# # ChangeLog for cpukit/score in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 02:16:42 Fri, 11 Aug 2017 08:44:04 GMT Sebastian Huber [c693a3a] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE In 64-bit mode, ... Tue, 01 Aug 2017 08:57:46 GMT Sebastian Huber [a6f84b27] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add 64-bit context/interrupt support Update #3082. Thu, 10 Aug 2017 11:09:22 GMT Sebastian Huber [7837728b] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: 64-bit _CPU_Context_Initialize() support Update #3082. Thu, 10 Aug 2017 09:35:33 GMT Sebastian Huber [5a9372f] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: 64-bit support for CPU_SIZEOF_POINTER Update #3082. Thu, 10 Aug 2017 09:34:32 GMT Sebastian Huber [ea9084de] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: ppc_interrupt_get_disable_mask() Fix warning on 64-bit ... Mon, 31 Jul 2017 13:08:06 GMT Sebastian Huber [caa12270] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add register defines Update #3082. Tue, 22 Aug 2017 12:18:09 GMT Sebastian Huber [93934f88] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/shell/print_heapinfo.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) heap: Fix integer types Update #3082. Thu, 10 Aug 2017 12:21:37 GMT Sebastian Huber [279c540] * cpukit/score/src/cpusetprintsupport.c (modified) score: Fix format specifier Update #3082. Thu, 10 Aug 2017 07:03:36 GMT Sebastian Huber [0daa8ab] * cpukit/score/cpu/arm/arm-context-validate.S (modified) arm: Use ARM code on Thumb 1 targets Update #3093. Thu, 10 Aug 2017 05:51:17 GMT Sebastian Huber [a95d909] * cpukit/score/cpu/arm/arm-context-validate.S (modified) arm: Validate IT[7:0] bit field of PSR Update #3093. Mon, 31 Jul 2017 11:34:46 GMT Sebastian Huber [a597984] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add register defines Update #3082. Update #3085. Fri, 28 Jul 2017 09:57:31 GMT Sebastian Huber [af97ba8f] * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) score: Add RTEMS_HAVE_MEMBER_SAME_TYPE() This fixes some "variably ... Fri, 28 Jul 2017 12:42:53 GMT Sebastian Huber [585706a4] * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) bsp/t32mppc: Add SMP support Mon, 17 Jul 2017 05:30:46 GMT Sebastian Huber [146adb1] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spsize/size.c (modified) sparc: Add lazy floating point switch The SPARC ABI is a bit ... Wed, 19 Jul 2017 07:07:17 GMT Sebastian Huber [600d88d] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal30/Makefile.am (added) * testsuites/sptests/spfatal30/init.c (added) * testsuites/sptests/spfatal30/spfatal30.doc (added) * testsuites/sptests/spfatal30/spfatal30.scn (added) * testsuites/sptests/spfatal31/Makefile.am (added) * testsuites/sptests/spfatal31/init.c (added) * testsuites/sptests/spfatal31/spfatal31.doc (added) * testsuites/sptests/spfatal31/spfatal31.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT Add new fatal ... Tue, 18 Jul 2017 13:11:41 GMT Sebastian Huber [a400d06f] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Rename SPARC_USE_SAFE_FP_SUPPORT Rename ... Tue, 18 Jul 2017 12:53:16 GMT Sebastian Huber [b2e1bded] * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadrestart.c (modified) score: Add optional _CPU_Context_Destroy() Update #3077. Mon, 17 Jul 2017 07:15:04 GMT Sebastian Huber [852d7059] * cpukit/score/src/schedulergetaffinity.c (modified) score: Fix warning Update #3059. Thu, 13 Jul 2017 07:26:50 GMT Daniel Cederman [2f8704b6] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Add assembly workaround for LEON3FT B2BST errata This patch ... Wed, 12 Jul 2017 08:44:57 GMT Sebastian Huber [e2623038] * cpukit/score/include/rtems/score/smpimpl.h (modified) score: Fix typo Update #3059. Tue, 11 Jul 2017 09:54:30 GMT Sebastian Huber [af207fa9] * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/score/include/rtems/score/processormask.h (modified) Add interrupt vector set/get affinity Close #3071. Fri, 07 Jul 2017 06:30:20 GMT Sebastian Huber [4a1bdd30] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: Fix set scheduler Ensure that the thread processor affinity ... Tue, 04 Jul 2017 07:57:30 GMT Sebastian Huber [34487537] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/scheduler.h (modified) * cpukit/score/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschededf01/init.c (modified) * testsuites/smptests/smpschededf02/Makefile.am (added) * testsuites/smptests/smpschededf02/init.c (added) * testsuites/smptests/smpschededf02/smpschededf02.doc (added) * testsuites/smptests/smpschededf02/smpschededf02.scn (added) * testsuites/smptests/smpschededf03/Makefile.am (added) * testsuites/smptests/smpschededf03/init.c (added) * testsuites/smptests/smpschededf03/smpschededf03.doc (added) * testsuites/smptests/smpschededf03/smpschededf03.scn (added) * testsuites/smptests/smpscheduler07/init.c (modified) score: Add simple affinity support to EDF SMP Update #3059. Fri, 07 Jul 2017 07:40:06 GMT Sebastian Huber [d19dc071] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) score: Pass scheduler nodes to processor allocator This allows ... Wed, 05 Jul 2017 13:14:26 GMT Sebastian Huber [197a614] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) score: Add scheduler node to set affinity op Update #3059. Fri, 07 Jul 2017 05:36:52 GMT Sebastian Huber [16347a6] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: Fix default set affinity The set of online processors must ... Fri, 07 Jul 2017 05:45:57 GMT Sebastian Huber [76d1198] * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Introduce _SMP_Get_online_processors() Update #3059. Tue, 04 Jul 2017 06:59:37 GMT Sebastian Huber [0232b28] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) score: Use processor mask for set affinity Update #3059. Tue, 04 Jul 2017 05:28:44 GMT Sebastian Huber [6b1d8c7] * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Add processor set to scheduler context Replace the simple ... Mon, 03 Jul 2017 12:05:26 GMT Sebastian Huber [7851555] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/schedulerdefaultgetaffinity.c (deleted) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: Move processor affinity to Thread_Control Update #3059. Wed, 05 Jul 2017 08:41:51 GMT Sebastian Huber [6223097a] * cpukit/score/include/rtems/score/processormask.h (modified) score: Add some processor mask functions Update #3059. Mon, 03 Jul 2017 11:14:35 GMT Sebastian Huber [7a5e4d94] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/src/processormaskcopy.c (added) score: Add processor mask to/from cpu_set_t Update #3059. Mon, 03 Jul 2017 09:46:12 GMT Sebastian Huber [3dfe55ee] * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Use for Processor_mask Implement the ... Wed, 05 Jul 2017 06:10:11 GMT Sebastian Huber [fab446f] * cpukit/score/src/scheduleredfsmp.c (modified) score: Fix format Wed, 05 Jul 2017 06:08:24 GMT Sebastian Huber [4cd52cc4] * cpukit/score/src/kern_tc.c (modified) score: Avoid clash with provided fls() Tue, 04 Jul 2017 12:15:03 GMT Sebastian Huber [3e782743] * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) arm: Fix ARMv7-M interrupt processing Right after a "msr ... Mon, 03 Jul 2017 05:28:15 GMT Sebastian Huber [550616e5] * cpukit/score/src/threaddispatch.c (modified) score: Add assert to _Thread_Dispatch() Update #3060. Thu, 29 Jun 2017 10:08:27 GMT Sebastian Huber [74f9db8] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_NO_INLINE Update #3056. Mon, 26 Jun 2017 08:35:45 GMT Sebastian Huber [f3d9f228] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/scheduler.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/scheduleredfsmp.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfsmp.c (added) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpscheduler03/test.c (modified) * testsuites/smptests/smpscheduler07/Makefile.am (added) * testsuites/smptests/smpscheduler07/init.c (added) * testsuites/smptests/smpscheduler07/smpscheduler07.doc (added) * testsuites/smptests/smpscheduler07/smpscheduler07.scn (added) score: Add SMP EDF scheduler Update #3056. Thu, 29 Jun 2017 07:44:16 GMT Sebastian Huber [15dbc710] * cpukit/score/include/rtems/score/schedulernode.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Add red-black tree node to Scheduler_Node In SMP ... Tue, 20 Jun 2017 11:01:02 GMT Sebastian Huber [d30c2cc] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Account for legacy AltiVec ... Tue, 20 Jun 2017 08:39:54 GMT Sebastian Huber [ae3e6af8] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix TLS support Do not zero the GPR2 in the thread context ... Wed, 14 Jun 2017 05:29:14 GMT Sebastian Huber [3dd67dd1] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threaddispatch.c (modified) score: Remove rtems_ada_self This task variable is superfluous ... Fri, 09 Jun 2017 13:42:36 GMT Sebastian Huber [7b0c74ff] * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) i386: Support thread-local storage (TLS) Update #2468. Fri, 09 Jun 2017 06:17:59 GMT Sebastian Huber [cb0d9a0] * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: Move _CPU_Context_Initialize() Update #2468. Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Wed, 07 Jun 2017 06:14:30 GMT Sebastian Huber [836f454] * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrgetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/score/include/rtems/score/cpusetimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/test.c (modified) Fix CPU_COPY() usage The original CPU_COPY() support of Newlib ... Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Tue, 23 May 2017 08:03:56 GMT Sebastian Huber [d5c8756] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix profiling support of Thumb-1 targets Update #2751. Wed, 26 Apr 2017 01:02:09 GMT Joel Sherrill [03e4be12] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning Wed, 26 Apr 2017 01:01:41 GMT Joel Sherrill [65807379] * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning Tue, 25 Apr 2017 18:56:31 GMT Joel Sherrill [f6bd41e] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxie/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 18:39:50 GMT Joel Sherrill [fdfbb0a8] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 16:41:35 GMT Joel Sherrill [28e5749e] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix typo to eliminate warning Sun, 23 Apr 2017 17:57:27 GMT Joel Sherrill [0c334a5] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix not a prototype warning Sat, 08 Apr 2017 10:30:50 GMT Cillian O'Donnell [62c238e] * cpukit/score/cpu/i386/cpu.c (modified) cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning. Wed, 05 Apr 2017 09:28:46 GMT Sebastian Huber [46f05b92] * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) SMP: Simplify SMP multicast actions Mon, 27 Mar 2017 06:01:38 GMT Sebastian Huber [cd3d747] * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Optimize context switch Set CPU_ENABLE_ROBUST_THREAD_DISPATCH ... Thu, 09 Mar 2017 13:32:04 GMT Sebastian Huber [b437a360] * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) arm: Fix CPU context validation for Cortex-R4 Do not touch the ... Tue, 07 Mar 2017 13:32:42 GMT Sebastian Huber [2433a8ab] * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (deleted) * c/src/lib/libbsp/arm/shared/abort/abort.h (deleted) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (deleted) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/start/start.S (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (deleted) * cpukit/score/cpu/arm/arm_exc_handler_low.S (deleted) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Remove legacy execption support Tue, 07 Mar 2017 12:07:02 GMT Sebastian Huber [088acbb0] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulersmp.c (added) score: Fix scheduler yield in SMP configurations Check that no ask ... Mon, 06 Mar 2017 10:16:25 GMT Sebastian Huber [f61195b2] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Tue, 21 Feb 2017 07:58:29 GMT Sebastian Huber [c833970] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_WEAK_ALIAS() Wed, 15 Feb 2017 10:09:32 GMT Sebastian Huber [7a462cc] * cpukit/score/src/threadinitialize.c (modified) score: Fix warning Tue, 14 Feb 2017 07:42:48 GMT Sebastian Huber [6dbbafc6] * cpukit/score/src/threadname.c (modified) score: Fix warning in _Thread_Set_name() Fri, 03 Feb 2017 07:57:18 GMT Sebastian Huber [bbfbfc8] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadscheduler.c (modified) score: Move _Thread_Scheduler_ask_for_help() Move ... Thu, 02 Feb 2017 15:24:05 GMT Sebastian Huber [ca1e546e] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Improve scheduler helping protocol Only register ask for ... Fri, 03 Feb 2017 09:16:40 GMT Sebastian Huber [e2b1c47d] * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Fix volatile clobber Do not adjust the stack pointer, since ... Tue, 31 Jan 2017 07:08:24 GMT Sebastian Huber [e366f77] * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add _Thread_queue_Object_name Add the special thread queue ... Tue, 31 Jan 2017 08:37:54 GMT Sebastian Huber [70488f56] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Fix _Thread_Initialize() Mon, 30 Jan 2017 11:29:31 GMT Sebastian Huber [c5430e06] * cpukit/score/include/rtems/score/rbtree.h (modified) score: Fix unused parameter warning Close #2890. Mon, 30 Jan 2017 10:33:31 GMT Christian Mauderer [180107e9] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/startup/armv7m-cpucounter.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable ... Fri, 27 Jan 2017 07:06:06 GMT Sebastian Huber [4ea92d1e] * cpukit/score/include/rtems/score/heap.h (modified) score: Clarify _Heap_Extend() Update #1747. Fri, 27 Jan 2017 06:42:29 GMT Sebastian Huber [abc963d] * cpukit/score/include/rtems/score/heap.h (modified) score: Fix typo Thu, 26 Jan 2017 10:06:50 GMT Sebastian Huber [6f6da82c] * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/userextiterate.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Fix user extensions order Use forward and reverse order for ... Wed, 25 Jan 2017 13:32:02 GMT Sebastian Huber [27bfcd8] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Delete _CPU_Context_Fp_start() Since the FP area pointer is ... Tue, 24 Jan 2017 14:40:31 GMT Kevin Kirspel [b43c2e8] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) Adding ARM VFP V2 support Mon, 23 Jan 2017 14:04:44 GMT Sebastian Huber [3d20f5fb] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Relax CPU_STACK_ALIGNMENT Close #2352. Mon, 23 Jan 2017 07:12:18 GMT Sebastian Huber [4aa23c96] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN Use de-facto standard ... Fri, 12 Aug 2016 19:25:10 GMT Gedare Bloom [ba776282] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/shm.h (added) * cpukit/posix/include/rtems/posix/shmimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/shm.c (added) * cpukit/posix/src/shmheap.c (added) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (added) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxshm01/Makefile.am (added) * testsuites/psxtests/psxshm01/init.c (added) * testsuites/psxtests/psxshm01/psxshm01.scn (added) * testsuites/psxtests/psxshm01/system.h (added) * testsuites/psxtests/psxshm02/Makefile.am (added) * testsuites/psxtests/psxshm02/init.c (added) * testsuites/psxtests/psxshm02/psxshm02.scn (added) * testsuites/psxtests/psxshm02/system.h (added) * testsuites/sptests/spsysinit01/init.c (modified) posix: shared memory support Add POSIX shared memory manager (Shm). ... Fri, 13 Jan 2017 10:33:28 GMT Sebastian Huber [9fad437] * cpukit/configure.ac (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) configure: Remove HAVE_STRUCT__THREAD_QUEUE_QUEUE Thu, 12 Jan 2017 12:46:55 GMT Sebastian Huber [da6ad56] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/status.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadname.c (modified) score: Add _Thread_Set_name() Add configuration option ... Thu, 12 Jan 2017 08:25:56 GMT Sebastian Huber [7ced9d9b] * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadname.c (added) score: Add and use _Thread_Get_name() Update #2858. Thu, 12 Jan 2017 09:15:56 GMT Sebastian Huber [2b72162] * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) score: Add Thread_queue_Queue::name Update #2858. Thu, 12 Jan 2017 07:28:57 GMT Sebastian Huber [b8bcebe] * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectgetnameasstring.c (modified) score: Add and use _Objects_Name_to_string() Update #2858. Wed, 11 Jan 2017 07:49:26 GMT Sebastian Huber [fa9f964f] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Remove unused _States_Is_*() Wed, 11 Jan 2017 07:42:04 GMT Sebastian Huber [d063e7b3] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Replace STATES_DELAYING Replace STATES_DELAYING with ... Wed, 11 Jan 2017 15:43:06 GMT Joel Sherrill [7a4b2645] * cpukit/configure.ac (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrcompare.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/score/include/rtems/score/cpuset.h (modified) * cpukit/score/include/rtems/score/cpusetimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/cpuset.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/system.h (modified) * testsuites/sptests/spcpuset01/test.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) Remove obsolete __RTEMS_HAVE_SYS_CPUSET_H__ Wed, 11 Jan 2017 12:41:55 GMT Sebastian Huber [3d35bc0] * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/threadq.c (modified) score: Improve SMP lock debug support The CPU index starts with ... Thu, 05 Jan 2017 14:40:57 GMT Sebastian Huber [4e07d9b3] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Optimize thread state values Fri, 23 Dec 2016 15:02:07 GMT Sebastian Huber [9a448aab] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER Add thread state bit ... Fri, 23 Dec 2016 06:09:02 GMT Sebastian Huber [c6000d2b] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Delete STATES_WAITING_FOR_BUFFER Fri, 23 Dec 2016 05:47:11 GMT Sebastian Huber [2e6d9865] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Format thread state defines Specify all 32-bits in a thread ... Fri, 23 Dec 2016 12:54:11 GMT Sebastian Huber [a7cfb4b] * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) score: Relax static assertions Only require that the ... Mon, 12 Dec 2016 14:03:35 GMT Christian Mauderer [fe7012a0] * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: Prevent thread_dispatch_disable_level < 0. Fri, 09 Dec 2016 08:28:31 GMT Sebastian Huber [e203b65e] * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED Update #2825. Fri, 09 Dec 2016 08:27:15 GMT Sebastian Huber [a5ba08eb] * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED Update #2825. Fri, 09 Dec 2016 07:44:49 GMT Sebastian Huber [9622f779] * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 07:44:22 GMT Sebastian Huber [82529688] * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 06:19:22 GMT Sebastian Huber [3a659b04] * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) score: Introduce _Internal_error()
