@c2ae79e
12/12/12 20:57:49 |
matkallada |
misc: Header File Doxygen Enhancement Task #3
4.115
@e12f5acf
12/09/12 13:12:19 |
Sebastian Huber |
sapi: Fix previous commit
4.115
@50dd75a
12/09/12 13:06:56 |
Sebastian Huber |
sapi: Revert documentation change
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@f9340ed7
12/03/12 10:35:43 |
Sebastian Huber |
posix: Add and use <rtems/posix/psignalimpl.h>
This file contains the …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@e4b40531
11/14/12 11:37:24 |
Sebastian Huber |
sapi: Add rtems_fatal_source and rtems_fatal_code
4.115
@228df42
11/07/12 13:10:56 |
Sebastian Huber |
sapi: Add BSP_INITIAL_EXTENSION to confdefs.h
A BSP can supply an …
4.115
@466cf31d
11/07/12 12:59:19 |
Sebastian Huber |
score: Statically initialize user extensions
The initial extensions …
4.115
@9ed2bef
11/07/12 09:54:49 |
Sebastian Huber |
score: Add and use RTEMS_ARRAY_SIZE()
4.115
@2195fd27
11/07/12 10:23:03 |
Sebastian Huber |
sapi: Make initial user extensions table read-only
4.115
@b596754
11/07/12 09:19:46 |
Sebastian Huber |
sapi: Fix user scheduler configuration
The comment in confdefs.h …
4.115
@ae4f125e
11/06/12 12:54:05 |
Sebastian Huber |
sapi: Make Configuration read-only
The Configuration is now read-only …
4.115
@ef5f359
11/06/12 11:18:10 |
Sebastian Huber |
sapi: Delete duplicate declarations
4.115
@e39fa07
11/06/12 11:13:29 |
Sebastian Huber |
sapi: Delete unused macros
Delete rtems_configuration_get_table(), …
4.115
@f536e12
11/06/12 10:59:43 |
Sebastian Huber |
sapi: Use rtems_*_get_user_multiprocessing_table
4.115
@2b875ff5
11/06/12 10:40:35 |
Sebastian Huber |
sapi: Use rtems_config*_get_maximum_extensions
4.115
@ec8b6c4
11/06/12 10:37:11 |
Sebastian Huber |
sapi: Use rtems_config*_get_device_driver_table
4.115
@1a75b4b
11/06/12 10:36:01 |
Sebastian Huber |
sapi: Use rtems_conf*_get_number_of_device_drivers
4.115
@c53b330c
11/06/12 10:34:10 |
Sebastian Huber |
sapi: Use rtems_configuration_get_maximum_drivers
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@fd71610
10/11/12 16:25:03 |
Ralf Corsepius |
Cleanup Krzysztof's copyright notices.
4.115
@a6eaa548
08/29/12 12:38:54 |
Krzysztof Miesowicz |
timespec helpers: Add wrappers with new test
4.115
@50fc8f6
06/13/12 07:44:32 |
Sebastian Huber |
sapi: Add nanoseconds_per_tick to configuration
Add …
4.115
@39ee704e
05/31/12 08:27:29 |
Sebastian Huber |
libblock: Add read-ahead task
Read-ahead requests were previously …
4.115
@b6911069
05/29/12 16:02:52 |
Sebastian Huber |
libblock: Add task stack size bdbuf configuration
The task stack size …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@f53aa8d
05/03/12 16:43:29 |
Gedare Bloom |
rbtree: API changes. Remove rbtree control node from RBTree_Next.
The …
4.115
@8572752
05/02/12 16:10:34 |
Gedare Bloom |
rbtree: API Changes
Make default for rtems_rbtree functions be …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@5a4bb75
04/26/12 12:28:52 |
Sebastian Huber |
Filesystem: Remove per file descriptor semaphore
The per file …
4.115
@ee32f67a
05/04/12 06:55:28 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@5c51ba1
04/16/12 08:38:31 |
Sebastian Huber |
rbheap: API changes and documentation
4.115
@8c6608bd
04/13/12 07:10:12 |
Sebastian Huber |
rbtree: PR2046: Replace rtems_rbtree_unique
4.115
@5eb434e
04/11/12 13:04:22 |
Sebastian Huber |
score: New macros and functions
New macros
o …
4.115
@e752630
04/10/12 09:19:39 |
Sebastian Huber |
rbheap: New files
In the Red-Black Tree Heap the administration data …
4.115
@dc62a48c
04/10/12 08:25:14 |
Sebastian Huber |
rbtree: PR1995: API change
New functions
o …
4.115
@9fc284c
03/30/12 09:35:39 |
Sebastian Huber |
score/rbtree: Add const qualifier
4.115
@e53aae2
03/26/12 20:42:38 |
Gedare Bloom |
confdefs: Add declaration for unlimited objects.
Adds to confdefs a …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@5693f2e
02/22/12 08:58:59 |
Ralf Corsepius |
2012-02-22 Ralf Corsépius <ralf.corsepius@…>
4.115
@184a612e
02/02/12 14:17:25 |
Joel Sherrill |
Merge remote branch 'remotes/origin/gitignore'
4.115
@72a3af3
01/23/12 14:55:42 |
Sebastian Huber |
Extended API to support iteration of const chains.
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@9fa3cf0d
12/14/11 13:17:19 |
Sebastian Huber |
2011-12-14 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@3df4d74
12/13/11 14:37:03 |
Sebastian Huber |
2011-12-13 Sebastian Huber <sebastian.huber@…>
4.115
@517bf08
12/13/11 10:52:21 |
Sebastian Huber |
4.115
@0042168
12/08/11 14:13:55 |
Ralf Corsepius |
2011-12-08 Ralf Corsépius <ralf.corsepius@…>
4.115
@540eec6e
12/05/11 17:01:30 |
Ralf Corsepius |
2011-12-05 Ralf Corsépius <ralf.corsepius@…>
4.115
@b929b39e
12/05/11 13:51:06 |
Ralf Corsepius |
4.115
@84e1742
11/18/11 20:04:49 |
Jennifer.Averett |
2011-11-18 Jennifer Averett <Jennifer.Averett@…>
4.115
@b4f635e
11/10/11 14:40:13 |
Sebastian Huber |
2011-11-10 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@48943dc
10/10/11 07:11:26 |
Ralf Corsepius |
2011-10-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@82db8e56
09/15/11 15:49:32 |
Joel Sherrill |
2011-09-15 Petr Benes <benesp16@…>
PR 1906/cpukit
4.115
@5472ad41
09/11/11 20:52:37 |
Joel Sherrill |
2011-09-11 Petr Benes <benesp16@…>
PR 1896/cpukit
4.115
@5817297
09/09/11 11:02:03 |
Sebastian Huber |
2011-09-09 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@ac9d2ecc
09/01/11 18:13:54 |
Joel Sherrill |
2011-09-01 Petr Benes <benesp16@…>
PR 1895/cpukit
4.115
@adae165b
08/29/11 21:30:32 |
Joel Sherrill |
2011-08-29 Joel Sherrill <joel.sherrilL@…>
4.115
@74f1c73e
08/21/11 20:07:11 |
Joel Sherrill |
2011-08-21 Petr Benes <benesp16@…>
PR 1886/cpukit
4.115
@542ae51
08/17/11 09:14:09 |
Sebastian Huber |
2011-08-17 Sebastian Huber <sebastian.huber@…>
4.115
@6de36ed
08/16/11 11:40:53 |
Sebastian Huber |
2011-08-16 Sebastian Huber <sebastian.huber@…>
4.115
@13c4f853
08/02/11 19:25:59 |
Joel Sherrill |
2011-08-02 Joel Sherrill <joel.sherrill@…>
PR 1877/cpukit …
4.115
@64adc13
07/24/11 23:55:15 |
Joel Sherrill |
2011-07-24 Joel Sherrill <joel.sherrill@…>
* ftpd/ftpd.c, …
4.115
@f58ef8ae
07/13/11 18:34:22 |
Joel Sherrill |
2011-07-13 Joel Sherrill <joel.sherrilL@…>
PR 1824/cpukit …
4.115
@21242c2
06/24/11 17:52:58 |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.115
@d4dc7c8
05/26/11 18:07:07 |
Jennifer.Averett |
2011-05-26 Jennifer Averett <Jennifer.Averett@…>
PR …
4.115
@c1545f0
05/23/11 16:06:23 |
Joel Sherrill |
2011-05-23 Marta Rybczynska <marta.rybczynska@…>
PR …
4.115
@49f6309b
05/23/11 14:55:58 |
Joel Sherrill |
2011-05-23 Joel Sherrill <joel.sherrilL@…>
PR 1804/cpukit …
4.115
@782e6aea
05/18/11 05:16:23 |
Ralf Corsepius |
2011-05-18 Ralf Corsépius <ralf.corsepius@…>
4.115
@ba7bc099
05/17/11 19:48:44 |
Joel Sherrill |
2011-05-17 Joel Sherrill <joel.sherrill@…>
PR 1789/cpukit …
4.115
@5af951f
05/13/11 13:49:16 |
Sebastian Huber |
2011-05-13 Sebastian Huber <sebastian.huber@…>
4.115
@0d5a9f1
04/27/11 17:18:59 |
Jennifer.Averett |
2011-04-27 Jennifer Averett <Jennifer.Averett@…>
PR 1784 …
4.115
@e58f80cb
04/11/11 17:23:06 |
Joel Sherrill |
2011-04-11 Joel Sherrill <joel.sherrill@…>
4.115
@bd9baa81
04/04/11 18:44:16 |
Joel Sherrill |
2010-07-28 Gedare Bloom <giddyup44@…>
PR 1641/cpukit
4.115
@e79093a
04/04/11 16:40:00 |
Joel Sherrill |
2011-04-04 Joel Sherrill <joel.sherrilL@…>
PR 1773/cpukit …
4.115
@06dcaf0
03/16/11 20:05:06 |
Joel Sherrill |
2011-03-16 Jennifer Averett <jennifer.averett@…>
PR …
4.115
@0118ed6
03/16/11 16:32:22 |
Joel Sherrill |
PR …
4.115
@08d01a1
03/10/11 16:39:14 |
Sebastian Huber |
2011-03-10 Sebastian Huber <sebastian.huber@…>
4.115
@4c794c8
03/03/11 16:01:35 |
Joel Sherrill |
2011-03-03 Joel Sherrill <joel.sherrill@…>
4.115
@fd580d5
02/23/11 14:13:16 |
Ralf Corsepius |
2011-02-23 Ralf Corsépius <ralf.corsepius@…>
4.115
@22c28282
02/21/11 17:00:51 |
Joel Sherrill |
2011-02-21 Joel Sherrill <joel.sherrill@…>
4.115
@4be93c0
02/21/11 11:54:37 |
Sebastian Huber |
2011-02-21 Sebastian Huber <sebastian.huber@…>
4.115
@108c4b0
02/18/11 15:12:44 |
Joel Sherrill |
2011-02-18 Joel Sherrill <joel.sherrill@…>
4.115
@010192d
02/17/11 22:21:44 |
Joel Sherrill |
2011-02-17 Joel Sherrill <joel.sherrill@…>
4.115
@b2b56cb9
02/09/11 06:18:57 |
Ralf Corsepius |
2011-02-09 Ralf Corsépius <ralf.corsepius@…>
4.115
@5aecf664
12/17/10 14:56:06 |
Joel Sherrill |
2010-12-17 Joel Sherrill <joel.sherrill@…>
Jennifer …
4.115
@5c4e0c5
11/25/10 13:24:26 |
Sebastian Huber |
2010-11-25 Sebastian Huber <sebastian.huber@…>
4.115
@0faa9dad
11/24/10 15:51:28 |
Joel Sherrill |
2010-11-24 Gedare Bloom <giddyup44@…>
PR 1647/cpukit
4.115
@db5f134
11/16/10 19:14:10 |
Joel Sherrill |
2010-11-16 Joel Sherrill <joel.sherrill@…>
PR 1718/cpukit …
4.115
@11236580
11/04/10 23:00:04 |
Joel Sherrill |
2010-11-04 Joel Sherrill <joel.sherrill@…>
4.115
@69f2a07
08/24/10 14:29:55 |
Sebastian Huber |
2010-08-24 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@b3263f5
08/20/10 13:26:55 |
Ralf Corsepius |
2010-08-16 Ralf Corsépius <ralf.corsepius@…>
4.115
@58fa947
08/11/10 12:16:11 |
Sebastian Huber |
2010-09-11 Sebastian Huber <sebastian.huber@…>
4.115
@7299818
08/10/10 22:56:35 |
Joel Sherrill |
2010-08-10 Joel Sherrill <joel.sherrill@…>
PR 1658/cpukit …
4.115
@b8af65a
08/09/10 07:38:51 |
Sebastian Huber |
2010-08-09 Sebastian Huber <sebastian.huber@…>
4.115
