# # ChangeLog for cpukit/score/cpu/i386/rtems/score/cpu.h in rtems # # Generated by Trac 1.2.1.dev0 # 05/14/24 04:44:26 Fri, 05 Nov 1999 16:44:02 GMT Joel Sherrill [458bd34] * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (modified) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.h (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/ictrl.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/monitor/mon-command.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu.h (modified) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/system.h (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) This is another pass at making sure that nothing outside the BSP ... Thu, 29 Jul 1999 23:01:15 GMT Joel Sherrill [6805640e] * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (modified) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.h (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu.h (modified) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) Patch from Charles-Antoine Gauthier to ... Thu, 18 Feb 1999 18:28:24 GMT Joel Sherrill [7908ba5b] * c/src/exec/score/cpu/a29k/rtems/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (added) * c/src/exec/score/cpu/a29k/rtems/score/a29ktypes.h (added) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/a29k/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppatypes.h (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/types.h (added) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (added) * c/src/exec/score/cpu/i386/rtems/score/i386types.h (added) * c/src/exec/score/cpu/i386/rtems/score/types.h (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960.h (added) * c/src/exec/score/cpu/i960/rtems/score/i960types.h (added) * c/src/exec/score/cpu/i960/rtems/score/types.h (added) * c/src/exec/score/cpu/i960/wrap/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (added) * c/src/exec/score/cpu/m68k/rtems/score/m68ktypes.h (added) * c/src/exec/score/cpu/m68k/rtems/score/types.h (added) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (added) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtcpu.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/idtmon.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/iregdef.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/mipstypes.h (added) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cputypes.h (added) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/powerpc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sh/rtems/score/cpu_isps.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7030.h (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/ispsh7032.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh.h (added) * c/src/exec/score/cpu/sh/rtems/score/sh_io.h (added) * c/src/exec/score/cpu/sh/rtems/score/shtypes.h (added) * c/src/exec/score/cpu/sh/rtems/score/types.h (added) * c/src/exec/score/cpu/sh/wrap/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (added) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (added) * c/src/exec/score/cpu/sparc/rtems/score/types.h (added) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (added) * c/src/exec/score/cpu/unix/rtems/score/types.h (added) * c/src/exec/score/cpu/unix/rtems/score/unix.h (added) * c/src/exec/score/cpu/unix/rtems/score/unixtypes.h (added) * c/src/exec/score/cpu/unix/wrap/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (added) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (added) * configure.in (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (added) * cpukit/score/cpu/a29k/rtems/score/cpu.h (added) * cpukit/score/cpu/a29k/rtems/score/types.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (added) * cpukit/score/cpu/hppa1.1/rtems/score/types.h (added) * cpukit/score/cpu/i386/rtems/score/cpu.h (added) * cpukit/score/cpu/i386/rtems/score/i386.h (added) * cpukit/score/cpu/i386/rtems/score/types.h (added) * cpukit/score/cpu/i960/rtems/score/cpu.h (added) * cpukit/score/cpu/i960/rtems/score/i960.h (added) * cpukit/score/cpu/i960/rtems/score/types.h (added) * cpukit/score/cpu/m68k/rtems/score/cpu.h (added) * cpukit/score/cpu/m68k/rtems/score/m68k.h (added) * cpukit/score/cpu/m68k/rtems/score/types.h (added) * cpukit/score/cpu/mips/rtems/score/cpu.h (added) * cpukit/score/cpu/mips/rtems/score/types.h (added) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (added) * cpukit/score/cpu/mips64orion/rtems/score/types.h (added) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (added) * cpukit/score/cpu/no_cpu/rtems/score/types.h (added) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/cpu.h (added) * cpukit/score/cpu/sh/rtems/score/sh.h (added) * cpukit/score/cpu/sh/rtems/score/sh_io.h (added) * cpukit/score/cpu/sh/rtems/score/types.h (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (added) * cpukit/score/cpu/sparc/rtems/score/sparc.h (added) * cpukit/score/cpu/sparc/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/cpu.h (added) * cpukit/score/cpu/unix/rtems/score/types.h (added) * cpukit/score/cpu/unix/rtems/score/unix.h (added) Part of the automake VI patch from Ralf Corsepius
