@4ccb79bc
03/02/15 11:23:20 |
Sebastian Huber |
score: Enable SMP barriers for all configurations
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@8d6e6eeb
02/17/15 09:00:43 |
Sebastian Huber |
score: Fix FP context restore via _Thread_Handler
After a context …
4.115
@50a50313
01/21/15 14:22:46 |
Sebastian Huber |
score: Delete superfluous Heap_Statistics::instance
This value …
4.115
@2a4f9d7
12/23/14 07:28:24 |
Sebastian Huber |
smp: Add and use _SMP_Should_start_processor()
4.115
@864d3475
12/17/14 14:11:00 |
Sebastian Huber |
smp: Fix timeout for MrsP semaphores
The previous timeout handling …
4.115
@d006b46d
11/28/14 10:53:55 |
Sebastian Huber |
score: Add heap statistics
Add lifetime bytes allocated and freed …
4.115
@2c3c657
11/27/14 12:25:22 |
Sebastian Huber |
score: Return heap stats via _Heap_Get_information
Print out heap …
4.115
@5bd822a7
11/26/14 10:51:34 |
Sebastian Huber |
smp: Fix scheduler helping protocol
Ensure that scheduler nodes in …
4.115
@79569ae
11/26/14 09:00:13 |
Sebastian Huber |
smp: Fix scheduler helping protocol assertions
4.115
@c562d0c
11/19/14 20:47:57 |
josh.oguin |
objectimpl.h: Add _Assert() to _Objects_Invalidate_Id()
CodeSonar? …
4.115
@fbafb8f2
11/19/14 20:46:43 |
josh.oguin |
chainimpl.h: Add _Assert() to _Chain_Initialize_empty()
CodeSonar? …
4.115
@26f4cdd
11/24/14 07:35:45 |
Sebastian Huber |
_Scheduler_FIXME_thread_priority_queues_are_broken
Delete this …
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
New test case for …
4.115
@89be4e7
11/23/14 00:25:12 |
Santosh Vattam |
rtems/score/object.h: Correct types on _Objects_Build_id
close 1423
4.115
@b2db1f5c
11/20/14 14:00:29 |
dolezj21 |
cpukit: basedefs: macro for packed attribute
4.115
@f9b19d9
09/19/14 19:04:49 |
Jennifer Averett |
score: Move is_executing_on_a_core from cpuusagereport.c to threadimpl.h
4.115
@134a181
09/08/14 14:46:43 |
Jennifer Averett |
score: Add capture data to tcb.
4.115
@8237b2d
10/15/14 14:15:07 |
Joel Sherrill |
rtems/score/object.h: Include <rtems/score/cpu.h> to honor 16-bit Ids
4.115
@a38ced2
10/10/14 07:09:19 |
Sebastian Huber |
score: Rework global construction
Ensure that the global construction …
4.115
@dadd7cd
09/22/14 10:01:49 |
Sebastian Huber |
score: Delete Thread_Wait_information::Block2n
This field is no …
4.115
@80ad7090
09/08/14 12:13:31 |
pisa |
score: More strict RTEMS_DEQUALIFY implementation.
This …
4.115
@a72f16e
09/05/14 06:32:28 |
Sebastian Huber |
score: Add RTEMS_DECONST|DEVOLATILE|DEQUALIFY()
4.115
@3bff410
09/02/14 23:07:36 |
Joel Sherrill |
rtems/score/assert.h: Rework to allow use of NDEBUG
4.115
@f553c6e
08/22/14 14:39:47 |
Sebastian Huber |
rtems: Inline rtems_clock_get_ticks_since_boot()
Update documentation.
4.115
@ddbc3f8d
07/11/14 14:37:56 |
cederman |
score: Add SMP support to the cache manager
Adds functions that …
4.115
@aed38189
07/08/14 09:35:14 |
cederman |
score: Rename SMP broadcast message function
Change message type to …
4.115
@a68cc1b
07/08/14 09:33:55 |
cederman |
score: Add function to send a SMP message to a set of CPUs
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@4cd55724
07/26/14 10:52:22 |
Sebastian Huber |
Delete unused *_Is_null() functions
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@9113798c
07/23/14 20:39:17 |
Joel Sherrill |
todimpl.h: Add missing Doxygen
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@0ea6d07
07/09/14 18:22:28 |
Joel Sherrill |
Use Shared Method for Thread Unblock Cleanup
When a thread is removed …
4.115
@3250664
07/15/14 17:37:36 |
Joel Sherrill |
Thread Queue: Merge discipline subroutines into main methods
There …
4.115
@ed7a028
07/07/14 19:26:13 |
Joel Sherrill |
Thread Queue Priority Discipline Reimplemented with RBTree
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@7e119990
07/12/14 19:22:21 |
Sebastian Huber |
rbtree: Delete unused functions
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@333f9426
07/10/14 10:49:43 |
Sebastian Huber |
score: Fix assertions
4.115
@c6048ee
07/09/14 09:20:23 |
Sebastian Huber |
score: _Scheduler_Thread_get_own_node()
Provide this function also …
4.115
@5c3d250
07/04/14 12:34:23 |
Sebastian Huber |
score: Implement scheduler helping protocol
The following scheduler …
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@ac532f3
07/04/14 11:40:10 |
Sebastian Huber |
score: Add _Scheduler_Help()
Manage the help state of threads with …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@19e41767
07/08/14 08:38:19 |
Sebastian Huber |
score: Simplify SMP processor allocation
Avoid copy and paste and set …
4.115
@835b88b
07/07/14 14:41:03 |
Sebastian Huber |
score: Rename _Scheduler_SMP_Update_heir()
Rename and move …
4.115
@5c632c4
07/07/14 11:31:07 |
Sebastian Huber |
score: Fix warning
4.115
@46cd17a
07/04/14 12:32:35 |
Sebastian Huber |
score: Fix MrsP resource root change
Use the root of the owner for …
4.115
@bec4730
06/30/14 10:55:50 |
Sebastian Huber |
score: Add PER_CPU_OFFSET_EXECUTING
Add PER_CPU_OFFSET_HEIR. Move …
4.115
@89f8eab5
05/07/14 12:55:37 |
Sebastian Huber |
score: Workaround for GCC 4.9 for atomic ops
The GCC 4.9 ships its …
4.115
@8f0c7a46
06/10/14 14:13:37 |
Sebastian Huber |
score: Decouple thread and scheduler nodes on SMP
Add a chain node to …
4.115
@647b95d
06/10/14 14:32:12 |
Sebastian Huber |
score: Use chain nodes for ready queue support
This reduces the API …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@92635cb
06/03/14 14:27:53 |
Sebastian Huber |
score: Remove scheduler parameter from most ops
Remove the scheduler …
4.115
@bd1431a
06/20/14 10:05:23 |
Sebastian Huber |
score: Use default get/set affinity operation
Add and use …
4.115
@2ba2743
06/12/14 12:50:33 |
Sebastian Huber |
score: Delete _Thread_Set_transient()
4.115
@a80c3b6
06/10/14 14:11:58 |
Sebastian Huber |
score: _Scheduler_priority_Get_scheduler_info()
Delete …
4.115
@701dd96f
06/12/14 12:37:57 |
Sebastian Huber |
score: PR2181: Add _Thread_Yield()
The _Scheduler_Yield() was called …
4.115
@4639002
06/12/14 07:17:39 |
Sebastian Huber |
score: Make functions inline
These functions are used only via the …
4.115
@82df6f3
06/12/14 07:06:53 |
Sebastian Huber |
score: Move NULL pointer check to order function
This helps to avoid …
4.115
@d9b54da
06/12/14 06:48:02 |
Sebastian Huber |
score: Format
4.115
@6f4993e
06/12/14 06:43:25 |
Sebastian Huber |
score: Add missing inline
4.115
@238629f
05/19/14 20:26:55 |
Joel Sherrill |
Add SMP Priority Scheduler with Affinity
This scheduler attempts to …
4.115
@e473f3c
06/10/14 12:30:47 |
Sebastian Huber |
score: Fix MrsP root node update
Set the new root after the resource …
4.115
@9a1bab2
06/05/14 09:19:32 |
Sebastian Huber |
score: _Per_CPU_State_wait_for_non_initial_state()
Replace …
4.115
@be3c257
06/05/14 09:17:26 |
Sebastian Huber |
score: Avoid NULL pointer access
Check that the executing thread is …
4.115
@c952ecab
06/05/14 08:28:08 |
Sebastian Huber |
score: Delete SMP_FATAL_SHUTDOWN_EARLY
Sort enum lexicographically.
4.115
@4d1f500
06/03/14 13:58:30 |
Sebastian Huber |
score: Rename _Scheduler_Update()
Rename _Scheduler_Update() to …
4.115
@8e467384
06/03/14 08:29:30 |
Sebastian Huber |
score: Replace _Scheduler_Allocate/Free()
Replace …
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@3045738
05/28/14 11:38:48 |
Sebastian Huber |
score: Add resource node to thread control block
4.115
@6c7caa1a
05/28/14 11:37:54 |
Sebastian Huber |
score: Add and use _Thread_Owns_resources()
4.115
@3e201139
05/23/14 08:00:33 |
Sebastian Huber |
score: Add Resource Handler
A resource is something that has at most …
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@a92c488
05/28/14 15:56:45 |
Sebastian Huber |
score: _Scheduler_Get_affinity()
Drop scheduler parameter. Coding style.
4.115
@e91ab8c
05/19/14 20:25:15 |
Joel Sherrill |
cpusetimpl.h: Add _CPU_set_Set() and improve Doxygen
4.115
@8e7db68c
04/14/14 21:05:04 |
Joel Sherrill |
Minor conditionals to enable building Scheduler Simulator on GNU/Linux …
4.115
@69c3f076
05/28/14 21:53:58 |
Joel Sherrill |
rtems/score/thread*.h: Really correct spelling error
4.115
@27caaa6
05/28/14 21:42:33 |
Joel Sherrill |
rtems/score/thread*.h: TERMINTING to TERMINATING
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@b3049a1d
05/23/14 13:51:51 |
Sebastian Huber |
score: Use _SMP_Fatal()
4.115
@0af322c
05/23/14 12:27:12 |
Daniel Hellstrom |
SMP: make IPI fatal code unique
The same smp fatal code is used in …
4.115
@1bf0666
05/21/14 20:08:23 |
Joel Sherrill |
schedulersmpimpl.h: Fix spacing
4.115
@c8e83288
05/21/14 08:29:59 |
Sebastian Huber |
score: Add and use _Scheduler_Get_index_by_id()
4.115
@4ddc3b5
05/21/14 08:29:36 |
Sebastian Huber |
score: Add const qualifier
4.115
@40f2eafe
05/21/14 06:30:25 |
Sebastian Huber |
score: Simplify _Scheduler_Set()
4.115
@2d96533
05/20/14 06:06:43 |
Sebastian Huber |
score: SMP scheduler support documentation
4.115
@1ac0b083
05/16/14 08:55:01 |
Sebastian Huber |
score: Simplify SMP scheduler support
4.115
@b532bb2c
05/16/14 08:54:48 |
Sebastian Huber |
score: Fix state diagram
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@b4bdbcf
05/15/14 07:41:20 |
Sebastian Huber |
score: Make _Thread_queue_Requeue() static
This function is only used …
4.115
