# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 15:42:53 Thu, 03 Mar 2022 12:27:32 GMT Christian Mauderer [d7955b2] * bsps/i386/pc386/ata/ide.c (modified) * bsps/i386/pc386/ata/idecfg.c (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/serdbg.h (modified) * cpukit/include/rtems/serdbgcnf.h (modified) * cpukit/include/rtems/termios_printk.h (modified) * cpukit/include/rtems/termios_printk_cnf.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/serdbg/serdbg.c (modified) bsps and cpukit: Manual file header clean up Updates #4625. Tue, 01 Mar 2022 20:40:44 GMT Joel Sherrill [255fe43] * cpukit/dev/i2c/eeprom.c (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/i2c/sensor-lm75a.c (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (modified) * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752-spi.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/include/dev/i2c/eeprom.h (modified) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (modified) * cpukit/include/dev/i2c/i2c.h (modified) * cpukit/include/dev/i2c/sensor-lm75a.h (modified) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (modified) * cpukit/include/dev/serial/sc16is752.h (modified) * cpukit/include/dev/spi/spi.h (modified) * cpukit/include/linux/i2c-dev.h (modified) * cpukit/include/linux/i2c.h (modified) * cpukit/include/linux/rbtree.h (modified) * cpukit/include/linux/spi/spidev.h (modified) * cpukit/include/rtems/bsd.h (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/ftpfs.h (modified) * cpukit/include/rtems/jffs2.h (modified) * cpukit/include/rtems/linkersets.h (modified) * cpukit/include/rtems/media.h (modified) * cpukit/include/rtems/profiling.h (modified) * cpukit/include/rtems/rbheap.h (modified) * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/sparse-disk.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/telnetd.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/thread.h (modified) * cpukit/include/rtems/timecounter.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) * cpukit/libcrypt/crypt.c (modified) * cpukit/libcsupport/src/arc4random_getentropy_fail.c (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (modified) * cpukit/libcsupport/src/clock.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/consolesimple.h (modified) * cpukit/libcsupport/src/consolesimpleread.c (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/printerfprintfputc.c (modified) * cpukit/libcsupport/src/printertask.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/pwdgrp.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/setgroups.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/jffs2/include/linux/kernel-rtems.h (modified) * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/shell/fdisk.c (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cmdchmod.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_cmdls.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/main_rtc.c (modified) * cpukit/libmisc/shell/shell-wait-for-input.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/rtemsmaxprio.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/panic.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/check_passwd.c (modified) cpukit/: Scripted embedded brains header file clean up Updates #4625. Tue, 01 Mar 2022 20:39:46 GMT Joel Sherrill [d8369225] * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) libmisc/serdbg: Manual header clean up Updates #4625. Tue, 01 Mar 2022 20:34:12 GMT Joel Sherrill [78af924] * cpukit/telnetd/telnetd.c (modified) telnetd.c: Manual cleanup of embedded brains File Headers This ... Tue, 08 Mar 2022 15:56:49 GMT Sebastian Huber [32f0f11] * cpukit/score/cpu/aarch64/cpu_asm.S (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/src/threadstartmultitasking.c (modified) SMP: Fix start multitasking for some targets The previous SMP ... Tue, 08 Mar 2022 08:44:31 GMT Sebastian Huber [5fcc2ca] * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) score: Disable thread dispatching earlier Disable thread ... Tue, 08 Mar 2022 07:12:29 GMT Sebastian Huber [709dfd4] * cpukit/score/src/objectmp.c (modified) mpci: Fix RTEMS_DEBUG support Thu, 17 Feb 2022 15:47:33 GMT Joel Sherrill [f381e9b] * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/media-desc.c (modified) * cpukit/libblock/src/media-dev-ident.c (modified) * cpukit/libblock/src/media-path.c (modified) * cpukit/libblock/src/media-server.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libblock/src/sparse-disk.c (modified) cpukit/libblock: Change license to BSD-2 Updates #3053. Thu, 17 Feb 2022 15:45:33 GMT Joel Sherrill [2dcc54f] * cpukit/ftpd/ftpd-init.c (modified) cpukit/ftpd: Change license to BSD-2 Not all files could be ... Thu, 17 Feb 2022 15:44:10 GMT Joel Sherrill [2fb29836] * cpukit/include/adainclude/rtems-barrier.adb (modified) * cpukit/include/adainclude/rtems-barrier.ads (modified) * cpukit/include/adainclude/rtems-clock.adb (modified) * cpukit/include/adainclude/rtems-clock.ads (modified) * cpukit/include/adainclude/rtems-cpu_usage.ads (modified) * cpukit/include/adainclude/rtems-event.adb (modified) * cpukit/include/adainclude/rtems-event.ads (modified) * cpukit/include/adainclude/rtems-extension.adb (modified) * cpukit/include/adainclude/rtems-extension.ads (modified) * cpukit/include/adainclude/rtems-fatal.adb (modified) * cpukit/include/adainclude/rtems-fatal.ads (modified) * cpukit/include/adainclude/rtems-interrupt.ads (modified) * cpukit/include/adainclude/rtems-io.adb (modified) * cpukit/include/adainclude/rtems-io.ads (modified) * cpukit/include/adainclude/rtems-message_queue.adb (modified) * cpukit/include/adainclude/rtems-message_queue.ads (modified) * cpukit/include/adainclude/rtems-multiprocessing.adb (modified) * cpukit/include/adainclude/rtems-multiprocessing.ads (modified) * cpukit/include/adainclude/rtems-object.adb (modified) * cpukit/include/adainclude/rtems-object.ads (modified) * cpukit/include/adainclude/rtems-partition.adb (modified) * cpukit/include/adainclude/rtems-partition.ads (modified) * cpukit/include/adainclude/rtems-port.adb (modified) * cpukit/include/adainclude/rtems-port.ads (modified) * cpukit/include/adainclude/rtems-rate_monotonic.adb (modified) * cpukit/include/adainclude/rtems-rate_monotonic.ads (modified) * cpukit/include/adainclude/rtems-region.adb (modified) * cpukit/include/adainclude/rtems-region.ads (modified) * cpukit/include/adainclude/rtems-semaphore.adb (modified) * cpukit/include/adainclude/rtems-semaphore.ads (modified) * cpukit/include/adainclude/rtems-signal.adb (modified) * cpukit/include/adainclude/rtems-signal.ads (modified) * cpukit/include/adainclude/rtems-stack_checker.ads (modified) * cpukit/include/adainclude/rtems-tasks.adb (modified) * cpukit/include/adainclude/rtems-tasks.ads (modified) * cpukit/include/adainclude/rtems-timer.adb (modified) * cpukit/include/adainclude/rtems-timer.ads (modified) * cpukit/include/adainclude/rtems.adb (modified) * cpukit/include/adainclude/rtems.ads (modified) cpukit/include/adainclude: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:51:18 GMT Joel Sherrill [c0ec0b29] * cpukit/score/cpu/v850/cpu.c (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/include/rtems/score/v850.h (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) score/cpu/v850: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 23:02:12 GMT Joel Sherrill [ef32245] * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/interrupt.S (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/sparc64/sparc64-syscall.S (modified) score/cpu/sparc64: Change license to BSD-2 Wed, 16 Feb 2022 22:56:15 GMT Joel Sherrill [e111974] * cpukit/score/cpu/sparc/access_le.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/include/libcpu/access.h (modified) * cpukit/score/cpu/sparc/include/libcpu/byteorder.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) * cpukit/score/cpu/sparc/sparc-access.S (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/sparc-isr-handler.S (modified) * cpukit/score/cpu/sparc/sparc-isr-install.c (modified) score/cpu/sparc: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:53:04 GMT Joel Sherrill [87076c9] * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) score/cpu/powerpc: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 23:04:21 GMT Joel Sherrill [2ec78aaf] * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/or1k.h (modified) * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) * cpukit/score/cpu/or1k/or1k-context-switch.S (modified) * cpukit/score/cpu/or1k/or1k-context-validate.S (modified) * cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S (modified) * cpukit/score/cpu/or1k/or1k-exception-default.c (modified) * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) score/cpu/or1k: Change license to BSD-2 Wed, 16 Feb 2022 22:55:20 GMT Joel Sherrill [3ca8895f] * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h (modified) score/cpu/no_cpu: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:51:56 GMT Joel Sherrill [4b5e64a] * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2.h (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) score/cpu/nios2: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:53:36 GMT Joel Sherrill [bf10d5b] * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/include/rtems/score/mips.h (modified) score/cpu/mips: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:52:19 GMT Joel Sherrill [51366002] * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) score/cpu/m68k: Change license to BSD-2 Updates #3053. Thu, 17 Feb 2022 15:39:53 GMT Joel Sherrill [f42730a] * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/include/rtems/score/idtr.h (modified) * cpukit/score/cpu/i386/include/rtems/score/interrupts.h (modified) * cpukit/score/cpu/i386/include/rtems/score/paravirt.h (modified) * cpukit/score/cpu/i386/include/rtems/score/registers.h (modified) score/cpu/i386: Change license to BSD-2 sse_test.c was ... Wed, 16 Feb 2022 22:54:29 GMT Joel Sherrill [e47a3b7] * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) * cpukit/score/cpu/arm/include/rtems/asm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/arm/include/rtems/score/paravirt.h (modified) score/cpu/arm: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:48:55 GMT Joel Sherrill [bd2e898] * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/getversionstring.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioclose.c (modified) * cpukit/sapi/src/iocontrol.c (modified) * cpukit/sapi/src/ioinitialize.c (modified) * cpukit/sapi/src/ioopen.c (modified) * cpukit/sapi/src/ioread.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/iounregisterdriver.c (modified) * cpukit/sapi/src/iowrite.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/rbtree.c (modified) * cpukit/sapi/src/rbtreefind.c (modified) * cpukit/sapi/src/sapirbtreeinsert.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/sapi/src/version.c (modified) sapi/src/*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:32:36 GMT Joel Sherrill [46a16ada] * cpukit/include/rtems/posix/aio_misc.h (modified) * cpukit/include/rtems/posix/barrierimpl.h (modified) * cpukit/include/rtems/posix/condimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mmanimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/muteximpl.h (modified) * cpukit/include/rtems/posix/posixapi.h (modified) * cpukit/include/rtems/posix/priorityimpl.h (modified) * cpukit/include/rtems/posix/psignal.h (modified) * cpukit/include/rtems/posix/psignalimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadattrimpl.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/rwlockimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/spinlockimpl.h (modified) * cpukit/include/rtems/posix/threadsup.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) cpukit/include/rtems/posix/*.h: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:37:25 GMT Joel Sherrill [fee2771] * cpukit/posix/src/_execve.c (modified) posix/src/_execve.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:32:05 GMT Joel Sherrill [380fb9f] * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/posix_madvise.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxnametoid.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/psxtimerdelete.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrdefault.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetguardsize.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstack.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadconcurrency.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetnamenp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetnamenp.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/rwlockattrgetpshared.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/rwlockattrsetpshared.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setitimer.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/posix/src/vfork.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/posix/src/waitpid.c (modified) cpukit/posix/src/[p-z]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:31:50 GMT Joel Sherrill [0a645dad] * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/barrierattrgetpshared.c (modified) * cpukit/posix/src/barrierattrinit.c (modified) * cpukit/posix/src/barrierattrsetpshared.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocknanosleep.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetclock.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetclock.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getitimer.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mlock.c (modified) * cpukit/posix/src/mlockall.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/msync.c (modified) * cpukit/posix/src/munlock.c (modified) * cpukit/posix/src/munlockall.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) cpukit/posix/src/[a-o]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:29:38 GMT Joel Sherrill [a2ed06e] * cpukit/include/rtems/rtems/asrdata.h (modified) * cpukit/include/rtems/rtems/attrimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/clockimpl.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/eventdata.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/optionsimpl.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/include/rtems/rtems/signalmp.h (modified) * cpukit/include/rtems/rtems/statusimpl.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) cpukit/include/rtems/rtems/*.h: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:28:59 GMT Joel Sherrill [b3b6d21e] * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/statustoerrno.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) cpukit/rtems/src/[s-z]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 22:28:43 GMT Joel Sherrill [c4fb617] * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/modes.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqconstruct.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) cpukit/rtems/src/[a-r]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 21:16:11 GMT Joel Sherrill [7b85efb8] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/smplockmcs.h (modified) * cpukit/include/rtems/score/smplockseq.h (modified) * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/include/rtems/score/smplockticket.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/statesimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/sysstate.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextdata.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/include/rtems/score/watchdog.h (modified) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) cpukit/include/rtems/score/[s-z]*.h: Change license to BSD-2 ... Wed, 16 Feb 2022 21:15:58 GMT Joel Sherrill [7ebce359] * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/apimutex.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/atomic.h (modified) * cpukit/include/rtems/score/chain.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/coremutex.h (modified) * cpukit/include/rtems/score/coremuteximpl.h (modified) * cpukit/include/rtems/score/corerwlockimpl.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/coresemimpl.h (modified) * cpukit/include/rtems/score/cpustdatomic.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/freechainimpl.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/heapinfo.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/mpciimpl.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/protectedheap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/rbtreeimpl.h (modified) cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2 ... Wed, 16 Feb 2022 21:09:32 GMT Joel Sherrill [2a1449c] * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadname.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadtimeout.c (modified) * cpukit/score/src/threadunpin.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecgetasnanoseconds.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/watchdogtickssinceboot.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) score/src/[t-z]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 21:09:20 GMT Joel Sherrill [4a0e418] * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultmappriority.c (modified) * cpukit/score/src/schedulerdefaultnodedestroy.c (modified) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/schedulerdefaultschedule.c (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerdefaultstartidle.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) score/src/[n-s]*.c: Change license to BSD-2 Updates #3053. Wed, 16 Feb 2022 21:09:06 GMT Joel Sherrill [ab02824] * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/apimutexisowner.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/log2table.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/mutex.c (modified) score/src/[a-m]*.c: Change license to BSD-2 Updates #3053. Fri, 25 Feb 2022 16:45:06 GMT Sebastian Huber [faaffbd9] * bsps/riscv/griscv/clock/clockdrv.c (modified) * bsps/riscv/shared/start/start.S (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/riscv-utility.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Use zicsr architecture extension This is required for ISA ... Thu, 17 Feb 2022 15:47:22 GMT Joel Sherrill [4bc3470] * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) cpukit/libblock: Clean up before license change Thu, 17 Feb 2022 15:36:02 GMT Joel Sherrill [cc9f433] * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/include/rtems/score/idtr.h (modified) * cpukit/score/cpu/i386/include/rtems/score/interrupts.h (modified) score/cpu/i386: Clean up file headers in prep for license change. Wed, 16 Feb 2022 22:38:08 GMT Joel Sherrill [1011484] * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) score/src/schedulersimple*.c: Replace found in found in with found in ... Wed, 26 Jan 2022 16:57:49 GMT Kinsey Moore [3317d1e] * cpukit/libdebugger/rtems-debugger-microblaze.c (added) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/objdbgmicroblaze.yml (added) * spec/build/cpukit/optlibdebugger.yml (modified) cpukit/libdebugger: Add MicroBlaze support Add MicroBlaze support ... Tue, 22 Feb 2022 22:01:33 GMT Kinsey Moore [16d40ce] * cpukit/libdebugger/rtems-debugger-target.c (modified) * cpukit/libdebugger/rtems-debugger-target.h (modified) cpukit/libdebugger: Avoid cascade for interrupts This updates ... Fri, 18 Feb 2022 16:05:25 GMT Kinsey Moore [dbdf38ea] * bsps/microblaze/microblaze_fpga/start/crtinit.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) microblaze: Decouple exceptions from interrupts Exception handling ... Thu, 10 Feb 2022 16:03:01 GMT Kinsey Moore [ea1a4fd2] * cpukit/libdebugger/rtems-debugger-target.h (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) cpukit/libdebugger: Add pure swbreak capability Add a capability ... Tue, 08 Feb 2022 18:58:56 GMT Kinsey Moore [924993a] * cpukit/libdebugger/rtems-debugger-target.c (modified) cpukit/libdebugger: Avoid missed swbreak removal It is possible to ... Tue, 22 Feb 2022 15:08:07 GMT Sebastian Huber [fa65ad7f] * cpukit/doxygen/appl-config.h (modified) config: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES Mon, 07 Feb 2022 15:10:45 GMT Sebastian Huber [8f1e8f8f] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timex.h (modified) * cpukit/posix/src/adjtime.c (deleted) * cpukit/score/src/kern_ntptime.c (modified) * cpukit/score/src/kern_tc.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (added) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/sptests/spntp01/init.c (added) kern_ntptime.c: Port to RTEMS Remove previous adjtime() ... Mon, 07 Feb 2022 14:37:54 GMT Sebastian Huber [91057b3] * cpukit/score/src/kern_ntptime.c (added) kern_ntptime.c: Import from FreeBSD The file was imported from this ... Tue, 30 Nov 2021 13:23:23 GMT Andriy Gapon [870cf96] * cpukit/score/src/kern_tc.c (modified) kern_tc: unify timecounter to bintime delta conversion There are ... Fri, 19 Nov 2021 22:29:28 GMT Mark Johnston [ede2278d] * cpukit/score/src/kern_tc.c (modified) timecounter: Initialize tc_lock earlier Hyper-V wants to register ... Fri, 18 Feb 2022 15:33:10 GMT Sebastian Huber [d69acf8] * cpukit/include/rtems/confdefs/threads.h (modified) config: CONFIGURE_DISABLE_NEWLIB_REENTRANCY Do not initialize ... Thu, 12 Aug 2021 07:51:55 GMT Christian Mauderer [7b5948d4] * cpukit/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Pass number of sent chars to l_start At the moment the ... Fri, 28 Jan 2022 23:12:57 GMT Kinsey Moore [17e05426] * cpukit/score/cpu/microblaze/cpu_asm.S (modified) cpukit/microblaze: Simplify dispatch assembly The dispatch code was ... Fri, 28 Jan 2022 22:45:47 GMT Kinsey Moore [c6d8d1cb] * bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h (modified) cpukit/microblaze: Clarify interrupt frame usage Avoid use of magic ... Wed, 26 Jan 2022 16:56:54 GMT Kinsey Moore [ace9955] * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.S (added) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.c (added) * spec/build/cpukit/cpumicroblaze.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) cpukit/microblaze: Add exception extensions Add the functions ... Wed, 26 Jan 2022 16:33:31 GMT Kinsey Moore [530a8c2] * bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S (added) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add debug vector and handler This patch adds a ... Wed, 26 Jan 2022 16:18:46 GMT Kinsey Moore [127980c] * bsps/microblaze/microblaze_fpga/start/_exception_handler.S (modified) * bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S (deleted) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add exception framework This patch updates the ... Thu, 23 Dec 2021 23:33:39 GMT Alex White [37543e19] * bsps/microblaze/microblaze_fpga/dts/system.dts (modified) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (modified) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * bsps/microblaze/microblaze_fpga/include/bsp/microblaze-dtb.h (moved) * bsps/microblaze/microblaze_fpga/irq/irq.c (modified) * bsps/microblaze/microblaze_fpga/start/bspstart.c (modified) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S (added) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdtbheaderpath.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml (added) microblaze: Add support for libbsd networking This includes fixes ... Wed, 26 Jan 2022 22:00:04 GMT Kinsey Moore [b539af8] * cpukit/libmisc/stackchk/check.c (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/stackchk02.yml (added) * testsuites/libtests/stackchk02/init.c (added) * testsuites/libtests/stackchk02/stackchk02.doc (added) * testsuites/libtests/stackchk02/stackchk02.scn (added) cpukit: Prevent error with disabled stack checker When the stack ... Wed, 26 Jan 2022 10:01:44 GMT Sebastian Huber [2145e0c7] * cpukit/include/rtems/gxx_wrappers.h (deleted) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/gxx01.yml (deleted) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal24.yml (deleted) * spec/build/testsuites/sptests/spfatal25.yml (deleted) * testsuites/libtests/gxx01/gxx01.doc (deleted) * testsuites/libtests/gxx01/gxx01.scn (deleted) * testsuites/libtests/gxx01/init.c (deleted) * testsuites/sptests/spfatal24/init.c (deleted) * testsuites/sptests/spfatal24/spfatal24.doc (deleted) * testsuites/sptests/spfatal24/spfatal24.scn (deleted) * testsuites/sptests/spfatal25/init.c (deleted) * testsuites/sptests/spfatal25/spfatal25.doc (deleted) * testsuites/sptests/spfatal25/spfatal25.scn (deleted) Remove obsolete rtems_gxx_*() implementation GCC versions prior to ... Thu, 13 Jan 2022 13:51:55 GMT Sebastian Huber [12a2a8e4] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/include/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) arm: Optimize interrupt handling Use the SRS (Store Return State) ... Thu, 13 Jan 2022 12:30:21 GMT Sebastian Huber [84ba194] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix stack alignment during interrupt handling On a public ... Mon, 17 Jan 2022 07:11:48 GMT Sebastian Huber [41a1903d] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Avoid duplicate move from CPSR Update #4579. Fri, 14 Jan 2022 08:05:50 GMT Sebastian Huber [0290e44] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Rework per-CPU control in interrupt handling Use volatile ... Fri, 14 Jan 2022 12:25:30 GMT Sebastian Huber [2d1ea1ab] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Use push/pop instructions for readability Update #4579. Wed, 22 Dec 2021 09:09:11 GMT Sebastian Huber [8657986] * cpukit/libtest/t-test-rtems-context.c (modified) libtest: Check for pending events Make sure there are no pending ... Wed, 22 Dec 2021 07:16:43 GMT Sebastian Huber [d404771] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Fix Clock Manager parameter descriptions Update #4572. Thu, 16 Dec 2021 20:36:19 GMT Ryan Long [98ab693] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) libmisc/rtems-fdt: close() file 'bf' close() file 'bf' to avoid ... Tue, 14 Dec 2021 15:06:19 GMT Sebastian Huber [60cec828] * cpukit/dtc/VERSION (modified) dtc: Update VERSION Thu, 18 Nov 2021 02:53:56 GMT Vikram Garhwal [75b3f48a] * cpukit/include/libfdt.h (modified) libfdt: overlay: make overlay_get_target() public This is done to ... Tue, 09 Nov 2021 15:47:19 GMT Elvira Khabirova [8b21a1b9] * cpukit/dtc/libfdt/fdt_addresses.c (modified) libfdt: fix an incorrect integer promotion UINT32_MAX is an integer ... Sat, 31 Jul 2021 11:48:42 GMT Georg Kotheimer [4c05a91] * cpukit/dtc/libfdt/fdt_strerror.c (modified) libfdt: Add ALIGNMENT error string The ALIGNMENT error was missing ... Fri, 18 Jun 2021 17:20:27 GMT Andre Przywara [c07e238] * cpukit/include/libfdt.h (modified) fdtget: Fix signedness comparisons warnings With -Wsign-compare, ... Tue, 08 Jun 2021 05:28:55 GMT David Gibson [21351a2] * cpukit/dtc/libfdt/fdt_rw.c (modified) Fix CID 1461557 Coverity gets a bit confused by loading ... Tue, 06 Apr 2021 19:07:12 GMT Rob Herring [34052ef] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: Add FDT alignment check to fdt_check_header() Only checking ... Tue, 09 Mar 2021 03:49:35 GMT David Gibson [a3fa0702] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Fix a possible "unchecked return value" warning Apparently ... Tue, 29 Dec 2020 04:17:49 GMT Justin Covell [a582ab3] * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) Set last_comp_version correctly in new dtb and fix potential version ... Wed, 16 Dec 2020 05:51:38 GMT David Gibson [0b85832] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Tweak description of assume-aligned load helpers There's a ... Fri, 11 Dec 2020 02:27:36 GMT Tom Rini [03b601af] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) * cpukit/include/libfdt.h (modified) libfdt: Internally perform potentially unaligned loads Commits ... Wed, 04 Nov 2020 13:06:05 GMT Tom Rini [064a1d7] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Check for 8-byte address alignment in fdt_ro_probe_() The ... Mon, 12 Oct 2020 16:53:31 GMT Andre Przywara [611a2a5a] * cpukit/include/libfdt.h (modified) libfdt: Fix kernel-doc comments The API documentation in libfdt.h ... Thu, 01 Oct 2020 16:46:30 GMT Andre Przywara [65b98121] * cpukit/dtc/libfdt/fdt_strerror.c (modified) libfdt: fdt_strerror(): Fix comparison warning With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:29 GMT Andre Przywara [140935c5] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_get_string(): Fix sequential write comparison warnings ... Thu, 01 Oct 2020 16:46:28 GMT Andre Przywara [58b4fe7] * cpukit/dtc/libfdt/fdt_wip.c (modified) libfdt: libfdt_wip: Fix comparison warning With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:27 GMT Andre Przywara [113cc99] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_create_with_flags(): Fix comparison warning With ... Thu, 01 Oct 2020 16:46:26 GMT Andre Przywara [a5ec1266] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fdt_move(): Fix comparison warnings With -Wsign-compare, ... Thu, 01 Oct 2020 16:46:25 GMT Andre Przywara [89e5744e] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_add_string_(): Fix comparison warning With ... Mon, 21 Sep 2020 16:53:02 GMT Andre Przywara [26bee33] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_node_offset_by_phandle(): Fix comparison warning With ... Mon, 21 Sep 2020 16:52:58 GMT Andre Przywara [bcc2bde] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_resize(): Fix comparison warning With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:56 GMT Andre Przywara [28f7e76] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: fdt_splice_(): Fix comparison warning With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:55 GMT Simon Glass [3437b91] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_get_string(): Fix comparison warnings With ... Mon, 21 Sep 2020 16:52:52 GMT Andre Przywara [11df656] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: fdt_grab_space_(): Fix comparison warning With ... Mon, 21 Sep 2020 16:52:51 GMT Andre Przywara [0df1a41f] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: fdt_mem_rsv(): Fix comparison warnings With -Wsign-compare, ... Mon, 21 Sep 2020 16:52:50 GMT Andre Przywara [0012580] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fdt_offset_ptr(): Fix comparison warnings With ... Thu, 13 Aug 2020 15:26:26 GMT Frank Mehnert [5a03ce8] * cpukit/dtc/libfdt/fdt.c (modified) libfdt: fix fdt_check_node_offset_ w/ VALID_INPUT ... Tue, 16 Jun 2020 01:12:17 GMT Patrick Oppenlander [f5379faf] * cpukit/include/libfdt.h (modified) libfdt: add extern "C" for C++ Signed-off-by: Patrick Oppenlander ... Thu, 18 Jun 2020 04:21:17 GMT Patrick Oppenlander [fcf257a] * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: trivial typo fix Signed-off-by: Patrick Oppenlander ... Mon, 15 Jun 2020 16:00:33 GMT Simon Glass [eaadf704] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Correct condition for reordering blocks This condition uses ... Thu, 05 Mar 2020 14:04:45 GMT Jan Beulich [caa59e66] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: fix undefined behaviour in fdt_splice_() libfdt: fix ... Mon, 02 Mar 2020 19:02:55 GMT Simon Glass [16420fbb] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checks This error ... Mon, 02 Mar 2020 19:02:54 GMT Simon Glass [fe0b99d] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Add support for disabling internal checks If libfdt returns ... Mon, 02 Mar 2020 19:02:53 GMT Simon Glass [1f2b9ad] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Improve comments in some of the assumptions Add a little ...
