@feb93ede
07/03/00 15:49:35 |
Joel Sherrill |
Changed extra_system_initialization_stack to …
4.104.114.84.95
@5532553
06/29/00 23:00:48 |
Joel Sherrill |
This is the initial addition of the port of RTEMS to the
Hitachi H8 …
4.104.114.84.95
@6f6ddc00
06/29/00 22:33:05 |
Joel Sherrill |
Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable code
that …
4.104.114.84.95
@d1716c98
06/15/00 22:02:28 |
Joel Sherrill |
Remove pragma align 4
4.104.114.84.95
@ac815430
06/14/00 17:07:54 |
Joel Sherrill |
Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius …
4.104.114.84.95
@61bd0301
06/14/00 15:52:24 |
Joel Sherrill |
Moved PowerPC cache management code to libcpu. Also compiled
mpc8xx …
4.104.114.84.95
@fdcb2b52
06/14/00 13:38:47 |
Joel Sherrill |
Thread iterator and libgjc support submitted too early.
4.104.114.84.95
@afd63b7
06/13/00 22:57:19 |
Joel Sherrill |
Added crude i960ka support.
4.104.114.84.95
@cf1f72e
06/13/00 21:53:38 |
Joel Sherrill |
Moved i386 and m68k cache management code to libcpu. Everything
now …
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@ce5b291f
06/12/00 18:45:54 |
Joel Sherrill |
Works on Solaris and Linux.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@e4c07444
04/13/00 14:47:15 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
4.104.114.84.95
@b6f9b5f1
03/01/00 18:08:53 |
Joel Sherrill |
Added routines to get and set C3x IOF register. The code is …
4.104.114.84.95
@8eacefcc
02/29/00 16:35:45 |
Joel Sherrill |
BSP now compiles and links with CAVSL board information. This …
4.104.114.84.95
@61ba9763
02/22/00 18:39:52 |
Joel Sherrill |
New port of RTEMS to TI C3x and C4x.
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@4e36a2f
01/31/00 15:27:02 |
Joel Sherrill |
Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from …
4.104.114.84.95
@318f591
01/27/00 14:37:17 |
Joel Sherrill |
Added after report from Quality Quorum <qqi@…> that …
4.104.114.84.95
@c941a98
01/21/00 15:07:55 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to implement this:
I'd …
4.104.114.84.95
@752badac
01/14/00 14:55:37 |
Joel Sherrill |
Removed warning.
4.104.114.84.95
@53fb837a
01/13/00 19:25:15 |
Joel Sherrill |
POSIX message queues now include complete functionality including …
4.104.114.84.95
@9c1c778d
01/13/00 18:32:38 |
Jennifer.Averett |
+ Added comments
4.104.114.84.95
@d65c3768
01/13/00 18:32:09 |
Jennifer.Averett |
+ Added and yellow line tested …
4.104.114.84.95
@e7d76dc
01/13/00 18:23:42 |
Jennifer.Averett |
Added comment.
4.104.114.84.95
@ea2c1d6
01/12/00 20:22:04 |
Jennifer.Averett |
+ Added code for waiting send
+ Yellow lined tested routine with Posix …
4.104.114.84.95
@89184f9
01/06/00 15:31:24 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@5870ac55
01/05/00 22:19:21 |
Joel Sherrill |
Added support for simple binary semaphores in addition to the high …
4.104.114.84.95
@db6ec79e
01/05/00 18:30:09 |
Joel Sherrill |
Fixed recursive release for mutexes with nesting allowed.
4.104.114.84.95
@b302d527
01/05/00 17:20:07 |
Jennifer.Averett |
+ Added return priority from message seize.
+ Changed priority to be …
4.104.114.84.95
@466b8882
01/05/00 17:18:51 |
Jennifer.Averett |
Added the recording of the submit type.
4.104.114.84.95
@58243b4
01/05/00 17:18:08 |
Jennifer.Averett |
+ Added return of the message priority.
4.104.114.84.95
@1dfc188e
01/04/00 13:58:47 |
Joel Sherrill |
Removed unitialized variable warning.
4.104.114.84.95
@e065e8ae
01/03/00 16:52:50 |
Joel Sherrill |
Increased stack size to 4K per Eric Norum.
4.104.114.84.95
@20385957
01/03/00 14:01:02 |
Joel Sherrill |
Increased minimum stack size so all tests will run.
4.104.114.84.95
@6b79a071
12/13/99 17:22:18 |
Joel Sherrill |
Patch from Jepsen Hans Peter <hans_peter_jepsen@…> to
use …
4.104.114.84.95
@7d91d72
12/13/99 15:29:20 |
Joel Sherrill |
First attempt at adding simple binary semaphore in addition to the …
4.104.114.84.95
@4090ebe
12/03/99 13:25:00 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius …
4.104.114.84.95
@43283456
12/02/99 17:45:14 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius …
4.104.114.84.95
@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@955a9ba7
12/01/99 15:05:26 |
Joel Sherrill |
4.104.114.84.95
@ccf8925b
12/01/99 14:22:12 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@b7912a89
11/22/99 14:25:01 |
Joel Sherrill |
Changed name of W, X, and Y macros for fields in the Clock
Synthesizer …
4.104.114.84.95
@75f2b0b
11/22/99 13:12:48 |
Joel Sherrill |
Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius …
4.104.114.84.95
@97c465c
11/18/99 21:30:12 |
Joel Sherrill |
Minor cleanup to reduce the code space.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@105d7872
11/18/99 19:50:15 |
Jennifer.Averett |
Added routine to remove an object from the namespace. It just clears …
4.104.114.84.95
@40fe60a3
11/17/99 20:44:13 |
Jennifer.Averett |
Comment added.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@7cc8d6c
11/02/99 21:48:15 |
Joel Sherrill |
Split core mutex and semaphore handlers into separate files.
4.104.114.84.95
@82cb78d8
11/02/99 21:45:15 |
Joel Sherrill |
Split core message queue and watchdog handler objects into separate files.
4.104.114.84.95
@93b4e6ef
11/02/99 21:05:17 |
Joel Sherrill |
Split Heap and Time of Day Handlers.
4.104.114.84.95
@dfbfa2b0
11/02/99 20:36:11 |
Joel Sherrill |
Split threadq.c into multiple files.
4.104.114.84.95
@317a5b5
11/02/99 19:43:52 |
Joel Sherrill |
Split object.c into multiple files.
4.104.114.84.95
@5d36b344
11/02/99 16:01:52 |
Joel Sherrill |
Fixed bug which resulted in misaligned object control structures
being …
4.104.114.84.95
@32441ab7
11/02/99 16:00:37 |
Joel Sherrill |
Added a comment to indicate that if a task blocked on a priority
based …
4.104.114.84.95
@2cd5444
11/02/99 15:58:39 |
Joel Sherrill |
Added code to allocate by index. This is the object ID style used
by …
4.104.114.84.95
@8f0529f
11/02/99 15:58:09 |
Joel Sherrill |
Added maximum count detection logic.
4.104.114.84.95
@9693fdac
11/02/99 15:57:58 |
Joel Sherrill |
Added support for message priority as required by POSIX.
4.104.114.84.95
@af10d3ef
11/02/99 15:57:43 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@7046cdd
10/28/99 16:01:41 |
Joel Sherrill |
Patch rtems-rc-19991011-3.diff from Ralf Corsepius.
4.104.114.84.95
@ae7325bd
10/27/99 17:25:53 |
Joel Sherrill |
rxgen960 now compiles -- may not link.
4.104.114.84.95
@702c5f5
10/27/99 15:29:18 |
Joel Sherrill |
The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson …
4.104.114.84.95
@e54a7d33
10/26/99 16:22:55 |
Joel Sherrill |
Patch from Gerwin Pfab <pb@…> to leave dispatching …
4.104.114.84.95
@30f7ff9
10/05/99 19:11:57 |
Joel Sherrill |
Removed targets and configurations that are no longer functional
and …
4.104.114.84.95
@d83c39dc
10/05/99 13:08:41 |
Joel Sherrill |
Bug report and fix from Jay Kulpinski <jskulpin@…> where …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@d392168
08/26/99 21:14:20 |
Joel Sherrill |
Typo causing compilation failure spotted by Ralf Corsepius and
fixed …
4.104.114.84.95
@71f16a4
08/19/99 22:07:00 |
Joel Sherrill |
Support for MPC505 from Sergei Organov <osv@…>. His patch was …
4.104.114.84.95
@f2180e0f
08/18/99 20:00:05 |
Joel Sherrill |
Patch from Jimen Ching <jimen@…>:
Please take a look at …
4.104.114.84.95
@e8367362
08/18/99 19:57:40 |
Joel Sherrill |
Slightly cleaner way to switch on the CPU model.
4.104.114.84.95
@ea562ee9
08/12/99 18:22:17 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
After …
4.104.114.84.95
@6805640e
07/29/99 23:01:15 |
Joel Sherrill |
to …
4.104.114.84.95
@f94e76ba
07/28/99 18:03:20 |
Joel Sherrill |
Fix after this report from Peter Pointner <pr@…>:
4.104.114.84.95
@b73e57b
07/09/99 17:08:48 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…>:
+ interrupt …
4.104.114.84.95
@64b29600
07/01/99 18:57:15 |
Joel Sherrill |
Removed hack to set USER_LABEL_PREFIX since late model gcc's and …
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@4c3a9c99
06/11/99 14:47:43 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
