# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 21:39:14 Fri, 05 Oct 2018 12:54:49 GMT Sebastian Huber [479a28e0] * cpukit/ftpd/ftpd.c (modified) ftpd: Avoid use of uninitialized memory Update #3530. Fri, 05 Oct 2018 12:47:21 GMT Sebastian Huber [51da629] * cpukit/ftpd/ftpd.c (modified) ftpd: Avoid malloc() and sscanf() Move the user name to the session ... Fri, 05 Oct 2018 12:39:46 GMT Sebastian Huber [dcf42bb2] * cpukit/ftpd/ftpd.c (modified) * testsuites/libtests/ftp01/ftp01.scn (modified) * testsuites/libtests/ftp01/init.c (modified) ftpd: Remove FTPD_SessionInfo_t::pass member There is no need to ... Fri, 05 Oct 2018 12:05:22 GMT Sebastian Huber [e761fb4] * cpukit/ftpd/ftpd.c (modified) ftpd: Avoid NULL pointer checks before free() They are superfluous ... Fri, 05 Oct 2018 11:56:59 GMT Sebastian Huber [05b5f9c0] * cpukit/libfs/src/jffs2/src/readinode.c (modified) jffs2: Avoid use of constant register variable Avoid the use of a ... Fri, 05 Oct 2018 07:37:44 GMT Sebastian Huber [4a7c6867] * cpukit/include/linux/rbtree.h (modified) Fix rbtree_postorder_for_each_entry_safe() Use the non-standard ... Fri, 05 Oct 2018 06:11:09 GMT Sebastian Huber [1d39e96] * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/semobtain.c (modified) score: Fix legacy RTEMS_STATIC_ASSERT() In standard C pointer ... Wed, 26 Sep 2018 04:34:54 GMT Sebastian Huber [8776bb9] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * testsuites/smptests/smpschededf04/init.c (modified) * testsuites/smptests/smpthreadpin01/init.c (modified) score: Remove CPU_PROVIDES_IDLE_THREAD_BODY Remove the ... Fri, 05 Oct 2018 11:39:49 GMT Sebastian Huber [b38887a] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Deal with a baud of zero Avoid division by zero and ... Thu, 04 Oct 2018 09:29:03 GMT Sebastian Huber [8777d4c] * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_request_set_vector() By default, the ... Thu, 13 Sep 2018 12:50:08 GMT Sebastian Huber [313f897] * cpukit/libcsupport/src/calloc.c (modified) Optimize calloc() Use return value of memset() to enable tail call ... Thu, 13 Sep 2018 12:49:16 GMT Sebastian Huber [1ad43f8] * cpukit/libcsupport/src/calloc.c (modified) Avoid need for -fno-builtin for calloc() Use ... Thu, 13 Sep 2018 04:22:21 GMT Sebastian Huber [5418890] * cpukit/include/rtems/pipe.h (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/pipe.c (deleted) * cpukit/libfs/src/pipe/pipe.c (modified) Remove superfluous pipe_create() Thu, 13 Sep 2018 04:19:05 GMT Sebastian Huber [242887bc] * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/psxsemaphore.c (moved) * cpukit/posix/src/psxtimercreate.c (moved) * cpukit/posix/src/psxtimerdelete.c (moved) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/src/sapirbtreeinsert.c (moved) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/sparc-access.S (moved) Rename files to make them unique within cpukit This allows to build ... Mon, 10 Sep 2018 15:46:19 GMT Sebastian Huber [f373bdc0] * cpukit/libdl/Makefile.am (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Avoid command line defines Update #3375. Mon, 10 Sep 2018 04:31:53 GMT Sebastian Huber [2e77151] * cpukit/mghttpd/Makefile.am (modified) * cpukit/mghttpd/mongoose.c (modified) mghttpd: Add configuration to source file Update #3375. Mon, 10 Sep 2018 04:29:11 GMT Sebastian Huber [06060da] * cpukit/pppd/Makefile.am (modified) pppd: Simplify Makefile.am Update #3375. Mon, 10 Sep 2018 04:27:10 GMT Sebastian Huber [e069f7fe] * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rtems-rpc-config.h (added) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) rpc: Use configuration header file Update #3375. Tue, 02 Oct 2018 08:22:15 GMT Sebastian Huber [f004b2b8] * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/shared/dev/ide/ata.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/telnetd/telnetd.c (modified) Use rtems_task_exit() Update #3530. Update #3533. Mon, 01 Oct 2018 07:25:06 GMT Sebastian Huber [e50e3f70] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/src/taskexit.c (added) * testsuites/sptests/spthreadlife01/init.c (modified) rtems: Add rtems_task_exit() Update #3533. Mon, 01 Oct 2018 06:20:11 GMT Sebastian Huber [57a7ecde] * cpukit/telnetd/telnetd.c (modified) telnetd: Remove CEXP convenience routines Close #3535. Wed, 26 Sep 2018 07:04:43 GMT Sebastian Huber [a346ebba] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/telnetd/telnetd.c (modified) telnetd: Remove CONFIGURE_MAXIMUM_PTYS Add a ... Wed, 26 Sep 2018 07:18:12 GMT Sebastian Huber [2da93bcb] * cpukit/telnetd/telnetd.c (modified) telnetd: Regroup includes Wed, 26 Sep 2018 07:17:55 GMT Sebastian Huber [8e075540] * cpukit/telnetd/telnetd.c (modified) telnetd: Remove dead code Wed, 26 Sep 2018 07:06:43 GMT Sebastian Huber [0413b14] * cpukit/telnetd/telnetd.c (modified) telnetd: Remove superfluous global variable Update #3528. Tue, 25 Sep 2018 13:07:35 GMT Sebastian Huber [b980f363] * cpukit/include/rtems/pty.h (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/telnetd.c (modified) telnetd: Convert pty driver to new Termios API Update #3526. Tue, 25 Sep 2018 13:19:08 GMT Sebastian Huber [ac9f8087] * cpukit/pppd/pppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) pppd: Remove unused get_pty() function Update #3526. Thu, 27 Sep 2018 05:21:27 GMT Sebastian Huber [c56721c] * cpukit/include/rtems/printer.h (modified) printer: Fix Doxygen comments Mon, 24 Sep 2018 07:15:10 GMT Sebastian Huber [7d1acc03] * cpukit/libmisc/stackchk/check.c (modified) stackchk: Fix interrupt stack preparation We have to prepare the ... Thu, 20 Sep 2018 06:47:44 GMT Sebastian Huber [4221d93] * cpukit/libmisc/stackchk/check.c (modified) stackchk: Improve support for interrupt stacks Prepare the ... Fri, 21 Sep 2018 05:30:44 GMT Sebastian Huber [a75a7d3] * cpukit/libmisc/stackchk/check.c (modified) stackchk: Remove heap hack It is now guranteed that threads do not ... Thu, 20 Sep 2018 05:57:08 GMT Sebastian Huber [56e61e24] * cpukit/include/rtems/score/interr.h (modified) * cpukit/score/src/isr.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal07/spfatal07.doc (deleted) * testsuites/sptests/spfatal07/spfatal07.scn (deleted) * testsuites/sptests/spfatal07/testcase.h (deleted) Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL The configured ... Fri, 31 Aug 2018 06:56:08 GMT Daniel Hellstrom [227b145] * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) sparc: clang AS does no accept UNIMP without argument Tue, 19 Dec 2017 12:36:33 GMT Daniel Cederman [1c34a9b] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Remove sequence that could trigger B2BST errata Tue, 12 Dec 2017 10:19:46 GMT Daniel Cederman [e20da8b] * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) sparc: Return to previous section type when done with ... Wed, 19 Sep 2018 09:52:47 GMT Sebastian Huber [776464a] * cpukit/score/src/wkspace.c (modified) score: Allocate per-CPU data only if necessary The ... Mon, 17 Sep 2018 09:53:10 GMT Sebastian Huber [68f339b6] * cpukit/include/rtems/confdefs.h (modified) Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE The RTEMS ... Mon, 17 Sep 2018 08:35:45 GMT Sebastian Huber [5fa0a1f6] * cpukit/include/rtems/confdefs.h (modified) config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE RTEMS had the ... Mon, 17 Sep 2018 08:31:29 GMT Sebastian Huber [bd5cec41] * cpukit/include/rtems/confdefs.h (modified) config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE This ... Fri, 14 Sep 2018 11:20:05 GMT Sebastian Huber [fe283f6c] * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) powerpc: Fix _CPU_Counter_read() for MPC860 The mpc860 is a ... Thu, 13 Sep 2018 09:33:11 GMT Sebastian Huber [aaa6653] * cpukit/include/rtems/score/percpudata.h (modified) score: Fix PER_CPU_DATA_ITEM_DECLARE() Fix ... Mon, 10 Sep 2018 09:47:24 GMT Sebastian Huber [1fe1b820] * cpukit/include/rtems/score/percpudata.h (modified) * testsuites/sptests/sppercpudata01/init.c (modified) score: Fix PER_CPU_DATA_GET_BY_OFFSET() Add uniprocessor version ... Wed, 05 Sep 2018 05:27:24 GMT Sebastian Huber [e58f1cd3] * cpukit/include/sys/priority.h (modified) Add more dummy values to Update #3472. Wed, 29 Aug 2018 07:43:44 GMT Sebastian Huber [7097962] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadunpin.c (added) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpthreadpin01/init.c (added) * testsuites/smptests/smpthreadpin01/smpthreadpin01.doc (added) * testsuites/smptests/smpthreadpin01/smpthreadpin01.scn (added) score: Add thread pin/unpin support Add support to temporarily pin ... Fri, 07 Sep 2018 09:27:45 GMT Sebastian Huber [d8bc0730] * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Modify _Scheduler_Unblock() In SMP configurations, obtain ... Mon, 27 Aug 2018 08:36:35 GMT Sebastian Huber [cfc4231d] * cpukit/headers.am (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (added) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sppercpudata01/init.c (added) * testsuites/sptests/sppercpudata01/item.c (added) * testsuites/sptests/sppercpudata01/sppercpudata01.doc (added) * testsuites/sptests/sppercpudata01/sppercpudata01.h (added) * testsuites/sptests/sppercpudata01/sppercpudata01.scn (added) score: Add flexible per-CPU data Update #3507. Fri, 07 Sep 2018 05:12:06 GMT Sebastian Huber [77d374f5] * cpukit/Makefile.am (modified) cpukit/Makefile.am: Cleanup Fri, 07 Sep 2018 04:19:02 GMT Sebastian Huber [cb68253] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/csb336/net/lan91c11x.c (modified) * bsps/arm/csb336/net/network.c (modified) * bsps/arm/csb337/net/network.c (modified) * bsps/arm/edb7312/net/network.c (modified) * bsps/arm/gumstix/net/rtl8019.c (modified) * bsps/arm/rtl22xx/net/network.c (modified) * bsps/arm/shared/net/lpc-ethernet.c (modified) * bsps/bfin/bf537Stamp/net/ethernet.c (modified) * bsps/bfin/bf537Stamp/net/networkconfig.c (modified) * bsps/i386/pc386/net/3c509.c (modified) * bsps/i386/pc386/net/elink.c (modified) * bsps/i386/pc386/net/ne2000.c (modified) * bsps/i386/pc386/net/wd8003.c (modified) * bsps/lm32/shared/net/network.c (modified) * bsps/lm32/shared/net/tsmac.c (modified) * bsps/m68k/av5282/net/network.c (modified) * bsps/m68k/csb360/net/network.c (modified) * bsps/m68k/gen68360/net/network.c (modified) * bsps/m68k/genmcf548x/net/network.c (modified) * bsps/m68k/mcf5235/net/network.c (modified) * bsps/m68k/mcf5329/net/network.c (modified) * bsps/m68k/mvme167/net/network.c (modified) * bsps/m68k/uC5282/net/network.c (modified) * bsps/mips/csb350/net/network.c (modified) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (modified) * bsps/powerpc/gen5200/net/network.c (modified) * bsps/powerpc/gen83xx/net/network.c (modified) * bsps/powerpc/haleakala/net/network.c (modified) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (modified) * bsps/powerpc/mpc8260ads/net/network.c (modified) * bsps/powerpc/mvme3100/net/tsec.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/qoriq/net/if_intercom.c (modified) * bsps/powerpc/qoriq/net/network.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/powerpc/tqm8xx/net/network_fec.c (modified) * bsps/powerpc/tqm8xx/net/network_scc.c (modified) * bsps/powerpc/virtex/net/xiltemac.c (modified) * bsps/shared/net/cs8900.c (modified) * bsps/shared/net/dec21140.c (modified) * bsps/shared/net/elnk.c (modified) * bsps/shared/net/greth2.c (modified) * bsps/shared/net/i82586.c (modified) * bsps/shared/net/if_dc.c (modified) * bsps/shared/net/if_fxp.c (modified) * bsps/shared/net/open_eth.c (modified) * bsps/shared/net/smc91111.c (modified) * bsps/shared/net/sonic.c (modified) * bsps/sparc/erc32/net/erc32sonic.c (modified) * bsps/sparc/leon2/net/leon_open_eth.c (modified) * bsps/sparc/leon2/net/leon_smc91111.c (modified) * bsps/sparc/leon3/net/leon_greth.c (modified) * bsps/sparc/leon3/net/leon_open_eth.c (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/shared/net/greth.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/kern/kern_mib.c (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getifaddrs.c (modified) * cpukit/libnetworking/libc/getnameinfo.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/if_indextoname.c (modified) * cpukit/libnetworking/libc/if_nameindex.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/machine/rtems-bsd-kernel-space.h (added) * cpukit/libnetworking/machine/rtems-bsd-user-space.h (added) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall_api.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/wrapup/Makefile.am (modified) network: Use kernel/user space header files Add and use ... Fri, 07 Sep 2018 05:06:05 GMT Sebastian Huber [43fb904e] * cpukit/libnetworking/Makefile.am (modified) network: Remove man page installation The man page installation is ... Fri, 07 Sep 2018 04:24:00 GMT Sebastian Huber [eae4d147] * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/libc/ether_addr.c (deleted) * cpukit/libnetworking/libc/gethostname.c (deleted) * cpukit/libnetworking/libc/inet_net_ntop.c (deleted) * cpukit/libnetworking/libc/inet_net_pton.c (deleted) * cpukit/libnetworking/libc/inet_neta.c (deleted) * cpukit/libnetworking/libc/ns_addr.c (deleted) * cpukit/libnetworking/libc/ns_ntoa.c (deleted) network: Remove unused files Fri, 07 Sep 2018 04:39:50 GMT Sebastian Huber [d9296d24] * cpukit/headers.am (modified) * cpukit/include/poll.h (moved) * cpukit/libnetworking/headers.am (modified) Move to set of default header files The is a ... Mon, 10 Sep 2018 08:36:41 GMT Sebastian Huber [ea0a680] * cpukit/include/rtems/score/chainimpl.h (modified) score: Debug aid for _Chain_Extract_unprotected() Ensure that a ... Fri, 07 Sep 2018 05:33:47 GMT Sebastian Huber [2d1c3dff] * cpukit/libfs/src/nfsclient/src/nfs.c (modified) nfsclient: Fix unused variable warning Mon, 03 Sep 2018 06:12:35 GMT Sebastian Huber [e0a9336b] * cpukit/score/src/scheduleredfsmp.c (modified) * testsuites/smptests/smpschededf02/init.c (modified) score: Fix EDF SMP scheduler Fix a special case: block a one-to-one ... Mon, 03 Sep 2018 07:31:19 GMT Sebastian Huber [3aad9d9b] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Generalize SMP scheduler block support Add extract from ... Wed, 29 Aug 2018 17:42:10 GMT Joel Sherrill [9b5b864] * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (modified) rtems/score/epiphany-utility.h: Fix not a prototype warning Wed, 29 Aug 2018 17:41:35 GMT Joel Sherrill [bc696482] * cpukit/score/cpu/bfin/cpu.c (modified) score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype Tue, 21 Aug 2018 15:32:48 GMT Joel Sherrill [14a218f] * cpukit/telnetd/pty.c (modified) cpukit/telnetd/pty.c: Fix format overflow warning on sprintf() ... Wed, 29 Aug 2018 05:53:02 GMT Sebastian Huber [9e8bba5] * cpukit/include/rtems/score/threadimpl.h (modified) score: Remove redundant #ifdef RTEMS_SMP Mon, 27 Aug 2018 05:33:29 GMT Sebastian Huber [6d70a11] * cpukit/include/machine/_kernel_types.h (modified) Include in The FreeBSD kernel ... Wed, 08 Aug 2018 09:52:09 GMT Sebastian Huber [27c89d7] * cpukit/headers.am (modified) * cpukit/include/machine/_kernel_in.h (added) * cpukit/include/machine/_kernel_in6.h (added) * cpukit/include/machine/_kernel_mman.h (added) * cpukit/include/machine/_kernel_uio.h (added) * cpukit/libnetworking/headers.am (modified) * cpukit/libnetworking/machine/_kernel_if.h (added) * cpukit/libnetworking/machine/_kernel_socket.h (added) Add FreeBSD kernel space header files Move the kernel space content ... Thu, 28 Jun 2018 12:39:37 GMT Daniel Hellstrom [0d51b6d8] * cpukit/libmisc/capture/capture.c (modified) capture: prevent unaligned access when reading time LLVM warns ... Thu, 12 Jul 2018 07:15:55 GMT Daniel Cederman [59a0541c] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Restore npc when returning from the syscall_lazy_fp_switch ... Thu, 23 Aug 2018 12:39:33 GMT Sebastian Huber [6695d02] * cpukit/include/machine/_kernel_time.h (modified) * cpukit/score/src/kern_tc.c (modified) Update FreeBSD kernel timespec support This change is based on the ... Fri, 10 Aug 2018 05:34:03 GMT Sebastian Huber [ba0e9631] * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) score: Do not inline _Thread_Dispatch_enable() This function is ... Thu, 23 Aug 2018 12:32:07 GMT Sebastian Huber [a36aa86] * cpukit/include/sys/priority.h (modified) Add dummy PI_SOFT to Update #3472. Fri, 10 Aug 2018 05:22:43 GMT Sebastian Huber [d14f934] * cpukit/include/rtems/score/threaddispatch.h (modified) score: Fix ISR enable in _Thread_Dispatch_enable() This bug had ... Wed, 15 Aug 2018 10:26:13 GMT Christian Mauderer [dcaea71] * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Add name space for field names. The field names for ... Mon, 13 Aug 2018 10:55:34 GMT Amaan Cheval [bc731313] * bsps/x86_64/amd64/clock/clock.c (added) * bsps/x86_64/amd64/headers.am (modified) * bsps/x86_64/amd64/include/apic.h (added) * bsps/x86_64/amd64/include/clock.h (added) * bsps/x86_64/amd64/include/pic.h (added) * bsps/x86_64/amd64/interrupts/pic.c (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add APIC timer based clock driver The APIC timer is ... Mon, 13 Aug 2018 10:50:38 GMT Amaan Cheval [6869321] * bsps/x86_64/amd64/interrupts/idt.c (added) * bsps/x86_64/amd64/interrupts/isr_handler.S (added) * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/headers.am (modified) * bsps/x86_64/include/bsp/irq.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/idt.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) bsps/x86_64: Add support for RTEMS interrupts Updates #2898. Mon, 13 Aug 2018 10:33:12 GMT Amaan Cheval [4544749e] * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/amd64/start/page.c (added) * bsps/x86_64/headers.am (added) * bsps/x86_64/include/libcpu/page.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. Mon, 13 Aug 2018 10:21:47 GMT Amaan Cheval [ab971bf5] * bsps/x86_64/amd64/config/amd64.cfg (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (modified) bsps/x86_64: Reorganize header files and compile-options Updates #2898. Mon, 06 Aug 2018 09:53:42 GMT Sebastian Huber [b2de426] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/address.h (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) score: Fix _Addresses_Subtract() Use architecture-specific integer ... Mon, 06 Aug 2018 08:51:00 GMT Sebastian Huber [66cb142] * cpukit/include/rtems/rtems/part.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Parameter types in rtems_partition_create() Use uintptr_t to ... Fri, 10 Aug 2018 05:11:56 GMT Sebastian Huber [b8eae140] * cpukit/include/sys/priority.h (modified) Add dummy PRI_MIN_KERN to Update #3472. Wed, 08 Aug 2018 09:17:36 GMT Sebastian Huber [aac36d15] * cpukit/configure.ac (modified) * cpukit/posix/src/mprotect.c (modified) posix: Add configure check for mprotect() Update #3491. Wed, 08 Aug 2018 05:52:18 GMT Sebastian Huber [71948f76] * cpukit/include/sys/event.h (modified) sys/event.h: Update version FreeBSD tag Update #3472. Wed, 18 Jul 2018 13:04:03 GMT dab [ac824ff] * cpukit/include/sys/event.h (modified) Make the definition of struct kevent in event.h match what the man ... Wed, 11 Jul 2018 02:09:11 GMT dab [96b32773] * cpukit/include/sys/event.h (modified) Address some (although not all) style(9) issues in event.h after ... Thu, 28 Jun 2018 20:37:17 GMT dab [1d00acb1] * cpukit/include/sys/event.h (modified) Fix compilation error in r335765 under gcc 4.2.1. The anonymous ... Thu, 28 Jun 2018 17:01:04 GMT dab [b37ef68] * cpukit/include/sys/event.h (modified) Remove potential identifier conflict in the EV_SET macro. PR43905 ... Mon, 27 Nov 2017 15:01:59 GMT pfg [bf026dd4] * cpukit/include/sys/event.h (modified) sys/sys: further adoption of SPDX licensing ID tags. Mainly focus ... Sat, 25 Nov 2017 04:49:12 GMT jhb [57c03363] * cpukit/include/sys/event.h (modified) Decode kevent structures logged via ktrace(2) in kdump. - Add a new ... Sat, 17 Jun 2017 00:57:26 GMT kib [e9b708a] * cpukit/include/sys/event.h (modified) Add abstime kqueue(2) timers and expand struct kevent members. This ... Sat, 08 Apr 2017 04:34:18 GMT pkelsey [f51aec8] * cpukit/include/sys/event.h (modified) Fix typo. hist -> hint MFC after: 3 days Tue, 07 Aug 2018 04:25:47 GMT Sebastian Huber [fd27bae] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE Make ... Sat, 04 Aug 2018 08:38:48 GMT Sebastian Huber [0b038bd4] * cpukit/include/rtems/blkdev.h (modified) * cpukit/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block11/init.c (modified) libblock: Add RTEMS_DEPRECATED Close #3358. Sat, 04 Aug 2018 08:56:46 GMT Sebastian Huber [ab96aec] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) dosfs: Avoid deprecated routine Update #3358. Fri, 03 Aug 2018 20:39:42 GMT Sebastian Huber [698093d] * cpukit/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/ide_part_table.c (modified) libblock: Use rtems_blkdev_create_partition() Update #3358. Tue, 31 Jul 2018 14:01:17 GMT Sebastian Huber [0fe7133] * cpukit/libblock/src/flashdisk.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) flashdisk: Use rtems_blkdev_create() Update #3358. Tue, 31 Jul 2018 13:54:29 GMT Sebastian Huber [16f3f10] * cpukit/libblock/src/nvdisk.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/fileio/system.h (modified) nvdisk: Use rtems_blkdev_create() Update #3358. Mon, 30 Jul 2018 04:39:09 GMT Sebastian Huber [24b94c4] * cpukit/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/fstests/support/ramdisk_support.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/samples/fileio/init.c (modified) ramdisk: Use rtems_blkdev_create() Update #3358. Sat, 04 Aug 2018 12:27:38 GMT Sebastian Huber [d56e68b] * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) rfs: Remove erroneous call of rtems_disk_release() The function ... Fri, 03 Aug 2018 05:58:07 GMT Sebastian Huber [42f9963d] * cpukit/include/rtems/score/basedefs.h (modified) score: Remove superfluous semicolon This avoids warnings like this: ... Thu, 02 Aug 2018 12:52:12 GMT Sebastian Huber [83ca9f0a] * cpukit/rtems/src/partcreate.c (modified) rtems: Relax partition buffer area alignment The partition buffer ... Thu, 02 Aug 2018 12:49:01 GMT Sebastian Huber [27bbc05] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) score: Remove CPU_PARTITION_ALIGNMENT Use the CPU_SIZEOF_POINTER ... Thu, 02 Aug 2018 07:41:08 GMT Sebastian Huber [28b8cf9b] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Fix CPU_ALIGNMENT Update #3433. Mon, 30 Jul 2018 05:35:26 GMT Sebastian Huber [334e1d2] * cpukit/include/rtems/confdefs.h (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) confdefs: Fix uniprocessor configuration Introduce a new internal ... Fri, 27 Jul 2018 12:47:17 GMT Sebastian Huber [cfc9573] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-counter.S (added) riscv: Rework CPU counter support Update #3433. Fri, 20 Jul 2018 08:57:59 GMT Sebastian Huber [6b9ef09] * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/dev/irq/clint.h (deleted) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add CLINT and PLIC support The CLINT and PLIC need some ...
