use RTEMS_INLINE_ROUTINE Wed, 08 Apr 2015 08:01:48 GMT Daniel Hellstrom [dc623099] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: moved comment out of license header Wed, 08 Apr 2015 08:00:48 GMT Daniel Hellstrom [e189f241] * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_bus.h (modified) PCI BUS: moved comment out of license header Wed, 08 Apr 2015 07:50:28 GMT Daniel Hellstrom [2fb0912] * cpukit/libdrvmgr/Makefile.am (modified) DRVMGR: clean-up Makefile.am Wed, 08 Apr 2015 07:49:11 GMT Daniel Hellstrom [eff69891] * cpukit/libdrvmgr/drvmgr.h (modified) DRVMGR: use RTEMS_INLINE_ROUTINE Tue, 07 Apr 2015 14:35:53 GMT Daniel Hellstrom [39937b6c] * cpukit/libpci/pci/ids.h (modified) LIBPCI: added license and auto-gen comment to pci/ids.h To be Merged. Tue, 07 Apr 2015 14:19:39 GMT Daniel Hellstrom [07e5a0e] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: clean-up pci_for_each_child() search arg Tue, 07 Apr 2015 14:08:05 GMT Daniel Hellstrom [4ab9296] * cpukit/libpci/Makefile.am (modified) LIBPCI: remove $Id in makefile.am Tue, 07 Apr 2015 12:25:49 GMT Daniel Hellstrom [c1c37a1] * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/pci.h (modified) * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/ids.h (modified) * cpukit/libpci/pci/pcireg.h (added) * cpukit/libpci/pci_access.c (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_find.c (modified) * cpukit/libpci/pci_for_each.c (modified) * cpukit/libpci/pci_irq.c (modified) * cpukit/libpci/pci_print.c (modified) * cpukit/libpci/preinstall.am (modified) LIBPCI: converted to BSD header Tue, 07 Apr 2015 12:25:23 GMT Daniel Hellstrom [56ea46ba] * cpukit/libpci/pci_bus.c (modified) DRVMGR: PCI BUS converted to BSD header Mon, 13 Apr 2015 08:12:08 GMT Daniel Hellstrom [1f66914] * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_bus.h (modified) LIBPCI: moved pci_bus copyright into a single line Fri, 27 Feb 2015 15:45:59 GMT Daniel Hellstrom [71e8a5c] * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/cfg.h (modified) * cpukit/libpci/pci/cfg_auto.h (modified) * cpukit/libpci/pci/cfg_peripheral.h (modified) * cpukit/libpci/pci/cfg_read.h (modified) * cpukit/libpci/pci/cfg_static.h (modified) * cpukit/libpci/pci/irq.h (modified) * cpukit/libpci/pci_access.c (modified) * cpukit/libpci/pci_access_func.c (modified) * cpukit/libpci/pci_access_io.c (modified) * cpukit/libpci/pci_access_mem.c (modified) * cpukit/libpci/pci_access_mem_be.c (modified) * cpukit/libpci/pci_access_mem_le.c (modified) * cpukit/libpci/pci_cfg.c (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_peripheral.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_find.c (modified) * cpukit/libpci/pci_find_dev.c (modified) * cpukit/libpci/pci_for_each.c (modified) * cpukit/libpci/pci_for_each_child.c (modified) * cpukit/libpci/pci_for_each_dev.c (modified) * cpukit/libpci/pci_get_dev.c (modified) * cpukit/libpci/pci_irq.c (modified) * cpukit/libpci/pci_print.c (modified) LIBPCI: moved copyright into a single line Fri, 27 Feb 2015 15:45:20 GMT Daniel Hellstrom [358b8543] * cpukit/libpci/CHANGES (deleted) LIBPCI: removed unused changes file Fri, 27 Feb 2015 15:44:48 GMT Daniel Hellstrom [a2e0e6e] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: fixed RES2DEV in pci/cfg.h Fri, 27 Feb 2015 15:42:36 GMT Daniel Hellstrom [65d1f35] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_by_id.c (modified) * cpukit/libdrvmgr/drvmgr_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_list_dev.c (modified) * cpukit/libdrvmgr/drvmgr_func.c (modified) * cpukit/libdrvmgr/drvmgr_func_call.c (modified) * cpukit/libdrvmgr/drvmgr_init.c (modified) * cpukit/libdrvmgr/drvmgr_internal.h (modified) * cpukit/libdrvmgr/drvmgr_list.c (modified) * cpukit/libdrvmgr/drvmgr_list.h (modified) * cpukit/libdrvmgr/drvmgr_lock.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libdrvmgr/drvmgr_res.c (modified) * cpukit/libdrvmgr/drvmgr_rw.c (modified) * cpukit/libdrvmgr/drvmgr_translate.c (modified) * cpukit/libdrvmgr/drvmgr_translate_check.c (modified) * cpukit/libdrvmgr/drvmgr_unregister.c (modified) DRVMGR: updated copyright into one line only Tue, 21 May 2013 08:10:21 GMT Daniel Hellstrom [ab907e8e] * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * cpukit/libpci/pci/ids_extra.h (modified) NGMP PCI: added support for NGMP prototype boards Wed, 08 May 2013 12:41:13 GMT Daniel Hellstrom [ffd8002d] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_leon4_n2x.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device ... Tue, 19 Jun 2012 06:50:11 GMT Daniel Hellstrom [0f49c0e] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (added) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA This patch ... Wed, 04 Feb 2015 09:18:20 GMT Daniel Hellstrom [30594a9] * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) DRVMGR: add LEON BSPs driver registration Mon, 28 Nov 2011 09:28:23 GMT Daniel Hellstrom [219d4045] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_drvmgr.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) DRVMGR: added drvmgr shell command Mon, 28 Nov 2011 09:16:09 GMT Daniel Hellstrom [1c5a7e5] * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/pci_bus.c (added) * cpukit/libpci/pci_bus.h (added) * cpukit/libpci/preinstall.am (modified) LIBPCI: added DRVMGR model for PCI bus Mon, 28 Nov 2011 08:52:03 GMT Daniel Hellstrom [e7fade3] * aclocal/enable-drvmgr.m4 (added) * c/src/aclocal/enable-drvmgr.m4 (added) * c/src/lib/libbsp/shared/bspdriverlevelhook.c (added) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/Makefile.am (modified) * cpukit/aclocal/enable-drvmgr.m4 (added) * cpukit/configure.ac (modified) * cpukit/libdrvmgr/Makefile.am (added) * cpukit/libdrvmgr/README (added) * cpukit/libdrvmgr/drvmgr.c (added) * cpukit/libdrvmgr/drvmgr.h (added) * cpukit/libdrvmgr/drvmgr_by_id.c (added) * cpukit/libdrvmgr/drvmgr_by_name.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (added) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (added) * cpukit/libdrvmgr/drvmgr_drvinf.c (added) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (added) * cpukit/libdrvmgr/drvmgr_for_each_list_dev.c (added) * cpukit/libdrvmgr/drvmgr_func.c (added) * cpukit/libdrvmgr/drvmgr_func_call.c (added) * cpukit/libdrvmgr/drvmgr_init.c (added) * cpukit/libdrvmgr/drvmgr_internal.h (added) * cpukit/libdrvmgr/drvmgr_list.c (added) * cpukit/libdrvmgr/drvmgr_list.h (added) * cpukit/libdrvmgr/drvmgr_lock.c (added) * cpukit/libdrvmgr/drvmgr_print.c (added) * cpukit/libdrvmgr/drvmgr_res.c (added) * cpukit/libdrvmgr/drvmgr_rw.c (added) * cpukit/libdrvmgr/drvmgr_translate.c (added) * cpukit/libdrvmgr/drvmgr_translate_check.c (added) * cpukit/libdrvmgr/drvmgr_unregister.c (added) * cpukit/preinstall.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/wrapup/Makefile.am (modified) DRVMGR: added driver manager to cpukit/libdrvmgr Mon, 28 Nov 2011 09:25:15 GMT Daniel Hellstrom [02550220] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_pci.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) LIBPCI: added PCI shell command Mon, 28 Nov 2011 09:11:10 GMT Daniel Hellstrom [a31845f7] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libpci/CHANGES (added) * cpukit/libpci/Makefile.am (added) * cpukit/libpci/README (added) * cpukit/libpci/pci.h (added) * cpukit/libpci/pci/access.h (added) * cpukit/libpci/pci/cfg.h (added) * cpukit/libpci/pci/cfg_auto.h (added) * cpukit/libpci/pci/cfg_peripheral.h (added) * cpukit/libpci/pci/cfg_read.h (added) * cpukit/libpci/pci/cfg_static.h (added) * cpukit/libpci/pci/ids.h (added) * cpukit/libpci/pci/ids_extra.h (added) * cpukit/libpci/pci/irq.h (added) * cpukit/libpci/pci_access.c (added) * cpukit/libpci/pci_access_func.c (added) * cpukit/libpci/pci_access_io.c (added) * cpukit/libpci/pci_access_mem.c (added) * cpukit/libpci/pci_access_mem_be.c (added) * cpukit/libpci/pci_access_mem_le.c (added) * cpukit/libpci/pci_cfg.c (added) * cpukit/libpci/pci_cfg_auto.c (added) * cpukit/libpci/pci_cfg_peripheral.c (added) * cpukit/libpci/pci_cfg_print_code.c (added) * cpukit/libpci/pci_cfg_read.c (added) * cpukit/libpci/pci_cfg_static.c (added) * cpukit/libpci/pci_find.c (added) * cpukit/libpci/pci_find_dev.c (added) * cpukit/libpci/pci_for_each.c (added) * cpukit/libpci/pci_for_each_child.c (added) * cpukit/libpci/pci_for_each_dev.c (added) * cpukit/libpci/pci_get_dev.c (added) * cpukit/libpci/pci_irq.c (added) * cpukit/libpci/pci_print.c (added) * cpukit/libpci/preinstall.am (added) * cpukit/preinstall.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/wrapup/Makefile.am (modified) * doc/ada_user/Makefile.am (modified) * doc/ada_user/ada_user.texi (modified) * doc/develenv/direct.t (modified) * doc/user/Makefile.am (modified) * doc/user/c_user.texi (modified) * doc/user/conf.t (modified) * doc/user/libpci.t (added) LIBPCI: added PCI layer to cpukit/libpci Thu, 24 Nov 2011 15:54:28 GMT Daniel Hellstrom [04cf2c5] * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) IO_MANAGER: early dynamic driver registration Adds the possibility ... Thu, 16 Apr 2015 09:23:29 GMT Sebastian Huber [e98df4d] * cpukit/score/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Add _ISR_lock_Flash() Thu, 16 Apr 2015 09:35:54 GMT Sebastian Huber [64548a3a] * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutexislocked.c (modified) score: Add const qualifier Thu, 16 Apr 2015 09:32:16 GMT Sebastian Huber [72e846d] * cpukit/score/src/apimutexislocked.c (modified) score: Fix _API_Mutex_Is_locked() Remove superfluous ISR ... Wed, 15 Apr 2015 18:23:31 GMT Sebastian Huber [45c9cf2a] * cpukit/score/include/rtems/score/watchdogimpl.h (modified) score: Delete unused WATCHDOG_MAXIMUM_INTERVAL Wed, 15 Apr 2015 06:46:51 GMT Sebastian Huber [644caa20] * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/src/apimutexislocked.c (modified) score: Fix name Tue, 14 Apr 2015 17:11:51 GMT Joel Sherrill [1047f37] * cpukit/posix/src/semdestroy.c (modified) semdestroy.c: Add missing _Objects_Allocator_unlock() closes 2319. Fri, 13 Mar 2015 12:54:16 GMT Daniel Krueger [5049dca] * cpukit/posix/src/semunlink.c (modified) semunlink.c: Add missing _Objects_Allocator_unlock() updates 2319. ... Tue, 14 Apr 2015 15:01:05 GMT Joel Sherrill [fc0756e] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/src/apimutexislocked.c (added) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxsem01/init.c (modified) * testsuites/support/include/tmacros.h (modified) Add test assertion for allocator mutex being unlocked The Allocator ... Mon, 13 Apr 2015 11:57:57 GMT Sebastian Huber [1dc6662] * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) score: Rename _Watchdog_Reset() Update #2307. Fri, 10 Apr 2015 14:19:48 GMT Sebastian Huber [54cf0e34] * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Add Watchdog_Header This type is intended to encapsulate all ... Fri, 10 Apr 2015 13:51:50 GMT Sebastian Huber [bcf536a] * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/watchdogadjust.c (modified) score: Split _Watchdog_Adjust() Split _Watchdog_Adjust() into ... Tue, 17 Mar 2015 14:02:59 GMT Daniel Krueger [a6c5a7e0] * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Align ARM exception frame to 8 bytes The stack pointer must be ... Thu, 09 Apr 2015 11:54:17 GMT Sebastian Huber [41814fa6] * cpukit/score/src/threadqenqueue.c (modified) score: Fix thread queue race condition On uni-processor ... Fri, 27 Mar 2015 20:13:29 GMT Sebastian Huber [1461aba8] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadready.c (deleted) score: Use _Thread_Clear_state() for _Thread_Ready Fri, 27 Mar 2015 20:08:21 GMT Sebastian Huber [edcf89b] * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: Atomically suspend/resume tasks Thu, 26 Mar 2015 20:45:20 GMT Sebastian Huber [342708b9] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadsetstate.c (modified) score: Return prev state in thread state set/clear Thu, 26 Mar 2015 20:16:09 GMT Sebastian Huber [ca10004] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadsetstate.c (modified) score: Simplify _Thread_Set_state() Wed, 08 Apr 2015 05:40:00 GMT Sebastian Huber [9baffdf] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/src/watchdogtickssinceboot.c (added) score: Move _Watchdog_Ticks_since_boot definition Fri, 03 Apr 2015 20:08:20 GMT Joel Sherrill [fd50acd] * cpukit/libmisc/shell/main_rtrace.c (modified) shell/main_rtrace.c: Fix warning Thu, 02 Apr 2015 13:11:26 GMT Hesham ALMatary [1c846616] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (modified) or1k: Send halt signal to or1k simulators when rtems terminates Thu, 02 Apr 2015 06:28:12 GMT Sebastian Huber [504e042] * cpukit/libmisc/capture/rtems-trace-buffer-vars.c (modified) capture: Define __rtld_tbg_lock Mon, 30 Mar 2015 11:19:17 GMT Chris Johns [a300920d] * cpukit/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/capture/rtems-trace-buffer-vars.c (added) * cpukit/libmisc/capture/rtems-trace-buffer-vars.h (added) * cpukit/libmisc/shell/main_rtrace.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/preinstall.am (modified) libmisc/shell: Add the rtrace command for buffered tracing support. ... Thu, 26 Mar 2015 20:37:33 GMT Sebastian Huber [1a6683a] * cpukit/libcsupport/src/pwdgrp.c (modified) libcsupport: Include missing header file Wed, 25 Mar 2015 10:40:08 GMT Sebastian Huber [cb4dd48] * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Ensure interrupt service after ISR enable Wed, 25 Mar 2015 10:33:34 GMT Sebastian Huber [10a699d] * cpukit/libmisc/testsupport/testparallel.c (modified) testsupport: Generate unique worker names Tue, 24 Mar 2015 10:28:32 GMT Sebastian Huber [a54866e9] * cpukit/libmisc/monitor/mon-prmisc.c (modified) monitor: Fix notepad dump Tue, 24 Mar 2015 07:29:44 GMT Sebastian Huber [ad57a59] * cpukit/score/include/rtems/score/mrspimpl.h (modified) score: Fix MrsP ISR/task sychronization Fri, 20 Mar 2015 12:41:27 GMT Sebastian Huber [4054c916] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadyield.c (modified) score: Add scheduler acquire/release This is currently a global ... Tue, 24 Mar 2015 09:47:02 GMT Sebastian Huber [3134eb8] * cpukit/score/src/threadqenqueue.c (modified) score: Use a dedicated ISR lock for thread queues This makes it ... Mon, 23 Mar 2015 14:05:32 GMT Sebastian Huber [57947f1] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add thread lock Update #2273. Tue, 17 Mar 2015 15:28:50 GMT Sebastian Huber [2e9c3d5] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) score: Add thread priority change handler Since the thread current ... Sun, 22 Mar 2015 19:59:14 GMT Joel Sherrill [e02b20a3] * cpukit/libmisc/utf8proc/utf8proc.c (modified) cpukit/libmisc/utf8proc/utf8proc.c: Avoid overflow Sun, 22 Mar 2015 15:27:00 GMT Joel Sherrill [0771936e] * cpukit/libdl/rtl-shell.c (modified) libdl/rtl-shell.c: Adjust printf() format for off_t based on target Sun, 22 Mar 2015 14:42:46 GMT Joel Sherrill [30ea9bf] * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) libdl/rtl-mdreloc-moxie.c: Fix printf() format warnings Fri, 20 Mar 2015 22:56:08 GMT Joel Sherrill [0d36bfb3] * cpukit/score/include/rtems/score/tls.h (modified) rtems/score/tls.h: Add casts to eliminate warnings on some targets Fri, 20 Mar 2015 15:44:42 GMT Joel Sherrill [0a9345ed] * cpukit/libmisc/shell/utils-cp.c (modified) shell/utils-cp.c: Avoid redefinition of TIMESPEC_TO_TIMEVAL Fri, 20 Mar 2015 15:43:46 GMT Joel Sherrill [54bfbe0] * cpukit/libmisc/dummy/default-configuration.c (modified) dummy/default-configuration.c: Tune configuration down for small targets Fri, 20 Mar 2015 15:43:19 GMT Joel Sherrill [735efe7] * cpukit/libmisc/capture/capture_support.c (modified) capture/capture_support.c: Fix printf() warning and formatting Fri, 20 Mar 2015 15:42:33 GMT Joel Sherrill [4727585] * cpukit/libfs/src/imfs/imfs.h (modified) imfs.h: Add cast to remove warning for pointer/integer size mismatch Wed, 18 Mar 2015 15:42:14 GMT Joel Sherrill [5cd910b] * cpukit/libmisc/shell/hexdump-conv.c (modified) cpukit/libmisc/shell/hexdump-conv.c: Eliminate printf() format warning Wed, 18 Mar 2015 15:40:11 GMT Joel Sherrill [5ce776ec] * cpukit/libmisc/shell/main_df.c (modified) cpukit/libmisc/shell/main_df.c: Eliminate printf() format warning Sun, 22 Mar 2015 13:31:59 GMT Sebastian Huber [a6524b9] * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Simplify debug code and use _Assert() Sun, 22 Mar 2015 10:58:10 GMT Sebastian Huber [d2bdf5c] * cpukit/score/Makefile.am (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqrequeue.c (deleted) score: Move _Thread_queue_Requeue() Now all the main thread queue ... Sun, 22 Mar 2015 09:43:06 GMT Sebastian Huber [688fbc44] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadqdequeue.c (deleted) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (deleted) score: Move _Thread_queue_Extract() Move _Thread_queue_Dequeue(). ... Sun, 22 Mar 2015 09:37:52 GMT Sebastian Huber [2429766] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadblockingoperationcancel.c (deleted) * cpukit/score/src/threadqenqueue.c (modified) score: Move _Thread_blocking_operation_Cancel() Move ... Fri, 20 Mar 2015 13:09:26 GMT Sebastian Huber [d4edbdbc] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (modified) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (modified) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn-shell.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap-shell.h (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rap.h (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-chain-iterator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-find-file.h (modified) * cpukit/libdl/rtl-fwd.h (modified) * cpukit/libdl/rtl-indirect-ptr.h (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-cache.h (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj-comp.h (modified) * cpukit/libdl/rtl-obj-fwd.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-shell.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-trace.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unresolved.h (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * testsuites/psxtests/psxclock01/init.c (modified) * testsuites/sptests/spclock_err01/delay.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spclock_err01/system.h (modified) * testsuites/sptests/spevent_err03/init.c (modified) * testsuites/sptests/spevent_err03/system.h (modified) * testsuites/sptests/spintr_err01/init.c (modified) * testsuites/sptests/spintr_err01/isr.c (modified) * testsuites/sptests/spintr_err01/system.h (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) * testsuites/sptests/spmsgq_err01/system.h (modified) * testsuites/sptests/spmsgq_err02/init.c (modified) * testsuites/sptests/spmsgq_err02/system.h (modified) * testsuites/sptests/spmsgq_err02/task3.c (modified) * testsuites/sptests/spport_err01/init.c (modified) * testsuites/sptests/spport_err01/system.h (modified) * testsuites/sptests/spratemon_err01/init.c (modified) * testsuites/sptests/spratemon_err01/screen10.c (modified) * testsuites/sptests/spratemon_err01/system.h (modified) * testsuites/sptests/spratemon_err01/task4.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/init.c (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/spsem_err02/task2.c (modified) * testsuites/sptests/spsignal_err01/init.c (modified) * testsuites/sptests/spsignal_err01/isr.c (modified) * testsuites/sptests/spsignal_err01/system.h (modified) * testsuites/sptests/sptask_err01/init.c (modified) * testsuites/sptests/sptask_err01/system.h (modified) * testsuites/sptests/sptask_err01/task2.c (modified) * testsuites/sptests/sptask_err02/init.c (modified) * testsuites/sptests/sptask_err02/system.h (modified) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptask_err03/system.h (modified) * testsuites/sptests/sptask_err04/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) Replace www.rtems.com with www.rtems.org Fri, 20 Mar 2015 07:28:20 GMT Alexander Krutwig [c3803167] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) * cpukit/score/src/ts64toticks.c (deleted) score: Delete unused _Timestamp_(To|From)_ticks() Fri, 20 Mar 2015 08:08:57 GMT Alexander Krutwig [677d2b09] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) * cpukit/score/src/ts64dividebyinteger.c (deleted) score: Delete unused _Timestamp_Divide_by_integer Tue, 17 Mar 2015 15:24:44 GMT Sebastian Huber [6a941e3] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical23/Makefile.am (added) * testsuites/sptests/spintrcritical23/init.c (added) * testsuites/sptests/spintrcritical23/spintrcritical23.doc (added) * testsuites/sptests/spintrcritical23/spintrcritical23.scn (added) score: Fix _Thread_Change_priority() Atomically update the current ... Thu, 19 Mar 2015 12:52:22 GMT Alexander Krutwig [e0a25fb] * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (modified) score: Delete unused _Timestamp_Is_valid() Thu, 19 Mar 2015 07:55:01 GMT Sebastian Huber [faf3ff8f] * cpukit/score/src/debugisownerofallocator.c (modified) score: Fix _Debug_Is_owner_of_allocator() Thu, 19 Mar 2015 07:23:12 GMT Chris Johns [da30417b] * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture_support.c (modified) libmisc/capture: Clean up formatting on ARM. The printing of 64bit ... Wed, 18 Mar 2015 12:49:36 GMT Sebastian Huber [55243d09] * cpukit/libmisc/testsupport/testparallel.c (modified) testsupport: Do not suspend worker tasks Wed, 18 Mar 2015 05:09:52 GMT Chris Johns [b9d16f7] * cpukit/libmisc/redirector/stdio-redirect.c (modified) libmisc/redirector: Fix unlock on exit from the handler. Mon, 16 Mar 2015 19:28:20 GMT Sebastian Huber [e6f4a612] * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) IMFS: NUL-terminate name returned by readdir() Sun, 15 Mar 2015 15:30:28 GMT Joel Sherrill [6b38b72f] * cpukit/include/rtems/btimer.h (modified) cpukit/include/rtems/btimer.h: Improve brief Sat, 14 Mar 2015 16:04:25 GMT Joel Sherrill [217b3f53] * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) Disable deprecated warning on implementation of deprecated methods Sat, 14 Mar 2015 16:04:00 GMT Joel Sherrill [0a6d12a] * cpukit/libmisc/monitor/mon-task.c (modified) libmisc/monitor/mon-task.c: Disable deprecated warning for use of ... Fri, 13 Mar 2015 21:10:08 GMT Joel Sherrill [4b7df86] * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification Tue, 17 Mar 2015 09:32:20 GMT Sebastian Huber [8c7eb00] * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testparallel.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) testsupport: Add worker setup handler Add ... Tue, 17 Mar 2015 07:30:40 GMT Sebastian Huber [3e3684ba] * cpukit/score/src/percpu.c (modified) score: Ensure properties of CPU_Uint32ptr Mon, 16 Mar 2015 20:15:55 GMT Gedare Bloom [46d3c6d8] * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/cpu/avr/rtems/score/types.h (modified) * cpukit/score/cpu/bfin/rtems/score/types.h (modified) * cpukit/score/cpu/h8300/rtems/score/types.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) * cpukit/score/cpu/m32c/rtems/score/types.h (modified) * cpukit/score/cpu/m32r/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/moxie/rtems/score/types.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/or1k/rtems/score/types.h (modified) * cpukit/score/cpu/powerpc/rtems/score/types.h (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) * cpukit/score/cpu/v850/rtems/score/types.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) cpukit: add and use CPU_Uint32ptr type Mon, 16 Mar 2015 17:23:36 GMT Jamie Iles [674f8b1b] * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) IMFS: don't strlen() an unterminated string in IMFS_dir_read(). ...
