@701dd96f
06/12/14 12:37:57 |
Sebastian Huber |
score: PR2181: Add _Thread_Yield()
The _Scheduler_Yield() was called …
4.115
@4639002
06/12/14 07:17:39 |
Sebastian Huber |
score: Make functions inline
These functions are used only via the …
4.115
@82df6f3
06/12/14 07:06:53 |
Sebastian Huber |
score: Move NULL pointer check to order function
This helps to avoid …
4.115
@6500614
06/12/14 06:49:08 |
Sebastian Huber |
score: Fix warnings
4.115
@d9b54da
06/12/14 06:48:02 |
Sebastian Huber |
score: Format
4.115
@6f4993e
06/12/14 06:43:25 |
Sebastian Huber |
score: Add missing inline
4.115
@238629f
05/19/14 20:26:55 |
Joel Sherrill |
Add SMP Priority Scheduler with Affinity
This scheduler attempts to …
4.115
@e473f3c
06/10/14 12:30:47 |
Sebastian Huber |
score: Fix MrsP root node update
Set the new root after the resource …
4.115
@9a1bab2
06/05/14 09:19:32 |
Sebastian Huber |
score: _Per_CPU_State_wait_for_non_initial_state()
Replace …
4.115
@be3c257
06/05/14 09:17:26 |
Sebastian Huber |
score: Avoid NULL pointer access
Check that the executing thread is …
4.115
@c952ecab
06/05/14 08:28:08 |
Sebastian Huber |
score: Delete SMP_FATAL_SHUTDOWN_EARLY
Sort enum lexicographically.
4.115
@4d1f500
06/03/14 13:58:30 |
Sebastian Huber |
score: Rename _Scheduler_Update()
Rename _Scheduler_Update() to …
4.115
@8e467384
06/03/14 08:29:30 |
Sebastian Huber |
score: Replace _Scheduler_Allocate/Free()
Replace …
4.115
@8df1f408
06/02/14 14:31:51 |
Christian.Mauderer |
score/sparc: Add support for paravirtualization
Guest systems in …
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@3045738
05/28/14 11:38:48 |
Sebastian Huber |
score: Add resource node to thread control block
4.115
@6c7caa1a
05/28/14 11:37:54 |
Sebastian Huber |
score: Add and use _Thread_Owns_resources()
4.115
@3e201139
05/23/14 08:00:33 |
Sebastian Huber |
score: Add Resource Handler
A resource is something that has at most …
4.115
@7c90670
06/02/14 11:23:07 |
Sebastian Huber |
arm: Add ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@a92c488
05/28/14 15:56:45 |
Sebastian Huber |
score: _Scheduler_Get_affinity()
Drop scheduler parameter. Coding style.
4.115
@e91ab8c
05/19/14 20:25:15 |
Joel Sherrill |
cpusetimpl.h: Add _CPU_set_Set() and improve Doxygen
4.115
@8e7db68c
04/14/14 21:05:04 |
Joel Sherrill |
Minor conditionals to enable building Scheduler Simulator on GNU/Linux …
4.115
@69c3f076
05/28/14 21:53:58 |
Joel Sherrill |
rtems/score/thread*.h: Really correct spelling error
4.115
@27caaa6
05/28/14 21:42:33 |
Joel Sherrill |
rtems/score/thread*.h: TERMINTING to TERMINATING
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@6a740c2
05/23/14 13:52:16 |
Daniel Hellstrom |
SPARC: add syscall 1 (exit) function entry point
The exit SPARC …
4.115
@b3049a1d
05/23/14 13:51:51 |
Sebastian Huber |
score: Use _SMP_Fatal()
4.115
@0af322c
05/23/14 12:27:12 |
Daniel Hellstrom |
SMP: make IPI fatal code unique
The same smp fatal code is used in …
4.115
@4edf348c
05/22/14 07:31:13 |
Sebastian Huber |
score: PR2179: Fix initially locked PCP mutexes
Elevate the priority …
4.115
@40741c44
05/19/14 20:26:20 |
Joel Sherrill |
cpuset.c: Fix formatting
4.115
@1bf0666
05/21/14 20:08:23 |
Joel Sherrill |
schedulersmpimpl.h: Fix spacing
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c8e83288
05/21/14 08:29:59 |
Sebastian Huber |
score: Add and use _Scheduler_Get_index_by_id()
4.115
@4ddc3b5
05/21/14 08:29:36 |
Sebastian Huber |
score: Add const qualifier
4.115
@884a6c59
05/21/14 07:18:29 |
Sebastian Huber |
score: Add comment regarding TLS workspace size
4.115
@40f2eafe
05/21/14 06:30:25 |
Sebastian Huber |
score: Simplify _Scheduler_Set()
4.115
@2d96533
05/20/14 06:06:43 |
Sebastian Huber |
score: SMP scheduler support documentation
4.115
@1ac0b083
05/16/14 08:55:01 |
Sebastian Huber |
score: Simplify SMP scheduler support
4.115
@b532bb2c
05/16/14 08:54:48 |
Sebastian Huber |
score: Fix state diagram
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@b4bdbcf
05/15/14 07:41:20 |
Sebastian Huber |
score: Make _Thread_queue_Requeue() static
This function is only used …
4.115
@6359b68
05/15/14 06:47:50 |
Sebastian Huber |
score: Add and use _Scheduler_SMP_Start_idle()
4.115
@3733b224
05/15/14 06:46:56 |
Sebastian Huber |
score: Add and use _Scheduler_default_Schedule()
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@2369b10
05/14/14 14:04:10 |
Sebastian Huber |
score: Add and use _Scheduler_Get_context()
4.115
@0f41cc3
05/14/14 09:25:07 |
Sebastian Huber |
score: _Scheduler_priority_Ready_queue_requeue()
Delete unused …
4.115
@c21c5912
05/14/14 09:11:05 |
Sebastian Huber |
score: Add STATES_RESTARTING
Use separate state for thread restart.
4.115
@01f302b
05/14/14 09:07:34 |
Sebastian Huber |
score: Typo
4.115
@3730a07f
05/13/14 13:08:07 |
Sebastian Huber |
score: Use Scheduler_Context for SMP scheduler
Use the basic …
4.115
@e9ee2f0
05/13/14 12:36:57 |
Sebastian Huber |
score: Capitalize SMP acronym
4.115
@c6522a65
05/12/14 06:38:38 |
Sebastian Huber |
score: SMP scheduler documentation
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@5b1ff71a
05/13/14 13:57:43 |
Sebastian Huber |
score: Scheduler documentation
4.115
@774ee002
05/14/14 08:17:47 |
cederman |
sparc: Change asm to asm to compile with -std=c99.
4.115
@390e73c4
05/12/14 13:55:25 |
Sebastian Huber |
score: Move out of RTEMS_HAVE_SYS_CPUSET_H
Move _Scheduler_Get() …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@6c36946f
05/07/14 12:22:56 |
Sebastian Huber |
score: Fix SMP startup
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@58444f7
05/06/14 13:16:39 |
Sebastian Huber |
score: Delete _SMP_Test_message_default_handler
A default handler is …
4.115
@07e7a7f8
05/07/14 06:13:44 |
Sebastian Huber |
score: Documentation
4.115
@4d906bda
05/02/14 13:47:57 |
Sebastian Huber |
score: Use atomic operations for SMP messages
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@bee71f8e
04/30/14 12:54:58 |
Sebastian Huber |
score: Fix TLS size usage
4.115
@dabf423
04/29/14 11:16:06 |
Sebastian Huber |
score: Typo
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a336d51
04/28/14 07:56:33 |
Sebastian Huber |
score: Avoid copy and paste
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@e5120a5
04/22/14 08:10:39 |
Sebastian Huber |
score: Add _CPU_Get_current_per_CPU_control()
Add optional method …
4.115
@1ed8762e
04/21/14 18:08:38 |
Joel Sherrill |
mpci.c: Now compiles again
4.115
@3380ee8
04/22/14 05:46:53 |
Sebastian Huber |
score: Use common names for per-CPU variables
Use "cpu" for an …
4.115
@f17e171
04/22/14 05:46:51 |
Sebastian Huber |
score: Fix warning
4.115
@861346d1
04/22/14 05:46:49 |
Sebastian Huber |
score: Delete superfluous assignments
These values are already zero …
4.115
@4c23fa4
04/22/14 05:46:47 |
Sebastian Huber |
score: Simplify Giant lock
4.115
@774edf2c
04/22/14 05:46:44 |
Sebastian Huber |
score: Use _Per_CPU_Get_snapshot()
4.115
@320faf8e
04/17/14 05:57:09 |
Sebastian Huber |
score: Clarify TLS support
4.115
@2e06be4
04/16/14 07:10:52 |
Sebastian Huber |
4.115
@33d0666
04/15/14 14:20:17 |
Sebastian Huber |
score: Critical fix for SMP
The _Scheduler_SMP_Allocate_processor() …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@27270b0d
04/09/14 08:09:39 |
Sebastian Huber |
rtems: Add task get/set scheduler
4.115
@1b67535d
04/09/14 08:09:57 |
Sebastian Huber |
rtems: Add scheduler get processors
4.115
@b427a92
04/09/14 08:09:24 |
Sebastian Huber |
rtems: Add scheduler identification
4.115
@133d54c5
04/09/14 08:33:00 |
Sebastian Huber |
score: Add scheduler name
4.115
@0712d17
04/08/14 09:14:27 |
Sebastian Huber |
score: Task get/set affinity
Make rtems_task_get_affinity() and …
4.115
@69aa3349
04/08/14 07:42:29 |
Sebastian Huber |
score: Simplify thread control initialization
The thread control …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@dc18190
04/14/14 10:41:57 |
Sebastian Huber |
score: Add and use RTEMS_ZERO_LENGTH_ARRAY
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@198c1433
04/10/14 06:18:00 |
Sebastian Huber |
score: Add _Per_CPU_Get_snapshot()
4.115
@67a7a2c
04/14/14 06:09:54 |
Sebastian Huber |
sparc: Use leon multilib define
4.115
@6cf45cb
04/07/14 14:50:13 |
Sebastian Huber |
score: Fix workspace size estimate for TLS
4.115
@d61c315
04/07/14 14:00:00 |
Sebastian Huber |
score: Fix for empty heap
4.115
@e785fbaa
04/04/14 11:58:26 |
Sebastian Huber |
score: Delete _Thread_Ticks_per_timeslice
Use the Configuration instead.
4.115
@47445846
04/04/14 11:43:15 |
Sebastian Huber |
score: Delete _Thread_Maximum_extensions
4.115
@57740ce8
04/07/14 12:50:24 |
Sebastian Huber |
score: Clarify CPU port alignment requirements
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@c6f0a4b7
04/04/14 14:24:44 |
Joel Sherrill |
schedulerpriorityaffinitysmp.h: Fix compilation error introduced by …
4.115
