@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@6365f81
04/22/96 16:46:00 |
Joel Sherrill |
made initialization routine a regular subroutine
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@adf98bd
02/21/96 14:44:11 |
Joel Sherrill |
Removed the internal thread objects and dispersed its contents to
the …
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@8d0b7d96
12/01/95 22:03:55 |
Joel Sherrill |
Insert mode argument to _Watchdog_Insert removed. Now are watchdog …
4.104.114.84.95
@ed32907
12/01/95 21:07:48 |
Joel Sherrill |
Added support for new synchronization algorithm. Specifically, the …
4.104.114.84.95
@9700578
10/30/95 21:54:45 |
Joel Sherrill |
SPARC port passes all tests
4.104.114.84.95
@11290355
09/29/95 17:19:16 |
Joel Sherrill |
all targets compile .. tony's patches in place
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@91a3554d
09/19/95 21:43:12 |
Joel Sherrill |
Modifications from Tony Bennett accepted to return aligned block.
4.104.114.84.95
@3652ad35
09/19/95 14:53:29 |
Joel Sherrill |
Minor bug fixes to get all targets compilable and running. The
single …
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@7f6a24ab
08/28/95 15:30:29 |
Joel Sherrill |
Added unused priority ceiling parameter to rtems_semaphore_create.
4.104.114.84.95
@5250ff39
08/23/95 21:06:31 |
Joel Sherrill |
Moved _Thread_Information -> _RTEMS_tasks_Information.
Added a table …
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@6b45e470
08/22/95 16:44:49 |
Joel Sherrill |
Merged PowerPC port as submitted by Andy Bray of I-CUBED, Ltd …
4.104.114.84.95
@95fbca1
08/18/95 21:41:27 |
Joel Sherrill |
+ Added object type field to object id.
+ Added name pointer to …
4.104.114.84.95
@45819022
08/16/95 19:42:41 |
Joel Sherrill |
bug fixes to make macro implementations work
4.104.114.84.95
@88d594a
05/24/95 21:39:42 |
Joel Sherrill |
Fully tested on all in-house targets
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
