# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 23:21:33 Tue, 22 Feb 2022 15:08:07 GMT Sebastian Huber [fa65ad7f] * cpukit/doxygen/appl-config.h (modified) config: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES Mon, 07 Feb 2022 15:10:45 GMT Sebastian Huber [8f1e8f8f] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timex.h (modified) * cpukit/posix/src/adjtime.c (deleted) * cpukit/score/src/kern_ntptime.c (modified) * cpukit/score/src/kern_tc.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (added) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/sptests/spntp01/init.c (added) kern_ntptime.c: Port to RTEMS Remove previous adjtime() ... Mon, 07 Feb 2022 14:37:54 GMT Sebastian Huber [91057b3] * cpukit/score/src/kern_ntptime.c (added) kern_ntptime.c: Import from FreeBSD The file was imported from this ... Tue, 30 Nov 2021 13:23:23 GMT Andriy Gapon [870cf96] * cpukit/score/src/kern_tc.c (modified) kern_tc: unify timecounter to bintime delta conversion There are ... Fri, 19 Nov 2021 22:29:28 GMT Mark Johnston [ede2278d] * cpukit/score/src/kern_tc.c (modified) timecounter: Initialize tc_lock earlier Hyper-V wants to register ... Fri, 18 Feb 2022 15:33:10 GMT Sebastian Huber [d69acf8] * cpukit/include/rtems/confdefs/threads.h (modified) config: CONFIGURE_DISABLE_NEWLIB_REENTRANCY Do not initialize ... Thu, 12 Aug 2021 07:51:55 GMT Christian Mauderer [7b5948d4] * cpukit/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Pass number of sent chars to l_start At the moment the ... Fri, 28 Jan 2022 23:12:57 GMT Kinsey Moore [17e05426] * cpukit/score/cpu/microblaze/cpu_asm.S (modified) cpukit/microblaze: Simplify dispatch assembly The dispatch code was ... Fri, 28 Jan 2022 22:45:47 GMT Kinsey Moore [c6d8d1cb] * bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h (modified) cpukit/microblaze: Clarify interrupt frame usage Avoid use of magic ... Wed, 26 Jan 2022 16:56:54 GMT Kinsey Moore [ace9955] * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.S (added) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.c (added) * spec/build/cpukit/cpumicroblaze.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) cpukit/microblaze: Add exception extensions Add the functions ... Wed, 26 Jan 2022 16:33:31 GMT Kinsey Moore [530a8c2] * bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S (added) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add debug vector and handler This patch adds a ... Wed, 26 Jan 2022 16:18:46 GMT Kinsey Moore [127980c] * bsps/microblaze/microblaze_fpga/start/_exception_handler.S (modified) * bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S (deleted) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add exception framework This patch updates the ... Thu, 23 Dec 2021 23:33:39 GMT Alex White [37543e19] * bsps/microblaze/microblaze_fpga/dts/system.dts (modified) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (modified) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * bsps/microblaze/microblaze_fpga/include/bsp/microblaze-dtb.h (moved) * bsps/microblaze/microblaze_fpga/irq/irq.c (modified) * bsps/microblaze/microblaze_fpga/start/bspstart.c (modified) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S (added) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdtbheaderpath.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml (added) microblaze: Add support for libbsd networking This includes fixes ... Wed, 26 Jan 2022 22:00:04 GMT Kinsey Moore [b539af8] * cpukit/libmisc/stackchk/check.c (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/stackchk02.yml (added) * testsuites/libtests/stackchk02/init.c (added) * testsuites/libtests/stackchk02/stackchk02.doc (added) * testsuites/libtests/stackchk02/stackchk02.scn (added) cpukit: Prevent error with disabled stack checker When the stack ... Wed, 26 Jan 2022 10:01:44 GMT Sebastian Huber [2145e0c7] * cpukit/include/rtems/gxx_wrappers.h (deleted) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/gxx01.yml (deleted) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal24.yml (deleted) * spec/build/testsuites/sptests/spfatal25.yml (deleted) * testsuites/libtests/gxx01/gxx01.doc (deleted) * testsuites/libtests/gxx01/gxx01.scn (deleted) * testsuites/libtests/gxx01/init.c (deleted) * testsuites/sptests/spfatal24/init.c (deleted) * testsuites/sptests/spfatal24/spfatal24.doc (deleted) * testsuites/sptests/spfatal24/spfatal24.scn (deleted) * testsuites/sptests/spfatal25/init.c (deleted) * testsuites/sptests/spfatal25/spfatal25.doc (deleted) * testsuites/sptests/spfatal25/spfatal25.scn (deleted) Remove obsolete rtems_gxx_*() implementation GCC versions prior to ... Thu, 13 Jan 2022 13:51:55 GMT Sebastian Huber [12a2a8e4] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/include/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) arm: Optimize interrupt handling Use the SRS (Store Return State) ... Thu, 13 Jan 2022 12:30:21 GMT Sebastian Huber [84ba194] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix stack alignment during interrupt handling On a public ... Mon, 17 Jan 2022 07:11:48 GMT Sebastian Huber [41a1903d] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Avoid duplicate move from CPSR Update #4579. Fri, 14 Jan 2022 08:05:50 GMT Sebastian Huber [0290e44] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Rework per-CPU control in interrupt handling Use volatile ... Fri, 14 Jan 2022 12:25:30 GMT Sebastian Huber [2d1ea1ab] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Use push/pop instructions for readability Update #4579. Wed, 22 Dec 2021 09:09:11 GMT Sebastian Huber [8657986] * cpukit/libtest/t-test-rtems-context.c (modified) libtest: Check for pending events Make sure there are no pending ... Wed, 22 Dec 2021 07:16:43 GMT Sebastian Huber [d404771] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Fix Clock Manager parameter descriptions Update #4572. Thu, 16 Dec 2021 20:36:19 GMT Ryan Long [98ab693] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: close() file 'bf' close() file 'bf' to avoid ... Tue, 14 Dec 2021 15:06:19 GMT Sebastian Huber [60cec828] * cpukit/dtc/VERSION (modified) dtc: Update VERSION Thu, 18 Nov 2021 02:53:56 GMT Vikram Garhwal [75b3f48a] * cpukit/include/libfdt.h (modified) libfdt: overlay: make overlay_get_target() public This is done to ... Tue, 09 Nov 2021 15:47:19 GMT Elvira Khabirova [8b21a1b9] * cpukit/dtc/libfdt/fdt_addresses.c (modified) libfdt: fix an incorrect integer promotion UINT32_MAX is an integer ... Sat, 31 Jul 2021 11:48:42 GMT Georg Kotheimer [4c05a91] * cpukit/dtc/libfdt/fdt_strerror.c (modified) libfdt: Add ALIGNMENT error string The ALIGNMENT error was missing ... Fri, 18 Jun 2021 17:20:27 GMT Andre Przywara [c07e238] * cpukit/include/libfdt.h (modified) fdtget: Fix signedness comparisons warnings With -Wsign-compare, ... Tue, 08 Jun 2021 05:28:55 GMT David Gibson [21351a2] * cpukit/dtc/libfdt/fdt_rw.c (modified) Fix CID 1461557 Coverity gets a bit confused by loading ... Tue, 06 Apr 2021 19:07:12 GMT Rob Herring [34052ef] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: Add FDT alignment check to fdt_check_header() Only checking ... Tue, 09 Mar 2021 03:49:35 GMT David Gibson [a3fa0702] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Fix a possible "unchecked return value" warning Apparently ... Tue, 29 Dec 2020 04:17:49 GMT Justin Covell [a582ab3] * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) Set last_comp_version correctly in new dtb and fix potential version ... Wed, 16 Dec 2020 05:51:38 GMT David Gibson [0b85832] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Tweak description of assume-aligned load helpers There's a ... Fri, 11 Dec 2020 02:27:36 GMT Tom Rini [03b601af] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) * cpukit/include/libfdt.h (modified) libfdt: Internally perform potentially unaligned loads Commits ... Wed, 04 Nov 2020 13:06:05 GMT Tom Rini [064a1d7] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Check for 8-byte address alignment in fdt_ro_probe_() The ... Mon, 12 Oct 2020 16:53:31 GMT Andre Przywara [611a2a5a] * cpukit/include/libfdt.h (modified) libfdt: Fix kernel-doc comments The API documentation in libfdt.h ... Thu, 01 Oct 2020 16:46:30 GMT Andre Przywara [65b98121] * cpukit/dtc/libfdt/fdt_strerror.c (modified) libfdt: fdt_strerror(): Fix comparison warning With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:29 GMT Andre Przywara [140935c5] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_get_string(): Fix sequential write comparison warnings ... Thu, 01 Oct 2020 16:46:28 GMT Andre Przywara [58b4fe7] * cpukit/dtc/libfdt/fdt_wip.c (modified) libfdt: libfdt_wip: Fix comparison warning With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:27 GMT Andre Przywara [113cc99] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_create_with_flags(): Fix comparison warning With ... Thu, 01 Oct 2020 16:46:26 GMT Andre Przywara [a5ec1266] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fdt_move(): Fix comparison warnings With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:25 GMT Andre Przywara [89e5744e] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_add_string_(): Fix comparison warning With ... Mon, 21 Sep 2020 16:53:02 GMT Andre Przywara [26bee33] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_node_offset_by_phandle(): Fix comparison warning With ... Mon, 21 Sep 2020 16:52:58 GMT Andre Przywara [bcc2bde] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_resize(): Fix comparison warning With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:56 GMT Andre Przywara [28f7e76] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: fdt_splice_(): Fix comparison warning With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:55 GMT Simon Glass [3437b91] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_get_string(): Fix comparison warnings With ... Mon, 21 Sep 2020 16:52:52 GMT Andre Przywara [11df656] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_grab_space_(): Fix comparison warning With ... Mon, 21 Sep 2020 16:52:51 GMT Andre Przywara [0df1a41f] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_mem_rsv(): Fix comparison warnings With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:50 GMT Andre Przywara [0012580] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fdt_offset_ptr(): Fix comparison warnings With ... Thu, 13 Aug 2020 15:26:26 GMT Frank Mehnert [5a03ce8] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fix fdt_check_node_offset_ w/ VALID_INPUT ... Tue, 16 Jun 2020 01:12:17 GMT Patrick Oppenlander [f5379faf] * cpukit/include/libfdt.h (modified) libfdt: add extern "C" for C++ Signed-off-by: Patrick Oppenlander ... Thu, 18 Jun 2020 04:21:17 GMT Patrick Oppenlander [fcf257a] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: trivial typo fix Signed-off-by: Patrick Oppenlander ... Mon, 15 Jun 2020 16:00:33 GMT Simon Glass [eaadf704] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Correct condition for reordering blocks This condition uses ... Thu, 05 Mar 2020 14:04:45 GMT Jan Beulich [caa59e66] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: fix undefined behaviour in fdt_splice_() libfdt: fix ... Mon, 02 Mar 2020 19:02:55 GMT Simon Glass [16420fbb] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checks This error ... Mon, 02 Mar 2020 19:02:54 GMT Simon Glass [fe0b99d] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Add support for disabling internal checks If libfdt returns ... Mon, 02 Mar 2020 19:02:53 GMT Simon Glass [1f2b9ad] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Improve comments in some of the assumptions Add a little ... Mon, 02 Mar 2020 19:02:52 GMT Simon Glass [f7a174ef] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Fix a few typos Fix 'saftey' and 'additional' typos noticed ... Fri, 10 Dec 2021 07:48:27 GMT Sebastian Huber [868e6d8] * cpukit/include/rtems/rtems/intr.h (modified) rtems: Improve ordering in Move the data ... Wed, 14 Oct 2020 08:47:44 GMT Sebastian Huber [fb17dfb1] * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) Avoid ISR_LOCK_MEMBER() since it confuses Doxygen If RTEMS_SMP is ... Wed, 01 Dec 2021 15:39:46 GMT Christian Mauderer [ffc57e3] * cpukit/libmisc/untar/untar.c (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar01/tar01.doc (modified) * testsuites/libtests/tar01/tar01.scn (modified) * testsuites/libtests/tar01/tar01.tar (modified) untar: Make behavior similar to GNU or BSD tar RTEMS untar ... Tue, 07 Dec 2021 15:31:45 GMT Sebastian Huber [39e6f532] * cpukit/include/rtems/score/wkspaceinitone.h (modified) score: Fix _Workspace_Initialize_for_one_area() In ... Fri, 26 Nov 2021 06:29:52 GMT Sebastian Huber [e543a16] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Fix sample reporting The sample reporting wronly added ... Fri, 26 Nov 2021 06:28:38 GMT Sebastian Huber [5e3607bc] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Fix overlap in measurement context Sun, 05 Dec 2021 15:37:33 GMT Sebastian Huber [69d643f7] * cpukit/include/rtems/score/cpustdatomic.h (modified) score: Fix atomic stores for C++ Close #4566. Thu, 02 Dec 2021 14:06:48 GMT Sebastian Huber [9089bcc] * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) rtems: Move all Interrupt Manager stuff to intr.h Since the ... Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Wed, 08 Apr 2020 15:14:41 GMT Sebastian Huber [d7205f0] * bsps/shared/start/mallocinitmulti.c (added) * bsps/shared/start/mallocinitone.c (added) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mallocinitmulti.h (added) * cpukit/include/rtems/mallocinitone.h (added) * cpukit/libcsupport/src/malloc_initialize.c (deleted) * cpukit/libcsupport/src/mallocheap.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/libtests/malloc04/init.c (modified) libc: Optimize malloc() initialization The BSPs provide memory for ... Wed, 08 Apr 2020 14:54:34 GMT Sebastian Huber [3d0620b] * bsps/shared/start/wkspaceinitmulti.c (added) * bsps/shared/start/wkspaceinitone.c (added) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (added) * cpukit/include/rtems/score/wkspaceinitone.h (added) * cpukit/score/src/wkspace.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) score: Optimize Workspace Handler initialization The BSPs provide ... Thu, 09 Apr 2020 07:31:28 GMT Sebastian Huber [0bd28da] * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceallocate.c (added) * cpukit/score/src/wkspacefree.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Split wkspace.c Splitting the file avoids unnecessary ... Thu, 09 Apr 2020 07:24:05 GMT Sebastian Huber [b070e012] * cpukit/score/src/wkspace.c (modified) wkspace.c: Change license to BSD-2-Clause Change licence according ... Mon, 29 Nov 2021 15:19:01 GMT Sebastian Huber [73305a1] * cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h (modified) arm: Add AARCH32_PMSA_DATA_READ_WRITE_DEFAULT Add default memory ... Mon, 29 Nov 2021 13:54:21 GMT Sebastian Huber [7fec89e2] * cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h (modified) arm: Fix AARCH32_PMSA_DATA_READ_WRITE_CACHED Fix definition of ... Wed, 24 Nov 2021 18:03:57 GMT Joel Sherrill [e945e3fc] * cpukit/aclocal/canonical-target-name.m4 (deleted) * cpukit/aclocal/canonicalize-tools.m4 (deleted) * cpukit/aclocal/check-func.m4 (deleted) * cpukit/aclocal/check-multiprocessing.m4 (deleted) * cpukit/aclocal/check-networking.m4 (deleted) * cpukit/aclocal/check-newlib.m4 (deleted) * cpukit/aclocal/check-posix.m4 (deleted) * cpukit/aclocal/check-rtems-debug.m4 (deleted) * cpukit/aclocal/check-smp.m4 (deleted) * cpukit/aclocal/check-tool.m4 (deleted) * cpukit/aclocal/enable-drvmgr.m4 (deleted) * cpukit/aclocal/enable-multiprocessing.m4 (deleted) * cpukit/aclocal/enable-networking.m4 (deleted) * cpukit/aclocal/enable-paravirt.m4 (deleted) * cpukit/aclocal/enable-posix.m4 (deleted) * cpukit/aclocal/enable-profiling.m4 (deleted) * cpukit/aclocal/enable-rtems-debug.m4 (deleted) * cpukit/aclocal/enable-smp.m4 (deleted) * cpukit/aclocal/env-rtemscpu.m4 (deleted) * cpukit/aclocal/gcc-pipe.m4 (deleted) * cpukit/aclocal/gcc-sanity.m4 (deleted) * cpukit/aclocal/gcc-weak.m4 (deleted) * cpukit/aclocal/multi.m4 (deleted) * cpukit/aclocal/multilib.m4 (deleted) * cpukit/aclocal/prog-cc.m4 (deleted) * cpukit/aclocal/prog-ccas.m4 (deleted) * cpukit/aclocal/rtems-bsp-includes.m4 (deleted) * cpukit/aclocal/rtems-build-top.m4 (deleted) * cpukit/aclocal/rtems-includes.m4 (deleted) * cpukit/aclocal/rtems-source-top.m4 (deleted) * cpukit/aclocal/rtems-top.m4 (deleted) * cpukit/aclocal/version.m4 (deleted) * testsuites/aclocal/canonical-target-name.m4 (deleted) * testsuites/aclocal/canonicalize-tools.m4 (deleted) * testsuites/aclocal/check-cpuopts.m4 (deleted) * testsuites/aclocal/check-custom-bsp.m4 (deleted) * testsuites/aclocal/check-cxx.m4 (deleted) * testsuites/aclocal/check-tool.m4 (deleted) * testsuites/aclocal/enable-cxx.m4 (deleted) * testsuites/aclocal/enable-tests.m4 (deleted) * testsuites/aclocal/env-rtemsbsp.m4 (deleted) * testsuites/aclocal/gcc-specs.m4 (deleted) * testsuites/aclocal/prog-cc.m4 (deleted) * testsuites/aclocal/prog-cxx.m4 (deleted) * testsuites/aclocal/project-root.m4 (deleted) * testsuites/aclocal/rtems-bsp-includes.m4 (deleted) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (deleted) * testsuites/aclocal/rtems-build-top.m4 (deleted) * testsuites/aclocal/rtems-includes.m4 (deleted) * testsuites/aclocal/rtems-source-top.m4 (deleted) * testsuites/aclocal/rtems-test-check.m4 (deleted) * testsuites/aclocal/rtems-top.m4 (deleted) * testsuites/aclocal/version.m4 (deleted) * testsuites/ada/aclocal/prog-gnat.m4 (deleted) */aclocal/*: Remove remnants of autoconf/automae build system ... Tue, 23 Nov 2021 15:32:23 GMT Sebastian Huber [bdcc814] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Add workaround for GRLIB-TN-0011 Affected components are the ... Tue, 23 Nov 2021 14:15:27 GMT Sebastian Huber [675e879] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Replace "precision" with "resolution" Resolution is the ... Thu, 11 Nov 2021 07:44:29 GMT Sebastian Huber [5468464] * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Properly continue the thread during restart The ... Fri, 12 Nov 2021 07:17:32 GMT Sebastian Huber [3b6e263a] * cpukit/score/src/threadqenqueue.c (modified) score: _Thread_queue_Surrender_no_priority() Simplify ... Thu, 11 Nov 2021 08:00:03 GMT Sebastian Huber [2e56aab] * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_queue_Extract() Move _Thread_queue_Extract() ... Thu, 11 Nov 2021 09:34:31 GMT Sebastian Huber [e429e97] * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) score: Simplify thread wait state handling Remove the ... Thu, 11 Nov 2021 07:35:22 GMT Sebastian Huber [50aef135] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadrestart.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objmpci.yml (modified) score: Add _Thread_MP_Extract_proxy() Remove ... Thu, 11 Nov 2021 07:33:36 GMT Sebastian Huber [cd791039] * cpukit/score/src/threadrestart.c (modified) score: Remove thread timer earlier The earlier we remove the thread ... Mon, 15 Nov 2021 09:20:30 GMT Sebastian Huber [834a86fe] * cpukit/score/src/scheduleredfsmp.c (modified) score: Restrict affinity for EDF SMP scheduler The SMP EDF ... Mon, 08 Nov 2021 10:08:24 GMT Sebastian Huber [c69a70a] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Fix rtems_scheduler_remove_processor() Return an error ... Wed, 10 Nov 2021 07:54:03 GMT Sebastian Huber [6443c9d] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Fix assertion in SMP scheduler framework Properly assert ... Fri, 29 Oct 2021 07:30:13 GMT Sebastian Huber [fc64e837] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Rework ask for help requests Process ask for help requests ... Fri, 29 Oct 2021 12:17:54 GMT Sebastian Huber [4d90289e] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: _Scheduler_SMP_Schedule_highest_ready() Simplify callers of ... Fri, 29 Oct 2021 12:45:28 GMT Sebastian Huber [d0434b88] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Remove victim thread from CPU allocation Update #4531. Fri, 29 Oct 2021 11:44:04 GMT Sebastian Huber [c6362f6] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Move _Scheduler_Unblock_node() Move ... Fri, 29 Oct 2021 11:38:43 GMT Sebastian Huber [dcd8b93] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Move _Scheduler_Block_node() Move _Scheduler_Block_node() ... Fri, 29 Oct 2021 06:29:51 GMT Sebastian Huber [f767ef80] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Simplify _Scheduler_SMP_Yield() There is not need to ... Wed, 27 Oct 2021 06:48:47 GMT Sebastian Huber [b9990b8d] * cpukit/score/src/scheduleredfsmp.c (modified) score: Fix SMP EDF priority group ordering The SMP EDF scheduler ... Wed, 27 Oct 2021 06:35:22 GMT Sebastian Huber [6d20f0c5] * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * testsuites/sptests/spchain/init.c (modified) score: Add node to insert to Chain_Node_order This allows to use ... Wed, 20 Oct 2021 12:21:20 GMT Sebastian Huber [ff20bc9] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Rework idle handling in SMP schedulers This patch fixes an ... Fri, 15 Oct 2021 09:21:31 GMT Sebastian Huber [3d6ebde1] * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulerdefaultmakecleansticky.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * spec/build/cpukit/objsmp.yml (modified) score: Add SMP scheduler make/clean sticky This patch fixes the ... Wed, 20 Oct 2021 06:24:24 GMT Sebastian Huber [3781709] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Add SMP scheduler idle exchange callback Update #4531. Wed, 27 Oct 2021 07:46:06 GMT Sebastian Huber [75527ef3] * cpukit/score/src/scheduleredfsmp.c (modified) score: Optimize SMP EDF move to ready operation If a node is moved ... Tue, 19 Oct 2021 12:28:48 GMT Sebastian Huber [9d3e8212] * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) score: Rework affine ready queue handling Rework the handling of ... Tue, 19 Oct 2021 11:06:09 GMT Sebastian Huber [a53229bb] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Use extract from scheduled callbacks Use the extract from ... Thu, 21 Oct 2021 09:07:21 GMT Sebastian Huber [757a1096] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Remove return value from enqueue scheduled The return value ...
