@2f0a0936
01/25/13 15:55:25 |
wei.a.yang |
score: atomic support for RTEMS. Generic atomic operations API definition.
4.115
@9d23df2
01/25/13 15:53:52 |
wei.a.yang |
score: atomic support for RTEMS automake and autoconf changes
4.115
@0cce75e
01/14/13 08:54:21 |
Sebastian Huber |
NIOS2: Fix register restore sequence in epilogue
This fix is …
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@b10825c
01/10/13 19:29:41 |
Joel Sherrill |
cpukit: Add EOL on files missing EOL at EOF
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@ed70eaea
01/10/13 14:50:33 |
alexivanov97 |
score: Doxygen Clean Up Task #14
4.115
@11050207
01/10/13 13:50:26 |
alexivanov97 |
score: Doxygen Clean Up Task #12
4.115
@d8134178
01/09/13 16:20:58 |
alexivanov97 |
score: Doxygen Clean Up Task #18
4.115
@1f0d013
01/09/13 13:56:28 |
alexivanov97 |
score: Doxygen Clean Up Task #17
4.115
@4f5740f
01/08/13 19:36:13 |
alexivanov97 |
score: Doxygen Clean Up Task #16
4.115
@1362b7a
01/08/13 17:39:08 |
alexivanov97 |
score: Doxygen Clean Up Task #4
4.115
@66fffc7
01/08/13 15:22:33 |
alexivanov97 |
score: Doxygen Clean Up Task #15
4.115
@34d12977
01/07/13 14:45:34 |
matkallada |
score: Doxygen Clean Up Task #11
4.115
@2570a2a8
01/07/13 13:55:23 |
Sebastian Huber |
arm: Add AIRCR register defines
4.115
@2f28a03
01/07/13 12:42:09 |
Sebastian Huber |
arm: Implement CPU_Exception_frame_print()
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@e377ad7
01/07/13 07:48:45 |
Sebastian Huber |
arm: Include <rtems/score/cpu.h>
4.115
@0d8cde9
01/07/13 07:39:45 |
Sebastian Huber |
arm: Provide CPU_Exception_frame for ARMv7-M
4.115
@0f7abd99
01/04/13 15:25:19 |
Sebastian Huber |
arm: Rename inline functions
Rename arm_status_irq_enable() to …
4.115
@8df0e91
01/04/13 15:22:18 |
Sebastian Huber |
arm: Move inline functions
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@50f3c42b
01/04/13 13:22:10 |
Sebastian Huber |
arm: Add and use _ARM_Exception_default()
4.115
@8d687737
01/04/13 13:09:19 |
Sebastian Huber |
arm: Change CPU_Exception_frame
Provide proper CPU_Exception_frame …
4.115
@010c09a
01/04/13 12:20:37 |
Sebastian Huber |
arm: Rename type and functions
Rename arm_exc_abort_handler to …
4.115
@c04ac2ca
01/04/13 12:16:35 |
Sebastian Huber |
arm: Move type definition and prototypes
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@31eebc9
01/04/13 11:32:19 |
Sebastian Huber |
arm: Delete unused arm_exc_undefined()
4.115
@b41f2e2
01/03/13 16:07:14 |
Sebastian Huber |
score: Fix _Objects_Shrink_information()
The chain iteration was …
4.115
@00c1cd5
01/04/13 15:06:08 |
matkallada |
score: Doxygen Clean Up Task #10
4.115
@a1f9934a
01/04/13 15:01:21 |
matkallada |
score: Doxygen Clean Up Task #3
4.115
@455bd4e
01/04/13 14:49:56 |
alexivanov97 |
score: Doxygen Clean Up Task #9
4.115
@d9e0006
01/02/13 17:27:31 |
alexivanov97 |
score: Doxygen Clean Up Task #5
4.115
@0ca61727
12/22/12 16:58:50 |
Sebastian Huber |
score: Add const qualifier
4.115
@53afcfd2
12/22/12 16:57:07 |
Sebastian Huber |
score: Do not inline _RBTree_Find_unprotected()
This function is to …
4.115
@1dbbc0c
12/29/12 16:27:48 |
matkallada |
4.115
@b98bb9e
12/29/12 13:34:18 |
matkallada |
score: Doxygen Clean Up Task #6
4.115
@9abeca85
12/29/12 12:22:26 |
Jennifer Averett |
cpukit avr: Replace dos eol with unix eol.
4.115
@38fcda7f
12/29/12 12:17:51 |
matkallada |
score: Doxygen Clean Up Task #8
4.115
@a65f4b19
12/29/12 00:12:12 |
matkallada |
score: Doxygen Clean Up Task #7
4.115
@319cb20
12/29/12 00:04:01 |
matkallada |
score: Doxygen Clean Up Task #2
4.115
@3cf4031
12/28/12 23:48:12 |
alexivanov97 |
Header File Doxygen Enhancement Task #1
4.115
@c5782a2
12/28/12 17:16:29 |
matkallada |
Header File Doxygen Enhancement Task #7
4.115
@b8fc260f
12/28/12 15:48:37 |
Joel Sherrill |
Miscellaneous Doxygen clean-up
4.115
@fe1dc22
12/21/12 09:17:34 |
Sebastian Huber |
score: Add _Objects_Active_count()
4.115
@cbd07e4
12/21/12 08:50:15 |
Sebastian Huber |
score: Add rtems_chain_node_count_unprotected()
4.115
@7b5513f0
12/18/12 16:27:49 |
Andreas Heinig |
PR2083 Wrong return value in _RBTree_Has_only_one_node
The function …
4.115
@d0b9295f
12/14/12 09:17:04 |
Sebastian Huber |
Fix spelling
4.115
@c2ae79e
12/12/12 20:57:49 |
matkallada |
misc: Header File Doxygen Enhancement Task #3
4.115
@b7185613
12/07/12 14:57:04 |
alexivanov97 |
score misc: Clean up Doxygen GCI Task #12
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@04b5d17
11/28/12 09:45:38 |
Sebastian Huber |
score: Add API extensions post switch list
Move post switch hook from …
4.115
@0d66dd7
12/05/12 15:04:02 |
Sebastian Huber |
score: Add _Chain_Append_if_is_off_chain_*()
4.115
@038bc6e7
12/05/12 16:56:19 |
Sebastian Huber |
score: Critical fix for timer server
Under certain conditions it is …
4.115
@43e0599
12/02/12 21:23:57 |
matkallada |
score misc: Clean up Doxygen #13 (GCI 2012)
This patch is a task from …
4.115
@5a58b1e
12/01/12 14:53:45 |
daniel.georgiev95 |
score misc: Score misc: Clean up Doxygen #11 (GCI 2012)
This patch is …
4.115
@f839bf5a
12/01/12 14:47:07 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #10 (GCI 2012)
This patch is …
4.115
@809b726a
12/01/12 00:12:59 |
Ric Claus |
Print MCSR and ESR.
The Machine Check and Exception Syndrome …
4.115
@1a33a6c
11/30/12 23:21:20 |
Ric Claus |
PR 2048: Removed use of PPC440 macro.
Retrying this patch as a stand …
4.115
@e0f91da
11/30/12 21:34:17 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #9 (GCI 2012)
This patch is …
4.115
@4a7dc837
11/30/12 20:56:14 |
Joel Sherrill |
sparc cpu.h: Correct spacing
4.115
@8396c18e
11/30/12 02:01:26 |
matkallada |
Score misc: Clean up Doxygen #8 (GCI 2012)
This patch is a task …
4.115
@f2f63d1
11/29/12 23:14:28 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #7 (GCI 2012)
This patch …
4.115
@1b475860
11/29/12 19:39:17 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #6 (GCI 2012)
This patch is …
4.115
@e655f7e
11/29/12 18:39:19 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #5
4.115
@f8ac52f2
11/29/12 14:07:12 |
Sebastian Huber |
score: Documentation
4.115
@bf54252
11/28/12 20:14:50 |
deviennealexandre |
Score misc: Clean up Doxygen #4 (GCI 2012)
4.115
@355ee7d
11/28/12 19:57:31 |
alexivanov97 |
score misc: Clean up Doxygen #3 (GCI 2012)
4.115
@d4d7899
11/28/12 19:31:53 |
Christopher Kerl |
score misc: Clean up Doxygen #2 (GCI 2012)
4.115
@f7f1d77
11/28/12 14:11:31 |
alexivanov97 |
score misc: Clean up Doxygen (GCI 2012)
This patch is a task from GCI …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@d2202ac
11/26/12 17:04:12 |
Sebastian Huber |
powerpc: Add CPU_Exception_frame
The powerpc port uses now a unified …
4.115
@f1738ed
11/04/12 20:04:39 |
Sebastian Huber |
score: PR1607: Add and use CPU_SIZEOF_POINTER
Add and use new CPU …
4.115
@74d22fd1
11/22/12 12:03:09 |
Sebastian Huber |
score: Inline _API_extensions_Run_postswitch()
The …
4.115
@32b2c83
11/22/12 14:00:21 |
Sebastian Huber |
score: Inline _User_extensions_Thread_switch()
The …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
This file contains the …
4.115
@67a9159e
11/22/12 11:40:33 |
Sebastian Huber |
score: Avoid superfluous loads
4.115
@1906a36
11/18/12 18:51:10 |
Sebastian Huber |
score: Change _Internal_error_Occurred()
Call the fatal handlers of …
4.115
@e5a2249a
11/18/12 18:19:18 |
Sebastian Huber |
score: Delete nest level from internal error state
This reverts …
4.115
@f4539aa
11/18/12 18:47:40 |
Sebastian Huber |
arm: Add _CPU_Thread_Idle_body for ARMv7-M
4.115
@7e32b62
11/17/12 11:31:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION
Add …
4.115
@62181b21
11/16/12 12:59:27 |
Sebastian Huber |
score: Add and use _TOD_Get_with_nanoseconds()
Delete …
4.115
@154721c4
11/16/12 12:39:55 |
Sebastian Huber |
score: Add _Timestamp_To_timeval()
4.115
@7f23ead
11/21/12 08:16:32 |
Sebastian Huber |
powerpc: Add more BUCSR register values
4.115
@a12f7e9
11/14/12 14:10:46 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER
4.115
@a0c7aa55
11/14/12 13:54:09 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_ASSERT
4.115
@b9bc399
11/14/12 12:50:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_SPECIFIC
4.115
@9d10cf90
11/14/12 12:58:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_GENERIC
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@038e2f4a
11/14/12 08:58:53 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_APPLICATION
4.115
@608940f
11/14/12 09:12:57 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BDBUF
Add rtems_bdbuf_fatal_code as a …
4.115
@156e91e
11/14/12 09:11:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_LAST
This enum value ensures that the …
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@7d0bdca
11/14/12 08:27:43 |
Sebastian Huber |
score: Add nest level to interal error state
Add …
4.115
@891d0d96
11/14/12 14:56:04 |
Sebastian Huber |
4.115
@00dae186
11/13/12 15:39:26 |
Sebastian Huber |
powerpc: Delete _CPU_Install_interrupt_stack()
This function is only …
4.115
@84ff9a47
11/12/12 10:53:16 |
Sebastian Huber |
score: Fix per CPU member offsets
Offset calculation was wrong for …
4.115
@ecf9858
11/07/12 11:33:48 |
Sebastian Huber |
score: Move global variables definition
Define _System_state_Current …
4.115
