Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/score/cpu
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @ef47bc78   02/11/09 19:35:09 Joel Sherrill 2009-02-11 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @e64a143   01/05/09 19:58:41 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * varvects.h: … 4.104.115
(edit) @314b835   12/17/08 06:35:31 Ralf Corsepius 2008-12-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @78aa060   12/11/08 21:10:26 Joel Sherrill 2008-12-11 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.115
(edit) @1cb54d1f   12/11/08 00:47:56 Ralf Corsepius #include <stdint.h> instead of <rtems/stdint.h>. 4.104.115
(edit) @601b863e   12/09/08 08:35:36 Ralf Corsepius Add prototypes, eliminate nested externs. 4.104.115
(edit) @383871ac   12/07/08 11:25:55 Ralf Corsepius Fix typo. 4.104.115
(edit) @a7db5cd   12/05/08 19:15:47 Joel Sherrill 2008-12-05 Joel Sherrill <joel.sherrill@…> * .cvsignore: … 4.104.115
(edit) @15e44fd   12/04/08 22:53:33 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @6b4d0b8   12/04/08 22:53:15 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * ChangeLog?, … 4.104.115
(edit) @63ca296   12/01/08 17:30:11 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * cpu.c: Links … 4.104.115
(edit) @274ee57   11/26/08 14:29:56 Joel Sherrill 2008-11-26 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.115
(edit) @55b115ec   10/28/08 21:44:58 Joel Sherrill 2008-10-28 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @0e5b446   10/28/08 20:03:19 Joel Sherrill 2008-10-28 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.115
(edit) @f1cf019   10/14/08 21:28:20 Joel Sherrill 2008-10-14 Joel Sherrill <joel.sherrill@…> * cpu_asm.S: … 4.104.115
(edit) @f389307   10/14/08 18:30:55 Joel Sherrill 2008-10-14 Steven Grunza <grunza@…> * cpu_asm.S: Use … 4.104.115
(edit) @f517be0   10/13/08 17:07:57 Joel Sherrill 2008-10-13 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @7059d8f   10/02/08 21:56:06 Joel Sherrill 2008-10-02 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @463454b   10/02/08 21:55:54 Joel Sherrill 2008-10-02 Joel Sherrill <joel.sherrill@…> * .cvsignore, … 4.104.115
(edit) @0c34b176   10/02/08 21:33:09 Joel Sherrill 2008-10-02 Joel Sherrill <joel.sherrill@…> * configure.ac, … 4.104.115
(edit) @ed6e947   10/02/08 21:32:44 Joel Sherrill 2008-10-02 Joel Sherrill <joel.sherrill@…> * .cvsignore, … 4.104.115
(edit) @3d0e458   10/02/08 20:20:17 Joel Sherrill 2008-10-02 Joel Sherrill <joel.sherrill@…> * cpu_asm.c, … 4.104.115
(edit) @8baeb42   09/30/08 16:23:34 Joel Sherrill 2008-09-30 Joel Sherrill <joel.sherrill@…> * cpu.c: Fine … 4.104.115
(edit) @d66a6cb   09/25/08 19:32:41 Joel Sherrill 2008-09-25 Joel Sherrill <joel.sherrill@…> * Makefile.am: … 4.104.115
(edit) @4bbf70bd   09/19/08 15:52:09 Joel Sherrill 2008-09-19 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @5c8d42b   09/14/08 23:17:13 Joel Sherrill 2008-09-14 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @6162bc2   09/11/08 14:10:16 Ralf Corsepius 2008-09-11 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @7a28ac8   09/10/08 15:41:37 Joel Sherrill 2008-09-10 Joel Sherrill <joel.sherrill@…> * configure.ac, … 4.104.115
(edit) @4ff2c04   09/10/08 15:35:28 Joel Sherrill 2008-09-10 Joel Sherrill <joel.sherrill@…> * configure.ac, … 4.104.115
(edit) @df4fcaa   09/08/08 15:19:23 Joel Sherrill 2008-09-08 Joel Sherrill <joel.sherrill@…> * cpu.c: Remove … 4.104.114.95
(edit) @7fa919fc   09/08/08 15:19:16 Joel Sherrill 2008-09-08 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @edb1810e   09/08/08 15:19:14 Joel Sherrill 2008-09-08 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.114.95
(edit) @6c283cbf   09/07/08 15:26:01 Ralf Corsepius 2008-09-07 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.95
(edit) @db507c16   09/07/08 15:24:36 Ralf Corsepius Merge thumb/Makefile.am. 4.104.114.95
(edit) @03a699d   09/07/08 15:24:24 Ralf Corsepius Remove (superfluous). 4.104.114.95
(edit) @917f816   09/05/08 06:38:12 Ralf Corsepius Stop using old-style defs. 4.104.114.95
(edit) @a28ce53   09/05/08 06:38:02 Ralf Corsepius 2008-09-05 Ralf Corsépius <ralf.corsepius@…> * cpu.c: Stop … 4.104.114.95
(edit) @cfdef834   09/05/08 02:00:39 Ralf Corsepius 2008-09-05 Ralf Corsépius <ralf.corsepius@…> * cpu.c, … 4.104.114.95
(edit) @5d42c1b7   09/05/08 02:00:15 Ralf Corsepius Convert to "bool". 4.104.114.95
(edit) @8f5cdbb   09/05/08 01:59:18 Ralf Corsepius 2008-09-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @eb441f03   09/05/08 01:49:49 Ralf Corsepius 2008-09-05 Ralf Corsépius <ralf.corsepius@…> * cpu.c, … 4.104.114.95
(edit) @182aecb   08/21/08 04:14:53 Ralf Corsepius 2008-08-21 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @5b31128   08/21/08 04:14:20 Ralf Corsepius Add avr25, avr31, avr35, avr51 to CPU_NAME cascade. 4.104.114.95
(edit) @bdf9e8de   08/21/08 04:12:26 Ralf Corsepius Add missing prototypes. 4.104.114.95
(edit) @b7b6100   08/21/08 04:10:51 Ralf Corsepius 2008-08-21 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @30e2df6   08/21/08 04:10:35 Ralf Corsepius Include stdbool.h. Use bool as base-type for boolean. 4.104.114.95
(edit) @b9f2bb8a   08/20/08 13:36:29 Joel Sherrill 2008-08-20 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @af063f6   08/19/08 19:10:46 Joel Sherrill 2008-08-19 Joel Sherrill <joel.sherrill@…> * cpu.c: Fix … 4.104.114.95
(edit) @1a7c300   08/19/08 18:46:20 Joel Sherrill 2008-08-19 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @60a3fa0c   08/19/08 14:19:12 Joel Sherrill 2008-08-19 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.114.95
(edit) @07f20cb   08/19/08 12:07:39 Ralf Corsepius 2008-08-19 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @6932bce   08/19/08 12:07:28 Ralf Corsepius Add missing prototype. 4.104.114.95
(edit) @d82bd279   08/19/08 06:34:44 Ralf Corsepius Add missing prototypes. 4.104.114.95
(edit) @226b1626   08/18/08 22:18:07 Joel Sherrill 2008-08-18 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.114.95
(edit) @93c6350   08/16/08 05:46:35 Ralf Corsepius 2008-08-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @1b502424   08/16/08 05:46:28 Ralf Corsepius Add missing prototypes. 4.104.114.95
(edit) @75da3f5   08/16/08 04:06:34 Ralf Corsepius Cosmetic indentation fixes. 4.104.114.95
(edit) @dc2503a   08/15/08 16:41:03 Joel Sherrill 2008-08-15 Joel Sherrill <joel.sherrill@…> * ChangeLog?: … 4.104.114.95
(edit) @4daebbd   08/14/08 15:25:14 Joel Sherrill 2008-08-14 Sebastian Huber <sebastian.huber@…> … 4.104.114.95
(edit) @b281e42   08/14/08 15:24:51 Joel Sherrill 2008-08-14 Sebastian Huber <sebastian.huber@…> * … 4.104.114.95
(edit) @334b3c1e   08/05/08 13:32:27 Joel Sherrill 2008-08-04 Sebastian Huber <sebastian.huber@…> * … 4.104.114.95
(edit) @97b2d15   08/04/08 20:35:18 Joel Sherrill 2008-08-04 Joel Sherrill <joel.sherrill@…> PR 1294/bsps * … 4.104.114.95
(edit) @e9dba243   08/04/08 19:51:27 Joel Sherrill 2008-08-04 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @3c87adba   07/31/08 14:55:56 Joel Sherrill 2008-07-31 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.114.95
(edit) @432a662c   07/31/08 14:55:54 Joel Sherrill 2008-07-31 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @d3c32136   07/18/08 15:56:48 Thomas.Doerfler Changed special purpose register inline functions to macros. fixed … 4.104.114.95
(edit) @3d28361d   07/16/08 21:52:04 strauman 2008-07-16 Till Straumann <strauman@…> * … 4.104.114.95
(edit) @441c930   07/16/08 21:47:04 strauman 2008-07-16 Till Straumann <strauman@…> * … 4.104.114.95
(edit) @3c6fe2e   07/14/08 08:46:06 Thomas.Doerfler added haleakala BSP contributed by Michael Hamel 4.104.114.95
(edit) @e0b8176   07/11/08 10:05:13 Thomas.Doerfler added support for mcf548x 4.104.114.95
(edit) @767cdd8   07/11/08 10:04:40 Thomas.Doerfler adapted for modified exception code 4.104.114.95
(edit) @06aab39   07/10/08 21:48:24 strauman 2008-07-10 Till Straumann <strauman@…> * … 4.104.114.95
(edit) @eed04912   07/10/08 12:56:31 Thomas.Doerfler added irq-extension.h declarations 4.104.114.95
(edit) @805cddc   06/16/08 23:37:42 Chris Johns hris Johns <chrisj@…> * cpukit/sapi/include/confdefs.h: Add … 4.104.114.95
(edit) @1603ecd   06/13/08 22:13:02 Joel Sherrill 2008-06-13 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @e339d8b   06/11/08 08:19:13 Chris Johns hris Johns <chrisj@…> * cpu_asm.S: Add Coldfire FPU support. … 4.104.114.95
(edit) @2fd427c   06/05/08 14:30:07 Joel Sherrill 2008-06-05 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @5a5bfea5   06/04/08 14:55:01 Joel Sherrill 2008-06-04 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @3766068   05/06/08 23:16:36 Joel Sherrill Fix date. 4.104.114.95
(edit) @86101e3   04/28/08 18:14:14 Joel Sherrill Fix typo. 4.104.114.95
(edit) @7cdaed0d   04/28/08 18:12:43 Joel Sherrill 2008-04-28 Daron Chabot <daron.chabot@…> * … 4.104.114.95
(edit) @547af38   04/18/08 13:47:59 Joel Sherrill 2008-04-18 Joel Sherrill <joel.sherrill@…> * cpu.c: Add … 4.104.114.95
(edit) @4f2cd78   04/17/08 22:42:03 Joel Sherrill 2008-04-17 Joel Sherrill <joel.sherrill@…> * cpu.c: Add … 4.104.114.95
(edit) @253e4cf   02/26/08 16:35:47 Joel Sherrill Update copyright date. 4.104.114.95
(edit) @49cff0fc   02/20/08 21:54:28 Joel Sherrill 2008-02-20 Alexandru Bugnar <a-bugnar@…> PR … 4.104.114.95
(edit) @3556e40   02/20/08 03:03:16 Ralf Corsepius 2008-02-20 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.95
(edit) @d11ee737   02/20/08 03:03:04 Ralf Corsepius Regenerate. 4.104.114.95
(edit) @a320b269   02/20/08 03:02:36 Ralf Corsepius Remove ref to rtems/old-exceptions/cpu.h. 4.104.114.95
(edit) @70f326cf   02/20/08 02:59:59 Ralf Corsepius Remove (Abandoned). 4.104.114.95
(edit) @95e7637   01/29/08 23:57:47 Joel Sherrill 2008-01-29 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @b4df56dd   01/22/08 15:18:26 Joel Sherrill 2008-01-22 Joel Sherrill <joel.sherrill@…> * cpu_asm.S: … 4.104.114.95
(edit) @47751810   12/20/07 22:38:07 Joel Sherrill 2007-12-20 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @0ca6d0d9   12/17/07 22:35:25 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @52ca649   12/17/07 16:12:47 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * rtems/asm.h: … 4.104.114.95
(edit) @43b4c7a   12/17/07 16:12:45 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @a0da07d   12/17/07 16:12:43 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * irq.c: Sweep … 4.104.114.95
(edit) @7ccdfbb   12/17/07 16:12:41 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @3575d0c   12/17/07 16:12:39 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @899b4f62   12/17/07 16:12:38 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @fe834391   12/17/07 16:12:37 Joel Sherrill 2007-12-17 Joel Sherrill <joel.sherrill@…> * cpu.c, irq.c, … 4.104.114.95
