source: rtems/cpukit/sapi
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @05e82bd7   07/18/13 09:53:48 Sebastian Huber score: Error for non-preemptible tasks on SMP A common use case for … 4.115
(edit) @f913c79   07/18/13 09:27:39 Sebastian Huber sapi: Add rtems_configuration_is_smp_enabled() Add a configuration … 4.115
(edit) @f9d533a5   07/17/13 12:34:05 Sebastian Huber posix: Create mutex implementation header Move implementation … 4.115
(edit) @2bbea657   07/17/13 11:52:00 Sebastian Huber rtems: Create semaphore implementation header Move implementation … 4.115
(edit) @9c9b62d8   07/17/13 09:44:55 Sebastian Huber score: Changes due to Newlib DYNAMIC_REENT Delete … 4.115
(edit) @a936aa49   06/06/13 13:41:00 Sebastian Huber scheduler: New simple SMP scheduler implementation The new Simple SMP … 4.115
(edit) @2d2352b   06/05/13 09:48:57 Sebastian Huber score: Add and use _Objects_Put() Add and use … 4.115
(edit) @e3be6915   05/27/13 15:31:46 Sebastian Huber score: Remove idle field of Per_CPU_Control This field is unused … 4.115
(edit) @e071c183   05/16/13 09:08:40 Sebastian Huber smp: Move secondary CPU initialization request Do not assume that the … 4.115
(edit) @baf8f4d   05/14/13 08:12:52 Sebastian Huber smp: Simplify main CPU initialization Call _SMP_Handler_initialize() … 4.115
(edit) @6c2eedc   05/13/13 11:37:06 Sebastian Huber smp: Add maximum_processors field to config Delete … 4.115
(edit) @b7cf1ff7   04/24/13 13:04:30 Sebastian Huber libcsupport: Delete libc_wrapup() Add and use … 4.115
(edit) @5fa0e5c5   04/24/13 12:37:50 Sebastian Huber libcsupport: Rename open_dev_console() Rename open_dev_console() to … 4.115
(edit) @a290fbe9   04/24/13 12:30:42 Sebastian Huber libcsupport: Make LibIO helper const Add and use rtems_libio_helper … 4.115
(edit) @10e348ab   04/23/13 07:46:29 Sebastian Huber sapi: Fix warnings 4.115
(edit) @dc76d98   04/11/13 11:57:10 Sebastian Huber sapi: Fix unified workspace option 4.115
(edit) @6784547   04/07/13 22:28:48 Joel Sherrill confdefs.h: Only one clock or timer configuration parameter can be … 4.115
(edit) @92b33b8d   04/07/13 22:27:46 Joel Sherrill confdefs.h: Eliminate BSP_DEFAULT_UNIFIED_WORK_AREAS This was not … 4.115
(edit) @5f745464   03/19/13 13:48:24 Andreas Heinig Fixed 2 compiler warnings 4.115
(edit) @7571a23   01/27/13 14:10:39 Sebastian Huber sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS 4.115
(edit) @68f36d14   01/27/13 13:02:50 Sebastian Huber score: Add and use rtems_assert_context 4.115
(edit) @e858f70   01/10/13 23:06:06 Joel Sherrill cpukit: Fix many Doxygen warnings 4.115
(edit) @b697bc6   01/10/13 21:06:42 Joel Sherrill cpukit: Use Consistent Beginning of Doxygen Group Notation This is … 4.115
(edit) @a15eaaf   01/10/13 19:20:34 Joel Sherrill cpukit: Doxygen group fixes and many warnings addressed The output of … 4.115
(edit) @e82fcb4   01/09/13 19:38:55 Sebastian Huber sapi: Documentation 4.115
(edit) @27f071cd   01/08/13 13:13:41 alexivanov97 sapi: Doxygen Clean Up Task #1 4.115
(edit) @f2f39b62   01/07/13 15:01:45 Sebastian Huber sapi: Add rtems_fatal_source_description() 4.115
(edit) @0ca61727   12/22/12 16:58:50 Sebastian Huber score: Add const qualifier 4.115
(edit) @3cf4031   12/28/12 23:48:12 alexivanov97 Header File Doxygen Enhancement Task #1 4.115
(edit) @c5782a2   12/28/12 17:16:29 matkallada Header File Doxygen Enhancement Task #7 4.115
(edit) @9ab091e   12/28/12 16:35:32 matkallada Header File Doxygen Enhancement Task #2 4.115
(edit) @cbd07e4   12/21/12 08:50:15 Sebastian Huber score: Add rtems_chain_node_count_unprotected() 4.115
(edit) @11109ea   12/18/12 20:46:38 alexivanov97 libfs: Doxygen Enhancement Task #24.115
(edit) @c2ae79e   12/12/12 20:57:49 matkallada misc: Header File Doxygen Enhancement Task #34.115
(edit) @e12f5acf   12/09/12 13:12:19 Sebastian Huber sapi: Fix previous commit 4.115
(edit) @50dd75a   12/09/12 13:06:56 Sebastian Huber sapi: Revert documentation change 4.115
(edit) @4c98a3e   12/07/12 14:49:54 Christopher Kerl sapi misc: Clean up Doxygen GCI task #14.115
(edit) @48bff53b   12/06/12 16:47:30 Sebastian Huber score: rtems_initialize_start_multitasking() Do not return from … 4.115
(edit) @f9340ed7   12/03/12 10:35:43 Sebastian Huber posix: Add and use <rtems/posix/psignalimpl.h> This file contains the … 4.115
(edit) @815994f   11/25/12 16:48:11 Sebastian Huber score: Add CPU_Exception_frame Add CPU port type CPU_Exception_frame … 4.115
(edit) @3be0c9a   11/22/12 13:51:25 Sebastian Huber score: Add and use <rtems/score/userextimpl.h> This file contains the … 4.115
(edit) @e2e5b492   11/14/12 08:51:41 Sebastian Huber score: Add rtems_fatal() 4.115
(edit) @b31a960   11/13/12 16:53:43 Sebastian Huber score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR Use … 4.115
(edit) @dc6e830   11/13/12 16:40:33 Sebastian Huber sapi: Add and use rtems_internal_error_description 4.115
(edit) @e4b40531   11/14/12 11:37:24 Sebastian Huber sapi: Add rtems_fatal_source and rtems_fatal_code 4.115
(edit) @228df42   11/07/12 13:10:56 Sebastian Huber sapi: Add BSP_INITIAL_EXTENSION to confdefs.h A BSP can supply an … 4.115
(edit) @466cf31d   11/07/12 12:59:19 Sebastian Huber score: Statically initialize user extensions The initial extensions … 4.115
(edit) @9ed2bef   11/07/12 09:54:49 Sebastian Huber score: Add and use RTEMS_ARRAY_SIZE() 4.115
(edit) @2195fd27   11/07/12 10:23:03 Sebastian Huber sapi: Make initial user extensions table read-only 4.115
(edit) @b596754   11/07/12 09:19:46 Sebastian Huber sapi: Fix user scheduler configuration The comment in confdefs.h … 4.115
(edit) @ae4f125e   11/06/12 12:54:05 Sebastian Huber sapi: Make Configuration read-only The Configuration is now read-only … 4.115
(edit) @ef5f359   11/06/12 11:18:10 Sebastian Huber sapi: Delete duplicate declarations 4.115
(edit) @e39fa07   11/06/12 11:13:29 Sebastian Huber sapi: Delete unused macros Delete rtems_configuration_get_table(), … 4.115
(edit) @f536e12   11/06/12 10:59:43 Sebastian Huber sapi: Use rtems_*_get_user_multiprocessing_table 4.115
(edit) @2b875ff5   11/06/12 10:40:35 Sebastian Huber sapi: Use rtems_config*_get_maximum_extensions 4.115
(edit) @ec8b6c4   11/06/12 10:37:11 Sebastian Huber sapi: Use rtems_config*_get_device_driver_table 4.115
(edit) @1a75b4b   11/06/12 10:36:01 Sebastian Huber sapi: Use rtems_conf*_get_number_of_device_drivers 4.115
(edit) @c53b330c   11/06/12 10:34:10 Sebastian Huber sapi: Use rtems_configuration_get_maximum_drivers 4.115
(edit) @47a3cd8   08/09/12 14:48:00 Sebastian Huber score: Work area initialization API change The work areas (RTEMS work … 4.115
(edit) @fd71610   10/11/12 16:25:03 Ralf Corsepius Cleanup Krzysztof's copyright notices. 4.115
(edit) @a6eaa548   08/29/12 12:38:54 Krzysztof Miesowicz timespec helpers: Add wrappers with new test 4.115
(edit) @50fc8f6   06/13/12 07:44:32 Sebastian Huber sapi: Add nanoseconds_per_tick to configuration Add … 4.115
(edit) @39ee704e   05/31/12 08:27:29 Sebastian Huber libblock: Add read-ahead task Read-ahead requests were previously … 4.115
(edit) @b6911069   05/29/12 16:02:52 Sebastian Huber libblock: Add task stack size bdbuf configuration The task stack size … 4.115
(edit) @9b4422a2   05/03/12 15:09:24 Joel Sherrill Remove All CVS Id Strings Possible Using a Script Script does what is … 4.115
(edit) @f53aa8d   05/03/12 16:43:29 Gedare Bloom rbtree: API changes. Remove rbtree control node from RBTree_Next. The … 4.115
(edit) @8572752   05/02/12 16:10:34 Gedare Bloom rbtree: API Changes Make default for rtems_rbtree functions be … 4.115
(edit) @33a105fb   05/07/12 16:08:48 Joel Sherrill Revert: Remove CVS Ids See … 4.115
(edit) @5a4bb75   04/26/12 12:28:52 Sebastian Huber Filesystem: Remove per file descriptor semaphore The per file … 4.115
(edit) @ee32f67a   05/04/12 06:55:28 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @5c51ba1   04/16/12 08:38:31 Sebastian Huber rbheap: API changes and documentation 4.115
(edit) @8c6608bd   04/13/12 07:10:12 Sebastian Huber rbtree: PR2046: Replace rtems_rbtree_unique 4.115
(edit) @5eb434e   04/11/12 13:04:22 Sebastian Huber score: New macros and functions New macros o … 4.115
(edit) @e752630   04/10/12 09:19:39 Sebastian Huber rbheap: New files In the Red-Black Tree Heap the administration data … 4.115
(edit) @dc62a48c   04/10/12 08:25:14 Sebastian Huber rbtree: PR1995: API change New functions o … 4.115
(edit) @9fc284c   03/30/12 09:35:39 Sebastian Huber score/rbtree: Add const qualifier 4.115
(edit) @e53aae2   03/26/12 20:42:38 Gedare Bloom confdefs: Add declaration for unlimited objects. Adds to confdefs a … 4.115
(edit) @3b7c123   03/13/12 10:33:51 Sebastian Huber Filesystem: Reference counting for locations o A new data structure … 4.115
(edit) @5693f2e   02/22/12 08:58:59 Ralf Corsepius 2012-02-22 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @184a612e   02/02/12 14:17:25 Joel Sherrill Merge remote branch 'remotes/origin/gitignore' 4.115
(edit) @72a3af3   01/23/12 14:55:42 Sebastian Huber Extended API to support iteration of const chains. 4.115
(edit) @61250b4   02/01/12 16:59:44 Joel Sherrill Remove all .cvsignore files. 4.115
(edit) @9fa3cf0d   12/14/11 13:17:19 Sebastian Huber 2011-12-14 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @3df4d74   12/13/11 14:37:03 Sebastian Huber 2011-12-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @517bf08   12/13/11 10:52:21 Sebastian Huber 2011-12-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @0042168   12/08/11 14:13:55 Ralf Corsepius 2011-12-08 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @540eec6e   12/05/11 17:01:30 Ralf Corsepius 2011-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @b929b39e   12/05/11 13:51:06 Ralf Corsepius 2011-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @84e1742   11/18/11 20:04:49 Jennifer.Averett 2011-11-18 Jennifer Averett <Jennifer.Averett@…> * … 4.115
(edit) @b4f635e   11/10/11 14:40:13 Sebastian Huber 2011-11-10 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @48943dc   10/10/11 07:11:26 Ralf Corsepius 2011-10-10 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @82db8e56   09/15/11 15:49:32 Joel Sherrill 2011-09-15 Petr Benes <benesp16@…> PR 1906/cpukit * … 4.115
(edit) @5472ad41   09/11/11 20:52:37 Joel Sherrill 2011-09-11 Petr Benes <benesp16@…> PR 1896/cpukit * … 4.115
(edit) @5817297   09/09/11 11:02:03 Sebastian Huber 2011-09-09 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @ac9d2ecc   09/01/11 18:13:54 Joel Sherrill 2011-09-01 Petr Benes <benesp16@…> PR 1895/cpukit * … 4.115
(edit) @adae165b   08/29/11 21:30:32 Joel Sherrill 2011-08-29 Joel Sherrill <joel.sherrilL@…> * … 4.115
(edit) @74f1c73e   08/21/11 20:07:11 Joel Sherrill 2011-08-21 Petr Benes <benesp16@…> PR 1886/cpukit * … 4.115
(edit) @542ae51   08/17/11 09:14:09 Sebastian Huber 2011-08-17 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @6de36ed   08/16/11 11:40:53 Sebastian Huber 2011-08-16 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @13c4f853   08/02/11 19:25:59 Joel Sherrill 2011-08-02 Joel Sherrill <joel.sherrill@…> PR 1877/cpukit … 4.115
