# # ChangeLog for cpukit/score in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 03:20:24 Fri, 20 Mar 2020 08:12:26 GMT Sebastian Huber [51307919] * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/irq/irq-armv7m.c (modified) * bsps/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/armv7m-initialize.c (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) arm: ARMv7-M statically initialized vector table Statically ... Thu, 12 Mar 2020 14:43:17 GMT Sebastian Huber [a6b36334] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iobase64.c (added) * testsuites/sptests/spprintk/init.c (modified) score: Add _IO_Base64() Update #3904. Wed, 26 Feb 2020 09:02:37 GMT Sebastian Huber [fcb11510] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/userextaddset.c (modified) * testsuites/sptests/spextensions01/init.c (modified) score: Fix context switch extensions (SMP) In uniprocessor and SMP ... Tue, 25 Feb 2020 13:43:52 GMT Sebastian Huber [01c97e64] * cpukit/score/src/threadinitialize.c (modified) score: Fix label defined but not used warning Update #3835. Sat, 15 Feb 2020 10:52:00 GMT Sebastian Huber [e50e42b8] * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: _Scheduler_Is_non_preempt_mode_supported() If the ... Sat, 15 Feb 2020 10:09:16 GMT Sebastian Huber [1ada3e55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add _SMP_Need_inter_processor_interrupts() Test for the ... Fri, 14 Feb 2020 12:48:18 GMT Sebastian Huber [ad85c00] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/score/src/wkspaceisunifieddefault.c (added) config: Add _Workspace_Is_unified Move the unified workspace ... Fri, 14 Feb 2020 12:36:30 GMT Sebastian Huber [5180762c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadidledefault.c (added) config: Add _Thread_Idle_body Move the idle thread body ... Fri, 14 Feb 2020 12:26:17 GMT Sebastian Huber [c70d112] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (added) * cpukit/score/src/threadcreateidle.c (modified) config: Add _Thread_Idle_stack_size Move the idle thread stack size ... Fri, 14 Feb 2020 11:58:21 GMT Sebastian Huber [308a2e0f] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/score/src/watchdogtimeslicedefault.c (added) config: Add _Watchdog_Ticks_per_timeslice Move the ticks per ... Thu, 13 Feb 2020 10:37:02 GMT Sebastian Huber [2807d556] * cpukit/score/src/wkspace.c (modified) score: Clean up wkspace.c Remove DEBUG_WORKSPACE support. There ... Thu, 13 Feb 2020 10:34:34 GMT Sebastian Huber [88c40ef8] * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/spwkspace/init.c (modified) score: Remove unused _Workspace_Allocate_aligned() Tue, 10 Dec 2019 10:13:18 GMT Sebastian Huber [d252e20a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/threadallocateunlimited.c (added) * cpukit/score/src/threadinitialize.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Simplify _Thread_Initialize() Allocate new thread queue ... Fri, 03 Jan 2020 06:19:47 GMT Sebastian Huber [fc32904] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Allocate_with_extend() Update #3835. Tue, 10 Dec 2019 10:26:20 GMT Sebastian Huber [dd9e501] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Activate_unlimited() Update #3835. Tue, 10 Dec 2019 10:09:32 GMT Sebastian Huber [8a43adb] * cpukit/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) score: Add _Freechain_Extend() Update #3835. Tue, 10 Dec 2019 09:46:52 GMT Sebastian Huber [36e59b2] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) score: _Objects_Extend_information() Return block index in ... Mon, 16 Dec 2019 14:10:05 GMT Sebastian Huber [8e118f22] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectnamespaceremove.c (modified) score: Inline _Objects_Namespace_remove_u32() This function is ... Mon, 16 Dec 2019 13:50:59 GMT Sebastian Huber [6135747] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectfreestatic.c (added) score: Split up objects free Split up the different objects free ... Tue, 10 Dec 2019 09:41:48 GMT Sebastian Huber [2485156] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (added) * cpukit/score/src/objectallocatestatic.c (added) * cpukit/score/src/objectallocateunlimited.c (added) score: Split up objects allocation Split up the different objects ... Tue, 10 Dec 2019 09:04:36 GMT Sebastian Huber [6f3bc0e] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectshrinkinformation.c (modified) score: Add _Objects_Free_objects_block() This is a preparation to ... Mon, 09 Dec 2019 15:03:11 GMT Sebastian Huber [32991495] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spstkalloc/init.c (modified) score: Statically allocate idle/MPCI stacks Place idle and MPCI ... Mon, 09 Dec 2019 13:48:34 GMT Sebastian Huber [01d5944] * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Move thread stack allocation Move thread stack allocation to ... Mon, 09 Dec 2019 13:33:06 GMT Sebastian Huber [4c9deb6c] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add _Stack_Extend_size() Update #3835. Mon, 09 Dec 2019 12:57:51 GMT Sebastian Huber [a08dcb2] * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add Thread_Configuration Add the Thread_Configuration ... Mon, 16 Dec 2019 13:32:47 GMT Sebastian Huber [00c7ad4] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/score/src/stackallocator.c (added) score: Split stack allocator configuration This allows the linker ... Mon, 09 Dec 2019 09:12:14 GMT Sebastian Huber [f4dbf37d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/src/configstackspacesize.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/tlsallocsize.c (added) * cpukit/score/src/wkspace.c (modified) score: Simplify TLS area allocation Use the stack area to allocate ... Sat, 07 Dec 2019 15:50:35 GMT Sebastian Huber [fc398fd] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Simplify FP context allocation Use the stack area to ... Sat, 07 Dec 2019 15:30:50 GMT Sebastian Huber [0e1ac917] * cpukit/score/src/threadcreateidle.c (modified) score: Remove _Stack_Ensure_minimum() call This call is superfluous ... Sat, 07 Dec 2019 15:28:21 GMT Sebastian Huber [0bde56b] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadstackfree.c (modified) score: Simplify thread stack free Update #3835. Sat, 07 Dec 2019 15:00:58 GMT Sebastian Huber [a0211fc9] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadstackallocate.c (modified) score: Simplify thread stack allocation Remove superfluous ... Fri, 06 Dec 2019 19:24:37 GMT Sebastian Huber [bf39a9e] * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) score: Remove superfluous FP types/defines Update #3835. Tue, 04 Feb 2020 14:26:31 GMT Sebastian Huber [2d07ce6] * bsps/shared/start/bootcard.c (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memorydirtyfreeareas.c (added) * testsuites/sptests/sp54/init.c (modified) config: Add CONFIGURE_DIRTY_MEMORY Replace the BSP_DIRTY_MEMORY BSP ... Tue, 04 Feb 2020 12:56:41 GMT Sebastian Huber [8ecbc38] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (added) * cpukit/score/src/memoryzerofreeareas.c (added) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/sp54/init.c (modified) sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY Use a dedicate system ... Fri, 13 Dec 2019 05:18:36 GMT Sebastian Huber [eea21eac] * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/imx/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/bspgetworkarea.c (modified) * bsps/powerpc/shared/start/sbrk.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/shared/start/bootcard.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/smptests/smpfatal09/init.c (modified) * testsuites/sptests/spfatal09/init.c (modified) * testsuites/sptests/spfatal12/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) bsps: Rework work area initialization The work area initialization ... Fri, 13 Dec 2019 05:25:03 GMT Sebastian Huber [c477d927] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memoryfill.c (added) score: Add _Memory_Fill() Update #3838. Tue, 10 Dec 2019 19:03:53 GMT Sebastian Huber [1cb9257] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/score/memory.h (added) * cpukit/score/src/memoryallocate.c (added) score: Add Memory Handler Update #3838. Sat, 01 Feb 2020 14:42:27 GMT Sebastian Huber [9e4f21b9] * cpukit/score/src/wkspace.c (modified) score: Optimize per-processor data placement Only align ... Thu, 02 Jan 2020 10:30:33 GMT Sebastian Huber [f74e806d] * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadmp.c (modified) mpci: Fix blocking proxy status Remove THREAD_STATUS_PROXY_BLOCKING ... Thu, 02 Jan 2020 08:17:03 GMT Sebastian Huber [a320aedd] * cpukit/score/src/objectinitializeinformation.c (modified) score: Fix objects node initialization The objects node is ... Thu, 12 Dec 2019 07:53:32 GMT Sebastian Huber [78211376] * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal08/init.c (deleted) * testsuites/sptests/spfatal08/spfatal08.doc (deleted) * testsuites/sptests/spfatal08/spfatal08.scn (deleted) score: Remove _Workspace_Allocate_or_fatal_error() This function is ... Thu, 12 Dec 2019 07:50:40 GMT Sebastian Huber [3fba9de2] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/objectmp.c (modified) config: Statically allocate MP object controls Update #3735. Thu, 12 Dec 2019 07:43:06 GMT Sebastian Huber [1d9f509e] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/threadmp.c (modified) config: Statically allocate MP thread proxies Update #3735. Thu, 12 Dec 2019 06:11:54 GMT Sebastian Huber [24f8915] * bsps/include/shm_driver.h (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (added) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/spsize/size.c (modified) config: Add _MPCI_Configuration Replace the user MPCI configuration ... Tue, 12 Nov 2019 15:33:41 GMT Joel Sherrill [08bd7d3] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/src/coretodhookdata.c (added) * cpukit/score/src/coretodhookregister.c (added) * cpukit/score/src/coretodhookrun.c (added) * cpukit/score/src/coretodhookunregister.c (added) * cpukit/score/src/coretodset.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclock_todhook01/init.c (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.doc (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.scn (added) Add TOD Hooks to allow BSP to take action when TOD is set Two use ... Thu, 05 Dec 2019 14:14:51 GMT Sebastian Huber [5ae6112] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/userextdata.h (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextiterate.c (modified) userext: Simplify configuration Avoid the use of the workspace and ... Fri, 29 Nov 2019 18:01:00 GMT Sebastian Huber [f4fda72] * bsps/riscv/riscv/headers.am (modified) * cpukit/score/cpu/riscv/headers.am (modified) Regenerate headers.am Mon, 11 Nov 2019 11:06:27 GMT Hesham Almatary [a4c5da6] * cpukit/configure.ac (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-riscv.c (added) * cpukit/score/cpu/riscv/include/machine/elf_machdep.h (added) * testsuites/libtests/configure.ac (modified) riscv: preliminarily support for libdl Support for targets compiled ... Mon, 04 Nov 2019 08:34:21 GMT Sebastian Huber [94584f17] * cpukit/score/src/heap.c (modified) heap: Simplify _Heap_Block_allocate() Determine the next block only ... Fri, 25 Oct 2019 13:19:01 GMT sebastian.huber [3859cd63] * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapfree.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) rtems-5: Improve heap fatal error information Update #3806. Mon, 28 Oct 2019 08:15:58 GMT Sebastian Huber [3fb72b0f] * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Add defines for small pages MMU Tue, 01 Oct 2019 11:48:27 GMT Sebastian Huber [8d989c5] * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Install timecounter according to quality This makes it ... Tue, 01 Oct 2019 11:04:29 GMT Sebastian Huber [47e5c1d] * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove strange timecounter init step The double call of the ... Tue, 01 Oct 2019 10:41:47 GMT Sebastian Huber [2763f53] * cpukit/include/sys/timetc.h (modified) * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove superfluous timecounter members Tue, 03 Sep 2019 08:11:21 GMT Sebastian Huber [0b3dcb3] * cpukit/score/cpu/arm/armv4-exception-default.S (modified) arm: Fix default exception handler Keep the stack pointer properly ... Tue, 25 Jun 2019 08:43:55 GMT Chris Johns [c43071f] * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Return the current handler from arm_cp15_set_exception_handler ... Thu, 06 Jun 2019 12:57:54 GMT Maksim E. Kozlov [2a720f4] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Fix mistakenly cleared PSR[EF] bit. The superfluously ... Wed, 05 Jun 2019 19:22:36 GMT Maksim E. Kozlov [a3818705] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Fix missed restoring of PSR in syscall_lazy_fp_switch It is ... Thu, 06 Jun 2019 05:53:09 GMT Sebastian Huber [7d7cbf3c] * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Improve _CPU_Context_validate() Use the FPU and check that ... Mon, 20 May 2019 07:15:36 GMT Sebastian Huber [5fa893e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpunicastaction.c (added) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Add _SMP_Unicast_action() Mon, 20 May 2019 07:06:48 GMT Sebastian Huber [41cddcc] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _Per_CPU_Wait_for_job() Sun, 28 Apr 2019 12:31:10 GMT Sebastian Huber [577293f0] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Add _SMP_Synchronize() Sun, 28 Apr 2019 12:15:45 GMT Sebastian Huber [bf867c55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Remove unused SMP_MESSAGE_TEST All uses were replaced by ... Fri, 19 Apr 2019 09:02:02 GMT Sebastian Huber [c63e8bb] * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Modify _Per_CPU_Perform_jobs() Process only the jobs ... Fri, 19 Apr 2019 09:01:31 GMT Sebastian Huber [85d6e845] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _Per_CPU_Add_job() Thu, 18 Apr 2019 06:38:00 GMT Sebastian Huber [8fa14da0] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Move per-processor job data structures This enables re-use ... Thu, 18 Apr 2019 05:08:32 GMT Sebastian Huber [3b2481f] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Simplify _SMP_Multicast_action() Move resposibility to ... Sun, 28 Apr 2019 12:29:21 GMT Sebastian Huber [7fdf48a] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _SMP_Othercast_action() Thu, 18 Apr 2019 04:47:01 GMT Sebastian Huber [65870044] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _SMP_Broadcast_action() Thu, 18 Apr 2019 04:31:33 GMT Sebastian Huber [4f06863] * cpukit/score/src/smpmulticastaction.c (modified) score: Use dedicated lock for per-CPU jobs Thu, 18 Apr 2019 04:29:57 GMT Sebastian Huber [327ae9ac] * cpukit/score/src/smpmulticastaction.c (modified) score: Fix per-CPU job done handling Fri, 12 Apr 2019 09:13:32 GMT Sebastian Huber [ef9d20f6] * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: More robust _SMP_Multicast_action() If the caller already ... Fri, 12 Apr 2019 05:55:31 GMT Sebastian Huber [ad40d05e] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (modified) score: Remove _SMP_Before_multitasking_action() Use ... Thu, 11 Apr 2019 13:39:36 GMT Sebastian Huber [f410b31b] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Improve _SMP_Multicast_action() Let it work during system ... Thu, 11 Apr 2019 13:16:40 GMT Sebastian Huber [e90486a] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Rework SMP multicast action Use a FIFO list of jobs per ... Tue, 09 Apr 2019 08:58:35 GMT Sebastian Huber [df8d7bd7] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpmulticast01/init.c (added) * testsuites/smptests/smpmulticast01/smpmulticast01.doc (added) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (added) score: Use processor mask in _SMP_Multicast_action Processor_mask ... Thu, 11 Apr 2019 11:47:50 GMT Sebastian Huber [e97b7c9a] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextremoveset.c (modified) score: Use an ISR lock for Per_CPU_Control::Lock The use of a hand ... Thu, 11 Apr 2019 10:10:53 GMT Sebastian Huber [18d45d9] * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/score/src/smp.c (modified) * testsuites/sptests/sp37/init.c (modified) score: Add _ISR_lock_Set_name() Add _ISR_lock_Set_name() to ... Thu, 11 Apr 2019 06:54:29 GMT Sebastian Huber [ad87de4] * bsps/powerpc/qoriq/start/bsprestart.c (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/shared/dev/clock/clockimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/rtems/src/getprocessorcount.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Rename _SMP_Get_processor_count() Rename ... Thu, 11 Apr 2019 06:52:36 GMT Sebastian Huber [cfcd6dc9] * bsps/powerpc/qoriq/start/bsprestart.c (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/score/src/smp.c (modified) score: Rename _SMP_Processor_count Rename _SMP_Processor_count in ... Fri, 05 Apr 2019 07:58:07 GMT Sebastian Huber [e0dcf294] * cpukit/posix/src/killinfo.c (modified) * cpukit/score/src/threaditerate.c (modified) Remove superfluous run-time check The _Objects_Information_table[ ... Thu, 04 Apr 2019 07:18:11 GMT Sebastian Huber [4c20da4b] * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/apimutex.h (modified) * cpukit/include/rtems/score/atomic.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/include/rtems/score/chain.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/coremutex.h (modified) * cpukit/include/rtems/score/coremuteximpl.h (modified) * cpukit/include/rtems/score/corerwlockimpl.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/coresemimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/heapinfo.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/mpciimpl.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/protectedheap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/rbtreeimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/smplockmcs.h (modified) * cpukit/include/rtems/score/smplockseq.h (modified) * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/include/rtems/score/smplockticket.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/statesimpl.h (modified) * cpukit/include/rtems/score/sysstate.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/timespec.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextdata.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/include/rtems/score/watchdog.h (modified) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/seterr.h (modified) * cpukit/include/rtems/system.h (modified) * cpukit/sapi/src/rbtreefind.c (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/src/apimutexisowner.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/log2table.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapinit.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultnodedestroy.c (modified) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadtimeout.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtickssinceboot.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) doxygen: Rename Score* groups in RTEMSScore* Update #3706 Tue, 02 Apr 2019 11:02:47 GMT Andreas Dachsberger [b2b7b58e] * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) doxygen: Added Management to Example CPU Architecture Update #3706. Mon, 01 Apr 2019 07:14:14 GMT Andreas Dachsberger [493c1e8] * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) doxygen: score: Put ARM Co-Processor 15 group in ARM Update #3706. Wed, 27 Mar 2019 10:17:16 GMT Andreas Dachsberger [95c76030] * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add x86-64 CPU architecture group Update #3706. Wed, 27 Mar 2019 10:11:54 GMT Andreas Dachsberger [9f8af67] * cpukit/score/cpu/v850/include/rtems/asm.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add V850 CPU architecture group Update #3706. Wed, 27 Mar 2019 09:59:35 GMT Andreas Dachsberger [2a50f87] * cpukit/score/cpu/sparc64/include/rtems/asm.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add SPARC64 CPU architecture group Update #3706. Wed, 27 Mar 2019 09:50:44 GMT Andreas Dachsberger [25afa79] * cpukit/score/cpu/sparc/include/rtems/asm.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add SPARC CPU architecture group Update #3706. Wed, 27 Mar 2019 09:46:08 GMT Andreas Dachsberger [2b37eca5] * cpukit/score/cpu/sh/include/rtems/asm.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add SuperH CPU architecture group Update #3706. Wed, 27 Mar 2019 09:38:56 GMT Andreas Dachsberger [71f9098] * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) doxygen: score: Add RISC-V CPU architecture group Update #3706. Tue, 26 Mar 2019 10:48:20 GMT Andreas Dachsberger [6ddbcbc] * cpukit/score/cpu/powerpc/include/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h (modified) doxygen: score: Add powerpc CPU architecture group Update #3706. Tue, 26 Mar 2019 10:40:41 GMT Andreas Dachsberger [39594416] * cpukit/score/cpu/or1k/include/rtems/asm.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) doxygen: score: Add or1k CPU architecture group Update #3706. Tue, 26 Mar 2019 10:33:40 GMT Andreas Dachsberger [92c2db64] * cpukit/score/cpu/nios2/include/rtems/asm.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add nios2 CPU architecture group Update #3706. Tue, 26 Mar 2019 10:25:44 GMT Andreas Dachsberger [f2e282d] * cpukit/score/cpu/moxie/include/rtems/asm.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add Moxie CPU architecture group Update #3706. Tue, 26 Mar 2019 09:44:58 GMT Andreas Dachsberger [0be1e54] * cpukit/score/cpu/m68k/include/rtems/asm.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/m68k.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/include/rtems/score/mips.h (modified) doxygen: score: Add m68k CPU architecture group Update #3706. Tue, 26 Mar 2019 09:22:26 GMT Andreas Dachsberger [ee38c54] * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (modified) doxygen: score: Change no_cpu architecture group Groups CPUContext ... Tue, 26 Mar 2019 08:50:42 GMT Andreas Dachsberger [9fa3561b] * cpukit/score/cpu/lm32/include/rtems/asm.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add lm32 CPU architecture group Update #3706. Tue, 26 Mar 2019 08:02:04 GMT Andreas Dachsberger [d670ef9] * cpukit/score/cpu/i386/include/rtems/asm.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/include/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/include/rtems/score/idtr.h (modified) * cpukit/score/cpu/i386/include/rtems/score/interrupts.h (modified) * cpukit/score/cpu/i386/include/rtems/score/paravirt.h (modified) * cpukit/score/cpu/i386/include/rtems/score/registers.h (modified) doxygen: score: Add i386 CPU architecture group Update #3706. Tue, 26 Mar 2019 07:15:29 GMT Andreas Dachsberger [40b90a08] * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (modified) doxygen: score: Add Epiphany CPU architecture group Update #3706. Mon, 25 Mar 2019 14:19:41 GMT Andreas Dachsberger [eca13a8f] * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (modified) doxygen: score: Add Blackfin CPU architecture group Update #3706.
