@7f04cb18
07/25/13 07:10:38 |
Sebastian Huber |
score: Create mpci implementation header
Move implementation specific …
4.115
@cba15292
07/25/13 07:07:23 |
Sebastian Huber |
score: Merge objectmp implementation into one file
4.115
@a112364
07/24/13 15:30:26 |
Sebastian Huber |
score: Create threadq implementation header
Move implementation …
4.115
@8d0bf322
07/24/13 14:50:27 |
Sebastian Huber |
score: Delete threadq.inl
4.115
@62590a7
07/24/13 14:30:54 |
Sebastian Huber |
score: Merge threadmp implementation into one file
4.115
@fe6c170c
07/24/13 14:19:52 |
Sebastian Huber |
score: Create states implementation header
4.115
@5618c37a
07/24/13 13:14:48 |
Sebastian Huber |
score: Create thread implementation header
4.115
@f0bfd7d8
07/24/13 11:25:57 |
Sebastian Huber |
score: Create prioritybitmap implementation header
Move …
4.115
@c6e21ee1
07/24/13 11:12:38 |
Sebastian Huber |
score: Create scheduler implementation header
4.115
@f068384e
07/24/13 10:03:31 |
Sebastian Huber |
score: Create schedulerpriority impl header
4.115
@bd5606ab
07/24/13 09:37:28 |
Sebastian Huber |
score: Create schedulersimple impl header
4.115
@4508a5a
07/24/13 13:24:51 |
Sebastian Huber |
score: Move _Heap_Area_overhead() definition.
This function is used …
4.115
@c9155f7
07/24/13 13:28:19 |
Sebastian Huber |
score: Include <rtems/score/cpu.h>
This file uses CPU_ALIGNMENT.
4.115
@8fb2bea
07/24/13 08:37:39 |
ashi08104 |
score: Add freechain
4.115
@df8f927
07/24/13 08:26:56 |
Sebastian Huber |
score: Delete priority.inl
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@218286bc
07/23/13 15:17:05 |
Sebastian Huber |
score: Create stack implementation header
4.115
@e6f7f81
07/23/13 14:50:51 |
Sebastian Huber |
score: Create heap implementation header
4.115
@965ef82
07/23/13 14:45:54 |
Sebastian Huber |
score: PR1782: CPU_USE_DEFERRED_FP_SWITCH
Do not redefine …
4.115
@1cb75cc
07/23/13 13:32:50 |
Sebastian Huber |
score: Merge wkspace API into one file
4.115
@f26f5fc1
07/23/13 13:30:16 |
Sebastian Huber |
score: Merge address API into one file
4.115
@d19c5352
07/23/13 11:34:21 |
Sebastian Huber |
score: Include <string.h> in basedefs.h
4.115
@93fb3cb0
07/23/13 08:38:11 |
Sebastian Huber |
score: Create rbtree implementation header
4.115
@2a3cff8
07/22/13 13:13:29 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Add SMP version of this …
4.115
@0eae7ba9
07/22/13 09:10:43 |
Sebastian Huber |
score: Add WATCHDOG_INITIALIZER()
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@6e93dc4a
07/22/13 08:49:19 |
Sebastian Huber |
score: Create chain implementation header
4.115
@16243a2
07/19/13 13:32:51 |
Sebastian Huber |
score: Avoid direct usage of _Thread_Executing
Pass the executing …
4.115
@c71b596
07/19/13 13:24:04 |
Sebastian Huber |
score: Create spinlock implementation header
4.115
@982e9746
07/19/13 13:00:11 |
Sebastian Huber |
4.115
@cbdabc8
07/19/13 12:48:57 |
Sebastian Huber |
score: Create rwlock implementation header
4.115
@0444947e
07/19/13 09:07:37 |
Sebastian Huber |
4.115
@bb2d9f9
07/19/13 09:00:19 |
Sebastian Huber |
score: Create barrier implementation header
4.115
@e64f164
07/19/13 06:51:52 |
Sebastian Huber |
score: Include <limits.h> in basedefs.h
4.115
@33a4a56
07/18/13 14:00:54 |
Sebastian Huber |
4.115
@b5d514f
07/18/13 13:35:23 |
Sebastian Huber |
score: Create message queue implementation header
4.115
@e36f2b8
07/18/13 12:27:30 |
Sebastian Huber |
4.115
@570045ed
07/18/13 12:26:58 |
Sebastian Huber |
score: Add const qualifier
4.115
@c4f58558
07/18/13 12:14:04 |
Sebastian Huber |
score: Create semaphore implementation header
4.115
@0bbd8fdc
07/18/13 07:02:53 |
Sebastian Huber |
score: Add and use _ISR_Get_nest_level()
4.115
@d0a97f2
07/18/13 09:04:23 |
Sebastian Huber |
score: Move ISR catch support functions
Delete now unused file …
4.115
@45b572f
07/18/13 09:03:10 |
Sebastian Huber |
score: Move ISR level content to single file
4.115
@95e09afa
07/17/13 13:53:17 |
Sebastian Huber |
4.115
@ac15b07
07/17/13 13:20:03 |
Sebastian Huber |
score: Convert to inline function
4.115
@20e239c2
07/17/13 12:23:14 |
Sebastian Huber |
score: Create mutex implementation header
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@a7ce0ce
06/13/13 08:34:12 |
Sebastian Huber |
smp: Delete RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY
The thread …
4.115
@9c9b62d8
07/17/13 09:44:55 |
Sebastian Huber |
score: Changes due to Newlib DYNAMIC_REENT
Delete …
4.115
@f74d9496
07/17/13 09:03:02 |
Sebastian Huber |
score: Add _Thread_Get_executing()
4.115
@a04182c
07/15/13 15:31:14 |
wei.a.yang |
clean up old atomic related files
4.115
@34229d5
07/15/13 15:31:09 |
wei.a.yang |
A generic atomic implementation for smp architectures
4.115
@1180099
07/15/13 15:31:08 |
wei.a.yang |
New atomic API definition based on C11 atomic
4.115
@d0d357ed
06/25/13 10:09:50 |
Sebastian Huber |
heap: Add _Heap_Greedy_allocate_all_except_largest
Add …
4.115
@4f1da72
06/21/13 07:16:19 |
Sebastian Huber |
score: _Heap_Protection_free_all_delayed_blocks()
Add and use …
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@961669d
06/14/13 13:30:37 |
Sebastian Huber |
documentation: Fix Doxygen comments
4.115
@a936aa49
06/06/13 13:41:00 |
Sebastian Huber |
scheduler: New simple SMP scheduler implementation
The new Simple SMP …
4.115
@a344308
06/06/13 13:32:22 |
Sebastian Huber |
scheduler: Add and use _Scheduler_default_Tick()
Delete …
4.115
@6eba7c85
06/10/13 14:15:46 |
Sebastian Huber |
scheduler: Specify thread of yield operation
The yielding thread of …
4.115
@1ccb64e1
06/06/13 13:28:41 |
Sebastian Huber |
scheduler: Add start idle thread operation
Add and use …
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@a8ef3bf0
06/11/13 07:29:45 |
Sebastian Huber |
smp: Add and use _Per_CPU_Lock_acquire()
Add and use …
4.115
@f70526a7
06/11/13 07:26:30 |
Sebastian Huber |
score: Avoid cyclic include dependency
4.115
@1270440
06/11/13 07:23:35 |
Sebastian Huber |
score: Add missing include
4.115
@3ccce23
06/10/13 09:12:39 |
Sebastian Huber |
score: Always provide <rtems/score/smplock.h>
4.115
@4fc370e
06/05/13 10:08:23 |
Sebastian Huber |
score: Move thread dispatch content to new file
Move thread dispatch …
4.115
@4f5baff
06/05/13 15:13:14 |
Sebastian Huber |
score: Simplify _CORE_mutex_Seize_interrupt_try*
4.115
@e358088
05/28/13 08:54:46 |
Sebastian Huber |
smp: New SMP lock API
Move the SMP lock implementation to the CPU …
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@2f6108f9
05/28/13 08:58:19 |
Sebastian Huber |
smp: Simplify SMP initialization sequence
Delete bsp_smp_wait_for(). …
4.115
@10643e9
05/13/13 13:44:02 |
Sebastian Huber |
smp: Make CPU_ALLOCATE_INTERRUPT_STACK optional
4.115
@f6db560
04/23/13 16:34:15 |
wei.a.yang |
Implement a generic atomic ops for all UP mode architectures with …
4.115
@91de38f8
02/14/13 16:27:15 |
Ralf Corsepius |
Include <stdint.h>
4.115
@68f36d14
01/27/13 13:02:50 |
Sebastian Huber |
score: Add and use rtems_assert_context
4.115
@2f0a0936
01/25/13 15:55:25 |
wei.a.yang |
score: atomic support for RTEMS. Generic atomic operations API definition.
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@b10825c
01/10/13 19:29:41 |
Joel Sherrill |
cpukit: Add EOL on files missing EOL at EOF
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@a1f9934a
01/04/13 15:01:21 |
matkallada |
score: Doxygen Clean Up Task #3
4.115
@0ca61727
12/22/12 16:58:50 |
Sebastian Huber |
4.115
@53afcfd2
12/22/12 16:57:07 |
Sebastian Huber |
score: Do not inline _RBTree_Find_unprotected()
This function is to …
4.115
@1dbbc0c
12/29/12 16:27:48 |
matkallada |
score: Doxygen Clean Up Task #1
4.115
@319cb20
12/29/12 00:04:01 |
matkallada |
score: Doxygen Clean Up Task #2
4.115
@fe1dc22
12/21/12 09:17:34 |
Sebastian Huber |
score: Add _Objects_Active_count()
4.115
@cbd07e4
12/21/12 08:50:15 |
Sebastian Huber |
score: Add rtems_chain_node_count_unprotected()
4.115
@d0b9295f
12/14/12 09:17:04 |
Sebastian Huber |
Fix spelling
4.115
@04b5d17
11/28/12 09:45:38 |
Sebastian Huber |
score: Add API extensions post switch list
Move post switch hook from …
4.115
@5a58b1e
12/01/12 14:53:45 |
daniel.georgiev95 |
score misc: Score misc: Clean up Doxygen #11 (GCI 2012)
This patch is …
4.115
@f839bf5a
12/01/12 14:47:07 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #10 (GCI 2012)
This patch is …
4.115
@e0f91da
11/30/12 21:34:17 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #9 (GCI 2012)
This patch is …
4.115
@8396c18e
11/30/12 02:01:26 |
matkallada |
Score misc: Clean up Doxygen #8 (GCI 2012)
This patch is a task …
4.115
@f2f63d1
11/29/12 23:14:28 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #7 (GCI 2012)
This patch …
4.115
@1b475860
11/29/12 19:39:17 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #6 (GCI 2012)
This patch is …
4.115
@e655f7e
11/29/12 18:39:19 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #5
4.115
@f8ac52f2
11/29/12 14:07:12 |
Sebastian Huber |
score: Documentation
4.115
@bf54252
11/28/12 20:14:50 |
deviennealexandre |
Score misc: Clean up Doxygen #4 (GCI 2012)
This patch is a task from …
4.115
@355ee7d
11/28/12 19:57:31 |
alexivanov97 |
score misc: Clean up Doxygen #3 (GCI 2012)
4.115
@d4d7899
11/28/12 19:31:53 |
Christopher Kerl |
score misc: Clean up Doxygen #2 (GCI 2012)
4.115
