# # ChangeLog for cpukit/score/src in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 03:37:46 Wed, 17 Feb 2021 07:05:37 GMT Sebastian Huber [fea848b] * cpukit/include/rtems/score/thread.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Change thread action locking Require that the corresponding ... Sat, 13 Feb 2021 01:22:07 GMT Chris Johns [b5aef78] * cpukit/score/src/threadqops.c (modified) score: Fix warning in thread queue ops Fri, 05 Feb 2021 13:35:56 GMT Sebastian Huber [96ea09ac] * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) score: Add barrier thread queue operations This fixes a missing ... Fri, 05 Feb 2021 13:13:31 GMT Sebastian Huber [9477d9ae] * cpukit/headers.am (modified) * cpukit/include/rtems/score/threadqops.h (added) * cpukit/score/src/threadqops.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) score: Make FIFO thread queue ops public Update #4230. Fri, 05 Feb 2021 13:19:06 GMT Sebastian Huber [2b5ce23b] * cpukit/include/rtems/score/threadq.h (modified) * cpukit/score/src/threadqops.c (modified) score: Constify Thread_queue_First_operation Update #4230. Thu, 28 Jan 2021 14:06:48 GMT Sebastian Huber [0c99206] * cpukit/score/src/scheduleredfsmp.c (modified) score: Remove double assignment This fix relates to a Coverity ... Thu, 28 Jan 2021 13:50:11 GMT Sebastian Huber [2c050633] * cpukit/score/src/coremsgbroadcast.c (modified) score: Simplify _CORE_message_queue_Broadcast() This fix relates to ... Thu, 28 Jan 2021 10:40:10 GMT Sebastian Huber [198e926] * cpukit/score/src/kern_tc.c (modified) kern_tc.c: Remove unused code This fix relates to a Coverity issue ... Thu, 28 Jan 2021 10:29:12 GMT Sebastian Huber [64189a70] * cpukit/score/src/coremsgsubmit.c (modified) score: Fix _CORE_message_queue_Submit() indentation This fix ... Thu, 28 Jan 2021 10:17:51 GMT Sebastian Huber [395c15f] * cpukit/score/src/objectgetinfo.c (modified) score: Fix _Objects_Get_information() indentation This fix relates ... Wed, 27 Jan 2021 18:28:56 GMT Sebastian Huber [bf8d4b9] * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add _Thread_Get_objects_information() We do not need all the ... Fri, 29 Jan 2021 17:45:05 GMT Sebastian Huber [76eec484] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/score/src/threadget.c (modified) score: Rename _Thread_Get_objects_information() Rename ... Thu, 03 Dec 2020 14:32:14 GMT Sebastian Huber [7930fbdd] * cpukit/score/src/objectsetname.c (modified) score: Fix discard 'const' qualifier warning Tue, 24 Nov 2020 12:36:32 GMT Sebastian Huber [e2f888d1] * cpukit/score/src/objectsetname.c (modified) score: Free old name in _Objects_Set_name() This is the behaviour ... Mon, 23 Nov 2020 16:22:10 GMT Sebastian Huber [13bab34] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectsetname.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) score: Return a status in _Objects_Set_name() Fri, 27 Nov 2020 16:21:23 GMT Sebastian Huber [9278f3d] * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/apimutex.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/atomic.h (modified) * cpukit/include/rtems/score/chain.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgbuffer.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/coremutex.h (modified) * cpukit/include/rtems/score/coremuteximpl.h (modified) * cpukit/include/rtems/score/corerwlockimpl.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/coresemimpl.h (modified) * cpukit/include/rtems/score/cpustdatomic.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/freechainimpl.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/heapinfo.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/mpciimpl.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/mrsp.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/muteximpl.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/percpudata.h (modified) * cpukit/include/rtems/score/priority.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/include/rtems/score/priorityimpl.h (modified) * cpukit/include/rtems/score/processormask.h (modified) * cpukit/include/rtems/score/profiling.h (modified) * cpukit/include/rtems/score/protectedheap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/rbtreeimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernode.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/semaphoreimpl.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/include/rtems/score/smpbarrier.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/smplock.h (modified) * cpukit/include/rtems/score/smplockmcs.h (modified) * cpukit/include/rtems/score/smplockseq.h (modified) * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/include/rtems/score/smplockticket.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/statesimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/sysstate.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threaddispatch.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/timecounterimpl.h (modified) * cpukit/include/rtems/score/timespec.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/include/rtems/score/userext.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/include/rtems/score/watchdog.h (modified) * cpukit/include/rtems/score/watchdogimpl.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/apimutexisowner.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/configstackspacesize.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodhookdata.c (modified) * cpukit/score/src/coretodhookregister.c (modified) * cpukit/score/src/coretodhookrun.c (modified) * cpukit/score/src/coretodhookunregister.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/iobase64.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/iovprintf.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/kern_tc.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/log2table.c (modified) * cpukit/score/src/memoryallocate.c (modified) * cpukit/score/src/memorydirtyfreeareas.c (modified) * cpukit/score/src/memoryfill.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (modified) * cpukit/score/src/memoryzerofreeareas.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (modified) * cpukit/score/src/objectallocatestatic.c (modified) * cpukit/score/src/objectallocateunlimited.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectfreestatic.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/once.c (modified) * cpukit/score/src/opt_compat.h (modified) * cpukit/score/src/opt_ffclock.h (modified) * cpukit/score/src/opt_ntp.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultaskforhelp.c (modified) * cpukit/score/src/schedulerdefaultmappriority.c (modified) * cpukit/score/src/schedulerdefaultnodedestroy.c (modified) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/schedulerdefaultschedule.c (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerdefaultstartidle.c (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/smpunicastaction.c (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/stackallocatorfree.c (modified) * cpukit/score/src/stackallocatorfreenothing.c (modified) * cpukit/score/src/stackallocatorinit.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadallocateunlimited.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadidledefault.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadname.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadtimeout.c (modified) * cpukit/score/src/threadunpin.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecgetasnanoseconds.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/watchdogtickssinceboot.c (modified) * cpukit/score/src/watchdogtimeslicedefault.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceisunifieddefault.c (modified) * cpukit/score/src/wkspacemallocinitdefault.c (modified) * cpukit/score/src/wkspacemallocinitunified.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) score: Canonicalize Doxygen @file comments Use common phrases for ... Fri, 27 Nov 2020 18:51:59 GMT Sebastian Huber [b48b1808] * cpukit/Makefile.am (modified) * cpukit/score/src/pheapinit.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) score: Delete empty pheapinit.c Thu, 19 Nov 2020 07:40:25 GMT Sebastian Huber [298b5ef1] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) config: Initialize task stack allocator on demand Register a custom ... Thu, 19 Nov 2020 07:40:13 GMT Sebastian Huber [c5af8aa0] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal06.yml (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal06/init.c (deleted) * testsuites/sptests/spfatal06/spfatal06.doc (deleted) * testsuites/sptests/spfatal06/spfatal06.scn (deleted) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) config: Simplify task stack allocator init Replace runtime checks ... Tue, 13 Oct 2020 11:47:06 GMT Sebastian Huber [3972085] * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/objectmp.c (modified) Remove *_Is_null() inline functions Simply compare the values ... Wed, 30 Sep 2020 09:31:58 GMT Sebastian Huber [f2185d10] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/mallocheap.c (added) * cpukit/score/src/wkspacemallocinitdefault.c (added) * cpukit/score/src/wkspacemallocinitunified.c (added) * spec/build/cpukit/librtemscpu.yml (modified) Decouple the C Program Heap initialization Before this patch ... Wed, 23 Sep 2020 14:47:58 GMT Sebastian Huber [4a4f41e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqconstruct.c (added) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgwkspace.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/mptests/mp09/initimpl.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/system.h (modified) rtems: Add rtems_message_queue_construct() In contrast to message ... Wed, 23 Sep 2020 08:33:51 GMT Sebastian Huber [69b4fe59] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Simplify CORE_message_queue_Buffer Merge ... Wed, 23 Sep 2020 08:09:37 GMT Sebastian Huber [5bc7c37] * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * testsuites/sptests/sp77/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Improve _CORE_message_queue_Initialize() Return a status ... Mon, 21 Sep 2020 06:15:27 GMT Sebastian Huber [34dd90a5] * cpukit/score/src/coremsg.c (modified) score: Gather message queue control initialization Initialize the ... Mon, 21 Sep 2020 06:14:05 GMT Sebastian Huber [fe2cb7c4] * cpukit/score/src/coremsg.c (modified) score: Fix allocation size calculation The previous multiplication ... Mon, 21 Sep 2020 06:10:06 GMT Sebastian Huber [3c025576] * cpukit/score/src/coremsg.c (modified) score: Use RTEMS_ALIGN_UP() Update #4007. Thu, 10 Sep 2020 14:35:09 GMT Sebastian Huber [c312f31] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal33.yml (added) * testsuites/sptests/spfatal33/init.c (added) * testsuites/sptests/spfatal33/spfatal33.doc (added) * testsuites/sptests/spfatal33/spfatal33.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE Add this application ... Fri, 11 Sep 2020 13:43:23 GMT Sebastian Huber [dd734d46] * cpukit/score/src/threadinitialize.c (modified) score: Fix _Thread_Initialize() Fix an error cleanup path in SMP ... Thu, 09 Apr 2020 10:11:19 GMT Sebastian Huber [aedd92d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/stackallocatorfreenothing.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add stack free handler to TCB This avoids a dependency to ... Thu, 09 Apr 2020 13:41:38 GMT Sebastian Huber [2d551030] * cpukit/Makefile.am (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/stackallocatorfree.c (added) score: Move _Stack_Allocator_free to separate file This decouples ... Thu, 09 Apr 2020 13:17:46 GMT Sebastian Huber [d817220] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/stackallocatorinit.c (added) * cpukit/score/src/thread.c (modified) score: Add _Stack_Allocator_do_initialize() Do the stack allocator ... Wed, 08 Apr 2020 09:31:02 GMT Sebastian Huber [159db411] * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Use _Freechain_Push() The nodes are never NULL. Update #3959. Wed, 08 Apr 2020 09:30:32 GMT Sebastian Huber [354c2b5] * cpukit/headers.am (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/freechainimpl.h (added) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadallocateunlimited.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/sptests/spfreechain01/init.c (modified) score: Add Hide implementation ... Wed, 08 Apr 2020 09:21:27 GMT Sebastian Huber [91c811a1] * cpukit/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) score: Add _Freechain_Push() Update #3959. Mon, 31 Aug 2020 15:07:19 GMT Sebastian Huber [5bb93f2] * cpukit/score/src/threadrestart.c (modified) score: Fix debug assert Do not access executing->current_state ... Thu, 25 Jun 2020 05:49:50 GMT Sebastian Huber [1818b9a] * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) score: Optimize _Objects_Name_to_id_u32() Remove the superfluous ... Wed, 24 Jun 2020 11:54:23 GMT Sebastian Huber [c7e3085] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/objectimpl.h (added) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/rtemsnametoid.c (added) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/score/src/objectnametoid.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) rtems: Add _RTEMS_Name_to_id() Simplify object name to identifier ... Wed, 24 Jun 2020 11:12:49 GMT Sebastian Huber [33dbb33] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) score: Constify objects name to id functions Fri, 21 Aug 2020 07:17:47 GMT Sebastian Huber [abf25bc] * cpukit/score/src/threadqenqueue.c (modified) score: Fix set but not used warning Mon, 29 Jun 2020 19:35:08 GMT Kinsey Moore [48dd7b8c] * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/src/threadhandler.c (modified) score: Add CPU_USE_LIBC_INIT_FINI_ARRAY This introduces the ... Mon, 27 Apr 2020 14:14:06 GMT Sebastian Huber [cfe8f7a] * cpukit/include/rtems/rtems-rfs.h (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-dump.c (modified) * cpukit/libblock/src/bdpart-mount.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-sort.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ioctl.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/assoclocalbyname.c (modified) * cpukit/libcsupport/src/assocremotebylocalbitfield.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/kill_noposix.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fcntl.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_mknod.c (modified) * cpukit/libfs/src/defaults/default_mount.c (modified) * cpukit/libfs/src/defaults/default_open.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unmount.c (modified) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/defaults/default_write.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c (modified) * cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/pipe/pipe.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_get.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparam.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c (modified) * cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/devnull/devnull.c (modified) * cpukit/libmisc/devnull/devzero.c (modified) * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/fb/mw_uid.c (modified) * cpukit/libmisc/fsmount/fsmount.c (modified) * cpukit/libmisc/mouse/mouse_parser.c (modified) * cpukit/libmisc/mouse/serial_mouse.c (modified) * cpukit/libmisc/shell/main_df.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stringto/stringtodouble.c (modified) * cpukit/libmisc/stringto/stringtofloat.c (modified) * cpukit/libmisc/stringto/stringtoint.c (modified) * cpukit/libmisc/stringto/stringtolong.c (modified) * cpukit/libmisc/stringto/stringtolongdouble.c (modified) * cpukit/libmisc/stringto/stringtolonglong.c (modified) * cpukit/libmisc/stringto/stringtopointer.c (modified) * cpukit/libmisc/stringto/stringtounsignedchar.c (modified) * cpukit/libmisc/stringto/stringtounsignedint.c (modified) * cpukit/libmisc/stringto/stringtounsignedlong.c (modified) * cpukit/libmisc/stringto/stringtounsignedlonglong.c (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/barrierattrgetpshared.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetclock.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetclock.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getitimer.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxnametoid.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/psxtimerdelete.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrdefault.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetguardsize.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstack.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadconcurrency.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/rwlockattrsetpshared.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setitimer.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/posix/src/vfork.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/src/rbtreefind.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) doxygen: Switch @brief and @ingroup This order change fixes the ... Wed, 15 Apr 2020 07:48:32 GMT Sebastian Huber [80cf60e] * cpukit/dev/i2c/eeprom.c (modified) * cpukit/dev/i2c/fpga-i2c-slave.c (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/dev/i2c/sensor-lm75a.c (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (modified) * cpukit/dev/i2c/ti-ads-16bit-adc.c (modified) * cpukit/dev/i2c/ti-lm25066a.c (modified) * cpukit/dev/i2c/ti-tmp112.c (modified) * cpukit/dev/spi/spi-bus.c (modified) * cpukit/ftpd/ftpd-init.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ioctl.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/ide_part_table.c (modified) * cpukit/libblock/src/nvdisk-sram.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * cpukit/libblock/src/show_bdbuf.c (modified) * cpukit/libcsupport/src/__assert.c (modified) * cpukit/libcsupport/src/__getpid.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/_calloc_r.c (modified) * cpukit/libcsupport/src/_free_r.c (modified) * cpukit/libcsupport/src/_malloc_r.c (modified) * cpukit/libcsupport/src/_realloc_r.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/alignedalloc.c (modified) * cpukit/libcsupport/src/assoc32tostring.c (modified) * cpukit/libcsupport/src/assoclocalbyname.c (modified) * cpukit/libcsupport/src/assoclocalbyremote.c (modified) * cpukit/libcsupport/src/assoclocalbyremotebitfield.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/assocnamebylocal.c (modified) * cpukit/libcsupport/src/assocnamebylocalbitfield.c (modified) * cpukit/libcsupport/src/assocnamebyremote.c (modified) * cpukit/libcsupport/src/assocnamebyremotebitfield.c (modified) * cpukit/libcsupport/src/assocptrbylocal.c (modified) * cpukit/libcsupport/src/assocptrbyname.c (modified) * cpukit/libcsupport/src/assocptrbyremote.c (modified) * cpukit/libcsupport/src/assocremotebylocal.c (modified) * cpukit/libcsupport/src/assocremotebylocalbitfield.c (modified) * cpukit/libcsupport/src/assocremotebyname.c (modified) * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfmakeraw.c (modified) * cpukit/libcsupport/src/cfmakesane.c (modified) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/clock.c (modified) * cpukit/libcsupport/src/clonenode.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/consolesimple.c (modified) * cpukit/libcsupport/src/consolesimpletask.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/flockfile.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/freenode.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ftrylockfile.c (modified) * cpukit/libcsupport/src/funlockfile.c (modified) * cpukit/libcsupport/src/getchark.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/geteuid.c (modified) * cpukit/libcsupport/src/getgid.c (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (modified) * cpukit/libcsupport/src/getgroups.c (modified) * cpukit/libcsupport/src/getlogin.c (modified) * cpukit/libcsupport/src/getpagesize.c (modified) * cpukit/libcsupport/src/getpgrp.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/getreentglobal.c (modified) * cpukit/libcsupport/src/getrusage.c (modified) * cpukit/libcsupport/src/getuid.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/isatty_r.c (modified) * cpukit/libcsupport/src/issetugid.c (modified) * cpukit/libcsupport/src/kill_noposix.c (modified) * cpukit/libcsupport/src/lchown.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_exit.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/malloc_dirtier.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_walk.c (modified) * cpukit/libcsupport/src/mallocdirtydefault.c (modified) * cpukit/libcsupport/src/mallocextenddefault.c (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mallocgetheapptr.c (modified) * cpukit/libcsupport/src/mallocinfo.c (modified) * cpukit/libcsupport/src/mallocsetheapptr.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/mkfifo.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount-mgr.c (modified) * cpukit/libcsupport/src/mount-mktgt.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/libcsupport/src/pathconf.c (modified) * cpukit/libcsupport/src/posix_devctl.c (modified) * cpukit/libcsupport/src/posix_memalign.c (modified) * cpukit/libcsupport/src/print_fprintf.c (modified) * cpukit/libcsupport/src/print_printf.c (modified) * cpukit/libcsupport/src/printf_plugin.c (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/libcsupport/src/printk_plugin.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/readv.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/rtems_heap_extend.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_null_extend.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libcsupport/src/rtems_mkdir.c (modified) * cpukit/libcsupport/src/rtems_put_char.c (modified) * cpukit/libcsupport/src/rtems_putc.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libcsupport/src/seteuid.c (modified) * cpukit/libcsupport/src/setgid.c (modified) * cpukit/libcsupport/src/setpgid.c (modified) * cpukit/libcsupport/src/setsid.c (modified) * cpukit/libcsupport/src/setuid.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_deviceio.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (modified) * cpukit/libcsupport/src/sup_fs_next_token.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcgetpgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_num2baud.c (modified) * cpukit/libcsupport/src/termios_posix_isig_handler.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libcsupport/src/utimes.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libcsupport/src/vprintk.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libcsupport/src/write_r.c (modified) * cpukit/libcsupport/src/writev.c (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unwind-dw2.c (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (modified) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_clone.c (modified) * cpukit/libfs/src/defaults/default_eval_path.c (modified) * cpukit/libfs/src/defaults/default_fchmod.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (modified) * cpukit/libfs/src/defaults/default_ioctl.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) * cpukit/libfs/src/defaults/default_lseek_directory.c (modified) * cpukit/libfs/src/defaults/default_lseek_file.c (modified) * cpukit/libfs/src/defaults/default_mknod.c (modified) * cpukit/libfs/src/defaults/default_mmap.c (modified) * cpukit/libfs/src/defaults/default_open.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_readv.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/defaults/default_writev.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs_add_node.c (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_config.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_dir.c (modified) * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) * cpukit/libfs/src/imfs/imfs_dir_minimal.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_eval_devfs.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_make_linfile.c (modified) * cpukit/libfs/src/imfs/imfs_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_node_destroy_default.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_stat_file.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libfs/src/nfsclient/src/xdr_mbuf.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-block.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-group.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-inode.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-mutex.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) * cpukit/libgnat/adasupp.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/cpuuse/cpuinforeport.c (modified) * cpukit/libmisc/fb/mw_print.c (modified) * cpukit/libmisc/shell/main_blkstats.c (modified) * cpukit/libmisc/shell/main_cmdchmod.c (modified) * cpukit/libmisc/shell/main_cmdchown.c (modified) * cpukit/libmisc/shell/main_cmdls.c (modified) * cpukit/libmisc/shell/main_cpuinfo.c (modified) * cpukit/libmisc/shell/main_hexdump.c (modified) * cpukit/libmisc/shell/main_lsof.c (modified) * cpukit/libmisc/shell/main_profreport.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/uuid/gen_uuid.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall_api.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/libtest/testwrappers.c (modified) * cpukit/libtrace/record/record-client.c (modified) * cpukit/libtrace/record/record-dump-base64.c (modified) * cpukit/libtrace/record/record-dump-fatal.c (modified) * cpukit/libtrace/record/record-dump-zbase64.c (modified) * cpukit/libtrace/record/record-dump-zfatal.c (modified) * cpukit/libtrace/record/record-dump.c (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-sysinit.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * cpukit/libtrace/record/record-util.c (modified) * cpukit/libtrace/record/record.c (modified) * cpukit/mghttpd/mongoose.c (modified) * cpukit/posix/src/_execve.c (modified) * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_error.c (modified) * cpukit/posix/src/aio_fsync.c (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_return.c (modified) * cpukit/posix/src/aio_suspend.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/barrierattrgetpshared.c (modified) * cpukit/posix/src/barrierattrinit.c (modified) * cpukit/posix/src/barrierattrsetpshared.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetclock.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetclock.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/fork.c (modified) * cpukit/posix/src/getitimer.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/keyzerokvp.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/lio_listio.c (modified) * cpukit/posix/src/mlock.c (modified) * cpukit/posix/src/mlockall.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueueconfig.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/msync.c (modified) * cpukit/posix/src/munlock.c (modified) * cpukit/posix/src/munlockall.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/posix_madvise.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalconfig.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/psxnametoid.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxsemaphoreconfig.c (modified) * cpukit/posix/src/psxtimerconfig.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/psxtimerdelete.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadatfork.c (modified) * cpukit/posix/src/pthreadattrdefault.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetguardsize.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstack.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadconcurrency.c (modified) * cpukit/posix/src/pthreadconfig.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetnamenp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetnamenp.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedprio.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/rwlockattrgetpshared.c (modified) * cpukit/posix/src/rwlockattrinit.c (modified) * cpukit/posix/src/rwlockattrsetpshared.c (modified) * cpukit/posix/src/sched_getparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/setitimer.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmconfig.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmops.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/posix/src/vfork.c (modified) * cpukit/posix/src/wait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/getapiconfig.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/modes.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/statustext.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskexit.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskgetpriority.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitdefault.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskiterate.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskself.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/chainappendnotify.c (modified) * cpukit/sapi/src/chaingetnotify.c (modified) * cpukit/sapi/src/chaingetwait.c (modified) * cpukit/sapi/src/chainprependnotify.c (modified) * cpukit/sapi/src/chainprotected.c (modified) * cpukit/sapi/src/delaynano.c (modified) * cpukit/sapi/src/delayticks.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/sapi/src/getversionstring.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioclose.c (modified) * cpukit/sapi/src/iocontrol.c (modified) * cpukit/sapi/src/iodefault.c (modified) * cpukit/sapi/src/ioinitialize.c (modified) * cpukit/sapi/src/ioopen.c (modified) * cpukit/sapi/src/ioread.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/iounregisterdriver.c (modified) * cpukit/sapi/src/iowrite.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/sapi/src/profilingreportxml.c (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/sapi/src/rbtree.c (modified) * cpukit/sapi/src/rbtreefind.c (modified) * cpukit/sapi/src/sapirbtreeinsert.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (modified) * cpukit/sapi/src/version.c (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (modified) * cpukit/score/cpu/arm/__tls_get_addr.c (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-default.c (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv7-thread-idle.c (modified) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/armv7m-context-restore.c (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-handler-set.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-get.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-handler.c (modified) * cpukit/score/cpu/arm/armv7m-exception-priority-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) * cpukit/score/cpu/arm/armv7m-isr-level-set.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (modified) * cpukit/score/cpu/epiphany/epiphany-context-initialize.c (modified) * cpukit/score/cpu/epiphany/epiphany-context-switch.S (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (modified) * cpukit/score/cpu/moxie/moxie-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (modified) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (modified) * cpukit/score/cpu/nios2/nios2-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-configuration.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-reset.c (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) * cpukit/score/cpu/or1k/or1k-context-switch.S (modified) * cpukit/score/cpu/or1k/or1k-context-validate.S (modified) * cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S (modified) * cpukit/score/cpu/or1k/or1k-exception-default.c (modified) * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (modified) * cpukit/score/src/allocatormutex.c (modified) * cpukit/score/src/apimutexisowner.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/configstackspacesize.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodhookdata.c (modified) * cpukit/score/src/coretodhookregister.c (modified) * cpukit/score/src/coretodhookrun.c (modified) * cpukit/score/src/coretodhookunregister.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapgreedy.c (modified) * cpukit/score/src/heapiterate.c (modified) * cpukit/score/src/heapnoextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/ioprintf.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/libatomic.c (modified) * cpukit/score/src/log2table.c (modified) * cpukit/score/src/memoryallocate.c (modified) * cpukit/score/src/memorydirtyfreeareas.c (modified) * cpukit/score/src/memoryfill.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (modified) * cpukit/score/src/memoryzerofreeareas.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (modified) * cpukit/score/src/objectallocatestatic.c (modified) * cpukit/score/src/objectallocateunlimited.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectfreestatic.c (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/percpustatewait.c (modified) * cpukit/score/src/pheapallocate.c (modified) * cpukit/score/src/pheapextend.c (modified) * cpukit/score/src/pheapfree.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/pheapgetfreeinfo.c (modified) * cpukit/score/src/pheapgetinfo.c (modified) * cpukit/score/src/pheapgetsize.c (modified) * cpukit/score/src/pheapinit.c (modified) * cpukit/score/src/pheapiterate.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/processormaskcopy.c (modified) * cpukit/score/src/profilingisrentryexit.c (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/rbtreepostorder.c (modified) * cpukit/score/src/rbtreereplace.c (modified) * cpukit/score/src/sched.c (modified) * cpukit/score/src/scheduler.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbscreateserver.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsgetserverid.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaultaskforhelp.c (modified) * cpukit/score/src/schedulerdefaultmappriority.c (modified) * cpukit/score/src/schedulerdefaultnodedestroy.c (modified) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (modified) * cpukit/score/src/schedulerdefaultreleasejob.c (modified) * cpukit/score/src/schedulerdefaultschedule.c (modified) * cpukit/score/src/schedulerdefaultsetaffinity.c (modified) * cpukit/score/src/schedulerdefaultstartidle.c (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/scheduleredfschedule.c (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) * cpukit/score/src/schedulerpriority.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerpriorityblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityschedule.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * cpukit/score/src/schedulersimple.c (modified) * cpukit/score/src/schedulersimpleblock.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleschedule.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/semaphore.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpbarrierwait.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/stackallocator.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadallocateunlimited.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadentryadaptoridle.c (modified) * cpukit/score/src/threadentryadaptornumeric.c (modified) * cpukit/score/src/threadentryadaptorpointer.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadidledefault.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threaditerate.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadname.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqops.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadscheduler.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadtimeout.c (modified) * cpukit/score/src/threadunpin.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) * cpukit/score/src/threadyield.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecgetasnanoseconds.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (modified) * cpukit/score/src/watchdogtickssinceboot.c (modified) * cpukit/score/src/watchdogtimeslicedefault.c (modified) * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceisunifieddefault.c (modified) * cpukit/score/src/wkstringduplicate.c (modified) * cpukit/telnetd/telnetd-init.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) * testsuites/fstests/fsimfsconfig02/init.c (modified) * testsuites/fstests/fsimfsconfig03/init.c (modified) * testsuites/fstests/fsjffs2gc01/init.c (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/fstests/fsrename/test.c (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) * testsuites/fstests/fsrofs01/init.c (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/block17/init.c (modified) * testsuites/libtests/complex/docomplex.c (modified) * testsuites/libtests/complex/docomplexf.c (modified) * testsuites/libtests/complex/docomplexl.c (modified) * testsuites/libtests/crypt01/init.c (modified) * testsuites/libtests/debugger01/remote.c (modified) * testsuites/libtests/defaultconfig01/init.c (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (modified) * testsuites/libtests/dl03/dl-cache.c (modified) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl04/dl-load.c (modified) * testsuites/libtests/dl04/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl05/init.c (modified) * testsuites/libtests/dl06/initimpl.h (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/init.c (modified) * testsuites/libtests/dl09/init.c (modified) * testsuites/libtests/dl10/init.c (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/getentropy01/init.c (modified) * testsuites/libtests/i2c01/init.c (modified) * testsuites/libtests/libfdt01/init.c (modified) * testsuites/libtests/math/domath.c (modified) * testsuites/libtests/mathf/domathf.c (modified) * testsuites/libtests/mathl/domathl.c (modified) * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp02/init.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/libtests/sha/init.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) * testsuites/libtests/spi01/init.c (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/libtests/utf8proc01/init.c (modified) * testsuites/psxtests/psxcleanup02/init.c (modified) * testsuites/psxtests/psxcleanup02/main.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxglobalcon01/init.cc (modified) * testsuites/psxtests/psxglobalcon02/init.cc (modified) * testsuites/psxtests/psxhdrs/netdb/endhostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endservent.c (modified) * testsuites/psxtests/psxhdrs/netdb/freeaddrinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/gai_strerror.c (modified) * testsuites/psxtests/psxhdrs/netdb/getaddrinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnameinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetbyaddr.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotobyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotobynumber.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservbyport.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservent.c (modified) * testsuites/psxtests/psxhdrs/netdb/h_errno.c (modified) * testsuites/psxtests/psxhdrs/netdb/sethostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setservent.c (modified) * testsuites/psxtests/psxhdrs/string/memccpy.c (modified) * testsuites/psxtests/psxhdrs/string/memchr.c (modified) * testsuites/psxtests/psxhdrs/string/memcmp.c (modified) * testsuites/psxtests/psxhdrs/string/memcpy.c (modified) * testsuites/psxtests/psxhdrs/string/memmove.c (modified) * testsuites/psxtests/psxhdrs/string/memset.c (modified) * testsuites/psxtests/psxhdrs/string/stpcpy.c (modified) * testsuites/psxtests/psxhdrs/string/stpncpy.c (modified) * testsuites/psxtests/psxhdrs/string/strcat.c (modified) * testsuites/psxtests/psxhdrs/string/strchr.c (modified) * testsuites/psxtests/psxhdrs/string/strcmp.c (modified) * testsuites/psxtests/psxhdrs/string/strcoll.c (modified) * testsuites/psxtests/psxhdrs/string/strcoll_l.c (modified) * testsuites/psxtests/psxhdrs/string/strcpy.c (modified) * testsuites/psxtests/psxhdrs/string/strcspn.c (modified) * testsuites/psxtests/psxhdrs/string/strdup.c (modified) * testsuites/psxtests/psxhdrs/string/strerror.c (modified) * testsuites/psxtests/psxhdrs/string/strerror_l.c (modified) * testsuites/psxtests/psxhdrs/string/strerror_r.c (modified) * testsuites/psxtests/psxhdrs/string/strlen.c (modified) * testsuites/psxtests/psxhdrs/string/strncat.c (modified) * testsuites/psxtests/psxhdrs/string/strncmp.c (modified) * testsuites/psxtests/psxhdrs/string/strncpy.c (modified) * testsuites/psxtests/psxhdrs/string/strndup.c (modified) * testsuites/psxtests/psxhdrs/string/strnlen.c (modified) * testsuites/psxtests/psxhdrs/string/strpbrk.c (modified) * testsuites/psxtests/psxhdrs/string/strrchr.c (modified) * testsuites/psxtests/psxhdrs/string/strsignal.c (modified) * testsuites/psxtests/psxhdrs/string/strspn.c (modified) * testsuites/psxtests/psxhdrs/string/strstr.c (modified) * testsuites/psxtests/psxhdrs/string/strtok.c (modified) * testsuites/psxtests/psxhdrs/string/strtok_r.c (modified) * testsuites/psxtests/psxhdrs/string/strxfrm.c (modified) * testsuites/psxtests/psxhdrs/string/strxfrm_l.c (modified) * testsuites/psxtests/psxhdrs/utime/utime.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcapture01/init.c (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/smptests/smpipi01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpmutex02/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschedaffinity01/init.c (modified) * testsuites/smptests/smpschedaffinity02/init.c (modified) * testsuites/smptests/smpschedaffinity03/init.c (modified) * testsuites/smptests/smpschedaffinity04/init.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) * testsuites/smptests/smpschededf04/init.c (modified) * testsuites/smptests/smpschedsem01/init.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler04/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpstrongapa01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/spatomic01/init.c (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcpucounter01/init.c (modified) * testsuites/sptests/spcpuset01/test.c (modified) * testsuites/sptests/speventsystem01/init.c (modified) * testsuites/sptests/speventtransient01/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spglobalcon01/init.cc (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/splinkersets01/init.c (modified) * testsuites/sptests/splinkersets01/items.c (modified) * testsuites/sptests/splinkersets01/sets.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spsem03/init.c (modified) * testsuites/sptests/spstdthreads01/init.c (modified) * testsuites/sptests/spstkalloc02/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) * testsuites/sptests/sptasknopreempt01/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/sptests/sptimecounter04/init.c (modified) * testsuites/sptests/sptimerserver01/init.c (modified) * testsuites/sptests/sptls01/init.c (modified) * testsuites/sptests/sptls03/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) * testsuites/tmtests/tmtimer01/init.c (modified) Canonicalize config.h include Use the following variant which was ... Mon, 13 Apr 2020 17:41:21 GMT Sebastian Huber [ea227af] * cpukit/posix/src/clocksettime.c (modified) * cpukit/score/src/coretodset.c (modified) * testsuites/psxtests/psxclock/init.c (modified) score: Check time of day in _TOD_Set() Close #3949. Mon, 13 Apr 2020 17:29:35 GMT Sebastian Huber [fb07f730] * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/src/coretodhookrun.c (modified) * cpukit/score/src/coretodset.c (modified) * testsuites/sptests/spclock_todhook01/init.c (modified) score: Return status in _TOD_Set() Update #3949. Sun, 05 Apr 2020 07:58:24 GMT Sebastian Huber [d582d0e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/score/src/isrstackareaend.c (deleted) Revert "score: Fix _ISR_Stack_area_end" This reverts commit ... Fri, 03 Apr 2020 07:47:21 GMT Sebastian Huber [8e80876] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/score/src/isrstackareaend.c (added) score: Fix _ISR_Stack_area_end The _ISR_Stack_area_begin and ... Thu, 12 Mar 2020 14:43:17 GMT Sebastian Huber [a6b36334] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iobase64.c (added) * testsuites/sptests/spprintk/init.c (modified) score: Add _IO_Base64() Update #3904. Wed, 26 Feb 2020 09:02:37 GMT Sebastian Huber [fcb11510] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/userextaddset.c (modified) * testsuites/sptests/spextensions01/init.c (modified) score: Fix context switch extensions (SMP) In uniprocessor and SMP ... Tue, 25 Feb 2020 13:43:52 GMT Sebastian Huber [01c97e64] * cpukit/score/src/threadinitialize.c (modified) score: Fix label defined but not used warning Update #3835. Sat, 15 Feb 2020 10:52:00 GMT Sebastian Huber [e50e42b8] * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: _Scheduler_Is_non_preempt_mode_supported() If the ... Sat, 15 Feb 2020 10:09:16 GMT Sebastian Huber [1ada3e55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add _SMP_Need_inter_processor_interrupts() Test for the ... Fri, 14 Feb 2020 12:48:18 GMT Sebastian Huber [ad85c00] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/score/src/wkspaceisunifieddefault.c (added) config: Add _Workspace_Is_unified Move the unified workspace ... Fri, 14 Feb 2020 12:36:30 GMT Sebastian Huber [5180762c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadidledefault.c (added) config: Add _Thread_Idle_body Move the idle thread body ... Fri, 14 Feb 2020 12:26:17 GMT Sebastian Huber [c70d112] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (added) * cpukit/score/src/threadcreateidle.c (modified) config: Add _Thread_Idle_stack_size Move the idle thread stack size ... Fri, 14 Feb 2020 11:58:21 GMT Sebastian Huber [308a2e0f] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/score/src/watchdogtimeslicedefault.c (added) config: Add _Watchdog_Ticks_per_timeslice Move the ticks per ... Thu, 13 Feb 2020 10:37:02 GMT Sebastian Huber [2807d556] * cpukit/score/src/wkspace.c (modified) score: Clean up wkspace.c Remove DEBUG_WORKSPACE support. There ... Thu, 13 Feb 2020 10:34:34 GMT Sebastian Huber [88c40ef8] * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/spwkspace/init.c (modified) score: Remove unused _Workspace_Allocate_aligned() Tue, 10 Dec 2019 10:13:18 GMT Sebastian Huber [d252e20a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/threadallocateunlimited.c (added) * cpukit/score/src/threadinitialize.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Simplify _Thread_Initialize() Allocate new thread queue ... Fri, 03 Jan 2020 06:19:47 GMT Sebastian Huber [fc32904] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Allocate_with_extend() Update #3835. Tue, 10 Dec 2019 10:26:20 GMT Sebastian Huber [dd9e501] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Activate_unlimited() Update #3835. Tue, 10 Dec 2019 10:09:32 GMT Sebastian Huber [8a43adb] * cpukit/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) score: Add _Freechain_Extend() Update #3835. Tue, 10 Dec 2019 09:46:52 GMT Sebastian Huber [36e59b2] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) score: _Objects_Extend_information() Return block index in ... Mon, 16 Dec 2019 14:10:05 GMT Sebastian Huber [8e118f22] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectnamespaceremove.c (modified) score: Inline _Objects_Namespace_remove_u32() This function is ... Mon, 16 Dec 2019 13:50:59 GMT Sebastian Huber [6135747] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectfreestatic.c (added) score: Split up objects free Split up the different objects free ... Tue, 10 Dec 2019 09:41:48 GMT Sebastian Huber [2485156] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatenone.c (added) * cpukit/score/src/objectallocatestatic.c (added) * cpukit/score/src/objectallocateunlimited.c (added) score: Split up objects allocation Split up the different objects ... Tue, 10 Dec 2019 09:04:36 GMT Sebastian Huber [6f3bc0e] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectshrinkinformation.c (modified) score: Add _Objects_Free_objects_block() This is a preparation to ... Mon, 09 Dec 2019 15:03:11 GMT Sebastian Huber [32991495] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spstkalloc/init.c (modified) score: Statically allocate idle/MPCI stacks Place idle and MPCI ... Mon, 09 Dec 2019 13:48:34 GMT Sebastian Huber [01d5944] * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Move thread stack allocation Move thread stack allocation to ... Mon, 09 Dec 2019 13:33:06 GMT Sebastian Huber [4c9deb6c] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add _Stack_Extend_size() Update #3835. Mon, 09 Dec 2019 12:57:51 GMT Sebastian Huber [a08dcb2] * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add Thread_Configuration Add the Thread_Configuration ... Mon, 16 Dec 2019 13:32:47 GMT Sebastian Huber [00c7ad4] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/score/src/stackallocator.c (added) score: Split stack allocator configuration This allows the linker ... Mon, 09 Dec 2019 09:12:14 GMT Sebastian Huber [f4dbf37d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/src/configstackspacesize.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/tlsallocsize.c (added) * cpukit/score/src/wkspace.c (modified) score: Simplify TLS area allocation Use the stack area to allocate ... Sat, 07 Dec 2019 15:50:35 GMT Sebastian Huber [fc398fd] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Simplify FP context allocation Use the stack area to ... Sat, 07 Dec 2019 15:30:50 GMT Sebastian Huber [0e1ac917] * cpukit/score/src/threadcreateidle.c (modified) score: Remove _Stack_Ensure_minimum() call This call is superfluous ... Sat, 07 Dec 2019 15:28:21 GMT Sebastian Huber [0bde56b] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadstackfree.c (modified) score: Simplify thread stack free Update #3835. Sat, 07 Dec 2019 15:00:58 GMT Sebastian Huber [a0211fc9] * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadstackallocate.c (modified) score: Simplify thread stack allocation Remove superfluous ... Tue, 04 Feb 2020 14:26:31 GMT Sebastian Huber [2d07ce6] * bsps/shared/start/bootcard.c (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memorydirtyfreeareas.c (added) * testsuites/sptests/sp54/init.c (modified) config: Add CONFIGURE_DIRTY_MEMORY Replace the BSP_DIRTY_MEMORY BSP ... Tue, 04 Feb 2020 12:56:41 GMT Sebastian Huber [8ecbc38] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * cpukit/score/src/memoryzerobeforeuse.c (added) * cpukit/score/src/memoryzerofreeareas.c (added) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/sp54/init.c (modified) sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY Use a dedicate system ... Fri, 13 Dec 2019 05:18:36 GMT Sebastian Huber [eea21eac] * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/imx/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/bspgetworkarea.c (modified) * bsps/powerpc/shared/start/sbrk.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/shared/start/bootcard.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/smptests/smpfatal09/init.c (modified) * testsuites/sptests/spfatal09/init.c (modified) * testsuites/sptests/spfatal12/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) bsps: Rework work area initialization The work area initialization ... Fri, 13 Dec 2019 05:25:03 GMT Sebastian Huber [c477d927] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/memory.h (modified) * cpukit/score/src/memoryfill.c (added) score: Add _Memory_Fill() Update #3838. Tue, 10 Dec 2019 19:03:53 GMT Sebastian Huber [1cb9257] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/score/memory.h (added) * cpukit/score/src/memoryallocate.c (added) score: Add Memory Handler Update #3838. Sat, 01 Feb 2020 14:42:27 GMT Sebastian Huber [9e4f21b9] * cpukit/score/src/wkspace.c (modified) score: Optimize per-processor data placement Only align ... Thu, 02 Jan 2020 10:30:33 GMT Sebastian Huber [f74e806d] * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadmp.c (modified) mpci: Fix blocking proxy status Remove THREAD_STATUS_PROXY_BLOCKING ... Thu, 02 Jan 2020 08:17:03 GMT Sebastian Huber [a320aedd] * cpukit/score/src/objectinitializeinformation.c (modified) score: Fix objects node initialization The objects node is ... Thu, 12 Dec 2019 07:53:32 GMT Sebastian Huber [78211376] * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal08/init.c (deleted) * testsuites/sptests/spfatal08/spfatal08.doc (deleted) * testsuites/sptests/spfatal08/spfatal08.scn (deleted) score: Remove _Workspace_Allocate_or_fatal_error() This function is ... Thu, 12 Dec 2019 07:50:40 GMT Sebastian Huber [3fba9de2] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/objectmp.c (modified) config: Statically allocate MP object controls Update #3735. Thu, 12 Dec 2019 07:43:06 GMT Sebastian Huber [1d9f509e] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/threadmp.c (modified) config: Statically allocate MP thread proxies Update #3735. Thu, 12 Dec 2019 06:11:54 GMT Sebastian Huber [24f8915] * bsps/include/shm_driver.h (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (added) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/spsize/size.c (modified) config: Add _MPCI_Configuration Replace the user MPCI configuration ... Tue, 12 Nov 2019 15:33:41 GMT Joel Sherrill [08bd7d3] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/src/coretodhookdata.c (added) * cpukit/score/src/coretodhookregister.c (added) * cpukit/score/src/coretodhookrun.c (added) * cpukit/score/src/coretodhookunregister.c (added) * cpukit/score/src/coretodset.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclock_todhook01/init.c (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.doc (added) * testsuites/sptests/spclock_todhook01/spclock_todhook01.scn (added) Add TOD Hooks to allow BSP to take action when TOD is set Two use ... Thu, 05 Dec 2019 14:14:51 GMT Sebastian Huber [5ae6112] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/userextdata.h (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextiterate.c (modified) userext: Simplify configuration Avoid the use of the workspace and ... Mon, 04 Nov 2019 08:34:21 GMT Sebastian Huber [94584f17] * cpukit/score/src/heap.c (modified) heap: Simplify _Heap_Block_allocate() Determine the next block only ... Fri, 25 Oct 2019 13:19:01 GMT sebastian.huber [3859cd63] * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapimpl.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapfree.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) rtems-5: Improve heap fatal error information Update #3806. Tue, 01 Oct 2019 11:48:27 GMT Sebastian Huber [8d989c5] * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Install timecounter according to quality This makes it ... Tue, 01 Oct 2019 11:04:29 GMT Sebastian Huber [47e5c1d] * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove strange timecounter init step The double call of the ... Tue, 01 Oct 2019 10:41:47 GMT Sebastian Huber [2763f53] * cpukit/include/sys/timetc.h (modified) * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove superfluous timecounter members Mon, 20 May 2019 07:15:36 GMT Sebastian Huber [5fa893e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpunicastaction.c (added) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Add _SMP_Unicast_action() Mon, 20 May 2019 07:06:48 GMT Sebastian Huber [41cddcc] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _Per_CPU_Wait_for_job() Sun, 28 Apr 2019 12:31:10 GMT Sebastian Huber [577293f0] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Add _SMP_Synchronize() Sun, 28 Apr 2019 12:15:45 GMT Sebastian Huber [bf867c55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Remove unused SMP_MESSAGE_TEST All uses were replaced by ...
