@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@99be750
04/29/14 05:48:09 |
Sebastian Huber |
sapi: Report profiling only if enabled for tests
4.115
@aea93fb4
04/22/14 09:50:29 |
Sebastian Huber |
sapi: Add profiling done message
4.115
@8365ad1
04/22/14 09:46:10 |
Sebastian Huber |
sapi: Add arithmetic means to XML profiling report
4.115
@0c5beb8e
04/26/14 23:32:20 |
Chris Johns |
rtems: Account for the network semaphore.
4.115
@e306f3df
04/25/14 17:56:36 |
Jennifer Averett |
sapi: Fix condef.h compile error for disabled network configuration.
4.115
@c9a0a10
04/25/14 06:14:19 |
Chris Johns |
rtems: Account for file system semaphores.
Add support to account for …
4.115
@0e98970
04/17/14 06:02:46 |
Sebastian Huber |
sapi: Fix CONFIGURE_UNLIMITED_OBJECTS
POSIX keys and key value pairs …
4.115
@2c1e7ff
04/15/14 11:32:40 |
Sebastian Huber |
sapi: Error case for CONFIGURE_UNLIMITED_OBJECTS
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@133d54c5
04/09/14 08:33:00 |
Sebastian Huber |
score: Add scheduler name
4.115
@69aa3349
04/08/14 07:42:29 |
Sebastian Huber |
score: Simplify thread control initialization
The thread control …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@94086a9
04/07/14 12:41:56 |
Sebastian Huber |
score: Fix POSIX threads size estimate
The POSIX threads are separate …
4.115
@fb9e98e
04/07/14 12:50:28 |
Sebastian Huber |
score: Fix workspace size estimate
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@439c494
04/03/14 10:02:09 |
Sebastian Huber |
score: Add and use Scheduler_simple_Control
4.115
@3891983
04/03/14 09:53:48 |
Sebastian Huber |
score: Add and use Scheduler_EDF_Control
4.115
@6d24e8b
03/18/14 18:54:01 |
Jennifer Averett |
sapi: Add priority affinity smp scheduler.
4.115
@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@5c0c0cf
03/27/14 13:23:21 |
Christian.Mauderer |
privateenv: Use POSIX keys instead of task variables.
4.115
@1fac361
03/24/14 07:51:37 |
Sebastian Huber |
score: PR2174: Add workaround
Add …
4.115
@e72bc923
03/10/14 14:17:27 |
Sebastian Huber |
sapi: Add profiling report for tests
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@51f823c9
03/18/14 07:28:14 |
Sebastian Huber |
posix: Use interal mutex for once implementation
Enable …
4.115
@840ae71
03/10/14 13:39:41 |
Sebastian Huber |
sapi: Add <rtems/test.h>
Provide support functions to print the …
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@f980561
03/10/14 09:04:09 |
Sebastian Huber |
score: Add per-CPU profiling
Add per-CPU profiling stats API. …
4.115
@350f88dc
03/10/14 09:20:40 |
Sebastian Huber |
sapi: Add SMP lock profiling app. level data
4.115
@29c9eb6
03/10/14 09:03:55 |
Sebastian Huber |
sapi: Add per-CPU profiling application level data
4.115
@4dad4b8
03/10/14 13:39:49 |
Sebastian Huber |
sapi: Add profiling application level support
4.115
@4d3e9334
03/13/14 15:03:09 |
Sebastian Huber |
sapi: Typos
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@e6c87f7
03/04/14 21:54:12 |
Joel Sherrill |
POSIX keys now enabled in all configurations.
Formerly POSIX keys …
4.115
@039a189d
01/27/14 19:55:58 |
Jennifer Averett |
sapi: Moved smp initialization and added cpuset initilization.
SMP …
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@6ca4f6a
02/17/14 13:56:51 |
Sebastian Huber |
score: Add and use <rtems/score/smpimpl.h>
Collect SMP implementation …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@8a6de83
02/17/14 09:10:27 |
Sebastian Huber |
score: Move _SMP_Request_other_cores_to_shutdown()
Move …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@4ea97d24
11/19/13 15:21:54 |
Sebastian Huber |
score/rbtree: Remove "unprotected" from API
4.115
@833dd90
11/19/13 15:09:39 |
Sebastian Huber |
score/rbtree: Delete protected operations
The user of the red-black …
4.115
@3c96bee
09/12/13 13:32:07 |
Sebastian Huber |
JFFS2: Add RTEMS support
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@23de794d
08/26/13 12:27:52 |
Sebastian Huber |
score: Add and use CHAIN_INITIALIZER_ONE_NODE().
Add and use …
4.115
@6e4c01e
08/23/13 04:56:36 |
Chris Johns |
posix: Update to the pthread_once changes.
Implement the reeview …
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@9d83f58a
08/12/13 08:32:32 |
Sebastian Huber |
smp: Replace Scheduler_simple_smp_Control
Replace …
4.115
@c1a356e9
08/09/13 12:31:02 |
Sebastian Huber |
score: _Priority_bit_map_Handler_initialization()
Delete …
4.115
@03acc59
08/14/13 00:21:41 |
Chris Johns |
posix: Change pthread_once to be SMP safe.
Change pthread_once from …
4.115
@6b4e448
08/06/13 14:01:36 |
Sebastian Huber |
PR766: Delete RTEMS_INSIDE
4.115
@2ad250e
08/06/13 12:46:24 |
Sebastian Huber |
posix: Create key implementation header
Move implementation specific …
4.115
@b5c9064
08/05/13 13:20:45 |
ashi08104 |
Unlimited objects support for POSIX keys
This patch enables unlimited …
4.115
@b4b309c
08/01/13 13:20:17 |
Sebastian Huber |
smp: Generalize _Thread_Start_multitasking()
Add context parameter to …
4.115
@2bca05f7
08/01/13 12:55:03 |
Sebastian Huber |
score: Delete SYSTEM_STATE_BEGIN_MULTITASKING
Nothing happened …
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@c236082
07/30/13 13:54:53 |
Sebastian Huber |
smp: Provide cache optimized Per_CPU_Control
Delete …
4.115
@a2e3f33
07/24/13 11:50:54 |
Sebastian Huber |
score: Create object implementation header
Move implementation …
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@7f04cb18
07/25/13 07:10:38 |
Sebastian Huber |
score: Create mpci implementation header
4.115
@6cec745f
07/25/13 08:20:24 |
Sebastian Huber |
rtems: Create signal implementation header
4.115
@5618c37a
07/24/13 13:14:48 |
Sebastian Huber |
score: Create thread implementation header
4.115
@f0bfd7d8
07/24/13 11:25:57 |
Sebastian Huber |
score: Create prioritybitmap implementation header
Move …
4.115
@c6e21ee1
07/24/13 11:12:38 |
Sebastian Huber |
score: Create scheduler implementation header
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@c404828
07/23/13 12:56:00 |
Sebastian Huber |
rtems: Create tasks implementation header
4.115
@f6c7c57d
07/23/13 12:38:19 |
Sebastian Huber |
rtems: Create region implementation header
4.115
@8695cae
07/23/13 12:19:58 |
Sebastian Huber |
rtems: Create part implementation header
4.115
@e90b1df
07/23/13 11:51:08 |
Sebastian Huber |
rtems: Create timer implementation header
4.115
@ecdcf01
07/23/13 11:13:45 |
Sebastian Huber |
rtems: Create ratemon implementation header
4.115
@562815c
07/23/13 11:00:31 |
Sebastian Huber |
rtems: Create dpmem implementation header
4.115
@e151eb1
07/23/13 10:47:35 |
Sebastian Huber |
rtems: Create event implementation header
4.115
@faa2f8c4
07/23/13 08:54:37 |
Sebastian Huber |
rtems: Create status implementation header
4.115
@ac252bdc
07/23/13 08:04:19 |
Sebastian Huber |
sapi: Create extension implementation header
4.115
@2445bda
07/23/13 07:50:22 |
Sebastian Huber |
sapi: Merge rbtree API into one file
4.115
@98c7eaca
07/23/13 07:48:38 |
Sebastian Huber |
sapi: Merge timespec API into one file
4.115
@b5ffa5e
07/23/13 07:44:47 |
Sebastian Huber |
sapi: Merge CBS API into one file
4.115
@b1564cc
07/22/13 14:27:30 |
Sebastian Huber |
sapi: Merge chain implementation into one file
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@6e93dc4a
07/22/13 08:49:19 |
Sebastian Huber |
score: Create chain implementation header
4.115
@eb448eec
07/19/13 13:18:08 |
Sebastian Huber |
posix: Create spinlock implementation header
4.115
@f17c779
07/19/13 13:08:53 |
Sebastian Huber |
posix: Create timer implementation header
4.115
@0e8656b4
07/19/13 12:39:45 |
Sebastian Huber |
posix: Create rwlock implementation header
4.115
@0c5317d
07/19/13 12:33:56 |
Sebastian Huber |
posix: Create pthread implementation header
4.115
@97552c98
07/19/13 12:15:59 |
Sebastian Huber |
posix: Create priority implementation header
4.115
@35210b12
07/19/13 10:08:02 |
Sebastian Huber |
posix: Create condition variable impl header
4.115
