@75f09e5
02/21/96 14:43:34 |
Joel Sherrill |
Dispersal of internal thread handler resulted in IDLE thread becoming …
4.104.114.84.95
@b2b52cbc
02/14/96 19:00:00 |
Joel Sherrill |
Removed arguments from _Thread_Start_multitasking.
4.104.114.84.95
@744d2878
02/14/96 18:48:39 |
Joel Sherrill |
removed arguments from _Thread_Start_multitasking
4.104.114.84.95
@df26b788
02/14/96 17:06:57 |
Joel Sherrill |
white space problem
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@391f6628
02/13/96 15:38:37 |
Joel Sherrill |
more comments added and existing ones cleaned up in synchronization paths
4.104.114.84.95
@b38955b
02/13/96 15:38:03 |
Joel Sherrill |
comma removed from end of last enumerated element
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@8a38f3b
02/09/96 14:21:37 |
Joel Sherrill |
added clear of _ISR_Signals_to_thread_executing
4.104.114.84.95
@d57392d
02/08/96 16:18:38 |
Joel Sherrill |
alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT
4.104.114.84.95
@4f60309b
02/01/96 22:09:07 |
Joel Sherrill |
Swapped order of nested acquisition check and check for returning …
4.104.114.84.95
@f00a0522
02/01/96 21:54:40 |
Joel Sherrill |
synchronization state bugs address
4.104.114.84.95
@665356af
02/01/96 19:39:21 |
Joel Sherrill |
invalid use of tcb field resource count
4.104.114.84.95
@5d3e539
01/17/96 20:11:33 |
Joel Sherrill |
added class to initial id macro
4.104.114.84.95
@a625ccd
01/15/96 23:04:50 |
Joel Sherrill |
Made real body of _Heap_Walk conditional on RTEMS_DEBUG. This is …
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@5c491aef
12/20/95 15:39:19 |
Joel Sherrill |
changes remerged after lost in disk crash -- recovered from snapshot, …
4.104.114.84.95
@8bdcfc4
12/19/95 20:26:32 |
Joel Sherrill |
changes remerged after disk crash -- history lost
4.104.114.84.95
@67d224a
12/08/95 21:06:15 |
Joel Sherrill |
added correct use of _Thread_queue_Enter_critical_section
4.104.114.84.95
@ca201c9
12/05/95 15:28:12 |
Joel Sherrill |
minor changes so it would compile
4.104.114.84.95
@8d0b7d96
12/01/95 22:03:55 |
Joel Sherrill |
Insert mode argument to _Watchdog_Insert removed. Now are watchdog …
4.104.114.84.95
@caaa47c
12/01/95 21:08:03 |
Joel Sherrill |
Added new synchronization algorithm.
4.104.114.84.95
@ed32907
12/01/95 21:07:48 |
Joel Sherrill |
Added support for new synchronization algorithm. Specifically, the …
4.104.114.84.95
@4250c8b
12/01/95 21:07:25 |
Joel Sherrill |
4.104.114.84.95
@eedbfd9
12/01/95 19:27:40 |
Joel Sherrill |
Corrected use of the state WATCHDOG_REINSERT and renamed it …
4.104.114.84.95
@c4808ca
10/31/95 21:28:16 |
Joel Sherrill |
typos fixed
4.104.114.84.95
@9700578
10/30/95 21:54:45 |
Joel Sherrill |
SPARC port passes all tests
4.104.114.84.95
@591d45e
10/06/95 20:49:51 |
Joel Sherrill |
fixed null pointer dereference
4.104.114.84.95
@eb5a7e07
10/06/95 20:48:38 |
Joel Sherrill |
fixed missing CVS IDs
4.104.114.84.95
@c62d36f
10/06/95 20:01:20 |
Joel Sherrill |
SPARC merged and successfully tested w/o interrupt support
4.104.114.84.95
@1ceface
10/06/95 16:33:30 |
Joel Sherrill |
moved to new development machine and went to gcc 2.7.0
4.104.114.84.95
@11290355
09/29/95 17:19:16 |
Joel Sherrill |
all targets compile .. tony's patches in place
4.104.114.84.95
@37f4c2d
09/27/95 20:53:58 |
Joel Sherrill |
Modified UNIX simulator port so all references to native unix
stuff is …
4.104.114.84.95
@c701f197
09/27/95 20:52:56 |
Joel Sherrill |
Fixed typo
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@1e0f4c80
09/22/95 17:27:56 |
Joel Sherrill |
Removed unnecessary include files.
4.104.114.84.95
@7fe12f6
09/22/95 17:27:14 |
Joel Sherrill |
Removed unneeded referenced to rtems/fatal.h
4.104.114.84.95
@7af35da5
09/21/95 20:55:07 |
Joel Sherrill |
More file movement required api extension to be added to score
4.104.114.84.95
@cda7ecc
09/21/95 17:58:58 |
Joel Sherrill |
More file movement
4.104.114.84.95
@be650a84
09/21/95 16:22:25 |
Joel Sherrill |
moving files around
4.104.114.84.95
@d434b8d6
09/19/95 21:43:45 |
Joel Sherrill |
Modifications from Tony Bennett accepted to return aligned block.
4.104.114.84.95
@91a3554d
09/19/95 21:43:12 |
Joel Sherrill |
4.104.114.84.95
@38ffa0c
09/19/95 18:32:18 |
Joel Sherrill |
Incorporated the submission from John S. Gwynne …
4.104.114.84.95
@3652ad35
09/19/95 14:53:29 |
Joel Sherrill |
Minor bug fixes to get all targets compilable and running. The
single …
4.104.114.84.95
@b3ac6a8d
09/12/95 19:45:42 |
Joel Sherrill |
Initial attempt at building HP PA-RISC using Solaris hosted tools.
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@5072b07
08/29/95 17:49:21 |
Joel Sherrill |
new file -- split from inlines
4.104.114.84.95
@7f6a24ab
08/28/95 15:30:29 |
Joel Sherrill |
Added unused priority ceiling parameter to rtems_semaphore_create.
4.104.114.84.95
@5250ff39
08/23/95 21:06:31 |
Joel Sherrill |
Moved _Thread_Information -> _RTEMS_tasks_Information.
Added a table …
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@63edbb3f
08/22/95 16:57:18 |
Joel Sherrill |
Fixed missing RCS Ids
4.104.114.84.95
@6b45e470
08/22/95 16:44:49 |
Joel Sherrill |
Merged PowerPC port as submitted by Andy Bray of I-CUBED, Ltd …
4.104.114.84.95
@da6375b
08/22/95 16:03:46 |
Joel Sherrill |
fix broken RCS Ids -- $ accidentally lost merging changes earlier
4.104.114.84.95
@61361688
08/22/95 13:56:54 |
Joel Sherrill |
Modified object name to id translation loop to make it easier to …
4.104.114.84.95
@9863dbf
08/18/95 21:42:58 |
Joel Sherrill |
+ Added object type field to object id.
+ Added name pointer to …
4.104.114.84.95
@95fbca1
08/18/95 21:41:27 |
Joel Sherrill |
4.104.114.84.95
@b06e68ef
08/17/95 19:51:51 |
Joel Sherrill |
Numerous miscellaneous features incorporated from Tony Bennett …
4.104.114.84.95
@45819022
08/16/95 19:42:41 |
Joel Sherrill |
bug fixes to make macro implementations work
4.104.114.84.95
@4d9fa26
08/11/95 14:13:51 |
Joel Sherrill |
added constant for number of notepads
4.104.114.84.95
@e7e016f
08/04/95 22:18:45 |
Joel Sherrill |
cleanup and optimization from Tony
4.104.114.84.95
@0d55427
08/02/95 20:01:26 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@3a5dbdc
07/31/95 22:22:38 |
Joel Sherrill |
Switched to events for mp receive server and eliminated the special …
4.104.114.84.95
@1690c6b
07/21/95 20:10:49 |
Joel Sherrill |
after testing go32 and cvme961
4.104.114.84.95
@10aed1e3
07/18/95 19:58:45 |
Joel Sherrill |
fixed for Linux
4.104.114.84.95
@8044533
07/18/95 19:27:50 |
Joel Sherrill |
merged Linux UNIX simulator support (C)
4.104.114.84.95
@637df35
07/12/95 19:47:25 |
Joel Sherrill |
Ada95, gnat, go32
4.104.114.84.95
@68931b5
06/14/95 20:59:22 |
Joel Sherrill |
added David Glessner's 68302 work.
4.104.114.84.95
@34d877e
06/07/95 02:40:23 |
Joel Sherrill |
corrected pseudo-code for _ISR_Handler
4.104.114.84.95
@9e86dd7d
06/07/95 01:27:28 |
Joel Sherrill |
incorporated mc68302 support
4.104.114.84.95
@7979e35
06/04/95 22:43:19 |
Joel Sherrill |
changed release number to 3.2.0
4.104.114.84.95
@152e31a
05/25/95 15:26:53 |
Joel Sherrill |
TEST
4.104.114.84.95
@88d594a
05/24/95 21:39:42 |
Joel Sherrill |
Fully tested on all in-house targets
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
