@a936aa49
06/06/13 13:41:00 |
Sebastian Huber |
scheduler: New simple SMP scheduler implementation
The new Simple SMP …
4.115
@6c2eedc
05/13/13 11:37:06 |
Sebastian Huber |
smp: Add maximum_processors field to config
Delete …
4.115
@b7cf1ff7
04/24/13 13:04:30 |
Sebastian Huber |
libcsupport: Delete libc_wrapup()
Add and use …
4.115
@5fa0e5c5
04/24/13 12:37:50 |
Sebastian Huber |
libcsupport: Rename open_dev_console()
Rename open_dev_console() to …
4.115
@a290fbe9
04/24/13 12:30:42 |
Sebastian Huber |
libcsupport: Make LibIO helper const
Add and use rtems_libio_helper …
4.115
@dc76d98
04/11/13 11:57:10 |
Sebastian Huber |
sapi: Fix unified workspace option
4.115
@6784547
04/07/13 22:28:48 |
Joel Sherrill |
confdefs.h: Only one clock or timer configuration parameter can be …
4.115
@92b33b8d
04/07/13 22:27:46 |
Joel Sherrill |
confdefs.h: Eliminate BSP_DEFAULT_UNIFIED_WORK_AREAS
This was not …
4.115
@7571a23
01/27/13 14:10:39 |
Sebastian Huber |
sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS
4.115
@68f36d14
01/27/13 13:02:50 |
Sebastian Huber |
score: Add and use rtems_assert_context
4.115
@b697bc6
01/10/13 21:06:42 |
Joel Sherrill |
cpukit: Use Consistent Beginning of Doxygen Group Notation
This is …
4.115
@a15eaaf
01/10/13 19:20:34 |
Joel Sherrill |
cpukit: Doxygen group fixes and many warnings addressed
The output of …
4.115
@e82fcb4
01/09/13 19:38:55 |
Sebastian Huber |
sapi: Documentation
4.115
@27f071cd
01/08/13 13:13:41 |
alexivanov97 |
sapi: Doxygen Clean Up Task #1
4.115
@f2f39b62
01/07/13 15:01:45 |
Sebastian Huber |
sapi: Add rtems_fatal_source_description()
4.115
@3cf4031
12/28/12 23:48:12 |
alexivanov97 |
Header File Doxygen Enhancement Task #1
4.115
@c5782a2
12/28/12 17:16:29 |
matkallada |
Header File Doxygen Enhancement Task #7
4.115
@9ab091e
12/28/12 16:35:32 |
matkallada |
Header File Doxygen Enhancement Task #2
4.115
@11109ea
12/18/12 20:46:38 |
alexivanov97 |
libfs: Doxygen Enhancement Task #2
4.115
@c2ae79e
12/12/12 20:57:49 |
matkallada |
misc: Header File Doxygen Enhancement Task #3
4.115
@e12f5acf
12/09/12 13:12:19 |
Sebastian Huber |
sapi: Fix previous commit
4.115
@50dd75a
12/09/12 13:06:56 |
Sebastian Huber |
sapi: Revert documentation change
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@f9340ed7
12/03/12 10:35:43 |
Sebastian Huber |
posix: Add and use <rtems/posix/psignalimpl.h>
This file contains the …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@e4b40531
11/14/12 11:37:24 |
Sebastian Huber |
sapi: Add rtems_fatal_source and rtems_fatal_code
4.115
@228df42
11/07/12 13:10:56 |
Sebastian Huber |
sapi: Add BSP_INITIAL_EXTENSION to confdefs.h
A BSP can supply an …
4.115
@466cf31d
11/07/12 12:59:19 |
Sebastian Huber |
score: Statically initialize user extensions
The initial extensions …
4.115
@9ed2bef
11/07/12 09:54:49 |
Sebastian Huber |
score: Add and use RTEMS_ARRAY_SIZE()
4.115
@2195fd27
11/07/12 10:23:03 |
Sebastian Huber |
sapi: Make initial user extensions table read-only
4.115
@b596754
11/07/12 09:19:46 |
Sebastian Huber |
sapi: Fix user scheduler configuration
The comment in confdefs.h …
4.115
@ae4f125e
11/06/12 12:54:05 |
Sebastian Huber |
sapi: Make Configuration read-only
The Configuration is now read-only …
4.115
@ef5f359
11/06/12 11:18:10 |
Sebastian Huber |
sapi: Delete duplicate declarations
4.115
@e39fa07
11/06/12 11:13:29 |
Sebastian Huber |
sapi: Delete unused macros
Delete rtems_configuration_get_table(), …
4.115
@c53b330c
11/06/12 10:34:10 |
Sebastian Huber |
sapi: Use rtems_configuration_get_maximum_drivers
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@fd71610
10/11/12 16:25:03 |
Ralf Corsepius |
Cleanup Krzysztof's copyright notices.
4.115
@a6eaa548
08/29/12 12:38:54 |
Krzysztof Miesowicz |
timespec helpers: Add wrappers with new test
4.115
@50fc8f6
06/13/12 07:44:32 |
Sebastian Huber |
sapi: Add nanoseconds_per_tick to configuration
Add …
4.115
@39ee704e
05/31/12 08:27:29 |
Sebastian Huber |
libblock: Add read-ahead task
Read-ahead requests were previously …
4.115
@b6911069
05/29/12 16:02:52 |
Sebastian Huber |
libblock: Add task stack size bdbuf configuration
The task stack size …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@5a4bb75
04/26/12 12:28:52 |
Sebastian Huber |
Filesystem: Remove per file descriptor semaphore
The per file …
4.115
@5c51ba1
04/16/12 08:38:31 |
Sebastian Huber |
rbheap: API changes and documentation
4.115
@8c6608bd
04/13/12 07:10:12 |
Sebastian Huber |
rbtree: PR2046: Replace rtems_rbtree_unique
4.115
@5eb434e
04/11/12 13:04:22 |
Sebastian Huber |
score: New macros and functions
New macros
o …
4.115
@e752630
04/10/12 09:19:39 |
Sebastian Huber |
rbheap: New files
In the Red-Black Tree Heap the administration data …
4.115
@e53aae2
03/26/12 20:42:38 |
Gedare Bloom |
confdefs: Add declaration for unlimited objects.
Adds to confdefs a …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@5693f2e
02/22/12 08:58:59 |
Ralf Corsepius |
2012-02-22 Ralf Corsépius <ralf.corsepius@…>
4.115
@9fa3cf0d
12/14/11 13:17:19 |
Sebastian Huber |
2011-12-14 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@3df4d74
12/13/11 14:37:03 |
Sebastian Huber |
2011-12-13 Sebastian Huber <sebastian.huber@…>
4.115
@517bf08
12/13/11 10:52:21 |
Sebastian Huber |
4.115
@b929b39e
12/05/11 13:51:06 |
Ralf Corsepius |
2011-12-05 Ralf Corsépius <ralf.corsepius@…>
4.115
@84e1742
11/18/11 20:04:49 |
Jennifer.Averett |
2011-11-18 Jennifer Averett <Jennifer.Averett@…>
4.115
@b4f635e
11/10/11 14:40:13 |
Sebastian Huber |
2011-11-10 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@48943dc
10/10/11 07:11:26 |
Ralf Corsepius |
2011-10-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@82db8e56
09/15/11 15:49:32 |
Joel Sherrill |
2011-09-15 Petr Benes <benesp16@…>
PR 1906/cpukit
4.115
@5472ad41
09/11/11 20:52:37 |
Joel Sherrill |
2011-09-11 Petr Benes <benesp16@…>
PR 1896/cpukit
4.115
@5817297
09/09/11 11:02:03 |
Sebastian Huber |
2011-09-09 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@ac9d2ecc
09/01/11 18:13:54 |
Joel Sherrill |
2011-09-01 Petr Benes <benesp16@…>
PR 1895/cpukit
4.115
@74f1c73e
08/21/11 20:07:11 |
Joel Sherrill |
2011-08-21 Petr Benes <benesp16@…>
PR 1886/cpukit
4.115
@542ae51
08/17/11 09:14:09 |
Sebastian Huber |
2011-08-17 Sebastian Huber <sebastian.huber@…>
4.115
@6de36ed
08/16/11 11:40:53 |
Sebastian Huber |
2011-08-16 Sebastian Huber <sebastian.huber@…>
4.115
@f58ef8ae
07/13/11 18:34:22 |
Joel Sherrill |
2011-07-13 Joel Sherrill <joel.sherrilL@…>
PR 1824/cpukit …
4.115
@21242c2
06/24/11 17:52:58 |
Joel Sherrill |
2011-06-24 Joel Sherrill <joel.sherrill@…>
4.115
@c1545f0
05/23/11 16:06:23 |
Joel Sherrill |
2011-05-23 Marta Rybczynska <marta.rybczynska@…>
PR …
4.115
@49f6309b
05/23/11 14:55:58 |
Joel Sherrill |
2011-05-23 Joel Sherrill <joel.sherrilL@…>
PR 1804/cpukit …
4.115
@ba7bc099
05/17/11 19:48:44 |
Joel Sherrill |
2011-05-17 Joel Sherrill <joel.sherrill@…>
PR 1789/cpukit …
4.115
@5af951f
05/13/11 13:49:16 |
Sebastian Huber |
2011-05-13 Sebastian Huber <sebastian.huber@…>
4.115
@e58f80cb
04/11/11 17:23:06 |
Joel Sherrill |
2011-04-11 Joel Sherrill <joel.sherrill@…>
4.115
@bd9baa81
04/04/11 18:44:16 |
Joel Sherrill |
2010-07-28 Gedare Bloom <giddyup44@…>
PR 1641/cpukit
4.115
@e79093a
04/04/11 16:40:00 |
Joel Sherrill |
2011-04-04 Joel Sherrill <joel.sherrilL@…>
PR 1773/cpukit …
4.115
@06dcaf0
03/16/11 20:05:06 |
Joel Sherrill |
2011-03-16 Jennifer Averett <jennifer.averett@…>
PR …
4.115
@0118ed6
03/16/11 16:32:22 |
Joel Sherrill |
PR …
4.115
@08d01a1
03/10/11 16:39:14 |
Sebastian Huber |
2011-03-10 Sebastian Huber <sebastian.huber@…>
4.115
@4c794c8
03/03/11 16:01:35 |
Joel Sherrill |
2011-03-03 Joel Sherrill <joel.sherrill@…>
4.115
@fd580d5
02/23/11 14:13:16 |
Ralf Corsepius |
2011-02-23 Ralf Corsépius <ralf.corsepius@…>
4.115
@22c28282
02/21/11 17:00:51 |
Joel Sherrill |
2011-02-21 Joel Sherrill <joel.sherrill@…>
4.115
@4be93c0
02/21/11 11:54:37 |
Sebastian Huber |
2011-02-21 Sebastian Huber <sebastian.huber@…>
4.115
@108c4b0
02/18/11 15:12:44 |
Joel Sherrill |
2011-02-18 Joel Sherrill <joel.sherrill@…>
4.115
@010192d
02/17/11 22:21:44 |
Joel Sherrill |
2011-02-17 Joel Sherrill <joel.sherrill@…>
4.115
@b2b56cb9
02/09/11 06:18:57 |
Ralf Corsepius |
2011-02-09 Ralf Corsépius <ralf.corsepius@…>
4.115
@5aecf664
12/17/10 14:56:06 |
Joel Sherrill |
2010-12-17 Joel Sherrill <joel.sherrill@…>
Jennifer …
4.115
@5c4e0c5
11/25/10 13:24:26 |
Sebastian Huber |
2010-11-25 Sebastian Huber <sebastian.huber@…>
4.115
@0faa9dad
11/24/10 15:51:28 |
Joel Sherrill |
2010-11-24 Gedare Bloom <giddyup44@…>
PR 1647/cpukit
4.115
@db5f134
11/16/10 19:14:10 |
Joel Sherrill |
2010-11-16 Joel Sherrill <joel.sherrill@…>
PR 1718/cpukit …
4.115
@69f2a07
08/24/10 14:29:55 |
Sebastian Huber |
2010-08-24 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@b3263f5
08/20/10 13:26:55 |
Ralf Corsepius |
2010-08-16 Ralf Corsépius <ralf.corsepius@…>
4.115
@58fa947
08/11/10 12:16:11 |
Sebastian Huber |
2010-09-11 Sebastian Huber <sebastian.huber@…>
4.115
@a46e6b6d
07/30/10 18:44:46 |
Joel Sherrill |
2010-07-30 Vinu Rajashekhar <vinutheraj@…>
4.115
@9bd0258d
07/26/10 22:20:43 |
Joel Sherrill |
2010-07-26 Joel Sherrill <joel.sherrill@…>
4.115
@80c1577
07/26/10 21:28:06 |
Joel Sherrill |
4.115
@39d3f8d
07/25/10 15:13:35 |
Joel Sherrill |
2010-07-25 Joel Sherrill <joel.sherrill@…>
4.115
@59673224
07/01/10 09:51:50 |
Sebastian Huber |
2010-07-01 Sebastian Huber <sebastian.huber@…>
4.115
@0de235f9
06/21/10 21:13:42 |
Joel Sherrill |
2010-06-21 Joel Sherrill <joel.sherrilL@…>
PR 1581/cpukit …
4.115
@46e69ff
06/20/10 19:41:33 |
Joel Sherrill |
2010-06-20 Joel Sherrill <joel.sherrill@…>
4.115
