# # ChangeLog for cpukit/score in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 13:49:36 Mon, 12 Nov 2018 12:09:36 GMT Sebastian Huber [0a9378af] * cpukit/score/cpu/x86_64/cpu.c (modified) x86_64: Remove duplicate _CPU_Thread_Idle_body() Thu, 08 Nov 2018 15:21:48 GMT Sebastian Huber [bfcf1473] * bsps/m32c/m32cbsp/README (deleted) * bsps/m32c/m32cbsp/btimer/btimer.c (deleted) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (deleted) * bsps/m32c/m32cbsp/config/m32csim.cfg (deleted) * bsps/m32c/m32cbsp/console/console-io.c (deleted) * bsps/m32c/m32cbsp/console/syscalls.S (deleted) * bsps/m32c/m32cbsp/doxygen.h (deleted) * bsps/m32c/m32cbsp/headers.am (deleted) * bsps/m32c/m32cbsp/include/bsp.h (deleted) * bsps/m32c/m32cbsp/include/tm27.h (deleted) * bsps/m32c/m32cbsp/start/bsp_specs (deleted) * bsps/m32c/m32cbsp/start/bspstart.c (deleted) * bsps/m32c/m32cbsp/start/crtn.S (deleted) * bsps/m32c/m32cbsp/start/linkcmds (deleted) * bsps/m32c/m32cbsp/start/start.S (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32c/Makefile.am (deleted) * c/src/lib/libbsp/m32c/acinclude.m4 (deleted) * c/src/lib/libbsp/m32c/configure.ac (deleted) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/score/cpu/m32c/context_init.c (deleted) * cpukit/score/cpu/m32c/context_switch.S (deleted) * cpukit/score/cpu/m32c/cpu.c (deleted) * cpukit/score/cpu/m32c/headers.am (deleted) * cpukit/score/cpu/m32c/include/rtems/asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (deleted) * cpukit/score/cpu/m32c/include/varvects.h (deleted) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (deleted) * cpukit/score/cpu/m32c/varvects.S (deleted) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) m32c: Remove this target Update #3599. Thu, 08 Nov 2018 15:46:17 GMT Sebastian Huber [947b679] * cpukit/score/cpu/h8300/headers.am (deleted) * cpukit/score/cpu/h8300/include/machine/elf_machdep.h (deleted) h8300: Remove left over files Update #2452. Tue, 06 Nov 2018 18:34:15 GMT Sebastian Huber [4fea054c] * bsps/mips/shared/irq/exception.S (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/score/cpu/m32c/cpu_asm.c (deleted) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/moxie/cpu_asm.S (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/interrupt.S (modified) score: Remove _ISR_Dispatch() This function was only used on some ... Tue, 06 Nov 2018 15:58:02 GMT Sebastian Huber [ff081aee] * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/include/bsp/vectors.h (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv/start/start.S (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/src/isr.c (modified) score: Rename interrupt stack symbols Rename * ... Mon, 05 Nov 2018 08:53:04 GMT Sebastian Huber [878487b0] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) score: Optimize Objects_Information Reduce structure internal ... Thu, 25 Oct 2018 08:54:12 GMT Sebastian Huber [54f35888] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/posix/pthreadattrimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) posix: Provide threads by default Update #2514. Sun, 14 Oct 2018 17:20:05 GMT Sebastian Huber [e97806a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/posix/config.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/psignal.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueconfig.c (added) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalconfig.c (added) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxsemaphoreconfig.c (added) * cpukit/posix/src/psxtimerconfig.c (added) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadconfig.c (added) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmconfig.c (added) * cpukit/score/src/wkspace.c (modified) posix: Split posix_api_configuration_table Use separate ... Thu, 25 Oct 2018 10:05:53 GMT Sebastian Huber [7038271] * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES Enable support for ... Thu, 25 Oct 2018 09:32:01 GMT Sebastian Huber [5090a71b] * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/src/thread.c (modified) score: Remove bogus thread object name support Update #2514. Mon, 10 Sep 2018 15:38:14 GMT Sebastian Huber [2548d14] * bootstrap (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (deleted) * cpukit/configure.ac (modified) * cpukit/header-dirs.am (added) * cpukit/headers.am (modified) * cpukit/libnetworking/Makefile.am (deleted) * cpukit/libnetworking/headers.am (modified) * cpukit/score/Makefile.am (deleted) * cpukit/score/cpu/Makefile.am (deleted) * cpukit/score/cpu/arm/Makefile.am (deleted) * cpukit/score/cpu/arm/headers.am (modified) * cpukit/score/cpu/bfin/Makefile.am (deleted) * cpukit/score/cpu/bfin/headers.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (deleted) * cpukit/score/cpu/epiphany/headers.am (modified) * cpukit/score/cpu/h8300/headers.am (modified) * cpukit/score/cpu/i386/Makefile.am (deleted) * cpukit/score/cpu/i386/headers.am (modified) * cpukit/score/cpu/lm32/Makefile.am (deleted) * cpukit/score/cpu/lm32/headers.am (modified) * cpukit/score/cpu/m32c/Makefile.am (deleted) * cpukit/score/cpu/m32c/headers.am (modified) * cpukit/score/cpu/m68k/Makefile.am (deleted) * cpukit/score/cpu/m68k/headers.am (modified) * cpukit/score/cpu/mips/Makefile.am (deleted) * cpukit/score/cpu/mips/headers.am (modified) * cpukit/score/cpu/moxie/Makefile.am (deleted) * cpukit/score/cpu/moxie/headers.am (modified) * cpukit/score/cpu/nios2/Makefile.am (deleted) * cpukit/score/cpu/nios2/headers.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (deleted) * cpukit/score/cpu/no_cpu/headers.am (modified) * cpukit/score/cpu/or1k/Makefile.am (deleted) * cpukit/score/cpu/or1k/headers.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (deleted) * cpukit/score/cpu/powerpc/headers.am (modified) * cpukit/score/cpu/riscv/Makefile.am (deleted) * cpukit/score/cpu/riscv/headers.am (modified) * cpukit/score/cpu/sh/Makefile.am (deleted) * cpukit/score/cpu/sh/headers.am (modified) * cpukit/score/cpu/sparc/Makefile.am (deleted) * cpukit/score/cpu/sparc/headers.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (deleted) * cpukit/score/cpu/sparc64/headers.am (modified) * cpukit/score/cpu/v850/Makefile.am (deleted) * cpukit/score/cpu/v850/headers.am (modified) * cpukit/score/cpu/x86_64/Makefile.am (deleted) * cpukit/score/cpu/x86_64/headers.am (modified) build: Include header.am in cpukit/Makefile.am Include all ... Sat, 06 Oct 2018 08:59:10 GMT Sebastian Huber [477bca2] * automake/local.am (deleted) * c/src/Makefile.am (modified) * c/src/automake/local.am (deleted) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/x86_64/Makefile.am (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/local.am (deleted) * cpukit/score/cpu/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/ada/Makefile.am (modified) * testsuites/ada/mptests/Makefile.am (modified) * testsuites/ada/mptests/mp01/Makefile.am (modified) * testsuites/ada/mptests/mp01/node1/Makefile.am (modified) * testsuites/ada/mptests/mp01/node2/Makefile.am (modified) * testsuites/ada/mptests/mp03/Makefile.am (modified) * testsuites/ada/mptests/mp03/node1/Makefile.am (modified) * testsuites/ada/mptests/mp03/node2/Makefile.am (modified) * testsuites/ada/mptests/mp04/Makefile.am (modified) * testsuites/ada/mptests/mp04/node1/Makefile.am (modified) * testsuites/ada/mptests/mp04/node2/Makefile.am (modified) * testsuites/ada/mptests/mp05/Makefile.am (modified) * testsuites/ada/mptests/mp05/node1/Makefile.am (modified) * testsuites/ada/mptests/mp05/node2/Makefile.am (modified) * testsuites/ada/mptests/mp06/Makefile.am (modified) * testsuites/ada/mptests/mp06/node1/Makefile.am (modified) * testsuites/ada/mptests/mp06/node2/Makefile.am (modified) * testsuites/ada/mptests/mp07/Makefile.am (modified) * testsuites/ada/mptests/mp07/node1/Makefile.am (modified) * testsuites/ada/mptests/mp07/node2/Makefile.am (modified) * testsuites/ada/mptests/mp08/Makefile.am (modified) * testsuites/ada/mptests/mp08/node1/Makefile.am (modified) * testsuites/ada/mptests/mp08/node2/Makefile.am (modified) * testsuites/ada/mptests/mp09/Makefile.am (modified) * testsuites/ada/mptests/mp09/node1/Makefile.am (modified) * testsuites/ada/mptests/mp09/node2/Makefile.am (modified) * testsuites/ada/mptests/mp10/Makefile.am (modified) * testsuites/ada/mptests/mp10/node1/Makefile.am (modified) * testsuites/ada/mptests/mp10/node2/Makefile.am (modified) * testsuites/ada/mptests/mp11/Makefile.am (modified) * testsuites/ada/mptests/mp11/node1/Makefile.am (modified) * testsuites/ada/mptests/mp11/node2/Makefile.am (modified) * testsuites/ada/mptests/mp12/Makefile.am (modified) * testsuites/ada/mptests/mp12/node1/Makefile.am (modified) * testsuites/ada/mptests/mp12/node2/Makefile.am (modified) * testsuites/ada/mptests/mp13/Makefile.am (modified) * testsuites/ada/mptests/mp13/node1/Makefile.am (modified) * testsuites/ada/mptests/mp13/node2/Makefile.am (modified) * testsuites/ada/mptests/mp14/Makefile.am (modified) * testsuites/ada/mptests/mp14/node1/Makefile.am (modified) * testsuites/ada/mptests/mp14/node2/Makefile.am (modified) * testsuites/ada/samples/Makefile.am (modified) * testsuites/ada/samples/base_mp/Makefile.am (modified) * testsuites/ada/samples/base_mp/node1/Makefile.am (modified) * testsuites/ada/samples/base_mp/node2/Makefile.am (modified) * testsuites/ada/samples/base_sp/Makefile.am (modified) * testsuites/ada/samples/hello/Makefile.am (modified) * testsuites/ada/samples/nsecs/Makefile.am (modified) * testsuites/ada/samples/ticker/Makefile.am (modified) * testsuites/ada/sptests/Makefile.am (modified) * testsuites/ada/sptests/sp01/Makefile.am (modified) * testsuites/ada/sptests/sp02/Makefile.am (modified) * testsuites/ada/sptests/sp03/Makefile.am (modified) * testsuites/ada/sptests/sp04/Makefile.am (modified) * testsuites/ada/sptests/sp05/Makefile.am (modified) * testsuites/ada/sptests/sp06/Makefile.am (modified) * testsuites/ada/sptests/sp07/Makefile.am (modified) * testsuites/ada/sptests/sp08/Makefile.am (modified) * testsuites/ada/sptests/sp09/Makefile.am (modified) * testsuites/ada/sptests/sp11/Makefile.am (modified) * testsuites/ada/sptests/sp12/Makefile.am (modified) * testsuites/ada/sptests/sp13/Makefile.am (modified) * testsuites/ada/sptests/sp14/Makefile.am (modified) * testsuites/ada/sptests/sp15/Makefile.am (modified) * testsuites/ada/sptests/sp16/Makefile.am (modified) * testsuites/ada/sptests/sp17/Makefile.am (modified) * testsuites/ada/sptests/sp19/Makefile.am (modified) * testsuites/ada/sptests/sp20/Makefile.am (modified) * testsuites/ada/sptests/sp22/Makefile.am (modified) * testsuites/ada/sptests/sp23/Makefile.am (modified) * testsuites/ada/sptests/sp24/Makefile.am (modified) * testsuites/ada/sptests/sp25/Makefile.am (modified) * testsuites/ada/sptests/spatcb01/Makefile.am (modified) * testsuites/ada/sptests/spname01/Makefile.am (modified) * testsuites/ada/support/Makefile.am (modified) * testsuites/ada/tmtests/Makefile.am (modified) * testsuites/ada/tmtests/tm01/Makefile.am (modified) * testsuites/ada/tmtests/tm02/Makefile.am (modified) * testsuites/ada/tmtests/tm03/Makefile.am (modified) * testsuites/ada/tmtests/tm04/Makefile.am (modified) * testsuites/ada/tmtests/tm05/Makefile.am (modified) * testsuites/ada/tmtests/tm06/Makefile.am (modified) * testsuites/ada/tmtests/tm07/Makefile.am (modified) * testsuites/ada/tmtests/tm08/Makefile.am (modified) * testsuites/ada/tmtests/tm09/Makefile.am (modified) * testsuites/ada/tmtests/tm10/Makefile.am (modified) * testsuites/ada/tmtests/tm11/Makefile.am (modified) * testsuites/ada/tmtests/tm12/Makefile.am (modified) * testsuites/ada/tmtests/tm13/Makefile.am (modified) * testsuites/ada/tmtests/tm14/Makefile.am (modified) * testsuites/ada/tmtests/tm15/Makefile.am (modified) * testsuites/ada/tmtests/tm16/Makefile.am (modified) * testsuites/ada/tmtests/tm17/Makefile.am (modified) * testsuites/ada/tmtests/tm18/Makefile.am (modified) * testsuites/ada/tmtests/tm19/Makefile.am (modified) * testsuites/ada/tmtests/tm20/Makefile.am (modified) * testsuites/ada/tmtests/tm21/Makefile.am (modified) * testsuites/ada/tmtests/tm22/Makefile.am (modified) * testsuites/ada/tmtests/tm23/Makefile.am (modified) * testsuites/ada/tmtests/tm24/Makefile.am (modified) * testsuites/ada/tmtests/tm25/Makefile.am (modified) * testsuites/ada/tmtests/tm28/Makefile.am (modified) * testsuites/ada/tmtests/tm29/Makefile.am (modified) * testsuites/ada/tmtests/tmck/Makefile.am (modified) * testsuites/ada/tmtests/tmoverhd/Makefile.am (modified) * testsuites/automake/local.am (deleted) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/mptests/mp01/Makefile.am (modified) * testsuites/mptests/mp03/Makefile.am (modified) * testsuites/mptests/mp04/Makefile.am (modified) * testsuites/mptests/mp05/Makefile.am (modified) * testsuites/mptests/mp06/Makefile.am (modified) * testsuites/mptests/mp07/Makefile.am (modified) * testsuites/mptests/mp08/Makefile.am (modified) * testsuites/mptests/mp09/Makefile.am (modified) * testsuites/mptests/mp10/Makefile.am (modified) * testsuites/mptests/mp11/Makefile.am (modified) * testsuites/mptests/mp12/Makefile.am (modified) * testsuites/mptests/mp13/Makefile.am (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Remove local.am Fri, 05 Oct 2018 18:12:40 GMT Sebastian Huber [637546a] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/x86_64/Makefile.am (modified) * cpukit/wrapup/Makefile.am (deleted) build: Merge score/cpu/*/Makefile.am Fri, 14 Sep 2018 18:02:02 GMT Sebastian Huber [1d93843] * cpukit/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) build: Merge score/Makefile.am Tue, 11 Sep 2018 04:30:20 GMT Sebastian Huber [68e1ccc4] * cpukit/dtc/libfdt/Makefile.am (modified) * cpukit/libcrypt/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/libstdthreads/Makefile.am (modified) * cpukit/mghttpd/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/x86_64/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) build: Remove specialized CPPFLAGS Wed, 26 Sep 2018 04:34:54 GMT Sebastian Huber [8776bb9] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpuidle.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * testsuites/smptests/smpschededf04/init.c (modified) * testsuites/smptests/smpthreadpin01/init.c (modified) score: Remove CPU_PROVIDES_IDLE_THREAD_BODY Remove the ... Thu, 13 Sep 2018 04:19:05 GMT Sebastian Huber [242887bc] * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/psxsemaphore.c (moved) * cpukit/posix/src/psxtimercreate.c (moved) * cpukit/posix/src/psxtimerdelete.c (moved) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/src/sapirbtreeinsert.c (moved) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/sparc-access.S (moved) Rename files to make them unique within cpukit This allows to build ... Tue, 02 Oct 2018 08:22:15 GMT Sebastian Huber [f004b2b8] * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/shared/dev/ide/ata.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/telnetd/telnetd.c (modified) Use rtems_task_exit() Update #3530. Update #3533. Thu, 20 Sep 2018 05:57:08 GMT Sebastian Huber [56e61e24] * cpukit/include/rtems/score/interr.h (modified) * cpukit/score/src/isr.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal07/spfatal07.doc (deleted) * testsuites/sptests/spfatal07/spfatal07.scn (deleted) * testsuites/sptests/spfatal07/testcase.h (deleted) Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL The configured ... Fri, 31 Aug 2018 06:56:08 GMT Daniel Hellstrom [227b145] * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) sparc: clang AS does no accept UNIMP without argument Tue, 19 Dec 2017 12:36:33 GMT Daniel Cederman [1c34a9b] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Remove sequence that could trigger B2BST errata Tue, 12 Dec 2017 10:19:46 GMT Daniel Cederman [e20da8b] * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (modified) sparc: Return to previous section type when done with ... Wed, 19 Sep 2018 09:52:47 GMT Sebastian Huber [776464a] * cpukit/score/src/wkspace.c (modified) score: Allocate per-CPU data only if necessary The ... Fri, 14 Sep 2018 11:20:05 GMT Sebastian Huber [fe283f6c] * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) powerpc: Fix _CPU_Counter_read() for MPC860 The mpc860 is a ... Wed, 29 Aug 2018 07:43:44 GMT Sebastian Huber [7097962] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadunpin.c (added) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpthreadpin01/init.c (added) * testsuites/smptests/smpthreadpin01/smpthreadpin01.doc (added) * testsuites/smptests/smpthreadpin01/smpthreadpin01.scn (added) score: Add thread pin/unpin support Add support to temporarily pin ... Mon, 27 Aug 2018 08:36:35 GMT Sebastian Huber [cfc4231d] * cpukit/headers.am (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (added) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sppercpudata01/init.c (added) * testsuites/sptests/sppercpudata01/item.c (added) * testsuites/sptests/sppercpudata01/sppercpudata01.doc (added) * testsuites/sptests/sppercpudata01/sppercpudata01.h (added) * testsuites/sptests/sppercpudata01/sppercpudata01.scn (added) score: Add flexible per-CPU data Update #3507. Mon, 03 Sep 2018 06:12:35 GMT Sebastian Huber [e0a9336b] * cpukit/score/src/scheduleredfsmp.c (modified) * testsuites/smptests/smpschededf02/init.c (modified) score: Fix EDF SMP scheduler Fix a special case: block a one-to-one ... Mon, 03 Sep 2018 07:31:19 GMT Sebastian Huber [3aad9d9b] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Generalize SMP scheduler block support Add extract from ... Wed, 29 Aug 2018 17:42:10 GMT Joel Sherrill [9b5b864] * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (modified) rtems/score/epiphany-utility.h: Fix not a prototype warning Wed, 29 Aug 2018 17:41:35 GMT Joel Sherrill [bc696482] * cpukit/score/cpu/bfin/cpu.c (modified) score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype Thu, 12 Jul 2018 07:15:55 GMT Daniel Cederman [59a0541c] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Restore npc when returning from the syscall_lazy_fp_switch ... Thu, 23 Aug 2018 12:39:33 GMT Sebastian Huber [6695d02] * cpukit/include/machine/_kernel_time.h (modified) * cpukit/score/src/kern_tc.c (modified) Update FreeBSD kernel timespec support This change is based on the ... Fri, 10 Aug 2018 05:34:03 GMT Sebastian Huber [ba0e9631] * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) score: Do not inline _Thread_Dispatch_enable() This function is ... Mon, 13 Aug 2018 10:55:34 GMT Amaan Cheval [bc731313] * bsps/x86_64/amd64/clock/clock.c (added) * bsps/x86_64/amd64/headers.am (modified) * bsps/x86_64/amd64/include/apic.h (added) * bsps/x86_64/amd64/include/clock.h (added) * bsps/x86_64/amd64/include/pic.h (added) * bsps/x86_64/amd64/interrupts/pic.c (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add APIC timer based clock driver The APIC timer is ... Mon, 13 Aug 2018 10:50:38 GMT Amaan Cheval [6869321] * bsps/x86_64/amd64/interrupts/idt.c (added) * bsps/x86_64/amd64/interrupts/isr_handler.S (added) * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/headers.am (modified) * bsps/x86_64/include/bsp/irq.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/idt.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) bsps/x86_64: Add support for RTEMS interrupts Updates #2898. Mon, 13 Aug 2018 10:33:12 GMT Amaan Cheval [4544749e] * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/amd64/start/page.c (added) * bsps/x86_64/headers.am (added) * bsps/x86_64/include/libcpu/page.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. Mon, 13 Aug 2018 10:21:47 GMT Amaan Cheval [ab971bf5] * bsps/x86_64/amd64/config/amd64.cfg (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (modified) bsps/x86_64: Reorganize header files and compile-options Updates #2898. Thu, 02 Aug 2018 12:49:01 GMT Sebastian Huber [27bbc05] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) score: Remove CPU_PARTITION_ALIGNMENT Use the CPU_SIZEOF_POINTER ... Thu, 02 Aug 2018 07:41:08 GMT Sebastian Huber [28b8cf9b] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Fix CPU_ALIGNMENT Update #3433. Fri, 27 Jul 2018 12:47:17 GMT Sebastian Huber [cfc9573] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-counter.S (added) riscv: Rework CPU counter support Update #3433. Fri, 20 Jul 2018 08:57:59 GMT Sebastian Huber [6b9ef09] * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/dev/irq/clint.h (deleted) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add CLINT and PLIC support The CLINT and PLIC need some ... Fri, 20 Jul 2018 07:07:40 GMT Sebastian Huber [c2670de] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Use wfi instruction for idle task Update #3433. Thu, 19 Jul 2018 10:11:19 GMT Sebastian Huber [8db3f0e] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/riscv/btimer/btimer.c (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (moved) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Rework exception handling Remove ... Thu, 19 Jul 2018 08:15:53 GMT Sebastian Huber [5694b0c] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-frame-print.c (modified) riscv: New CPU_Exception_frame Use the CPU_Interrupt_frame for the ... Thu, 19 Jul 2018 07:35:54 GMT Sebastian Huber [d779a1e2] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Add exception codes Update #3433. Tue, 24 Jul 2018 07:00:18 GMT Sebastian Huber [a1f7d7d] * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * testsuites/sptests/spmisc01/init.c (modified) score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() Add ... Tue, 24 Jul 2018 09:18:27 GMT Sebastian Huber [406dd62] * bsps/arm/include/bsp/arm-a9mpcore-start.h (modified) * bsps/arm/raspberrypi/start/bspsmp_init.c (modified) * bsps/i386/pc386/start/smp-imps.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) _SMP_Start_multitasking_on_secondary_processor() Pass current ... Wed, 25 Jul 2018 07:54:56 GMT Sebastian Huber [05259de1] * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) powerpc: Fix _CPU_Instruction_illegal() Apparently the .word ... Thu, 19 Jul 2018 10:53:34 GMT Sebastian Huber [3a646426] * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * testsuites/sptests/spfatal26/init.c (modified) score: Add _CPU_Instruction_illegal() On some ... Fri, 20 Jul 2018 06:06:46 GMT Sebastian Huber [b74353e] * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * testsuites/sptests/spcache01/init.c (modified) score: Add _CPU_Instruction_no_operation() This helps to reduce the ... Fri, 20 Jul 2018 05:56:43 GMT Sebastian Huber [42f2fdfd] * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * testsuites/sptests/spcontext01/init.c (modified) score: Move context validation declarations The context validation ... Fri, 20 Jul 2018 07:10:29 GMT Sebastian Huber [248ca7a] * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) score: Remove obsolete CPU port defines Wed, 18 Jul 2018 06:54:57 GMT Sebastian Huber [bda8f80] * cpukit/score/src/iovprintf.c (modified) score: Add a FALLTHROUGH comment to kvprintf() This change was ... Tue, 17 Jul 2018 13:33:49 GMT Sebastian Huber [ffd4617] * cpukit/score/src/scheduleredfsmp.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschededf04/init.c (added) * testsuites/smptests/smpschededf04/smpschededf04.doc (added) * testsuites/smptests/smpschededf04/smpschededf04.scn (added) score: Fix _Scheduler_EDF_SMP_Set_affinity() Commit ... Fri, 29 Jun 2018 18:00:28 GMT Sebastian Huber [6539bea] * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/src/rbtreepostorder.c (added) * testsuites/sptests/sprbtree01/init.c (modified) score: Add postorder tree iteration support Update #3465. Mon, 09 Jul 2018 11:12:57 GMT Amaan Cheval [cf811a4] * bsps/x86_64/amd64/console/console.c (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) x86_64/console: Add NS16550 polled console driver This addition ... Mon, 09 Jul 2018 11:12:56 GMT Amaan Cheval [76c03152] * bsps/x86_64/amd64/config/amd64.cfg (added) * bsps/x86_64/amd64/console/console.c (added) * bsps/x86_64/amd64/headers.am (added) * bsps/x86_64/amd64/include/bsp.h (added) * bsps/x86_64/amd64/include/start.h (added) * bsps/x86_64/amd64/include/tm27.h (added) * bsps/x86_64/amd64/start/bsp_specs (added) * bsps/x86_64/amd64/start/bspstart.c (added) * bsps/x86_64/amd64/start/linkcmds (added) * bsps/x86_64/amd64/start/start.c (added) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/x86_64/Makefile.am (added) * c/src/lib/libbsp/x86_64/acinclude.m4 (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (added) * c/src/lib/libbsp/x86_64/amd64/configure.ac (added) * c/src/lib/libbsp/x86_64/configure.ac (added) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/x86_64/Makefile.am (added) * cpukit/score/cpu/x86_64/cpu.c (added) * cpukit/score/cpu/x86_64/headers.am (added) * cpukit/score/cpu/x86_64/include/machine/elf_machdep.h (added) * cpukit/score/cpu/x86_64/include/rtems/asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (added) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (added) bsp/x86_64: Minimal bootable BSP Current state: - Basic context ... Fri, 06 Jul 2018 09:07:20 GMT Sebastian Huber [bca36d9] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Add LADDR assembler define An address must be loaded to a ... Fri, 06 Jul 2018 06:12:40 GMT Sebastian Huber [dd32e2b2] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Implement CPU counter Update #3433. Tue, 03 Jul 2018 07:54:47 GMT Sebastian Huber [e755782] * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Clear reservations See also RISC-V User-Level ISA V2.3, ... Mon, 02 Jul 2018 13:21:36 GMT Sebastian Huber [e07b51a7] * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Fix fcsr initialization Update #3433. Fri, 29 Jun 2018 10:08:01 GMT Sebastian Huber [79d69ae] * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Fix SMP context switch support Update #3433. Fri, 29 Jun 2018 06:07:02 GMT Sebastian Huber [109bc1c7] * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Add SMP context switch support Update #3433. Thu, 28 Jun 2018 07:32:26 GMT Sebastian Huber [52352387] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Add floating-point support Update #3433. Thu, 28 Jun 2018 06:21:44 GMT Sebastian Huber [995e91e8] * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/src/threadhandler.c (modified) riscv: Fix global construction Update #3433. Thu, 28 Jun 2018 06:20:47 GMT Sebastian Huber [694e79a0] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Add TLS support Update #3433. Wed, 27 Jun 2018 12:46:06 GMT Sebastian Huber [afb60eb] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Remove dead code Update #3433. Wed, 27 Jun 2018 08:05:50 GMT Sebastian Huber [e43994d] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Optimize context switch and interrupts Save/restore ... Wed, 27 Jun 2018 07:43:39 GMT Sebastian Huber [a8188730] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Fix _CPU_Context_Initialize() prototype Update #3433. Thu, 28 Jun 2018 11:55:29 GMT Sebastian Huber [dffc08c] * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Fix interrupt save/restore Update #3433. Wed, 27 Jun 2018 10:18:09 GMT Sebastian Huber [40f81ce6] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) riscv: Implement _CPU_Context_validate() Update #3433. Wed, 27 Jun 2018 10:17:21 GMT Sebastian Huber [71af1a4] * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Make some CPU port defines visible to asm Move SREG and LREG ... Wed, 27 Jun 2018 06:57:08 GMT Sebastian Huber [8f035cb] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) riscv: Implement _CPU_Context_volatile_clobber() Update #3433. Wed, 27 Jun 2018 06:54:13 GMT Sebastian Huber [b706b4a] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Remove mstatus from thread context The mstatus register ... Wed, 27 Jun 2018 06:43:25 GMT Sebastian Huber [2987c4f] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Remove x8 initialization The RISC-V psABI ... Wed, 27 Jun 2018 06:42:48 GMT Sebastian Huber [04698eb] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Properly align the thread stack Update #3433. Wed, 27 Jun 2018 06:37:34 GMT Sebastian Huber [a49a3c8e] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Do not clear thread context Do not clear the complete thread ... Wed, 27 Jun 2018 06:35:13 GMT Sebastian Huber [9510742] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Fix CPU_STACK_ALIGNMENT According to the RISC-V psABI ... Wed, 27 Jun 2018 06:08:10 GMT Sebastian Huber [98f051e] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Remove RISCV_GCC_RED_ZONE_SIZE The current ABI says that ... Tue, 26 Jun 2018 06:53:28 GMT Sebastian Huber [9704d86f] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Enable interrupts during dispatch after ISR The code ... Tue, 26 Jun 2018 05:15:28 GMT Sebastian Huber [0fd8287] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add _CPU_Get_current_per_CPU_control() Update #3433. Tue, 26 Jun 2018 05:13:28 GMT Sebastian Huber [3be4478f] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Avoid namespace pollution Remove ... Thu, 28 Jun 2018 12:59:38 GMT Sebastian Huber [bc3bdf2] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Optimize and fix interrupt disable/enable Use the atomic ... Fri, 11 May 2018 04:54:59 GMT Sebastian Huber [2086948a] * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpfatal08/init.c (modified) riscv: Add dummy SMP support Update #3433. Fri, 22 Jun 2018 11:30:49 GMT Sebastian Huber [7c3b0df1] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Implement ISR set/get level Fix prototypes. Update #3433. Fri, 22 Jun 2018 11:30:21 GMT Sebastian Huber [9b2ef07f] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) bsp/riscv: Load global pointer Update #3433. Tue, 26 Jun 2018 05:48:06 GMT Sebastian Huber [52f4fb6] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Format assembler files Use tabs to match the GCC generated ... Tue, 19 Jun 2018 07:09:51 GMT Sebastian Huber [511dc4b] * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (deleted) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (deleted) * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/imx/start/linkcmds.imx7 (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/linkcmds (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (deleted) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (deleted) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/malta/start/start.S (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/mips/shared/irq/exception.S (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv_generic/start/start.S (modified) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/include/bsp.h (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/include/bsp.h (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shared/start/bspstart.c (modified) * bsps/sh/shsim/include/bsp.h (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpuasm.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spsize/size.c (modified) Rework initialization and interrupt stack support Statically ... Tue, 19 Jun 2018 12:59:51 GMT Sebastian Huber [c8df844] * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) score: Add CPU_INTERRUPT_STACK_ALIGNMENT Add CPU port define for ... Wed, 27 Jun 2018 06:17:26 GMT Sebastian Huber [718a84af] * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) Remove unused CPU_MODES_INTERRUPT_LEVEL Tue, 22 May 2018 06:52:13 GMT Sebastian Huber [762fa62] * bsps/arm/include/bsp/clock-armv7m.h (added) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) arm: Simplify CPU counter support Use the standard ARMv7-M systick ... Wed, 23 May 2018 12:17:25 GMT Sebastian Huber [65f868c] * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * bsps/arm/include/bsp/arm-a9mpcore-clock.h (modified) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/lpc24xx/start/system-clocks.c (modified) * bsps/arm/lpc32xx/start/bspstart.c (modified) * bsps/arm/realview-pbx-a9/start/bspstart.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * bsps/arm/tms570/cpucounter/cpucounterread.c (modified) * bsps/arm/xilinx-zynq/start/bspstart.c (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/shared/dev/cpucounter/cpucounterfrequency.c (added) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) Add _CPU_Counter_frequency() Add rtems_counter_frequency() API ... Thu, 07 Jun 2018 05:18:23 GMT Sebastian Huber [5249a4c] * bsps/powerpc/ss555/include/bsp.h (modified) * bsps/powerpc/ss555/start/irq_asm.S (modified) * bsps/powerpc/ss555/start/vectors.S (modified) * cpukit/score/cpu/powerpc/include/rtems/asm.h (modified) powerpc: Fix ss555 build The mpc555 define is provided via ... Fri, 25 May 2018 12:12:22 GMT Sebastian Huber [b8774933] * cpukit/score/src/objectgetnameasstring.c (modified) score: Simplify _Objects_Name_to_string() Do not use isprint() from ... Mon, 30 Apr 2018 22:18:49 GMT Joel Sherrill [c77cd426] * bsps/arm/lpc176x/can/can.c (modified) * bsps/arm/lpc176x/include/bsp/adc-defs.h (modified) * bsps/arm/lpc176x/include/bsp/adc.h (modified) * bsps/arm/lpc176x/include/bsp/can-defs.h (modified) * bsps/arm/lpc176x/include/bsp/can.h (modified) * bsps/arm/lpc176x/include/bsp/mbed-pinmap.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout-defs.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout.h (modified) * bsps/arm/lpc176x/pwm/pwmout.c (modified) * bsps/arm/lpc176x/start/adc.c (modified) * bsps/arm/lpc32xx/irq/irq.c (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_flash.h (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_otgfs.h (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_pwr.h (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_rcc.h (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_syscfg.h (modified) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_tim.h (modified) * bsps/include/libchip/ns16550_p.h (modified) * bsps/powerpc/include/libcpu/cpuIdent.h (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/score/cpu/arm/include/rtems/score/arm.h (modified) * testsuites/fstests/fsdosfsname01/files.h (modified) Drop executable permissions on .[ch] files Fri, 20 Apr 2018 11:22:29 GMT Sebastian Huber [c49896f1] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu_asm.S (moved) sparc: Move irq_asm.S This file is BSP-independent. This patch is ... Fri, 20 Apr 2018 11:19:28 GMT Sebastian Huber [28b4c7ac] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/cpu.c (deleted) * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Move _CPU_Trap_slot_template The definition of ... Mon, 16 Apr 2018 05:34:18 GMT Sebastian Huber [f35c3be9] * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/include/rtems/score/interrupts.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/lm32.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/m68k.h (modified) * cpukit/score/cpu/mips/include/rtems/score/mips.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) Remove register keyword from public header files The following code ... Thu, 05 Apr 2018 04:56:26 GMT Sebastian Huber [9edb72e] * c/src/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * testsuites/Makefile.am (modified) build: Remove DISTCLEANFILES A "make distclean" is not supported. ... Fri, 30 Mar 2018 18:42:21 GMT Sebastian Huber [2d0bc83] * Makefile.am (modified) * c/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libdrvmgr/Makefile.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libgnat/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libpci/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/telnetd/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/ada/Makefile.am (modified) * testsuites/ada/samples/base_mp/Makefile.am (modified) * testsuites/ada/support/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/mathl/Makefile.am (modified) * testsuites/samples/pppd/Makefile.am (modified) * tools/build/Makefile.am (modified) build: Remove EXTRA_DIST A "make dist" is not supported. So, it ...
