Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/score
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @b4e3b2b   10/28/98 19:25:12 Joel Sherrill Patch from Ian Lance Taylor <ian@…>. I just happened … 4.104.114.84.95
(edit) @ecc3fe3   09/23/98 16:41:00 Joel Sherrill IDLE task stack size now specified as a field in the CPU Table for all … 4.104.114.84.95
(edit) @b285860   08/31/98 23:03:45 Joel Sherrill Patch from Eric Valette <valette@…>: Eric> NB : there … 4.104.114.84.95
(edit) @eb562f2   08/21/98 16:39:52 Joel Sherrill Patch from Eric Valette <valette@…>: Here is a patch … 4.104.114.84.95
(edit) @29381405   08/21/98 16:16:00 Joel Sherrill Spacing changes 4.104.114.84.95
(edit) @8b2ee37c   08/19/98 20:09:59 Joel Sherrill Patch from Eric Valette <valette@…>: - Use the … 4.104.114.84.95
(edit) @ab0df696   08/05/98 15:15:46 Joel Sherrill Automatic CPU type detection code from Eric Valette … 4.104.114.84.95
(edit) @5ef4fae   08/01/98 14:40:51 Joel Sherrill Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire?4.104.114.84.95
(edit) @67a2288   07/23/98 22:02:34 Joel Sherrill Patch from Eric VALETTE <valette@…>: Here is a … 4.104.114.84.95
(edit) @dd6dddc   07/01/98 21:33:11 Joel Sherrill Fixed typo. 4.104.114.84.95
(edit) @7e4c3d8b   06/18/98 18:58:42 Joel Sherrill Modified _Objects_Is_class_valid() to correctly report that 0 was not … 4.104.114.84.95
(edit) @9a6994b4   06/18/98 15:22:35 Joel Sherrill Added freebsd support from Dario Alcocer <alcocer@…>. 4.104.114.84.95
(edit) @7738906   06/12/98 21:12:12 Joel Sherrill Added optimized version of memcpy.c to this directory since RTEMS … 4.104.114.84.95
(edit) @937a6f3c   06/03/98 19:00:17 Joel Sherrill Added CPU_ISR_PASSES_FRAME_POINTER so some ports could pass just the … 4.104.114.84.95
(edit) @75d0b0b   06/03/98 18:49:38 Joel Sherrill Corrected macros for assembly language program sections. 4.104.114.84.95
(edit) @72aa8cf   04/27/98 14:16:29 Joel Sherrill Fixed CVS Id 4.104.114.84.95
(edit) @8a1636d   04/15/98 22:16:22 Joel Sherrill Added bh, ch, dh, bl, cl, and dl register macros. 4.104.114.84.95
(edit) @0451b44   04/15/98 00:02:10 Joel Sherrill Per suggestion from Eric Norum, went from one initial extension set to … 4.104.114.84.95
(edit) @4381e50   04/14/98 22:44:49 Joel Sherrill Ralf Corsepius suggested a way to get rid of UNIX compiler files and … 4.104.114.84.95
(edit) @5e34bf4   03/31/98 14:19:27 Joel Sherrill Added "sigemptyset()" call to insure that the memcmp() would work. It … 4.104.114.84.95
(edit) @a30359bb   03/27/98 19:42:58 Joel Sherrill Changed int to unsigned32 to match cpu.h. 4.104.114.84.95
(edit) @c80add4   03/25/98 18:46:47 Joel Sherrill m68k software interrupt stack support from Chris Johns and Eric Norum. 4.104.114.84.95
(edit) @ddf142d   03/24/98 20:53:48 Joel Sherrill Added _XOPEN_SOURCE definition to allow use of UNIX IPC. 4.104.114.84.95
(edit) @bdac86b5   03/24/98 17:13:03 Joel Sherrill Real definition for the beginning of the data section per Eric Norum's … 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
(edit) @50cf94da   03/20/98 17:16:31 Joel Sherrill SH port submitted from Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @9b39bab   02/20/98 20:23:57 Joel Sherrill Modified to make it possible for an ISR to return a mutex which did … 4.104.114.84.95
(edit) @c7744ee0   02/18/98 19:34:51 Joel Sherrill Ralf Corsepius noted that there was a dead path in _Thread_Initialize. 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @77ea27fc   02/04/98 14:47:23 Joel Sherrill Ralf Corsepius noticed that generally was spelled incorrectly. 4.104.114.84.95
(edit) @3a85d03d   01/28/98 15:39:30 Joel Sherrill Change to remove warning on glibc2 systems per Ralf Corsepius's suggestion. 4.104.114.84.95
(edit) @2936b425   01/23/98 17:45:05 Joel Sherrill Solaris port updates from Chris Johns 4.104.114.84.95
(edit) @6ab91d9   01/20/98 20:32:15 Joel Sherrill Removed warning per Chris Johns' suggestion. 4.104.114.84.95
(edit) @87904ba   01/15/98 21:39:15 Joel Sherrill Error reported by Duncan Smith <dds@…>: >> >>There is a … 4.104.114.84.95
(edit) @b2225d7   01/06/98 15:40:35 Joel Sherrill Fixed spacing. 4.104.114.84.95
(edit) @01a5f6b2   12/06/97 15:09:30 Joel Sherrill Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were … 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @b6770d1   10/06/97 21:29:29 Joel Sherrill Fixed comment. 4.104.114.84.95
(edit) @e63e254e   08/22/97 19:19:07 Joel Sherrill Corrected bug per Katsutoshi Shibuya's report: The definition of … 4.104.114.84.95
(edit) @91333c2   07/31/97 22:04:17 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @eb14a2ff   07/09/97 23:55:39 Joel Sherrill Repository damaged -- files readded. 4.104.114.84.95
(edit) @b5fc21c   07/09/97 23:50:28 Joel Sherrill Added post switch extension. 4.104.114.84.95
(edit) @8fabc273   07/09/97 23:33:08 Joel Sherrill Added sp, sfc, and fpcsr register defines. 4.104.114.84.95
(edit) @00d2a828   05/28/97 20:36:35 Joel Sherrill Added support for context switching the data used by the gcc m68k … 4.104.114.84.95
(edit) @0a6fb22   04/22/97 20:19:25 Joel Sherrill Patch from Chris John <cjohns@…> to add use of a select … 4.104.114.84.95
(edit) @f2545552   04/22/97 19:57:02 Joel Sherrill multiprocessing fixed on linux by fixing cpu.c so correct form of … 4.104.114.84.95
(edit) @e71ce071   04/22/97 17:47:16 Joel Sherrill updated with new license information per Tony Bennett. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @5bf6ffb   04/16/97 17:34:40 Joel Sherrill Added FPSP support for MC68040 4.104.114.84.95
(edit) @3fc076d   04/09/97 20:04:52 Joel Sherrill added support for tracking thread cpu usage. 4.104.114.84.95
(edit) @192259f   04/09/97 20:04:36 Joel Sherrill enhanced printf statements 4.104.114.84.95
(edit) @48e34595   04/09/97 20:04:22 Joel Sherrill corrected spacing. 4.104.114.84.95
(edit) @bbb846b   04/09/97 20:03:59 Joel Sherrill added SYSTEM_STATE_SHUTDOWN 4.104.114.84.95
(edit) @d6ba279   04/07/97 21:24:02 Joel Sherrill added initialization of variable to eliminate warning. 4.104.114.84.95
(edit) @12d6f14   04/07/97 21:22:15 Joel Sherrill added "ifndef" to avoid redefinition warning. 4.104.114.84.95
(edit) @d749165   04/07/97 21:20:48 Joel Sherrill added "return" to eliminate warning. 4.104.114.84.95
(edit) @2ff1d549   04/07/97 21:20:35 Joel Sherrill added "ifndef" to avoid redefinition warning 4.104.114.84.95
(edit) @32ef3dc   04/07/97 21:19:59 Joel Sherrill commented out sccs_id to eliminate warning. 4.104.114.84.95
(edit) @77d20fb   04/07/97 21:18:50 Joel Sherrill Replaced warning message for cpus which do not have hardware support … 4.104.114.84.95
(edit) @94784cf8   04/07/97 21:16:47 Joel Sherrill changed signed int to unsigned to eliminate warning 4.104.114.84.95
(edit) @17c4511   04/07/97 21:16:31 Joel Sherrill added "ifndef" for ASM to avoid redefinition warnings. 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @c43b34c   03/11/97 15:42:14 Joel Sherrill modified _Chain_Insert_unprotected to have the form required to be … 4.104.114.84.95
(edit) @a3cfa9f   03/10/97 19:37:44 Joel Sherrill initialized a stack variable to avoid a warning. 4.104.114.84.95
(edit) @f926b34   03/08/97 03:51:55 Joel Sherrill Modified calls to _Thread_Change_priority to take a third argument. … 4.104.114.84.95
(edit) @541dfb2   01/29/97 00:22:24 Joel Sherrill Removed definitions which are now in targopts.h. This eliminates the … 4.104.114.84.95
(edit) @36dbb51   01/29/97 00:21:53 Joel Sherrill added type to macro to eliminate warning for untyped use of a register. 4.104.114.84.95
(edit) @b9181082   01/29/97 00:13:00 Joel Sherrill Added include of targopts.h. 4.104.114.84.95
(edit) @fc5e2d73   01/15/97 20:21:48 Joel Sherrill fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) 4.104.114.84.95
(edit) @1019ae4   01/08/97 16:20:47 Joel Sherrill added some casts to reduce warnings reported by users with Microtec … 4.104.114.84.95
(edit) @0d051533   01/08/97 16:19:47 Joel Sherrill added type definitions for all supported task entry formats 4.104.114.84.95
(edit) @e1a06d1b   12/02/96 22:47:38 Joel Sherrill Changes to reflect new revision of erc32 per Jiri Gaisler's … 4.104.114.84.95
(edit) @29d8227e   12/02/96 19:48:29 Joel Sherrill Updates from Derrick Ostertag <ostertag@…> to fix bug in … 4.104.114.84.95
(edit) @f4b7e297   12/02/96 19:43:22 Joel Sherrill Update from Chris Johns <cjohns@…> to add better support for … 4.104.114.84.95
(edit) @27f0d424   10/15/96 21:38:43 Joel Sherrill added support for cpu time used field in tcb 4.104.114.84.95
(edit) @f8c6333   10/15/96 21:38:33 Joel Sherrill added cpu time used field to tcb 4.104.114.84.95
(edit) @855edec   09/30/96 20:15:01 Joel Sherrill fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. 4.104.114.84.95
(edit) @94218b8   09/18/96 20:51:48 Joel Sherrill loop to clear workspace memory changed to use sizeof rather than … 4.104.114.84.95
(edit) @56e0b88   09/18/96 20:50:58 Joel Sherrill corrected prototype of _Objects_Get_next 4.104.114.84.95
(edit) @3861130   09/18/96 20:50:27 Joel Sherrill uses address object rather than direct pointer arithmetic 4.104.114.84.95
(edit) @4944b5bf   09/18/96 20:50:04 Joel Sherrill OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than … 4.104.114.84.95
(edit) @857c52f   09/18/96 20:49:36 Joel Sherrill MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof … 4.104.114.84.95
(edit) @533f89f   09/18/96 20:48:56 Joel Sherrill modified declaration of CORE_message_queue_Buffer_control to avoid use … 4.104.114.84.95
(edit) @d1193c7   09/18/96 20:47:31 Joel Sherrill corrected white space problems added CPU_STRUCTURE_ALIGNMENT to … 4.104.114.84.95
(edit) @a4d97d94   09/18/96 20:45:27 Joel Sherrill new files submitted by Craig Lebakken (lebakken@…) and Derrick … 4.104.114.84.95
(edit) @1d9d044   09/17/96 21:33:07 Joel Sherrill Reversed logic in conditional to correctly distinguish between FIFO … 4.104.114.84.95
(edit) @cda277f   09/11/96 19:16:07 Joel Sherrill added $Id$ to file headers cpu.h: added prototype for _CPU_ISR_Get_level() 4.104.114.84.95
(edit) @f198c63   09/06/96 18:11:41 Joel Sherrill new file for MIPS port by Craig Lebakken (lebakken@…) and … 4.104.114.84.95
(edit) @7fea679b   09/06/96 15:16:19 Joel Sherrill changed _TOD_Is_set from a function to a boolean variable 4.104.114.84.95
(edit) @cd3868cd   08/15/96 21:09:02 Joel Sherrill updates from Tony Bennett (tbennett@…) 4.104.114.84.95
(edit) @0600e86f   08/15/96 21:05:21 Joel Sherrill _Thread_Start_multitasking: added code to initialize the floating … 4.104.114.84.95
(edit) @c53eb2c3   08/13/96 20:46:10 Mark.Johannes removed count from Thread_queue_Control 4.104.114.84.95
(edit) @a66fcc5   08/13/96 20:43:51 Mark.Johannes removed Thread_queue_Get_number_waiting 4.104.114.84.95
(edit) @b2e8026   08/13/96 15:43:12 Joel Sherrill fixed spacing 4.104.114.84.95
(edit) @2a9a479   08/08/96 18:27:11 Mark.Johannes CORE_mutex_Status: added CORE_MUTEX_STATUS_CEILING_VIOLATED to enum 4.104.114.84.95
(edit) @6b722e2   08/08/96 12:32:50 Mark.Johannes _MPCI_Register_packet_processor: Changed prototype of fist parameter … 4.104.114.84.95
(edit) @3fd3da4   08/08/96 12:31:01 Mark.Johannes _MPCI_Register_packet_processor: changes first parameter type to … 4.104.114.84.95
(edit) @cc757fe   08/07/96 20:57:28 Mark.Johannes _CORE_Mutex_seize: added checks for priority ceiling violation, also … 4.104.114.84.95
(edit) @0f99198   08/06/96 16:26:11 Mark.Johannes _CORE_mutex_Seize: added change priority case if the mutex was obtained. 4.104.114.84.95
(edit) @503dc058   07/03/96 14:20:03 Joel Sherrill switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" 4.104.114.84.95
