# # ChangeLog for cpukit/score/cpu in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 18:48:00 Thu, 27 Aug 2015 18:19:24 GMT Sudarshan Rajagopalan [7263a50] * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) Fix exception handler for supporting FPU Tue, 01 Sep 2015 07:47:12 GMT Sebastian Huber [95b43d0] * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) arm: Replace __sync_synchronize() implementation Tue, 01 Sep 2015 07:42:46 GMT Sebastian Huber [39e3e20] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Use compiler memory barrier by default Sat, 01 Aug 2015 10:43:12 GMT Jan Sommer [7e798b4] * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (added) Add __synch_synchronize function for arm Fixes link failure when ... Fri, 24 Jul 2015 08:47:25 GMT Sebastian Huber [f7d95581] * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) m68k: Include proper header file Thu, 23 Jul 2015 18:34:19 GMT Sebastian Huber [98a41f41] * cpukit/score/cpu/arm/__tls_get_addr.c (modified) arm: Include proper header file Thu, 16 Jul 2015 18:15:10 GMT Joel Sherrill [db01d0c] * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64/rtems/score/cpu.h: Delete dead declaration Wed, 15 Jul 2015 08:51:12 GMT Sebastian Huber [93f5adb] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Do not use the ATB for e500 multilib The e500v1 has no ... Wed, 15 Jul 2015 06:55:42 GMT Nick Withers [e2fcb7d] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix _CPU_Counter_read() The mftb is not available on Book ... Thu, 02 Jul 2015 11:11:14 GMT Sebastian Huber [4c68431] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add BUCSR register defines Thu, 25 Jun 2015 12:11:53 GMT Sebastian Huber [48fed9a] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/corespinlockrelease.c (modified) score: Simplify Drop the ... Mon, 15 Jun 2015 18:45:56 GMT Sebastian Huber [9d838902] * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) arm: Implement _CPU_ISR_Get_level() for ARMv7-M Sat, 30 May 2015 15:48:27 GMT Sebastian Huber [a51b352] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Add SPARC_USE_SAFE_FP_SUPPORT The SPARC ABI is a bit special ... Tue, 02 Jun 2015 19:43:54 GMT Sebastian Huber [335e5ca] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Add Thread_Control::is_fp Store the floating-point unit ... Fri, 29 May 2015 13:54:27 GMT Alexander Krutwig [2764bd43] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Disable FPU in interrupt context Update #2270. Fri, 29 May 2015 13:54:29 GMT Sebastian Huber [1f6cdba6] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Remove superfluous FP enable The FP context save/restore ... Fri, 29 May 2015 13:54:28 GMT Sebastian Huber [8a1dc71b] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Avoid new window for FP save/restore Update #2270. Fri, 29 May 2015 08:18:19 GMT Alexander Krutwig [4a5a4504] * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Improve _CPU_Context_validate() Write the pattern only once ... Tue, 26 May 2015 12:13:44 GMT Sebastian Huber [76030c7] * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Add static assertion Tue, 26 May 2015 12:09:11 GMT Sebastian Huber [422de7f7] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc: Delete unused CONTEXT_CONTROL_SIZE Tue, 26 May 2015 12:08:11 GMT Sebastian Huber [139c0dc] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc: Delete unused ISF_STACK_FRAME_OFFSET Tue, 26 May 2015 12:03:35 GMT Sebastian Huber [fedc6828] * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Add static offset assertions Thu, 21 May 2015 16:52:56 GMT Hesham ALMatary [66a5000d] * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (added) * cpukit/score/cpu/epiphany/cpu.c (added) * cpukit/score/cpu/epiphany/epiphany-context-initialize.c (added) * cpukit/score/cpu/epiphany/epiphany-context-switch.S (added) * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (added) * cpukit/score/cpu/epiphany/preinstall.am (added) * cpukit/score/cpu/epiphany/rtems/asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany.h (added) * cpukit/score/cpu/epiphany/rtems/score/types.h (added) cpukit: Add Epiphany architecture port v4 Fri, 24 Apr 2015 14:05:50 GMT Alexander Krutwig [1c59cad] * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (added) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (added) sparc: Add support for sptests/spcontext01 Implement ... Fri, 17 Apr 2015 14:45:05 GMT Joel Sherrill [c5d86ec0] * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (modified) or1k-utility.h: Add missing end of C++ header pattern closes 2326. Tue, 17 Mar 2015 14:02:59 GMT Daniel Krueger [a6c5a7e0] * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Align ARM exception frame to 8 bytes The stack pointer must be ... Thu, 02 Apr 2015 13:11:26 GMT Hesham ALMatary [1c846616] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (modified) or1k: Send halt signal to or1k simulators when rtems terminates Wed, 25 Mar 2015 10:40:08 GMT Sebastian Huber [cb4dd48] * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Ensure interrupt service after ISR enable Fri, 20 Mar 2015 13:09:26 GMT Sebastian Huber [d4edbdbc] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (modified) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (modified) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn-shell.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap-shell.h (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rap.h (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-chain-iterator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-find-file.h (modified) * cpukit/libdl/rtl-fwd.h (modified) * cpukit/libdl/rtl-indirect-ptr.h (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-cache.h (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj-comp.h (modified) * cpukit/libdl/rtl-obj-fwd.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-shell.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-trace.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unresolved.h (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * testsuites/psxtests/psxclock01/init.c (modified) * testsuites/sptests/spclock_err01/delay.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spclock_err01/system.h (modified) * testsuites/sptests/spevent_err03/init.c (modified) * testsuites/sptests/spevent_err03/system.h (modified) * testsuites/sptests/spintr_err01/init.c (modified) * testsuites/sptests/spintr_err01/isr.c (modified) * testsuites/sptests/spintr_err01/system.h (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) * testsuites/sptests/spmsgq_err01/system.h (modified) * testsuites/sptests/spmsgq_err02/init.c (modified) * testsuites/sptests/spmsgq_err02/system.h (modified) * testsuites/sptests/spmsgq_err02/task3.c (modified) * testsuites/sptests/spport_err01/init.c (modified) * testsuites/sptests/spport_err01/system.h (modified) * testsuites/sptests/spratemon_err01/init.c (modified) * testsuites/sptests/spratemon_err01/screen10.c (modified) * testsuites/sptests/spratemon_err01/system.h (modified) * testsuites/sptests/spratemon_err01/task4.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/init.c (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/spsem_err02/task2.c (modified) * testsuites/sptests/spsignal_err01/init.c (modified) * testsuites/sptests/spsignal_err01/isr.c (modified) * testsuites/sptests/spsignal_err01/system.h (modified) * testsuites/sptests/sptask_err01/init.c (modified) * testsuites/sptests/sptask_err01/system.h (modified) * testsuites/sptests/sptask_err01/task2.c (modified) * testsuites/sptests/sptask_err02/init.c (modified) * testsuites/sptests/sptask_err02/system.h (modified) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptask_err03/system.h (modified) * testsuites/sptests/sptask_err04/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) Replace www.rtems.com with www.rtems.org Mon, 16 Mar 2015 20:15:55 GMT Gedare Bloom [46d3c6d8] * cpukit/score/cpu/arm/rtems/score/types.h (modified) * cpukit/score/cpu/avr/rtems/score/types.h (modified) * cpukit/score/cpu/bfin/rtems/score/types.h (modified) * cpukit/score/cpu/h8300/rtems/score/types.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/lm32/rtems/score/types.h (modified) * cpukit/score/cpu/m32c/rtems/score/types.h (modified) * cpukit/score/cpu/m32r/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/moxie/rtems/score/types.h (modified) * cpukit/score/cpu/nios2/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/or1k/rtems/score/types.h (modified) * cpukit/score/cpu/powerpc/rtems/score/types.h (modified) * cpukit/score/cpu/sh/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) * cpukit/score/cpu/v850/rtems/score/types.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) cpukit: add and use CPU_Uint32ptr type Fri, 13 Mar 2015 19:21:40 GMT Hesham ALMatary [a764d673] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/or1k: Fix warnings. Add missing prototypes Closes #2304 Tue, 10 Mar 2015 17:39:59 GMT Joel Sherrill [bdf23b6c] * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture-cli.h (modified) * cpukit/libmisc/capture/capture_support.c (modified) * cpukit/libmisc/fb/fb.h (modified) * cpukit/libmisc/fb/mw_uid.c (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coremutexsurrender.c (modified) cpukit: Remove old DESCRIPTION: in comments These were remnants of ... Sun, 08 Mar 2015 19:08:31 GMT Joel Sherrill [ef598c37] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) or1k/rtems/score/cpu.h: Add no_return attribute to _CPU_Context_restore Sun, 08 Mar 2015 18:52:33 GMT Joel Sherrill [4f4e7bb6] * cpukit/score/cpu/sh/context.c (modified) cpukit/score/cpu/sh/context.c: Correct name of _CPU_Context_switch Sun, 08 Mar 2015 18:52:00 GMT Joel Sherrill [2a11a46f] * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) or1k: Correct _CPU_Thread_Idle_body prototype Wed, 04 Mar 2015 15:13:49 GMT Sebastian Huber [8ac3549] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITY Wed, 04 Mar 2015 23:15:41 GMT Hesham ALMatary [3358d62] * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/preinstall.am (modified) * cpukit/score/cpu/or1k/rtems/score/cpuatomic.h (added) score/cpu/or1k: Add cpuatomic.h to fix broken build. ... Tue, 03 Mar 2015 20:09:41 GMT Hesham ALMatary [262a0d7] * cpukit/score/cpu/or1k/or1k-exception-default.c (modified) or1k/or1k-exception-default.c: Eliminate dependency on BSP provided ... Thu, 26 Feb 2015 17:39:05 GMT Martin Galvan [63e91fe6] * cpukit/score/cpu/arm/armv4-exception-default.S (modified) ARM: Fix _ARMV4_Exception_fiq_default In ... Mon, 23 Feb 2015 20:42:59 GMT Gedare Bloom [9d090fb7] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/start/bspinit.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/start/bspinit.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) sparc64: fix copyright notices. The sparc64 port had some incorrect ... Thu, 19 Feb 2015 20:48:47 GMT Gedare Bloom [7f1bb40a] * cpukit/score/cpu/bfin/cpu_asm.S (modified) bfin: do not reset dispatch needed Closes #2148 Fix suggested in ... Mon, 16 Feb 2015 10:55:03 GMT Sebastian Huber [c34f94f7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/shared/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) score: Add _CPU_SMP_Prepare_start_multitasking() Update #2268. Tue, 10 Feb 2015 20:18:27 GMT Hesham ALMatary [1c7ee73] * cpukit/score/cpu/or1k/cpu.c (modified) or1k/cpu.c: Eliminate dependency on BSP provided header Tue, 20 Jan 2015 13:01:50 GMT Sebastian Huber [60d39b66] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix AltiVec VSCR save/restore Tue, 23 Dec 2014 13:18:06 GMT Sebastian Huber [3e2647a7] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: AltiVec and FPU context support Add AltiVec and FPU ... Tue, 13 Jan 2015 07:24:36 GMT Sebastian Huber [99a1f122] * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) nios2: Disable assembler warning Close #2232. Fri, 09 Jan 2015 12:25:09 GMT Sebastian Huber [5759510] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix compile error for ARMv6-M multilib ARMv6-M is not ... Wed, 07 Jan 2015 09:37:23 GMT Sebastian Huber [b1268e6] * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: Add AltiVec register ASM defines Tue, 23 Dec 2014 11:27:53 GMT Sebastian Huber [2e19bfd] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use PPC_HAS_FPU Provide floating point context support ... Tue, 23 Dec 2014 10:46:08 GMT Sebastian Huber [0d0095f1] * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add PPC_STACK_ALIGN_POWER Simplify PPC_STACK_ALIGNMENT ... Tue, 23 Dec 2014 10:38:34 GMT Sebastian Huber [7c16e1a5] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Set PPC_DEFAULT_CACHE_LINE_SIZE for e6500 Tue, 23 Dec 2014 10:34:40 GMT Sebastian Huber [84d3b9b0] * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Use PPC_DEFAULT_CACHE_LINE_SIZE Use it for the default ... Tue, 23 Dec 2014 10:05:21 GMT Sebastian Huber [7f28f237] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * testsuites/sptests/spsize/size.c (modified) powerpc: Delete _CPU_IRQ_info Mon, 22 Dec 2014 10:46:17 GMT Sebastian Huber [bb7bd148] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use alternate time base for CPU counter Mon, 08 Dec 2014 18:16:37 GMT Gedare Bloom [71d97c9] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) sparc64: put each copyright on one line Wed, 03 Dec 2014 23:56:39 GMT Jan Dolezal [038e1dba] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: doxygen and comments related to VESA real mode framebuffer Wed, 03 Dec 2014 10:35:52 GMT Daniel Hellstrom [dff1803] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * doc/cpu_supplement/sparc.t (modified) SPARC: optimize IRQ enable & disable * Coding style cleanups. * ... Tue, 25 Nov 2014 14:42:56 GMT Sebastian Huber [46689a1e] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC Converting 64-bit ... Thu, 20 Nov 2014 14:00:27 GMT Jan Dolezal [58af50d] * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) score: i386: functions converting real mode pointer to physical ... Mon, 20 Oct 2014 02:46:06 GMT Joel Sherrill [0e74a51] * cpukit/score/cpu/lm32/irq.c (modified) cpukit/score/cpu/lm32/irq.c: Fix warning Mon, 20 Oct 2014 02:45:51 GMT Joel Sherrill [a9c45a04] * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) score/cpu/lm32/rtems/score/cpu.h: Fix set but not used warning Mon, 20 Oct 2014 02:45:37 GMT Joel Sherrill [6c8e0dc8] * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) score/cpu/i386/rtems/score/cpu.h: Fix set but not used warning Tue, 14 Oct 2014 16:03:38 GMT Joel Sherrill [ed6365a] * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/console/console.c (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/shared/start/start.S (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * cpukit/score/cpu/bfin/rtems/bfin/bfin.h (modified) bfin libcpu and libbsp: Fix warnings Wed, 15 Oct 2014 14:26:44 GMT Joel Sherrill [b6bfa1a2] * cpukit/score/cpu/h8300/cpu_asm.S (modified) h8300/cpu_asm.S: Correct register size suffix for loading DISPATCH_NEEDED Mon, 13 Oct 2014 18:54:28 GMT Gedare Bloom [805ee4fa] * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) sparc64: fix warnings in cpukit/score/cpu Sun, 12 Oct 2014 21:06:06 GMT Joel Sherrill [6b514360] * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) score/cpu/m32c: Fix warnings Fri, 10 Oct 2014 09:54:55 GMT Sebastian Huber [037b57a] * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix warning Wed, 08 Oct 2014 20:11:11 GMT Joel Sherrill [a3ae261a] * cpukit/score/cpu/m32r/cpu_asm.c (modified) m32r/cpu_asm.c: Add prototype to fix warning Wed, 08 Oct 2014 20:10:35 GMT Joel Sherrill [60ec7a6] * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) m32r/rtems/score/cpu.h: Fix macros to avoid warnings Wed, 08 Oct 2014 20:09:50 GMT Joel Sherrill [1314849] * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) h8300/rtems/score/cpu.h: Fix macros to avoid warnings Wed, 08 Oct 2014 20:09:39 GMT Joel Sherrill [81074900] * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * doc/tools/bmenu/address.inl (deleted) avr/rtems/score/cpu.h: Fix macros to avoid warnings Tue, 07 Oct 2014 22:42:23 GMT Joel Sherrill [4efdc8e9] * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) m68k/rtems/score/cpu.h: _CPU_Context_Restart_self needed ... Tue, 07 Oct 2014 22:41:52 GMT Joel Sherrill [a5bbd3ac] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxiertems/score/cpu.h: _CPU_Context_switch needed ... Tue, 07 Oct 2014 22:40:49 GMT Joel Sherrill [bf19dbc3] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm/rtems/score/cpu.h: _ARMV7M_Start_multitasking needed ... Tue, 07 Oct 2014 19:10:57 GMT Joel Sherrill [461f9f48] * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) nios2-iic-irq.c: Fix warnings Tue, 07 Oct 2014 19:09:39 GMT Joel Sherrill [905b656c] * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) nios2-iic-irq.c: Include so it builds Tue, 20 May 2014 15:45:07 GMT Daniel Hellstrom [9bd7b3b1] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c (added) * c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) SPARC: Fatal_halt use source and exit codes The Fatal_halt handler ... Fri, 19 Sep 2014 14:55:09 GMT Hesham ALMatary [5464752f] * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) or1k fix bug: Initialize thread context with higher stack address. ... Tue, 23 Sep 2014 06:01:56 GMT Sebastian Huber [5323247] * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) m68k: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC Converting 64-bit ... Tue, 23 Sep 2014 05:57:56 GMT Sebastian Huber [30e5e765] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC Converting 64-bit ... Thu, 18 Sep 2014 13:33:33 GMT Sebastian Huber [386d8b5] * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) sparc: Add comment Mon, 15 Sep 2014 22:33:30 GMT Hesham ALMatary [e0aef221] * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) score/cpu/or1k: Follow no_cpu ISR_Handler algorithm. This patch ... Mon, 15 Sep 2014 22:33:28 GMT Hesham ALMatary [eb14fc2b] * c/src/lib/libbsp/or1k/or1ksim/start/start.S (modified) * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) OpenRISC: Account for red-zone (fixup printf bug). This patch ... Thu, 11 Sep 2014 07:10:16 GMT Sebastian Huber [c48cf0bd] * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) score: Rename _BSP_Exception_frame_print() Rename ... Thu, 11 Sep 2014 07:07:36 GMT Sebastian Huber [6e0000c] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Delete PPC_BSP_HAS_FIXED_PR288 Wed, 10 Sep 2014 13:08:52 GMT Hesham ALMatary [0facefc] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) or1k: Let CPU/BSP Fatal handler have access to source This patchs ... Wed, 04 Jun 2014 09:23:34 GMT Daniel Hellstrom [f82752a4] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/src/interr.c (modified) Let CPU/BSP Fatal handler have access to source Without the source ... Thu, 04 Sep 2014 17:55:39 GMT Hesham ALMatary [bc35eeca] * cpukit/score/cpu/or1k/preinstall.am (modified) Regenerate preinstall.am for score/cpu/or1k This patch regenerates ... Sun, 31 Aug 2014 23:29:41 GMT Hesham ALMatary [305357e] * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/or1k-context-validate.S (added) * cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S (added) * cpukit/score/cpu/or1k/preinstall.am (modified) or1k: Implement context validate and context volatile clobber ... Sun, 31 Aug 2014 23:28:49 GMT Hesham ALMatary [23e8f3d] * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) Add missing r31 load instruction _ISR_Handler _ISR_Handler: r31 was ... Mon, 25 Aug 2014 10:59:34 GMT Daniel Cederman [fecaeca1] * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC ... Fri, 29 Aug 2014 02:48:01 GMT Chris Johns [59990cc] * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gba/preinstall.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (modified) * c/src/lib/libbsp/arm/gumstix/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/rtl22xx/preinstall.am (modified) * c/src/lib/libbsp/arm/smdk2410/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/avr/avrtest/preinstall.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/preinstall.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/preinstall.am (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/preinstall.am (modified) * c/src/lib/libbsp/lm32/milkymist/preinstall.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/preinstall.am (modified) * c/src/lib/libbsp/m32r/m32rsim/preinstall.am (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf52235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5329/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/sim68000/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/hurricane/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/mips/malta/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/powerpc/beatnik/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc64/niagara/preinstall.am (modified) * c/src/lib/libbsp/sparc64/usiii/preinstall.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/preinstall.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/bfin/preinstall.am (modified) * c/src/lib/libcpu/lm32/preinstall.am (modified) * c/src/lib/libcpu/mips/preinstall.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/sparc64/preinstall.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/librtems++/preinstall.am (modified) * cpukit/ftpd/preinstall.am (modified) * cpukit/libfs/src/nfsclient/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/pppd/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/sapi/preinstall.am (modified) * cpukit/score/cpu/bfin/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m32r/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sparc64/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate all preinstall.am files. With this patch the ... Thu, 28 Aug 2014 13:44:52 GMT Joel Sherrill [b597c0d] * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (modified) * c/src/lib/libbsp/arm/gp32/preinstall.am (modified) * c/src/lib/libbsp/arm/gumstix/preinstall.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/preinstall.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/preinstall.am (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/preinstall.am (modified) * c/src/lib/libbsp/lm32/milkymist/preinstall.am (modified) * c/src/lib/libbsp/m32r/m32rsim/preinstall.am (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf52235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5329/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme136/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (modified) * c/src/lib/libbsp/mips/genmongoosev/preinstall.am (modified) * c/src/lib/libbsp/mips/malta/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/moxie/moxiesim/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/or1k/or1ksim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/beatnik/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ep1a/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh1/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh2/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc64/usiii/preinstall.am (modified) * c/src/lib/libcpu/arm/preinstall.am (modified) * c/src/lib/libcpu/bfin/preinstall.am (modified) * c/src/lib/libcpu/lm32/preinstall.am (modified) * c/src/lib/libcpu/mips/preinstall.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/sparc64/preinstall.am (modified) * c/src/librtems++/preinstall.am (modified) * cpukit/ftpd/preinstall.am (modified) * cpukit/mghttpd/preinstall.am (modified) * cpukit/posix/preinstall.am (modified) * cpukit/preinstall.am (modified) * cpukit/score/cpu/bfin/preinstall.am (modified) * cpukit/score/cpu/h8300/preinstall.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/m32r/preinstall.am (modified) * cpukit/score/cpu/mips/preinstall.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/sparc64/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * cpukit/telnetd/preinstall.am (modified) * cpukit/zlib/preinstall.am (modified) Regenerate all preinstall.am files. Apparently, at some point ... Fri, 11 Jul 2014 14:09:41 GMT Daniel Cederman [bba83e5] * cpukit/score/cpu/sparc/cpu.c (modified) score/sparc: Add comment on icache flush after trap table update ... Thu, 03 Jul 2014 09:18:55 GMT Daniel Cederman [54f3476e] * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) bsp/sparc: Flush icache before first time enabling interrupts A ... Mon, 18 Aug 2014 21:06:46 GMT Hesham ALMatary [de62e5d8] * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (modified) Add or1k tick timer register definitions Thu, 14 Aug 2014 12:27:40 GMT Sebastian Huber [1a2d3497] * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) arm: PR2186: Fix compile error Tue, 12 Aug 2014 18:46:49 GMT Joel Sherrill [700f97e] * cpukit/score/cpu/or1k/preinstall.am (added) or1k/.../preinstall.am: Add missing file Tue, 12 Aug 2014 15:57:42 GMT Hesham ALMatary [94d45f6] * cpukit/configure.ac (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (added) * cpukit/score/cpu/or1k/cpu.c (added) * cpukit/score/cpu/or1k/or1k-context-initialize.c (added) * cpukit/score/cpu/or1k/or1k-context-switch.S (added) * cpukit/score/cpu/or1k/or1k-exception-default.c (added) * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (added) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (added) * cpukit/score/cpu/or1k/rtems/asm.h (added) * cpukit/score/cpu/or1k/rtems/score/cpu.h (added) * cpukit/score/cpu/or1k/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (added) * cpukit/score/cpu/or1k/rtems/score/or1k.h (added) * cpukit/score/cpu/or1k/rtems/score/types.h (added) Add support for OpenRISC - Fixed issues This work is based on the ... Sun, 10 Aug 2014 16:36:30 GMT Sebastian Huber [8ae37323] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Add support for FPv4-SP floating point unit This floating ...
