# # ChangeLog for cpukit/score/cpu in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 07:13:43 Mon, 31 Jul 2017 13:08:06 GMT Sebastian Huber [caa12270] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add register defines Update #3082. Thu, 10 Aug 2017 07:03:36 GMT Sebastian Huber [0daa8ab] * cpukit/score/cpu/arm/arm-context-validate.S (modified) arm: Use ARM code on Thumb 1 targets Update #3093. Thu, 10 Aug 2017 05:51:17 GMT Sebastian Huber [a95d909] * cpukit/score/cpu/arm/arm-context-validate.S (modified) arm: Validate IT[7:0] bit field of PSR Update #3093. Mon, 31 Jul 2017 11:34:46 GMT Sebastian Huber [a597984] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add register defines Update #3082. Update #3085. Fri, 28 Jul 2017 12:42:53 GMT Sebastian Huber [585706a4] * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) bsp/t32mppc: Add SMP support Mon, 17 Jul 2017 05:30:46 GMT Sebastian Huber [146adb1] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spsize/size.c (modified) sparc: Add lazy floating point switch The SPARC ABI is a bit ... Tue, 18 Jul 2017 13:11:41 GMT Sebastian Huber [a400d06f] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Rename SPARC_USE_SAFE_FP_SUPPORT Rename ... Tue, 18 Jul 2017 12:53:16 GMT Sebastian Huber [b2e1bded] * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadrestart.c (modified) score: Add optional _CPU_Context_Destroy() Update #3077. Thu, 13 Jul 2017 07:26:50 GMT Daniel Cederman [2f8704b6] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Add assembly workaround for LEON3FT B2BST errata This patch ... Tue, 04 Jul 2017 12:15:03 GMT Sebastian Huber [3e782743] * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) arm: Fix ARMv7-M interrupt processing Right after a "msr ... Tue, 20 Jun 2017 11:01:02 GMT Sebastian Huber [d30c2cc] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Account for legacy AltiVec ... Tue, 20 Jun 2017 08:39:54 GMT Sebastian Huber [ae3e6af8] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix TLS support Do not zero the GPR2 in the thread context ... Fri, 09 Jun 2017 13:42:36 GMT Sebastian Huber [7b0c74ff] * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) i386: Support thread-local storage (TLS) Update #2468. Fri, 09 Jun 2017 06:17:59 GMT Sebastian Huber [cb0d9a0] * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: Move _CPU_Context_Initialize() Update #2468. Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Tue, 23 May 2017 08:03:56 GMT Sebastian Huber [d5c8756] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix profiling support of Thumb-1 targets Update #2751. Wed, 26 Apr 2017 01:02:09 GMT Joel Sherrill [03e4be12] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning Wed, 26 Apr 2017 01:01:41 GMT Joel Sherrill [65807379] * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning Tue, 25 Apr 2017 18:56:31 GMT Joel Sherrill [f6bd41e] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxie/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 18:39:50 GMT Joel Sherrill [fdfbb0a8] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 16:41:35 GMT Joel Sherrill [28e5749e] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix typo to eliminate warning Sun, 23 Apr 2017 17:57:27 GMT Joel Sherrill [0c334a5] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix not a prototype warning Sat, 08 Apr 2017 10:30:50 GMT Cillian O'Donnell [62c238e] * cpukit/score/cpu/i386/cpu.c (modified) cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning. Mon, 27 Mar 2017 06:01:38 GMT Sebastian Huber [cd3d747] * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Optimize context switch Set CPU_ENABLE_ROBUST_THREAD_DISPATCH ... Thu, 09 Mar 2017 13:32:04 GMT Sebastian Huber [b437a360] * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) arm: Fix CPU context validation for Cortex-R4 Do not touch the ... Tue, 07 Mar 2017 13:32:42 GMT Sebastian Huber [2433a8ab] * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (deleted) * c/src/lib/libbsp/arm/shared/abort/abort.h (deleted) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (deleted) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/start/start.S (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (deleted) * cpukit/score/cpu/arm/arm_exc_handler_low.S (deleted) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Remove legacy execption support Mon, 06 Mar 2017 10:16:25 GMT Sebastian Huber [f61195b2] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE Fri, 03 Feb 2017 09:16:40 GMT Sebastian Huber [e2b1c47d] * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Fix volatile clobber Do not adjust the stack pointer, since ... Mon, 30 Jan 2017 10:33:31 GMT Christian Mauderer [180107e9] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/startup/armv7m-cpucounter.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable ... Wed, 25 Jan 2017 13:32:02 GMT Sebastian Huber [27bfcd8] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Delete _CPU_Context_Fp_start() Since the FP area pointer is ... Tue, 24 Jan 2017 14:40:31 GMT Kevin Kirspel [b43c2e8] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) Adding ARM VFP V2 support Mon, 23 Jan 2017 14:04:44 GMT Sebastian Huber [3d20f5fb] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Relax CPU_STACK_ALIGNMENT Close #2352. Mon, 23 Jan 2017 07:12:18 GMT Sebastian Huber [4aa23c96] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN Use de-facto standard ... Fri, 09 Dec 2016 06:19:22 GMT Sebastian Huber [3a659b04] * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) score: Introduce _Internal_error() Thu, 08 Dec 2016 15:41:30 GMT Sebastian Huber [b6606e8] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/fatal2.c (deleted) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/nios2-isr-set-level.c (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/devnullfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal01/testcase.h (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal02/testcase.h (modified) * testsuites/sptests/spfatal03/testcase.h (modified) * testsuites/sptests/spfatal04/testcase.h (modified) * testsuites/sptests/spfatal05/testcase.h (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal13/testcase.h (modified) * testsuites/sptests/spfatal14/testcase.h (modified) * testsuites/sptests/spfatal15/testcase.h (modified) * testsuites/sptests/spfatal16/testcase.h (modified) * testsuites/sptests/spfatal17/testcase.h (modified) * testsuites/sptests/spfatal18/testcase.h (modified) * testsuites/sptests/spfatal19/testcase.h (modified) * testsuites/sptests/spfatal20/testcase.h (modified) * testsuites/sptests/spfatal24/testcase.h (modified) * testsuites/sptests/spfatal25/testcase.h (modified) * testsuites/sptests/spfatal27/testcase.h (modified) * testsuites/sptests/spfatal28/testcase.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Remove fatal is internal indicator The fatal is internal ... Fri, 02 Dec 2016 12:10:31 GMT Sebastian Huber [f65dcc71] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) score: Fix ARM and PowerPC context initialization Update #2751. Tue, 22 Nov 2016 09:13:27 GMT Sebastian Huber [6a1b9e4] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of ... Thu, 24 Nov 2016 10:53:59 GMT Sebastian Huber [bd0d585] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix _CPU_ISR_Is_enabled() for ARMv7-M Update #2811. Thu, 10 Nov 2016 11:02:28 GMT Sebastian Huber [84e6f15] * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal06/Makefile.am (added) * testsuites/smptests/smpfatal06/init.c (added) * testsuites/smptests/smpfatal06/smpfatal06.doc (added) * testsuites/smptests/smpfatal06/smpfatal06.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) score: Robust thread dispatch On SMP configurations, it is a fatal ... Wed, 23 Nov 2016 09:15:07 GMT Sebastian Huber [1d18a902] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Fix _ARMV4_Exception_interrupt Use the right register to ... Mon, 21 Nov 2016 10:40:00 GMT Sebastian Huber [4e2bc0a] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) arm: Fix Thumb-1 targets We cannot use the MRS or MSR instructions ... Mon, 21 Nov 2016 09:25:58 GMT Sebastian Huber [27eccda] * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64: Fix _CPU_ISR_Is_enabled() Update #2820. Mon, 21 Nov 2016 09:13:37 GMT Sebastian Huber [fd6d3f1] * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) nios2: Fix _CPU_ISR_Is_enabled() Close #2818. Mon, 21 Nov 2016 09:11:18 GMT Sebastian Huber [9f225dea] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE Close #2816. Mon, 21 Nov 2016 09:06:36 GMT Sebastian Huber [c6f446b] * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) bfin: ASM compatibility for Close #2817. Thu, 10 Nov 2016 14:17:28 GMT Sebastian Huber [408609f6] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-isr-get-level.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Add _ISR_Is_enabled() In contrast to _ISR_Get_level() the ... Mon, 14 Nov 2016 14:23:40 GMT Sebastian Huber [7ce60b3] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Mon, 14 Nov 2016 08:53:57 GMT Sebastian Huber [d59585d] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Sun, 13 Nov 2016 14:20:59 GMT Sebastian Huber [2668e4f6] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Simplify _ARMV4_Exception_interrupt Move profiling code closer ... Sat, 12 Nov 2016 15:52:55 GMT Sebastian Huber [4924756] * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) arm: Use local labels Mon, 14 Nov 2016 13:42:56 GMT Sebastian Huber [c11ac2d5] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) sparc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Fri, 11 Nov 2016 13:37:51 GMT Sebastian Huber [d5e073c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Allow interrupts during thread dispatch Use a ... Fri, 11 Nov 2016 13:12:03 GMT Sebastian Huber [f9aa34d] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Add Per_CPU_Control::Interrupt_frame Update #2809. Fri, 11 Nov 2016 11:37:17 GMT Sebastian Huber [dbeccf0e] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpuimpl.h (modified) arm: Provide CPU_Interrupt_frame for ARMv4 Update #2809. Mon, 14 Nov 2016 11:06:46 GMT Sebastian Huber [2599c8e] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) powerpc: Add up to date CPU_Interrupt_frame Rename ... Fri, 11 Nov 2016 10:31:13 GMT Sebastian Huber [bf4fdb1] * c/src/lib/libbsp/powerpc/ss555/irq/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Move legacy CPU_Interrupt_frame The only remaining user of ... Mon, 14 Nov 2016 10:34:54 GMT Sebastian Huber [c539a865] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Move CPU_Interrupt_frame related defines Move ... Fri, 11 Nov 2016 10:17:02 GMT Sebastian Huber [427dcee] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Rename CPU_Minimum_stack_frame Rename SPARC-specific ... Fri, 11 Nov 2016 10:16:33 GMT Sebastian Huber [d18560a] * c/src/lib/libbsp/sparc64/shared/start/start.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64: Rename CPU_Minimum_stack_frame Rename SPARC64-specific ... Fri, 11 Nov 2016 09:51:25 GMT Sebastian Huber [141e16d] * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) rtems: Conditionally define rtems_interrupt_frame Update #2808. Fri, 11 Nov 2016 09:16:33 GMT Sebastian Huber [82d30a3] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpuimpl.h (modified) score: Move CPU_PER_CPU_CONTROL_SIZE Move CPU_PER_CPU_CONTROL_SIZE ... Thu, 10 Nov 2016 06:12:55 GMT Sebastian Huber [acc6d9bf] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: Remove obsolete defines The thread dispatch inline option is ... Sun, 13 Nov 2016 14:18:58 GMT Sebastian Huber [04bd261] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpuimpl.h (modified) arm: Use TPIDRPRW for current per-CPU control Use the previously ... Wed, 09 Nov 2016 13:59:33 GMT Sebastian Huber [38a1449] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpmutex02/smpmutex02.scn (modified) * testsuites/tmtests/tmfine01/tmfine01.scn (modified) powerpc: Add _CPU_Get_current_per_CPU_control() Add ... Wed, 09 Nov 2016 14:16:03 GMT Sebastian Huber [58bced6] * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) score: Move _CPU_Get_current_per_CPU_control() Move ... Fri, 04 Nov 2016 12:29:00 GMT Sebastian Huber [7790d95f] * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) sparc: Provide _CPU_Get_thread_executing() Fri, 04 Nov 2016 12:28:23 GMT Sebastian Huber [df48ed2] * cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/threadhandler.c (modified) score: Add optional _CPU_Get_thread_executing() Fri, 04 Nov 2016 12:45:25 GMT Sebastian Huber [df63fbd1] * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/arm/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/preinstall.am (modified) * cpukit/score/cpu/bfin/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/preinstall.am (modified) * cpukit/score/cpu/epiphany/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/i386/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/preinstall.am (modified) * cpukit/score/cpu/lm32/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/preinstall.am (modified) * cpukit/score/cpu/m32c/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/preinstall.am (modified) * cpukit/score/cpu/m68k/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/mips/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/preinstall.am (modified) * cpukit/score/cpu/moxie/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/preinstall.am (modified) * cpukit/score/cpu/nios2/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/preinstall.am (modified) * cpukit/score/cpu/or1k/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/preinstall.am (modified) * cpukit/score/cpu/sh/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/preinstall.am (modified) * cpukit/score/cpu/sparc64/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/preinstall.am (modified) * cpukit/score/cpu/v850/rtems/score/cpuimpl.h (added) score: Add The aim of this file is to ... Tue, 04 Oct 2016 21:30:22 GMT Pavel Pisa [8714684] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) score/arm: Correct logic to select 64 byte cache line maximum size ... Fri, 23 Sep 2016 04:52:33 GMT Sebastian Huber [9149c87e] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Fix C/C++ compatibility issue Only use CPU_Per_CPU_control ... Wed, 07 Sep 2016 12:08:06 GMT Sebastian Huber [8bb9d41] * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) stackchk: Use a const pattern to check Fri, 19 Aug 2016 05:38:07 GMT Kevin Kirspel [36fad91] * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) arm: Add VFP context validate support for ARMv5 Tue, 26 Jul 2016 05:54:05 GMT Sebastian Huber [75fc27ad] * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) score: Fix printk() format specifiers Sat, 02 Jul 2016 12:33:11 GMT Pavel Pisa [0cb50ab] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) score/arm: Ensure that copile time alignment is 64 bytes for Cortex-A ... Thu, 30 Jun 2016 22:05:33 GMT Pavel Pisa [19a9090] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm/score and shared: define ARM hypervisor mode and alternate vector ... Wed, 29 Jun 2016 09:04:39 GMT Sebastian Huber [297d4372] * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) score: _CPU_SMP_Send_interrupt() documentation Wed, 22 Jun 2016 11:45:02 GMT Sebastian Huber [655ce0fb] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparcimpl.h (added) * cpukit/score/cpu/sparc/sparc-counter.c (modified) sparc: Optimize CPU counter support Mon, 20 Jun 2016 08:08:39 GMT Sebastian Huber [9460333e] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (added) * cpukit/score/cpu/sparc/sparc-counter.c (modified) sparc: Rework CPU counter support Rework CPU counter support to ... Mon, 13 Jun 2016 07:46:17 GMT Sebastian Huber [3bf9fdb] * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: Fix _CPU_Bitfield_Find_first_bit() Bug introduced by ... Tue, 07 Jun 2016 19:36:48 GMT Sebastian Huber [b04b76c6] * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/cpu/bfin/rtems/score/types.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/types.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) * cpukit/score/cpu/m32c/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/moxie/rtems/score/types.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/types.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/types.h (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) * cpukit/score/cpu/v850/rtems/score/types.h (modified) * cpukit/score/include/rtems/score/prioritybitmap.h (modified) * cpukit/score/include/rtems/score/prioritybitmapimpl.h (modified) score: Simplify priority bit map implementation The priority bit ... Wed, 08 Jun 2016 08:10:40 GMT Sebastian Huber [18e29faf] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-count-zeros.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/prioritybitmapimpl.h (modified) * cpukit/score/src/log2table.c (modified) score: Delete CPU_USE_GENERIC_BITFIELD_DATA Rename __log2table into ... Tue, 07 Jun 2016 20:09:12 GMT Sebastian Huber [987ea1a] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Define bitmap defines to FALSE Tue, 07 Jun 2016 20:09:01 GMT Sebastian Huber [ec5d7f92] * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Delete dead copy and paste code Tue, 31 May 2016 07:36:52 GMT Chris Johns [23213135] * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) arm: Fix printk warnings. Tue, 19 Apr 2016 07:25:03 GMT Sebastian Huber [fd6fde8] * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (deleted) * cpukit/score/src/libatomic.c (added) score: Add libatomic support Close #2695. Mon, 23 May 2016 05:28:56 GMT Chris Johns [458e4c4] * cpukit/score/cpu/i386/cpu.c (modified) score/i386: Fix printk format warnings. Wed, 18 May 2016 06:06:54 GMT Sebastian Huber [24713163] * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/dpram.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Disable() and _ISR_Enable() Rename ... Wed, 18 May 2016 06:03:05 GMT Sebastian Huber [4b04cb61] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadhandler.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Rename _ISR_Disable_without_giant() Rename ... Tue, 17 May 2016 13:57:48 GMT Sebastian Huber [d2bacb6c] * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: _Thread_Dispatch_increment_disable_level() Avoid ... Fri, 22 Apr 2016 12:10:47 GMT Sebastian Huber [d35e6dde] * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add FSL_EIS_TENSR, etc. defines Wed, 13 Apr 2016 07:30:28 GMT Sebastian Huber [f1a5630] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add FSL_EIS_MAS8 Fri, 04 Mar 2016 13:48:51 GMT Sebastian Huber [0a5aa2d] * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: Define _CPU_SMP_Prepare_start_multitasking() Define ... Wed, 17 Feb 2016 13:26:29 GMT Sebastian Huber [decff899] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Add CPU_MAXIMUM_PROCESSORS Maximum number of processors of ... Sat, 23 Jan 2016 19:06:22 GMT Joel Sherrill [328bd35] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/i386/cache.c (modified) * c/src/lib/libcpu/i386/cpu.h (deleted) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/i386/page.h (added) * c/src/lib/libcpu/i386/preinstall.am (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: refactor libcpu/cpu.h into rtems/score/i386.h Fixes #2515. Sat, 09 Jan 2016 21:22:16 GMT Joel Sherrill [dda25b1] * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386 ..score/cpu.h: Fix spacing Fri, 08 Jan 2016 21:54:20 GMT Gedare Bloom [3267f95] * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/interrupts.h (modified) i386: prepare for paravirtualized interrupts Fri, 08 Jan 2016 21:28:45 GMT Gedare Bloom [505dc61] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c (added) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: relocate fatal halt to bsp layer Fri, 08 Jan 2016 21:16:18 GMT Gedare Bloom [6a4efc55] * cpukit/score/cpu/i386/rtems/score/interrupts.h (modified) i386: remove redundant CPP defines Fri, 08 Jan 2016 17:15:46 GMT Gedare Bloom [fd05a05] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspidle.S (added) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) i386: move idle thread into BSP layer
