@905b656c
10/07/14 19:09:39 |
Joel Sherrill |
nios2-iic-irq.c: Include <rtems/score/interr.h> so it builds
4.115
@9bd7b3b1
05/20/14 15:45:07 |
Daniel Hellstrom |
SPARC: Fatal_halt use source and exit codes
The Fatal_halt handler …
4.115
@5464752f
09/19/14 14:55:09 |
Hesham Almatary |
or1k fix bug: Initialize thread context with higher stack address.
4.115
@5323247
09/23/14 06:01:56 |
Sebastian Huber |
m68k: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC
Converting 64-bit …
4.115
@30e5e765
09/23/14 05:57:56 |
Sebastian Huber |
powerpc: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC
Converting 64-bit …
4.115
@386d8b5
09/18/14 13:33:33 |
Sebastian Huber |
sparc: Add comment
4.115
@e0aef221
09/15/14 22:33:30 |
Hesham Almatary |
score/cpu/or1k: Follow no_cpu ISR_Handler algorithm.
This patch …
4.115
@eb14fc2b
09/15/14 22:33:28 |
Hesham Almatary |
OpenRISC: Account for red-zone (fixup printf bug).
This patch …
4.115
@c48cf0bd
09/11/14 07:10:16 |
Sebastian Huber |
score: Rename _BSP_Exception_frame_print()
Rename …
4.115
@6e0000c
09/11/14 07:07:36 |
Sebastian Huber |
powerpc: Delete PPC_BSP_HAS_FIXED_PR288
4.115
@0facefc
09/10/14 13:08:52 |
Hesham Almatary |
or1k: Let CPU/BSP Fatal handler have access to source
This patchs …
4.115
@f82752a4
06/04/14 09:23:34 |
Daniel Hellstrom |
Without the source …
4.115
@bc35eeca
09/04/14 17:55:39 |
Hesham Almatary |
Regenerate preinstall.am for score/cpu/or1k
This patch regenerates …
4.115
@305357e
08/31/14 23:29:41 |
Hesham Almatary |
or1k: Implement context validate and context volatile clobber …
4.115
@23e8f3d
08/31/14 23:28:49 |
Hesham Almatary |
Add missing r31 load instruction _ISR_Handler
_ISR_Handler: r31 was …
4.115
@fecaeca1
08/25/14 10:59:34 |
cederman |
score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC …
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@b597c0d
08/28/14 13:44:52 |
Joel Sherrill |
Apparently, at some point …
4.115
@bba83e5
07/11/14 14:09:41 |
cederman |
score/sparc: Add comment on icache flush after trap table update
4.115
@54f3476e
07/03/14 09:18:55 |
cederman |
bsp/sparc: Flush icache before first time enabling interrupts
A …
4.115
@de62e5d8
08/18/14 21:06:46 |
Hesham Almatary |
Add or1k tick timer register definitions
4.115
@1a2d3497
08/14/14 12:27:40 |
Sebastian Huber |
arm: PR2186: Fix compile error
4.115
@700f97e
08/12/14 18:46:49 |
Joel Sherrill |
or1k/.../preinstall.am: Add missing file
4.115
@94d45f6
08/12/14 15:57:42 |
Hesham Almatary |
Add support for OpenRISC - Fixed issues
This work is based on the old …
4.115
@8ae37323
08/10/14 16:36:30 |
Sebastian Huber |
arm: Add support for FPv4-SP floating point unit
This floating point …
4.115
@fbda4a8
07/01/14 08:48:28 |
Sebastian Huber |
score: PR2183: Fix context switch on SMP
Fix context switch on SMP …
4.115
@f28f5c4
06/30/14 14:47:06 |
Sebastian Huber |
arm: Use local label in _CPU_Context_restore()
4.115
@8df1f408
06/02/14 14:31:51 |
Christian.Mauderer |
score/sparc: Add support for paravirtualization
Guest systems in …
4.115
@7c90670
06/02/14 11:23:07 |
Sebastian Huber |
arm: Add ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
4.115
@6a740c2
05/23/14 13:52:16 |
Daniel Hellstrom |
SPARC: add syscall 1 (exit) function entry point
The exit SPARC …
4.115
@774ee002
05/14/14 08:17:47 |
cederman |
sparc: Change asm to asm to compile with -std=c99.
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@e5120a5
04/22/14 08:10:39 |
Sebastian Huber |
score: Add _CPU_Get_current_per_CPU_control()
Add optional method …
4.115
@320faf8e
04/17/14 05:57:09 |
Sebastian Huber |
score: Clarify TLS support
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@67a7a2c
04/14/14 06:09:54 |
Sebastian Huber |
sparc: Use leon multilib define
4.115
@57740ce8
04/07/14 12:50:24 |
Sebastian Huber |
score: Clarify CPU port alignment requirements
4.115
@f570b071
04/01/14 08:20:01 |
Sebastian Huber |
score: Rename Priority_bit_map_Control
Rename …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@148d6e9
03/06/14 14:51:10 |
Sebastian Huber |
arm: Add support for interrupt profiling
4.115
@e7d3967
03/06/14 14:16:01 |
Sebastian Huber |
arm: Fix stack alignment in interrupt handler
According to AAPCS, …
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@a4bc90af
02/24/14 11:45:00 |
Sebastian Huber |
sparc: Fix CPU counter support
The SPARC processors supported by …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@0344ce03
02/13/14 14:43:03 |
Sebastian Huber |
score: Use atomic API for SMP lock
Use a ticket lock implementation …
4.115
@dcd97c7
02/14/14 11:48:49 |
Sebastian Huber |
sparc: Add atomic support for SPARC V8
Use SWAP instruction with one …
4.115
@ad56361
02/13/14 12:00:00 |
Sebastian Huber |
sparc: Add LEON3_ASR17_PROCESSOR_INDEX_SHIFT
Add …
4.115
@6f90ef7
02/13/14 12:08:46 |
Sebastian Huber |
score: Remove volatile from asm statements
The instructions to get …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@ece9754
02/11/14 13:48:35 |
Sebastian Huber |
sparc: Increase CPU_STRUCTURE_ALIGNMENT to 32
Recent LEON4 systems …
4.115
@97cf623d
02/05/14 10:36:05 |
Sebastian Huber |
sparc: Save/restore only non-volatile context
The …
4.115
@558cc8d
02/05/14 14:41:00 |
Sebastian Huber |
score: _CPU_Context_switch_to_first_task_smp()
Delete …
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@805ef2f2
11/30/13 19:53:41 |
Sebastian Huber |
arm: Add ARMv7-M SHCSR register bits
4.115
@f859d20
12/16/13 13:45:26 |
Sebastian Huber |
arm: Fix set by but not used warning
4.115
@4402308b
12/14/13 17:56:33 |
Joel Sherrill |
no_cpu/cpusmplock.h: Clean up to be compilable
4.115
@b4e8306
12/03/13 10:56:55 |
Sebastian Huber |
arm: Clear reservations
Recent GCC versions use atomic operations …
4.115
@ea3e6928
11/26/13 07:08:38 |
Sebastian Huber |
nios2: Typos
4.115
@39a4574
06/24/13 13:21:46 |
Sebastian Huber |
powerpc: Add r2 to CPU context
The r2 may be used for thread-local …
4.115
@8dc2e7b
11/18/13 13:34:13 |
Sebastian Huber |
powerpc: Do not validate reserved XER bits
4.115
@f8a39cdc
11/14/13 23:27:13 |
Joel Sherrill |
no_cpu/.../cpu.h: Comment improvement
4.115
@bd90283
11/14/13 23:26:31 |
Joel Sherrill |
mips/.../cpu.h: Comment improvement
4.115
@784d2a1
09/06/13 08:05:35 |
Sebastian Huber |
arm: Fix inconsistent define usage
4.115
@03e097b7
09/03/13 10:59:54 |
Sebastian Huber |
nios2: Include proper header file
4.115
@58a70b76
08/27/13 13:14:04 |
wei.a.yang |
score: Simplify <rtems/score/cpuatomic.h>
Add proper license and …
4.115
@1a246d7e
08/22/13 11:19:06 |
Sebastian Huber |
arm: Make barrier operations more visible
4.115
@2606fee
08/13/13 07:54:25 |
Sebastian Huber |
powerpc: Fix _CPU_Context_validate()
4.115
@f8ad6c6f
08/02/13 12:12:55 |
Sebastian Huber |
sparc: Make _CPU_ISR_Dispatch_disable per-CPU
This variable must be …
4.115
@88f6c4fc
08/02/13 12:06:52 |
Sebastian Huber |
sparc: Move _CPU_Context_switch(), etc.
Move the …
4.115
@0756790
08/01/13 15:46:37 |
Sebastian Huber |
arm: Per-CPU thread dispatch disable
Interrupt support for per-CPU …
4.115
@d19cce29
08/05/13 12:54:11 |
Sebastian Huber |
score: Per-CPU thread dispatch disable level
Use a per-CPU thread …
4.115
@10fd4aac
08/02/13 11:54:08 |
Sebastian Huber |
score/cpu: Add CPU_Per_CPU_control
Add CPU port specific per-CPU control.
4.115
@71336bf
08/05/13 15:27:35 |
Sebastian Huber |
arm: Fix ISR level context initialization
4.115
@007bdc4
08/05/13 08:16:31 |
Sebastian Huber |
arm: Fix CPU_MODES_INTERRUPT_MASK
The set of interrupt levels must be …
4.115
@26bdc9fc
08/01/13 15:02:17 |
Joel Sherrill |
bfin/cpu.h: Remove duplicate definition of CPU_SIMPLE_VECTORED_INTERRUPTS
4.115
@9e6df6a
07/30/13 13:29:43 |
Sebastian Huber |
score/cpu: Fix _CPU_SMP_lock_Acquire()
Avoid infinite loops due to …
4.115
@f346bcf7
07/30/13 09:08:49 |
Sebastian Huber |
score/i386: Fix _CPU_Fatal_halt()
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@965ef82
07/23/13 14:45:54 |
Sebastian Huber |
score: PR1782: CPU_USE_DEFERRED_FP_SWITCH
Do not redefine …
4.115
@f7740e97
06/13/13 14:05:20 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_receive()
Rename to …
4.115
@07f6e419
06/13/13 14:00:54 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_broadcast()
Rename to …
4.115
@ca63ae2
06/13/13 13:41:21 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Send_interrupt()
Delete bsp_smp_interrupt_cpu().
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@d61e54c2
07/15/13 15:31:10 |
wei.a.yang |
update-all-architectures-to-new-atomic-implementation
4.115
@4e5608dd
07/16/13 06:25:41 |
Sebastian Huber |
arm: Fix exception frame information
Use the right stack pointer …
4.115
@818d4b0
07/13/13 20:52:06 |
Ric Claus |
bsps/arm: Fix printk args to match format
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@1ebffa89
06/21/13 07:18:01 |
Chris Johns |
arm: Fix default exception prologues
4.115
@961669d
06/14/13 13:30:37 |
Sebastian Huber |
documentation: Fix Doxygen comments
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@f2f211c5
05/31/13 11:59:34 |
Sebastian Huber |
smp: Add ARM support
4.115
@ffbeb6f
01/18/13 08:42:49 |
Sebastian Huber |
smp: Add PowerPC support
4.115
