@007bdc4
08/05/13 08:16:31 |
Sebastian Huber |
arm: Fix CPU_MODES_INTERRUPT_MASK
The set of interrupt levels must be …
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@f7740e97
06/13/13 14:05:20 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_receive()
Rename to …
4.115
@07f6e419
06/13/13 14:00:54 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_broadcast()
Rename to …
4.115
@ca63ae2
06/13/13 13:41:21 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Send_interrupt()
Delete bsp_smp_interrupt_cpu().
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@d61e54c2
07/15/13 15:31:10 |
wei.a.yang |
update-all-architectures-to-new-atomic-implementation
4.115
@4e5608dd
07/16/13 06:25:41 |
Sebastian Huber |
arm: Fix exception frame information
Use the right stack pointer …
4.115
@818d4b0
07/13/13 20:52:06 |
Ric Claus |
bsps/arm: Fix printk args to match format
4.115
@1ebffa89
06/21/13 07:18:01 |
Chris Johns |
arm: Fix default exception prologues
4.115
@f2f211c5
05/31/13 11:59:34 |
Sebastian Huber |
smp: Add ARM support
4.115
@d9bd5cd6
05/22/13 07:54:34 |
Sebastian Huber |
arm: Add CPU specific idle thread for ARMv7
4.115
@18e1e5b
05/23/13 07:04:19 |
Sebastian Huber |
arm: Fix CPSR and SPSR access
The GNU assembler translates for …
4.115
@cfd8d7a
05/08/13 07:30:31 |
Sebastian Huber |
arm: Support VFP-D32 and Neon
4.115
@9dcc683
05/07/13 10:05:43 |
Sebastian Huber |
arm: Simplify architecture selection
4.115
@39993d6
05/07/13 08:14:55 |
Sebastian Huber |
score: Add CPU context validation
4.115
@aedeb57
05/07/13 09:22:38 |
Sebastian Huber |
arm: Add FUNCTION_THUMB_ENTRY(), etc.
Add FUNCTION_THUMB_ENTRY(), …
4.115
@3806e01a
05/10/13 08:33:11 |
Chris Johns |
Revert bootstrap whitespace changes.
4.115
@2bbea4dd
05/03/13 14:14:45 |
Sebastian Huber |
arm: Switch to ARM only for Thumb-1
The Thumb-2 instruction set as …
4.115
@57c05b54
05/03/13 14:07:34 |
Sebastian Huber |
arm: Fix DEFINE_FUNCTION_ARM() for ARMv7-AR
4.115
@9b605b28
04/23/13 16:34:16 |
wei.a.yang |
Using the generic atomic ops to implement UP mode atomic for all …
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@75e5127
02/20/13 17:41:12 |
alan.p.cudmore |
add ARM_ARCH_6ZK to cpukit/score/cpu/arm/rtems/score/arm.h
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@66fffc7
01/08/13 15:22:33 |
alexivanov97 |
score: Doxygen Clean Up Task #15
4.115
@2570a2a8
01/07/13 13:55:23 |
Sebastian Huber |
arm: Add AIRCR register defines
4.115
@2f28a03
01/07/13 12:42:09 |
Sebastian Huber |
arm: Implement CPU_Exception_frame_print()
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@e377ad7
01/07/13 07:48:45 |
Sebastian Huber |
arm: Include <rtems/score/cpu.h>
4.115
@0d8cde9
01/07/13 07:39:45 |
Sebastian Huber |
arm: Provide CPU_Exception_frame for ARMv7-M
4.115
@0f7abd99
01/04/13 15:25:19 |
Sebastian Huber |
arm: Rename inline functions
Rename arm_status_irq_enable() to …
4.115
@8df0e91
01/04/13 15:22:18 |
Sebastian Huber |
arm: Move inline functions
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@50f3c42b
01/04/13 13:22:10 |
Sebastian Huber |
arm: Add and use _ARM_Exception_default()
4.115
@8d687737
01/04/13 13:09:19 |
Sebastian Huber |
arm: Change CPU_Exception_frame
Provide proper CPU_Exception_frame …
4.115
@010c09a
01/04/13 12:20:37 |
Sebastian Huber |
arm: Rename type and functions
Rename arm_exc_abort_handler to …
4.115
@c04ac2ca
01/04/13 12:16:35 |
Sebastian Huber |
arm: Move type definition and prototypes
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@31eebc9
01/04/13 11:32:19 |
Sebastian Huber |
arm: Delete unused arm_exc_undefined()
4.115
@b7185613
12/07/12 14:57:04 |
alexivanov97 |
score misc: Clean up Doxygen GCI Task #12
4.115
@43e0599
12/02/12 21:23:57 |
matkallada |
score misc: Clean up Doxygen #13 (GCI 2012)
This patch is a task from …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@f1738ed
11/04/12 20:04:39 |
Sebastian Huber |
score: PR1607: Add and use CPU_SIZEOF_POINTER
Add and use new CPU …
4.115
@f4539aa
11/18/12 18:47:40 |
Sebastian Huber |
arm: Add _CPU_Thread_Idle_body for ARMv7-M
4.115
@dea10503
06/11/12 17:28:58 |
Joel Sherrill |
arm/cpu.h: Define CPU_SIMPLE_VECTORED_INTERRUPTS and remove …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@ee32f67a
05/04/12 06:55:28 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@f0d66b1
03/26/12 16:12:22 |
Sebastian Huber |
arm: New function
Add and use function …
4.115
@f442e6b4
03/27/12 15:37:00 |
Sebastian Huber |
ARM: PR2042: Provide stub for ARMv6-M
4.115
@f9ec6004
03/24/12 19:07:17 |
Sebastian Huber |
ARM: New define ARMV7M_EXCEPTION_PRIORITY_LOWEST
4.115
@701f078
02/07/12 21:07:01 |
Sebastian Huber |
Support Thumb 2.
4.115
@6091f1a6
02/07/12 21:11:01 |
Sebastian Huber |
ARMv7-M NVIC and MPU API changes.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@6962842
11/20/11 14:59:41 |
Sebastian Huber |
Typo.
4.115
@bb92954
11/19/11 14:34:10 |
Sebastian Huber |
2011-11-07 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@6343ea4e
11/07/11 07:58:17 |
Sebastian Huber |
4.115
@e2691dcb
11/07/11 07:48:11 |
Sebastian Huber |
PR …
4.115
@abd25309
09/27/11 09:14:46 |
Sebastian Huber |
Typo.
4.115
@d0630763
09/27/11 09:14:03 |
Sebastian Huber |
2011-09-28 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@c5ed148
09/24/11 12:56:51 |
Sebastian Huber |
2011-09-24 Sebastian Huber <sebastian.huber@…>
4.115
@3ce764a
09/16/11 09:47:09 |
Sebastian Huber |
2011-09-16 Sebastian Huber <sebastian.huber@…>
4.115
@78f11e2
05/18/11 05:18:22 |
Ralf Corsepius |
2011-05-18 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@86820eda
04/15/11 08:06:16 |
Sebastian Huber |
2011-04-15 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@9f9371f
02/11/11 09:08:14 |
Ralf Corsepius |
2011-02-11 Ralf Corsépius <ralf.corsepius@…>
* cpu.c, …
4.115
@db26513
11/23/10 15:59:18 |
Sebastian Huber |
2010-11-23 Gedare Bloom <giddyup44@…>
PR 1719/cpukit
4.115
@71c8457
11/22/10 13:06:46 |
Sebastian Huber |
2010-11-22 Sebastian Huber <sebastian.huber@…>
4.115
@a44edd15
07/29/10 17:52:00 |
Joel Sherrill |
2010-07-29 Gedare Bloom <giddyup44@…>
PR 1635/cpukit
4.115
@89b85e51
07/16/10 08:46:29 |
Sebastian Huber |
2010-07-16 Sebastian Huber <sebastian.huber@…>
4.115
@f7bac00b
07/06/10 07:52:36 |
Sebastian Huber |
2010-07-06 Sebastian Huber <sebastian.huber@…>
4.115
@b616350
06/29/10 00:31:02 |
Joel Sherrill |
2010-06-28 Joel Sherrill <joel.sherrill@…>
PR 1573/cpukit …
4.115
@b2f251a8
05/10/10 20:29:13 |
Joel Sherrill |
2010-05-10 Joel Sherrill <joel.sherrilL@…>
4.104.115
@78623bce
04/08/10 10:13:46 |
Thomas.Doerfler |
add/adapt documentation
4.104.115
@58597dd
04/07/10 14:04:12 |
Joel Sherrill |
2010-04-07 Joel Sherrill <joel.sherrill@…>
4.104.115
@0acc9af3
03/27/10 15:01:19 |
Joel Sherrill |
2010-03-27 Joel Sherrill <joel.sherrill@…>
4.104.115
@39c8fdb
01/12/10 15:03:22 |
Thomas.Doerfler |
add support for lpc32xx
4.104.115
@9db18dd
12/15/09 15:14:12 |
Thomas.Doerfler |
add support for ARM11, reimplement nested interrupts
4.104.115
@5bb38e15
12/04/09 05:25:30 |
Ralf Corsepius |
Whitespace removal.
4.104.115
@13c5cea
10/01/09 21:47:42 |
Joel Sherrill |
2009-10-01 Joel Sherrill <joel.sherrill@…>
4.104.115
@f98ce8b8
10/01/09 12:57:30 |
Joel Sherrill |
4.104.115
@5e61c80
09/18/09 08:07:23 |
Thomas.Doerfler |
* rtems/score/cpu.h: Fix for inline asm in _CPU_Fatal_halt().
4.104.115
@db0df7b
08/19/09 16:39:05 |
Joel Sherrill |
2009-08-19 Joel Sherrill <joel.sherrill@…>
4.104.115
@9364cf66
07/17/09 15:16:50 |
Thomas.Doerfler |
adding lpc24xx BSP parts
4.104.115
@ebe76f94
07/17/09 13:59:43 |
Thomas.Doerfler |
removing unneeded files
4.104.115
@632e4306
07/17/09 13:50:31 |
Thomas.Doerfler |
exception handler maintenance
4.104.115
@4848b56
05/05/09 19:37:10 |
Joel Sherrill |
2009-05-05 Joel Sherrill <joel.sherrill@…>
4.104.115
@c03e2bc
02/11/09 21:45:05 |
Joel Sherrill |
2009-02-11 Joel Sherrill <joel.sherrill@…>
* cpu.c, …
4.104.115
@1cb54d1f
12/11/08 00:47:56 |
Ralf Corsepius |
#include <stdint.h> instead of <rtems/stdint.h>.
4.104.115
@383871ac
12/07/08 11:25:55 |
Ralf Corsepius |
Fix typo.
4.104.115
@6162bc2
09/11/08 14:10:16 |
Ralf Corsepius |
2008-09-11 Ralf Corsépius <ralf.corsepius@…>
4.104.115
@df4fcaa
09/08/08 15:19:23 |
Joel Sherrill |
2008-09-08 Joel Sherrill <joel.sherrill@…>
* cpu.c: Remove …
4.104.114.95
@6c283cbf
09/07/08 15:26:01 |
Ralf Corsepius |
2008-09-07 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.95
@db507c16
09/07/08 15:24:36 |
Ralf Corsepius |
Merge thumb/Makefile.am.
4.104.114.95
@03a699d
09/07/08 15:24:24 |
Ralf Corsepius |
Remove (superfluous).
4.104.114.95
@cfdef834
09/05/08 02:00:39 |
Ralf Corsepius |
2008-09-05 Ralf Corsépius <ralf.corsepius@…>
* cpu.c, …
4.104.114.95
@5d42c1b7
09/05/08 02:00:15 |
Ralf Corsepius |
Convert to "bool".
4.104.114.95
@b7b6100
08/21/08 04:10:51 |
Ralf Corsepius |
2008-08-21 Ralf Corsépius <ralf.corsepius@…>
4.104.114.95
@30e2df6
08/21/08 04:10:35 |
Ralf Corsepius |
Include stdbool.h. Use bool as base-type for boolean.
4.104.114.95
