@6b79a071
12/13/99 17:22:18 |
Joel Sherrill |
Patch from Jepsen Hans Peter <hans_peter_jepsen@…> to
use …
4.104.114.84.95
@7d91d72
12/13/99 15:29:20 |
Joel Sherrill |
First attempt at adding simple binary semaphore in addition to the …
4.104.114.84.95
@4090ebe
12/03/99 13:25:00 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius …
4.104.114.84.95
@43283456
12/02/99 17:45:14 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius …
4.104.114.84.95
@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@955a9ba7
12/01/99 15:05:26 |
Joel Sherrill |
4.104.114.84.95
@ccf8925b
12/01/99 14:22:12 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@b7912a89
11/22/99 14:25:01 |
Joel Sherrill |
Changed name of W, X, and Y macros for fields in the Clock
Synthesizer …
4.104.114.84.95
@75f2b0b
11/22/99 13:12:48 |
Joel Sherrill |
Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius …
4.104.114.84.95
@97c465c
11/18/99 21:30:12 |
Joel Sherrill |
Minor cleanup to reduce the code space.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@105d7872
11/18/99 19:50:15 |
Jennifer.Averett |
Added routine to remove an object from the namespace. It just clears …
4.104.114.84.95
@40fe60a3
11/17/99 20:44:13 |
Jennifer.Averett |
Comment added.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@7cc8d6c
11/02/99 21:48:15 |
Joel Sherrill |
Split core mutex and semaphore handlers into separate files.
4.104.114.84.95
@82cb78d8
11/02/99 21:45:15 |
Joel Sherrill |
Split core message queue and watchdog handler objects into separate files.
4.104.114.84.95
@93b4e6ef
11/02/99 21:05:17 |
Joel Sherrill |
Split Heap and Time of Day Handlers.
4.104.114.84.95
@dfbfa2b0
11/02/99 20:36:11 |
Joel Sherrill |
Split threadq.c into multiple files.
4.104.114.84.95
@317a5b5
11/02/99 19:43:52 |
Joel Sherrill |
Split object.c into multiple files.
4.104.114.84.95
@5d36b344
11/02/99 16:01:52 |
Joel Sherrill |
Fixed bug which resulted in misaligned object control structures
being …
4.104.114.84.95
@32441ab7
11/02/99 16:00:37 |
Joel Sherrill |
Added a comment to indicate that if a task blocked on a priority
based …
4.104.114.84.95
@2cd5444
11/02/99 15:58:39 |
Joel Sherrill |
Added code to allocate by index. This is the object ID style used
by …
4.104.114.84.95
@8f0529f
11/02/99 15:58:09 |
Joel Sherrill |
Added maximum count detection logic.
4.104.114.84.95
@9693fdac
11/02/99 15:57:58 |
Joel Sherrill |
Added support for message priority as required by POSIX.
4.104.114.84.95
@af10d3ef
11/02/99 15:57:43 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@7046cdd
10/28/99 16:01:41 |
Joel Sherrill |
Patch rtems-rc-19991011-3.diff from Ralf Corsepius.
4.104.114.84.95
@ae7325bd
10/27/99 17:25:53 |
Joel Sherrill |
rxgen960 now compiles -- may not link.
4.104.114.84.95
@702c5f5
10/27/99 15:29:18 |
Joel Sherrill |
The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson …
4.104.114.84.95
@e54a7d33
10/26/99 16:22:55 |
Joel Sherrill |
Patch from Gerwin Pfab <pb@…> to leave dispatching …
4.104.114.84.95
@30f7ff9
10/05/99 19:11:57 |
Joel Sherrill |
Removed targets and configurations that are no longer functional
and …
4.104.114.84.95
@d83c39dc
10/05/99 13:08:41 |
Joel Sherrill |
Bug report and fix from Jay Kulpinski <jskulpin@…> where …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@d392168
08/26/99 21:14:20 |
Joel Sherrill |
Typo causing compilation failure spotted by Ralf Corsepius and
fixed …
4.104.114.84.95
@71f16a4
08/19/99 22:07:00 |
Joel Sherrill |
Support for MPC505 from Sergei Organov <osv@…>. His patch was …
4.104.114.84.95
@f2180e0f
08/18/99 20:00:05 |
Joel Sherrill |
Patch from Jimen Ching <jimen@…>:
Please take a look at …
4.104.114.84.95
@e8367362
08/18/99 19:57:40 |
Joel Sherrill |
Slightly cleaner way to switch on the CPU model.
4.104.114.84.95
@ea562ee9
08/12/99 18:22:17 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
After …
4.104.114.84.95
@6805640e
07/29/99 23:01:15 |
Joel Sherrill |
to …
4.104.114.84.95
@f94e76ba
07/28/99 18:03:20 |
Joel Sherrill |
Fix after this report from Peter Pointner <pr@…>:
4.104.114.84.95
@b73e57b
07/09/99 17:08:48 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…>:
+ interrupt …
4.104.114.84.95
@64b29600
07/01/99 18:57:15 |
Joel Sherrill |
Removed hack to set USER_LABEL_PREFIX since late model gcc's and …
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@4c3a9c99
06/11/99 14:47:43 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@73b943bc
03/31/99 23:21:19 |
Joel Sherrill |
Fixed paths to include files so this will build.
4.104.114.84.95
@6a10709
03/31/99 22:33:14 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
joel@… wrote:
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@6dfebd9
02/24/99 14:32:46 |
Joel Sherrill |
Corrected name of constant so this would compile.
4.104.114.84.95
@12710a56
02/19/99 23:35:42 |
Joel Sherrill |
Moved back up in tree.
4.104.114.84.95
@db903c74
02/19/99 23:32:51 |
Joel Sherrill |
Moved asm.h back up in tree.
4.104.114.84.95
@7713808
02/19/99 23:26:19 |
Joel Sherrill |
Moved to proper rtems/score
4.104.114.84.95
@7908ba5b
02/18/99 18:28:24 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@25d457b8
02/18/99 18:16:40 |
Joel Sherrill |
Yet another part of automake VI from Ralf Corsepius …
4.104.114.84.95
@e029467
02/18/99 15:16:37 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
You will find …
4.104.114.84.95
@f91b8df1
01/20/99 15:55:52 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to make m68360.h usable …
4.104.114.84.95
@ba2adf5
01/19/99 20:09:33 |
Joel Sherrill |
getting the …
4.104.114.84.95
@9d5c22e3
12/15/98 19:56:41 |
Joel Sherrill |
Switched to use of ASM compilation conditional.
4.104.114.84.95
@2417b15
12/15/98 15:00:25 |
Joel Sherrill |
Changed reference from no_cpu to mips64orion.
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@ed0e74e
12/03/98 21:53:25 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@b4e3b2b
10/28/98 19:25:12 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>.
I just happened …
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Eric> NB : there …
4.104.114.84.95
@eb562f2
08/21/98 16:39:52 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@29381405
08/21/98 16:16:00 |
Joel Sherrill |
Spacing changes
4.104.114.84.95
@8b2ee37c
08/19/98 20:09:59 |
Joel Sherrill |
- Use the …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@5ef4fae
08/01/98 14:40:51 |
Joel Sherrill |
Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire? …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@dd6dddc
07/01/98 21:33:11 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@7e4c3d8b
06/18/98 18:58:42 |
Joel Sherrill |
Modified _Objects_Is_class_valid() to correctly report that 0 was
not …
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@7738906
06/12/98 21:12:12 |
Joel Sherrill |
Added optimized version of memcpy.c to this directory since RTEMS …
4.104.114.84.95
@937a6f3c
06/03/98 19:00:17 |
Joel Sherrill |
Added CPU_ISR_PASSES_FRAME_POINTER so some ports could pass just the …
4.104.114.84.95
@75d0b0b
06/03/98 18:49:38 |
Joel Sherrill |
Corrected macros for assembly language program sections.
4.104.114.84.95
@72aa8cf
04/27/98 14:16:29 |
Joel Sherrill |
Fixed CVS Id
4.104.114.84.95
@8a1636d
04/15/98 22:16:22 |
Joel Sherrill |
Added bh, ch, dh, bl, cl, and dl register macros.
4.104.114.84.95
