@d0a97f2
07/18/13 09:04:23 |
Sebastian Huber |
score: Move ISR catch support functions
Delete now unused file …
4.115
@45b572f
07/18/13 09:03:10 |
Sebastian Huber |
score: Move ISR level content to single file
4.115
@95e09afa
07/17/13 13:53:17 |
Sebastian Huber |
score: Avoid direct usage of _Thread_Executing
Pass the executing …
4.115
@ac15b07
07/17/13 13:20:03 |
Sebastian Huber |
score: Convert to inline function
4.115
@20e239c2
07/17/13 12:23:14 |
Sebastian Huber |
score: Create mutex implementation header
Move implementation …
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@a7ce0ce
06/13/13 08:34:12 |
Sebastian Huber |
smp: Delete RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY
The thread …
4.115
@9c9b62d8
07/17/13 09:44:55 |
Sebastian Huber |
score: Changes due to Newlib DYNAMIC_REENT
Delete …
4.115
@f74d9496
07/17/13 09:03:02 |
Sebastian Huber |
score: Add _Thread_Get_executing()
4.115
@a04182c
07/15/13 15:31:14 |
wei.a.yang |
clean up old atomic related files
4.115
@34229d5
07/15/13 15:31:09 |
wei.a.yang |
A generic atomic implementation for smp architectures
4.115
@1180099
07/15/13 15:31:08 |
wei.a.yang |
New atomic API definition based on C11 atomic
4.115
@d0d357ed
06/25/13 10:09:50 |
Sebastian Huber |
heap: Add _Heap_Greedy_allocate_all_except_largest
Add …
4.115
@4f1da72
06/21/13 07:16:19 |
Sebastian Huber |
score: _Heap_Protection_free_all_delayed_blocks()
Add and use …
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@961669d
06/14/13 13:30:37 |
Sebastian Huber |
documentation: Fix Doxygen comments
4.115
@a936aa49
06/06/13 13:41:00 |
Sebastian Huber |
scheduler: New simple SMP scheduler implementation
The new Simple SMP …
4.115
@a344308
06/06/13 13:32:22 |
Sebastian Huber |
scheduler: Add and use _Scheduler_default_Tick()
Delete …
4.115
@6eba7c85
06/10/13 14:15:46 |
Sebastian Huber |
scheduler: Specify thread of yield operation
The yielding thread of …
4.115
@1ccb64e1
06/06/13 13:28:41 |
Sebastian Huber |
scheduler: Add start idle thread operation
Add and use …
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@a8ef3bf0
06/11/13 07:29:45 |
Sebastian Huber |
smp: Add and use _Per_CPU_Lock_acquire()
Add and use …
4.115
@f70526a7
06/11/13 07:26:30 |
Sebastian Huber |
score: Avoid cyclic include dependency
4.115
@1270440
06/11/13 07:23:35 |
Sebastian Huber |
score: Add missing include
4.115
@3ccce23
06/10/13 09:12:39 |
Sebastian Huber |
score: Always provide <rtems/score/smplock.h>
4.115
@4fc370e
06/05/13 10:08:23 |
Sebastian Huber |
score: Move thread dispatch content to new file
Move thread dispatch …
4.115
@4f5baff
06/05/13 15:13:14 |
Sebastian Huber |
score: Simplify _CORE_mutex_Seize_interrupt_try*
4.115
@e358088
05/28/13 08:54:46 |
Sebastian Huber |
smp: New SMP lock API
Move the SMP lock implementation to the CPU …
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@2f6108f9
05/28/13 08:58:19 |
Sebastian Huber |
smp: Simplify SMP initialization sequence
Delete bsp_smp_wait_for(). …
4.115
@10643e9
05/13/13 13:44:02 |
Sebastian Huber |
smp: Make CPU_ALLOCATE_INTERRUPT_STACK optional
4.115
@f6db560
04/23/13 16:34:15 |
wei.a.yang |
Implement a generic atomic ops for all UP mode architectures with …
4.115
@91de38f8
02/14/13 16:27:15 |
Ralf Corsepius |
Include <stdint.h>
4.115
@68f36d14
01/27/13 13:02:50 |
Sebastian Huber |
score: Add and use rtems_assert_context
4.115
@2f0a0936
01/25/13 15:55:25 |
wei.a.yang |
score: atomic support for RTEMS. Generic atomic operations API definition.
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@b10825c
01/10/13 19:29:41 |
Joel Sherrill |
cpukit: Add EOL on files missing EOL at EOF
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@a1f9934a
01/04/13 15:01:21 |
matkallada |
score: Doxygen Clean Up Task #3
4.115
@0ca61727
12/22/12 16:58:50 |
Sebastian Huber |
score: Add const qualifier
4.115
@53afcfd2
12/22/12 16:57:07 |
Sebastian Huber |
score: Do not inline _RBTree_Find_unprotected()
This function is to …
4.115
@1dbbc0c
12/29/12 16:27:48 |
matkallada |
score: Doxygen Clean Up Task #1
4.115
@319cb20
12/29/12 00:04:01 |
matkallada |
score: Doxygen Clean Up Task #2
4.115
@fe1dc22
12/21/12 09:17:34 |
Sebastian Huber |
score: Add _Objects_Active_count()
4.115
@cbd07e4
12/21/12 08:50:15 |
Sebastian Huber |
score: Add rtems_chain_node_count_unprotected()
4.115
@d0b9295f
12/14/12 09:17:04 |
Sebastian Huber |
Fix spelling
4.115
@04b5d17
11/28/12 09:45:38 |
Sebastian Huber |
score: Add API extensions post switch list
Move post switch hook from …
4.115
@5a58b1e
12/01/12 14:53:45 |
daniel.georgiev95 |
score misc: Score misc: Clean up Doxygen #11 (GCI 2012)
This patch is …
4.115
@f839bf5a
12/01/12 14:47:07 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #10 (GCI 2012)
This patch is …
4.115
@e0f91da
11/30/12 21:34:17 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #9 (GCI 2012)
This patch is …
4.115
@8396c18e
11/30/12 02:01:26 |
matkallada |
Score misc: Clean up Doxygen #8 (GCI 2012)
This patch is a task …
4.115
@f2f63d1
11/29/12 23:14:28 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #7 (GCI 2012)
This patch …
4.115
@1b475860
11/29/12 19:39:17 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #6 (GCI 2012)
This patch is …
4.115
@e655f7e
11/29/12 18:39:19 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #5
4.115
@f8ac52f2
11/29/12 14:07:12 |
Sebastian Huber |
score: Documentation
4.115
@bf54252
11/28/12 20:14:50 |
deviennealexandre |
Score misc: Clean up Doxygen #4 (GCI 2012)
This patch is a task from …
4.115
@355ee7d
11/28/12 19:57:31 |
alexivanov97 |
score misc: Clean up Doxygen #3 (GCI 2012)
4.115
@d4d7899
11/28/12 19:31:53 |
Christopher Kerl |
score misc: Clean up Doxygen #2 (GCI 2012)
4.115
@f7f1d77
11/28/12 14:11:31 |
alexivanov97 |
score misc: Clean up Doxygen (GCI 2012)
This patch is a task from GCI …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@f1738ed
11/04/12 20:04:39 |
Sebastian Huber |
score: PR1607: Add and use CPU_SIZEOF_POINTER
Add and use new CPU …
4.115
@74d22fd1
11/22/12 12:03:09 |
Sebastian Huber |
score: Inline _API_extensions_Run_postswitch()
The …
4.115
@32b2c83
11/22/12 14:00:21 |
Sebastian Huber |
score: Inline _User_extensions_Thread_switch()
The …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
This file contains the …
4.115
@1906a36
11/18/12 18:51:10 |
Sebastian Huber |
score: Change _Internal_error_Occurred()
Call the fatal handlers of …
4.115
@e5a2249a
11/18/12 18:19:18 |
Sebastian Huber |
score: Delete nest level from internal error state
This reverts …
4.115
@7e32b62
11/17/12 11:31:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION
Add …
4.115
@62181b21
11/16/12 12:59:27 |
Sebastian Huber |
score: Add and use _TOD_Get_with_nanoseconds()
Delete …
4.115
@154721c4
11/16/12 12:39:55 |
Sebastian Huber |
score: Add _Timestamp_To_timeval()
4.115
@a12f7e9
11/14/12 14:10:46 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER
4.115
@a0c7aa55
11/14/12 13:54:09 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_ASSERT
4.115
@b9bc399
11/14/12 12:50:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_SPECIFIC
4.115
@9d10cf90
11/14/12 12:58:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_GENERIC
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@038e2f4a
11/14/12 08:58:53 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_APPLICATION
4.115
@608940f
11/14/12 09:12:57 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BDBUF
Add rtems_bdbuf_fatal_code as a …
4.115
@156e91e
11/14/12 09:11:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_LAST
This enum value ensures that the …
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@7d0bdca
11/14/12 08:27:43 |
Sebastian Huber |
score: Add nest level to interal error state
Add …
4.115
@891d0d96
11/14/12 14:56:04 |
Sebastian Huber |
4.115
@84ff9a47
11/12/12 10:53:16 |
Sebastian Huber |
score: Fix per CPU member offsets
Offset calculation was wrong for …
4.115
@ecf9858
11/07/12 11:33:48 |
Sebastian Huber |
score: Move global variables definition
Define _System_state_Current …
4.115
@466cf31d
11/07/12 12:59:19 |
Sebastian Huber |
score: Statically initialize user extensions
The initial extensions …
4.115
@e5ae7c92
11/07/12 09:11:17 |
Sebastian Huber |
score: Add and use _User_extensions_Iterate()
Replace the separate …
4.115
@9ed2bef
11/07/12 09:54:49 |
Sebastian Huber |
score: Add and use RTEMS_ARRAY_SIZE()
4.115
@e278f8b7
11/04/12 18:56:34 |
Sebastian Huber |
score: Support static_assert and _Static_assert
4.115
@0edf263
10/26/12 08:05:07 |
Sebastian Huber |
rtems: Add system events
System events are similar to normal events. …
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@6ccfe72
08/09/12 08:17:42 |
Sebastian Huber |
score: Change _Heap_Extend() API
The _Heap_Extend() has now the same …
4.115
@196fe59
10/02/12 18:27:04 |
Joel Sherrill |
score/thread.h: Move Thread_CPU_usage_t definition down
At the …
4.115
@9e735966
10/02/12 18:24:20 |
Joel Sherrill |
score/percpu.h: _Thread_Time_of_last_context_switch always available
4.115
@b249d7f
10/02/12 18:23:23 |
Joel Sherrill |
score/tod.h: Fix formatting
4.115
@7a9288fe
08/06/12 17:46:27 |
Andreas Heinig |
PR2069: [CBS Scheduler] Memory leak and enqueue problem
Due to the …
4.115
@317ee8d
07/17/12 08:19:16 |
Sebastian Huber |
score: Change greedy allocation API
4.115
@c34bb0d
06/13/12 09:39:43 |
Sebastian Huber |
score: Fix performance issue for 64-bit timestamps
The 64-bit …
4.115
@3246b0f8
06/13/12 09:29:53 |
Sebastian Huber |
score: New structure TOD_Control
Group the global TOD variables …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@826fa6b1
05/07/12 23:29:56 |
Joel Sherrill |
Score ISR - Minimize Capabilities When Not Simple Vectored
In …
4.115
