source: rtems/cpukit/sapi/include
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @e2e5b492   11/14/12 08:51:41 Sebastian Huber score: Add rtems_fatal() 4.115
(edit) @dc6e830   11/13/12 16:40:33 Sebastian Huber sapi: Add and use rtems_internal_error_description 4.115
(edit) @e4b40531   11/14/12 11:37:24 Sebastian Huber sapi: Add rtems_fatal_source and rtems_fatal_code 4.115
(edit) @228df42   11/07/12 13:10:56 Sebastian Huber sapi: Add BSP_INITIAL_EXTENSION to confdefs.h A BSP can supply an … 4.115
(edit) @466cf31d   11/07/12 12:59:19 Sebastian Huber score: Statically initialize user extensions The initial extensions … 4.115
(edit) @9ed2bef   11/07/12 09:54:49 Sebastian Huber score: Add and use RTEMS_ARRAY_SIZE() 4.115
(edit) @2195fd27   11/07/12 10:23:03 Sebastian Huber sapi: Make initial user extensions table read-only 4.115
(edit) @b596754   11/07/12 09:19:46 Sebastian Huber sapi: Fix user scheduler configuration The comment in confdefs.h … 4.115
(edit) @ae4f125e   11/06/12 12:54:05 Sebastian Huber sapi: Make Configuration read-only The Configuration is now read-only … 4.115
(edit) @ef5f359   11/06/12 11:18:10 Sebastian Huber sapi: Delete duplicate declarations 4.115
(edit) @e39fa07   11/06/12 11:13:29 Sebastian Huber sapi: Delete unused macros Delete rtems_configuration_get_table(), … 4.115
(edit) @c53b330c   11/06/12 10:34:10 Sebastian Huber sapi: Use rtems_configuration_get_maximum_drivers 4.115
(edit) @47a3cd8   08/09/12 14:48:00 Sebastian Huber score: Work area initialization API change The work areas (RTEMS work … 4.115
(edit) @fd71610   10/11/12 16:25:03 Ralf Corsepius Cleanup Krzysztof's copyright notices. 4.115
(edit) @a6eaa548   08/29/12 12:38:54 Krzysztof Miesowicz timespec helpers: Add wrappers with new test 4.115
(edit) @50fc8f6   06/13/12 07:44:32 Sebastian Huber sapi: Add nanoseconds_per_tick to configuration Add … 4.115
(edit) @39ee704e   05/31/12 08:27:29 Sebastian Huber libblock: Add read-ahead task Read-ahead requests were previously … 4.115
(edit) @b6911069   05/29/12 16:02:52 Sebastian Huber libblock: Add task stack size bdbuf configuration The task stack size … 4.115
(edit) @9b4422a2   05/03/12 15:09:24 Joel Sherrill Remove All CVS Id Strings Possible Using a Script Script does what is … 4.115
(edit) @5a4bb75   04/26/12 12:28:52 Sebastian Huber Filesystem: Remove per file descriptor semaphore The per file … 4.115
(edit) @5c51ba1   04/16/12 08:38:31 Sebastian Huber rbheap: API changes and documentation 4.115
(edit) @8c6608bd   04/13/12 07:10:12 Sebastian Huber rbtree: PR2046: Replace rtems_rbtree_unique 4.115
(edit) @5eb434e   04/11/12 13:04:22 Sebastian Huber score: New macros and functions New macros o … 4.115
(edit) @e752630   04/10/12 09:19:39 Sebastian Huber rbheap: New files In the Red-Black Tree Heap the administration data … 4.115
(edit) @e53aae2   03/26/12 20:42:38 Gedare Bloom confdefs: Add declaration for unlimited objects. Adds to confdefs a … 4.115
(edit) @3b7c123   03/13/12 10:33:51 Sebastian Huber Filesystem: Reference counting for locations o A new data structure … 4.115
(edit) @5693f2e   02/22/12 08:58:59 Ralf Corsepius 2012-02-22 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @9fa3cf0d   12/14/11 13:17:19 Sebastian Huber 2011-12-14 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @3df4d74   12/13/11 14:37:03 Sebastian Huber 2011-12-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @517bf08   12/13/11 10:52:21 Sebastian Huber 2011-12-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @b929b39e   12/05/11 13:51:06 Ralf Corsepius 2011-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @84e1742   11/18/11 20:04:49 Jennifer.Averett 2011-11-18 Jennifer Averett <Jennifer.Averett@…> * … 4.115
(edit) @b4f635e   11/10/11 14:40:13 Sebastian Huber 2011-11-10 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @48943dc   10/10/11 07:11:26 Ralf Corsepius 2011-10-10 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @82db8e56   09/15/11 15:49:32 Joel Sherrill 2011-09-15 Petr Benes <benesp16@…> PR 1906/cpukit * … 4.115
(edit) @5472ad41   09/11/11 20:52:37 Joel Sherrill 2011-09-11 Petr Benes <benesp16@…> PR 1896/cpukit * … 4.115
(edit) @5817297   09/09/11 11:02:03 Sebastian Huber 2011-09-09 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @ac9d2ecc   09/01/11 18:13:54 Joel Sherrill 2011-09-01 Petr Benes <benesp16@…> PR 1895/cpukit * … 4.115
(edit) @74f1c73e   08/21/11 20:07:11 Joel Sherrill 2011-08-21 Petr Benes <benesp16@…> PR 1886/cpukit * … 4.115
(edit) @542ae51   08/17/11 09:14:09 Sebastian Huber 2011-08-17 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @6de36ed   08/16/11 11:40:53 Sebastian Huber 2011-08-16 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @f58ef8ae   07/13/11 18:34:22 Joel Sherrill 2011-07-13 Joel Sherrill <joel.sherrilL@…> PR 1824/cpukit … 4.115
(edit) @21242c2   06/24/11 17:52:58 Joel Sherrill 2011-06-24 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @c1545f0   05/23/11 16:06:23 Joel Sherrill 2011-05-23 Marta Rybczynska <marta.rybczynska@…> PR … 4.115
(edit) @49f6309b   05/23/11 14:55:58 Joel Sherrill 2011-05-23 Joel Sherrill <joel.sherrilL@…> PR 1804/cpukit … 4.115
(edit) @ba7bc099   05/17/11 19:48:44 Joel Sherrill 2011-05-17 Joel Sherrill <joel.sherrill@…> PR 1789/cpukit … 4.115
(edit) @5af951f   05/13/11 13:49:16 Sebastian Huber 2011-05-13 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @e58f80cb   04/11/11 17:23:06 Joel Sherrill 2011-04-11 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @bd9baa81   04/04/11 18:44:16 Joel Sherrill 2010-07-28 Gedare Bloom <giddyup44@…> PR 1641/cpukit * … 4.115
(edit) @e79093a   04/04/11 16:40:00 Joel Sherrill 2011-04-04 Joel Sherrill <joel.sherrilL@…> PR 1773/cpukit … 4.115
(edit) @06dcaf0   03/16/11 20:05:06 Joel Sherrill 2011-03-16 Jennifer Averett <jennifer.averett@…> PR … 4.115
(edit) @0118ed6   03/16/11 16:32:22 Joel Sherrill 2011-03-16 Jennifer Averett <jennifer.averett@…> PR … 4.115
(edit) @08d01a1   03/10/11 16:39:14 Sebastian Huber 2011-03-10 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @4c794c8   03/03/11 16:01:35 Joel Sherrill 2011-03-03 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @fd580d5   02/23/11 14:13:16 Ralf Corsepius 2011-02-23 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @22c28282   02/21/11 17:00:51 Joel Sherrill 2011-02-21 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @4be93c0   02/21/11 11:54:37 Sebastian Huber 2011-02-21 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @108c4b0   02/18/11 15:12:44 Joel Sherrill 2011-02-18 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @010192d   02/17/11 22:21:44 Joel Sherrill 2011-02-17 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @b2b56cb9   02/09/11 06:18:57 Ralf Corsepius 2011-02-09 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @5aecf664   12/17/10 14:56:06 Joel Sherrill 2010-12-17 Joel Sherrill <joel.sherrill@…> Jennifer … 4.115
(edit) @5c4e0c5   11/25/10 13:24:26 Sebastian Huber 2010-11-25 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @0faa9dad   11/24/10 15:51:28 Joel Sherrill 2010-11-24 Gedare Bloom <giddyup44@…> PR 1647/cpukit * … 4.115
(edit) @db5f134   11/16/10 19:14:10 Joel Sherrill 2010-11-16 Joel Sherrill <joel.sherrill@…> PR 1718/cpukit … 4.115
(edit) @69f2a07   08/24/10 14:29:55 Sebastian Huber 2010-08-24 Sebastian Huber <sebastian.huber@…> PR … 4.115
(edit) @b3263f5   08/20/10 13:26:55 Ralf Corsepius 2010-08-16 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @58fa947   08/11/10 12:16:11 Sebastian Huber 2010-09-11 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @a46e6b6d   07/30/10 18:44:46 Joel Sherrill 2010-07-30 Vinu Rajashekhar <vinutheraj@…> * … 4.115
(edit) @9bd0258d   07/26/10 22:20:43 Joel Sherrill 2010-07-26 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @80c1577   07/26/10 21:28:06 Joel Sherrill 2010-07-26 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @39d3f8d   07/25/10 15:13:35 Joel Sherrill 2010-07-25 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @59673224   07/01/10 09:51:50 Sebastian Huber 2010-07-01 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @0de235f9   06/21/10 21:13:42 Joel Sherrill 2010-06-21 Joel Sherrill <joel.sherrilL@…> PR 1581/cpukit … 4.115
(edit) @46e69ff   06/20/10 19:41:33 Joel Sherrill 2010-06-20 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @659019e   06/19/10 23:39:56 Joel Sherrill 2010-06-19 Joel Sherrill <joel.sherrilL@…> * … 4.115
(edit) @1a5f4bc7   06/18/10 04:04:05 Ralf Corsepius 2010-06-18 Ralf Corsépius <ralf.corsepius@…> * … 4.115
(edit) @08c3066   06/18/10 03:03:22 Ralf Corsepius Remove RTEMS_ITRON_API conditional blocks. 4.115
(edit) @97e2fc3f   06/17/10 18:39:28 Joel Sherrill 2010-06-17 Joel Sherrill <joel.sherrill@…> * … 4.115
(edit) @739329f   06/17/10 18:38:00 Joel Sherrill 2010-06-17 Joel Sherrill <joel.sherrilL@…> * … 4.115
(edit) @f89c34bb   06/14/10 09:48:41 Sebastian Huber 2010-06-14 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @14fc3a77   06/09/10 09:38:10 Sebastian Huber 2010-06-09 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @241f4c96   06/08/10 10:25:46 Sebastian Huber 2010-06-08 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @7d01d244   06/07/10 15:35:24 Sebastian Huber 2010-06-07 Sebastian Huber <sebastian.huber@…> * … 4.115
(edit) @46969df   06/03/10 06:46:51 Chris Johns 2010-06-03 Chris Johns <chrisj@…> * … 4.104.115
(edit) @dfce6724   06/02/10 00:43:13 Chris Johns 2010-06-01 Chris Johns <chrisj@…> * … 4.104.115
(edit) @29e92b0   05/31/10 13:56:37 Chris Johns 2010-05-31 Chris Johns <chrisj@…> * … 4.104.115
(edit) @b2f216e1   05/03/10 09:13:36 Sebastian Huber 2010-05-03 Sebastian Huber <sebastian.huber@…> * … 4.104.115
(edit) @7a09a7a   03/04/10 14:40:51 Joel Sherrill 2010-03-04 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @b7de5de   01/26/10 15:01:56 Thomas.Doerfler User extension API: add const to some params, inline … 4.104.115
(edit) @5ad790ff   11/30/09 13:20:29 Thomas.Doerfler Added defines for initialization of empty chains. 4.104.115
(edit) @28352fae   11/29/09 13:51:53 Ralf Corsepius Whitespace removal. 4.104.115
(edit) @35693ae2   10/21/09 16:06:50 strauman 2009-10-21 Till Straumann <strauman@…> * … 4.104.115
(edit) @031b57c   10/09/09 13:46:39 Joel Sherrill 2009-10-09 Sebastian Huber <Sebastian.Huber@…> * … 4.104.115
(edit) @456a776   10/05/09 15:00:53 Joel Sherrill 2009-10-04 Sebastian Huber <Sebastian.Huber@…> * … 4.104.115
(edit) @c42d1a4   09/25/09 17:51:46 Joel Sherrill 2009-09-25 Sebastian Huber <Sebastian.Huber@…> * … 4.104.115
(edit) @7bbedbe   08/26/09 12:18:42 Joel Sherrill 2009-08-26 Sebastian Huber <Sebastian.Huber@…> * … 4.104.115
(edit) @93f7ea15   08/19/09 16:40:03 Joel Sherrill 2009-08-19 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @717391f5   08/12/09 20:53:33 Joel Sherrill 2009-08-12 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @2b558ffd   08/05/09 19:13:27 Joel Sherrill 2009-08-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @61ae99b   08/05/09 16:43:33 Joel Sherrill 2009-08-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
