Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/score
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @1178b8c   05/17/99 22:19:29 Joel Sherrill Splitting the Thread Handler forced the inclusion of more prototypes. 4.104.114.84.95
(edit) @05df0a8   05/17/99 20:41:13 Joel Sherrill Thread Handler split into multiple files. Eventually, as RTEMS is … 4.104.114.84.95
(edit) @c2463d9   04/19/99 21:02:31 Joel Sherrill Intel i960HA support submitted by Jimen Ching <jimen@…> … 4.104.114.84.95
(edit) @b56206a   04/19/99 17:30:02 Joel Sherrill Unlimited objects patch design document. Submitted by Chris Johns … 4.104.114.84.95
(edit) @3084de2   04/07/99 15:57:05 Joel Sherrill MPC821 support and PPC patches from Andrew Bray … 4.104.114.84.95
(edit) @73b943bc   03/31/99 23:21:19 Joel Sherrill Fixed paths to include files so this will build. 4.104.114.84.95
(edit) @6a10709   03/31/99 22:33:14 Joel Sherrill Patch from Chris Johns <ccj@…>: joel@… wrote: > > … 4.104.114.84.95
(edit) @f4a8ee1   03/17/99 16:01:03 Joel Sherrill Unlimited objects patch from Chris Johns <ccj@…>. Email … 4.104.114.84.95
(edit) @6dfebd9   02/24/99 14:32:46 Joel Sherrill Corrected name of constant so this would compile. 4.104.114.84.95
(edit) @12710a56   02/19/99 23:35:42 Joel Sherrill Moved back up in tree. 4.104.114.84.95
(edit) @db903c74   02/19/99 23:32:51 Joel Sherrill Moved asm.h back up in tree. 4.104.114.84.95
(edit) @7713808   02/19/99 23:26:19 Joel Sherrill Moved to proper rtems/score 4.104.114.84.95
(edit) @7908ba5b   02/18/99 18:28:24 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @25d457b8   02/18/99 18:16:40 Joel Sherrill Yet another part of automake VI from Ralf Corsepius … 4.104.114.84.95
(edit) @e029467   02/18/99 15:16:37 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: You will find … 4.104.114.84.95
(edit) @f91b8df1   01/20/99 15:55:52 Joel Sherrill Patch from Eric Norum <eric@…> to make m68360.h usable … 4.104.114.84.95
(edit) @ba2adf5   01/19/99 20:09:33 Joel Sherrill Patch from Jiri Gaisler <jgais@…>: getting the … 4.104.114.84.95
(edit) @9d5c22e3   12/15/98 19:56:41 Joel Sherrill Switched to use of ASM compilation conditional. 4.104.114.84.95
(edit) @2417b15   12/15/98 15:00:25 Joel Sherrill Changed reference from no_cpu to mips64orion. 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @ed0e74e   12/03/98 21:53:25 Joel Sherrill Corrected spacing. 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @847375f   11/19/98 17:35:49 Joel Sherrill Patch from Eric Norum <eric@…>: 1) Socket timeout … 4.104.114.84.95
(edit) @b4e3b2b   10/28/98 19:25:12 Joel Sherrill Patch from Ian Lance Taylor <ian@…>. I just happened … 4.104.114.84.95
(edit) @ecc3fe3   09/23/98 16:41:00 Joel Sherrill IDLE task stack size now specified as a field in the CPU Table for all … 4.104.114.84.95
(edit) @b285860   08/31/98 23:03:45 Joel Sherrill Patch from Eric Valette <valette@…>: Eric> NB : there … 4.104.114.84.95
(edit) @eb562f2   08/21/98 16:39:52 Joel Sherrill Patch from Eric Valette <valette@…>: Here is a patch … 4.104.114.84.95
(edit) @29381405   08/21/98 16:16:00 Joel Sherrill Spacing changes 4.104.114.84.95
(edit) @8b2ee37c   08/19/98 20:09:59 Joel Sherrill Patch from Eric Valette <valette@…>: - Use the … 4.104.114.84.95
(edit) @ab0df696   08/05/98 15:15:46 Joel Sherrill Automatic CPU type detection code from Eric Valette … 4.104.114.84.95
(edit) @5ef4fae   08/01/98 14:40:51 Joel Sherrill Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire?4.104.114.84.95
(edit) @67a2288   07/23/98 22:02:34 Joel Sherrill Patch from Eric VALETTE <valette@…>: Here is a … 4.104.114.84.95
(edit) @dd6dddc   07/01/98 21:33:11 Joel Sherrill Fixed typo. 4.104.114.84.95
(edit) @7e4c3d8b   06/18/98 18:58:42 Joel Sherrill Modified _Objects_Is_class_valid() to correctly report that 0 was not … 4.104.114.84.95
(edit) @9a6994b4   06/18/98 15:22:35 Joel Sherrill Added freebsd support from Dario Alcocer <alcocer@…>. 4.104.114.84.95
(edit) @7738906   06/12/98 21:12:12 Joel Sherrill Added optimized version of memcpy.c to this directory since RTEMS … 4.104.114.84.95
(edit) @937a6f3c   06/03/98 19:00:17 Joel Sherrill Added CPU_ISR_PASSES_FRAME_POINTER so some ports could pass just the … 4.104.114.84.95
(edit) @75d0b0b   06/03/98 18:49:38 Joel Sherrill Corrected macros for assembly language program sections. 4.104.114.84.95
(edit) @72aa8cf   04/27/98 14:16:29 Joel Sherrill Fixed CVS Id 4.104.114.84.95
(edit) @8a1636d   04/15/98 22:16:22 Joel Sherrill Added bh, ch, dh, bl, cl, and dl register macros. 4.104.114.84.95
(edit) @0451b44   04/15/98 00:02:10 Joel Sherrill Per suggestion from Eric Norum, went from one initial extension set to … 4.104.114.84.95
(edit) @4381e50   04/14/98 22:44:49 Joel Sherrill Ralf Corsepius suggested a way to get rid of UNIX compiler files and … 4.104.114.84.95
(edit) @5e34bf4   03/31/98 14:19:27 Joel Sherrill Added "sigemptyset()" call to insure that the memcmp() would work. It … 4.104.114.84.95
(edit) @a30359bb   03/27/98 19:42:58 Joel Sherrill Changed int to unsigned32 to match cpu.h. 4.104.114.84.95
(edit) @c80add4   03/25/98 18:46:47 Joel Sherrill m68k software interrupt stack support from Chris Johns and Eric Norum. 4.104.114.84.95
(edit) @ddf142d   03/24/98 20:53:48 Joel Sherrill Added _XOPEN_SOURCE definition to allow use of UNIX IPC. 4.104.114.84.95
(edit) @bdac86b5   03/24/98 17:13:03 Joel Sherrill Real definition for the beginning of the data section per Eric Norum's … 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
(edit) @50cf94da   03/20/98 17:16:31 Joel Sherrill SH port submitted from Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @9b39bab   02/20/98 20:23:57 Joel Sherrill Modified to make it possible for an ISR to return a mutex which did … 4.104.114.84.95
(edit) @c7744ee0   02/18/98 19:34:51 Joel Sherrill Ralf Corsepius noted that there was a dead path in _Thread_Initialize. 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @77ea27fc   02/04/98 14:47:23 Joel Sherrill Ralf Corsepius noticed that generally was spelled incorrectly. 4.104.114.84.95
(edit) @3a85d03d   01/28/98 15:39:30 Joel Sherrill Change to remove warning on glibc2 systems per Ralf Corsepius's suggestion. 4.104.114.84.95
(edit) @2936b425   01/23/98 17:45:05 Joel Sherrill Solaris port updates from Chris Johns 4.104.114.84.95
(edit) @6ab91d9   01/20/98 20:32:15 Joel Sherrill Removed warning per Chris Johns' suggestion. 4.104.114.84.95
(edit) @87904ba   01/15/98 21:39:15 Joel Sherrill Error reported by Duncan Smith <dds@…>: >> >>There is a … 4.104.114.84.95
(edit) @b2225d7   01/06/98 15:40:35 Joel Sherrill Fixed spacing. 4.104.114.84.95
(edit) @01a5f6b2   12/06/97 15:09:30 Joel Sherrill Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were … 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @b6770d1   10/06/97 21:29:29 Joel Sherrill Fixed comment. 4.104.114.84.95
(edit) @e63e254e   08/22/97 19:19:07 Joel Sherrill Corrected bug per Katsutoshi Shibuya's report: The definition of … 4.104.114.84.95
(edit) @91333c2   07/31/97 22:04:17 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @eb14a2ff   07/09/97 23:55:39 Joel Sherrill Repository damaged -- files readded. 4.104.114.84.95
(edit) @b5fc21c   07/09/97 23:50:28 Joel Sherrill Added post switch extension. 4.104.114.84.95
(edit) @8fabc273   07/09/97 23:33:08 Joel Sherrill Added sp, sfc, and fpcsr register defines. 4.104.114.84.95
(edit) @00d2a828   05/28/97 20:36:35 Joel Sherrill Added support for context switching the data used by the gcc m68k … 4.104.114.84.95
(edit) @0a6fb22   04/22/97 20:19:25 Joel Sherrill Patch from Chris John <cjohns@…> to add use of a select … 4.104.114.84.95
(edit) @f2545552   04/22/97 19:57:02 Joel Sherrill multiprocessing fixed on linux by fixing cpu.c so correct form of … 4.104.114.84.95
(edit) @e71ce071   04/22/97 17:47:16 Joel Sherrill updated with new license information per Tony Bennett. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @5bf6ffb   04/16/97 17:34:40 Joel Sherrill Added FPSP support for MC68040 4.104.114.84.95
(edit) @3fc076d   04/09/97 20:04:52 Joel Sherrill added support for tracking thread cpu usage. 4.104.114.84.95
(edit) @192259f   04/09/97 20:04:36 Joel Sherrill enhanced printf statements 4.104.114.84.95
(edit) @48e34595   04/09/97 20:04:22 Joel Sherrill corrected spacing. 4.104.114.84.95
(edit) @bbb846b   04/09/97 20:03:59 Joel Sherrill added SYSTEM_STATE_SHUTDOWN 4.104.114.84.95
(edit) @d6ba279   04/07/97 21:24:02 Joel Sherrill added initialization of variable to eliminate warning. 4.104.114.84.95
(edit) @12d6f14   04/07/97 21:22:15 Joel Sherrill added "ifndef" to avoid redefinition warning. 4.104.114.84.95
(edit) @d749165   04/07/97 21:20:48 Joel Sherrill added "return" to eliminate warning. 4.104.114.84.95
(edit) @2ff1d549   04/07/97 21:20:35 Joel Sherrill added "ifndef" to avoid redefinition warning 4.104.114.84.95
(edit) @32ef3dc   04/07/97 21:19:59 Joel Sherrill commented out sccs_id to eliminate warning. 4.104.114.84.95
(edit) @77d20fb   04/07/97 21:18:50 Joel Sherrill Replaced warning message for cpus which do not have hardware support … 4.104.114.84.95
(edit) @94784cf8   04/07/97 21:16:47 Joel Sherrill changed signed int to unsigned to eliminate warning 4.104.114.84.95
(edit) @17c4511   04/07/97 21:16:31 Joel Sherrill added "ifndef" for ASM to avoid redefinition warnings. 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @c43b34c   03/11/97 15:42:14 Joel Sherrill modified _Chain_Insert_unprotected to have the form required to be … 4.104.114.84.95
(edit) @a3cfa9f   03/10/97 19:37:44 Joel Sherrill initialized a stack variable to avoid a warning. 4.104.114.84.95
(edit) @f926b34   03/08/97 03:51:55 Joel Sherrill Modified calls to _Thread_Change_priority to take a third argument. … 4.104.114.84.95
(edit) @541dfb2   01/29/97 00:22:24 Joel Sherrill Removed definitions which are now in targopts.h. This eliminates the … 4.104.114.84.95
(edit) @36dbb51   01/29/97 00:21:53 Joel Sherrill added type to macro to eliminate warning for untyped use of a register. 4.104.114.84.95
(edit) @b9181082   01/29/97 00:13:00 Joel Sherrill Added include of targopts.h. 4.104.114.84.95
(edit) @fc5e2d73   01/15/97 20:21:48 Joel Sherrill fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) 4.104.114.84.95
(edit) @1019ae4   01/08/97 16:20:47 Joel Sherrill added some casts to reduce warnings reported by users with Microtec … 4.104.114.84.95
(edit) @0d051533   01/08/97 16:19:47 Joel Sherrill added type definitions for all supported task entry formats 4.104.114.84.95
(edit) @e1a06d1b   12/02/96 22:47:38 Joel Sherrill Changes to reflect new revision of erc32 per Jiri Gaisler's … 4.104.114.84.95
(edit) @29d8227e   12/02/96 19:48:29 Joel Sherrill Updates from Derrick Ostertag <ostertag@…> to fix bug in … 4.104.114.84.95
(edit) @f4b7e297   12/02/96 19:43:22 Joel Sherrill Update from Chris Johns <cjohns@…> to add better support for … 4.104.114.84.95
(edit) @27f0d424   10/15/96 21:38:43 Joel Sherrill added support for cpu time used field in tcb 4.104.114.84.95
(edit) @f8c6333   10/15/96 21:38:33 Joel Sherrill added cpu time used field to tcb 4.104.114.84.95
(edit) @855edec   09/30/96 20:15:01 Joel Sherrill fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. 4.104.114.84.95
