# # ChangeLog for cpukit/zlib/INDEX in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 08:04:47 Sun, 28 Mar 2010 21:13:35 GMT Ralf Corsepius [f9be936] * cpukit/zlib/INDEX (modified) Import from zlib-1.2.5 Tue, 23 Feb 2010 04:38:27 GMT Ralf Corsepius [dbe1601] * cpukit/zlib/INDEX (modified) Import from zlib-1.2.4 Fri, 28 Oct 2005 07:22:42 GMT Ralf Corsepius [959f7df2] * cpukit/zlib/ChangeLog (added) * cpukit/zlib/FAQ (added) * cpukit/zlib/INDEX (added) * cpukit/zlib/Makefile (added) * cpukit/zlib/Makefile.in (added) * cpukit/zlib/README (added) * cpukit/zlib/adler32.c (added) * cpukit/zlib/algorithm.txt (added) * cpukit/zlib/amiga/Makefile.pup (added) * cpukit/zlib/amiga/Makefile.sas (added) * cpukit/zlib/as400/bndsrc (added) * cpukit/zlib/as400/compile.clp (added) * cpukit/zlib/as400/readme.txt (added) * cpukit/zlib/as400/zlib.inc (added) * cpukit/zlib/compress.c (added) * cpukit/zlib/configure (added) * cpukit/zlib/contrib/README.contrib (added) * cpukit/zlib/contrib/ada/buffer_demo.adb (added) * cpukit/zlib/contrib/ada/mtest.adb (added) * cpukit/zlib/contrib/ada/read.adb (added) * cpukit/zlib/contrib/ada/readme.txt (added) * cpukit/zlib/contrib/ada/test.adb (added) * cpukit/zlib/contrib/ada/zlib-streams.adb (added) * cpukit/zlib/contrib/ada/zlib-streams.ads (added) * cpukit/zlib/contrib/ada/zlib-thin.adb (added) * cpukit/zlib/contrib/ada/zlib-thin.ads (added) * cpukit/zlib/contrib/ada/zlib.adb (added) * cpukit/zlib/contrib/ada/zlib.ads (added) * cpukit/zlib/contrib/ada/zlib.gpr (added) * cpukit/zlib/contrib/asm586/README.586 (added) * cpukit/zlib/contrib/asm586/match.S (added) * cpukit/zlib/contrib/asm686/README.686 (added) * cpukit/zlib/contrib/asm686/match.S (added) * cpukit/zlib/contrib/blast/Makefile (added) * cpukit/zlib/contrib/blast/README (added) * cpukit/zlib/contrib/blast/blast.c (added) * cpukit/zlib/contrib/blast/blast.h (added) * cpukit/zlib/contrib/blast/test.pk (added) * cpukit/zlib/contrib/blast/test.txt (added) * cpukit/zlib/contrib/delphi/ZLib.pas (added) * cpukit/zlib/contrib/delphi/ZLibConst.pas (added) * cpukit/zlib/contrib/delphi/readme.txt (added) * cpukit/zlib/contrib/delphi/zlibd32.mak (added) * cpukit/zlib/contrib/dotzlib/DotZLib.build (added) * cpukit/zlib/contrib/dotzlib/DotZLib.chm (added) * cpukit/zlib/contrib/dotzlib/DotZLib.sln (added) * cpukit/zlib/contrib/dotzlib/DotZLib/AssemblyInfo.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/ChecksumImpl.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/CircularBuffer.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/CodecBase.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/Deflater.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/DotZLib.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/DotZLib.csproj (added) * cpukit/zlib/contrib/dotzlib/DotZLib/GZipStream.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/Inflater.cs (added) * cpukit/zlib/contrib/dotzlib/DotZLib/UnitTests.cs (added) * cpukit/zlib/contrib/dotzlib/LICENSE_1_0.txt (added) * cpukit/zlib/contrib/dotzlib/readme.txt (added) * cpukit/zlib/contrib/infback9/README (added) * cpukit/zlib/contrib/infback9/infback9.c (added) * cpukit/zlib/contrib/infback9/infback9.h (added) * cpukit/zlib/contrib/infback9/inffix9.h (added) * cpukit/zlib/contrib/infback9/inflate9.h (added) * cpukit/zlib/contrib/infback9/inftree9.c (added) * cpukit/zlib/contrib/infback9/inftree9.h (added) * cpukit/zlib/contrib/inflate86/inffas86.c (added) * cpukit/zlib/contrib/inflate86/inffast.S (added) * cpukit/zlib/contrib/iostream/test.cpp (added) * cpukit/zlib/contrib/iostream/zfstream.cpp (added) * cpukit/zlib/contrib/iostream/zfstream.h (added) * cpukit/zlib/contrib/iostream2/zstream.h (added) * cpukit/zlib/contrib/iostream2/zstream_test.cpp (added) * cpukit/zlib/contrib/iostream3/README (added) * cpukit/zlib/contrib/iostream3/TODO (added) * cpukit/zlib/contrib/iostream3/test.cc (added) * cpukit/zlib/contrib/iostream3/zfstream.cc (added) * cpukit/zlib/contrib/iostream3/zfstream.h (added) * cpukit/zlib/contrib/masm686/match.asm (added) * cpukit/zlib/contrib/masmx86/gvmat32.asm (added) * cpukit/zlib/contrib/masmx86/gvmat32c.c (added) * cpukit/zlib/contrib/masmx86/inffas32.asm (added) * cpukit/zlib/contrib/masmx86/mkasm.bat (added) * cpukit/zlib/contrib/masmx86/readme.txt (added) * cpukit/zlib/contrib/minizip/ChangeLogUnzip (added) * cpukit/zlib/contrib/minizip/Makefile (added) * cpukit/zlib/contrib/minizip/crypt.h (added) * cpukit/zlib/contrib/minizip/ioapi.c (added) * cpukit/zlib/contrib/minizip/ioapi.h (added) * cpukit/zlib/contrib/minizip/iowin32.c (added) * cpukit/zlib/contrib/minizip/iowin32.h (added) * cpukit/zlib/contrib/minizip/miniunz.c (added) * cpukit/zlib/contrib/minizip/minizip.c (added) * cpukit/zlib/contrib/minizip/mztools.c (added) * cpukit/zlib/contrib/minizip/mztools.h (added) * cpukit/zlib/contrib/minizip/unzip.c (added) * cpukit/zlib/contrib/minizip/unzip.h (added) * cpukit/zlib/contrib/minizip/zip.c (added) * cpukit/zlib/contrib/minizip/zip.h (added) * cpukit/zlib/contrib/pascal/example.pas (added) * cpukit/zlib/contrib/pascal/readme.txt (added) * cpukit/zlib/contrib/pascal/zlibd32.mak (added) * cpukit/zlib/contrib/pascal/zlibpas.pas (added) * cpukit/zlib/contrib/puff/Makefile (added) * cpukit/zlib/contrib/puff/README (added) * cpukit/zlib/contrib/puff/puff.c (added) * cpukit/zlib/contrib/puff/puff.h (added) * cpukit/zlib/contrib/puff/zeros.raw (added) * cpukit/zlib/contrib/testzlib/testzlib.c (added) * cpukit/zlib/contrib/testzlib/testzlib.sln (added) * cpukit/zlib/contrib/testzlib/testzlib.vcproj (added) * cpukit/zlib/contrib/untgz/Makefile (added) * cpukit/zlib/contrib/untgz/Makefile.msc (added) * cpukit/zlib/contrib/untgz/untgz.c (added) * cpukit/zlib/contrib/vstudio/readme.txt (added) * cpukit/zlib/contrib/vstudio/vc7/miniunz.vcproj (added) * cpukit/zlib/contrib/vstudio/vc7/minizip.vcproj (added) * cpukit/zlib/contrib/vstudio/vc7/zlib.rc (added) * cpukit/zlib/contrib/vstudio/vc7/zlibstat.vcproj (added) * cpukit/zlib/contrib/vstudio/vc7/zlibvc.def (added) * cpukit/zlib/contrib/vstudio/vc7/zlibvc.sln (added) * cpukit/zlib/contrib/vstudio/vc7/zlibvc.vcproj (added) * cpukit/zlib/crc32.c (added) * cpukit/zlib/crc32.h (added) * cpukit/zlib/deflate.c (added) * cpukit/zlib/deflate.h (added) * cpukit/zlib/example.c (added) * cpukit/zlib/examples/README.examples (added) * cpukit/zlib/examples/fitblk.c (added) * cpukit/zlib/examples/gzappend.c (added) * cpukit/zlib/examples/gzjoin.c (added) * cpukit/zlib/examples/gzlog.c (added) * cpukit/zlib/examples/gzlog.h (added) * cpukit/zlib/examples/zlib_how.html (added) * cpukit/zlib/examples/zpipe.c (added) * cpukit/zlib/gzio.c (added) * cpukit/zlib/infback.c (added) * cpukit/zlib/inffast.c (added) * cpukit/zlib/inffast.h (added) * cpukit/zlib/inffixed.h (added) * cpukit/zlib/inflate.c (added) * cpukit/zlib/inflate.h (added) * cpukit/zlib/inftrees.c (added) * cpukit/zlib/inftrees.h (added) * cpukit/zlib/make_vms.com (added) * cpukit/zlib/minigzip.c (added) * cpukit/zlib/msdos/Makefile.bor (added) * cpukit/zlib/msdos/Makefile.dj2 (added) * cpukit/zlib/msdos/Makefile.emx (added) * cpukit/zlib/msdos/Makefile.msc (added) * cpukit/zlib/msdos/Makefile.tc (added) * cpukit/zlib/old/Makefile.riscos (added) * cpukit/zlib/old/README (added) * cpukit/zlib/old/descrip.mms (added) * cpukit/zlib/old/os2/Makefile.os2 (added) * cpukit/zlib/old/os2/zlib.def (added) * cpukit/zlib/old/visual-basic.txt (added) * cpukit/zlib/old/zlib.html (added) * cpukit/zlib/projects/README.projects (added) * cpukit/zlib/projects/visualc6/README.txt (added) * cpukit/zlib/projects/visualc6/example.dsp (added) * cpukit/zlib/projects/visualc6/minigzip.dsp (added) * cpukit/zlib/projects/visualc6/zlib.dsp (added) * cpukit/zlib/projects/visualc6/zlib.dsw (added) * cpukit/zlib/qnx/package.qpg (added) * cpukit/zlib/trees.c (added) * cpukit/zlib/trees.h (added) * cpukit/zlib/uncompr.c (added) * cpukit/zlib/win32/DLL_FAQ.txt (added) * cpukit/zlib/win32/Makefile.bor (added) * cpukit/zlib/win32/Makefile.emx (added) * cpukit/zlib/win32/Makefile.gcc (added) * cpukit/zlib/win32/Makefile.msc (added) * cpukit/zlib/win32/VisualC.txt (added) * cpukit/zlib/win32/zlib.def (added) * cpukit/zlib/win32/zlib1.rc (added) * cpukit/zlib/zconf.h (added) * cpukit/zlib/zconf.in.h (added) * cpukit/zlib/zlib.3 (added) * cpukit/zlib/zlib.h (added) * cpukit/zlib/zutil.c (added) * cpukit/zlib/zutil.h (added) Import of zlib-1.2.2.2.tar.gz
