# # ChangeLog for cpukit/score in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 21:08:12 Fri, 09 Jun 2017 13:42:36 GMT Sebastian Huber [7b0c74ff] * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) i386: Support thread-local storage (TLS) Update #2468. Fri, 09 Jun 2017 06:17:59 GMT Sebastian Huber [cb0d9a0] * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: Move _CPU_Context_Initialize() Update #2468. Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Wed, 07 Jun 2017 06:14:30 GMT Sebastian Huber [836f454] * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrgetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/score/include/rtems/score/cpusetimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/test.c (modified) Fix CPU_COPY() usage The original CPU_COPY() support of Newlib ... Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Tue, 23 May 2017 08:03:56 GMT Sebastian Huber [d5c8756] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix profiling support of Thumb-1 targets Update #2751. Wed, 26 Apr 2017 01:02:09 GMT Joel Sherrill [03e4be12] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning Wed, 26 Apr 2017 01:01:41 GMT Joel Sherrill [65807379] * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning Tue, 25 Apr 2017 18:56:31 GMT Joel Sherrill [f6bd41e] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxie/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 18:39:50 GMT Joel Sherrill [fdfbb0a8] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 16:41:35 GMT Joel Sherrill [28e5749e] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix typo to eliminate warning Sun, 23 Apr 2017 17:57:27 GMT Joel Sherrill [0c334a5] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix not a prototype warning Sat, 08 Apr 2017 10:30:50 GMT Cillian O'Donnell [62c238e] * cpukit/score/cpu/i386/cpu.c (modified) cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning. Wed, 05 Apr 2017 09:28:46 GMT Sebastian Huber [46f05b92] * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) SMP: Simplify SMP multicast actions Mon, 27 Mar 2017 06:01:38 GMT Sebastian Huber [cd3d747] * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Optimize context switch Set CPU_ENABLE_ROBUST_THREAD_DISPATCH ... Thu, 09 Mar 2017 13:32:04 GMT Sebastian Huber [b437a360] * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) arm: Fix CPU context validation for Cortex-R4 Do not touch the ... Tue, 07 Mar 2017 13:32:42 GMT Sebastian Huber [2433a8ab] * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (deleted) * c/src/lib/libbsp/arm/shared/abort/abort.h (deleted) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (deleted) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/start/start.S (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (deleted) * cpukit/score/cpu/arm/arm_exc_handler_low.S (deleted) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Remove legacy execption support Tue, 07 Mar 2017 12:07:02 GMT Sebastian Huber [088acbb0] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulersmp.c (added) score: Fix scheduler yield in SMP configurations Check that no ask ... Mon, 06 Mar 2017 10:16:25 GMT Sebastian Huber [f61195b2] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Tue, 21 Feb 2017 07:58:29 GMT Sebastian Huber [c833970] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_WEAK_ALIAS() Wed, 15 Feb 2017 10:09:32 GMT Sebastian Huber [7a462cc] * cpukit/score/src/threadinitialize.c (modified) score: Fix warning Tue, 14 Feb 2017 07:42:48 GMT Sebastian Huber [6dbbafc6] * cpukit/score/src/threadname.c (modified) score: Fix warning in _Thread_Set_name() Fri, 03 Feb 2017 07:57:18 GMT Sebastian Huber [bbfbfc8] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadscheduler.c (modified) score: Move _Thread_Scheduler_ask_for_help() Move ... Thu, 02 Feb 2017 15:24:05 GMT Sebastian Huber [ca1e546e] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Improve scheduler helping protocol Only register ask for ... Fri, 03 Feb 2017 09:16:40 GMT Sebastian Huber [e2b1c47d] * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Fix volatile clobber Do not adjust the stack pointer, since ... Tue, 31 Jan 2017 07:08:24 GMT Sebastian Huber [e366f77] * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add _Thread_queue_Object_name Add the special thread queue ... Tue, 31 Jan 2017 08:37:54 GMT Sebastian Huber [70488f56] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Fix _Thread_Initialize() Mon, 30 Jan 2017 11:29:31 GMT Sebastian Huber [c5430e06] * cpukit/score/include/rtems/score/rbtree.h (modified) score: Fix unused parameter warning Close #2890. Mon, 30 Jan 2017 10:33:31 GMT Christian Mauderer [180107e9] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/startup/armv7m-cpucounter.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable ... Fri, 27 Jan 2017 07:06:06 GMT Sebastian Huber [4ea92d1e] * cpukit/score/include/rtems/score/heap.h (modified) score: Clarify _Heap_Extend() Update #1747. Fri, 27 Jan 2017 06:42:29 GMT Sebastian Huber [abc963d] * cpukit/score/include/rtems/score/heap.h (modified) score: Fix typo Thu, 26 Jan 2017 10:06:50 GMT Sebastian Huber [6f6da82c] * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/userextiterate.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Fix user extensions order Use forward and reverse order for ... Wed, 25 Jan 2017 13:32:02 GMT Sebastian Huber [27bfcd8] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Delete _CPU_Context_Fp_start() Since the FP area pointer is ... Tue, 24 Jan 2017 14:40:31 GMT Kevin Kirspel [b43c2e8] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) Adding ARM VFP V2 support Mon, 23 Jan 2017 14:04:44 GMT Sebastian Huber [3d20f5fb] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Relax CPU_STACK_ALIGNMENT Close #2352. Mon, 23 Jan 2017 07:12:18 GMT Sebastian Huber [4aa23c96] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN Use de-facto standard ... Fri, 12 Aug 2016 19:25:10 GMT Gedare Bloom [ba776282] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/shm.h (added) * cpukit/posix/include/rtems/posix/shmimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/shm.c (added) * cpukit/posix/src/shmheap.c (added) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (added) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxshm01/Makefile.am (added) * testsuites/psxtests/psxshm01/init.c (added) * testsuites/psxtests/psxshm01/psxshm01.scn (added) * testsuites/psxtests/psxshm01/system.h (added) * testsuites/psxtests/psxshm02/Makefile.am (added) * testsuites/psxtests/psxshm02/init.c (added) * testsuites/psxtests/psxshm02/psxshm02.scn (added) * testsuites/psxtests/psxshm02/system.h (added) * testsuites/sptests/spsysinit01/init.c (modified) posix: shared memory support Add POSIX shared memory manager (Shm). ... Fri, 13 Jan 2017 10:33:28 GMT Sebastian Huber [9fad437] * cpukit/configure.ac (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) configure: Remove HAVE_STRUCT__THREAD_QUEUE_QUEUE Thu, 12 Jan 2017 12:46:55 GMT Sebastian Huber [da6ad56] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/status.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadname.c (modified) score: Add _Thread_Set_name() Add configuration option ... Thu, 12 Jan 2017 08:25:56 GMT Sebastian Huber [7ced9d9b] * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadname.c (added) score: Add and use _Thread_Get_name() Update #2858. Thu, 12 Jan 2017 09:15:56 GMT Sebastian Huber [2b72162] * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) score: Add Thread_queue_Queue::name Update #2858. Thu, 12 Jan 2017 07:28:57 GMT Sebastian Huber [b8bcebe] * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectgetnameasstring.c (modified) score: Add and use _Objects_Name_to_string() Update #2858. Wed, 11 Jan 2017 07:49:26 GMT Sebastian Huber [fa9f964f] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Remove unused _States_Is_*() Wed, 11 Jan 2017 07:42:04 GMT Sebastian Huber [d063e7b3] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Replace STATES_DELAYING Replace STATES_DELAYING with ... Wed, 11 Jan 2017 15:43:06 GMT Joel Sherrill [7a4b2645] * cpukit/configure.ac (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrcompare.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/score/include/rtems/score/cpuset.h (modified) * cpukit/score/include/rtems/score/cpusetimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/cpuset.c (modified) * cpukit/score/src/cpusetprintsupport.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/system.h (modified) * testsuites/sptests/spcpuset01/test.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) Remove obsolete __RTEMS_HAVE_SYS_CPUSET_H__ Wed, 11 Jan 2017 12:41:55 GMT Sebastian Huber [3d35bc0] * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/threadq.c (modified) score: Improve SMP lock debug support The CPU index starts with ... Thu, 05 Jan 2017 14:40:57 GMT Sebastian Huber [4e07d9b3] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Optimize thread state values Fri, 23 Dec 2016 15:02:07 GMT Sebastian Huber [9a448aab] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER Add thread state bit ... Fri, 23 Dec 2016 06:09:02 GMT Sebastian Huber [c6000d2b] * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Delete STATES_WAITING_FOR_BUFFER Fri, 23 Dec 2016 05:47:11 GMT Sebastian Huber [2e6d9865] * cpukit/score/include/rtems/score/statesimpl.h (modified) score: Format thread state defines Specify all 32-bits in a thread ... Fri, 23 Dec 2016 12:54:11 GMT Sebastian Huber [a7cfb4b] * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadq.c (modified) score: Relax static assertions Only require that the ... Mon, 12 Dec 2016 14:03:35 GMT Christian Mauderer [fe7012a0] * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: Prevent thread_dispatch_disable_level < 0. Fri, 09 Dec 2016 08:28:31 GMT Sebastian Huber [e203b65e] * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED Update #2825. Fri, 09 Dec 2016 08:27:15 GMT Sebastian Huber [a5ba08eb] * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED Update #2825. Fri, 09 Dec 2016 07:44:49 GMT Sebastian Huber [9622f779] * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 07:44:22 GMT Sebastian Huber [82529688] * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 06:19:22 GMT Sebastian Huber [3a659b04] * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) score: Introduce _Internal_error() Fri, 09 Dec 2016 05:51:44 GMT Sebastian Huber [0a81a58] * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 05:49:25 GMT Sebastian Huber [279d5260] * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED Update #2825. Fri, 09 Dec 2016 09:49:49 GMT Sebastian Huber [6a9282d] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/score/include/rtems/score/userext.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) Rename is_internal to always_set_to_false Update #2825. Thu, 08 Dec 2016 15:41:30 GMT Sebastian Huber [b6606e8] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatal2.c (deleted) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/testcase.h (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spfatal28/testcase.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove fatal is internal indicator The fatal is internal ... Tue, 06 Dec 2016 10:35:34 GMT Sebastian Huber [4b579c5f] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/linkersets.h (modified) * testsuites/sptests/splinkersets01/init.c (modified) score: Simplify linker set API Resurrect RTEMS_LINKER_SET_BEGIN() ... Fri, 02 Dec 2016 12:10:31 GMT Sebastian Huber [f65dcc71] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) score: Fix ARM and PowerPC context initialization Update #2751. Thu, 01 Dec 2016 19:42:48 GMT Sebastian Huber [5b6c290] * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) score: Initialize thread queue context early Initialize thread ... Thu, 01 Dec 2016 21:24:02 GMT Sebastian Huber [b3cb2c1] * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) score: Fix debug thread queue context init On ARM Thumb we may have ... Tue, 22 Nov 2016 09:13:27 GMT Sebastian Huber [6a1b9e4] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of ... Mon, 28 Nov 2016 12:28:32 GMT Sebastian Huber [c09db57] * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Fix thread queue context initialization Initialize the ... Thu, 24 Nov 2016 10:53:59 GMT Sebastian Huber [bd0d585] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix _CPU_ISR_Is_enabled() for ARMv7-M Update #2811. Thu, 24 Nov 2016 05:13:11 GMT Sebastian Huber [620b23e] * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Optimize _Thread_queue_Enqueue() Move thread state for ... Wed, 23 Nov 2016 15:15:13 GMT Sebastian Huber [4b5ff47] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/score/include/rtems/score/profiling.h (modified) * cpukit/score/src/profilingisrentryexit.c (modified) score: Fix interrupt profiling Callers of _Thread_Do_dispatch() ... Wed, 23 Nov 2016 12:43:12 GMT Sebastian Huber [f6edd880] * cpukit/score/include/rtems/score/interr.h (modified) score: Explicitly define the fatal source numbers Update #2825. Wed, 23 Nov 2016 11:48:57 GMT Sebastian Huber [bee0323] * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Uncomment unused internal error codes Update #2825. Wed, 16 Nov 2016 13:50:09 GMT Sebastian Huber [c42be504] * cpukit/configure.ac (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/spinlock.h (deleted) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/pspin.c (deleted) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspintrylock.c (deleted) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corespinlock.h (deleted) * cpukit/score/include/rtems/score/corespinlockimpl.h (deleted) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corespinlockrelease.c (deleted) * cpukit/score/src/corespinlockwait.c (deleted) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxspin01/main.c (modified) * testsuites/psxtests/psxspin01/psxspin01.scn (modified) * testsuites/psxtests/psxspin01/test.c (modified) * testsuites/psxtests/psxspin02/Makefile.am (deleted) * testsuites/psxtests/psxspin02/main.c (deleted) * testsuites/psxtests/psxspin02/psxspin02.doc (deleted) * testsuites/psxtests/psxspin02/psxspin02.scn (deleted) * testsuites/psxtests/psxspin02/test.c (deleted) * testsuites/sptests/spsysinit01/init.c (modified) posix: Add self-contained pthread spinlock Turn pthread_spinlock_t ... Tue, 22 Nov 2016 07:46:02 GMT Sebastian Huber [520e07db] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_ALIAS() Tue, 22 Nov 2016 09:53:03 GMT Sebastian Huber [a4217c6] * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Rename _Thread_queue_Enqueue_critical() Delete unused ... Wed, 16 Nov 2016 15:39:43 GMT Sebastian Huber [125f248] * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spfatal03/testcase.h (modified) score: Add thread queue enqueue callout Replace the expected thread ... Thu, 10 Nov 2016 11:02:28 GMT Sebastian Huber [84e6f15] * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal06/Makefile.am (added) * testsuites/smptests/smpfatal06/init.c (added) * testsuites/smptests/smpfatal06/smpfatal06.doc (added) * testsuites/smptests/smpfatal06/smpfatal06.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) score: Robust thread dispatch On SMP configurations, it is a fatal ... Wed, 23 Nov 2016 06:16:41 GMT Sebastian Huber [ec17ad4] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulersmpdebug.c (deleted) score: Delete obsolete scheduler debug aid Wed, 23 Nov 2016 09:15:07 GMT Sebastian Huber [1d18a902] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix _ARMV4_Exception_interrupt Use the right register to ... Wed, 23 Nov 2016 06:47:57 GMT Sebastian Huber [a550b3f] * cpukit/score/include/rtems/score/percpu.h (modified) score: Force Per_CPU_Control::executing alignment This fixes the ... Mon, 21 Nov 2016 10:40:00 GMT Sebastian Huber [4e2bc0a] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) arm: Fix Thumb-1 targets We cannot use the MRS or MSR instructions ... Mon, 21 Nov 2016 09:26:32 GMT Sebastian Huber [ccc92b8] * cpukit/score/include/rtems/score/percpu.h (modified) score: Group Per_CPU_Control members by alignment Close #2820. Mon, 21 Nov 2016 09:25:58 GMT Sebastian Huber [27eccda] * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64: Fix _CPU_ISR_Is_enabled() Update #2820. Mon, 21 Nov 2016 09:13:37 GMT Sebastian Huber [fd6d3f1] * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) nios2: Fix _CPU_ISR_Is_enabled() Close #2818. Mon, 21 Nov 2016 09:11:18 GMT Sebastian Huber [9f225dea] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE Close #2816. Mon, 21 Nov 2016 09:06:36 GMT Sebastian Huber [c6f446b] * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) bfin: ASM compatibility for Close #2817. Thu, 17 Nov 2016 06:40:05 GMT Sebastian Huber [142628e] * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) score: Optimize self-contained objects Avoid use of the stack for ... Thu, 17 Nov 2016 06:20:07 GMT Sebastian Huber [1b87f27] * cpukit/score/include/rtems/score/mrspimpl.h (modified) score: Constify _MRSP_Get_owner() Thu, 10 Nov 2016 14:17:28 GMT Sebastian Huber [408609f6] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Add _ISR_Is_enabled() In contrast to _ISR_Get_level() the ... Thu, 10 Nov 2016 15:25:41 GMT Sebastian Huber [537f00eb] * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) score: Restrict task interrupt level to 0 on SMP Update #2811. Mon, 14 Nov 2016 14:23:40 GMT Sebastian Huber [7ce60b3] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Mon, 14 Nov 2016 08:53:57 GMT Sebastian Huber [d59585d] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Sun, 13 Nov 2016 14:20:59 GMT Sebastian Huber [2668e4f6] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Simplify _ARMV4_Exception_interrupt Move profiling code closer ... Sat, 12 Nov 2016 15:52:55 GMT Sebastian Huber [4924756] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Use local labels Mon, 14 Nov 2016 13:42:56 GMT Sebastian Huber [c11ac2d5] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) sparc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Fri, 11 Nov 2016 13:37:51 GMT Sebastian Huber [d5e073c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Allow interrupts during thread dispatch Use a ... Fri, 11 Nov 2016 13:12:03 GMT Sebastian Huber [f9aa34d] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Add Per_CPU_Control::Interrupt_frame Update #2809. Fri, 11 Nov 2016 14:45:10 GMT Sebastian Huber [2072dd2] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Add Per_CPU_Control::isr_dispatch_disable Update #2751. Fri, 11 Nov 2016 11:37:17 GMT Sebastian Huber [dbeccf0e] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpuimpl.h (modified) arm: Provide CPU_Interrupt_frame for ARMv4 Update #2809. Mon, 14 Nov 2016 11:06:46 GMT Sebastian Huber [2599c8e] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) powerpc: Add up to date CPU_Interrupt_frame Rename ...
