@2ff1d549
04/07/97 21:20:35 |
Joel Sherrill |
added "ifndef" to avoid redefinition warning
4.104.114.84.95
@32ef3dc
04/07/97 21:19:59 |
Joel Sherrill |
commented out sccs_id to eliminate warning.
4.104.114.84.95
@77d20fb
04/07/97 21:18:50 |
Joel Sherrill |
Replaced warning message for cpus which do not have hardware support …
4.104.114.84.95
@94784cf8
04/07/97 21:16:47 |
Joel Sherrill |
changed signed int to unsigned to eliminate warning
4.104.114.84.95
@17c4511
04/07/97 21:16:31 |
Joel Sherrill |
added "ifndef" for ASM to avoid redefinition warnings.
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@c43b34c
03/11/97 15:42:14 |
Joel Sherrill |
modified _Chain_Insert_unprotected to have the form required to be …
4.104.114.84.95
@a3cfa9f
03/10/97 19:37:44 |
Joel Sherrill |
initialized a stack variable to avoid a warning.
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@541dfb2
01/29/97 00:22:24 |
Joel Sherrill |
Removed definitions which are now in targopts.h. This eliminates the …
4.104.114.84.95
@36dbb51
01/29/97 00:21:53 |
Joel Sherrill |
added type to macro to eliminate warning for untyped use of a register.
4.104.114.84.95
@b9181082
01/29/97 00:13:00 |
Joel Sherrill |
Added include of targopts.h.
4.104.114.84.95
@fc5e2d73
01/15/97 20:21:48 |
Joel Sherrill |
fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof)
4.104.114.84.95
@1019ae4
01/08/97 16:20:47 |
Joel Sherrill |
added some casts to reduce warnings reported by users with Microtec …
4.104.114.84.95
@0d051533
01/08/97 16:19:47 |
Joel Sherrill |
added type definitions for all supported task entry formats
4.104.114.84.95
@e1a06d1b
12/02/96 22:47:38 |
Joel Sherrill |
Changes to reflect new revision of erc32 per Jiri Gaisler's …
4.104.114.84.95
@29d8227e
12/02/96 19:48:29 |
Joel Sherrill |
Updates from Derrick Ostertag <ostertag@…> to fix bug in …
4.104.114.84.95
@f4b7e297
12/02/96 19:43:22 |
Joel Sherrill |
Update from Chris Johns <cjohns@…> to add better support for …
4.104.114.84.95
@27f0d424
10/15/96 21:38:43 |
Joel Sherrill |
added support for cpu time used field in tcb
4.104.114.84.95
@f8c6333
10/15/96 21:38:33 |
Joel Sherrill |
added cpu time used field to tcb
4.104.114.84.95
@855edec
09/30/96 20:15:01 |
Joel Sherrill |
fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro.
4.104.114.84.95
@94218b8
09/18/96 20:51:48 |
Joel Sherrill |
loop to clear workspace memory changed to use sizeof rather than …
4.104.114.84.95
@56e0b88
09/18/96 20:50:58 |
Joel Sherrill |
corrected prototype of _Objects_Get_next
4.104.114.84.95
@3861130
09/18/96 20:50:27 |
Joel Sherrill |
uses address object rather than direct pointer arithmetic
4.104.114.84.95
@4944b5bf
09/18/96 20:50:04 |
Joel Sherrill |
OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than …
4.104.114.84.95
@857c52f
09/18/96 20:49:36 |
Joel Sherrill |
MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof …
4.104.114.84.95
@533f89f
09/18/96 20:48:56 |
Joel Sherrill |
modified declaration of CORE_message_queue_Buffer_control to avoid use …
4.104.114.84.95
@d1193c7
09/18/96 20:47:31 |
Joel Sherrill |
corrected white space problems
added CPU_STRUCTURE_ALIGNMENT to …
4.104.114.84.95
@a4d97d94
09/18/96 20:45:27 |
Joel Sherrill |
new files submitted by Craig Lebakken (lebakken@…) and Derrick …
4.104.114.84.95
@1d9d044
09/17/96 21:33:07 |
Joel Sherrill |
Reversed logic in conditional to correctly distinguish between
FIFO …
4.104.114.84.95
@cda277f
09/11/96 19:16:07 |
Joel Sherrill |
added $Id$ to file headers
cpu.h: added prototype for _CPU_ISR_Get_level()
4.104.114.84.95
@f198c63
09/06/96 18:11:41 |
Joel Sherrill |
new file for MIPS port by Craig Lebakken (lebakken@…) and …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@cd3868cd
08/15/96 21:09:02 |
Joel Sherrill |
updates from Tony Bennett (tbennett@…)
4.104.114.84.95
@0600e86f
08/15/96 21:05:21 |
Joel Sherrill |
_Thread_Start_multitasking: added code to initialize the floating …
4.104.114.84.95
@c53eb2c3
08/13/96 20:46:10 |
Mark.Johannes |
removed count from Thread_queue_Control
4.104.114.84.95
@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@2a9a479
08/08/96 18:27:11 |
Mark.Johannes |
CORE_mutex_Status: added CORE_MUTEX_STATUS_CEILING_VIOLATED to enum
4.104.114.84.95
@6b722e2
08/08/96 12:32:50 |
Mark.Johannes |
_MPCI_Register_packet_processor: Changed prototype of fist parameter …
4.104.114.84.95
@3fd3da4
08/08/96 12:31:01 |
Mark.Johannes |
_MPCI_Register_packet_processor: changes first parameter type to …
4.104.114.84.95
@cc757fe
08/07/96 20:57:28 |
Mark.Johannes |
_CORE_Mutex_seize: added checks for priority ceiling violation, also …
4.104.114.84.95
@0f99198
08/06/96 16:26:11 |
Mark.Johannes |
_CORE_mutex_Seize: added change priority case if the mutex was obtained.
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@1b17790c
06/13/96 16:43:39 |
Joel Sherrill |
Added code so post context switch extensions can be run on every …
4.104.114.84.95
@4a1bc34b
06/12/96 17:45:34 |
Joel Sherrill |
added waiting for signal state.
4.104.114.84.95
@12aeff91
06/11/96 16:03:15 |
Joel Sherrill |
Interruptible by signals state was added to the STATES_BLOCKED set. …
4.104.114.84.95
@0f63c86
06/10/96 20:47:56 |
Joel Sherrill |
added code to _Thread_Clear_state to check if the state was not …
4.104.114.84.95
@81daab3
06/07/96 15:22:19 |
Joel Sherrill |
added states for "join at exit" and "interruptible by signal"
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@2f200c7
06/06/96 14:55:01 |
Joel Sherrill |
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@7169852
06/05/96 18:34:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@23305a25
06/05/96 14:46:04 |
Joel Sherrill |
added support for the api providing the thread stack area
4.104.114.84.95
@98162c35
06/05/96 14:45:45 |
Joel Sherrill |
added boolean to indicate whether or not the stack area was provided …
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@f6e6ed8
06/03/96 15:49:22 |
Joel Sherrill |
changed so this file is usable from assembly files.
no longer uses …
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@c832429
05/31/96 19:02:13 |
Joel Sherrill |
added nanoseconds per second constant
4.104.114.84.95
@7c55e06
05/30/96 20:48:33 |
Joel Sherrill |
Added nanoseconds constant
4.104.114.84.95
@d835a35
05/29/96 19:28:15 |
Joel Sherrill |
spacing
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@7640525
05/28/96 19:29:02 |
Joel Sherrill |
added enumerated constant for the POSIX API as an error source
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
@d196e48
05/23/96 15:34:54 |
Joel Sherrill |
updates from Tony Bennett.
Broke the setjmp/longjmp pair in the …
4.104.114.84.95
@ef006c1
05/22/96 22:34:18 |
Joel Sherrill |
Modified to correct variables which defined the range of object …
4.104.114.84.95
@1c964ffa
05/08/96 21:53:50 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@dce1c1a1
05/01/96 15:24:37 |
Joel Sherrill |
Updates from Eric Norum to use the mcpu32 flags and fix comments.
4.104.114.84.95
@1543932
04/24/96 17:36:35 |
Joel Sherrill |
added comment regarding stack alignment issues to thread stack …
4.104.114.84.95
@8faca06
04/22/96 16:46:36 |
Joel Sherrill |
thread.c: added support for optional user provided stack allocator
4.104.114.84.95
@6365f81
04/22/96 16:46:00 |
Joel Sherrill |
made initialization routine a regular subroutine
4.104.114.84.95
@a155b3c
04/22/96 16:45:47 |
Joel Sherrill |
interr.h: added stack allocater error code
wkspace.h: made …
4.104.114.84.95
@cc4c1fe4
04/22/96 16:44:54 |
Joel Sherrill |
added stack allocation fields to the cpu table
updates from Tony …
4.104.114.84.95
@9a1ccb3
04/22/96 16:43:44 |
Joel Sherrill |
added CPU_M68K_EXTB_L …
4.104.114.84.95
@d0b7c4e6
04/22/96 16:30:02 |
Joel Sherrill |
updartes from Tony Bennett
4.104.114.84.95
@f4d52cd7
04/19/96 19:36:59 |
Joel Sherrill |
changes to compile in macro configuration without warnings.
4.104.114.84.95
@14966f8
03/21/96 20:19:55 |
Joel Sherrill |
4.104.114.84.95
@f398452
03/21/96 20:19:33 |
Joel Sherrill |
updated for 68302 and so gen68360 bsp would compile
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@8e76546
03/06/96 21:26:28 |
Joel Sherrill |
Removed prototyes for static inline rgutines and moved the comments …
4.104.114.84.95
@adf98bd
02/21/96 14:44:11 |
Joel Sherrill |
Removed the internal thread objects and dispersed its contents to
the …
4.104.114.84.95
@75f09e5
02/21/96 14:43:34 |
Joel Sherrill |
Dispersal of internal thread handler resulted in IDLE thread becoming …
4.104.114.84.95
@b2b52cbc
02/14/96 19:00:00 |
Joel Sherrill |
Removed arguments from _Thread_Start_multitasking.
4.104.114.84.95
@744d2878
02/14/96 18:48:39 |
Joel Sherrill |
removed arguments from _Thread_Start_multitasking
4.104.114.84.95
@df26b788
02/14/96 17:06:57 |
Joel Sherrill |
white space problem
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@391f6628
02/13/96 15:38:37 |
Joel Sherrill |
more comments added and existing ones cleaned up in synchronization paths
4.104.114.84.95
@b38955b
02/13/96 15:38:03 |
Joel Sherrill |
comma removed from end of last enumerated element
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@8a38f3b
02/09/96 14:21:37 |
Joel Sherrill |
added clear of _ISR_Signals_to_thread_executing
4.104.114.84.95
@d57392d
02/08/96 16:18:38 |
Joel Sherrill |
alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT
4.104.114.84.95
@4f60309b
02/01/96 22:09:07 |
Joel Sherrill |
Swapped order of nested acquisition check and check for returning …
4.104.114.84.95
@f00a0522
02/01/96 21:54:40 |
Joel Sherrill |
synchronization state bugs address
4.104.114.84.95
@665356af
02/01/96 19:39:21 |
Joel Sherrill |
invalid use of tcb field resource count
4.104.114.84.95
@5d3e539
01/17/96 20:11:33 |
Joel Sherrill |
added class to initial id macro
4.104.114.84.95
@a625ccd
01/15/96 23:04:50 |
Joel Sherrill |
Made real body of _Heap_Walk conditional on RTEMS_DEBUG. This is …
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@5c491aef
12/20/95 15:39:19 |
Joel Sherrill |
changes remerged after lost in disk crash -- recovered from snapshot, …
4.104.114.84.95
@8bdcfc4
12/19/95 20:26:32 |
Joel Sherrill |
changes remerged after disk crash -- history lost
4.104.114.84.95
