@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@f31311aa
03/18/14 12:22:54 |
Sebastian Huber |
score: Add _Assert_Not_reached()
4.115
@72f4b98b
03/18/14 11:11:37 |
Sebastian Huber |
score: Add _Debug_Is_owner_of_allocator()
4.115
@a3dd225b
03/18/14 10:56:42 |
Sebastian Huber |
score: Delete _Assert_Owner_of_giant()
Add …
4.115
@ff25926
03/18/14 10:49:38 |
Sebastian Huber |
score: Delete _Assert_Thread_dispatching_repressed
Add …
4.115
@51f823c9
03/18/14 07:28:14 |
Sebastian Huber |
posix: Use interal mutex for once implementation
Enable …
4.115
@fa3993d9
03/18/14 09:56:17 |
Sebastian Huber |
score: Make _ISR_Enable_without_giant() available
Make …
4.115
@d6da1b1
03/14/14 12:55:00 |
Sebastian Huber |
score: Use only next field for chain on/off
It is sufficient to use …
4.115
@2a37016
03/13/14 14:21:09 |
cederman |
score: Add include for uintptr_t definition.
4.115
@148d6e9
03/06/14 14:51:10 |
Sebastian Huber |
arm: Add support for interrupt profiling
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@f980561
03/10/14 09:04:09 |
Sebastian Huber |
score: Add per-CPU profiling
Add per-CPU profiling stats API. …
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@e7d3967
03/06/14 14:16:01 |
Sebastian Huber |
arm: Fix stack alignment in interrupt handler
According to AAPCS, …
4.115
@e6c87f7
03/04/14 21:54:12 |
Joel Sherrill |
POSIX keys now enabled in all configurations.
Formerly POSIX keys …
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@9db8705
02/06/14 18:42:24 |
Jennifer Averett |
score: Add cpuset support to Score.
This new Score Handler provides a …
4.115
@3ca84d0c
03/06/14 09:53:17 |
Sebastian Huber |
score: Fix per-CPU state documentation
4.115
@825cb1f
03/04/14 12:02:18 |
Sebastian Huber |
score: Delete _Thread_Dispatch_set_disable_level()
This function was …
4.115
@8b50a55
03/03/14 08:09:24 |
Sebastian Huber |
score: Add _Atomic_Fence()
4.115
@ba25cc2
02/19/14 10:21:34 |
Sebastian Huber |
score: Add and use _Giant_Drop()
New test smptests/smpfatal03.
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@a4bc90af
02/24/14 11:45:00 |
Sebastian Huber |
sparc: Fix CPU counter support
The SPARC processors supported by …
4.115
@95d0c98
02/24/14 09:13:32 |
Sebastian Huber |
score: Fix thread TLS area initialization
Do not use _TLS_Size here …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@7ee4e72
02/20/14 16:05:44 |
Sebastian Huber |
score: _Thread_Start_multitasking()
Fix serious race-condition. Read …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@8a65a960
02/18/14 12:36:35 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Inline …
4.115
@c4ff027
02/18/14 12:30:28 |
Sebastian Huber |
score: Wait for per-CPU state changes later
Wait for per-CPU changes …
4.115
@b1d08a58
02/18/14 12:20:08 |
Sebastian Huber |
score: Initialize per-CPU locks
4.115
@282bfd3
02/18/14 12:03:27 |
Sebastian Huber |
score: Move _SMP_Handler_initialize()
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@6ca4f6a
02/17/14 13:56:51 |
Sebastian Huber |
score: Add and use <rtems/score/smpimpl.h>
Collect SMP implementation …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@2afe065
02/17/14 13:12:21 |
Sebastian Huber |
score: Remove ASM guard
4.115
@2cb95b5f
02/17/14 12:58:01 |
Sebastian Huber |
score: Rename RTEMS_BSP_SMP_SHUTDOWN
Rename RTEMS_BSP_SMP_SHUTDOWN in …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@8a6de83
02/17/14 09:10:27 |
Sebastian Huber |
score: Move _SMP_Request_other_cores_to_shutdown()
Move …
4.115
@38ee758
02/17/14 08:58:43 |
Sebastian Huber |
score: Disable ISR in _Internal_error_Occurred()
Disable interrupts …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@c2934b96
02/17/14 12:24:55 |
Sebastian Huber |
score: Move SMP interrupt stack initialization
Move SMP interrupt …
4.115
@ad7292f
02/14/14 11:57:53 |
Sebastian Huber |
score: Add SMP barrier
4.115
@0344ce03
02/13/14 14:43:03 |
Sebastian Huber |
score: Use atomic API for SMP lock
Use a ticket lock implementation …
4.115
@8a9568d2
02/14/14 10:18:13 |
Sebastian Huber |
Require presence of <stdatomic.h> for SMP support
4.115
@dcd97c7
02/14/14 11:48:49 |
Sebastian Huber |
sparc: Add atomic support for SPARC V8
Use SWAP instruction with one …
4.115
@ad56361
02/13/14 12:00:00 |
Sebastian Huber |
sparc: Add LEON3_ASR17_PROCESSOR_INDEX_SHIFT
Add …
4.115
@945853b7
02/13/14 14:38:52 |
Sebastian Huber |
score: Add Atomic_Uint
4.115
@cd2c655
02/13/14 13:28:50 |
Sebastian Huber |
score: Fix warnings, C++ compatibility, fix typos
4.115
@6f90ef7
02/13/14 12:08:46 |
Sebastian Huber |
score: Remove volatile from asm statements
The instructions to get …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@ece9754
02/11/14 13:48:35 |
Sebastian Huber |
sparc: Increase CPU_STRUCTURE_ALIGNMENT to 32
Recent LEON4 systems …
4.115
@97cf623d
02/05/14 10:36:05 |
Sebastian Huber |
sparc: Save/restore only non-volatile context
The …
4.115
@01794eb
02/07/14 07:55:02 |
Sebastian Huber |
score: Format _Thread_Get_maximum_internal_threads
4.115
@558cc8d
02/05/14 14:41:00 |
Sebastian Huber |
score: _CPU_Context_switch_to_first_task_smp()
Delete …
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@16a41cc
01/29/14 08:29:39 |
Sebastian Huber |
score: Add _Thread_Get_maximum_internal_threads()
4.115
@a49bc35
01/28/14 10:49:57 |
Sebastian Huber |
score: Add _Heap_Size_with_overhead()
4.115
@a850d04
01/28/14 10:32:35 |
Sebastian Huber |
score: Add _Workspace_Allocate_aligned()
4.115
@805ef2f2
11/30/13 19:53:41 |
Sebastian Huber |
arm: Add ARMv7-M SHCSR register bits
4.115
@2d1bdc8
12/24/13 05:38:42 |
Chris Johns |
cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. …
4.115
@f859d20
12/16/13 13:45:26 |
Sebastian Huber |
arm: Fix set by but not used warning
4.115
@4402308b
12/14/13 17:56:33 |
Joel Sherrill |
no_cpu/cpusmplock.h: Clean up to be compilable
4.115
@b4e8306
12/03/13 10:56:55 |
Sebastian Huber |
arm: Clear reservations
Recent GCC versions use atomic operations …
4.115
@aaaedba
11/29/13 10:13:51 |
Sebastian Huber |
score: Minor _Thread_Dispatch() optimization
It is not necessary to …
4.115
@ea3e6928
11/26/13 07:08:38 |
Sebastian Huber |
nios2: Typos
4.115
@1350a702
11/22/13 09:53:17 |
Sebastian Huber |
score: Format changes in _Thread_Set_state()
4.115
@96962b5
11/21/13 14:09:46 |
Sebastian Huber |
score: Simplify _Thread_queue_Dequeue_priority()
4.115
@e99b0e2
11/21/13 12:43:07 |
Sebastian Huber |
score: Use local variables for consistency
4.115
@4ea97d24
11/19/13 15:21:54 |
Sebastian Huber |
score/rbtree: Remove "unprotected" from API
4.115
@833dd90
11/19/13 15:09:39 |
Sebastian Huber |
score/rbtree: Delete protected operations
The user of the red-black …
4.115
@eea7c937
11/19/13 15:09:17 |
Sebastian Huber |
scheduler/EDF: Use unprotected insert and extract
Interrupts are …
4.115
@39a4574
06/24/13 13:21:46 |
Sebastian Huber |
powerpc: Add r2 to CPU context
The r2 may be used for thread-local …
4.115
@8dc2e7b
11/18/13 13:34:13 |
Sebastian Huber |
powerpc: Do not validate reserved XER bits
4.115
@3a7628e8
11/15/13 14:38:52 |
Sebastian Huber |
score: Objects_Information::extract visibility
This filed is only …
4.115
@85b52642
11/14/13 15:21:41 |
Sebastian Huber |
heapgetinfo: Free all delayed blocks
4.115
@f8a39cdc
11/14/13 23:27:13 |
Joel Sherrill |
no_cpu/.../cpu.h: Comment improvement
4.115
@bd90283
11/14/13 23:26:31 |
Joel Sherrill |
mips/.../cpu.h: Comment improvement
4.115
@b68cef17
10/23/13 11:29:17 |
Sebastian Huber |
score: New state STATES_WAITING_FOR_BSD_WAKEUP
This state is …
4.115
@ecd82b6d
09/22/13 14:40:44 |
Joel Sherrill |
basedefs.h: Add RTEMS_COMPILER_UNUSED_ATTRIBUTE.
4.115
@784d2a1
09/06/13 08:05:35 |
Sebastian Huber |
arm: Fix inconsistent define usage
4.115
@03e097b7
09/03/13 10:59:54 |
Sebastian Huber |
nios2: Include proper header file
4.115
@3bac8a4c
09/03/13 09:04:33 |
Sebastian Huber |
score: Use void * for some atomic pointer ops
4.115
@29f7d317
09/02/13 13:08:05 |
Sebastian Huber |
score: Use unsigned long for atomic integers
Use unsigned long …
4.115
@bf30999
08/23/13 14:15:50 |
Sebastian Huber |
smp: Add and use _Assert_Owner_of_giant()
Add and use …
4.115
@03aad60
08/28/13 09:27:26 |
Sebastian Huber |
score: Atomic flag changes
Delete _Atomic_Init_flag(). Change …
4.115
@58a70b76
08/27/13 13:14:04 |
wei.a.yang |
score: Simplify <rtems/score/cpuatomic.h>
Add proper license and …
4.115
@4288f9fd
08/27/13 13:10:50 |
Sebastian Huber |
score: Use static inline directly
This file uses already C11 …
4.115
@697d31e
08/25/13 13:45:41 |
wei.a.yang |
add atomic init function
4.115
@a4c3e71
08/26/13 15:38:15 |
Sebastian Huber |
score: Add SMP support to _Watchdog_Report_chain()
4.115
@23de794d
08/26/13 12:27:52 |
Sebastian Huber |
score: Add and use CHAIN_INITIALIZER_ONE_NODE().
Add and use …
4.115
@db0e05ff
08/23/13 09:57:11 |
Sebastian Huber |
score: Delete unused function parameter
4.115
@f8f1bdad
08/23/13 10:19:13 |
Sebastian Huber |
score: PR2140: Fix _Thread_queue_Process_timeout()
The …
4.115
@215ccce
08/23/13 09:52:01 |
Sebastian Huber |
score: PR2140: _Thread_queue_Extract()
Return if the executing …
4.115
