@cc480f9c
09/05/00 15:35:00 |
Joel Sherrill |
2000-09-04 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@ca7858bb
07/26/00 19:28:11 |
Joel Sherrill |
Port of RTEMS to the Texas Instruments C3x/C4x DSP families including …
4.104.114.84.95
@e001d84
07/24/00 22:28:15 |
Joel Sherrill |
Use bitwise and not cast to unsigned16 to remove upper bits.
4.104.114.84.95
@8a3278fc
07/06/00 19:11:15 |
Joel Sherrill |
Added objjectgetbyisr.c
4.104.114.84.95
@12aeaec6
07/06/00 19:10:30 |
Joel Sherrill |
The code that attempts to obtain a mutex has now been inlined. The …
4.104.114.84.95
@3b4413c0
07/06/00 19:09:27 |
Joel Sherrill |
Directly index local table to avoid error check.
4.104.114.84.95
@d895fe8
07/06/00 19:06:59 |
Joel Sherrill |
New file. Convert ID to pointer and return with interrupts -- not …
4.104.114.84.95
@42ed3004
07/06/00 19:01:58 |
Joel Sherrill |
Format of return line changed.
4.104.114.84.95
@0147d5e
07/03/00 15:49:58 |
Joel Sherrill |
Added blocked_count field to allow for optimizations.
4.104.114.84.95
@fdcb2b52
06/14/00 13:38:47 |
Joel Sherrill |
Thread iterator and libgjc support submitted too early.
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@e4c07444
04/13/00 14:47:15 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@4e36a2f
01/31/00 15:27:02 |
Joel Sherrill |
Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from …
4.104.114.84.95
@53fb837a
01/13/00 19:25:15 |
Joel Sherrill |
POSIX message queues now include complete functionality including …
4.104.114.84.95
@9c1c778d
01/13/00 18:32:38 |
Jennifer.Averett |
+ Added comments
4.104.114.84.95
@d65c3768
01/13/00 18:32:09 |
Jennifer.Averett |
+ Added and yellow line tested …
4.104.114.84.95
@e7d76dc
01/13/00 18:23:42 |
Jennifer.Averett |
Added comment.
4.104.114.84.95
@ea2c1d6
01/12/00 20:22:04 |
Jennifer.Averett |
+ Added code for waiting send
+ Yellow lined tested routine with Posix …
4.104.114.84.95
@89184f9
01/06/00 15:31:24 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@5870ac55
01/05/00 22:19:21 |
Joel Sherrill |
Added support for simple binary semaphores in addition to the high …
4.104.114.84.95
@db6ec79e
01/05/00 18:30:09 |
Joel Sherrill |
Fixed recursive release for mutexes with nesting allowed.
4.104.114.84.95
@466b8882
01/05/00 17:18:51 |
Jennifer.Averett |
Added the recording of the submit type.
4.104.114.84.95
@58243b4
01/05/00 17:18:08 |
Jennifer.Averett |
+ Added return of the message priority.
4.104.114.84.95
@7d91d72
12/13/99 15:29:20 |
Joel Sherrill |
First attempt at adding simple binary semaphore in addition to the …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@40fe60a3
11/17/99 20:44:13 |
Jennifer.Averett |
Comment added.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@7cc8d6c
11/02/99 21:48:15 |
Joel Sherrill |
Split core mutex and semaphore handlers into separate files.
4.104.114.84.95
@82cb78d8
11/02/99 21:45:15 |
Joel Sherrill |
Split core message queue and watchdog handler objects into separate files.
4.104.114.84.95
@93b4e6ef
11/02/99 21:05:17 |
Joel Sherrill |
Split Heap and Time of Day Handlers.
4.104.114.84.95
@dfbfa2b0
11/02/99 20:36:11 |
Joel Sherrill |
Split threadq.c into multiple files.
4.104.114.84.95
@317a5b5
11/02/99 19:43:52 |
Joel Sherrill |
Split object.c into multiple files.
4.104.114.84.95
@5d36b344
11/02/99 16:01:52 |
Joel Sherrill |
Fixed bug which resulted in misaligned object control structures
being …
4.104.114.84.95
@32441ab7
11/02/99 16:00:37 |
Joel Sherrill |
Added a comment to indicate that if a task blocked on a priority
based …
4.104.114.84.95
@2cd5444
11/02/99 15:58:39 |
Joel Sherrill |
Added code to allocate by index. This is the object ID style used
by …
4.104.114.84.95
@8f0529f
11/02/99 15:58:09 |
Joel Sherrill |
Added maximum count detection logic.
4.104.114.84.95
@9693fdac
11/02/99 15:57:58 |
Joel Sherrill |
Added support for message priority as required by POSIX.
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@f94e76ba
07/28/99 18:03:20 |
Joel Sherrill |
Fix after this report from Peter Pointner <pr@…>:
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@6a10709
03/31/99 22:33:14 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
joel@… wrote:
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@ed0e74e
12/03/98 21:53:25 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@9b39bab
02/20/98 20:23:57 |
Joel Sherrill |
Modified to make it possible for an ISR to return a mutex which did …
4.104.114.84.95
@c7744ee0
02/18/98 19:34:51 |
Joel Sherrill |
Ralf Corsepius noted that there was a dead path in _Thread_Initialize.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@b2225d7
01/06/98 15:40:35 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@3fc076d
04/09/97 20:04:52 |
Joel Sherrill |
added support for tracking thread cpu usage.
4.104.114.84.95
@192259f
04/09/97 20:04:36 |
Joel Sherrill |
enhanced printf statements
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@1019ae4
01/08/97 16:20:47 |
Joel Sherrill |
added some casts to reduce warnings reported by users with Microtec …
4.104.114.84.95
@27f0d424
10/15/96 21:38:43 |
Joel Sherrill |
added support for cpu time used field in tcb
4.104.114.84.95
@94218b8
09/18/96 20:51:48 |
Joel Sherrill |
loop to clear workspace memory changed to use sizeof rather than …
4.104.114.84.95
@56e0b88
09/18/96 20:50:58 |
Joel Sherrill |
corrected prototype of _Objects_Get_next
4.104.114.84.95
@3861130
09/18/96 20:50:27 |
Joel Sherrill |
uses address object rather than direct pointer arithmetic
4.104.114.84.95
@1d9d044
09/17/96 21:33:07 |
Joel Sherrill |
Reversed logic in conditional to correctly distinguish between
FIFO …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@0600e86f
08/15/96 21:05:21 |
Joel Sherrill |
_Thread_Start_multitasking: added code to initialize the floating …
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@3fd3da4
08/08/96 12:31:01 |
Mark.Johannes |
_MPCI_Register_packet_processor: changes first parameter type to …
4.104.114.84.95
@cc757fe
08/07/96 20:57:28 |
Mark.Johannes |
_CORE_Mutex_seize: added checks for priority ceiling violation, also …
4.104.114.84.95
@0f99198
08/06/96 16:26:11 |
Mark.Johannes |
_CORE_mutex_Seize: added change priority case if the mutex was obtained.
4.104.114.84.95
@1b17790c
06/13/96 16:43:39 |
Joel Sherrill |
Added code so post context switch extensions can be run on every …
4.104.114.84.95
@0f63c86
06/10/96 20:47:56 |
Joel Sherrill |
added code to _Thread_Clear_state to check if the state was not …
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@7169852
06/05/96 18:34:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@23305a25
06/05/96 14:46:04 |
Joel Sherrill |
added support for the api providing the thread stack area
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@d835a35
05/29/96 19:28:15 |
Joel Sherrill |
spacing
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
@1543932
04/24/96 17:36:35 |
Joel Sherrill |
added comment regarding stack alignment issues to thread stack …
4.104.114.84.95
@8faca06
04/22/96 16:46:36 |
Joel Sherrill |
thread.c: added support for optional user provided stack allocator
4.104.114.84.95
@14966f8
03/21/96 20:19:55 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@adf98bd
02/21/96 14:44:11 |
Joel Sherrill |
Removed the internal thread objects and dispersed its contents to
the …
4.104.114.84.95
@744d2878
02/14/96 18:48:39 |
Joel Sherrill |
removed arguments from _Thread_Start_multitasking
4.104.114.84.95
@df26b788
02/14/96 17:06:57 |
Joel Sherrill |
white space problem
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@391f6628
02/13/96 15:38:37 |
Joel Sherrill |
more comments added and existing ones cleaned up in synchronization paths
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@4f60309b
02/01/96 22:09:07 |
Joel Sherrill |
Swapped order of nested acquisition check and check for returning …
4.104.114.84.95
@f00a0522
02/01/96 21:54:40 |
Joel Sherrill |
synchronization state bugs address
4.104.114.84.95
@665356af
02/01/96 19:39:21 |
Joel Sherrill |
invalid use of tcb field resource count
4.104.114.84.95
