@31be416
04/20/15 09:08:22 |
alexander.krutwig |
timecounter: Port to RTEMS
New test sptests/timecounter01.
Update #2271.
4.115
@8d6fd40
04/17/15 06:45:50 |
Sebastian Huber |
sapi: Avoid declaration in source, fix type
4.115
@e7fade3
11/28/11 08:52:03 |
Daniel Hellstrom |
DRVMGR: added driver manager to cpukit/libdrvmgr
4.115
@04cf2c5
11/24/11 15:54:28 |
Daniel Hellstrom |
IO_MANAGER: early dynamic driver registration
Adds the possibility to …
4.115
@a6524b9
03/22/15 13:31:59 |
Sebastian Huber |
score: Simplify debug code and use _Assert()
4.115
@18d0a49
03/05/15 07:44:59 |
Sebastian Huber |
Move test support from sapi to libmisc/testsupport
4.115
@1a3c611c
11/04/14 20:55:43 |
Joel Sherrill |
sapi/src/testextension.c: Fix warnings
4.115
@801ad184
10/24/14 05:09:31 |
Sebastian Huber |
sapi: Use an interrupt lock for test extension
Ensure to report only …
4.115
@a4203273
10/23/14 13:39:28 |
Sebastian Huber |
sapi: Report only if not an SMP shutdown response
4.115
@fe826e2
09/02/14 12:10:19 |
Sebastian Huber |
sapi: Add profiling report begin/end message
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@99be750
04/29/14 05:48:09 |
Sebastian Huber |
sapi: Report profiling only if enabled for tests
4.115
@aea93fb4
04/22/14 09:50:29 |
Sebastian Huber |
sapi: Add profiling done message
4.115
@8365ad1
04/22/14 09:46:10 |
Sebastian Huber |
sapi: Add arithmetic means to XML profiling report
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@e72bc923
03/10/14 14:17:27 |
Sebastian Huber |
sapi: Add profiling report for tests
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@51f823c9
03/18/14 07:28:14 |
Sebastian Huber |
posix: Use interal mutex for once implementation
Enable …
4.115
@840ae71
03/10/14 13:39:41 |
Sebastian Huber |
sapi: Add <rtems/test.h>
Provide support functions to print the …
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@f980561
03/10/14 09:04:09 |
Sebastian Huber |
score: Add per-CPU profiling
Add per-CPU profiling stats API. …
4.115
@350f88dc
03/10/14 09:20:40 |
Sebastian Huber |
sapi: Add SMP lock profiling app. level data
4.115
@29c9eb6
03/10/14 09:03:55 |
Sebastian Huber |
sapi: Add per-CPU profiling application level data
4.115
@4dad4b8
03/10/14 13:39:49 |
Sebastian Huber |
sapi: Add profiling application level support
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@e6c87f7
03/04/14 21:54:12 |
Joel Sherrill |
POSIX keys now enabled in all configurations.
Formerly POSIX keys …
4.115
@039a189d
01/27/14 19:55:58 |
Jennifer Averett |
sapi: Moved smp initialization and added cpuset initilization.
SMP …
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@6ca4f6a
02/17/14 13:56:51 |
Sebastian Huber |
score: Add and use <rtems/score/smpimpl.h>
Collect SMP implementation …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@8a6de83
02/17/14 09:10:27 |
Sebastian Huber |
score: Move _SMP_Request_other_cores_to_shutdown()
Move …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@4ea97d24
11/19/13 15:21:54 |
Sebastian Huber |
score/rbtree: Remove "unprotected" from API
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@6e4c01e
08/23/13 04:56:36 |
Chris Johns |
posix: Update to the pthread_once changes.
Implement the reeview …
4.115
@c1a356e9
08/09/13 12:31:02 |
Sebastian Huber |
score: _Priority_bit_map_Handler_initialization()
Delete …
4.115
@03acc59
08/14/13 00:21:41 |
Chris Johns |
posix: Change pthread_once to be SMP safe.
Change pthread_once from …
4.115
@2ad250e
08/06/13 12:46:24 |
Sebastian Huber |
posix: Create key implementation header
Move implementation specific …
4.115
@b4b309c
08/01/13 13:20:17 |
Sebastian Huber |
smp: Generalize _Thread_Start_multitasking()
Add context parameter to …
4.115
@2bca05f7
08/01/13 12:55:03 |
Sebastian Huber |
score: Delete SYSTEM_STATE_BEGIN_MULTITASKING
Nothing happened …
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@a2e3f33
07/24/13 11:50:54 |
Sebastian Huber |
score: Create object implementation header
Move implementation …
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@7f04cb18
07/25/13 07:10:38 |
Sebastian Huber |
score: Create mpci implementation header
4.115
@6cec745f
07/25/13 08:20:24 |
Sebastian Huber |
rtems: Create signal implementation header
4.115
@5618c37a
07/24/13 13:14:48 |
Sebastian Huber |
score: Create thread implementation header
4.115
@f0bfd7d8
07/24/13 11:25:57 |
Sebastian Huber |
score: Create prioritybitmap implementation header
Move …
4.115
@c6e21ee1
07/24/13 11:12:38 |
Sebastian Huber |
score: Create scheduler implementation header
4.115
@c404828
07/23/13 12:56:00 |
Sebastian Huber |
rtems: Create tasks implementation header
4.115
@f6c7c57d
07/23/13 12:38:19 |
Sebastian Huber |
rtems: Create region implementation header
4.115
@8695cae
07/23/13 12:19:58 |
Sebastian Huber |
rtems: Create part implementation header
4.115
@e90b1df
07/23/13 11:51:08 |
Sebastian Huber |
rtems: Create timer implementation header
4.115
@ecdcf01
07/23/13 11:13:45 |
Sebastian Huber |
rtems: Create ratemon implementation header
4.115
@562815c
07/23/13 11:00:31 |
Sebastian Huber |
rtems: Create dpmem implementation header
4.115
@e151eb1
07/23/13 10:47:35 |
Sebastian Huber |
rtems: Create event implementation header
4.115
@faa2f8c4
07/23/13 08:54:37 |
Sebastian Huber |
rtems: Create status implementation header
4.115
@ac252bdc
07/23/13 08:04:19 |
Sebastian Huber |
sapi: Create extension implementation header
4.115
@4b48ece0
07/22/13 08:21:03 |
Sebastian Huber |
score: Create watchdog implementation header
4.115
@eb448eec
07/19/13 13:18:08 |
Sebastian Huber |
posix: Create spinlock implementation header
4.115
@f17c779
07/19/13 13:08:53 |
Sebastian Huber |
posix: Create timer implementation header
4.115
@0e8656b4
07/19/13 12:39:45 |
Sebastian Huber |
posix: Create rwlock implementation header
4.115
@0c5317d
07/19/13 12:33:56 |
Sebastian Huber |
posix: Create pthread implementation header
4.115
@97552c98
07/19/13 12:15:59 |
Sebastian Huber |
posix: Create priority implementation header
4.115
@35210b12
07/19/13 10:08:02 |
Sebastian Huber |
posix: Create condition variable impl header
4.115
@6b4a3770
07/19/13 08:51:44 |
Sebastian Huber |
posix: Create barrier implementation header
4.115
@0b32bb8
07/19/13 08:42:39 |
Sebastian Huber |
rtems: Create barrier implementation header
4.115
@972a5c5f
07/18/13 13:12:05 |
Sebastian Huber |
posix: Create message queue implementation header
4.115
@993a888
07/18/13 13:05:37 |
Sebastian Huber |
rtems: Create message queue implementation header
4.115
@9c743e8e
07/18/13 11:50:25 |
Sebastian Huber |
posix: Create semaphore implementation header
4.115
@f9d533a5
07/17/13 12:34:05 |
Sebastian Huber |
posix: Create mutex implementation header
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@2d2352b
06/05/13 09:48:57 |
Sebastian Huber |
score: Add and use _Objects_Put()
Add and use …
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@e071c183
05/16/13 09:08:40 |
Sebastian Huber |
smp: Move secondary CPU initialization request
Do not assume that the …
4.115
@baf8f4d
05/14/13 08:12:52 |
Sebastian Huber |
smp: Simplify main CPU initialization
Call _SMP_Handler_initialize() …
4.115
@6c2eedc
05/13/13 11:37:06 |
Sebastian Huber |
smp: Add maximum_processors field to config
Delete …
4.115
@10e348ab
04/23/13 07:46:29 |
Sebastian Huber |
sapi: Fix warnings
4.115
@5f745464
03/19/13 13:48:24 |
Andreas Heinig |
Fixed 2 compiler warnings
4.115
@f2f39b62
01/07/13 15:01:45 |
Sebastian Huber |
sapi: Add rtems_fatal_source_description()
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
This file contains the …
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@f536e12
11/06/12 10:59:43 |
Sebastian Huber |
sapi: Use rtems_*_get_user_multiprocessing_table
4.115
@2b875ff5
11/06/12 10:40:35 |
Sebastian Huber |
sapi: Use rtems_config*_get_maximum_extensions
4.115
@ec8b6c4
11/06/12 10:37:11 |
Sebastian Huber |
sapi: Use rtems_config*_get_device_driver_table
4.115
