# # ChangeLog for cpukit/score/cpu in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 10:50:47 Tue, 15 Jun 2010 22:43:56 GMT Joel Sherrill [c86da31c] * cpukit/score/cpu/sparc64/.cvsignore (added) * cpukit/score/cpu/sparc64/ChangeLog (added) * cpukit/score/cpu/sparc64/Makefile.am (added) * cpukit/score/cpu/sparc64/Makefile.in (added) * cpukit/score/cpu/sparc64/README (added) * cpukit/score/cpu/sparc64/context.S (added) * cpukit/score/cpu/sparc64/cpu.c (added) * cpukit/score/cpu/sparc64/preinstall.am (added) * cpukit/score/cpu/sparc64/rtems/asm.h (added) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (added) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (added) * cpukit/score/cpu/sparc64/rtems/score/types.h (added) 2010-06-15 Joel Sherrill ... Tue, 15 Jun 2010 16:25:16 GMT Joel Sherrill [cd9ce6be] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) 2010-06-15 Joel Sherrill * ... Fri, 11 Jun 2010 12:28:40 GMT Ralf Corsepius [3490d70] * c/src/lib/libbsp/c4x/.cvsignore (deleted) * c/src/lib/libbsp/c4x/ChangeLog (deleted) * c/src/lib/libbsp/c4x/Makefile.am (deleted) * c/src/lib/libbsp/c4x/acinclude.m4 (deleted) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/README (deleted) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (deleted) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/console.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/simio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/simio.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/tm27.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/make/custom/c3xsim.cfg (deleted) * c/src/lib/libbsp/c4x/c4xsim/make/custom/c4xsim.cfg (deleted) * c/src/lib/libbsp/c4x/c4xsim/preinstall.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/start/start.S (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/bsppretaskinghook.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in (deleted) * c/src/lib/libbsp/c4x/configure.ac (deleted) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (deleted) * c/src/lib/libbsp/c4x/shared/c3xspurious.c (deleted) * c/src/lib/libbsp/c4x/shared/c4xspurious.c (deleted) * cpukit/score/cpu/c4x/.cvsignore (deleted) * cpukit/score/cpu/c4x/ChangeLog (deleted) * cpukit/score/cpu/c4x/Makefile.am (deleted) * cpukit/score/cpu/c4x/cpu.c (deleted) * cpukit/score/cpu/c4x/cpu_asm.S (deleted) * cpukit/score/cpu/c4x/irq.c (deleted) * cpukit/score/cpu/c4x/preinstall.am (deleted) * cpukit/score/cpu/c4x/rtems/asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/c4x.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/types.h (deleted) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (deleted) Remove (Abandoned). Fri, 11 Jun 2010 12:24:57 GMT Ralf Corsepius [4e48fab] * cpukit/ChangeLog (modified) * cpukit/score/cpu/Makefile.am (modified) 2010-06-11 Ralf Corsépius * ... Sat, 29 May 2010 05:19:13 GMT Ralf Corsepius [f88a1a0] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/irq.c (modified) 2010-05-29 Ralf Corsépius * ... Sun, 23 May 2010 05:47:27 GMT Ralf Corsepius [a4f9124] * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/cpu.c (modified) 2010-05-23 Ralf Corsépius * ... Fri, 21 May 2010 19:02:05 GMT Joel Sherrill [4a76be7e] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/rtems/score/registers.h (modified) 2010-05-21 Vinu Rajashekhar * ... Mon, 10 May 2010 20:29:13 GMT Joel Sherrill [b2f251a8] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) 2010-05-10 Joel Sherrill * ... Mon, 10 May 2010 20:08:50 GMT Joel Sherrill [6563691] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/context_switch.S (modified) * cpukit/score/cpu/m32c/cpu.c (modified) 2010-05-10 Joel Sherrill * ... Mon, 10 May 2010 16:31:24 GMT Joel Sherrill [31af0dfe] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/avr/boot.h (modified) * cpukit/score/cpu/avr/avr/common.h (modified) * cpukit/score/cpu/avr/avr/eeprom.h (modified) * cpukit/score/cpu/avr/avr/fuse.h (modified) * cpukit/score/cpu/avr/avr/interrupt.h (modified) * cpukit/score/cpu/avr/avr/io.h (modified) * cpukit/score/cpu/avr/avr/io1200.h (modified) * cpukit/score/cpu/avr/avr/io2313.h (modified) * cpukit/score/cpu/avr/avr/io2323.h (modified) * cpukit/score/cpu/avr/avr/io2333.h (modified) * cpukit/score/cpu/avr/avr/io2343.h (modified) * cpukit/score/cpu/avr/avr/io43u32x.h (modified) * cpukit/score/cpu/avr/avr/io43u35x.h (modified) * cpukit/score/cpu/avr/avr/io4414.h (modified) * cpukit/score/cpu/avr/avr/io4433.h (modified) * cpukit/score/cpu/avr/avr/io4434.h (modified) * cpukit/score/cpu/avr/avr/io76c711.h (modified) * cpukit/score/cpu/avr/avr/io8515.h (modified) * cpukit/score/cpu/avr/avr/io8534.h (modified) * cpukit/score/cpu/avr/avr/io8535.h (modified) * cpukit/score/cpu/avr/avr/io86r401.h (modified) * cpukit/score/cpu/avr/avr/io90pwm1.h (modified) * cpukit/score/cpu/avr/avr/io90pwm216.h (modified) * cpukit/score/cpu/avr/avr/io90pwm2b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm316.h (modified) * cpukit/score/cpu/avr/avr/io90pwm3b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm81.h (modified) * cpukit/score/cpu/avr/avr/io90pwmx.h (modified) * cpukit/score/cpu/avr/avr/io90scr100.h (modified) * cpukit/score/cpu/avr/avr/ioa6289.h (modified) * cpukit/score/cpu/avr/avr/ioat94k.h (modified) * cpukit/score/cpu/avr/avr/iocan128.h (modified) * cpukit/score/cpu/avr/avr/iocan32.h (modified) * cpukit/score/cpu/avr/avr/iocan64.h (modified) * cpukit/score/cpu/avr/avr/iocanxx.h (modified) * cpukit/score/cpu/avr/avr/iom103.h (modified) * cpukit/score/cpu/avr/avr/iom128.h (modified) * cpukit/score/cpu/avr/avr/iom1280.h (modified) * cpukit/score/cpu/avr/avr/iom1281.h (modified) * cpukit/score/cpu/avr/avr/iom128rfa1.h (modified) * cpukit/score/cpu/avr/avr/iom16.h (modified) * cpukit/score/cpu/avr/avr/iom161.h (modified) * cpukit/score/cpu/avr/avr/iom162.h (modified) * cpukit/score/cpu/avr/avr/iom163.h (modified) * cpukit/score/cpu/avr/avr/iom164.h (modified) * cpukit/score/cpu/avr/avr/iom165.h (modified) * cpukit/score/cpu/avr/avr/iom165p.h (modified) * cpukit/score/cpu/avr/avr/iom168.h (modified) * cpukit/score/cpu/avr/avr/iom168p.h (modified) * cpukit/score/cpu/avr/avr/iom169.h (modified) * cpukit/score/cpu/avr/avr/iom169p.h (modified) * cpukit/score/cpu/avr/avr/iom169pa.h (added) * cpukit/score/cpu/avr/avr/iom16a.h (added) * cpukit/score/cpu/avr/avr/iom16hva.h (modified) * cpukit/score/cpu/avr/avr/iom16hva2.h (added) * cpukit/score/cpu/avr/avr/iom16hvb.h (added) * cpukit/score/cpu/avr/avr/iom16m1.h (modified) * cpukit/score/cpu/avr/avr/iom16u2.h (added) * cpukit/score/cpu/avr/avr/iom16u4.h (modified) * cpukit/score/cpu/avr/avr/iom2560.h (modified) * cpukit/score/cpu/avr/avr/iom2561.h (modified) * cpukit/score/cpu/avr/avr/iom32.h (modified) * cpukit/score/cpu/avr/avr/iom323.h (modified) * cpukit/score/cpu/avr/avr/iom324.h (modified) * cpukit/score/cpu/avr/avr/iom324pa.h (added) * cpukit/score/cpu/avr/avr/iom325.h (modified) * cpukit/score/cpu/avr/avr/iom3250.h (modified) * cpukit/score/cpu/avr/avr/iom328p.h (modified) * cpukit/score/cpu/avr/avr/iom329.h (modified) * cpukit/score/cpu/avr/avr/iom3290.h (modified) * cpukit/score/cpu/avr/avr/iom32c1.h (modified) * cpukit/score/cpu/avr/avr/iom32hvb.h (modified) * cpukit/score/cpu/avr/avr/iom32m1.h (modified) * cpukit/score/cpu/avr/avr/iom32u2.h (added) * cpukit/score/cpu/avr/avr/iom32u4.h (modified) * cpukit/score/cpu/avr/avr/iom32u6.h (modified) * cpukit/score/cpu/avr/avr/iom406.h (modified) * cpukit/score/cpu/avr/avr/iom48p.h (modified) * cpukit/score/cpu/avr/avr/iom64.h (modified) * cpukit/score/cpu/avr/avr/iom640.h (modified) * cpukit/score/cpu/avr/avr/iom644.h (modified) * cpukit/score/cpu/avr/avr/iom644p.h (added) * cpukit/score/cpu/avr/avr/iom644pa.h (added) * cpukit/score/cpu/avr/avr/iom645.h (modified) * cpukit/score/cpu/avr/avr/iom6450.h (modified) * cpukit/score/cpu/avr/avr/iom649.h (modified) * cpukit/score/cpu/avr/avr/iom6490.h (modified) * cpukit/score/cpu/avr/avr/iom649p.h (added) * cpukit/score/cpu/avr/avr/iom64c1.h (modified) * cpukit/score/cpu/avr/avr/iom64hve.h (added) * cpukit/score/cpu/avr/avr/iom64m1.h (modified) * cpukit/score/cpu/avr/avr/iom8.h (modified) * cpukit/score/cpu/avr/avr/iom8515.h (modified) * cpukit/score/cpu/avr/avr/iom8535.h (modified) * cpukit/score/cpu/avr/avr/iom88.h (modified) * cpukit/score/cpu/avr/avr/iom88p.h (modified) * cpukit/score/cpu/avr/avr/iom88pa.h (added) * cpukit/score/cpu/avr/avr/iom8hva.h (modified) * cpukit/score/cpu/avr/avr/iom8u2.h (added) * cpukit/score/cpu/avr/avr/iomx8.h (modified) * cpukit/score/cpu/avr/avr/iomxx0_1.h (modified) * cpukit/score/cpu/avr/avr/iomxxhva.h (modified) * cpukit/score/cpu/avr/avr/iotn11.h (modified) * cpukit/score/cpu/avr/avr/iotn12.h (modified) * cpukit/score/cpu/avr/avr/iotn13.h (modified) * cpukit/score/cpu/avr/avr/iotn13a.h (modified) * cpukit/score/cpu/avr/avr/iotn15.h (modified) * cpukit/score/cpu/avr/avr/iotn167.h (modified) * cpukit/score/cpu/avr/avr/iotn22.h (modified) * cpukit/score/cpu/avr/avr/iotn2313a.h (added) * cpukit/score/cpu/avr/avr/iotn24a.h (added) * cpukit/score/cpu/avr/avr/iotn26.h (modified) * cpukit/score/cpu/avr/avr/iotn261a.h (added) * cpukit/score/cpu/avr/avr/iotn28.h (modified) * cpukit/score/cpu/avr/avr/iotn4313.h (added) * cpukit/score/cpu/avr/avr/iotn43u.h (modified) * cpukit/score/cpu/avr/avr/iotn44a.h (added) * cpukit/score/cpu/avr/avr/iotn461a.h (added) * cpukit/score/cpu/avr/avr/iotn48.h (modified) * cpukit/score/cpu/avr/avr/iotn861a.h (added) * cpukit/score/cpu/avr/avr/iotn87.h (modified) * cpukit/score/cpu/avr/avr/iotn88.h (modified) * cpukit/score/cpu/avr/avr/iotnx4.h (modified) * cpukit/score/cpu/avr/avr/iotnx5.h (modified) * cpukit/score/cpu/avr/avr/iotnx61.h (modified) * cpukit/score/cpu/avr/avr/iousb1286.h (modified) * cpukit/score/cpu/avr/avr/iousb1287.h (modified) * cpukit/score/cpu/avr/avr/iousb162.h (modified) * cpukit/score/cpu/avr/avr/iousb646.h (modified) * cpukit/score/cpu/avr/avr/iousb647.h (modified) * cpukit/score/cpu/avr/avr/iousb82.h (modified) * cpukit/score/cpu/avr/avr/iousbxx2.h (modified) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (modified) * cpukit/score/cpu/avr/avr/iox128a1.h (modified) * cpukit/score/cpu/avr/avr/iox128a3.h (modified) * cpukit/score/cpu/avr/avr/iox128d3.h (added) * cpukit/score/cpu/avr/avr/iox16a4.h (modified) * cpukit/score/cpu/avr/avr/iox16d4.h (modified) * cpukit/score/cpu/avr/avr/iox192a3.h (added) * cpukit/score/cpu/avr/avr/iox192d3.h (added) * cpukit/score/cpu/avr/avr/iox256a3.h (modified) * cpukit/score/cpu/avr/avr/iox256a3b.h (modified) * cpukit/score/cpu/avr/avr/iox256d3.h (added) * cpukit/score/cpu/avr/avr/iox32a4.h (modified) * cpukit/score/cpu/avr/avr/iox32d4.h (modified) * cpukit/score/cpu/avr/avr/iox64a1.h (modified) * cpukit/score/cpu/avr/avr/iox64a3.h (modified) * cpukit/score/cpu/avr/avr/iox64d3.h (added) * cpukit/score/cpu/avr/avr/lock.h (modified) * cpukit/score/cpu/avr/avr/pgmspace.h (modified) * cpukit/score/cpu/avr/avr/portpins.h (modified) * cpukit/score/cpu/avr/avr/power.h (modified) * cpukit/score/cpu/avr/avr/sfr_defs.h (modified) * cpukit/score/cpu/avr/avr/signature.h (added) * cpukit/score/cpu/avr/avr/sleep.h (modified) * cpukit/score/cpu/avr/avr/version.h (modified) * cpukit/score/cpu/avr/avr/wdt.h (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/asm.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2010-05-10 Joel Sherrill * ... Sun, 25 Apr 2010 22:17:35 GMT Joel Sherrill [ceda5c27] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/context_init.c (modified) 2010-04-25 Joel Sherrill * ... Sun, 25 Apr 2010 21:37:46 GMT Joel Sherrill [a0cb87c] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2010-04-25 Joel Sherrill * ... Sun, 25 Apr 2010 15:06:32 GMT Joel Sherrill [2146dbac] * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) 2010-04-25 Joel Sherrill * ... Sun, 25 Apr 2010 14:58:27 GMT Joel Sherrill [524055a9] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2010-04-25 Joel Sherrill * ... Tue, 20 Apr 2010 13:27:48 GMT Joel Sherrill [32eadeb] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) 2010-04-20 Allan Hessenflow * ... Sat, 17 Apr 2010 19:24:16 GMT Joel Sherrill [dace69bf] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) 2010-04-17 Allan Hessenflow * ... Sat, 17 Apr 2010 17:34:34 GMT Joel Sherrill [340d782] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) 2010-04-17 Mike Frysinger * ... Thu, 15 Apr 2010 04:51:23 GMT Ralf Corsepius [6d521f0] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) 2010-04-15 Ralf Corsépius * ... Thu, 08 Apr 2010 16:37:34 GMT Joel Sherrill [4ad55267] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) 2010-04-08 Till Straumann ... Thu, 08 Apr 2010 10:13:46 GMT Thomas Doerfler [78623bce] * cpukit/ChangeLog (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/include/rtems/score/object.h (modified) add/adapt documentation Wed, 07 Apr 2010 14:04:12 GMT Joel Sherrill [58597dd] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) 2010-04-07 Joel Sherrill * ... Sat, 27 Mar 2010 15:03:09 GMT Joel Sherrill [febaa8a] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:02:35 GMT Joel Sherrill [f086af89] * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/context.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:02:31 GMT Joel Sherrill [8eff201] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:02:26 GMT Joel Sherrill [fe31ab2] * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:02:21 GMT Joel Sherrill [5632f8d] * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/c4x/cpu_asm.S (modified) * cpukit/score/cpu/c4x/irq.c (modified) * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) * cpukit/score/cpu/nios2/irq.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:02:02 GMT Joel Sherrill [4990792] * cpukit/score/cpu/m32r/ChangeLog (modified) * cpukit/score/cpu/m32r/context_init.c (modified) * cpukit/score/cpu/m32r/context_switch.S (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/cpu_asm.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:01:57 GMT Joel Sherrill [c9f5531] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/context_switch.S (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/varvects.S (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:01:47 GMT Joel Sherrill [199041aa] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/sse_test.c (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 15:01:19 GMT Joel Sherrill [0acc9af3] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) 2010-03-27 Joel Sherrill * ... Sat, 27 Mar 2010 14:59:26 GMT Joel Sherrill [ff8dd26] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/bfin/irq.c (deleted) 2010-03-27 Joel Sherrill * ... Tue, 02 Mar 2010 16:25:06 GMT Joel Sherrill [daa0add] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) 2010-03-02 Michael Walle * cpu.c: ... Tue, 12 Jan 2010 15:03:22 GMT Thomas Doerfler [39c8fdb] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-ethernet-config.h (added) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bspopts.h.in (modified) * c/src/lib/libbsp/arm/lpc32xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-ethernet-config.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (added) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/Makefile.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/arm/shared/arm920/mmu.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (added) * c/src/lib/libcpu/arm/shared/include/cache.h (added) * c/src/lib/libcpu/arm/shared/include/cache_.h (added) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_abort.S (added) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) add support for lpc32xx Tue, 15 Dec 2009 15:14:12 GMT Thomas Doerfler [9db18dd] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) add support for ARM11, reimplement nested interrupts Fri, 04 Dec 2009 05:25:30 GMT Ralf Corsepius [5bb38e15] * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/h8300/rtems/asm.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/h8300.h (modified) * cpukit/score/cpu/m32c/varvects.S (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/cpu_asm.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/m32r.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh_io.h (modified) Whitespace removal. Fri, 04 Dec 2009 04:27:21 GMT Ralf Corsepius [42e243e] * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/idtr.S (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (modified) * cpukit/score/cpu/bfin/irq.c (modified) * cpukit/score/cpu/bfin/rtems/score/bfin.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/c4x/cpu_asm.S (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/lm32.h (modified) Whitespace removal. Wed, 02 Dec 2009 10:23:33 GMT Ralf Corsepius [46e483b8] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) 2009-12-02 Ralf Corsépius * ... Wed, 02 Dec 2009 09:48:25 GMT Ralf Corsepius [80f7732] * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/nios2.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/telnetd/des.c (modified) * cpukit/telnetd/genpw.c (modified) * cpukit/telnetd/icmds.c (modified) * cpukit/telnetd/pty.c (modified) * cpukit/telnetd/pty.h (modified) Whitespace removal. Wed, 02 Dec 2009 01:24:52 GMT Till Straumann [6c28773e] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) 2009-12-01 Till Straumann ... Mon, 30 Nov 2009 16:01:51 GMT Ralf Corsepius [05c1886] * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_arm.h (modified) * cpukit/libnetworking/rtems/bsdnet/_types.h (modified) * cpukit/libnetworking/rtems/bsdnet/servers.h (modified) * cpukit/libnetworking/rtems/dhcp.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.h (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.h (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/cbcp.c (modified) * cpukit/pppd/ccp.c (modified) * cpukit/pppd/chap.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/ipcp.h (modified) * cpukit/pppd/lcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/score/cpu/avr/avr/boot.h (modified) * cpukit/score/cpu/avr/avr/common.h (modified) * cpukit/score/cpu/avr/avr/eeprom.h (modified) * cpukit/score/cpu/avr/avr/fuse.h (modified) * cpukit/score/cpu/avr/avr/interrupt.h (modified) * cpukit/score/cpu/avr/avr/io.h (modified) * cpukit/score/cpu/avr/avr/io1200.h (modified) * cpukit/score/cpu/avr/avr/io2313.h (modified) * cpukit/score/cpu/avr/avr/io2323.h (modified) * cpukit/score/cpu/avr/avr/io2333.h (modified) * cpukit/score/cpu/avr/avr/io2343.h (modified) * cpukit/score/cpu/avr/avr/io43u32x.h (modified) * cpukit/score/cpu/avr/avr/io43u35x.h (modified) * cpukit/score/cpu/avr/avr/io4414.h (modified) * cpukit/score/cpu/avr/avr/io4433.h (modified) * cpukit/score/cpu/avr/avr/io4434.h (modified) * cpukit/score/cpu/avr/avr/io76c711.h (modified) * cpukit/score/cpu/avr/avr/io8515.h (modified) * cpukit/score/cpu/avr/avr/io8534.h (modified) * cpukit/score/cpu/avr/avr/io8535.h (modified) * cpukit/score/cpu/avr/avr/io86r401.h (modified) * cpukit/score/cpu/avr/avr/io90pwm1.h (modified) * cpukit/score/cpu/avr/avr/io90pwm216.h (modified) * cpukit/score/cpu/avr/avr/io90pwm2b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm316.h (modified) * cpukit/score/cpu/avr/avr/io90pwm3b.h (modified) * cpukit/score/cpu/avr/avr/io90pwm81.h (modified) * cpukit/score/cpu/avr/avr/io90pwmx.h (modified) * cpukit/score/cpu/avr/avr/io90scr100.h (modified) * cpukit/score/cpu/avr/avr/ioa6289.h (modified) * cpukit/score/cpu/avr/avr/ioat94k.h (modified) * cpukit/score/cpu/avr/avr/iocan128.h (modified) * cpukit/score/cpu/avr/avr/iocan32.h (modified) * cpukit/score/cpu/avr/avr/iocan64.h (modified) * cpukit/score/cpu/avr/avr/iocanxx.h (modified) * cpukit/score/cpu/avr/avr/iom103.h (modified) * cpukit/score/cpu/avr/avr/iom128.h (modified) * cpukit/score/cpu/avr/avr/iom1280.h (modified) * cpukit/score/cpu/avr/avr/iom1281.h (modified) * cpukit/score/cpu/avr/avr/iom128rfa1.h (modified) * cpukit/score/cpu/avr/avr/iom16.h (modified) * cpukit/score/cpu/avr/avr/iom161.h (modified) * cpukit/score/cpu/avr/avr/iom162.h (modified) * cpukit/score/cpu/avr/avr/iom163.h (modified) * cpukit/score/cpu/avr/avr/iom164.h (modified) * cpukit/score/cpu/avr/avr/iom165.h (modified) * cpukit/score/cpu/avr/avr/iom165p.h (modified) * cpukit/score/cpu/avr/avr/iom168.h (modified) * cpukit/score/cpu/avr/avr/iom168p.h (modified) * cpukit/score/cpu/avr/avr/iom169.h (modified) * cpukit/score/cpu/avr/avr/iom169p.h (modified) * cpukit/score/cpu/avr/avr/iom16hva.h (modified) * cpukit/score/cpu/avr/avr/iom16m1.h (modified) * cpukit/score/cpu/avr/avr/iom16u4.h (modified) * cpukit/score/cpu/avr/avr/iom2560.h (modified) * cpukit/score/cpu/avr/avr/iom2561.h (modified) * cpukit/score/cpu/avr/avr/iom32.h (modified) * cpukit/score/cpu/avr/avr/iom323.h (modified) * cpukit/score/cpu/avr/avr/iom324.h (modified) * cpukit/score/cpu/avr/avr/iom325.h (modified) * cpukit/score/cpu/avr/avr/iom3250.h (modified) * cpukit/score/cpu/avr/avr/iom328p.h (modified) * cpukit/score/cpu/avr/avr/iom329.h (modified) * cpukit/score/cpu/avr/avr/iom3290.h (modified) * cpukit/score/cpu/avr/avr/iom32c1.h (modified) * cpukit/score/cpu/avr/avr/iom32hvb.h (modified) * cpukit/score/cpu/avr/avr/iom32m1.h (modified) * cpukit/score/cpu/avr/avr/iom32u4.h (modified) * cpukit/score/cpu/avr/avr/iom32u6.h (modified) * cpukit/score/cpu/avr/avr/iom406.h (modified) * cpukit/score/cpu/avr/avr/iom48p.h (modified) * cpukit/score/cpu/avr/avr/iom64.h (modified) * cpukit/score/cpu/avr/avr/iom640.h (modified) * cpukit/score/cpu/avr/avr/iom644.h (modified) * cpukit/score/cpu/avr/avr/iom645.h (modified) * cpukit/score/cpu/avr/avr/iom6450.h (modified) * cpukit/score/cpu/avr/avr/iom649.h (modified) * cpukit/score/cpu/avr/avr/iom6490.h (modified) * cpukit/score/cpu/avr/avr/iom64c1.h (modified) * cpukit/score/cpu/avr/avr/iom64m1.h (modified) * cpukit/score/cpu/avr/avr/iom8.h (modified) * cpukit/score/cpu/avr/avr/iom8515.h (modified) * cpukit/score/cpu/avr/avr/iom8535.h (modified) * cpukit/score/cpu/avr/avr/iom88.h (modified) * cpukit/score/cpu/avr/avr/iom88p.h (modified) * cpukit/score/cpu/avr/avr/iom8hva.h (modified) * cpukit/score/cpu/avr/avr/iomx8.h (modified) * cpukit/score/cpu/avr/avr/iomxx0_1.h (modified) * cpukit/score/cpu/avr/avr/iomxxhva.h (modified) * cpukit/score/cpu/avr/avr/iotn11.h (modified) * cpukit/score/cpu/avr/avr/iotn12.h (modified) * cpukit/score/cpu/avr/avr/iotn13.h (modified) * cpukit/score/cpu/avr/avr/iotn13a.h (modified) * cpukit/score/cpu/avr/avr/iotn15.h (modified) * cpukit/score/cpu/avr/avr/iotn167.h (modified) * cpukit/score/cpu/avr/avr/iotn22.h (modified) * cpukit/score/cpu/avr/avr/iotn26.h (modified) * cpukit/score/cpu/avr/avr/iotn28.h (modified) * cpukit/score/cpu/avr/avr/iotn43u.h (modified) * cpukit/score/cpu/avr/avr/iotn48.h (modified) * cpukit/score/cpu/avr/avr/iotn87.h (modified) * cpukit/score/cpu/avr/avr/iotn88.h (modified) * cpukit/score/cpu/avr/avr/iotnx4.h (modified) * cpukit/score/cpu/avr/avr/iotnx5.h (modified) * cpukit/score/cpu/avr/avr/iotnx61.h (modified) * cpukit/score/cpu/avr/avr/iousb1286.h (modified) * cpukit/score/cpu/avr/avr/iousb1287.h (modified) * cpukit/score/cpu/avr/avr/iousb162.h (modified) * cpukit/score/cpu/avr/avr/iousb646.h (modified) * cpukit/score/cpu/avr/avr/iousb647.h (modified) * cpukit/score/cpu/avr/avr/iousb82.h (modified) * cpukit/score/cpu/avr/avr/iousbxx2.h (modified) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (modified) * cpukit/score/cpu/avr/avr/iox128a1.h (modified) * cpukit/score/cpu/avr/avr/iox128a3.h (modified) * cpukit/score/cpu/avr/avr/iox16a4.h (modified) * cpukit/score/cpu/avr/avr/iox16d4.h (modified) * cpukit/score/cpu/avr/avr/iox256a3.h (modified) * cpukit/score/cpu/avr/avr/iox256a3b.h (modified) * cpukit/score/cpu/avr/avr/iox32a4.h (modified) * cpukit/score/cpu/avr/avr/iox32d4.h (modified) * cpukit/score/cpu/avr/avr/iox64a1.h (modified) * cpukit/score/cpu/avr/avr/iox64a3.h (modified) * cpukit/score/cpu/avr/avr/lock.h (modified) * cpukit/score/cpu/avr/avr/pgmspace.h (modified) * cpukit/score/cpu/avr/avr/power.h (modified) * cpukit/score/cpu/avr/avr/sfr_defs.h (modified) * cpukit/score/cpu/avr/avr/sleep.h (modified) * cpukit/score/cpu/avr/avr/wdt.h (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/asm.h (modified) * cpukit/score/cpu/avr/rtems/score/avr.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) Whitespace removal. Sun, 29 Nov 2009 13:51:53 GMT Ralf Corsepius [28352fae] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/c4x/rtems/score/c4x.h (modified) * cpukit/score/cpu/c4x/rtems/score/cpu.h (modified) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/m32c.h (modified) * cpukit/score/cpu/m32c/varvects.h (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/pheapresizeblock.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecgreaterthan.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64divide.c (modified) * cpukit/score/src/ts64getnanoseconds.c (modified) * cpukit/score/src/ts64toticks.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddapiset.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/userextthreadswitch.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdogreport.c (modified) * cpukit/score/src/watchdogtickle.c (modified) Whitespace removal. Sat, 28 Nov 2009 06:15:55 GMT Ralf Corsepius [e447c7d2] * cpukit/automake/subdirs.am (modified) * cpukit/itron/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) Whitespace removal. Tue, 10 Nov 2009 06:55:28 GMT Till Straumann [b02f4cc1] * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/sse_test.c (added) 2009-11-09 Till Straumann ... Tue, 10 Nov 2009 04:02:25 GMT Till Straumann [70f6ff7] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) 2009-11-09 Till Straumann ... Fri, 30 Oct 2009 19:28:46 GMT Thomas Doerfler [3fcc78ae] * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) move timebase access functions from cpukit to libcpu Thu, 29 Oct 2009 16:29:46 GMT Till Straumann [b01d7c7] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) 2009-10-29 Till Straumann ... Thu, 29 Oct 2009 03:59:17 GMT Till Straumann [78667e3] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) 2009-10-28 Till Straumann ... Thu, 29 Oct 2009 03:57:05 GMT Till Straumann [af3bf16] * cpukit/ChangeLog (modified) * cpukit/score/cpu/i386/ChangeLog (modified) 2009-10-28 Till Straumann ... Thu, 29 Oct 2009 03:15:03 GMT Till Straumann [a6d48e3] * cpukit/ChangeLog (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) 2009-10-28 Till Straumann ... Wed, 28 Oct 2009 02:45:24 GMT Till Straumann [16e1b45] * cpukit/ChangeLog (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) 2009-10-27 Till Straumann ... Thu, 22 Oct 2009 17:10:59 GMT Ralf Corsepius [4ef27382] * cpukit/ChangeLog (modified) * cpukit/score/cpu/Makefile.am (modified) 2009-10-22 Ralf Corsépius * ... Wed, 21 Oct 2009 13:19:09 GMT Thomas Doerfler [2067679] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) * rtems/powerpc/registers.h: Added defines DEAR_BOOKE and DEAR_405. ... Tue, 20 Oct 2009 14:51:37 GMT Till Straumann [020363d] * cpukit/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) 2009-10-20 Till Straumann ... Wed, 14 Oct 2009 12:16:34 GMT Ralf Corsepius [fbfe76d] * cpukit/score/cpu/Makefile.am (modified) Remove unix subdir. Wed, 14 Oct 2009 12:15:21 GMT Ralf Corsepius [25bcc34d] * cpukit/score/cpu/unix/.cvsignore (deleted) * cpukit/score/cpu/unix/ChangeLog (deleted) * cpukit/score/cpu/unix/Makefile.am (deleted) * cpukit/score/cpu/unix/cpu.c (deleted) * cpukit/score/cpu/unix/preinstall.am (deleted) * cpukit/score/cpu/unix/rtems/asm.h (deleted) * cpukit/score/cpu/unix/rtems/score/cpu.h (deleted) * cpukit/score/cpu/unix/rtems/score/types.h (deleted) * cpukit/score/cpu/unix/rtems/score/unix.h (deleted) Remove (Abandoned) Thu, 01 Oct 2009 21:47:42 GMT Joel Sherrill [13c5cea] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) 2009-10-01 Joel Sherrill * ... Thu, 01 Oct 2009 12:57:30 GMT Joel Sherrill [f98ce8b8] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) 2009-10-01 Joel Sherrill * ... Sun, 27 Sep 2009 18:56:47 GMT Joel Sherrill [15fef93] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) 2009-09-27 Joel Sherrill * ... Fri, 25 Sep 2009 12:07:54 GMT Joel Sherrill [1154ced] * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) 2009-09-25 Joel Sherrill * ... Fri, 18 Sep 2009 08:07:23 GMT Thomas Doerfler [5e61c80] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/arm_exc_handler_low.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * rtems/score/cpu.h: Fix for inline asm in _CPU_Fatal_halt(). ... Fri, 11 Sep 2009 00:08:50 GMT Joel Sherrill [97f46a8] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) 2009-09-10 Joel Sherrill * ... Mon, 24 Aug 2009 10:29:10 GMT Thomas Doerfler [da42259] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) Define M68K_FP_STATE_SIZE also if used in assembler files. Wed, 19 Aug 2009 16:39:05 GMT Joel Sherrill [db0df7b] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) 2009-08-19 Joel Sherrill * ... Tue, 11 Aug 2009 17:03:01 GMT Joel Sherrill [cdfe85a7] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-08-11 Josh Switnicki ... Thu, 06 Aug 2009 14:52:07 GMT Joel Sherrill [04a62dce] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/avr/boot.h (added) * cpukit/score/cpu/avr/avr/common.h (added) * cpukit/score/cpu/avr/avr/crc16.h (added) * cpukit/score/cpu/avr/avr/delay.h (added) * cpukit/score/cpu/avr/avr/eeprom.h (added) * cpukit/score/cpu/avr/avr/fuse.h (added) * cpukit/score/cpu/avr/avr/interrupt.h (added) * cpukit/score/cpu/avr/avr/io.h (added) * cpukit/score/cpu/avr/avr/io1200.h (added) * cpukit/score/cpu/avr/avr/io2313.h (added) * cpukit/score/cpu/avr/avr/io2323.h (added) * cpukit/score/cpu/avr/avr/io2333.h (added) * cpukit/score/cpu/avr/avr/io2343.h (added) * cpukit/score/cpu/avr/avr/io43u32x.h (added) * cpukit/score/cpu/avr/avr/io43u35x.h (added) * cpukit/score/cpu/avr/avr/io4414.h (added) * cpukit/score/cpu/avr/avr/io4433.h (added) * cpukit/score/cpu/avr/avr/io4434.h (added) * cpukit/score/cpu/avr/avr/io76c711.h (added) * cpukit/score/cpu/avr/avr/io8515.h (added) * cpukit/score/cpu/avr/avr/io8534.h (added) * cpukit/score/cpu/avr/avr/io8535.h (added) * cpukit/score/cpu/avr/avr/io86r401.h (added) * cpukit/score/cpu/avr/avr/io90pwm1.h (added) * cpukit/score/cpu/avr/avr/io90pwm216.h (added) * cpukit/score/cpu/avr/avr/io90pwm2b.h (added) * cpukit/score/cpu/avr/avr/io90pwm316.h (added) * cpukit/score/cpu/avr/avr/io90pwm3b.h (added) * cpukit/score/cpu/avr/avr/io90pwm81.h (added) * cpukit/score/cpu/avr/avr/io90pwmx.h (added) * cpukit/score/cpu/avr/avr/io90scr100.h (added) * cpukit/score/cpu/avr/avr/ioa6289.h (added) * cpukit/score/cpu/avr/avr/ioat94k.h (added) * cpukit/score/cpu/avr/avr/iocan128.h (added) * cpukit/score/cpu/avr/avr/iocan32.h (added) * cpukit/score/cpu/avr/avr/iocan64.h (added) * cpukit/score/cpu/avr/avr/iocanxx.h (added) * cpukit/score/cpu/avr/avr/iom103.h (added) * cpukit/score/cpu/avr/avr/iom128.h (added) * cpukit/score/cpu/avr/avr/iom1280.h (added) * cpukit/score/cpu/avr/avr/iom1281.h (added) * cpukit/score/cpu/avr/avr/iom1284p.h (added) * cpukit/score/cpu/avr/avr/iom128rfa1.h (added) * cpukit/score/cpu/avr/avr/iom16.h (added) * cpukit/score/cpu/avr/avr/iom161.h (added) * cpukit/score/cpu/avr/avr/iom162.h (added) * cpukit/score/cpu/avr/avr/iom163.h (added) * cpukit/score/cpu/avr/avr/iom164.h (added) * cpukit/score/cpu/avr/avr/iom165.h (added) * cpukit/score/cpu/avr/avr/iom165p.h (added) * cpukit/score/cpu/avr/avr/iom168.h (added) * cpukit/score/cpu/avr/avr/iom168p.h (added) * cpukit/score/cpu/avr/avr/iom169.h (added) * cpukit/score/cpu/avr/avr/iom169p.h (added) * cpukit/score/cpu/avr/avr/iom16hva.h (added) * cpukit/score/cpu/avr/avr/iom16m1.h (added) * cpukit/score/cpu/avr/avr/iom16u4.h (added) * cpukit/score/cpu/avr/avr/iom2560.h (added) * cpukit/score/cpu/avr/avr/iom2561.h (added) * cpukit/score/cpu/avr/avr/iom32.h (added) * cpukit/score/cpu/avr/avr/iom323.h (added) * cpukit/score/cpu/avr/avr/iom324.h (added) * cpukit/score/cpu/avr/avr/iom325.h (added) * cpukit/score/cpu/avr/avr/iom3250.h (added) * cpukit/score/cpu/avr/avr/iom328p.h (added) * cpukit/score/cpu/avr/avr/iom329.h (added) * cpukit/score/cpu/avr/avr/iom3290.h (added) * cpukit/score/cpu/avr/avr/iom32c1.h (added) * cpukit/score/cpu/avr/avr/iom32hvb.h (added) * cpukit/score/cpu/avr/avr/iom32m1.h (added) * cpukit/score/cpu/avr/avr/iom32u4.h (added) * cpukit/score/cpu/avr/avr/iom32u6.h (added) * cpukit/score/cpu/avr/avr/iom406.h (added) * cpukit/score/cpu/avr/avr/iom48.h (added) * cpukit/score/cpu/avr/avr/iom48p.h (added) * cpukit/score/cpu/avr/avr/iom64.h (added) * cpukit/score/cpu/avr/avr/iom640.h (added) * cpukit/score/cpu/avr/avr/iom644.h (added) * cpukit/score/cpu/avr/avr/iom645.h (added) * cpukit/score/cpu/avr/avr/iom6450.h (added) * cpukit/score/cpu/avr/avr/iom649.h (added) * cpukit/score/cpu/avr/avr/iom6490.h (added) * cpukit/score/cpu/avr/avr/iom64c1.h (added) * cpukit/score/cpu/avr/avr/iom64m1.h (added) * cpukit/score/cpu/avr/avr/iom8.h (added) * cpukit/score/cpu/avr/avr/iom8515.h (added) * cpukit/score/cpu/avr/avr/iom8535.h (added) * cpukit/score/cpu/avr/avr/iom88.h (added) * cpukit/score/cpu/avr/avr/iom88p.h (added) * cpukit/score/cpu/avr/avr/iom8hva.h (added) * cpukit/score/cpu/avr/avr/iomx8.h (added) * cpukit/score/cpu/avr/avr/iomxx0_1.h (added) * cpukit/score/cpu/avr/avr/iomxx4.h (added) * cpukit/score/cpu/avr/avr/iomxxhva.h (added) * cpukit/score/cpu/avr/avr/iotn11.h (added) * cpukit/score/cpu/avr/avr/iotn12.h (added) * cpukit/score/cpu/avr/avr/iotn13.h (added) * cpukit/score/cpu/avr/avr/iotn13a.h (added) * cpukit/score/cpu/avr/avr/iotn15.h (added) * cpukit/score/cpu/avr/avr/iotn167.h (added) * cpukit/score/cpu/avr/avr/iotn22.h (added) * cpukit/score/cpu/avr/avr/iotn2313.h (added) * cpukit/score/cpu/avr/avr/iotn24.h (added) * cpukit/score/cpu/avr/avr/iotn25.h (added) * cpukit/score/cpu/avr/avr/iotn26.h (added) * cpukit/score/cpu/avr/avr/iotn261.h (added) * cpukit/score/cpu/avr/avr/iotn28.h (added) * cpukit/score/cpu/avr/avr/iotn43u.h (added) * cpukit/score/cpu/avr/avr/iotn44.h (added) * cpukit/score/cpu/avr/avr/iotn45.h (added) * cpukit/score/cpu/avr/avr/iotn461.h (added) * cpukit/score/cpu/avr/avr/iotn48.h (added) * cpukit/score/cpu/avr/avr/iotn84.h (added) * cpukit/score/cpu/avr/avr/iotn85.h (added) * cpukit/score/cpu/avr/avr/iotn861.h (added) * cpukit/score/cpu/avr/avr/iotn87.h (added) * cpukit/score/cpu/avr/avr/iotn88.h (added) * cpukit/score/cpu/avr/avr/iotnx4.h (added) * cpukit/score/cpu/avr/avr/iotnx5.h (added) * cpukit/score/cpu/avr/avr/iotnx61.h (added) * cpukit/score/cpu/avr/avr/iousb1286.h (added) * cpukit/score/cpu/avr/avr/iousb1287.h (added) * cpukit/score/cpu/avr/avr/iousb162.h (added) * cpukit/score/cpu/avr/avr/iousb646.h (added) * cpukit/score/cpu/avr/avr/iousb647.h (added) * cpukit/score/cpu/avr/avr/iousb82.h (added) * cpukit/score/cpu/avr/avr/iousbxx2.h (added) * cpukit/score/cpu/avr/avr/iousbxx6_7.h (added) * cpukit/score/cpu/avr/avr/iox128a1.h (added) * cpukit/score/cpu/avr/avr/iox128a3.h (added) * cpukit/score/cpu/avr/avr/iox16a4.h (added) * cpukit/score/cpu/avr/avr/iox16d4.h (added) * cpukit/score/cpu/avr/avr/iox256a3.h (added) * cpukit/score/cpu/avr/avr/iox256a3b.h (added) * cpukit/score/cpu/avr/avr/iox32a4.h (added) * cpukit/score/cpu/avr/avr/iox32d4.h (added) * cpukit/score/cpu/avr/avr/iox64a1.h (added) * cpukit/score/cpu/avr/avr/iox64a3.h (added) * cpukit/score/cpu/avr/avr/lock.h (added) * cpukit/score/cpu/avr/avr/parity.h (added) * cpukit/score/cpu/avr/avr/pgmspace.h (added) * cpukit/score/cpu/avr/avr/portpins.h (added) * cpukit/score/cpu/avr/avr/power.h (added) * cpukit/score/cpu/avr/avr/sfr_defs.h (added) * cpukit/score/cpu/avr/avr/signal.h (added) * cpukit/score/cpu/avr/avr/sleep.h (added) * cpukit/score/cpu/avr/avr/version.h (added) * cpukit/score/cpu/avr/avr/wdt.h (added) * cpukit/score/cpu/avr/preinstall.am (modified) 2009-08-05 Josh Switnicki ... Mon, 03 Aug 2009 14:22:10 GMT Joel Sherrill [8960aa54] * cpukit/ChangeLog (modified) * cpukit/score/cpu/Makefile.am (modified) 2009-08-03 Roger Dahlkvist * ... Tue, 28 Jul 2009 23:14:23 GMT Joel Sherrill [b32020b] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-07-28 Joel Sherrill * ... Thu, 23 Jul 2009 17:40:06 GMT Joel Sherrill [3da35a18] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) 2009-07-23 Joel Sherrill * ... Fri, 17 Jul 2009 18:33:35 GMT Joel Sherrill [b4404843] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) 2009-07-17 Josh Switnicki ... Fri, 17 Jul 2009 15:16:50 GMT Thomas Doerfler [9364cf66] * c/src/lib/libbsp/arm/lpc24xx/include/i2c.h (added) * c/src/lib/libbsp/arm/lpc24xx/include/idle.h (added) * c/src/lib/libbsp/arm/lpc24xx/include/io.h (added) * c/src/lib/libbsp/arm/lpc24xx/misc/idle.c (added) * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (added) * c/src/lib/libbsp/shared/include/stackalloc.h (added) * c/src/lib/libbsp/shared/src/stackalloc.c (added) * cpukit/score/cpu/arm/arm_exc_handler_high.c (added) * cpukit/score/cpu/arm/arm_exc_handler_low.S (added) * cpukit/score/cpu/arm/arm_exc_interrupt.S (added) adding lpc24xx BSP parts Fri, 17 Jul 2009 13:59:43 GMT Thomas Doerfler [ebe76f94] * cpukit/score/cpu/arm/thumb/.cvsignore (deleted) * cpukit/score/cpu/arm/thumb/ChangeLog (deleted) * cpukit/score/cpu/arm/thumb/thumb_isr.c (deleted) removing unneeded files Fri, 17 Jul 2009 13:50:31 GMT Thomas Doerfler [632e4306] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/types.h (modified) exception handler maintenance Fri, 10 Jul 2009 19:07:54 GMT Joel Sherrill [36c2586] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu_asm.S (modified) 2009-07-09 Josh Switnicki ... Mon, 06 Jul 2009 15:36:23 GMT Joel Sherrill [7c46cf5] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/cpu_asm.S (moved) * cpukit/score/cpu/avr/rtems/asm.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-07-03 Josh Switnicki * ... Wed, 17 Jun 2009 21:15:16 GMT Chris Johns [bf7cc57] * cpukit/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) 2009-06-18 Chris Johns * ... Sun, 14 Jun 2009 23:33:44 GMT Chris Johns [3967dbe4] * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) Fixed nested includes. Sun, 14 Jun 2009 23:31:05 GMT Chris Johns [4896ab5d] * cpukit/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) 2009-06-15 Chris Johns * ... Wed, 27 May 2009 12:05:19 GMT Joel Sherrill [3fb3de1] * cpukit/score/cpu/bfin/ChangeLog (modified) PR fixed. Wed, 27 May 2009 12:01:59 GMT Joel Sherrill [c7935a4a] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) 2009-05-25 Allan Hessenflow PR ... Fri, 15 May 2009 07:20:38 GMT Thomas Doerfler [3b7e9bc] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) cpu.c, cpu_asm.S, rtems/score/cpu.h: Cleanup of the floating point ... Tue, 05 May 2009 21:17:11 GMT Joel Sherrill [e8de5c7] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-05-05 Joel Sherrill * ... Tue, 05 May 2009 19:37:10 GMT Joel Sherrill [4848b56] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) 2009-05-05 Joel Sherrill * ... Tue, 05 May 2009 14:19:58 GMT Joel Sherrill [af2b90d] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) 2009-05-05 Michael Walle * ... Tue, 05 May 2009 01:11:05 GMT Joel Sherrill [6eae3bdd] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-05-04 Joel Sherrill * ... Mon, 04 May 2009 20:34:42 GMT Joel Sherrill [aaa5c0d] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu_asm.c (modified) 2009-05-04 Joel Sherrill * ... Tue, 14 Apr 2009 13:44:29 GMT Joel Sherrill [7c4c284c] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (added) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) 2009-04-14 Michael Walle * cpu.h: ... Mon, 06 Apr 2009 21:23:51 GMT Joel Sherrill [504fadb] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) 2009-04-06 Michael Walle * ... Thu, 12 Mar 2009 14:16:50 GMT Joel Sherrill [0067feb] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2009-03-12 Joel Sherrill ... Mon, 02 Mar 2009 18:34:12 GMT Joel Sherrill [b7f49f7] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 12:12:17 GMT Joel Sherrill [f547bc8] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) 2009-03-02 Joel Sherrill * ... Fri, 27 Feb 2009 18:19:33 GMT Joel Sherrill [fd234b8] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 11:06:21 GMT Thomas Doerfler [cd4ed38] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * rtems/powerpc/registers.h: Added Freescale Book E Implementation ... Tue, 17 Feb 2009 20:39:44 GMT Joel Sherrill [94dd4f6] * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) 2009-02-17 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:55 GMT Joel Sherrill [cca8379] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:54 GMT Joel Sherrill [59b68bd] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:36 GMT Joel Sherrill [8bbead13] * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu.c (modified) 2009-02-12 Joel Sherrill * ... Wed, 11 Feb 2009 21:45:05 GMT Joel Sherrill [c03e2bc] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/c4x/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/ChangeLog (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 21:44:59 GMT Joel Sherrill [ef1be69] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:35:30 GMT Joel Sherrill [9cf17fb] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:35:09 GMT Joel Sherrill [ef47bc78] * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ...
