@3733b224
05/15/14 06:46:56 |
Sebastian Huber |
score: Add and use _Scheduler_default_Schedule()
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@2369b10
05/14/14 14:04:10 |
Sebastian Huber |
score: Add and use _Scheduler_Get_context()
4.115
@0f41cc3
05/14/14 09:25:07 |
Sebastian Huber |
score: _Scheduler_priority_Ready_queue_requeue()
Delete unused …
4.115
@c21c5912
05/14/14 09:11:05 |
Sebastian Huber |
score: Add STATES_RESTARTING
Use separate state for thread restart.
4.115
@01f302b
05/14/14 09:07:34 |
Sebastian Huber |
score: Typo
4.115
@3730a07f
05/13/14 13:08:07 |
Sebastian Huber |
score: Use Scheduler_Context for SMP scheduler
Use the basic …
4.115
@e9ee2f0
05/13/14 12:36:57 |
Sebastian Huber |
score: Capitalize SMP acronym
4.115
@c6522a65
05/12/14 06:38:38 |
Sebastian Huber |
score: SMP scheduler documentation
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@5b1ff71a
05/13/14 13:57:43 |
Sebastian Huber |
score: Scheduler documentation
4.115
@774ee002
05/14/14 08:17:47 |
cederman |
sparc: Change asm to asm to compile with -std=c99.
4.115
@390e73c4
05/12/14 13:55:25 |
Sebastian Huber |
score: Move out of RTEMS_HAVE_SYS_CPUSET_H
Move _Scheduler_Get() …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@6c36946f
05/07/14 12:22:56 |
Sebastian Huber |
score: Fix SMP startup
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@58444f7
05/06/14 13:16:39 |
Sebastian Huber |
score: Delete _SMP_Test_message_default_handler
A default handler is …
4.115
@07e7a7f8
05/07/14 06:13:44 |
Sebastian Huber |
score: Documentation
4.115
@4d906bda
05/02/14 13:47:57 |
Sebastian Huber |
score: Use atomic operations for SMP messages
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@bee71f8e
04/30/14 12:54:58 |
Sebastian Huber |
score: Fix TLS size usage
4.115
@dabf423
04/29/14 11:16:06 |
Sebastian Huber |
score: Typo
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a336d51
04/28/14 07:56:33 |
Sebastian Huber |
score: Avoid copy and paste
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@e5120a5
04/22/14 08:10:39 |
Sebastian Huber |
score: Add _CPU_Get_current_per_CPU_control()
Add optional method …
4.115
@1ed8762e
04/21/14 18:08:38 |
Joel Sherrill |
mpci.c: Now compiles again
4.115
@3380ee8
04/22/14 05:46:53 |
Sebastian Huber |
score: Use common names for per-CPU variables
Use "cpu" for an …
4.115
@f17e171
04/22/14 05:46:51 |
Sebastian Huber |
score: Fix warning
4.115
@861346d1
04/22/14 05:46:49 |
Sebastian Huber |
score: Delete superfluous assignments
These values are already zero …
4.115
@4c23fa4
04/22/14 05:46:47 |
Sebastian Huber |
score: Simplify Giant lock
4.115
@774edf2c
04/22/14 05:46:44 |
Sebastian Huber |
score: Use _Per_CPU_Get_snapshot()
4.115
@320faf8e
04/17/14 05:57:09 |
Sebastian Huber |
score: Clarify TLS support
4.115
@2e06be4
04/16/14 07:10:52 |
Sebastian Huber |
4.115
@33d0666
04/15/14 14:20:17 |
Sebastian Huber |
score: Critical fix for SMP
The _Scheduler_SMP_Allocate_processor() …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@27270b0d
04/09/14 08:09:39 |
Sebastian Huber |
rtems: Add task get/set scheduler
4.115
@1b67535d
04/09/14 08:09:57 |
Sebastian Huber |
rtems: Add scheduler get processors
4.115
@b427a92
04/09/14 08:09:24 |
Sebastian Huber |
rtems: Add scheduler identification
4.115
@133d54c5
04/09/14 08:33:00 |
Sebastian Huber |
score: Add scheduler name
4.115
@0712d17
04/08/14 09:14:27 |
Sebastian Huber |
score: Task get/set affinity
Make rtems_task_get_affinity() and …
4.115
@69aa3349
04/08/14 07:42:29 |
Sebastian Huber |
score: Simplify thread control initialization
The thread control …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@dc18190
04/14/14 10:41:57 |
Sebastian Huber |
score: Add and use RTEMS_ZERO_LENGTH_ARRAY
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@198c1433
04/10/14 06:18:00 |
Sebastian Huber |
score: Add _Per_CPU_Get_snapshot()
4.115
@67a7a2c
04/14/14 06:09:54 |
Sebastian Huber |
sparc: Use leon multilib define
4.115
@6cf45cb
04/07/14 14:50:13 |
Sebastian Huber |
score: Fix workspace size estimate for TLS
4.115
@d61c315
04/07/14 14:00:00 |
Sebastian Huber |
score: Fix for empty heap
4.115
@e785fbaa
04/04/14 11:58:26 |
Sebastian Huber |
score: Delete _Thread_Ticks_per_timeslice
Use the Configuration instead.
4.115
@47445846
04/04/14 11:43:15 |
Sebastian Huber |
score: Delete _Thread_Maximum_extensions
4.115
@57740ce8
04/07/14 12:50:24 |
Sebastian Huber |
score: Clarify CPU port alignment requirements
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@c6f0a4b7
04/04/14 14:24:44 |
Joel Sherrill |
schedulerpriorityaffinitysmp.h: Fix compilation error introduced by …
4.115
@24934e36
04/03/14 13:03:35 |
Sebastian Huber |
score: Add scheduler control to scheduler ops
Scheduler operations …
4.115
@439c494
04/03/14 10:02:09 |
Sebastian Huber |
score: Add and use Scheduler_simple_Control
4.115
@3891983
04/03/14 09:53:48 |
Sebastian Huber |
score: Add and use Scheduler_EDF_Control
4.115
@e8fffc2d
04/04/14 07:39:58 |
Sebastian Huber |
score: Delete superfluous field
4.115
@d62b5ac9
04/04/14 07:37:23 |
Sebastian Huber |
score: Include missing header file
4.115
@fc3c759
04/04/14 06:36:19 |
Sebastian Huber |
score: Move declaration to end of file
4.115
@da5b1b9
03/18/14 17:52:43 |
Jennifer Averett |
score: Remove affinity element from thread.
4.115
@56c396b
03/19/14 20:20:01 |
Jennifer Averett |
score: Add priority affinity smp scheduler.
4.115
@cfe457f
03/06/14 14:37:21 |
Jennifer Averett |
score: score: Add get/set affinity to Scheduler Framework.
4.115
@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
@f570b071
04/01/14 08:20:01 |
Sebastian Huber |
score: Rename Priority_bit_map_Control
Rename …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@4994927
04/01/14 08:01:52 |
Sebastian Huber |
score: Move log2table to separate file
4.115
@91e7b0c
03/27/14 08:04:47 |
Sebastian Huber |
score: PR2172: _Thread_queue_Extract()
Add …
4.115
@600bb68f
03/27/14 07:30:51 |
Sebastian Huber |
score: _Thread_queue_Extract_with_proxy()
Drop the return status, …
4.115
@03e89287
03/27/14 13:46:31 |
Sebastian Huber |
score: Delete CORE_mutex_Control::lock
The holder field is enough to …
4.115
@b1ce1161
03/27/14 13:29:00 |
Sebastian Huber |
score: Delete CORE_mutex_Control::holder_id
We can use the holder …
4.115
@cb8d3e7
03/27/14 07:04:10 |
Sebastian Huber |
score: Delete CORE_mutex_Control::blocked_count
4.115
@f0b4fd9
03/28/14 08:29:51 |
Sebastian Huber |
score: Do not reset resource count during restart
This fixes an …
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@34684573
03/27/14 12:38:04 |
Sebastian Huber |
score: Use thread life protection for API mutexes
This prevents that …
4.115
@fb7199d
03/13/14 14:25:06 |
Sebastian Huber |
score: Relax Giant lock usage for API mutexes
It is no longer …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@226c731
03/25/14 10:03:21 |
Sebastian Huber |
score: Replace _Thread_Reset()
Replace _Thread_Reset() with …
4.115
@8690b53
03/25/14 09:53:28 |
Sebastian Huber |
score: Add parameter to _Thread_Restart()
The executing thread will …
4.115
@391ad3e
03/17/14 14:03:22 |
Sebastian Huber |
score: Fix thread restart extensions context
Run the thread restart …
4.115
@084c5cc
03/18/14 15:13:23 |
Sebastian Huber |
score: Reduce _Thread_Reset() parameters
Move thread entry parameters …
4.115
@dcd5e26
03/18/14 15:11:03 |
Sebastian Huber |
score: Move _Thread_Reset() and make static
4.115
@5c731a83
03/17/14 09:12:14 |
Sebastian Huber |
score: Use thread action for thread restart
The thread restart is now …
4.115
@8061f56
03/14/14 10:55:28 |
Sebastian Huber |
score: Delete post-switch API extensions
Use thread post-switch …
4.115
@0dd732d
03/14/14 10:50:58 |
Sebastian Huber |
score: Add thread actions
Thread actions are the building block for …
4.115
@a5ac9da
03/14/14 09:17:34 |
Sebastian Huber |
score: Add and use thread get/set CPU functions
4.115
@c2225d7
03/28/14 08:24:28 |
Sebastian Huber |
score: Add _Scheduler_Change_priority_if_higher()
Add …
4.115
@298d0fd
03/24/14 06:44:00 |
Sebastian Huber |
score: Add _Scheduler_Highest_priority_of_two()
Use inline functions …
4.115
@7552e77c
11/18/13 12:25:49 |
Sebastian Huber |
score: PR2151: _Thread_queue_Extract_with_proxy()
Avoid NULL pointer …
4.115
@79e2d9b
03/06/14 10:11:59 |
Sebastian Huber |
score: Add per-CPU state function
Add …
4.115
@1fac361
03/24/14 07:51:37 |
Sebastian Huber |
score: PR2174: Add workaround
Add …
4.115
@9b44339c
03/24/14 06:53:45 |
Sebastian Huber |
score: Delete _Watchdog_Report()
Delete _Watchdog_Report_chain(). …
4.115
@5f104ee
03/25/14 07:53:33 |
Sebastian Huber |
score: Fix heap protection
Partially revert commit …
4.115
@2a713e3
03/24/14 14:57:29 |
Sebastian Huber |
score: _Heap_Protection_set_delayed_free_fraction
Add and use …
4.115
@383b2d3
03/24/14 06:54:16 |
Sebastian Huber |
score: Start thread dispatch profiling later
We are not interested in …
4.115
@72d8db9c
03/24/14 06:53:34 |
Sebastian Huber |
score: Delete _Thread_Internal_free()
4.115
@b0efca5
03/20/14 09:00:28 |
Sebastian Huber |
score: _Debug_Is_thread_dispatching_allowed()
Do not check ISR level …
4.115
@b3b9600
03/20/14 07:16:20 |
Sebastian Huber |
score: Delete unused STATES_ALL_SET
4.115
