@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
@f570b071
04/01/14 08:20:01 |
Sebastian Huber |
score: Rename Priority_bit_map_Control
Rename …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@91e7b0c
03/27/14 08:04:47 |
Sebastian Huber |
score: PR2172: _Thread_queue_Extract()
Add …
4.115
@600bb68f
03/27/14 07:30:51 |
Sebastian Huber |
score: _Thread_queue_Extract_with_proxy()
Drop the return status, …
4.115
@03e89287
03/27/14 13:46:31 |
Sebastian Huber |
score: Delete CORE_mutex_Control::lock
The holder field is enough to …
4.115
@b1ce1161
03/27/14 13:29:00 |
Sebastian Huber |
score: Delete CORE_mutex_Control::holder_id
We can use the holder …
4.115
@cb8d3e7
03/27/14 07:04:10 |
Sebastian Huber |
score: Delete CORE_mutex_Control::blocked_count
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@34684573
03/27/14 12:38:04 |
Sebastian Huber |
score: Use thread life protection for API mutexes
This prevents that …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@8690b53
03/25/14 09:53:28 |
Sebastian Huber |
score: Add parameter to _Thread_Restart()
The executing thread will …
4.115
@391ad3e
03/17/14 14:03:22 |
Sebastian Huber |
score: Fix thread restart extensions context
Run the thread restart …
4.115
@dcd5e26
03/18/14 15:11:03 |
Sebastian Huber |
score: Move _Thread_Reset() and make static
4.115
@5c731a83
03/17/14 09:12:14 |
Sebastian Huber |
score: Use thread action for thread restart
The thread restart is now …
4.115
@8061f56
03/14/14 10:55:28 |
Sebastian Huber |
score: Delete post-switch API extensions
Use thread post-switch …
4.115
@0dd732d
03/14/14 10:50:58 |
Sebastian Huber |
score: Add thread actions
Thread actions are the building block for …
4.115
@a5ac9da
03/14/14 09:17:34 |
Sebastian Huber |
score: Add and use thread get/set CPU functions
4.115
@c2225d7
03/28/14 08:24:28 |
Sebastian Huber |
score: Add _Scheduler_Change_priority_if_higher()
Add …
4.115
@298d0fd
03/24/14 06:44:00 |
Sebastian Huber |
score: Add _Scheduler_Highest_priority_of_two()
Use inline functions …
4.115
@79e2d9b
03/06/14 10:11:59 |
Sebastian Huber |
score: Add per-CPU state function
Add …
4.115
@1fac361
03/24/14 07:51:37 |
Sebastian Huber |
score: PR2174: Add workaround
Add …
4.115
@9b44339c
03/24/14 06:53:45 |
Sebastian Huber |
score: Delete _Watchdog_Report()
Delete _Watchdog_Report_chain(). …
4.115
@2a713e3
03/24/14 14:57:29 |
Sebastian Huber |
score: _Heap_Protection_set_delayed_free_fraction
Add and use …
4.115
@72d8db9c
03/24/14 06:53:34 |
Sebastian Huber |
score: Delete _Thread_Internal_free()
4.115
@b3b9600
03/20/14 07:16:20 |
Sebastian Huber |
score: Delete unused STATES_ALL_SET
4.115
@3b5e7dc
03/19/14 09:40:47 |
Sebastian Huber |
score: Set name before object is made public
4.115
@a5385b1
03/20/14 08:22:00 |
Christian.Mauderer |
score: Unify pthread and gxx_wrapper once and move to score.
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@f31311aa
03/18/14 12:22:54 |
Sebastian Huber |
score: Add _Assert_Not_reached()
4.115
@72f4b98b
03/18/14 11:11:37 |
Sebastian Huber |
score: Add _Debug_Is_owner_of_allocator()
4.115
@a3dd225b
03/18/14 10:56:42 |
Sebastian Huber |
score: Delete _Assert_Owner_of_giant()
Add …
4.115
@ff25926
03/18/14 10:49:38 |
Sebastian Huber |
score: Delete _Assert_Thread_dispatching_repressed
Add …
4.115
@51f823c9
03/18/14 07:28:14 |
Sebastian Huber |
posix: Use interal mutex for once implementation
Enable …
4.115
@fa3993d9
03/18/14 09:56:17 |
Sebastian Huber |
score: Make _ISR_Enable_without_giant() available
Make …
4.115
@d6da1b1
03/14/14 12:55:00 |
Sebastian Huber |
score: Use only next field for chain on/off
It is sufficient to use …
4.115
@2a37016
03/13/14 14:21:09 |
cederman |
score: Add include for uintptr_t definition.
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@f980561
03/10/14 09:04:09 |
Sebastian Huber |
score: Add per-CPU profiling
Add per-CPU profiling stats API. …
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@e6c87f7
03/04/14 21:54:12 |
Joel Sherrill |
POSIX keys now enabled in all configurations.
Formerly POSIX keys …
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@9db8705
02/06/14 18:42:24 |
Jennifer Averett |
score: Add cpuset support to Score.
This new Score Handler provides a …
4.115
@3ca84d0c
03/06/14 09:53:17 |
Sebastian Huber |
score: Fix per-CPU state documentation
4.115
@825cb1f
03/04/14 12:02:18 |
Sebastian Huber |
score: Delete _Thread_Dispatch_set_disable_level()
This function was …
4.115
@8b50a55
03/03/14 08:09:24 |
Sebastian Huber |
score: Add _Atomic_Fence()
4.115
@ba25cc2
02/19/14 10:21:34 |
Sebastian Huber |
score: Add and use _Giant_Drop()
New test smptests/smpfatal03.
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@8a65a960
02/18/14 12:36:35 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Inline …
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@6ca4f6a
02/17/14 13:56:51 |
Sebastian Huber |
score: Add and use <rtems/score/smpimpl.h>
Collect SMP implementation …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@2afe065
02/17/14 13:12:21 |
Sebastian Huber |
score: Remove ASM guard
4.115
@2cb95b5f
02/17/14 12:58:01 |
Sebastian Huber |
score: Rename RTEMS_BSP_SMP_SHUTDOWN
Rename RTEMS_BSP_SMP_SHUTDOWN in …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@8a6de83
02/17/14 09:10:27 |
Sebastian Huber |
score: Move _SMP_Request_other_cores_to_shutdown()
Move …
4.115
@38ee758
02/17/14 08:58:43 |
Sebastian Huber |
score: Disable ISR in _Internal_error_Occurred()
Disable interrupts …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@ad7292f
02/14/14 11:57:53 |
Sebastian Huber |
score: Add SMP barrier
4.115
@0344ce03
02/13/14 14:43:03 |
Sebastian Huber |
score: Use atomic API for SMP lock
Use a ticket lock implementation …
4.115
@945853b7
02/13/14 14:38:52 |
Sebastian Huber |
score: Add Atomic_Uint
4.115
@cd2c655
02/13/14 13:28:50 |
Sebastian Huber |
score: Fix warnings, C++ compatibility, fix typos
4.115
@01794eb
02/07/14 07:55:02 |
Sebastian Huber |
score: Format _Thread_Get_maximum_internal_threads
4.115
@558cc8d
02/05/14 14:41:00 |
Sebastian Huber |
score: _CPU_Context_switch_to_first_task_smp()
Delete …
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@16a41cc
01/29/14 08:29:39 |
Sebastian Huber |
score: Add _Thread_Get_maximum_internal_threads()
4.115
@a49bc35
01/28/14 10:49:57 |
Sebastian Huber |
score: Add _Heap_Size_with_overhead()
4.115
@a850d04
01/28/14 10:32:35 |
Sebastian Huber |
score: Add _Workspace_Allocate_aligned()
4.115
@2d1bdc8
12/24/13 05:38:42 |
Chris Johns |
cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. …
4.115
@e99b0e2
11/21/13 12:43:07 |
Sebastian Huber |
score: Use local variables for consistency
4.115
@4ea97d24
11/19/13 15:21:54 |
Sebastian Huber |
score/rbtree: Remove "unprotected" from API
4.115
@833dd90
11/19/13 15:09:39 |
Sebastian Huber |
score/rbtree: Delete protected operations
The user of the red-black …
4.115
@3a7628e8
11/15/13 14:38:52 |
Sebastian Huber |
score: Objects_Information::extract visibility
This filed is only …
4.115
@b68cef17
10/23/13 11:29:17 |
Sebastian Huber |
score: New state STATES_WAITING_FOR_BSD_WAKEUP
This state is …
4.115
@ecd82b6d
09/22/13 14:40:44 |
Joel Sherrill |
basedefs.h: Add RTEMS_COMPILER_UNUSED_ATTRIBUTE.
4.115
@3bac8a4c
09/03/13 09:04:33 |
Sebastian Huber |
score: Use void * for some atomic pointer ops
4.115
@29f7d317
09/02/13 13:08:05 |
Sebastian Huber |
score: Use unsigned long for atomic integers
Use unsigned long …
4.115
@bf30999
08/23/13 14:15:50 |
Sebastian Huber |
smp: Add and use _Assert_Owner_of_giant()
Add and use …
4.115
@03aad60
08/28/13 09:27:26 |
Sebastian Huber |
score: Atomic flag changes
Delete _Atomic_Init_flag(). Change …
4.115
@4288f9fd
08/27/13 13:10:50 |
Sebastian Huber |
score: Use static inline directly
This file uses already C11 …
4.115
@697d31e
08/25/13 13:45:41 |
wei.a.yang |
add atomic init function
4.115
@23de794d
08/26/13 12:27:52 |
Sebastian Huber |
score: Add and use CHAIN_INITIALIZER_ONE_NODE().
Add and use …
4.115
@db0e05ff
08/23/13 09:57:11 |
Sebastian Huber |
score: Delete unused function parameter
4.115
@215ccce
08/23/13 09:52:01 |
Sebastian Huber |
score: PR2140: _Thread_queue_Extract()
Return if the executing …
4.115
@07332ae
08/22/13 13:20:06 |
Sebastian Huber |
score: _Thread_queue_Enqueue_with_handler()
Add thread parameter to …
4.115
@269dd12
08/20/13 13:14:13 |
Sebastian Huber |
smp: Documentation
4.115
@2cfbf23a
08/20/13 13:07:33 |
Sebastian Huber |
smp: Delete RTEMS_BSP_SMP_SIGNAL_TO_SELF
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@48c4a55
08/13/13 11:13:25 |
Sebastian Huber |
smp: Generalize Simple SMP scheduler
4.115
@aea4a91
08/08/13 09:49:15 |
Sebastian Huber |
smp: Optimize Simple SMP scheduler
Add Thread_Control::is_in_the_air …
4.115
@fc2ad63
08/12/13 08:59:40 |
Sebastian Huber |
smp: _Scheduler_simple_smp_Allocate_processor()
Rename …
4.115
@6ba15488
08/12/13 10:34:27 |
Sebastian Huber |
smp: Rename _Scheduler_simple_smp_Start_idle()
Rename …
4.115
