@833dd90
11/19/13 15:09:39 |
Sebastian Huber |
score/rbtree: Delete protected operations
The user of the red-black …
4.115
@3c96bee
09/12/13 13:32:07 |
Sebastian Huber |
JFFS2: Add RTEMS support
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@23de794d
08/26/13 12:27:52 |
Sebastian Huber |
score: Add and use CHAIN_INITIALIZER_ONE_NODE().
Add and use …
4.115
@6e4c01e
08/23/13 04:56:36 |
Chris Johns |
posix: Update to the pthread_once changes.
Implement the reeview …
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@9d83f58a
08/12/13 08:32:32 |
Sebastian Huber |
smp: Replace Scheduler_simple_smp_Control
Replace …
4.115
@c1a356e9
08/09/13 12:31:02 |
Sebastian Huber |
score: _Priority_bit_map_Handler_initialization()
Delete …
4.115
@03acc59
08/14/13 00:21:41 |
Chris Johns |
posix: Change pthread_once to be SMP safe.
Change pthread_once from …
4.115
@6b4e448
08/06/13 14:01:36 |
Sebastian Huber |
PR766: Delete RTEMS_INSIDE
4.115
@2ad250e
08/06/13 12:46:24 |
Sebastian Huber |
posix: Create key implementation header
Move implementation specific …
4.115
@b5c9064
08/05/13 13:20:45 |
ashi08104 |
Unlimited objects support for POSIX keys
This patch enables unlimited …
4.115
@b4b309c
08/01/13 13:20:17 |
Sebastian Huber |
smp: Generalize _Thread_Start_multitasking()
Add context parameter to …
4.115
@2bca05f7
08/01/13 12:55:03 |
Sebastian Huber |
score: Delete SYSTEM_STATE_BEGIN_MULTITASKING
Nothing happened …
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@c236082
07/30/13 13:54:53 |
Sebastian Huber |
smp: Provide cache optimized Per_CPU_Control
Delete …
4.115
@a2e3f33
07/24/13 11:50:54 |
Sebastian Huber |
score: Create object implementation header
Move implementation …
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@7f04cb18
07/25/13 07:10:38 |
Sebastian Huber |
score: Create mpci implementation header
4.115
@6cec745f
07/25/13 08:20:24 |
Sebastian Huber |
rtems: Create signal implementation header
4.115
@5618c37a
07/24/13 13:14:48 |
Sebastian Huber |
score: Create thread implementation header
4.115
@f0bfd7d8
07/24/13 11:25:57 |
Sebastian Huber |
score: Create prioritybitmap implementation header
Move …
4.115
@c6e21ee1
07/24/13 11:12:38 |
Sebastian Huber |
score: Create scheduler implementation header
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@c404828
07/23/13 12:56:00 |
Sebastian Huber |
rtems: Create tasks implementation header
4.115
@f6c7c57d
07/23/13 12:38:19 |
Sebastian Huber |
rtems: Create region implementation header
4.115
@8695cae
07/23/13 12:19:58 |
Sebastian Huber |
rtems: Create part implementation header
4.115
@e90b1df
07/23/13 11:51:08 |
Sebastian Huber |
rtems: Create timer implementation header
4.115
@ecdcf01
07/23/13 11:13:45 |
Sebastian Huber |
rtems: Create ratemon implementation header
4.115
@562815c
07/23/13 11:00:31 |
Sebastian Huber |
rtems: Create dpmem implementation header
4.115
@e151eb1
07/23/13 10:47:35 |
Sebastian Huber |
rtems: Create event implementation header
4.115
@faa2f8c4
07/23/13 08:54:37 |
Sebastian Huber |
rtems: Create status implementation header
4.115
@ac252bdc
07/23/13 08:04:19 |
Sebastian Huber |
sapi: Create extension implementation header
4.115
@2445bda
07/23/13 07:50:22 |
Sebastian Huber |
sapi: Merge rbtree API into one file
4.115
@98c7eaca
07/23/13 07:48:38 |
Sebastian Huber |
sapi: Merge timespec API into one file
4.115
@b5ffa5e
07/23/13 07:44:47 |
Sebastian Huber |
sapi: Merge CBS API into one file
4.115
@b1564cc
07/22/13 14:27:30 |
Sebastian Huber |
sapi: Merge chain implementation into one file
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@6e93dc4a
07/22/13 08:49:19 |
Sebastian Huber |
score: Create chain implementation header
4.115
@eb448eec
07/19/13 13:18:08 |
Sebastian Huber |
posix: Create spinlock implementation header
4.115
@f17c779
07/19/13 13:08:53 |
Sebastian Huber |
posix: Create timer implementation header
4.115
@0e8656b4
07/19/13 12:39:45 |
Sebastian Huber |
posix: Create rwlock implementation header
4.115
@0c5317d
07/19/13 12:33:56 |
Sebastian Huber |
posix: Create pthread implementation header
4.115
@97552c98
07/19/13 12:15:59 |
Sebastian Huber |
posix: Create priority implementation header
4.115
@35210b12
07/19/13 10:08:02 |
Sebastian Huber |
posix: Create condition variable impl header
4.115
@6b4a3770
07/19/13 08:51:44 |
Sebastian Huber |
posix: Create barrier implementation header
4.115
@0b32bb8
07/19/13 08:42:39 |
Sebastian Huber |
rtems: Create barrier implementation header
4.115
@972a5c5f
07/18/13 13:12:05 |
Sebastian Huber |
posix: Create message queue implementation header
4.115
@993a888
07/18/13 13:05:37 |
Sebastian Huber |
rtems: Create message queue implementation header
4.115
@9c743e8e
07/18/13 11:50:25 |
Sebastian Huber |
posix: Create semaphore implementation header
4.115
@05e82bd7
07/18/13 09:53:48 |
Sebastian Huber |
score: Error for non-preemptible tasks on SMP
A common use case for …
4.115
@f913c79
07/18/13 09:27:39 |
Sebastian Huber |
sapi: Add rtems_configuration_is_smp_enabled()
Add a configuration …
4.115
@f9d533a5
07/17/13 12:34:05 |
Sebastian Huber |
posix: Create mutex implementation header
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@9c9b62d8
07/17/13 09:44:55 |
Sebastian Huber |
score: Changes due to Newlib DYNAMIC_REENT
Delete …
4.115
@a936aa49
06/06/13 13:41:00 |
Sebastian Huber |
scheduler: New simple SMP scheduler implementation
The new Simple SMP …
4.115
@2d2352b
06/05/13 09:48:57 |
Sebastian Huber |
score: Add and use _Objects_Put()
Add and use …
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@e071c183
05/16/13 09:08:40 |
Sebastian Huber |
smp: Move secondary CPU initialization request
Do not assume that the …
4.115
@baf8f4d
05/14/13 08:12:52 |
Sebastian Huber |
smp: Simplify main CPU initialization
Call _SMP_Handler_initialize() …
4.115
@6c2eedc
05/13/13 11:37:06 |
Sebastian Huber |
smp: Add maximum_processors field to config
Delete …
4.115
@b7cf1ff7
04/24/13 13:04:30 |
Sebastian Huber |
libcsupport: Delete libc_wrapup()
Add and use …
4.115
@5fa0e5c5
04/24/13 12:37:50 |
Sebastian Huber |
libcsupport: Rename open_dev_console()
Rename open_dev_console() to …
4.115
@a290fbe9
04/24/13 12:30:42 |
Sebastian Huber |
libcsupport: Make LibIO helper const
Add and use rtems_libio_helper …
4.115
@10e348ab
04/23/13 07:46:29 |
Sebastian Huber |
sapi: Fix warnings
4.115
@dc76d98
04/11/13 11:57:10 |
Sebastian Huber |
sapi: Fix unified workspace option
4.115
@6784547
04/07/13 22:28:48 |
Joel Sherrill |
confdefs.h: Only one clock or timer configuration parameter can be …
4.115
@92b33b8d
04/07/13 22:27:46 |
Joel Sherrill |
confdefs.h: Eliminate BSP_DEFAULT_UNIFIED_WORK_AREAS
This was not …
4.115
@5f745464
03/19/13 13:48:24 |
Andreas Heinig |
Fixed 2 compiler warnings
4.115
@7571a23
01/27/13 14:10:39 |
Sebastian Huber |
sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS
4.115
@68f36d14
01/27/13 13:02:50 |
Sebastian Huber |
score: Add and use rtems_assert_context
4.115
@e858f70
01/10/13 23:06:06 |
Joel Sherrill |
cpukit: Fix many Doxygen warnings
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@e82fcb4
01/09/13 19:38:55 |
Sebastian Huber |
sapi: Documentation
4.115
@27f071cd
01/08/13 13:13:41 |
alexivanov97 |
sapi: Doxygen Clean Up Task #1
4.115
@f2f39b62
01/07/13 15:01:45 |
Sebastian Huber |
sapi: Add rtems_fatal_source_description()
4.115
@0ca61727
12/22/12 16:58:50 |
Sebastian Huber |
score: Add const qualifier
4.115
@3cf4031
12/28/12 23:48:12 |
alexivanov97 |
Header File Doxygen Enhancement Task #1
4.115
@c5782a2
12/28/12 17:16:29 |
matkallada |
Header File Doxygen Enhancement Task #7
4.115
@9ab091e
12/28/12 16:35:32 |
matkallada |
Header File Doxygen Enhancement Task #2
4.115
@cbd07e4
12/21/12 08:50:15 |
Sebastian Huber |
score: Add rtems_chain_node_count_unprotected()
4.115
@11109ea
12/18/12 20:46:38 |
alexivanov97 |
libfs: Doxygen Enhancement Task #2
4.115
@c2ae79e
12/12/12 20:57:49 |
matkallada |
misc: Header File Doxygen Enhancement Task #3
4.115
@e12f5acf
12/09/12 13:12:19 |
Sebastian Huber |
sapi: Fix previous commit
4.115
@50dd75a
12/09/12 13:06:56 |
Sebastian Huber |
sapi: Revert documentation change
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@f9340ed7
12/03/12 10:35:43 |
Sebastian Huber |
posix: Add and use <rtems/posix/psignalimpl.h>
This file contains the …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@e4b40531
11/14/12 11:37:24 |
Sebastian Huber |
sapi: Add rtems_fatal_source and rtems_fatal_code
4.115
@228df42
11/07/12 13:10:56 |
Sebastian Huber |
sapi: Add BSP_INITIAL_EXTENSION to confdefs.h
A BSP can supply an …
4.115
@466cf31d
11/07/12 12:59:19 |
Sebastian Huber |
score: Statically initialize user extensions
The initial extensions …
4.115
@9ed2bef
11/07/12 09:54:49 |
Sebastian Huber |
score: Add and use RTEMS_ARRAY_SIZE()
4.115
@2195fd27
11/07/12 10:23:03 |
Sebastian Huber |
sapi: Make initial user extensions table read-only
4.115
@b596754
11/07/12 09:19:46 |
Sebastian Huber |
sapi: Fix user scheduler configuration
The comment in confdefs.h …
4.115
