@d83c39dc
10/05/99 13:08:41 |
Joel Sherrill |
Bug report and fix from Jay Kulpinski <jskulpin@…> where …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@d392168
08/26/99 21:14:20 |
Joel Sherrill |
Typo causing compilation failure spotted by Ralf Corsepius and
fixed …
4.104.114.84.95
@71f16a4
08/19/99 22:07:00 |
Joel Sherrill |
Support for MPC505 from Sergei Organov <osv@…>. His patch was …
4.104.114.84.95
@f2180e0f
08/18/99 20:00:05 |
Joel Sherrill |
Patch from Jimen Ching <jimen@…>:
Please take a look at …
4.104.114.84.95
@e8367362
08/18/99 19:57:40 |
Joel Sherrill |
Slightly cleaner way to switch on the CPU model.
4.104.114.84.95
@ea562ee9
08/12/99 18:22:17 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
After …
4.104.114.84.95
@6805640e
07/29/99 23:01:15 |
Joel Sherrill |
to …
4.104.114.84.95
@f94e76ba
07/28/99 18:03:20 |
Joel Sherrill |
Fix after this report from Peter Pointner <pr@…>:
4.104.114.84.95
@b73e57b
07/09/99 17:08:48 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…>:
+ interrupt …
4.104.114.84.95
@64b29600
07/01/99 18:57:15 |
Joel Sherrill |
Removed hack to set USER_LABEL_PREFIX since late model gcc's and …
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@4c3a9c99
06/11/99 14:47:43 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@73b943bc
03/31/99 23:21:19 |
Joel Sherrill |
Fixed paths to include files so this will build.
4.104.114.84.95
@6a10709
03/31/99 22:33:14 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
joel@… wrote:
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@6dfebd9
02/24/99 14:32:46 |
Joel Sherrill |
Corrected name of constant so this would compile.
4.104.114.84.95
@12710a56
02/19/99 23:35:42 |
Joel Sherrill |
Moved back up in tree.
4.104.114.84.95
@db903c74
02/19/99 23:32:51 |
Joel Sherrill |
Moved asm.h back up in tree.
4.104.114.84.95
@7713808
02/19/99 23:26:19 |
Joel Sherrill |
Moved to proper rtems/score
4.104.114.84.95
@7908ba5b
02/18/99 18:28:24 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@25d457b8
02/18/99 18:16:40 |
Joel Sherrill |
Yet another part of automake VI from Ralf Corsepius …
4.104.114.84.95
@e029467
02/18/99 15:16:37 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
You will find …
4.104.114.84.95
@f91b8df1
01/20/99 15:55:52 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to make m68360.h usable …
4.104.114.84.95
@ba2adf5
01/19/99 20:09:33 |
Joel Sherrill |
getting the …
4.104.114.84.95
@9d5c22e3
12/15/98 19:56:41 |
Joel Sherrill |
Switched to use of ASM compilation conditional.
4.104.114.84.95
@2417b15
12/15/98 15:00:25 |
Joel Sherrill |
Changed reference from no_cpu to mips64orion.
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@ed0e74e
12/03/98 21:53:25 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@b4e3b2b
10/28/98 19:25:12 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>.
I just happened …
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Eric> NB : there …
4.104.114.84.95
@eb562f2
08/21/98 16:39:52 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@29381405
08/21/98 16:16:00 |
Joel Sherrill |
Spacing changes
4.104.114.84.95
@8b2ee37c
08/19/98 20:09:59 |
Joel Sherrill |
- Use the …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@5ef4fae
08/01/98 14:40:51 |
Joel Sherrill |
Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire? …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@dd6dddc
07/01/98 21:33:11 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@7e4c3d8b
06/18/98 18:58:42 |
Joel Sherrill |
Modified _Objects_Is_class_valid() to correctly report that 0 was
not …
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@7738906
06/12/98 21:12:12 |
Joel Sherrill |
Added optimized version of memcpy.c to this directory since RTEMS …
4.104.114.84.95
@937a6f3c
06/03/98 19:00:17 |
Joel Sherrill |
Added CPU_ISR_PASSES_FRAME_POINTER so some ports could pass just the …
4.104.114.84.95
@75d0b0b
06/03/98 18:49:38 |
Joel Sherrill |
Corrected macros for assembly language program sections.
4.104.114.84.95
@72aa8cf
04/27/98 14:16:29 |
Joel Sherrill |
Fixed CVS Id
4.104.114.84.95
@8a1636d
04/15/98 22:16:22 |
Joel Sherrill |
Added bh, ch, dh, bl, cl, and dl register macros.
4.104.114.84.95
@0451b44
04/15/98 00:02:10 |
Joel Sherrill |
Per suggestion from Eric Norum, went from one initial extension set
to …
4.104.114.84.95
@4381e50
04/14/98 22:44:49 |
Joel Sherrill |
Ralf Corsepius suggested a way to get rid of UNIX compiler files and …
4.104.114.84.95
@5e34bf4
03/31/98 14:19:27 |
Joel Sherrill |
Added "sigemptyset()" call to insure that the memcmp() would work.
It …
4.104.114.84.95
@a30359bb
03/27/98 19:42:58 |
Joel Sherrill |
Changed int to unsigned32 to match cpu.h.
4.104.114.84.95
@c80add4
03/25/98 18:46:47 |
Joel Sherrill |
m68k software interrupt stack support from Chris Johns and Eric Norum.
4.104.114.84.95
@ddf142d
03/24/98 20:53:48 |
Joel Sherrill |
Added _XOPEN_SOURCE definition to allow use of UNIX IPC.
4.104.114.84.95
@bdac86b5
03/24/98 17:13:03 |
Joel Sherrill |
Real definition for the beginning of the data section per Eric Norum's …
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@50cf94da
03/20/98 17:16:31 |
Joel Sherrill |
SH port submitted from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@9b39bab
02/20/98 20:23:57 |
Joel Sherrill |
Modified to make it possible for an ISR to return a mutex which did …
4.104.114.84.95
@c7744ee0
02/18/98 19:34:51 |
Joel Sherrill |
Ralf Corsepius noted that there was a dead path in _Thread_Initialize.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@77ea27fc
02/04/98 14:47:23 |
Joel Sherrill |
Ralf Corsepius noticed that generally was spelled incorrectly.
4.104.114.84.95
@3a85d03d
01/28/98 15:39:30 |
Joel Sherrill |
Change to remove warning on glibc2 systems per Ralf Corsepius's
suggestion.
4.104.114.84.95
@2936b425
01/23/98 17:45:05 |
Joel Sherrill |
Solaris port updates from Chris Johns
4.104.114.84.95
@6ab91d9
01/20/98 20:32:15 |
Joel Sherrill |
Removed warning per Chris Johns' suggestion.
4.104.114.84.95
@87904ba
01/15/98 21:39:15 |
Joel Sherrill |
Error reported by Duncan Smith <dds@…>:
>> >>There is a …
4.104.114.84.95
@b2225d7
01/06/98 15:40:35 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@01a5f6b2
12/06/97 15:09:30 |
Joel Sherrill |
Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@b6770d1
10/06/97 21:29:29 |
Joel Sherrill |
Fixed comment.
4.104.114.84.95
@e63e254e
08/22/97 19:19:07 |
Joel Sherrill |
Corrected bug per Katsutoshi Shibuya's report:
The definition of …
4.104.114.84.95
@91333c2
07/31/97 22:04:17 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@eb14a2ff
07/09/97 23:55:39 |
Joel Sherrill |
Repository damaged -- files readded.
4.104.114.84.95
@b5fc21c
07/09/97 23:50:28 |
Joel Sherrill |
Added post switch extension.
4.104.114.84.95
@8fabc273
07/09/97 23:33:08 |
Joel Sherrill |
Added sp, sfc, and fpcsr register defines.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@0a6fb22
04/22/97 20:19:25 |
Joel Sherrill |
Patch from Chris John <cjohns@…> to add use of a select …
4.104.114.84.95
@f2545552
04/22/97 19:57:02 |
Joel Sherrill |
multiprocessing fixed on linux by fixing cpu.c so correct form of …
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@5bf6ffb
04/16/97 17:34:40 |
Joel Sherrill |
Added FPSP support for MC68040
4.104.114.84.95
@3fc076d
04/09/97 20:04:52 |
Joel Sherrill |
added support for tracking thread cpu usage.
4.104.114.84.95
@192259f
04/09/97 20:04:36 |
Joel Sherrill |
enhanced printf statements
4.104.114.84.95
@48e34595
04/09/97 20:04:22 |
Joel Sherrill |
corrected spacing.
4.104.114.84.95
@bbb846b
04/09/97 20:03:59 |
Joel Sherrill |
added SYSTEM_STATE_SHUTDOWN
4.104.114.84.95
@d6ba279
04/07/97 21:24:02 |
Joel Sherrill |
added initialization of variable to eliminate warning.
4.104.114.84.95
@12d6f14
04/07/97 21:22:15 |
Joel Sherrill |
added "ifndef" to avoid redefinition warning.
4.104.114.84.95
@d749165
04/07/97 21:20:48 |
Joel Sherrill |
added "return" to eliminate warning.
4.104.114.84.95
@2ff1d549
04/07/97 21:20:35 |
Joel Sherrill |
4.104.114.84.95
@32ef3dc
04/07/97 21:19:59 |
Joel Sherrill |
commented out sccs_id to eliminate warning.
4.104.114.84.95
@77d20fb
04/07/97 21:18:50 |
Joel Sherrill |
Replaced warning message for cpus which do not have hardware support …
4.104.114.84.95
@94784cf8
04/07/97 21:16:47 |
Joel Sherrill |
changed signed int to unsigned to eliminate warning
4.104.114.84.95
