@3168deaa
01/22/08 18:28:53 |
Joel Sherrill |
2008-01-22 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@fd84982
12/21/07 15:50:09 |
Joel Sherrill |
2007-12-21 Xi Yang <hiyangxi@…>
* configure.ac, …
4.104.114.95
@9221838
11/28/07 22:04:31 |
Joel Sherrill |
2007-11-28 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@6cd8bbe
11/26/07 19:35:33 |
Joel Sherrill |
2007-11-26 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@78dabb69
10/26/07 19:44:10 |
Joel Sherrill |
2007-10-26 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@c3330a8
05/17/07 22:46:45 |
Joel Sherrill |
2007-05-17 Joel Sherrill <joel.sherrill@…>
* ChangeLog?, …
4.104.114.84.95
@728a0bd3
05/08/07 10:43:06 |
Ralf Corsepius |
Use size_t for stacksizes.
4.104.114.84.95
@3c86f88
04/17/07 04:55:44 |
Ralf Corsepius |
Use Context_Control_fp* instead of void* for fp_contexts.
4.104.114.84.95
@04dba49
10/19/06 19:20:10 |
Joel Sherrill |
2006-10-19 Joel Sherrill <joel@…>
* configure.ac, …
4.104.114.84.95
@6a07436
01/16/06 15:13:58 |
Joel Sherrill |
2006-01-16 Joel Sherrill <joel@…>
Large patch to improve …
4.104.114.84.95
@092f142a
01/28/05 05:00:21 |
Ralf Corsepius |
New header guard.
4.104.114.84.95
@11874561
11/21/04 07:17:38 |
Ralf Corsepius |
Adjust doxygen @file.
4.104.114.84.95
@baff4da
11/01/04 13:22:41 |
Joel Sherrill |
2004-11-01 Joel Sherrill <joel@…>
4.104.114.84.95
@a0ed4ed
04/18/04 06:13:55 |
Ralf Corsepius |
Remove stray white spaces.
4.104.114.84.95
@05279b84
04/17/04 13:32:13 |
Ralf Corsepius |
4.104.114.84.95
@d6154c7
03/29/04 16:41:13 |
Ralf Corsepius |
2004-03-29 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@8af72be
11/23/03 21:45:00 |
Ralf Corsepius |
2003-11-23 Ralf Corsepius <corsepiu@…>
PR 525/rtems
4.104.114.84.95
@d36b3152
09/15/03 01:01:51 |
Ralf Corsepius |
2003-09-15 Ralf Corsepius <corsepiu@…>
PR 489/rtems
4.104.114.84.95
@dd687d97
09/04/03 18:56:05 |
Joel Sherrill |
2003-09-04 Joel Sherrill <joel@…>
* include/rtems/debug.h, …
4.104.114.84.95
@17c66867
08/14/03 20:04:18 |
Joel Sherrill |
2003-08-14 Joel Sherrill <joel@…>
PR 408/filesystem
4.104.114.84.95
@0df8293e
05/15/02 15:14:58 |
Joel Sherrill |
2002-05-15 Chris Johns <ccj@…>
* include/rtems/score/thread.h, …
4.104.114.84.95
@499d443
08/01/00 19:42:39 |
Joel Sherrill |
Look at both hardware and software FP settings.
4.104.114.84.95
@47ca0d0a
08/01/00 18:26:02 |
Joel Sherrill |
The fp_context field is needed if software or hardware floating point …
4.104.114.84.95
@17508d02
07/26/00 19:26:28 |
Joel Sherrill |
Port of RTEMS to the Texas Instruments C3x/C4x DSP families including …
4.104.114.84.95
@fdcb2b52
06/14/00 13:38:47 |
Joel Sherrill |
Thread iterator and libgjc support submitted too early.
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@c941a98
01/21/00 15:07:55 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to implement this:
I'd …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@b6770d1
10/06/97 21:29:29 |
Joel Sherrill |
Fixed comment.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@0d051533
01/08/97 16:19:47 |
Joel Sherrill |
added type definitions for all supported task entry formats
4.104.114.84.95
@f8c6333
10/15/96 21:38:33 |
Joel Sherrill |
added cpu time used field to tcb
4.104.114.84.95
@1b17790c
06/13/96 16:43:39 |
Joel Sherrill |
Added code so post context switch extensions can be run on every …
4.104.114.84.95
@2f200c7
06/06/96 14:55:01 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@98162c35
06/05/96 14:45:45 |
Joel Sherrill |
added boolean to indicate whether or not the stack area was provided …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@f4d52cd7
04/19/96 19:36:59 |
Joel Sherrill |
changes to compile in macro configuration without warnings.
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@adf98bd
02/21/96 14:44:11 |
Joel Sherrill |
Removed the internal thread objects and dispersed its contents to
the …
4.104.114.84.95
@b2b52cbc
02/14/96 19:00:00 |
Joel Sherrill |
Removed arguments from _Thread_Start_multitasking.
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@b38955b
02/13/96 15:38:03 |
Joel Sherrill |
comma removed from end of last enumerated element
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@7f6a24ab
08/28/95 15:30:29 |
Joel Sherrill |
Added unused priority ceiling parameter to rtems_semaphore_create.
4.104.114.84.95
@5250ff39
08/23/95 21:06:31 |
Joel Sherrill |
Moved _Thread_Information -> _RTEMS_tasks_Information.
Added a table …
4.104.114.84.95
@95fbca1
08/18/95 21:41:27 |
Joel Sherrill |
+ Added object type field to object id.
+ Added name pointer to …
4.104.114.84.95
@b06e68ef
08/17/95 19:51:51 |
Joel Sherrill |
Numerous miscellaneous features incorporated from Tony Bennett …
4.104.114.84.95
@4d9fa26
08/11/95 14:13:51 |
Joel Sherrill |
added constant for number of notepads
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
